Nick:
Can you look at this Arago boot and commands to see if something is weird? Note the last attempted command where I try to use "echo stop"
U-Boot SPL 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Resetting on cold boot to workaround ErrataID:i2331
Please resend tiboot3.bin in case of UART/DFU boot
resetting ...
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
SPL initial stack usage: 13384 bytes
Trying to boot from MMC2
Authentication passed
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
NOTICE: BL31: Built : 09:34:15, Aug 24 2023
I/TC:
I/TC: OP-TEE version: 4.0.0 (gcc version 11.4.0 (GCC)) #1 Fri Oct 20 18:29:31 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
SoC: AM64X SR2.0 HS-FS
Model: Texas Instruments AM642 EVM
Board: AM64-EVM rev C
DRAM: 2 GiB
Core: 66 devices, 31 uclasses, devicetree: separate
NAND: 0 MiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Unidentified board claims AM64-EVM in eeprom header
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
574 bytes read in 30 ms (18.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
## Error: "main_cpsw0_qsgmii_phyinit" not defined
16169472 bytes read in 666 ms (23.2 MiB/s)
59008 bytes read in 36 ms (1.6 MiB/s)
Working FDT set to 88000000
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.46-rt13-gb871cdee8c (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Thu Dec 7 23:52:13 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM642 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a57fffff]
[ 0.000000] node 0: [mem 0x00000000a5800000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] cma: Reserved 32 MiB at 0x00000000fbe00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s44928 r8192 d28800 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=70d18eb9-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1897072K/2097152K available (10368K kernel code, 1198K rwdata, 2328K rodata, 1792K init, 420K bss, 167312K reserved, 32768K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: 0xffff80000840dd70
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000277] Console: colour dummy device 80x25
[ 0.538125] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
[ 0.538137] pid_max: default: 32768 minimum: 301
[ 0.538236] LSM: Security Framework initializing
[ 0.538386] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.538409] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.540214] rcu: Hierarchical SRCU implementation.
[ 0.540225] rcu: Max phase no-delay instances is 400.
[ 0.540272] printk: bootconsole [ns16550a0] printing thread started
[ I /T C0:. S59e2c7o5n5d]ar Pyl aCPtfUo r1m iMniSIt:i amlsizi-incogn
trolI/leTrC@: 1S8e20c0o0n0d adroy mCaPiUn 1 c srewiattecdh
i
ng[ to 0no.5rm93a0l4 w6]or lPdCI /bMooStI
/bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.593173] EFI services will not be available.
[ 0.593412] smp: Bringing up secondary CPUs ...
[ 0.610526] Detected VIPT I-cache on CPU1
[ 0.610650] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
[ 0.610669] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[ 0.610724] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.651999] smp: Brought up 1 node, 2 CPUs
[ 0.652008] SMP: Total of 2 processors activated.
[ 0.652013] CPU features: detected: 32-bit EL0 Support
[ 0.652018] CPU features: detected: CRC32 instructions
[ 0.652065] CPU: All CPU(s) started at EL2
[ 0.652067] alternatives: applying system-wide alternatives
[ 0.653603] devtmpfs: initialized
[ 0.666005] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.666031] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.667506] pinctrl core: initialized pinctrl subsystem
[ 0.668212] DMI not present or invalid.
[ 0.668776] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.705319] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.705539] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.705744] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.705874] audit: initializing netlink subsys (disabled)
[ 0.706770] thermal_sys: Registered thermal governor 'step_wise'
[ 0.707025] ASID allocator initialised with 65536 entries
[ 0.715261] audit: type=2000 audit(0.703:1): state=initialized audit_enabled=0 res=1
[ 0.731949] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.731961] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.731966] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.731970] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.731974] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.731977] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.731982] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.731985] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.733862] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
[ 0.736144] iommu: Default domain type: Translated
[ 0.736156] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.736589] SCSI subsystem initialized
[ 0.737024] usbcore: registered new interface driver usbfs
[ 0.737075] usbcore: registered new interface driver hub
[ 0.737108] usbcore: registered new device driver usb
[ 0.737676] pps_core: LinuxPPS API ver. 1 registered
[ 0.737680] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.737702] PTP clock support registered
[ 0.737859] EDAC MC: Ver: 3.0.0
[ 0.738835] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
[ 0.739150] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
[ 0.739346] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
[ 0.739915] FPGA manager framework
[ 0.740055] Advanced Linux Sound Architecture Driver Initialized.
