Part Number: DRA829V
We've received the following inquiry from my customer. Could you please answer to their questions below.
Since I heard that tifs is different in HS-FS from GP device, I changed tifs.bin, but Sciclient fails to initialize.
Sciclient initialization will also fail if you use SBL built with _hs.
I thought there was a combination, so I added the 8 tifs.bins in PDK8.5 and PDK9.1.
I tried 16 combinations of SBL built normally and SBL built with _hs, but Sciclient fails to initialize.
The image at the failure is attached below.
Every failure causes an infinite loop in Sciclient_flush().
Please let me know if there are any possible causes for this phenomenon.
The following 8 tifs files were tested.
[PDK8.5]
tifs.bin
tifs_sr1.1-hs-enc.bin
tifs-hs-enc.bin
[PDK9.1]
tifs.bin
tifs_sr2-hs-enc.bin
tifs_sr2-hs-fs-enc.bin
tifs-hs-enc.bin
Thanks and regards,
Hideaki
