I installed ti-processor-sdk-linux-am335x-evm-09.01.00.001-Linux-x86-Install.bin at my ubuntu 22.04 (LTS) 64bit virtual machine (VBOX)
see below
howdoudo@howdoudo-VirtualBox:plugin$ uname -a
Linux howdoudo-VirtualBox 6.5.0-17-generic #17~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Jan 16 14:32:32 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
After install SDK and Prerequisites,
I run "source linux-devkit/environment-setup"
then run make
While building kernel image, i got an error message like below
make[1]: Entering directory '/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-linux-kernel-6.1.46+gitAUTOINC+1d4b5da681-g1d4b5da681'
SYNC include/config/auto.conf.cmd
HOSTCXX scripts/gcc-plugins/arm_ssp_per_task_plugin.so
In file included from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/system.h:531,
from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/gcc-plugin.h:28,
from scripts/gcc-plugins/gcc-common.h:7,
from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3:
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/linux-devkit/sysroots/armv7at2hf-neon-oe-linux-gnueabi/usr/include/stdint.h:109: warning: "__INT64_C" redefined
109 | # define __INT64_C(c) c ## LL
<built-in>: note: this is the location of the previous definition
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/linux-devkit/sysroots/armv7at2hf-neon-oe-linux-gnueabi/usr/include/stdint.h:110: warning: "__UINT64_C" redefined
110 | # define __UINT64_C(c) c ## ULL
In file included from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/system.h:535,
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/linux-devkit/sysroots/armv7at2hf-neon-oe-linux-gnueabi/usr/include/inttypes.h:290:17: warning: declaration of ‘intmax_t imaxabs(intmax_t ’ conflicts with built-in declaration ‘long int imaxabs(long int)’ [-Wbuiltin-declaration-mismatch]
290 | extern intmax_t imaxabs (intmax_t __n) __THROW __attribute__ ((__const__));
In file included from scripts/gcc-plugins/gcc-common.h:18,
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/tree.h: In function ‘hashval_t struct_ptr_hash(const void*)’:
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/tree.h:5184:10: error: cast from ‘const void*’ to ‘intptr_t’ {aka ‘int’} loses precision [-fpermissive]
5184 | return (intptr_t)*x >> 4;
In file included from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/tree-pretty-print.h:25,
from scripts/gcc-plugins/gcc-common.h:52,
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/pretty-print.h: In function ‘void pp_wide_integer(pretty_printer*, long int)’:
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hwint.h:110:33: warning: format ‘%lld’ expects argument of type ‘long long int’, but argument 3 has type ‘long int’ [-Wformat=]
110 | #define HOST_WIDE_INT_PRINT_DEC "%" PRId64
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/pretty-print.h:329:46: note: in definition of macro ‘pp_scalar’
329 | sprintf (pp_buffer (PP)->digit_buffer, FORMAT, SCALAR); \
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/pretty-print.h:430:18: note: in expansion of macro ‘HOST_WIDE_INT_PRINT_DEC’
430 | pp_scalar (pp, HOST_WIDE_INT_PRINT_DEC, i);
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/linux-devkit/sysroots/armv7at2hf-neon-oe-linux-gnueabi/usr/include/inttypes.h:57:41: note: format string is defined here
