AM625: adjust Kernel debug level result in falcon boot fail
Part Number: AM625
implemented falcon boot with SDK8.3, then adjust Kenel Console debug level as below:
--- tisdk_am62xx-evm_defconfig	2024-03-05 12:54:51.311163346 +0800
+++ tisdk_am62xx-evm_debug_defconfig	2024-03-05 13:00:48.541023731 +0800
@@ -7381,10 +7381,9 @@
 # printk and dmesg options
 CONFIG_PRINTK_TIME=y
-# CONFIG_PRINTK_CALLER is not set
-CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
-CONFIG_CONSOLE_LOGLEVEL_QUIET=4
-CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
+CONFIG_CONSOLE_LOGLEVEL_DEFAULT=4
+CONFIG_CONSOLE_LOGLEVEL_QUIET=2
+CONFIG_MESSAGE_LOGLEVEL_DEFAULT=1
 # CONFIG_BOOT_PRINTK_DELAY is not set
 # CONFIG_DYNAMIC_DEBUG is not set
 # CONFIG_DYNAMIC_DEBUG_CORE is not set
[2024-03-05 04:38:05.530] ?
[2024-03-05 04:38:06.026] U-Boot SPL 2021.01-00002-g77bcc61275-dirty (Feb 29 2024 - 09:43:16 +0800)
[2024-03-05 04:38:06.060] SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
[2024-03-05 04:38:06.108] Trying to boot from MMC2
[2024-03-05 04:38:07.403] Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2024-03-05 04:38:07.467] Starting ATF on ARM64 core...
[2024-03-05 04:38:07.483]
[2024-03-05 04:38:07.483] NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
[2024-03-05 04:38:07.483] NOTICE:  BL31: Built : 16:35:46, May 30 2022
[2024-03-05 04:38:08.554] ERROR:   Timeout waiting for thread SP_RESPONSE to fill
[2024-03-05 04:38:08.570] ERROR:   Thread SP_RESPONSE verification failed (-60)
[2024-03-05 04:38:08.570] ERROR:   Message receive failed (-60)
[2024-03-05 04:38:08.570] ERROR:   Failed to get response (-60)
[2024-03-05 04:38:08.570] ERROR:   Transfer send failed (-60)
[2024-03-05 04:38:08.586] ERROR:   Request to start core failed: -60
[2024-03-05 04:38:08.586] [    1.027138] psci: failed to boot CPU1 (-22)
[2024-03-05 04:38:08.586] [    1.031439] CPU1: failed to boot: -22
[2024-03-05 04:38:09.770] [    2.211807] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: platform_drv_probe+0x54/0xa8)
[2024-03-05 04:38:09.787] [    2.221702] ti-sci 44043000.system-controller: Mbox send fail -110
[2024-03-05 04:38:09.787] [    2.228025] ti-sci 44043000.system-controller: Unable to communicate with TISCI(-110)
[2024-03-05 04:38:09.805] [    2.245112] Warning: unable to open an initial console.
[2024-03-05 04:38:09.805] [    2.250796] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[2024-03-05 04:38:09.818] [    2.258513] Please append a correct "root=" boot option; here are the available partitions:
[2024-03-05 04:38:09.818] [    2.267076] 0100            4096 ram0
[2024-03-05 04:38:09.833] [    2.267080]  (driver?)
[2024-03-05 04:38:09.833] [    2.273340] 0101            4096 ram1
[2024-03-05 04:38:09.833] [    2.273342]  (driver?)
[2024-03-05 04:38:09.833] [    2.279584] 0102            4096 ram2
[2024-03-05 04:38:09.833] [    2.279587]  (driver?)
[2024-03-05 04:38:09.850] [    2.285828] 0103            4096 ram3
[2024-03-05 04:38:09.850] [    2.285831]  (driver?)
[2024-03-05 04:38:09.850] [    2.292071] 0104            4096 ram4
[2024-03-05 04:38:09.850] [    2.292074]  (driver?)
[2024-03-05 04:38:09.850] [    2.298309] 0105            4096 ram5
[2024-03-05 04:38:09.869] [    2.298312]  (driver?)
[2024-03-05 04:38:09.869] [    2.304553] 0106            4096 ram6
[2024-03-05 04:38:09.869] [    2.304556]  (driver?)
[2024-03-05 04:38:09.869] [    2.310791] 0107            4096 ram7
[2024-03-05 04:38:09.869] [    2.310794]  (driver?)
[2024-03-05 04:38:09.884] [    2.317035] 0108            4096 ram8
[2024-03-05 04:38:09.884] [    2.317039]  (driver?)
[2024-03-05 04:38:09.884] [    2.323275] 0109            4096 ram9
[2024-03-05 04:38:09.884] [    2.323277]  (driver?)
[2024-03-05 04:38:09.884] [    2.329518] 010a            4096 ram10
[2024-03-05 04:38:09.899] [    2.329521]  (driver?)
[2024-03-05 04:38:09.899] [    2.335850] 010b            4096 ram11
[2024-03-05 04:38:09.899] [    2.335853]  (driver?)
[2024-03-05 04:38:09.899] [    2.342177] 010c            4096 ram12
[2024-03-05 04:38:09.899] [    2.342180]  (driver?)
[2024-03-05 04:38:09.915] [    2.348515] 010d            4096 ram13
[2024-03-05 04:38:09.915] [    2.348518]  (driver?)
[2024-03-05 04:38:09.915] [    2.354842] 010e            4096 ram14
[2024-03-05 04:38:09.915] [    2.354845]  (driver?)
[2024-03-05 04:38:09.915] [    2.361174] 010f            4096 ram15
[2024-03-05 04:38:09.931] [    2.361177]  (driver?)
[2024-03-05 04:38:09.931] [    2.367509] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[2024-03-05 04:38:09.931] [    2.375961] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.109-g9e58028f94 #1
[2024-03-05 04:38:09.947] [    2.383250] Hardware name: Texas Instruments AM625 SK (DT)
[2024-03-05 04:38:09.947] [    2.388853] Call trace:
[2024-03-05 04:38:09.947] [    2.391358]  dump_backtrace+0x0/0x1a0
[2024-03-05 04:38:09.947] [    2.395098]  show_stack+0x18/0x68
[2024-03-05 04:38:09.963] [    2.398484]  dump_stack+0xd0/0x12c
[2024-03-05 04:38:09.963] [    2.401956]  panic+0x16c/0x334
[2024-03-05 04:38:09.963] [    2.405075]  mount_block_root+0x1c4/0x254
[2024-03-05 04:38:09.963] [    2.409167]  mount_root+0x10c/0x140
[2024-03-05 04:38:09.978] [    2.412727]  prepare_namespace+0x130/0x170
[2024-03-05 04:38:09.978] [    2.416909]  kernel_init_freeable+0x25c/0x2a0
[2024-03-05 04:38:09.978] [    2.421360]  kernel_init+0x14/0x114
[2024-03-05 04:38:09.978] [    2.424921]  ret_from_fork+0x10/0x34
[2024-03-05 04:38:09.994] [    2.428579] Kernel Offset: 0x80000 from 0xffff800010000000
[2024-03-05 04:38:09.994] [    2.434181] PHYS_OFFSET: 0x80000000
[2024-03-05 04:38:09.994] [    2.437742] CPU features: 0x0040002,2080200c
[2024-03-05 04:38:09.994] [    2.442101] Memory Limit: none
[2024-03-05 04:38:10.047] [    2.445224] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
With the same Kernel, boot successfully in normal procedure from tiboot3, tispl, uboot, kernel.
[2024-03-05 05:12:14.413] U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:40:44 +0000)
[2024-03-05 05:12:14.429] SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
[2024-03-05 05:12:14.476] Trying to boot from MMC2
[2024-03-05 05:12:14.683] Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2024-03-05 05:12:14.699]
[2024-03-05 05:12:14.763] Starting ATF on ARM64 core...
[2024-03-05 05:12:14.763] NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
[2024-03-05 05:12:14.779] NOTICE:  BL31: Built : 16:35:46, May 30 2022
[2024-03-05 05:12:15.933]
[2024-03-05 05:12:15.933] U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
[2024-03-05 05:12:15.933] SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
[2024-03-05 05:12:15.949] Trying to boot from MMC2
[2024-03-05 05:12:17.596]
[2024-03-05 05:12:17.596] U-Boot 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
[2024-03-05 05:12:17.611]
[2024-03-05 05:12:17.611] SoC:   AM62X SR1.0
[2024-03-05 05:12:17.611] Model: Texas Instruments AM625 SK
[2024-03-05 05:12:17.660] EEPROM not available at 0x50, trying to read at 0x51
[2024-03-05 05:12:17.692] Board: AM62-SKEVM rev E3
[2024-03-05 05:12:17.692] DRAM:  2 GiB
[2024-03-05 05:12:17.723] MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
[2024-03-05 05:12:17.772] Loading Environment from MMC... *** Warning - bad CRC, using default environment
[2024-03-05 05:12:17.835]
[2024-03-05 05:12:17.835] In:    serial@2800000
[2024-03-05 05:12:17.835] Out:   serial@2800000
[2024-03-05 05:12:17.853] Err:   serial@2800000
[2024-03-05 05:12:17.869] Net:   eth0: ethernet@8000000port@1
[2024-03-05 05:12:17.885] Hit any key to stop autoboot:  2  1  0
[2024-03-05 05:12:19.915] switch to partitions #0, OK
[2024-03-05 05:12:19.915] mmc1 is current device
[2024-03-05 05:12:19.946] SD/MMC found on device 1
[2024-03-05 05:12:19.964] Failed to load 'boot.scr'
[2024-03-05 05:12:19.964] 1490 bytes read in 3 ms (484.4 KiB/s)
[2024-03-05 05:12:19.964] Loaded env from uEnv.txt
[2024-03-05 05:12:19.964] Importing environment from mmc1 ...
[2024-03-05 05:12:19.980] Running uenvcmd ...
[2024-03-05 05:12:19.980] 1 bytes read in 2 ms (0 Bytes/s)
[2024-03-05 05:12:19.980] Already setup.
[2024-03-05 05:12:20.781] 18448896 bytes read in 786 ms (22.4 MiB/s)
[2024-03-05 05:12:20.796] 55666 bytes read in 7 ms (7.6 MiB/s)
[2024-03-05 05:12:20.796] ## Flattened Device Tree blob at 88000000
[2024-03-05 05:12:20.796]    Booting using the fdt blob at 0x88000000
[2024-03-05 05:12:20.811]    Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
[2024-03-05 05:12:20.828]
[2024-03-05 05:12:20.828] Starting kernel ...