[ 0.741242] clocksource: Switched to clocksource arch_sys_counter
[ 0.74154I9/]T CV:F S:R eDsiersvk edqu sothaasre dd qumeotm_o6ry.6 i.s0
en[a b l e0d.
7
41I5/9T3C] : VDFyS:na Dmiqcuo tsh-caracehde mhemasohr yt aisb lee neanbtlredi
es
: I51/T2 C(: orNdorerm a0l, Wo40rl96d bviyrtteus)a
l
iz[ a ti on0 .s7u4p9p0or60t] iNsE dTi:s Rabeglieds
te
reId/ TPCF: _IANsyETn cphrrootnoocuos ln fotaimfiilyc
at
i[o n s 0ar.e7 49d5is0a1]b leIdP
idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.751635] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes, linear)
[ 0.751689] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.751707] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.751960] TCP bind hash table entries: 16384 (order: 8, 1310720 bytes, linear)
[ 0.753463] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.753682] UDP hash table entries: 1024 (order: 4, 98304 bytes, linear)
[ 0.753838] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes, linear)
[ 0.754196] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.754856] RPC: Registered named UNIX socket transport module.
[ 0.754863] RPC: Registered udp transport module.
[ 0.754866] RPC: Registered tcp transport module.
[ 0.754869] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.754881] PCI: CLS 0 bytes, default 64
[ 0.788182] Initialise system trusted keyrings
[s 0.788472] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[ 1.055323] printk: console [ttyS2] enabled
[ 1.055329] printk: bootconsole [ns16550a0] disabled
[ 1.055344] printk: bootconsole [ns16550a0] printing thread stopped
[ 1.055347] printk: console [ttyS2] printing thread started
[ 1.064930] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.065054] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.065065] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.065074] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[ 1.066758] 0x000000100000-0x000000300000 : "ospi.tispl"
[ 1.068194] 0x000000300000-0x000000700000 : "ospi.u-boot"
[ 1.069629] 0x000000700000-0x000000740000 : "ospi.env"
[ 1.071039] 0x000000740000-0x000000780000 : "ospi.env.backup"
[ 1.072473] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.073892] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.085947] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.120283] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.121670] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.121730] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
[ 1.121969] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
[ 1.121977] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.122747] pps pps0: new PPS source ptp0
[ 1.123081] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.139388] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
[ 1.144113] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 1.146672] gpio-mux mux-controller: 2-way mux-controller registered
[ 1.147783] mmc0: CQHCI version 5.10
[ 1.167408] debugfs: Directory 'pd:114' with parent 'pm_genpd' already present!
[ 1.170184] mmc1: CQHCI version 5.10
[ 1.179502] ALSA device list:
[ 1.179515] No soundcards found.
[ 1.189484] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.205748] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.219177] Waiting for root device PARTUUID=70d18eb9-02...
[ 1.257711] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.258626] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 1.262940] mmcblk1: p1 p2
[ 1.271710] mmc0: Command Queue Engine enabled
[ 1.271734] mmc0: new HS200 MMC card at address 0001
[ 1.272589] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.274792] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.277390] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.280741] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.576797] EXT4-fs (mmcblk1p2): recovery complete
[ 1.577920] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.578017] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.579783] devtmpfs: mounted
[ 1.581038] Freeing unused kernel memory: 1792K
[ 1.581171] Run /sbin/init as init process
[ 1.740366] systemd[1]: System time before build time, advancing clock.
