Part Number: TDA4VL-Q1
Do you have documentation to adapt QNX / RTOS image and SDK from the evalboard to a custom board?
Are you first trying with RTOS or qnx? I can check accordingly. Linux we gave a board brings up guide.
Keerthy
For the most part the TI SDK QNX release is board agnostic, and no/or minimal modifications would be required when moving from TI EVM to a custom board. Most of the board level customizations to be done would be within the QNX BSP for the TI EVM.
The QNX BSP for the TI EVM is provided by QNX/Blackberry, for which QNX/Blackberry offer services for customization. The TI EVM BSP source code as you are likely aware available on QNX Software Centre can be customized as needed.
If the customization is to be done without QNX/Blackberry, some basic high level steps to follow:
For the RTOS side, will loop in a different TI'er to comment.
kb
