SK-TDA4VM: DMPAC maximum resolution usage
Part Number: SK-TDA4VM
Hi experts,
I am using SK-TDA4VM and SDK 9.1 to test DMPAC capability. I followed instruction mentioned in this e2e, and the documentation of SDK 8.5 (https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-sk-tda4vm/08_05_00/exports/docs/dmpac_demos.html ). I modified gstreamer command and used the following command:
gst-launch-1.0                                                              \
filesrc location=/opt/edgeai-gst-apps/data/videos/left-1280x720.avi !          \
avidemux ! h264parse ! v4l2h264dec !                                        \
video/x-raw, format=NV12 ! queue ! sde.left_sink                            \
filesrc location=/opt/edgeai-gst-apps/data/videos/right-1280x720.avi !         \
video/x-raw, format=NV12 ! queue ! sde.right_sink                           \
tiovxsde name=sde ! tiovxsdeviz ! kmssink driver-name=tidss sync=false
This command works.
I resized the images using videoscale and this works for 1280*1024 and 1300*1024.
However, when I try to resize the images to 1500*1024, problems occurs:
root@tda4vm-sk:/opt/edgeai-gst-apps# gst-launch-1.0                                                              \
> video/x-raw, format=NV12 !                   \
> videoscale !                                   \
> video/x-raw, width=1500, height=1024 !                  \
> videoscale !                               \
> tiovxsde name=sde ! tiovxsdeviz ! multifilesink location=/opt/edgeai-gst-apps/data/output/sde_1500_1024_%d.bmp
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=6) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
   660.008512 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
   660.008572 s:  VX_ZONE_INIT:Enabled
   660.008580 s:  VX_ZONE_ERROR:Enabled
   660.008586 s:  VX_ZONE_WARNING:Enabled
   660.009276 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
   660.010162 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
Redist[  654.596406] unclassified data detected!
ribute latency...
[  654.603833] unclassified data detected!
[  654.623471] unclassified data detected!
[  654.635749] unclassified data detected!
   660.172622 s:  VX_ZONE_ERROR:[ownContextSendCmd:822] Command ack message returned failure cmd_status: -1
   660.172678 s:  VX_ZONE_ERROR:[ownContextSendCmd:862] tivxEventWait() failed.
   660.172686 s:  VX_ZONE_ERROR:[ownNodeKernelInit:584] Target kernel, TIVX_CMD_NODE_CREATE failed for node node_136
   660.172692 s:  VX_ZONE_ERROR:[ownNodeKernelInit:585] Please be sure the target callbacks have been registered for this core
   660.172700 s:  VX_ZONE_ERROR:[ownNodeKernelInit:586] If the target callbacks have been registered, please ensure no errors are occurl
   660.172707 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.hwa.dmpac_sde ... failed !!!
   660.172721 s:  VX_ZONE_ERROR:[vxVerifyGraph:2059] Node kernel init failed
   660.172727 s:  VX_ZONE_ERROR:[vxVerifyGraph:2113] Graph verify failed
   660.172825 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:601] Invalid reference
ERROR: from element /GstPipeline:pipeline0/GstTIOVXSde:sde: Unable to init TIOVX module
Additional debug info:
../git/gst-libs/gst/tiovx/gsttiovxmiso.c(1508): gst_tiovx_miso_negotiated_src_caps (): /GstPipeline:pipeline0/GstTIOVXSde:sde
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
[MCU2_1]    660.172338 s:  VX_ZONE_ERROR:[tivxDmpacSdeCreate:571] Set parameters request failed
[MCU2_1]    660.172395 s:  VX_ZONE_ERROR:[tivxDmpacSdeCreate:575] Not enough SL2 memory for this configuration
Freeing pipeline ...
   660.205742 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb57aa370 of type 00000816 at external count 1, internt
   660.205759 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=user_data_object_128) now as a part of garbage colln
   660.205829 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb5864378 of type 00000813 at external count 1, internt
   660.205838 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=object_array_130) now as a part of garbage collectin
   660.205851 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb57e24b8 of type 0000080f at external count 1, internt
   660.205857 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=image_131) now as a part of garbage collection
   660.206232 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb5864518 of type 00000813 at external count 1, internt
   660.206241 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=object_array_132) now as a part of garbage collectin
   660.206251 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb57e2770 of type 0000080f at external count 1, internt
   660.206259 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=image_133) now as a part of garbage collection
   660.206599 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb58646b8 of type 00000813 at external count 1, internt
   660.206607 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=object_array_134) now as a part of garbage collectin
   660.206617 s:  VX_ZONE_WARNING:[vxReleaseContext:1088] Found a reference 0xffffb57e2a28 of type 0000080f at external count 1, internt
   660.206624 s:  VX_ZONE_WARNING:[vxReleaseContext:1090] Releasing reference (name=image_135) now as a part of garbage collection
   660.207109 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
   660.210525 s:  VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!!
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
IPC: Deinit ... !!!
IPC: DeInit ... Done !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 13 alloc's of 33882152 bytes
DDR_SHARED_MEM: Free's : 13 free's  of 33882152 bytes
DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
Please note these two lines:
So does DMPAC supports 2MP in current version? How can I test the maximum resolution?
Adam
