AM3352: SDK 09.01.00.001 cross compilation issue
Part Number: AM3352
We are trying to move to SDK version 09.01.00.001 but we are having some issues when trying to compile the kernel.
We are following instructions from https://software-dl.ti.com/processor-sdk-linux/esd/AM335X/09_01_00_001/exports/docs/linux/Foundational_Components_Kernel_Users_Guide.html#getting-the-kernel-source-code
- Install SDK
- export PATH=/opt/crosstool/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin:$PATH
- make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- distclean
- make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- multi_v7_defconfig ti_multi_v7_prune.config no_smp.config
- make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- zImage
 SYNC    include/config/auto.conf.cmd
 SYSHDR  arch/arm/include/generated/uapi/asm/unistd-oabi.h
 SYSHDR  arch/arm/include/generated/uapi/asm/unistd-eabi.h
 HOSTCC  scripts/dtc/dtc.o
 HOSTCC  scripts/dtc/flattree.o
 HOSTCC  scripts/dtc/fstree.o
 HOSTCC  scripts/dtc/data.o
 HOSTCC  scripts/dtc/livetree.o
 HOSTCC  scripts/dtc/treesource.o
 HOSTCC  scripts/dtc/srcpos.o
 HOSTCC  scripts/dtc/checks.o
 HOSTCC  scripts/dtc/util.o
 LEX     scripts/dtc/dtc-lexer.lex.c
 YACC    scripts/dtc/dtc-parser.tab.[ch]
 HOSTCC  scripts/dtc/dtc-lexer.lex.o
 HOSTCC  scripts/dtc/dtc-parser.tab.o
 HOSTLD  scripts/dtc/dtc
 HOSTCC  scripts/dtc/libfdt/fdt.o
 HOSTCC  scripts/dtc/libfdt/fdt_ro.o
 HOSTCC  scripts/dtc/libfdt/fdt_wip.o
 HOSTCC  scripts/dtc/libfdt/fdt_sw.o
 HOSTCC  scripts/dtc/libfdt/fdt_rw.o
 HOSTCC  scripts/dtc/libfdt/fdt_strerror.o
 HOSTCC  scripts/dtc/libfdt/fdt_empty_tree.o
 HOSTCC  scripts/dtc/libfdt/fdt_addresses.o
 HOSTCC  scripts/dtc/libfdt/fdt_overlay.o
 HOSTCC  scripts/dtc/fdtoverlay.o
 HOSTLD  scripts/dtc/fdtoverlay
 HOSTCXX scripts/gcc-plugins/arm_ssp_per_task_plugin.so
In file included from scripts/gcc-plugins/gcc-common.h:95,
                from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3:
/mnt/SDA/opt/crosstool/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/builtins.h:23:10: fatal error: mpc.h:
No existe el archivo o el directorio
  23 | #include <mpc.h>
We had not this issue before, could you please help us with this issue?
Best regards and thank you
    Thanks for your query.
    Our expert will look into this and get back to you.
    can we try "apt-get install libgmp3-dev"?
    -Hong
    Thank you for your help.
    I have installed this package:
    apt list --installed | grep libgmp3
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    libgmp3-dev/focal-updates,focal-security,now 2:6.2.0+dfsg-4ubuntu0.1 amd64 [instalado]
    But still have the same issue:
    make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- zImage -j11
    WRAP arch/arm/include/generated/uapi/asm/kvm_para.h
    WRAP arch/arm/include/generated/uapi/asm/bitsperlong.h
    WRAP arch/arm/include/generated/uapi/asm/bpf_perf_event.h
    WRAP arch/arm/include/generated/uapi/asm/errno.h
    WRAP arch/arm/include/generated/uapi/asm/ioctl.h
    WRAP arch/arm/include/generated/uapi/asm/ipcbuf.h
    WRAP arch/arm/include/generated/uapi/asm/msgbuf.h
    WRAP arch/arm/include/generated/uapi/asm/param.h
    WRAP arch/arm/include/generated/uapi/asm/poll.h
    WRAP arch/arm/include/generated/uapi/asm/resource.h
    WRAP arch/arm/include/generated/uapi/asm/sembuf.h
    WRAP arch/arm/include/generated/uapi/asm/shmbuf.h
    WRAP arch/arm/include/generated/uapi/asm/siginfo.h
    WRAP arch/arm/include/generated/uapi/asm/socket.h
    WRAP arch/arm/include/generated/uapi/asm/sockios.h
    WRAP arch/arm/include/generated/uapi/asm/termbits.h
    WRAP arch/arm/include/generated/uapi/asm/termios.h
    WRAP arch/arm/include/generated/asm/early_ioremap.h
    WRAP arch/arm/include/generated/asm/extable.h
    WRAP arch/arm/include/generated/asm/flat.h
    WRAP arch/arm/include/generated/asm/parport.h
    WRAP arch/arm/include/generated/asm/compat.h
    WRAP arch/arm/include/generated/asm/dma-mapping.h
    WRAP arch/arm/include/generated/asm/emergency-restart.h
    WRAP arch/arm/include/generated/asm/exec.h
    WRAP arch/arm/include/generated/asm/irq_regs.h
    WRAP arch/arm/include/generated/asm/kdebug.h
    WRAP arch/arm/include/generated/asm/kmap_size.h
    WRAP arch/arm/include/generated/asm/local.h
    WRAP arch/arm/include/generated/asm/local64.h
    WRAP arch/arm/include/generated/asm/mmiowb.h
    WRAP arch/arm/include/generated/asm/msi.h
    WRAP arch/arm/include/generated/asm/preempt.h
    WRAP arch/arm/include/generated/asm/rwonce.h
    WRAP arch/arm/include/generated/asm/serial.h
    WRAP arch/arm/include/generated/asm/simd.h
    WRAP arch/arm/include/generated/asm/softirq_stack.h
    WRAP arch/arm/include/generated/asm/trace_clock.h
    WRAP arch/arm/include/generated/asm/unaligned.h
    UPD include/generated/uapi/linux/version.h
    UPD include/config/kernel.release
    UPD include/generated/compile.h
    UPD include/generated/utsrelease.h
    HOSTCC scripts/kallsyms
    HOSTCC scripts/sorttable
    HOSTCC scripts/asn1_compiler
    /mnt/SDA/opt/crosstool/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/../lib/gcc/arm-none-linux-gnueabihf/11.3.1/plugin/include/builtins.h:23:10: fatal error: mpc.h: No existe el archivo o el directorio
    compilation terminated.
    make[2]: *** [scripts/gcc-plugins/Makefile:54: scripts/gcc-plugins/arm_ssp_per_task_plugin.so] Error 1
    make[1]: *** [scripts/Makefile.build:502: scripts/gcc-plugins] Error 2
    I misread your original post.
    Can we try "sudo apt install libmpfr-dev libmpc-dev"?
    -Hong
    Great, that works, thank you very much for your help.
    Best regards
