Hi Suren,
I'm running into the same problem again, I can't see any difference in the different compression levels.
I use the following script to build my pipeline:
#!/bin/bash INPUT="frame.jpg" OUTPUT="output" HEVC_PROFILE="main" HEVC_LEVEL="1" VIDEO_BITRATE=0 # VIDEO_BITRATE_MODE: 0 = on, 1 = off VIDEO_BITRATE_MODE=0 FRAME_RATE_CONTROL=0 TEMP=$(getopt -o 'p:l:b:i:o:h' --long 'profile:,level:,bitrate:,bitratemode:,perframe,input:,output:,help' -n '$0' -- "$@") if [ $? -ne 0 ]; then echo 'Terminating...' >&2 exit 1 fi eval set -- "$TEMP" unset TEMP while true; do case "$1" in '-h'|'--help') echo "$0 - H.265 compress a JPEG file into a one second stream" echo "Parameters:" echo " -p main|main-still-picture|main-10 (HEVC Profile)" echo " -l 1|2|2.1|3|3.1|4|4.1|5|5.1 (HEVC Level)" echo " -b 0..700000000 (Video Bitrate)" echo " -i input.jpg (Input JPEG file)" echo " -o output (Base name of output files - gets converted to output%03d.jpg)" echo " -h This help" exit 0 shift continue ;; '-p'|'--profile') case "$2" in 'main'|'Main'|'0') HEVC_PROFILE="main" ;; 'main-still-picture'|'1') HEVC_PROFILE="main-still-picture" ;; 'main-10'|'2') HEVC_PROFILE="main-10" ;; *) HEVC_PROFILE="main" ;; esac echo "HEVC Profile: '$HEVC_PROFILE'" shift 2 continue ;; '-l'|'--level') case "$2" in '1'|'2'|'2.1'|'3'|'3.1'|'4'|'4.1'|'5'|'5.1') HEVC_LEVEL="$2" ;; *) HEVC_LEVEL="1" ;; esac echo "HEVC Level: '$HEVC_LEVEL'" shift 2 continue ;; '-b'|'--bitrate') echo "Video Bitrate: '$2'" VIDEO_BITRATE=$2 shift 2 continue ;; '-i'|'--input') echo "Input: '$2'" INPUT=$2 shift 2 continue ;; '-o'|'--output') echo "Output: '$2'" OUTPUT=$2 shift 2 continue ;; '--bitratemode') echo "Video Bitrate Mode: $2" VIDEO_BITRATE_MODE=$2 shift 2 continue ;; '--perframe') echo "Frame Rate per Frame" FRAME_RATE_CONTROL=1 shift continue ;; '--') shift break ;; *) echo 'Internal error!' >&2 exit 1 ;; esac done #if [ $VIDEO_BITRATE -gt 0 ]; then # FRAME_RATE_CONTROL=1 #fi echo -n "Compressing $INPUT to $OUTPUT:" gst-launch-1.0 -q multifilesrc location="$INPUT" start-index=0 stop-index=29 caps="image/jpeg,framerate=30/1" loop=0 \ ! jpegparse \ ! jpegdec \ ! 'video/x-raw,format=I420' \ ! videoconvert \ ! v4l2h265enc extra-controls="controls, prepend_sps_and_pps_to_idr=1, frame_level_rate_control_enable=${FRAME_RATE_CONTROL}, video_gop_size=5, video_bitrate_mode=${VIDEO_BITRATE_MODE}, video_bitrate=$VIDEO_BITRATE" \ ! "video/x-h265, profile=(string)${HEVC_PROFILE}, level=(string)${HEVC_LEVEL}" \ ! tee name=tee0 \ ! h265parse \ ! v4l2h265dec \ ! jpegenc \ ! multifilesink location="${OUTPUT}-p${HEVC_PROFILE}l${HEVC_LEVEL}b${VIDEO_BITRATE}m${VIDEO_BITRATE_MODE}f${FRAME_RATE_CONTROL}.%03d.jpg" \ tee0. \ ! filesink location="${OUTPUT}-p${HEVC_PROFILE}l${HEVC_LEVEL}b${VIDEO_BITRATE}m${VIDEO_BITRATE_MODE}f${FRAME_RATE_CONTROL}.h265" echo "Done."
I have some input files at google drive, this includes the script above.
When I call the script multiple times with different parameters:
./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 5.1 -b 6000 --bitratemode 1 ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 5.1 -b 6000 --bitratemode 1 --perframe ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 5.1 -b 6000 --bitratemode 0 ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 5.1 -b 6000 --bitratemode 0 --perframe ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 3 -b 1000 --bitratemode 1 ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 3 -b 1000 --bitratemode 1 --perframe ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 3 -b 1000 --bitratemode 0 --perframe ./h265-compress -i "Frame %d.jpg" -o onsemi2 -p main -l 3 -b 1000 --bitratemode 0
I get the same output:
-rw-r--r-- 1 root root 3112480 Feb 13 06:50 onsemi2-pmainl3b1000m0f0.h265 -rw-r--r-- 1 root root 163960 Feb 13 06:48 onsemi2-pmainl3b1000m0f1.h265 -rw-r--r-- 1 root root 3112480 Feb 13 06:44 onsemi2-pmainl3b1000m1f0.h265 -rw-r--r-- 1 root root 163960 Feb 13 06:46 onsemi2-pmainl3b1000m1f1.h265 -rw-r--r-- 1 root root 3112480 Feb 13 06:55 onsemi2-pmainl5.1b6000m0f0.h265 -rw-r--r-- 1 root root 163960 Feb 13 07:04 onsemi2-pmainl5.1b6000m0f1.h265 -rw-r--r-- 1 root root 3112480 Feb 13 06:40 onsemi2-pmainl5.1b6000m1f0.h265 -rw-r--r-- 1 root root 163960 Feb 13 06:42 onsemi2-pmainl5.1b6000m1f1.h265
The only setting that seems to make a difference is the frame_level_rate_control_enable setting (f0 and f1 in the filenames).
My questions:
* How do I set things up in such a way that the bitrate is taken into account?
* What does the hevc_profile and hevc_level do exactly?
The ultimate goal is to get a stream with a bitrate of 6 Mbps, with variable bitrate enabled.
Bas Vermeulen