[2024-03-05 05:12:22.459] [    1.330306] davinci-mcasp 2b10000.mcasp: IRQ common not found
[2024-03-05 05:12:22.685] [    1.550808] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[2024-03-05 05:12:22.685] [    1.556583] cpu cpu0: OPP table can't be empty
[2024-03-05 05:12:22.701] [    1.561092] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[2024-03-05 05:12:22.701] [    1.566834] cpu cpu0: OPP table can't be empty
[2024-03-05 05:12:22.701] [    1.571324] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[2024-03-05 05:12:22.716] [    1.577063] cpu cpu0: OPP table can't be empty
[2024-03-05 05:12:22.716] [    1.581554] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[2024-03-05 05:12:22.716] [    1.587298] cpu cpu0: OPP table can't be empty
[2024-03-05 05:12:22.763] [    1.634862] davinci-mcasp 2b10000.mcasp: IRQ common not found
[2024-03-05 05:12:22.940] [    1.803169] mmc0: mmc_select_hs200 failed, error -110
[2024-03-05 05:12:22.940] [    1.808267] mmc0: error -110 whilst initialising MMC card
[2024-03-05 05:12:22.957] [    1.819558] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[2024-03-05 05:12:22.957] [    1.826863] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[2024-03-05 05:12:22.973] [    1.834209] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[2024-03-05 05:12:22.973] [    1.841899] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[2024-03-05 05:12:23.086] [    1.946310] mmc0: mmc_select_hs200 failed, error -110
[2024-03-05 05:12:23.086] [    1.951383] mmc0: error -110 whilst initialising MMC card
[2024-03-05 05:12:23.246] [    2.105746] mmc0: mmc_select_hs200 failed, error -110
[2024-03-05 05:12:23.246] [    2.110826] mmc0: error -110 whilst initialising MMC card
[2024-03-05 05:12:23.434] [    2.308160] mmc0: mmc_select_hs200 failed, error -110
[2024-03-05 05:12:23.451] [    2.313215] mmc0: error -110 whilst initialising MMC card
[2024-03-05 05:12:23.947]
[2024-03-05 05:12:23.947] Welcome to Arago 2021.09!
[2024-03-05 05:12:24.365] [  OK  ] Created slice system-getty.slice.
[2024-03-05 05:12:24.380] [  OK  ] Created slice system-serial\x2dgetty.slice.
[2024-03-05 05:12:24.396] [  OK  ] Created slice User and Session Slice.
[2024-03-05 05:12:24.482] [  OK  ] Started Dispatch Password 鈥s to Console Directory Watch.
[2024-03-05 05:12:24.487] [  OK  ] Started Forward Password R鈥ests to Wall Directory Watch.
[2024-03-05 05:12:24.487] [  OK  ] Reached target Paths.
[2024-03-05 05:12:24.487] [  OK  ] Reached target Remote File Systems.
[2024-03-05 05:12:24.487] [  OK  ] Reached target Slices.
[2024-03-05 05:12:24.487] [  OK  ] Reached target Swap.
[2024-03-05 05:12:24.523] [  OK  ] Listening on RPCbind Server Activation Socket.
[2024-03-05 05:12:24.557] [  OK  ] Reached target RPC Port Mapper.
[2024-03-05 05:12:24.573] [  OK  ] Listening on Process Core Dump Socket.
[2024-03-05 05:12:24.589] [  OK  ] Listening on initctl Compatibility Named Pipe.
[2024-03-05 05:12:24.603] [  OK  ] Listening on Journal Socket (/dev/log).
[2024-03-05 05:12:24.621] [  OK  ] Listening on Journal Socket.
[2024-03-05 05:12:24.635] [  OK  ] Listening on Network Service Netlink Socket.
[2024-03-05 05:12:24.654] [  OK  ] Listening on udev Control Socket.
[2024-03-05 05:12:24.670] [  OK  ] Listening on udev Kernel Socket.
[2024-03-05 05:12:24.682]          Mounting Huge Pages File System...
[2024-03-05 05:12:24.699]          Mounting POSIX Message Queue File System...
[2024-03-05 05:12:24.733]          Mounting Kernel Debug File System...
[2024-03-05 05:12:24.748]          Mounting Temporary Directory (/tmp)...
[2024-03-05 05:12:24.766]          Starting Start psplash boot splash screen...
[2024-03-05 05:12:24.780]          Starting RPC Bind...
[2024-03-05 05:12:24.797]          Starting Journal Service...
[2024-03-05 05:12:24.830]          Starting Load Kernel Modules...
[2024-03-05 05:12:24.846]          Starting Remount Root and Kernel File Systems...
[2024-03-05 05:12:24.862]          Starting udev Coldplug all Devices...
[2024-03-05 05:12:24.877] [  OK  ] Started RPC Bind.
[2024-03-05 05:12:24.893] [  OK  ] Mounted Huge Pages File System.
[2024-03-05 05:12:24.909] [  OK  ] Started Journal Service.
[2024-03-05 05:12:24.924] [  OK  ] Mounted POSIX Message Queue File System.
[2024-03-05 05:12:24.957] [  OK  ] Mounted Kernel Debug File System.
[2024-03-05 05:12:24.973] [  OK  ] Mounted Temporary Directory (/tmp).
[2024-03-05 05:12:24.990] [FAILED] Failed to start Start psplash boot splash screen.
[2024-03-05 05:12:25.006] See 'systemctl status psplash-start.service' for details.
[2024-03-05 05:12:25.021] [DEPEND] Dependency failed for Star鈥rogress communication helper.
[2024-03-05 05:12:25.036] [FAILED] Failed to start Load Kernel Modules.
[2024-03-05 05:12:25.051] See 'systemctl status systemd-modules-load.service' for details.
[2024-03-05 05:12:25.068] [  OK  ] Started Remount Root and Kernel File Systems.
[2024-03-05 05:12:25.101]          Mounting Kernel Configuration File System...
[2024-03-05 05:12:25.149]          Starting Flush Journal to Persistent Storage...
[2024-03-05 05:12:25.163]          Starting Apply Kernel Variables...
[2024-03-05 05:12:25.182]          Starting Create Static Device Nodes in /dev...
[2024-03-05 05:12:25.195] [  OK  ] Mounted Kernel Configuration File System.
[2024-03-05 05:12:25.227] [  OK  ] Started Flush Journal to Persistent Storage.
[2024-03-05 05:12:25.246] [  OK  ] Started Apply Kernel Variables.
[2024-03-05 05:12:25.259] [  OK  ] Started Create Static Device Nodes in /dev.
[2024-03-05 05:12:25.292] [  OK  ] Reached target Local File Systems (Pre).
[2024-03-05 05:12:25.310]          Mounting /media/ram...
[2024-03-05 05:12:25.325]          Mounting /var/volatile...
[2024-03-05 05:12:25.341]          Starting udev Kernel Device Manager...
[2024-03-05 05:12:25.356] [  OK  ] Started udev Coldplug all Devices.
[2024-03-05 05:12:25.372] [  OK  ] Mounted /media/ram.
[2024-03-05 05:12:25.388] [  OK  ] Mounted /var/volatile.
[2024-03-05 05:12:25.402]          Starting udev Wait for Complete Device Initialization...
[2024-03-05 05:12:25.436]          Starting Load/Save Random Seed...
[2024-03-05 05:12:25.452] [  OK  ] Reached target Local File Systems.
[2024-03-05 05:12:25.465]          Starting Create Volatile Files and Directories...
[2024-03-05 05:12:25.483] [  OK  ] Started udev Kernel Device Manager.
[2024-03-05 05:12:25.515] [  OK  ] Started Create Volatile Files and Directories.
[2024-03-05 05:12:25.548]          Starting Network Time Synchronization...
[2024-03-05 05:12:25.565]          Starting Update UTMP about System Boot/Shutdown...
[2024-03-05 05:12:25.594] [  OK  ] Started Update UTMP about System Boot/Shutdown.
[2024-03-05 05:12:25.754] [  OK  ] Started Network Time Synchronization.
[2024-03-05 05:12:25.790] [  OK  ] Reached target System Time Set.
[2024-03-05 05:12:25.808] [  OK  ] Reached target System Time Synchronized.
[2024-03-05 05:12:27.131] [  OK  ] Created slice system-systemd\x2dfsck.slice.
[2024-03-05 05:12:27.229] [  OK  ] Found device /dev/mmcblk1p1.
[2024-03-05 05:12:27.244]          Starting File System Check on /dev/mmcblk1p1...
[2024-03-05 05:12:27.260] [  OK  ] Started udev Wait for Complete Device Initialization.
[2024-03-05 05:12:27.278] [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[2024-03-05 05:12:27.278] [  OK  ] Reached target System Initialization.
[2024-03-05 05:12:27.278] [  OK  ] Started Daily rotation of log files.
[2024-03-05 05:12:27.294] [  OK  ] Started Daily Cleanup of Temporary Directories.
[2024-03-05 05:12:27.294] [  OK  ] Reached target Timers.
[2024-03-05 05:12:27.294] [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[2024-03-05 05:12:27.310] [  OK  ] Listening on D-Bus System Message Bus Socket.
[2024-03-05 05:12:27.310]          Starting Docker Socket for the API.
[2024-03-05 05:12:27.326] [  OK  ] Listening on dropbear.socket.
[2024-03-05 05:12:27.326]          Starting Reboot and dump vmcore via kexec...
[2024-03-05 05:12:27.326] [  OK  ] Listening on Docker Socket for the API.
[2024-03-05 05:12:27.341] [  OK  ] Reached target Sockets.
[2024-03-05 05:12:27.341] [  OK  ] Reached target Basic System.
[2024-03-05 05:12:27.358] [  OK  ] Started Job spooling tools.
[2024-03-05 05:12:27.358] [  OK  ] Started Periodic Command Scheduler.
[2024-03-05 05:12:27.358] [  OK  ] Started D-Bus System Message Bus.
[2024-03-05 05:12:27.372]          Starting Print notice about GPLv3 packages...
[2024-03-05 05:12:27.372]          Starting IPv6 Packet Filtering Framework...
[2024-03-05 05:12:27.372]          Starting IPv4 Packet Filtering Framework...
[2024-03-05 05:12:27.389] [  OK  ] Started irqbalance daemon.
[2024-03-05 05:12:27.389]          Starting rc.pvr.service...
[2024-03-05 05:12:27.389]          Starting startwlanap...
[2024-03-05 05:12:27.406]          Starting startwlansta...
[2024-03-05 05:12:27.419]          Starting Login Service...
[2024-03-05 05:12:27.419] [  OK  ] Started TEE Supplicant.
[2024-03-05 05:12:27.433] [  OK  ] Started Reboot and dump vmcore via kexec.
[2024-03-05 05:12:27.451] [  OK  ] Started startwlansta.
[2024-03-05 05:12:27.451] [  OK  ] Started startwlanap.
[2024-03-05 05:12:27.499] [    6.333304] startwlanap.sh[596]: modprobe: FATAL: Module wl18xx not found in directory /lib/modules/5.10.10
[2024-03-05 05:12:27.499] 9-g9e58028f94
[2024-03-05 05:12:27.516] [    6.338458] startwlanap.sh[597]: modprobe: FATAL: Module wlcore_sdio not found in directory /lib/modules/5.
[2024-03-05 05:12:27.516] 10.109-g9e58028f94
[2024-03-05 05:12:27.580] [  OK  ] Started File System Check on /dev/mmcblk1p1.
[2024-03-05 05:12:27.580] [  OK  ] Started IPv6 Packet Filtering Framework.
[2024-03-05 05:12:27.598] [  OK  ] Started IPv4 Packet Filtering Framework.
[2024-03-05 05:12:27.614] [  OK  ] Started rc.pvr.service.
[2024-03-05 05:12:27.614] [  OK  ] Reached target Network (Pre).
