Part Number: PROCESSOR-SDK-AM64X
Other Parts Discussed in Thread: SYSCONFIG, TMDS64EVM
Hi
"In the generated code from sysconfig, I noticed some inconsistencies between the MPU interrupt configuration and its actual usage. Can you assist me in addressing this issue?
"For UART, we have UART0 located at address 0x2800000. Should it be configured for both read and write access? Why is it configured as user read-only? I mean, users also need to write to UART for debugging purposes, correct?"
"Additionally, if we want to configure Timer at address 0x2410000, it should also be set for user read and write access, right? Why is it not configured anywhere?"
"If register access privilege is not configured in the MPU, what will be the default behavior?
Thanks.
<generated code>
