Part Number: TDA4VM
Is there an interface to obtain the frame rate of the camera?
SDK:08.06.00.12 vision_apps app_multi_cam_codec
Yueqian
Part Number: TDA4VM
Yueqian
We do not have a direct interface from capture node, however, you could check the timestamps provided by the capture node to calculate the fps based on the time difference between each frames.
You could refer the below to access the timestamp
Nikhil