[2024-03-05 05:12:27.614] [    6.449264] startwlansta.sh[603]: modprobe: FATAL: Module wl18xx not found in directory /lib/modules/5.10.1
[2024-03-05 05:12:27.627] 09-g9e58028f94
[2024-03-05 05:12:27.627]          Mounting /run/media/mmcblk1p1...
[2024-03-05 05:12:27.627] [    6.460589] startwlansta.sh[604]: modprobe: FATAL: Module wlcore_sdio not found in directory /lib/modules/5
[2024-03-05 05:12:27.644] .10.109-g9e58028f94
[2024-03-05 05:12:27.644]          Starting Network Service...
[2024-03-05 05:12:27.644]          Starting weston.service...
[2024-03-05 05:12:27.708] [  OK  ] Mounted /run/media/mmcblk1p1.
[2024-03-05 05:12:27.819] [  OK  ] Started Load/Save Random Seed.
[2024-03-05 05:12:27.933] [  OK  ] Started Network Service.
[2024-03-05 05:12:27.933]          Starting Wait for Network to be Configured...
[2024-03-05 05:12:27.933]          Starting Network Name Resolution...
[2024-03-05 05:12:27.994] [  OK  ] Started Login Service.
[2024-03-05 05:12:28.185] [  OK  ] Started Network Name Resolution.
[2024-03-05 05:12:28.207] [  OK  ] Reached target Network.
[2024-03-05 05:12:28.207] [  OK  ] Reached target Host and Network Name Lookups.
[2024-03-05 05:12:28.207]          Starting Avahi mDNS/DNS-SD Stack...
[2024-03-05 05:12:28.220]          Starting Enable and configure wl18xx bluetooth stack...
[2024-03-05 05:12:28.220] [  OK  ] Started NFS status monitor for NFSv2/3 locking..
[2024-03-05 05:12:28.237]          Starting Simple Network Ma鈥nt Protocol (SNMP) Daemon....
[2024-03-05 05:12:28.237]          Starting Permit User Sessions...
[2024-03-05 05:12:28.266] [  OK  ] Started Permit User Sessions.
[2024-03-05 05:12:28.302] [  OK  ] Started Getty on tty1.
[2024-03-05 05:12:28.302] [  OK  ] Started Serial Getty on ttyS2.
[2024-03-05 05:12:28.317] [  OK  ] Reached target Login Prompts.
[2024-03-05 05:12:28.332]          Starting Synchronize System and HW clocks...
[2024-03-05 05:12:28.366] [  OK  ] Started Enable and configure wl18xx bluetooth stack.
[2024-03-05 05:12:28.366] [  OK  ] Started Avahi mDNS/DNS-SD Stack.
[2024-03-05 05:12:28.589] [    7.425622] startwlanap.sh[637]: nl80211 not found.
[2024-03-05 05:12:28.619] [    7.450093] startwlanap.sh[642]: nl80211 not found.
[2024-03-05 05:12:28.637] [    7.474055] startwlanap.sh[647]: nl80211 not found.
[2024-03-05 05:12:28.699] [    7.533196] startwlanap.sh[654]: adding wlan1 interface
[2024-03-05 05:12:28.713] [    7.558685] startwlanap.sh[655]: ls: cannot access '/sys/class/ieee80211/': No such file or directory
[2024-03-05 05:12:28.749] [    7.582198] startwlanap.sh[656]: nl80211 not found.
[2024-03-05 05:12:28.860] [    7.691269] startwlanap.sh[658]: Configuration file: /usr/share/wl18xx/hostapd.conf
[2024-03-05 05:12:28.877] [    7.708630] startwlanap.sh[658]: nl80211: 'nl80211' generic netlink not found
[2024-03-05 05:12:28.877] [    7.709213] startwlanap.sh[658]: Failed to initialize driver 'nl80211'
[2024-03-05 05:12:28.893] [    7.709480] startwlanap.sh[658]: wlan1: interface state UNINITIALIZED->DISABLED
[2024-03-05 05:12:28.893] [    7.709675] startwlanap.sh[658]: wlan1: AP-DISABLED
[2024-03-05 05:12:28.893] [    7.709813] startwlanap.sh[658]: wlan1: CTRL-EVENT-TERMINATING
[2024-03-05 05:12:28.908] [    7.709948] startwlanap.sh[658]: hostapd_free_hapd_data: Interface wlan1 wasn't started
[2024-03-05 05:12:28.908] [  OK  ] Started Synchronize System and HW clocks.
[2024-03-05 05:12:29.193] [  OK  ] Started Simple Network Man鈥ment Protocol (SNMP) Daemon..
[2024-03-05 05:12:29.787] [    8.629675] startwlanap.sh[663]: SIOCSIFADDR: No such device
[2024-03-05 05:12:29.820] [    8.652728] startwlanap.sh[663]: wlan1: ERROR while getting interface flags: No such device
[2024-03-05 05:12:29.833] [    8.676836] startwlanap.sh[663]: SIOCSIFNETMASK: No such device
[2024-03-05 05:12:29.869] [    8.701073] startwlanap.sh[663]: wlan1: ERROR while getting interface flags: No such device
[2024-03-05 05:12:29.948] [    8.791777] startwlanap.sh[683]: modprobe: FATAL: Module ip_tables not found in directory /lib/modules/5.10
[2024-03-05 05:12:29.966] .109-g9e58028f94
[2024-03-05 05:12:29.966] [    8.792680] startwlanap.sh[679]: iptables v1.8.4 (legacy): can't initialize iptables table `nat': Table doe
[2024-03-05 05:12:29.981] s not exist (do you need to insmod?)
[2024-03-05 05:12:29.981] [    8.792977] startwlanap.sh[679]: Perhaps iptables or your kernel needs to be upgraded.
[2024-03-05 05:12:30.831] [  OK  ] Started weston.service.
[2024-03-05 05:12:30.831]          Starting telnetd.service...
[2024-03-05 05:12:30.877] [  OK  ] Started telnetd.service.
[2024-03-05 05:12:30.877]          Starting hmi_demo.service...
[2024-03-05 05:12:30.894]          Starting LSB: Expand Rootfs of boot device...
[2024-03-05 05:12:30.988] [    9.820754] startwlanap.sh[850]: iperf3: error - unable to start listener for connections: Cannot assign re
[2024-03-05 05:12:30.988] quested address
[2024-03-05 05:12:31.006] [    9.821220] startwlanap.sh[850]: iperf3: exiting
[2024-03-05 05:12:31.019] ***************************************************************
[2024-03-05 05:12:31.019] NOTICE: This file system contains the following GPLv3 packages:
[2024-03-05 05:12:31.040] 	autoconf
[2024-03-05 05:12:31.040] 	bash-dev
[2024-03-05 05:12:31.040] 	bc
[2024-03-05 05:12:31.040] 	binutils
[2024-03-05 05:12:31.040] 	cifs-utils
[2024-03-05 05:12:31.040] 	coreutils-stdbuf
[2024-03-05 05:12:31.040] 	cpio
[2024-03-05 05:12:31.040] 	cpp-symlinks
[2024-03-05 05:12:31.040] 	dosfstools
[2024-03-05 05:12:31.040] 	elfutils
[2024-03-05 05:12:31.040] 	g++-symlinks
[2024-03-05 05:12:31.058] 	g++
[2024-03-05 05:12:31.058] 	gawk
[2024-03-05 05:12:31.058] 	gcc-symlinks
[2024-03-05 05:12:31.058] 	gdb
[2024-03-05 05:12:31.058] 	gdbserver
[2024-03-05 05:12:31.058] 	gettext
[2024-03-05 05:12:31.058] 	glmark2
[2024-03-05 05:12:31.058] 	gstreamer1.0-libav
[2024-03-05 05:12:31.058] 	gzip
[2024-03-05 05:12:31.058] 	hidapi
[2024-03-05 05:12:31.058] 	less
[2024-03-05 05:12:31.058] 	libasm1
[2024-03-05 05:12:31.058] 	libbfd
[2024-03-05 05:12:31.058] 	libdw1
[2024-03-05 05:12:31.058] 	libelf1
[2024-03-05 05:12:31.058] 	libgdbm-compat4
[2024-03-05 05:12:31.072] 	libgdbm-dev
[2024-03-05 05:12:31.072] 	libgdbm6
[2024-03-05 05:12:31.072] 	libgettextlib
[2024-03-05 05:12:31.072] 	libgettextsrc
[2024-03-05 05:12:31.072] 	libgmp10
[2024-03-05 05:12:31.072] 	libidn2-0
[2024-03-05 05:12:31.072] 	libmpc3
[2024-03-05 05:12:31.072] 	libmpfr6
[2024-03-05 05:12:31.072] 	libreadline-dev
[2024-03-05 05:12:31.072] 	libreadline8
[2024-03-05 05:12:31.072] 	libunistring2
[2024-03-05 05:12:31.072] 	m4-dev
[2024-03-05 05:12:31.072] 	make
[2024-03-05 05:12:31.072] 	nettle
[2024-03-05 05:12:31.072] 	parted
[2024-03-05 05:12:31.084] 	tar
[2024-03-05 05:12:31.084] 	which
[2024-03-05 05:12:31.084] If you do not wish to distribute GPLv3 components please remove
[2024-03-05 05:12:31.084] the above packages prior to distribution.  This can be done using
[2024-03-05 05:12:31.084] the opkg remove command.  i.e.:
[2024-03-05 05:12:31.104]     opkg remove <package>
[2024-03-05 05:12:31.104] Where <package> is the name printed in the list above
[2024-03-05 05:12:31.104] NOTE: If the package is a dependency of another package you
[2024-03-05 05:12:31.104]       will be notified of the dependent packages.  You should
[2024-03-05 05:12:31.119]       use the --force-removal-of-dependent-packages option to
[2024-03-05 05:12:31.119]       also remove the dependent packages as well
[2024-03-05 05:12:31.119] ***************************************************************
[2024-03-05 05:12:31.132] ***************************************************************
[2024-03-05 05:12:31.150] [  OK  ] Started Print notice about GPLv3 packages.
[2024-03-05 05:12:31.246] [  OK  ] Started LSB: Expand Rootfs of boot device.
[2024-03-05 05:12:34.349]
[2024-03-05 05:12:34.349]  _____                    _____           _         _
[2024-03-05 05:12:34.349] |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
[2024-03-05 05:12:34.349] |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
[2024-03-05 05:12:34.349] |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
[2024-03-05 05:12:34.365]               |___|                    |___|
[2024-03-05 05:12:34.365] Arago Project am62xx-evm ttyS2
[2024-03-05 05:12:34.365] Arago 2021.09 am62xx-evm ttyS2
[2024-03-05 05:12:34.380]
[2024-03-05 05:12:34.380] am62xx-evm login: root
[2024-03-05 05:12:40.156] root@am62xx-evm:~#
  • Hi Tony,
    Is this running on AM62 SK EVM or custom board?
    Is OPTEE included in the kernel FIT image (the falcon mode tispl.bin)?
  • Does the kernel boot properly if you don't adjust the boot level in kernel config?
  • Hi,Bin,
    Both, upper log from EVM verified by me.
