Part Number: AM625
#1. From data sheet, the maximum OSPI_CLK is 50MHz in SDK mode, 25MHz in DDR mode.
#. How can it achieve >50Mbyte/s throughput?
Part Number: AM625
Hi Tony,
This cannot be done in Tap mode, it has to be in PHY mode.
Bin,
How to set to PHy mode?
customer test according to upper post, can only achieve 13+MByte/s throughput. actually the RAW mode is using DD command to access OSPI.
Hi Tony,
Please refer to the "Phy calibration" section in the link below for how to flash the phy calibration pattern. The driver will set to PHY mode once the phy calibration pattern exists on the flash. The documentation has a link for downloading the pattern file.