57 | # define PRId64 __PRI64_PREFIX "d"
In file included from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-table.h:252,
from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/coretypes.h:482,
from /home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/gcc-plugin.h:29,
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-traits.h: In instantiation of ‘static hashval_t pointer_hash<Type>::hash(Type* const&) [with Type = const void; hashval_t = unsigned int; pointer_hash<Type>::value_type = const void*]’:
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-map-traits.h:50:18: required from ‘static hashval_t simple_hashmap_traits<H, Value>::hash(const key_type&) [with H = default_hash_traits<const void*>; Value = mem_usage_pair<mem_usage>; hashval_t = unsigned int; simple_hashmap_traits<H, Value>::key_type = const void*]’
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-map.h:185:63: required from ‘Value* hash_map< <template-parameter-1-1>, <template-parameter-1-2>, <template-parameter-1-3> >::get(const Key&) [with KeyId = const void*; Value = mem_usage_pair<mem_usage>; Traits = simple_hashmap_traits<default_hash_traits<const void*>, mem_usage_pair<mem_usage> >; hash_map< <template-parameter-1-1>, <template-parameter-1-2>, <template-parameter-1-3> >::Key = const void*]’
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/mem-stats.h:514:48: required from ‘T* mem_alloc_description<T>::release_instance_overhead(void*, size_t, bool) [with T = mem_usage; size_t = long unsigned int]’
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-table.h:689:22: required from ‘hash_table<Descriptor, Lazy, Allocator>::~hash_table() [with Descriptor = hash_map<int_hash<short unsigned int, 0>, short unsigned int>::hash_entry; bool Lazy = false; Allocator = xcallocator]’
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-map.h:39:19: required from here
/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/hash-traits.h:166:23: error: cast from ‘pointer_hash<const void>::value_type’ {aka ‘const void*’} to ‘intptr_t’ {aka ‘int’} loses precision [-fpermissive]
166 | return (hashval_t) ((intptr_t)candidate >> 3);
make[3]: *** [scripts/gcc-plugins/Makefile:54: scripts/gcc-plugins/arm_ssp_per_task_plugin.so] Error 1
make[2]: *** [scripts/Makefile.build:502: scripts/gcc-plugins] Error 2
make[1]: *** [Makefile:1273: scripts] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-linux-kernel-6.1.46+gitAUTOINC+1d4b5da681-g1d4b5da681'
make: *** [makerules/Makefile_linux:8: linux] Error 2
It seems intptr_t is not working in my ubuntu.
I attached my environment-setup
Please let me know how to fix above error
SDK_PATH="/home/howdoudo/ti-processor-sdk-linux-am335x-evm-09.01.00.001/linux-devkit" if [ -z "$ZSH_NAME" ] && [ "x$0" = "x./environment-setup" ]; then echo "Error: This script needs to be sourced. Please run as \". ./environment-setup\"" exit 1 else if [ -n "$BASH_SOURCE" ]; then SDK_PATH="`dirname $BASH_SOURCE`" fi SDK_PATH=`readlink -f "$SDK_PATH"` export SDK_PATH fi export SDK_SYS=x86_64-arago-linux export REAL_MULTIMACH_TARGET_SYS=armv7at2hf-neon-oe-linux-gnueabi export TARGET_SYS=arm-oe-linux-gnueabi export TARGET_PREFIX=$TARGET_SYS- export SDK_PATH_NATIVE=$SDK_PATH/sysroots/$SDK_SYS export SDK_PATH_TARGET=$SDK_PATH/sysroots/$REAL_MULTIMACH_TARGET_SYS export