[ 1.780101] NET: Registered PF_INET6 protocol family
[ 1.781579] Segment Routing with IPv6
[ 1.781621] In-situ OAM (IOAM) with IPv6
[ 1.801517] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
Welcome to [1mArago 2023.10[0m!
[ 1.802156] systemd[1]: Detected architecture arm64.
[ 1.845382] systemd[1]: Hostname set to <am64xx-evm>.
[ 2.008893] systemd-sysv-generator[151]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.011222] systemd-sysv-generator[151]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.011548] systemd-sysv-generator[151]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.302435] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.379887] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 2.462006] systemd[1]: Queued start job for default target Graphical Interface.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/getty[[ 2.466304] systemd[1]: Created slice Slice /system/getty.
0m.
[ 2.485028] systemd[1]: Created slice Slice /system/modprobe.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/modprobe[0m.
[ 2.501034] systemd[1]: Created slice Slice /system/serial-getty.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/serial-getty[0m.
[[0;32m OK [0m] Created slice [0;1;39mUser and Session Slic[ 2.516389] systemd[1]: Created slice User and Session Slice.
e[0m.
[ 2.530967] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[[0;32m OK [0m] Started [0;1;39mDispatch Password …ts to Console Directory Watch[0m.
[[0;32m OK [0m] Started [0;1;39mForward Password R…uests [ 2.550921] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
to Wall Directory Watch[0m.
[ 2.568088] systemd[1]: Reached target Path Units.
[[0;32m OK [0m] Reached target [0;1;39mPath Units[0m.
[[0;32m OK [0m] Reached target [0;1;39mRemote File Systems[ 2.581622] systemd[1]: Reached target Remote File Systems.
[0m.
[[0;32m OK [0m] Reached target [0;1;39mSlice Units[0m.[ 2.595573] systemd[1]: Reached target Slice Units.
[[0;32m OK [0m] Reached target [0;1;39mSwaps[0m.
[ 2.608610] systemd[1]: Reached target Swaps.
[ 2.625161] systemd[1]: Listening on RPCbind Server Activation Socket.
[[0;32m OK [0m] Listening on [0;1;39mRPCbind Server Activation Socket[0m.
[[0;32m OK [0m] Reached target [0;1;39mRPC Port Mapper[0m.[ 2.640580] systemd[1]: Reached target RPC Port Mapper.
[[0;32m OK [0m] Listening on [0;1;39mProcess Core Dump Sock[ 2.664637] systemd[1]: Listening on Process Core Dump Socket.
et[0m.
[ 2.680025] systemd[1]: Listening on initctl Compatibility Named Pipe.
[[0;32m OK [0m] Listening on [0;1;39minitctl Compatibility Named Pipe[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Audit Socket[[ 2.696773] systemd[1]: Listening on Journal Audit Socket.
0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket (/dev/l[ 2.711501] systemd[1]: Listening on Journal Socket (/dev/log).
og)[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket[0m.[ 2.727575] systemd[1]: Listening on Journal Socket.
[[0;32m OK [0m] Listening on [0;1;39mNetwork Service Netlin[ 2.741779] systemd[1]: Listening on Network Service Netlink Socket.
k Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mudev Control Socket[0[ 2.760421] systemd[1]: Listening on udev Control Socket.
m.
[[0;32m OK [0m] Listening on [0;1;39mudev Kernel Socket[0m[ 2.775216] systemd[1]: Listening on udev Kernel Socket.
[[0;32m OK [0m] Listening on [0;1;39mUser Database Manager [ 2.790516] systemd[1]: Listening on User Database Manager Socket.
Socket[0m.
[ 2.813991] systemd[1]: Mounting Huge Pages File System...
Mounting [0;1;39mHuge Pages File System[0m...
[ 2.833959] systemd[1]: Mounting POSIX Message Queue File System...
Mounting [0;1;39mPOSIX Message Queue File System[0m...
Mounting [0;1;39mKernel Debug File System[0m...[ 2.856925] systemd[1]: Mounting Kernel Debug File System...
[ 2.872035] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 2.893985] systemd[1]: Mounting Temporary Directory /tmp...