    Yes, This is the .its file you share with me before
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/falcon_5F00_tispl_2D00_verified.its
    Yes, without adjusting console boot level debug, can boot to Kernel properly.
  • Hi Tony,
    Can you compare the output of command 'mkimage -l tispl.bin' on the two fit images with and without kernel config change?
  • Hi, Bin
    no difference except the date.
  • Hi Tony,
    Before I get a chance to reproduce and debug it, can you please try the following kernel patch to set the log level instead of modifying it in kernel config? This is what I used a year+ ago.
    diff --git a/arch/arm64/boot/dts/ti/k3-am625-sk.dts b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
    index 894ec3066634..1dc3c38ceae7 100644
    --- a/arch/arm64/boot/dts/ti/k3-am625-sk.dts
    +++ b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
    @@ -30,7 +30,7 @@ aliases {
            chosen {
                    stdout-path = "serial2:115200n8";
    -               bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    +               bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 loglevel=1";
  • Hi, Bin,
    SD boot, not find difference in log with this dts change.
    loglevel=1
    loglevel1_240306_151811_COM.log
    default loglevel
    [2024-03-06 07:15:57.600] �
    [2024-03-06 07:15:58.095] U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:40:44 +0000)
    [2024-03-06 07:15:58.112] SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
    [2024-03-06 07:15:58.158] Trying to boot from MMC2
    [2024-03-06 07:15:58.367] Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    [2024-03-06 07:15:58.383]
    [2024-03-06 07:15:58.449] Starting ATF on ARM64 core...
    [2024-03-06 07:15:58.449] NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
    [2024-03-06 07:15:58.449] NOTICE:  BL31: Built : 16:35:46, May 30 2022
    [2024-03-06 07:15:59.616]
    [2024-03-06 07:15:59.616] U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
    [2024-03-06 07:15:59.634] SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
    [2024-03-06 07:15:59.634] Trying to boot from MMC2
    [2024-03-06 07:16:01.296]
    [2024-03-06 07:16:01.296] U-Boot 2021.01-00002-g77bcc61275-dirty (Mar 05 2024 - 14:51:41 +0800)
    [2024-03-06 07:16:01.296] SoC:   AM62X SR1.0
    [2024-03-06 07:16:01.296] Model: Texas Instruments AM625 SK
    [2024-03-06 07:16:01.358] EEPROM not available at 0x50, trying to read at 0x51
    [2024-03-06 07:16:01.375] Board: AM62-SKEVM rev E3
    [2024-03-06 07:16:01.375] DRAM:  2 GiB
    [2024-03-06 07:16:01.426] MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    [2024-03-06 07:16:01.472] Loading Environment from MMC... *** Warning - bad CRC, using default environment
    [2024-03-06 07:16:01.522]
    [2024-03-06 07:16:01.522] In:    serial@2800000
    [2024-03-06 07:16:01.522] Out:   serial@2800000
    [2024-03-06 07:16:01.535] Err:   serial@2800000
    [2024-03-06 07:16:01.551] Net:   eth0: ethernet@8000000port@1
    [2024-03-06 07:16:01.567] Hit any key to stop autoboot:  2  1  0
    [2024-03-06 07:16:03.598] switch to partitions #0, OK
    [2024-03-06 07:16:03.598] mmc1 is current device
    [2024-03-06 07:16:03.629] SD/MMC found on device 1
    [2024-03-06 07:16:03.647] Failed to load 'boot.scr'
    [2024-03-06 07:16:03.647] Failed to load 'uEnv.txt'
    [2024-03-06 07:16:04.429] 19147264 bytes read in 775 ms (23.6 MiB/s)
    [2024-03-06 07:16:04.447] 33012 bytes read in 12 ms (2.6 MiB/s)
    [2024-03-06 07:16:04.447] ## Flattened Device Tree blob at 88000000
    [2024-03-06 07:16:04.463]    Booting using the fdt blob at 0x88000000
    [2024-03-06 07:16:04.463]    Loading Device Tree to 000000008fef4000, end 000000008fffffff ... OK
    [2024-03-06 07:16:04.480]
    [2024-03-06 07:16:04.480] Starting kernel ...
    [2024-03-06 07:16:04.671] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [2024-03-06 07:16:04.687] [    0.000000] Linux version 5.10.168-g2c23e6c538 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (a
    [2024-03-06 07:16:04.687] rm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Feb 24 05:59:04 U
    [2024-03-06 07:16:04.704] TC 2023
    [2024-03-06 07:16:04.704] [    0.000000] Machine model: Texas Instruments AM625 SK
    [2024-03-06 07:16:04.717] [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [2024-03-06 07:16:04.717] [    0.000000] printk: bootconsole [ns16550a0] enabled
    [2024-03-06 07:16:04.717] [    0.000000] efi: UEFI not found.
    [2024-03-06 07:16:04.734] [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [2024-03-06 07:16:04.734] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool
    [2024-03-06 07:16:04.784] [    0.000000] Zone ranges:
    [2024-03-06 07:16:04.804] [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [2024-03-06 07:16:04.804] [    0.000000]   DMA32    empty
    [2024-03-06 07:16:04.804] [    0.000000]   Normal   empty
    [2024-03-06 07:16:04.804] [    0.000000] Movable zone start for each node
    [2024-03-06 07:16:04.814] [    0.000000] Early memory node ranges
    [2024-03-06 07:16:04.814] [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009dafffff]
    [2024-03-06 07:16:04.814] [    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
    [2024-03-06 07:16:04.830] [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [2024-03-06 07:16:04.830] [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [2024-03-06 07:16:04.830] [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [2024-03-06 07:16:04.847] [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [2024-03-06 07:16:04.864] [    0.000000] cma: Reserved 512 MiB at 0x00000000dd000000
    [2024-03-06 07:16:04.884] [    0.000000] psci: probing for conduit method from DT.
    [2024-03-06 07:16:04.884] [    0.000000] psci: PSCIv1.1 detected in firmware.
    [2024-03-06 07:16:04.884] [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [2024-03-06 07:16:04.899] [    0.000000] psci: Trusted OS migration not required
    [2024-03-06 07:16:04.899] [    0.000000] psci: SMC Calling Convention v1.2
    [2024-03-06 07:16:04.899] [    0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112
    [2024-03-06 07:16:04.915] [    0.000000] Detected VIPT I-cache on CPU0
    [2024-03-06 07:16:04.915] [    0.000000] CPU features: detected: ARM erratum 845719
    [2024-03-06 07:16:04.915] [    0.000000] CPU features: detected: GIC system register CPU interface
    [2024-03-06 07:16:04.926] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [2024-03-06 07:16:04.926] [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=c879998c-02 rw rootfstype=ext4 rootwait
    [2024-03-06 07:16:04.950] [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [2024-03-06 07:16:04.950] [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [2024-03-06 07:16:04.963] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [2024-03-06 07:16:05.007] [    0.000000] Memory: 1476040K/2097152K available (11200K kernel code, 1162K rwdata, 4308K rodata, 1920K init, 431K bss, 96824K reserved, 524288K cma-reser
    [2024-03-06 07:16:05.023] ved)
    [2024-03-06 07:16:05.023] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [2024-03-06 07:16:05.038] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [2024-03-06 07:16:05.038] [    0.000000] rcu: 	RCU event tracing is enabled.
    [2024-03-06 07:16:05.038] [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [2024-03-06 07:16:05.056] [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [2024-03-06 07:16:05.056] [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [2024-03-06 07:16:05.056] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [2024-03-06 07:16:05.071] [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [2024-03-06 07:16:05.071] [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [2024-03-06 07:16:05.087] [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [2024-03-06 07:16:05.087] [    0.000000] GICv3: 256 SPIs implemented
    [2024-03-06 07:16:05.087] [    0.000000] GICv3: 0 Extended SPIs implemented
    [2024-03-06 07:16:05.087] [    0.000000] GICv3: Distributor has no Range Selector support
    [2024-03-06 07:16:05.102] [    0.000000] GICv3: 16 PPIs implemented
    [2024-03-06 07:16:05.102] [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [2024-03-06 07:16:05.102] [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [2024-03-06 07:16:05.119] [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [2024-03-06 07:16:05.119] [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [2024-03-06 07:16:05.139] [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [2024-03-06 07:16:05.139] [    0.000000] ITS: using cache flushing for cmd queue
    [2024-03-06 07:16:05.149] [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [2024-03-06 07:16:05.149] [    0.000000] GIC: using cache flushing for LPI property table
    [2024-03-06 07:16:05.149] [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [2024-03-06 07:16:05.168] [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [2024-03-06 07:16:05.168] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [2024-03-06 07:16:05.183] [    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [2024-03-06 07:16:05.200] [    0.008478] Console: colour dummy device 80x25
    [2024-03-06 07:16:05.200] [    0.013070] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [2024-03-06 07:16:05.200] [    0.023752] pid_max: default: 32768 minimum: 301
    [2024-03-06 07:16:05.216] [    0.028561] LSM: Security Framework initializing
    [2024-03-06 07:16:05.216] [    0.033348] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [2024-03-06 07:16:05.232] [    0.040929] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [2024-03-06 07:16:05.232] [    0.050677] rcu: Hierarchical SRCU implementation.
    [2024-03-06 07:16:05.232] [    0.055870] Platform MSI: msi-controller@1820000 domain created
    [2024-03-06 07:16:05.248] [    0.062120] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [2024-03-06 07:16:05.248] [    0.071343] EFI services will not be available.
    [2024-03-06 07:16:05.262] [    0.076130] smp: Bringing up secondary CPUs ...
    [2024-03-06 07:16:05.281] [    0.091961] Detected VIPT I-cache on CPU1
    [2024-03-06 07:16:05.281] [    0.092000] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [2024-03-06 07:16:05.281] [    0.092014] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [2024-03-06 07:16:05.296] [    0.092076] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [2024-03-06 07:16:05.296] [    0.092200] smp: Brought up 1 node, 2 CPUs
    [2024-03-06 07:16:05.315] [    0.121585] SMP: Total of 2 processors activated.
    [2024-03-06 07:16:05.315] [    0.126399] CPU features: detected: 32-bit EL0 Support
    [2024-03-06 07:16:05.315] [    0.131669] CPU features: detected: CRC32 instructions
    [2024-03-06 07:16:05.327] [    0.144517] CPU: All CPU(s) started at EL2
    [2024-03-06 07:16:05.327] [    0.148723] alternatives: patching kernel code
    [2024-03-06 07:16:05.343] [    0.154391] devtmpfs: initialized
    [2024-03-06 07:16:05.343] [    0.162985] KASLR disabled due to lack of seed
    [2024-03-06 07:16:05.344] [    0.167746] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [2024-03-06 07:16:05.358] [    0.177724] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [2024-03-06 07:16:05.375] [    0.199423] pinctrl core: initialized pinctrl subsystem
    [2024-03-06 07:16:05.390] [    0.205456] DMI not present or invalid.
