TMS320C5505: TMS320C5505 USB Stick
Part Number: TMS320C5505
How to generate 1mv sine wave on TMS320C5505 USB Stick.
What changes should i do in the files below to generate 1mv sine wave signal.
/* FILENAME        */
/*   sinewaves.c                                                             */
/* DESCRIPTION                                                               */
/*   Sinewave generation for the TMS320C5505 USB Stick.                      */
/*   Generates two sinewaves of adjustable frequency using sine() function   */
/*   in 55xdsph.lib                                                          */
/*   The frequency of range of the sine wave is 10 Hz to 8000 Hz.            */
/* REVISION        */
/*   Revision: 1.00                                                          */
/*   Author  : Richard Sikora                                                */
/* HISTORY        */
/*   Revision 1.00                                                           */
/*   20th December 2009. Created by Richard Sikora from TMS320C5510 code.    */
 * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "tms320.h"
#include "dsplib.h"
/* generate_sinewave_1()                                                     */
/* Generate a sinewave. Based on sampling rate of 48000 Hz.                  */
/* PARAMETER 1: The frequency of the sinewave between 10 Hz and 16000 Hz.    */
/* PARAMETER 2: The maximum amplitude of the sinewave between 1 to 32767.    */
signed int generate_sinewave_1( signed short int frequency,
                                signed short int amplitude)
 short int sinusoid;
 signed long result;
 static short int count = 0;
 /* Multiply frequency by scaling factor of 32767 / 48000 */
 result = ( (long)frequency * 22368 ) >> 14 ;
 if ( result > 32767)
     result = 32767; /* Maximum value for highest frequency */
 else if ( 0 == result)
     result = 1;     /* Minimum value for lowest fequency */
 else if ( result < -32767)
     result = -32767;
 count += (short int) result;
 /* Obtain sine of input */
 sine ( &count, &sinusoid, 1);
 if ( amplitude > 32767 )
     amplitude = 32767; /* Range limit amplitude */
 /* Scale sine wave to have maximum value set by amplitude */
 result =  ( (long) sinusoid * amplitude ) >> 15;
 return ( (signed int ) result );
/* generate_sinewave_2()                                                     */
/* Generate a second sinewave.                                               */
signed int generate_sinewave_2( signed short int frequency,
 short int sinusoid;
 signed long result;
 /* Multiply frequency by scaling factor of ratio 32767 / 48000 */
 result = ( (long) frequency * 22368 ) >> 14 ;
     result = -32767;
 count += (signed int) result;
/* End of sinewaves.c                                                         */
/* PROJECT        */
/*   Sinewaves                                                               */
/* FILENAME        */
/* 	 main.c        */
/* DESCRIPTION                                                               */
/*   TMS320C5505 USB Stick Application 4. Generating sine waves.             */
/*   Generating sinewaves of variable frequency using DSPLIB.                */
/* REVISION        */
/* HISTORY        */
/*   Revision 1.00                                                           */
/*   1st March 2010. Original template code Spectrum Digital.                */
/*   Revision 1.01                                                           */
/*   5th August 2010. Converted to use CSL.                                  */
 *  are met:
 *    distribution.
#include "stdio.h"
#include "usbstk5505.h"
#include "aic3204.h"
#include "PLL.h"
#include "sinewaves.h"
Int16 left_input;
Int16 right_input;
Int16 left_output;
Int16 right_output;
#define SAMPLES_PER_SECOND 48000
#define GAIN_IN_dB         0
unsigned long int i = 0;
 *  main( )        *
void main( void )
    /* Initialize BSL */
    USBSTK5505_init( );
    /* Initialize the Phase Locked Loop in EEPROM */
    pll_frequency_setup(100);
    /* Initialise hardware interface and I2C for code */
    aic3204_hardware_init();
    /* Initialise the AIC3204 codec */
	aic3204_init();
	/* Set sampling frequency in Hz and ADC gain in dB */
    set_sampling_frequency_and_gain(SAMPLES_PER_SECOND, GAIN_IN_dB);
    printf("\nRunning Sinewaves Project\n\n");
    printf( "Sinewave 250Hz on left HP output, 1000Hz on right HP output\n\n" );
    asm(" bclr XF");
 	for ( i = 0  ; i < SAMPLES_PER_SECOND * 600L  ;i++  )
     aic3204_codec_read(&left_input, &right_input); // Configured for one interrupt per two channels.
     left_output = generate_sinewave_1(250, 10000);   // Sinewave 1 is 250 Hz.
     right_output = generate_sinewave_2(1000, 10000); // Sinewave 2 is 1000 Hz.
     aic3204_codec_write(left_output, right_output);
   /* Disable I2S and put codec into reset */
    aic3204_disable();
    printf( "\n***Program has Terminated***\n" );
    SW_BREAKPOINT;
 *  End of main.c                                                           *
  • Hi Parash,
    I am no expert of the AIC3204. Based on my limited knowledge about audio processing, I think you should be able to adjust the output voltage by adjust the values in left_output, right_output, like scale down by divide or logarithm. If you want to achieve this set up the AIC304, then may have to consult AIC3204 expert.
    Ming
  • Hi Ming,
    Thank you for your help.
    I have tried to lower the value of second parameter i.e. Amplitude  in left_output.
    But in  "left_output = generate_sinewave_1(250, 10000);"  when i put 100 instead of 10000 I am not getting sine wave, I am only getting noise.
  • Hi Paresh,
    If you plot the left_output with CCS graph tool, you should see a sine wave with amplitude peak at 100. It means the generate_sinewave_1 is working properly. You still hear noise from the headphone, it may be caused by the AIC3204, due to the low amplitude in left_output. I am not sure the AIC3204 can go as low as 1mv.
    Ming
  • Hey Ming,
    Can you please tell me what values should i give in the following terms to plot graph:
    • Acquisition Buffer Size
    • Dsp Data Type(options are 16-bit and 32-bit signed and unsigned integer)
    • Start Address
    • Display data size
  • Hi Paresh,
    • Acquisition Buffer Size: sample number*2
    • Dsp Data Type(options are 16-bit and 32-bit signed and unsigned integer): signed 16-bit integer
    • Start Address: left_output
    • Display data size: sample number*2
