Part Number: TDA4VM
Hi Team,
I'm new to TI.
I'm using SDK v 08_02_00_05 (Linux+RTOS).
I'm trying to run a application which loads and display a bmp image using OpenGLES. I'm running application at PC level.
The code is attached below.
gcc m_own_trial.c -o my_own_trial -lwayland-client -lwayland-egl -lEGL -lGLESv2 -lglut -lGL -lGLU
#define EGL_NO_X11
#include <EGL/egl.h>
#include <GLES2/gl2.h>
#include <assert.h>
#include <string.h>
#include <wayland-client.h>
#include <wayland-egl.h>
#include <EGL/eglext.h>
#include <GL/gl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
struct wl_display *display = NULL;
struct wl_compositor *compositor = NULL;
struct wl_surface *surface = NULL;
struct wl_shell *shell = NULL;
struct wl_shell_surface *shell_surface = NULL;
struct wl_egl_window *egl_window = NULL;
EGLDisplay egl_display;
EGLContext egl_context;
EGLSurface egl_surface;
GLuint texture;
struct WaylandGlobals {
struct wl_compositor* compositor;
struct wl_shell* shell;
* Registry callbacks
static void registry_global(void* data, struct wl_registry* registry, uint32_t id, const char* interface, uint32_t version)
struct WaylandGlobals* globals = (struct WaylandGlobals *)data;
if (strcmp(interface, "wl_compositor") == 0) {
globals->compositor = wl_registry_bind(registry, id, &wl_compositor_interface, 1);
} else if (strcmp(interface, "wl_shell") == 0) {
globals->shell = wl_registry_bind(registry, id, &wl_shell_interface, 1);
static const struct wl_registry_listener registry_listener = { registry_global, NULL };
* Connect to the Wayland display and return the display and the surface
* output wlDisplay
* output wlSurface
static void initWaylandDisplay(struct wl_display** wlDisplay, struct wl_surface** wlSurface)
struct WaylandGlobals globals = {0};
*wlDisplay = wl_display_connect(NULL);
assert(*wlDisplay != NULL);
struct wl_registry* registry = wl_display_get_registry(*wlDisplay);
wl_registry_add_listener(registry, ®istry_listener, (void *) &globals);
wl_display_dispatch(*wlDisplay);
wl_display_roundtrip(*wlDisplay);
assert(globals.compositor);
assert(globals.shell);
*wlSurface = wl_compositor_create_surface(globals.compositor);
assert(*wlSurface != NULL);
struct wl_shell_surface* shellSurface = wl_shell_get_shell_surface(globals.shell, *wlSurface);
wl_shell_surface_set_toplevel(shellSurface);
* Configure EGL and return necessary resources
* input nativeDisplay
* input nativeWindow
* output eglDisplay
* output eglSurface
static void initEGLDisplay(EGLNativeDisplayType nativeDisplay, EGLNativeWindowType nativeWindow, EGLDisplay* eglDisplay, EGLSurface* eglSurface)
EGLint number_of_config;
EGLint config_attribs[] = {
EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8,
EGL_RENDERABLE_TYPE, EGL_OPENGL_ES2_BIT,
EGL_NONE
static const EGLint context_attribs[] = {
EGL_CONTEXT_CLIENT_VERSION, 2,
EGL_NONE
*eglDisplay = eglGetDisplay(nativeDisplay);
assert(*eglDisplay != EGL_NO_DISPLAY);
EGLBoolean initialized = eglInitialize(*eglDisplay, NULL, NULL);
assert(initialized == EGL_TRUE);
EGLConfig configs[1];
eglChooseConfig(*eglDisplay, config_attribs, configs, 1, &number_of_config);
assert(number_of_config);
EGLContext eglContext = eglCreateContext(*eglDisplay, configs[0], EGL_NO_CONTEXT, context_attribs);
*eglSurface = eglCreateWindowSurface(*eglDisplay, configs[0], nativeWindow, NULL);
assert(*eglSurface != EGL_NO_SURFACE);
EGLBoolean makeCurrent = eglMakeCurrent(*eglDisplay, *eglSurface, *eglSurface, eglContext);
assert(makeCurrent == EGL_TRUE);
* Connect Wayland and make EGL
* input width
* input height
* output wlDisplay
* output eglDisplay
* output eglSurface
static void initWindow(GLint width, GLint height, struct wl_display** wlDisplay, EGLDisplay* eglDisplay, EGLSurface* eglSurface)
struct wl_surface* wlSurface;
initWaylandDisplay(wlDisplay, &wlSurface);
struct wl_egl_window* wlEglWindow = wl_egl_window_create(wlSurface, width, height);
assert(wlEglWindow != NULL);
initEGLDisplay((EGLNativeDisplayType) *wlDisplay, (EGLNativeWindowType) wlEglWindow, eglDisplay, eglSurface);
* Return the loaded and compiled shader
GLuint LoadShader(GLenum type, const char* shaderSrc)
GLuint shader = glCreateShader(type);
assert(shader);
glShaderSource(shader, 1, &shaderSrc, NULL);
glCompileShader(shader);
GLint compiled;
glGetShaderiv(shader, GL_COMPILE_STATUS, &compiled);
