Part Number: AM3351
Hi ,
Customer designed own board with NAND attached to AM3351 and is looking to ensure the GPMC configuration is optimal for the geometry and timing of the NAND part they picked. Will appreciate your guidance
thank you
Michael
Part Number: AM3351
Hi ,
thank you
Michael
U-Boot 2023.04-gd74d0993e2 (Oct 18 2023 - 17:49:46 +0000)
CPU : AM335X-GP rev 2.1
DRAM: 128 MiB
Core: 150 devices, 12 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing every 1000ms (60s timeout)
NAND: 256 MiB
Loading Environment from NAND... OK
Loading Environment from nowhere... OK
<ethaddr> not set. Validating first E-fuse MAC
Net: eth2: usb_ether
Hit any key to stop autoboot: 0
=> nand info
Device 0: nand0, sector size 128 KiB
Page size 2048 b
OOB size 128 b
Erase size 131072 b
ecc strength 16 bits
ecc step size 512 b
subpagesize 512 b
options 0x4000400c
bbt options 0x00008000
=> mtdparts
device nand0 <nand.0>, # parts = 14
#: name size offset mask_flags
0: SPL 0x00020000 0x00000000 0
1: SPL.backup1 0x00020000 0x00020000 0
2: SPL.backup2 0x00020000 0x00040000 0
3: SPL.backup3 0x00020000 0x00060000 0
4: u-boot-spl-os 0x00040000 0x00080000 0
5: u-boot 0x00100000 0x000c0000 0
6: u-boot-env 0x00020000 0x001c0000 0
7: u-boot-env.backup1 0x00020000 0x001e0000 0
8: reserved1 0x00200000 0x00200000 0
9: kernel_a 0x00c00000 0x00400000 0
10: rootfs_a 0x04a00000 0x01000000 0
11: kernel_b 0x00c00000 0x05a00000 0
12: rootfs_b 0x04a00000 0x06600000 0
13: userdata 0x05000000 0x0b000000 0
active partition: nand0,0 - (SPL) 0x00020000 @ 0x00000000
defaults:
mtdids : nand0=nand.0
mtdparts: mtdparts=nand.0:128k(SPL),128k(SPL.backup1),128k(SPL.backup2),128k(SPL.backup3),256k(u-boot-spl-os),1m(u-boot),128k(u-boot-env),128k(u-boot-env.backup1),2m(reserved1),12m(kernel_a),74m(rootfs_a),12m(kernel_b),74m(rootfs_b),-(userdata)
=> time nand read ${loadaddr} kernel_a
NAND read: device 0 offset 0x400000, size 0xc00000
12582912 bytes read: OK
time: 6.678 seconds
Hello Michael,
Thanks for running the test on the customer board.
Let's apply the attached u-boot "testing patch", and share the result from running the same cmds @u-boot.
-Hong
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_GPMC_2D00_NAND_2D00_register_2D00_timing_2D00_in_2D00_SPL_2D00_for_2D00_the_2D00_NAND_2D00_on_2D00_AM3.patch
Hi Hong,
Here is the new time measurement.
=> nand info
Page size 2048 b
OOB size 128 b
Erase size 131072 b
ecc step size 512 b
subpagesize 512 b
options 0x4000400c
time: 2.577 seconds
thanks
Michael
Hello Michael,
It looks like NAND read performance is improved x2.5.
For your reference, I'm attaching NAND read performance test @u-boot on AM335x EVM (1GHz Part)
- am3_9.1.0.1_gpmc_rd.log: with the current GPMC timing parameter configuration
- am3_9.1.0.1_patch_gpmc_rd.log: with the updated GPMC timing parameter configuration
=> NAND read time is improved x4 on reading 8Mbytes @u-boot with the updated GPMC timing parameter
1.85Mbyte/s with the current GPMC parameter timing parameter
7.7Mbyte/s with the updated GPMC parameter timing parameter
-Hong
Model: TI AM335x EVM
DRAM: 1 GiB
Core: 156 devices, 17 uclasses, devicetree: separate
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
Net: eth2: ethernet@4a100000, eth3: usb_ether
Hit any key to stop autoboot: 2 0
=> nand info
Page size 2048 b
OOB size 64 b
Erase size 131072 b
ecc strength 8 bits
ecc step size 512 b
subpagesize 512 b
options 0x0000400c
=> mtdparts
device nand0 <nand.0>, # parts = 10
0: NAND.SPL 0x00020000 0x00000000 0
1: NAND.SPL.backup1 0x00020000 0x00020000 0
2: NAND.SPL.backup2 0x00020000 0x00040000 0
3: NAND.SPL.backup3 0x00020000 0x00060000 0
4: NAND.u-boot-spl-os 0x00040000 0x00080000 0
5: NAND.u-boot 0x00100000 0x000c0000 0
6: NAND.u-boot-env 0x00020000 0x001c0000 0
7: NAND.u-boot-env.backup10x00020000 0x001e0000 0
8: NAND.kernel 0x00800000 0x00200000 0
9: NAND.file-system 0x0f600000 0x00a00000 0
active partition: nand0,0 - (NAND.SPL) 0x00020000 @ 0x00000000
defaults:
mtdparts: mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)
=> md.l 0x50000060 0x7
50000060: 00000800 001e1e00 001e1e00 16051807 ................
50000070: 00151e1e 16000f80 00000f48 ........H...
=> time nand read ${loadaddr} NAND.kernel
NAND read: device 0 offset 0x200000, size 0x800000
8388608 bytes read: OK
time: 4.332 seconds
U-Boot 2023.04-00001-ga6b09c3a4c-dirty (Feb 07 2024 - 10:30:04 -0600)
DRAM: 1 GiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
=> nand info
Page size 2048 b
OOB size 64 b
Erase size 131072 b
ecc strength 8 bits
ecc step size 512 b
subpagesize 512 b
options 0x0000400c
=> mtdparts
defaults:
50000060: 00000800 00050500 00050401 04000600 ................
50000070: 00070909 84000000 00000f48 ........H...
time: 1.038 seconds