Mounting [0;1;39mTemporary Directory /tmp[0m...
Starting [0;1;39mCreate List of Static Device Nodes[0[ 2.918431] systemd[1]: Starting Create List of Static Device Nodes...
m...
Starting [0;1;39mLoad Kernel Module configfs[0m...
[ 2.942438] systemd[1]: Starting Load Kernel Module configfs...
Starting [0;1;39mLoad Kernel Module drm[0m...
[ 2.959483] systemd[1]: Starting Load Kernel Module drm...
Starting [0;1;39mLoad Kernel Module fuse[0m...
[ 2.980683] systemd[1]: Starting Load Kernel Module fuse...
[ 2.994369] fuse: init (API version 7.37)
Starting [0;1;39mRPC Bind[0m...[ 3.005500] systemd[1]: Starting RPC Bind...
[ 3.016831] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 3.018377] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 3.018404] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
Starting [0;1;39mJournal Service[0m...
[ 3.044586] systemd[1]: Starting Journal Service...
Starting [0;1;39mLoad Kernel Modules[0m...[ 3.075626] systemd[1]: Starting Load Kernel Modules...
Starting [0;1;39mGenerate network …ts from Kernel co[ 3.094789] systemd[1]: Starting Generate network units from Kernel command line...
mmand line[0m...
Starting [0;1;39mRemount Root and Kernel File Systems[ 3.118641] systemd[1]: Starting Remount Root and Kernel File Systems...
[0m...
[ 3.132423] cryptodev: loading out-of-tree module taints kernel.
[ 3.141334] cryptodev: driver 1.12 loaded.
Starting [0;1;39mColdplug All udev Devices[0m...[ 3.161524] systemd[1]: Starting Coldplug All udev Devices...
[[0;32m OK [0m] Started [0;1;39mRPC Bind[0m.[ 3.196657] systemd[1]: Started RPC Bind.
[[0;32m OK [0m] Started [0;1;39mJournal Service[0m.
[ 3.215475] systemd[1]: Started Journal Service.
[ 3.225741] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[[0;32m OK [0m] Mounted [0;1;39mHuge Pages File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mPOSIX Message Queue File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mKernel Debug File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mTemporary Directory /tmp[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate List of Static Device Nodes[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module configfs[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module drm[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module fuse[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Modules[0m.
[[0;32m OK [0m] Finished [0;1;39mGenerate network units from Kernel command line[0m.
[[0;32m OK [0m] Finished [0;1;39mRemount Root and Kernel File Systems[0m.
Mounting [0;1;39mFUSE Control File System[0m...
Mounting [0;1;39mKernel Configuration File System[0m...
Starting [0;1;39mFlush Journal to Persistent Storage[0m...
Starting [0;1;39mApply Kernel Variables[0m...[ 3.452019] systemd-journald[161]: Received client request to flush runtime journal.
Starting [0;1;39mCreate Static Device Nodes in /dev[0m...
[[0;32m OK [0m] Mounted [0;1;39mFUSE Control File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mKernel Configuration File System[0m.
[[0;32m OK [0m] Finished [0;1;39mFlush Journal to Persistent Storage[0m.
[[0;32m OK [0m] Finished [0;1;39mApply Kernel Variables[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate Static Device Nodes in /dev[0m.
[[0;32m OK [0m] Reached target [0;1;39mPreparation for Local File Systems[0m.
Mounting [0;1;39m/media/ram[0m...
Mounting [0;1;39m/var/volatile[0m...
Starting [0;1;39mRule-based Manage…for Device Events and Files[0m...
[[0;32m OK [0m] Mounted [0;1;39m/media/ram[0m.
[[0;32m OK [0m] Mounted [0;1;39m/var/volatile[0m.
Starting [0;1;39mLoad/Save Random Seed[0m...
[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems[0m.
Starting [0;1;39mCreate Volatile Files and Directories[0m...
[[0;32m OK [0m] Started [0;1;39mRule-based Manager for Device Events and Files[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate Volatile Files and Directories[0m.