    [2024-03-06 07:16:05.390] [    0.210076] NET: Registered protocol family 16
    [2024-03-06 07:16:05.408] [    0.216259] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [2024-03-06 07:16:05.408] [    0.223608] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [2024-03-06 07:16:05.408] [    0.231682] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [2024-03-06 07:16:05.424] [    0.240349] thermal_sys: Registered thermal governor 'step_wise'
    [2024-03-06 07:16:05.424] [    0.240354] thermal_sys: Registered thermal governor 'power_allocator'
    [2024-03-06 07:16:05.439] [    0.246722] cpuidle: using governor menu
    [2024-03-06 07:16:05.439] [    0.257629] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [2024-03-06 07:16:05.453] [    0.264631] ASID allocator initialised with 65536 entries
    [2024-03-06 07:16:05.470] [    0.291244] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [2024-03-06 07:16:05.487] [    0.298124] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [2024-03-06 07:16:05.487] [    0.304978] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [2024-03-06 07:16:05.487] [    0.311830] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [2024-03-06 07:16:05.503] [    0.319794] cryptd: max_cpu_qlen set to 1000
    [2024-03-06 07:16:05.503] [    0.327109] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [2024-03-06 07:16:05.519] [    0.336132] vcc_5v0: supplied by vmain_pd
    [2024-03-06 07:16:05.519] [    0.340704] vcc_3v3_sys: supplied by vmain_pd
    [2024-03-06 07:16:05.533] [    0.345691] vcc_1v8: supplied by vcc_3v3_sys
    [2024-03-06 07:16:05.533] [    0.351072] iommu: Default domain type: Translated
    [2024-03-06 07:16:05.533] [    0.356419] SCSI subsystem initialized
    [2024-03-06 07:16:05.551] [    0.360640] mc: Linux media interface: v0.10
    [2024-03-06 07:16:05.551] [    0.365031] videodev: Linux video capture interface: v2.00
    [2024-03-06 07:16:05.551] [    0.370707] pps_core: LinuxPPS API ver. 1 registered
    [2024-03-06 07:16:05.551] [    0.375784] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [2024-03-06 07:16:05.568] [    0.385133] PTP clock support registered
    [2024-03-06 07:16:05.568] [    0.389173] EDAC MC: Ver: 3.0.0
    [2024-03-06 07:16:05.583] [    0.393000] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [2024-03-06 07:16:05.583] [    0.400115] FPGA manager framework
    [2024-03-06 07:16:05.583] [    0.403702] Advanced Linux Sound Architecture Driver Initialized.
    [2024-03-06 07:16:05.598] [    0.410835] clocksource: Switched to clocksource arch_sys_counter
    [2024-03-06 07:16:05.598] [    0.417298] VFS: Disk quotas dquot_6.6.0
    [2024-03-06 07:16:05.598] [    0.421367] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [2024-03-06 07:16:05.614] [    0.433858] NET: Registered protocol family 2
    [2024-03-06 07:16:05.614] [    0.438609] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [2024-03-06 07:16:05.630] [    0.447381] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [2024-03-06 07:16:05.630] [    0.456165] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [2024-03-06 07:16:05.648] [    0.464374] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [2024-03-06 07:16:05.648] [    0.472109] TCP: Hash tables configured (established 16384 bind 16384)
    [2024-03-06 07:16:05.664] [    0.479000] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [2024-03-06 07:16:05.664] [    0.485900] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [2024-03-06 07:16:05.681] [    0.493371] NET: Registered protocol family 1
    [2024-03-06 07:16:05.681] [    0.498333] RPC: Registered named UNIX socket transport module.
    [2024-03-06 07:16:05.696] [    0.504424] RPC: Registered udp transport module.
    [2024-03-06 07:16:05.696] [    0.509235] RPC: Registered tcp transport module.
    [2024-03-06 07:16:05.696] [    0.514044] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [2024-03-06 07:16:05.712] [    0.520636] NET: Registered protocol family 44
    [2024-03-06 07:16:05.712] [    0.525196] PCI: CLS 0 bytes, default 64
    [2024-03-06 07:16:05.712] [    0.529912] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [2024-03-06 07:16:05.731] [    0.541948] Initialise system trusted keyrings
    [2024-03-06 07:16:05.731] [    0.546717] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [2024-03-06 07:16:05.748] [    0.557181] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [2024-03-06 07:16:05.748] [    0.563744] NFS: Registering the id_resolver key type
    [2024-03-06 07:16:05.763] [    0.568999] Key type id_resolver registered
    [2024-03-06 07:16:05.763] [    0.573276] Key type id_legacy registered
    [2024-03-06 07:16:05.763] [    0.577435] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [2024-03-06 07:16:05.781] [    0.584290] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [2024-03-06 07:16:05.781] [    0.592044] 9p: Installing v9fs 9p2000 file system support
    [2024-03-06 07:16:05.824] [    0.634191] Key type asymmetric registered
    [2024-03-06 07:16:05.824] [    0.638388] Asymmetric key parser 'x509' registered
    [2024-03-06 07:16:05.824] [    0.643419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [2024-03-06 07:16:05.840] [    0.650985] io scheduler mq-deadline registered
    [2024-03-06 07:16:05.840] [    0.655623] io scheduler kyber registered
    [2024-03-06 07:16:05.840] [    0.661541] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [2024-03-06 07:16:05.865] [    0.667887] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [2024-03-06 07:16:05.874] [    0.680484] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [2024-03-06 07:16:05.890] [    0.699411] brd: module loaded
    [2024-03-06 07:16:05.890] [    0.708983] loop: module loaded
    [2024-03-06 07:16:05.903] [    0.713029] megasas: 07.714.04.00-rc1
    [2024-03-06 07:16:05.903] [    0.720244] tun: Universal TUN/TAP device driver, 1.6
    [2024-03-06 07:16:05.903] [    0.725932] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [2024-03-06 07:16:05.918] [    0.732356] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [2024-03-06 07:16:05.918] [    0.738465] sky2: driver version 1.30
    [2024-03-06 07:16:05.918] [    0.743069] VFIO - User Level meta-driver version: 0.3
    [2024-03-06 07:16:05.936] [    0.749303] i2c /dev entries driver
    [2024-03-06 07:16:05.936] [    0.753971] cpu cpu0: OPP-v2 not supported, cpufreq-dt will attempt to use legacy tables.
    [2024-03-06 07:16:05.953] [    0.762608] cpu cpu0: cpufreq_init: failed to get clk: -2
    [2024-03-06 07:16:05.954] [    0.768190] cpu cpu0: cpufreq_init: failed to get clk: -2
    [2024-03-06 07:16:05.954] [    0.774038] sdhci: Secure Digital Host Controller Interface driver
    [2024-03-06 07:16:05.968] [    0.780362] sdhci: Copyright(c) Pierre Ossman
    [2024-03-06 07:16:05.968] [    0.785098] sdhci-pltfm: SDHCI platform and OF driver helper
    [2024-03-06 07:16:05.968] [    0.791782] ledtrig-cpu: registered to indicate activity on CPUs
    [2024-03-06 07:16:05.984] [    0.798246] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [2024-03-06 07:16:05.984] [    0.806028] optee: probing for conduit method.
    [2024-03-06 07:16:05.999] [    0.810626] optee: revision 3.12 (3d47a131)
    [2024-03-06 07:16:05.999] [    0.811118] optee: initialized driver
    [2024-03-06 07:16:05.999] [    0.820920] NET: Registered protocol family 17
    [2024-03-06 07:16:06.014] [    0.825652] 9pnet: Installing 9P2000 support
    [2024-03-06 07:16:06.014] [    0.830099] Key type dns_resolver registered
    [2024-03-06 07:16:06.014] [    0.834884] Loading compiled-in X.509 certificates
    [2024-03-06 07:16:06.029] [    0.849911] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
    [2024-03-06 07:16:06.547] [    1.357127] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [2024-03-06 07:16:06.598] [    1.407733] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [2024-03-06 07:16:06.615] [    1.418795] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [2024-03-06 07:16:06.615] [    1.425108] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [2024-03-06 07:16:06.634] [    1.433530] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [2024-03-06 07:16:06.634] [    1.442883] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [2024-03-06 07:16:06.641] [    1.451929] ti-udma 485c0100.dma-controller: Number of rings: 82
    [2024-03-06 07:16:06.641] [    1.459981] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [2024-03-06 07:16:06.655] [    1.471086] ti-udma 485c0000.dma-controller: Number of rings: 150
    [2024-03-06 07:16:06.671] [    1.480950] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [2024-03-06 07:16:06.671] [    1.491404] printk: console [ttyS2] disabled
    [2024-03-06 07:16:06.671] [    1.495854] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
    [2024-03-06 07:16:06.688] [    1.504625] printk: console [ttyS2] enabled
    [2024-03-06 07:16:06.715] [    1.513069] printk: bootconsole [ns16550a0] disabled
    [2024-03-06 07:16:06.757] [    1.569722] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [2024-03-06 07:16:06.757] [    1.574763] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [2024-03-06 07:16:06.771] [    1.581716] Creating 7 MTD partitions on "fc40000.spi.0":
    [2024-03-06 07:16:06.771] [    1.587111] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [2024-03-06 07:16:06.783] [    1.593765] 0x000000080000-0x000000280000 : "ospi.tispl"
    [2024-03-06 07:16:06.783] [    1.600085] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [2024-03-06 07:16:06.783] [    1.606422] 0x000000680000-0x0000006c0000 : "ospi.env"
    [2024-03-06 07:16:06.798] [    1.612494] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [2024-03-06 07:16:06.798] [    1.619183] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [2024-03-06 07:16:06.815] [    1.625506] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [2024-03-06 07:16:06.852] [    1.664922] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [2024-03-06 07:16:06.901] [    1.710863] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2024-03-06 07:16:06.914] [    1.720536] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [2024-03-06 07:16:06.914] [    1.728641] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [2024-03-06 07:16:06.928] [    1.736819] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [2024-03-06 07:16:06.928] [    1.749661] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [2024-03-06 07:16:06.942] [    1.756790] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [2024-03-06 07:16:06.958] [    1.768764] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [2024-03-06 07:16:06.958] [    1.779026] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [2024-03-06 07:16:06.990] [    1.800291] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [2024-03-06 07:16:06.990] [    1.805506] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
    [2024-03-06 07:16:07.022] [    1.846994] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [2024-03-06 07:16:07.068] [    1.895116] mmc0: CQHCI version 5.10
    [2024-03-06 07:16:07.118] [    1.939919] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [2024-03-06 07:16:07.204] [    2.011984] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [2024-03-06 07:16:07.204] [    2.019983] pca953x 1-0022: supply vcc not found, using dummy regulator
    [2024-03-06 07:16:07.214] [    2.026731] pca953x 1-0022: using AI
    [2024-03-06 07:16:07.214] [    2.030197] mmc0: mmc_select_hs200 failed, error -110
    [2024-03-06 07:16:07.214] [    2.035351] mmc0: error -110 whilst initialising MMC card
    [2024-03-06 07:16:07.231] [    2.054340] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [2024-03-06 07:16:07.247] [    2.061255] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [2024-03-06 07:16:07.247] [    2.070628] i2c i2c-1: Added multiplexed i2c bus 2
    [2024-03-06 07:16:07.335] [    2.140659] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [2024-03-06 07:16:07.335] [    2.148415] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [2024-03-06 07:16:07.359] [    2.174718] mmc0: mmc_select_hs200 failed, error -110
    [2024-03-06 07:16:07.359] [    2.179774] mmc0: error -110 whilst initialising MMC card
    [2024-03-06 07:16:07.380] [    2.189681] vdd_mmc1: supplied by vcc_3v3_sys
    [2024-03-06 07:16:07.380] [    2.195951] wlan_lten: supplied by vcc_3v3_sys
    [2024-03-06 07:16:07.389] [    2.201154] wlan_en: supplied by wlan_lten
    [2024-03-06 07:16:07.389] [    2.206073] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [2024-03-06 07:16:07.407] [    2.220230] mmc1: CQHCI version 5.10
    [2024-03-06 07:16:07.407] [    2.224381] mmc2: CQHCI version 5.10
    [2024-03-06 07:16:07.439] [    2.257220] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [2024-03-06 07:16:07.453] [    2.262716] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [2024-03-06 07:16:07.453] [    2.277212] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
    [2024-03-06 07:16:07.487] [    2.297483] mmc2: new high speed SDIO card at address 0001
    [2024-03-06 07:16:07.504] [    2.312785] mmc1: new high speed SDHC card at address aaaa
    [2024-03-06 07:16:07.504] [    2.319021] mmcblk1: mmc1:aaaa SS32G 29.7 GiB
    [2024-03-06 07:16:07.504] [    2.325562]  mmcblk1: p1 p2
    [2024-03-06 07:16:07.520] [    2.339756] mmc0: mmc_select_hs200 failed, error -110
    [2024-03-06 07:16:07.533] [    2.344839] mmc0: error -110 whilst initialising MMC card
    [2024-03-06 07:16:07.580] [    2.398554] ALSA device list:
    [2024-03-06 07:16:07.580] [    2.401529]   No soundcards found.