PATH=$SDK_PATH_NATIVE/usr/bin:$SDK_PATH_NATIVE/usr/bin/arm-oe-linux-gnueabi:$PATH export CPATH=$SDK_PATH_TARGET/usr/include:$CPATH export PKG_CONFIG_SYSROOT_DIR=$SDK_PATH_TARGET export PKG_CONFIG_PATH=$SDK_PATH_TARGET/usr/lib/pkgconfig:$SDK_PATH_TARGET/usr/share/pkgconfig export PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 export CONFIG_SITE=$SDK_PATH/site-config-$REAL_MULTIMACH_TARGET_SYS export CC="${TARGET_PREFIX}gcc --sysroot=$SDK_PATH_TARGET" export CXX="${TARGET_PREFIX}g++ --sysroot=$SDK_PATH_TARGET" export GDB=${TARGET_PREFIX}gdb export CPP="${TARGET_PREFIX}gcc -E --sysroot=$SDK_PATH_TARGET" export LD="${TARGET_PREFIX}ld --sysroot=$SDK_PATH_TARGET" export NM=${TARGET_PREFIX}nm export AS=${TARGET_PREFIX}as export AR=${TARGET_PREFIX}ar export RANLIB=${TARGET_PREFIX}ranlib export OBJCOPY=${TARGET_PREFIX}objcopy export OBJDUMP=${TARGET_PREFIX}objdump export STRIP=${TARGET_PREFIX}strip export CONFIGURE_FLAGS="--target=arm-oe-linux-gnueabi --host=arm-oe-linux-gnueabi --build=x86_64-linux --with-libtool-sysroot=$SDK_PATH_TARGET" export CPPFLAGS=" -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=$SDK_PATH_TARGET" export CFLAGS="$CPPFLAGS" export CXXFLAGS="$CPPFLAGS" export LDFLAGS=" --sysroot=$SDK_PATH_TARGET" export OECORE_NATIVE_SYSROOT=$SDK_PATH_NATIVE export OECORE_TARGET_SYSROOT=$SDK_PATH_TARGET export SDKTARGETSYSROOT=$SDK_PATH_TARGET export OECORE_ACLOCAL_OPTS="-I $SDK_PATH_NATIVE/usr/share/aclocal" export OECORE_DISTRO_VERSION="2023.04" export OECORE_SDK_VERSION="2023.04" export OECORE_BASELIB="lib" export OECORE_TARGET_ARCH="arm" export OECORE_TARGET_OS="linux-gnueabi" # Append environment subscripts if [ -d "$OECORE_TARGET_SYSROOT/environment-setup.d" ]; then for envfile in $OECORE_TARGET_SYSROOT/environment-setup.d/*.sh; do . $envfile done fi if [ -d "$OECORE_NATIVE_SYSROOT/environment-setup.d" ]; then for envfile in $OECORE_NATIVE_SYSROOT/environment-setup.d/*.sh; do . $envfile done fi export PS1="\[\e[32;1m\][linux-devkit]\[\e[0m\]:\w> " export PATH=$SDK_PATH_NATIVE/usr/bin/${QT_DIR_NAME}:$PATH export OE_QMAKE_CFLAGS="$CFLAGS" export OE_QMAKE_CXXFLAGS="$CXXFLAGS" export OE_QMAKE_LDFLAGS="$LDFLAGS" export OE_QMAKE_CC="$CC" export OE_QMAKE_CXX="$CXX" export OE_QMAKE_LINK="$CXX" export OE_QMAKE_AR="$AR" export OE_QMAKE_PREFIX_QT=/usr export OE_QMAKE_LIBDIR_QT=/usr/lib export OE_QMAKE_INCDIR_QT=/usr/include/${QT_DIR_NAME} export OE_QMAKE_HOST_BINDIR_QT=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX} export OE_QMAKE_MOC=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}moc${QT_BIN_SUFFIX} export OE_QMAKE_UIC=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}uic${QT_BIN_SUFFIX} export OE_QMAKE_UIC3=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}uic3${QT_BIN_SUFFIX} export OE_QMAKE_RCC=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}rcc${QT_BIN_SUFFIX} export OE_QMAKE_QDBUSCPP2XML=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}qdbuscpp2xml${QT_BIN_SUFFIX} export OE_QMAKE_QDBUSXML2CPP=$SDK_PATH_NATIVE/usr/bin/${QT_BIN_PREFIX}qdbusxml2cpp${QT_BIN_SUFFIX} export OE_QMAKE_QT_CONFIG=$SDK_PATH_TARGET/usr/lib/${QT_DIR_NAME}/mkspecs/qconfig.pri export OE_QMAKE_STRIP="echo" export QMAKESPEC=$SDK_PATH_TARGET/usr/lib/${QT_DIR_NAME}/mkspecs/linux-oe-g++ export QMAKE_DEFAULT_LIBDIRS=${QT_QMAKE_LIBDIR_QT} export QMAKE_DEFAULT_INCDIRS=${QT_QMAKE_INCDIR_QT}