assert(compiled);
return shader;
* Initialize the shaders and return the program object
GLuint initProgramObject()
char vShaderStr[] = "#version 300 es \n"
"layout(location = 0) in vec4 vPosition; \n"
"void main() \n"
"{ \n"
" gl_Position = vPosition; \n"
"} \n";
char fShaderStr[] = "#version 300 es \n"
"precision mediump float; \n"
"out vec4 fragColor; \n"
"void main() \n"
"{ \n"
" fragColor = vec4 ( 1.0, 0.0, 0.0, 1.0 ); \n"
"} \n";
GLuint vertexShader = LoadShader(GL_VERTEX_SHADER, vShaderStr);
GLuint fragmentShader = LoadShader(GL_FRAGMENT_SHADER, fShaderStr);
GLuint programObject = glCreateProgram();
assert(programObject);
glAttachShader(programObject, vertexShader);
glAttachShader(programObject, fragmentShader);
glLinkProgram(programObject);
GLint linked;
glGetProgramiv(programObject, GL_LINK_STATUS, &linked);
assert(linked);
return programObject;
void load_texture(const char *filename) {
FILE *file = fopen(filename, "rb");
if (!file) {
fprintf(stderr, "Failed to open file: %s\n", filename);
exit(1);
unsigned char header[54];
fread(header, sizeof(unsigned char), 54, file);
int width = *(int*)&header[18];
int height = *(int*)&header[22];
int size = 3 * width * height;
unsigned char *data = (unsigned char *)malloc(size);
fread(data, sizeof(unsigned char), size, file);
fclose(file);
glBindTexture(GL_TEXTURE_2D, texture);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB, width, height, 0, GL_BGR, GL_UNSIGNED_BYTE, data);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
//fclose(file);
free(data);
void draw() {
glClear(GL_COLOR_BUFFER_BIT);
glViewport(0, 0, 768, 512);
glEnableClientState(GL_TEXTURE_COORD_ARRAY);
/* glBegin(GL_QUADS);
glTexCoord2f(0, 0); glVertex2f(-1, -1);
glTexCoord2f(1, 0); glVertex2f(1, -1);
glTexCoord2f(1, 1); glVertex2f(1, 1);
glTexCoord2f(0, 1); glVertex2f(-1, 1);
glEnd();*/
// Specify the texture coordinates and vertices for a quad
GLfloat texCoords[] = {0.0f, 0.0f,
1.0f, 0.0f,
1.0f, 1.0f,
0.0f, 1.0f};
GLfloat vertices[] = {-1.0f, -1.0f,
1.0f, -1.0f,
1.0f, 1.0f,
-1.0f, 1.0f};
// Draw the quad
glTexCoordPointer(2, GL_FLOAT, 0, texCoords);
glVertexPointer(2, GL_FLOAT, 0, vertices);
glDrawArrays(GL_QUADS, 0, 4);
// Disable texture coordinates
glDisableClientState(GL_TEXTURE_COORD_ARRAY);
// Swap the buffers
eglSwapBuffers(egl_display, egl_surface);
//glFlush();
* Draw a triangle
/*void draw(GLuint programObject, GLint width, GLint height)
GLfloat vVertices[] = { -0.5f, -0.5f, 0.0f,
0.0f, 0.5f, 0.0f,
0.5f, -0.5f, 0.0f };
glViewport(0, 0, width, height);
glClearColor(1.0f, 1.0f, 1.0f, 0.0f);
glUseProgram(programObject);
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, 0, vVertices);
glEnableVertexAttribArray(0);
glDrawArrays(GL_TRIANGLES, 0, 3);
int main(int argc, char** argv)
int width = 768;
int height = 512;
if (argc < 2) {
fprintf(stderr, "Usage: %s <image_file>\n", argv[0]);
return 1;
struct wl_display* wlDisplay;
EGLDisplay eglDisplay;
EGLSurface eglSurface;
printf("1\n");
initWindow(width, height, &wlDisplay, &eglDisplay, &eglSurface);
printf("2\n");
GLuint programObject = initProgramObject();
printf("3\n");
printf("4\n");
load_texture(argv[1]);
printf("5\n");
//draw();
//draw(programObject, width, height);
eglSwapBuffers(eglDisplay, eglSurface);
printf("6\n");
printf("display:%d\n",wl_display_dispatch(wlDisplay));
while (wl_display_dispatch(wlDisplay) != -1) {
draw();
printf("7\n");
glDeleteProgram(programObject);
printf("8\n");
wl_display_disconnect(wlDisplay);
return 0;
While running the code, it is working fine without errors but no output on display. please find the logs and output image attached below for reference.
prakash@kli:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/vision_apps/apps/dl_demos/OpenGL_Task/Using_GLUT$ gcc m_own_trial.c -o my_own_trial -lwayland-client -lwayland-egl -lEGL -lGLESv2 -lglut -lGL -lGLU prakash@kli:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/vision_apps/apps/dl_demos/OpenGL_Task/Using_GLUT$ ./my_own_trial image.bmp 1 2 3 4 5 6 display:3 7 7 Killed prakash@kli:~/ti-processor-sdk-rtos-j721e-evm-08_02_00_05/vision_apps/apps/dl_demos/OpenGL_Task/Using_GLUT$
As shown in image no output is able to visualise on display.
Kindly let me know how to resolve this, I have all dependencies installed in system and running application using wayland support.
Chaitanya Prakash Uppala