    [2024-03-06 07:16:07.736] [    2.539647] mmc0: mmc_select_hs200 failed, error -110
    [2024-03-06 07:16:07.736] [    2.544769] mmc0: error -110 whilst initialising MMC card
    [2024-03-06 07:16:07.796] [    2.607145] EXT4-fs (mmcblk1p2): recovery complete
    [2024-03-06 07:16:07.796] [    2.613388] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [2024-03-06 07:16:07.807] [    2.621549] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [2024-03-06 07:16:07.807] [    2.630132] devtmpfs: mounted
    [2024-03-06 07:16:07.823] [    2.634462] Freeing unused kernel memory: 1920K
    [2024-03-06 07:16:07.823] [    2.639100] Run /sbin/init as init process
    [2024-03-06 07:16:08.179] [    2.988085] systemd[1]: System time before build time, advancing clock.
    [2024-03-06 07:16:08.264] [    3.072924] NET: Registered protocol family 10
    [2024-03-06 07:16:08.264] [    3.078512] Segment Routing with IPv6
    [2024-03-06 07:16:08.303] [    3.124285] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS
    [2024-03-06 07:16:08.321]  +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [2024-03-06 07:16:08.332] [    3.146284] systemd[1]: Detected architecture arm64.
    [2024-03-06 07:16:08.365]
    [2024-03-06 07:16:08.365] Welcome to Arago 2021.09!
    [2024-03-06 07:16:08.380] [    3.192107] systemd[1]: Set hostname to <am62xx-evm>.
    [2024-03-06 07:16:08.686] [    3.509409] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [2024-03-06 07:16:08.713] [    3.521998] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [2024-03-06 07:16:08.735] [    3.546712] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
    [2024-03-06 07:16:08.765] [    3.578912] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.s
    [2024-03-06 07:16:08.784] ock → /run/docker.sock; please update the unit file accordingly.
    [2024-03-06 07:16:08.879] [    3.697547] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:08.896] [    3.708228] systemd[1]: Created slice system-getty.slice.
    [2024-03-06 07:16:08.896] [  OK  ] Created slice system-getty.slice.
    [2024-03-06 07:16:08.911] [    3.731035] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:08.932] [    3.739597] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [2024-03-06 07:16:08.932] [  OK  ] Created slice system-serial\x2dgetty.slice.
    [2024-03-06 07:16:08.953] [    3.763077] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:08.959] [    3.771494] systemd[1]: Created slice User and Session Slice.
    [2024-03-06 07:16:08.959] [  OK  ] Created slice User and Session Slice.
    [2024-03-06 07:16:08.972] [    3.795398] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [2024-03-06 07:16:08.992] [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [2024-03-06 07:16:09.011] [    3.819195] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [2024-03-06 07:16:09.011] [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [2024-03-06 07:16:09.021] [    3.843152] systemd[1]: Reached target Paths.
    [2024-03-06 07:16:09.021] [  OK  ] Reached target Paths.
    [2024-03-06 07:16:09.036] [    3.862997] systemd[1]: Reached target Remote File Systems.
    [2024-03-06 07:16:09.054] [  OK  ] Reached target Remote File Systems.
    [2024-03-06 07:16:09.068] [    3.882971] systemd[1]: Reached target Slices.
    [2024-03-06 07:16:09.069] [  OK  ] Reached target Slices.
    [2024-03-06 07:16:09.085] [    3.902996] systemd[1]: Reached target Swap.
    [2024-03-06 07:16:09.085] [  OK  ] Reached target Swap.
    [2024-03-06 07:16:09.147] [    3.950718] systemd[1]: Listening on RPCbind Server Activation Socket.
    [2024-03-06 07:16:09.147] [  OK  ] Listening on RPCbind Server Activation Socket.
    [2024-03-06 07:16:09.150] [    3.975198] systemd[1]: Reached target RPC Port Mapper.
    [2024-03-06 07:16:09.165] [  OK  ] Reached target RPC Port Mapper.
    [2024-03-06 07:16:09.184] [    4.000262] systemd[1]: Listening on Process Core Dump Socket.
    [2024-03-06 07:16:09.184] [  OK  ] Listening on Process Core Dump Socket.
    [2024-03-06 07:16:09.200] [    4.023378] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [2024-03-06 07:16:09.215] [  OK  ] Listening on initctl Compatibility Named Pipe.
    [2024-03-06 07:16:09.229] [    4.050487] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [2024-03-06 07:16:09.246] [    4.059431] systemd[1]: Listening on Journal Socket (/dev/log).
    [2024-03-06 07:16:09.246] [  OK  ] Listening on Journal Socket (/dev/log).
    [2024-03-06 07:16:09.262] [    4.083639] systemd[1]: Listening on Journal Socket.
    [2024-03-06 07:16:09.279] [  OK  ] Listening on Journal Socket.
    [2024-03-06 07:16:09.279] [    4.099784] systemd[1]: Listening on Network Service Netlink Socket.
    [2024-03-06 07:16:09.301] [  OK  ] Listening on Network Service Netlink Socket.
    [2024-03-06 07:16:09.318] [    4.123588] systemd[1]: Listening on udev Control Socket.
    [2024-03-06 07:16:09.318] [  OK  ] Listening on udev Control Socket.
    [2024-03-06 07:16:09.328] [    4.143369] systemd[1]: Listening on udev Kernel Socket.
    [2024-03-06 07:16:09.328] [  OK  ] Listening on udev Kernel Socket.
    [2024-03-06 07:16:09.361] [    4.167912] systemd[1]: Mounting Huge Pages File System...
    [2024-03-06 07:16:09.361]          Mounting Huge Pages File System...
    [2024-03-06 07:16:09.380] [    4.188076] systemd[1]: Mounting POSIX Message Queue File System...
    [2024-03-06 07:16:09.380]          Mounting POSIX Message Queue File System...
    [2024-03-06 07:16:09.414] [    4.215929] systemd[1]: Mounting Kernel Debug File System...
    [2024-03-06 07:16:09.414]          Mounting Kernel Debug File System...
    [2024-03-06 07:16:09.423] [    4.245081] systemd[1]: Mounting Temporary Directory (/tmp)...
    [2024-03-06 07:16:09.438]          Mounting Temporary Directory (/tmp)...
    [2024-03-06 07:16:09.455] [    4.268393] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [2024-03-06 07:16:09.455]          Starting Create list of st…odes for the current kernel...
    [2024-03-06 07:16:09.486] [    4.306003] systemd[1]: Starting Start psplash boot splash screen...
    [2024-03-06 07:16:09.504]          Starting Start psplash boot splash screen...
    [2024-03-06 07:16:09.520] [    4.332519] systemd[1]: Starting RPC Bind...
    [2024-03-06 07:16:09.520]          Starting RPC Bind...
    [2024-03-06 07:16:09.535] [    4.351312] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [2024-03-06 07:16:09.552] [    4.367942] systemd[1]: Starting Journal Service...
    [2024-03-06 07:16:09.552]          Starting Journal Service...
    [2024-03-06 07:16:09.588] [    4.397543] systemd[1]: Starting Load Kernel Modules...
    [2024-03-06 07:16:09.588]          Starting Load Kernel Modules...
    [2024-03-06 07:16:09.604] [    4.420275] systemd[1]: Starting Remount Root and Kernel File Systems...
    [2024-03-06 07:16:09.616]          Starting Remount Root and Kernel File Systems...
    [2024-03-06 07:16:09.616] [    4.436460] cryptodev: loading out-of-tree module taints kernel.
    [2024-03-06 07:16:09.629] [    4.452484] systemd[1]: Starting udev Coldplug all Devices...
    [2024-03-06 07:16:09.647]          Starting udev Coldplug all Devices...
    [2024-03-06 07:16:09.647] [    4.468159] cryptodev: driver 1.10 loaded.
    [2024-03-06 07:16:09.662] [    4.482493] systemd[1]: Started RPC Bind.
    [2024-03-06 07:16:09.679] [  OK  ] Started RPC Bind.
    [2024-03-06 07:16:09.679] [    4.492650] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [2024-03-06 07:16:09.694] [    4.505119] systemd[1]: Started Journal Service.
    [2024-03-06 07:16:09.694] [  OK  ] Started Journal Service.
    [2024-03-06 07:16:09.711] [  OK  ] Mounted Huge Pages File System.
    [2024-03-06 07:16:09.747] [  OK  ] Mounted POSIX Message Queue File System.
    [2024-03-06 07:16:09.763] [  OK  ] Mounted Kernel Debug File System.
    [2024-03-06 07:16:09.779] [  OK  ] Mounted Temporary Directory (/tmp).
    [2024-03-06 07:16:09.791] [  OK  ] Started Create list of sta… nodes for the current kernel.
    [2024-03-06 07:16:09.805] [FAILED] Failed to start Start psplash boot splash screen.
    [2024-03-06 07:16:09.822] See 'systemctl status psplash-start.service' for details.
    [2024-03-06 07:16:09.845] [DEPEND] Dependency failed for Star…progress communication helper.
    [2024-03-06 07:16:09.855] [  OK  ] Started Load Kernel Modules.
    [2024-03-06 07:16:09.871] [  OK  ] Started Remount Root and Kernel File Systems.
    [2024-03-06 07:16:09.885] [    4.711316] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:09.902] [    4.719862] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:09.930]          Mounting Kernel Configuration File System...
    [2024-03-06 07:16:09.930] [    4.742067] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:09.946]          Starting Flush Journal to Persistent Storage...
    [2024-03-06 07:16:09.964]          Starting Apply Kernel Variables...[    4.783461] systemd-journald[171]: Received client request to flush runtime journal.
