Other Parts Discussed in Thread: DRA821
Hi, TI
I am using DRA821 with eMMC (KLM8G1GEUF-B04Q) connected to mmc0, but experiencing eMMC Booting Failures in specific samples
It's not failing every time, but approximately 100 out of 1000 attempts result in failure.
The booting FAIL logs are attached, and there are primarily three distinct cases that are observed.
When a 10~20pF capacitor is connected between GND and the CMD Line of the specific sample, eMMC booting operates normally
I am curious if connecting a capacitor to the CMD Line is a valid solution
==== Fail Log #1===============================
[ 0.026000] U-Boot SPL 2023.04 (Feb 23 2024 - 11:12:26 +0900)
Trying to boot from MMC1
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
[ 0.327000] Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):803903ea3-dirty
NOTICE: BL31: Built : 07:33:39, Dec 21 2023
I/TC:
I/TC: OP-TEE version: 4.0.0 (gcc version 11.4.0 (GCC)) #1 Fri Oct 20 18:29:31 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
unable to select a mode : -5
mmc_init: -524, time 95
spl: mmc init failed with error: -524
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
=======Fail Log #2============================
[ 0.328000] Starting ATF on ARM64 core...
I/TC:
mmc_load_image_raw_sector: mmc block read error
** Partition 1 not valid on device 0 **
spl_register_fat_device: fat register err - -1
spl_load_image_fat: error reading image u-boot.img, err - -1
===Fail Log #3 ===============================
I/TC:
[ 0.674000] U-Boot 2023.04 (Feb 23 2024 - 11:12:17 +0900)
[ 0.677000] SoC: J7200 SR2.0 GP
[ 0.678000] DRAM: 4 GiB
[ 0.711000] wifi get node 6588
[ 0.714000] tgu: wifipower enable
[ 0.716000] MCU reset get node 30104
[ 0.718000] MCU reset
[ 0.720000] PHY reset get node 29828
[ 0.722000] PHY reset
[ 1.223000] CELL reset get node 29920
[ 1.225000] CELL reset
[ 1.727000] SPI reset get node 30012
[ 1.728000] SPI reset
Core: 88 devices, 31 uclasses, devicetree: separate
Flash: 0 Bytes
[ 2.233000] MMC: mmc@4f80000: 0, mmc@4fb0000: 1
[env_relocate] env load
Loading Environment from MMC... Partition 1: invalid GUID
Partition 2: invalid GUID
Partition 3: invalid GUID
Partition 4: invalid GUID
Partition 5: invalid GUID
Partition 6: invalid GUID
Partition 7: invalid GUID
Partition 8: invalid GUID
*** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
read_env size : 0x00020000 , offset: 0x01800000
blk start : 0x0000C000 , blk_cnt : 0x00000100, rcnt : 0x00000000
!read failed
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
[ 2.936000] Net: [ 2.940000] eth0: ethernet@46000000port@1
[ 2.943000] Hit any key to stop autoboot: 0
[ 3.059000] switch to partitions #0, OK
[ 3.061000] mmc0(part 0) is current device
SD/MMC found on device 0
Can't set block device
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@21: Error reading output register
pca953x gpio@20: Error reading output register
pca953x gpio@22: Error reading output register
GPIO: 'gpio@22_17' not found
Command 'gpio' failed: Error -22
GPIO: 'gpio@22_16' not found
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
Invalid partition 5 **
Couldn't find partition mmc 0:5
No partition table - mmc 0 **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Bad Linux ARM64 Image magic!
[ 3.386000] switch to partitions #0, OK
[ 3.388000] mmc0(part 0) is current device
Couldn't find partition mmc 0:1
Card did not respond to voltage select! : -110
mmc_init: -95, time 65
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2
ethernet@46000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
am65_cpsw_nuss_port ethernet@46000000port@1: phy_startup failed
am65_cpsw_nuss_port ethernet@46000000port@1: am65_cpsw_start end error
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-34-08-e1-65-b1-6e
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-k3-j721e
Config file not found
starting USB...
Thank you.