    [2024-03-06 07:16:09.983]
    [2024-03-06 07:16:10.005]          Starting Create Static Device Nodes in /dev...
    [2024-03-06 07:16:10.022] [  OK  ] Mounted Kernel Configuration File System.
    [2024-03-06 07:16:10.030] [  OK  ] Started Flush Journal to Persistent Storage.
    [2024-03-06 07:16:10.052] [  OK  ] Started Apply Kernel Variables.
    [2024-03-06 07:16:10.079] [  OK  ] Started Create Static Device Nodes in /dev.
    [2024-03-06 07:16:10.094] [  OK  ] Reached target Local File Systems (Pre).
    [2024-03-06 07:16:10.111]          Mounting /media/ram...
    [2024-03-06 07:16:10.127]          Mounting /var/volatile...
    [2024-03-06 07:16:10.141]          Starting udev Kernel Device Manager...
    [2024-03-06 07:16:10.177] [  OK  ] Started udev Coldplug all Devices.
    [2024-03-06 07:16:10.193] [  OK  ] Mounted /media/ram.
    [2024-03-06 07:16:10.213] [  OK  ] Mounted /var/volatile.
    [2024-03-06 07:16:10.230]          Starting udev Wait for Complete Device Initialization...
    [2024-03-06 07:16:10.238]          Starting Load/Save Random Seed...
    [2024-03-06 07:16:10.255] [  OK  ] Reached target Local File Systems.
    [2024-03-06 07:16:10.267]          Starting Create Volatile Files and Directories...
    [2024-03-06 07:16:10.320] [  OK  ] Started Create Volatile Files and Directories.
    [2024-03-06 07:16:10.334] [  OK  ] Started udev Kernel Device Manager.
    [2024-03-06 07:16:10.365]          Starting Network Time Synchronization...
    [2024-03-06 07:16:10.383]          Starting Update UTMP about System Boot/Shutdown...
    [2024-03-06 07:16:10.415] [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [2024-03-06 07:16:10.621] [  OK  ] Started Network Time Synchronization.
    [2024-03-06 07:16:10.645] [  OK  ] Reached target System Time Set.
    [2024-03-06 07:16:10.653] [  OK  ] Reached target System Time Synchronized.
    [2024-03-06 07:16:10.958] [    5.778771] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:10.977] [    5.789090] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:11.101] [    5.926260] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:11.198] [    6.021979] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
    [2024-03-06 07:16:11.248] [    6.063057] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
    [2024-03-06 07:16:11.293] [    6.114446] remoteproc remoteproc0: releasing 5000000.m4fss
    [2024-03-06 07:16:11.347] [    6.151898] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
    [2024-03-06 07:16:11.765] [    6.569294] PVR_K:  199: Read BVNC 33.15.11.3 from HW device registers
    [2024-03-06 07:16:11.897] [    6.700198] PVR_K:  199: RGX Device registered with BVNC 33.15.11.3
    [2024-03-06 07:16:11.984] [    6.795039] [drm] Initialized pvr 1.15.6133109 20170530 for fd00000.gpu on minor 1
    [2024-03-06 07:16:12.112] [    6.921021] random: systemd: uninitialized urandom read (16 bytes read)
    [2024-03-06 07:16:12.174] [    6.994912] random: crng init done
    [2024-03-06 07:16:12.174] [    6.998342] random: 75 urandom warning(s) missed due to ratelimiting
    [2024-03-06 07:16:12.209] [  OK  ] Started Load/Save Random Seed.
    [2024-03-06 07:16:13.405] [    8.228187] remoteproc remoteproc0: 30074000.pru is available
    [2024-03-06 07:16:13.458] [    8.268723] remoteproc remoteproc1: 30078000.pru is available
    [2024-03-06 07:16:13.468] [    8.292626] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [2024-03-06 07:16:13.492] [    8.302063] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
    [2024-03-06 07:16:13.568] [    8.389535] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [2024-03-06 07:16:13.598]          Starting Start psplash boot splash screen...
    [2024-03-06 07:16:13.633] [FAILED] Failed to start Start psplash boot splash screen.
    [2024-03-06 07:16:13.647] See 'systemctl status psplash-start.service' for details.
    [2024-03-06 07:16:13.662] [DEPEND] Dependency failed for Star…progress communication helper.
    [2024-03-06 07:16:13.677] [    8.494177] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [2024-03-06 07:16:13.693] [    8.510783] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [2024-03-06 07:16:13.724] [  OK  ] Reached target Hardware activated U[    8.550600] usbcore: registered new interface driver usbfs
    [2024-03-06 07:16:13.743] SB gadget.
    [2024-03-06 07:16:13.743] [    8.559480] usbcore: registered new interface driver hub
    [2024-03-06 07:16:13.759] [    8.569097] usbcore: registered new device driver usb
    [2024-03-06 07:16:13.759] [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [2024-03-06 07:16:13.824] [    8.644037] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [2024-03-06 07:16:13.844] [    8.649648] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [2024-03-06 07:16:13.844] [    8.657608] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [2024-03-06 07:16:13.858] [    8.667303] xhci-hcd xhci-hcd.2.auto: irq 489, io mem 0x31100000
    [2024-03-06 07:16:13.858] [    8.673825] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [2024-03-06 07:16:13.858] [    8.679382] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [2024-03-06 07:16:13.876] [    8.687342] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [2024-03-06 07:16:13.876] [    8.694546] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [2024-03-06 07:16:13.892] [    8.702873] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [2024-03-06 07:16:13.892] [    8.710292] usb usb1: Product: xHCI Host Controller
    [2024-03-06 07:16:13.901] [    8.715629] usb usb1: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd
    [2024-03-06 07:16:13.901] [    8.722422] usb usb1: SerialNumber: xhci-hcd.2.auto
    [2024-03-06 07:16:13.919] [    8.728036] hub 1-0:1.0: USB hub found
    [2024-03-06 07:16:13.919] [    8.732129] hub 1-0:1.0: 1 port detected
    [2024-03-06 07:16:13.919] [    8.736865] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [2024-03-06 07:16:13.936] [    8.745249] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [2024-03-06 07:16:13.936] [    8.753697] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [2024-03-06 07:16:13.952] [    8.761133] usb usb2: Product: xHCI Host Controller
    [2024-03-06 07:16:13.952] [    8.766065] usb usb2: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd
    [2024-03-06 07:16:13.952] [    8.772787] usb usb2: SerialNumber: xhci-hcd.2.auto
    [2024-03-06 07:16:13.965] [    8.778713] hub 2-0:1.0: USB hub found
    [2024-03-06 07:16:13.965] [    8.782681] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
    [2024-03-06 07:16:14.013] [    8.832290] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [2024-03-06 07:16:14.162] [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [2024-03-06 07:16:14.261] [  OK  ] Found device /dev/mmcblk1p1.
    [2024-03-06 07:16:14.274] [  OK  ] Started udev Wait for Complete Device Initialization.
    [2024-03-06 07:16:14.284] [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [2024-03-06 07:16:14.317] [  OK  ] Reached target System Initialization.
    [2024-03-06 07:16:14.333] [  OK  ] Started Daily rotation of log files.
    [2024-03-06 07:16:14.351] [  OK  ] Started Daily Cleanup of Temporary Directories.
    [2024-03-06 07:16:14.363] [    9.187421] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [2024-03-06 07:16:14.382] [  OK  ] Reached target Timers.
    [2024-03-06 07:16:14.382] [    9.200701] wlcore: loaded
    [2024-03-06 07:16:14.396] [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [2024-03-06 07:16:14.415] [  OK  ] Listening on D-Bus System Message Bus Socket.
    [2024-03-06 07:16:14.430]          Starting Docker Socket for the API.
    [2024-03-06 07:16:14.465] [  OK  ] Listening on dropbear.socket.
    [2024-03-06 07:16:14.476]          Starting Reboot and dump vmcore via kexec...
    [2024-03-06 07:16:14.495]          Starting File System Check on /dev/mmcblk1p1...
    [2024-03-06 07:16:14.510] [  OK  ] Listening on Docker Socket for the API.
    [2024-03-06 07:16:14.526] [  OK  ] Reached target Sockets.
    [2024-03-06 07:16:14.526] [  OK  ] Reached target Basic System.
    [2024-03-06 07:16:14.542]          Starting Save/Restore Sound Card State...
    [2024-03-06 07:16:14.566] [  OK  ] Started Job spooling tools.
    [2024-03-06 07:16:14.573] [  OK  ] Started Periodic Command Scheduler.
    [2024-03-06 07:16:14.573] [  OK  ] Started D-Bus System Message Bus.
    [2024-03-06 07:16:14.611]          Starting Print notice about GPLv3 packages...
    [2024-03-06 07:16:14.623]          Starting IPv6 Packet Filtering Framework...
    [2024-03-06 07:16:14.623]          Starting IPv4 Packet Filtering Framework...
    [2024-03-06 07:16:14.651] [  OK  ] Started irqbalance daemon.
    [2024-03-06 07:16:14.658]          Starting rc.pvr.service...
    [2024-03-06 07:16:14.670]          Starting startwlanap...
    [2024-03-06 07:16:14.689]          Starting startwlansta...
    [2024-03-06 07:16:14.708]          Starting Login Service...
    [2024-03-06 07:16:14.723]          Starting Load/Save RF Kill Switch Status...
    [2024-03-06 07:16:14.816] [  OK  ] Started TEE Supplicant.
    [2024-03-06 07:16:14.830] [  OK  ] Started Load/Save RF Kill Switch Status.
    [2024-03-06 07:16:14.850] [  OK  ] Started Reboot and dump vmcore via kexec.
    [2024-03-06 07:16:14.850] [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [2024-03-06 07:16:14.863] [  OK  ] Started Save/Restore Sound Card State.
    [2024-03-06 07:16:14.863] [  OK  ] Started IPv6 Packet Filtering Framework.
    [2024-03-06 07:16:14.878] [  OK  ] Started IPv4 Packet Filtering Framework.
    [2024-03-06 07:16:14.893] [  OK  ] Started startwlanap.
    [2024-03-06 07:16:14.893] [  OK  ] Started startwlansta.
    [2024-03-06 07:16:14.893] [  OK  ] Reached target Network (Pre).
    [2024-03-06 07:16:14.893] [  OK  ] Reached target Sound Card.
    [2024-03-06 07:16:14.915]          Mounting /run/media/mmcblk1p1...
    [2024-03-06 07:16:14.915]          Starting Network Service...
    [2024-03-06 07:16:15.063] [  OK  ] Mounted /run/media/mmcblk1p1.
    [2024-03-06 07:16:15.310] [  OK  ] Started Network Service.
    [2024-03-06 07:16:15.310]          Starting Wait for Network to be Configured...
    [2024-03-06 07:16:15.327]          Starting Network Name Resolution...
    [2024-03-06 07:16:15.592] [  OK  ] Started Login Service.
    [2024-03-06 07:16:15.745] [   10.562207] wlcore: using inverted interrupt logic: 2
    [2024-03-06 07:16:15.825] [   10.635066] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [2024-03-06 07:16:15.918] [   10.738491] wlcore: firmware booted (Rev 8.9.0.0.86)
    [2024-03-06 07:16:15.968] [  OK  ] Started Network Name Resolution.
    [2024-03-06 07:16:15.968] [  OK  ] Reached target Network.
    [2024-03-06 07:16:15.968] [  OK  ] Reached target Host and Network Name Lookups.
    [2024-03-06 07:16:15.981]          Starting Avahi mDNS/DNS-SD Stack...
    [2024-03-06 07:16:15.999]          Starting Enable and configure wl18xx bluetooth stack...
    [2024-03-06 07:16:16.026] [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    [2024-03-06 07:16:16.040]          Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
    [2024-03-06 07:16:16.045]          Starting Permit User Sessions...
    [2024-03-06 07:16:16.095] [   10.912242] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [2024-03-06 07:16:16.115] [  OK  ] Started Permit User Sessions.
    [2024-03-06 07:16:16.126] [  OK  ] Started Getty on tty1.
    [2024-03-06 07:16:16.140] [  OK  ] Started Serial Getty on ttyS2.
    [2024-03-06 07:16:16.140] [  OK  ] Reached target Login Prompts.
    [2024-03-06 07:16:16.159]          Starting Synchronize System and HW clocks...
    [2024-03-06 07:16:16.187] [   10.886271] startwlansta.sh[586]: Wi-Fi user configuration file missing, exit
    [2024-03-06 07:16:16.222] [   11.032426] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [2024-03-06 07:16:16.254] [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [2024-03-06 07:16:16.254] [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [2024-03-06 07:16:16.317] [   11.142207] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [2024-03-06 07:16:16.348] [   11.165343] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [2024-03-06 07:16:16.527] [  OK  ] Started rc.pvr.service.
    [2024-03-06 07:16:16.543]          Starting weston.service...
    [2024-03-06 07:16:16.612] [   11.295609] startwlanap.sh[676]: adding wlan1 interface
    [2024-03-06 07:16:16.840] [   11.523094] startwlanap.sh[685]: Configuration file: /usr/share/wl18xx/hostapd.conf
    [2024-03-06 07:16:16.874] [   11.675799] wlcore: down
    [2024-03-06 07:16:16.890] [   11.571670] startwlanap.sh[685]: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
    [2024-03-06 07:16:16.958] [   11.646425] startwlanap.sh[685]: Using interface wlan1 with hwaddr 3c:e4:b0:74:1b:35 and ssid "AM62xSK-AP_b0741b"
    [2024-03-06 07:16:17.008] [   11.816958] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
    [2024-03-06 07:16:17.037] [   11.734697] startwlanap.sh[685]: wlan1: interface state COUNTRY_UPDATE->ENABLED
    [2024-03-06 07:16:17.054] [   11.735150] startwlanap.sh[685]: wlan1: AP-ENABLED
    [2024-03-06 07:16:17.181] [  OK  ] Started Synchronize System and HW clocks.
    [2024-03-06 07:16:17.199] [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [2024-03-06 07:16:18.638] ***************************************************************
    [2024-03-06 07:16:18.657] ***************************************************************
    [2024-03-06 07:16:18.657] NOTICE: This file system contains the following GPLv3 packages:
    [2024-03-06 07:16:18.657] 	autoconf
    [2024-03-06 07:16:18.657] 	bash-dev
    [2024-03-06 07:16:18.676] 	bash
    [2024-03-06 07:16:18.676] 	bc
    [2024-03-06 07:16:18.676] 	binutils
    [2024-03-06 07:16:18.676] 	cifs-utils
    [2024-03-06 07:16:18.676] 	coreutils-stdbuf
    [2024-03-06 07:16:18.676] 	cpio
    [2024-03-06 07:16:18.676] 	cpp-symlinks
    [2024-03-06 07:16:18.676] 	dosfstools
    [2024-03-06 07:16:18.676] 	elfutils
    [2024-03-06 07:16:18.676] 	g++-symlinks
    [2024-03-06 07:16:18.676] 	gawk
    [2024-03-06 07:16:18.676] 	gcc-symlinks
    [2024-03-06 07:16:18.676] 	gdb
    [2024-03-06 07:16:18.676] 	gdbserver
    [2024-03-06 07:16:18.694] 	gettext
    [2024-03-06 07:16:18.694] 	glmark2
    [2024-03-06 07:16:18.694] 	gstreamer1.0-libav
    [2024-03-06 07:16:18.694] 	gzip
    [2024-03-06 07:16:18.694] 	hidapi
    [2024-03-06 07:16:18.694] 	less
    [2024-03-06 07:16:18.694] 	libasm1
    [2024-03-06 07:16:18.694] 	libbfd
    [2024-03-06 07:16:18.694] 	libdw1
    [2024-03-06 07:16:18.694] 	libelf1
    [2024-03-06 07:16:18.694] 	libgdbm-compat4
    [2024-03-06 07:16:18.694] 	libgdbm-dev
    [2024-03-06 07:16:18.694] 	libgdbm6
    [2024-03-06 07:16:18.694] 	libgettextlib
    [2024-03-06 07:16:18.694] 	libgettextsrc
    [2024-03-06 07:16:18.694] 	libgmp10
    [2024-03-06 07:16:18.711] 	libidn2-0
    [2024-03-06 07:16:18.711] 	libmpc3
    [2024-03-06 07:16:18.711] 	libmpfr6
    [2024-03-06 07:16:18.711] 	libreadline-dev
    [2024-03-06 07:16:18.711] 	libreadline8
    [2024-03-06 07:16:18.711] 	libunistring2
    [2024-03-06 07:16:18.711] 	m4-dev
    [2024-03-06 07:16:18.711] 	make
    [2024-03-06 07:16:18.711] 	nettle
    [2024-03-06 07:16:18.711] 	parted
    [2024-03-06 07:16:18.711] 	tar
    [2024-03-06 07:16:18.711] 	which
    [2024-03-06 07:16:18.711] If you do not wish to distribute GPLv3 components please remove
    [2024-03-06 07:16:18.717] the above packages prior to distribution.  This can be done using
    [2024-03-06 07:16:18.717] the opkg remove command.  i.e.:
    [2024-03-06 07:16:18.717]     opkg remove <package>
    [2024-03-06 07:16:18.717] Where <package> is the name printed in the list above
    [2024-03-06 07:16:18.733]
    [2024-03-06 07:16:18.733] NOTE: If the package is a dependency of another package you
    [2024-03-06 07:16:18.733]       will be notified of the dependent packages.  You should
    [2024-03-06 07:16:18.733]       use the --force-removal-of-dependent-packages option to
    [2024-03-06 07:16:18.753]       also remove the dependent packages as well
    [2024-03-06 07:16:18.753] ***************************************************************
    [2024-03-06 07:16:18.770] [  OK  ] Started Print notice about GPLv3 packages.
    [2024-03-06 07:16:19.821] [  OK  ] Started weston.service.
    [2024-03-06 07:16:19.854]          Starting telnetd.service...
    [2024-03-06 07:16:19.884] [  OK  ] Started telnetd.service.
    [2024-03-06 07:16:19.923]          Starting hmi_demo.service...
    [2024-03-06 07:16:19.936]          Starting LSB: Expand Rootfs of boot device...
    [2024-03-06 07:16:20.287] [  OK  ] Started LSB: Expand Rootfs of boot device.
    [2024-03-06 07:16:20.594] [   15.405268] PVR_K:  860: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [2024-03-06 07:16:20.642] [   15.454187] PVR_K:  860: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [2024-03-06 07:16:20.926] [  OK  ] Started hmi_demo.service.
    [2024-03-06 07:16:22.222]
    [2024-03-06 07:16:22.222]  _____                    _____           _         _
    [2024-03-06 07:16:22.222] |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    [2024-03-06 07:16:22.222] |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    [2024-03-06 07:16:22.237] |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
    [2024-03-06 07:16:22.237]               |___|                    |___|
    [2024-03-06 07:16:22.237] Arago Project am62xx-evm ttyS2
    [2024-03-06 07:16:22.237] Arago 2021.09 am62xx-evm ttyS2
    [2024-03-06 07:16:22.254]
    [2024-03-06 07:16:22.254] am62xx-evm login:
  • Tony,
    loglevel=1 in kernel dts only works in falcon mode. In normal u-boot boot the kernel cmdline is passed from u-boot env.
  • Hi, Bin,
    I tried to boot it from eMMC in falcon mode, there is not more log after starting kernel...
    is it right? if not, I can try more tomorrow.
  • Hi Tony,
    With loglevel=1, you won't see normal kernel boot message, but you should get the login prompt at the end of the boot process.
    If you want to see more kernel boot messages, you would have to increase the log level number, it corresponds to the kernel printk levels. Of cause, showing more boot messages slow down the boot time.
  • It works as below, ignore the error as no filesystem.
    [2024-03-07 07:43:00.997] init_env from device 9 not supported!
    [2024-03-07 07:43:00.997] Starting ATF on ARM64 core...
    [2024-03-07 07:43:01.013]
    [2024-03-07 07:43:01.013] NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
    [2024-03-07 07:43:01.013] NOTICE:  BL31: Built : 16:35:46, May 30 2022
    [2024-03-07 07:43:01.057] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [2024-03-07 07:43:01.057] [    0.000000] Linux version 5.10.109-g9e58028f94 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain
    [2024-03-07 07:43:01.074]  for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profil
    [2024-03-07 07:43:01.074] e Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon May 30 16:43:25 UTC 2022
    [2024-03-07 07:43:01.089] [    0.000000] Machine model: Texas Instruments AM625 SK
    [2024-03-07 07:43:01.089] [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [2024-03-07 07:43:01.104] [    0.000000] printk: bootconsole [ns16550a0] enabled
    [2024-03-07 07:43:03.445] [    2.299363] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
    [2024-03-07 07:43:03.445] [    2.307620] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.109-g9e58028f94 #1
    [2024-03-07 07:43:03.460] [    2.314736] Hardware name: Texas Instruments AM625 SK (DT)
    [2024-03-07 07:43:03.460] [    2.320208] Call trace:
    [2024-03-07 07:43:03.460] [    2.322656]  dump_backtrace+0x0/0x1a0
    [2024-03-07 07:43:03.460] [    2.326310]  show_stack+0x18/0x68
    [2024-03-07 07:43:03.476] [    2.329618]  dump_stack+0xd0/0x12c
    [2024-03-07 07:43:03.476] [    2.333009]  panic+0x16c/0x334
    [2024-03-07 07:43:03.476] [    2.336059]  mount_block_root+0x1c4/0x254
    [2024-03-07 07:43:03.476] [    2.340056]  mount_root+0x10c/0x140
    [2024-03-07 07:43:03.476] [    2.343534]  prepare_namespace+0x130/0x170
    [2024-03-07 07:43:03.489] [    2.347620]  kernel_init_freeable+0x25c/0x2a0
    [2024-03-07 07:43:03.489] [    2.351967]  kernel_init+0x14/0x114
    [2024-03-07 07:43:03.489] [    2.355446]  ret_from_fork+0x10/0x34
    [2024-03-07 07:43:03.489] [    2.359021] Kernel Offset: 0x80000 from 0xffff800010000000
    [2024-03-07 07:43:03.507] [    2.364490] PHYS_OFFSET: 0x80000000