Starting [0;1;39mNetwork Time Synchronization[0m...
Starting [0;1;39mRecord System Boot/Shutdown in UTMP[0m...
[ 3.956356] random: crng init done
[[0;32m OK [0m] Finished [0;1;39mLoad/Save Random Seed[0m.
[[0;32m OK [0m] Finished [0;1;39mRecord System Boot/Shutdown in UTMP[0m.
[[0;32m OK [0m] Finished [0;1;39mColdplug All udev Devices[0m.
[ 4.567571] CAN device driver interface
[[0;32m OK [0m] Found device [0;1;39m/dev/ttyS2[0m.
[ 4.761177] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
[ 4.810285] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 4.874214] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
[ 4.888456] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
[ 4.889346] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[ 4.889516] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ 4.890055] remoteproc remoteproc0: 5000000.m4fss is available
[ 4.897703] remoteproc remoteproc0: powering up 5000000.m4fss
[[0;32m OK [0m] Started [0;1;39mNetwork Time Synchronizatio[ 4.897731] remoteproc remoteproc0: Booting fw image am64-mcu-m4f0_0-fw, size 86084
n[0m.
[ 4.995514] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node m4f-dma-memory@a4000000
[[0;32m OK [0m] Reached target [0;1;39mSystem Initializatio[ 4.995776] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
n[0m.
[[0;32m OK [0m] Started [0;1;39mTimer service to update the[ 4.995789] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
IP on OLED each 10s[0m.
[ 5.057185] systemd-journald[161]: Oldest entry in /run/log/journal/13e16a12cb9f4f1eb08f0b0036d43a94/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[[0;32m OK [0m] Started [0;1;39mDaily Cleanup of Temporary [ 5.057217] systemd-journald[161]: /run/log/journal/13e16a12cb9f4f1eb08f0b0036d43a94/system.journal: Journal header limits reached or header out-of-date, rotating.
Directories[0m.
[ 5.116434] virtio_rpmsg_bus virtio0: rpmsg host is online
[[0;32m OK [0m] Reached target [0;1;39mSystem Time Set[0m.[ 5.117682] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 5.117917] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[[0;32m OK [0m] Started [0;1;39mDaily rotation of log files[ 5.154405] j721e-pcie-host f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
[0m.
[[0;32m OK [0m] Reached target [0;1;39mTimer Units[0m.[ 5.154513] j721e-pcie-host f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000
[ 5.154553] j721e-pcie-host f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000
[[0;32m OK [0m] Listening on [0;1;39mAvahi mDNS/DNS-SD Stac[ 5.154580] j721e-pcie-host f102000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
k Activation Socket[0m.
[ 5.157646] platform 78000000.r5f: configured R5F for remoteproc mode
[[0;32m OK [0m] Listening on [0;1;39mD-Bus System Message B[ 5.158424] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
us Socket[0m.
Starting [0;1;39mDocker Socket for the API[0m...[ 5.158839] remoteproc remoteproc1: 78000000.r5f is available
[[0;32m OK [0m] Listening on [0;1;39mdropbear.socket[0m.[ 5.158950] m_can_platform 20701000.can: m_can device registered (irq=506, version=32)
[ 5.160198] platform 78200000.r5f: configured R5F for remoteproc mode
[[0;32m OK [0m] Listening on [0;1;39mPC/SC Smart Card Daemo[ 5.160645] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
n Activation Socket[0m.
Starting [0;1;39mConsole System Startup Logging[0m...[ 5.161055] remoteproc remoteproc2: 78200000.r5f is available
[ 5.161978] remoteproc remoteproc1: powering up 78000000.r5f
[ 5.162006] remoteproc remoteproc1: Booting fw image am64-main-r5f0_0-fw, size 86352
[ 5.163928] remoteproc remoteproc2: powering up 78200000.r5f
[ 5.163955] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
[ 5.224044] m_can_platform 20711000.can: m_can device registered (irq=507, version=32)
[ 5.228777] platform 78400000.r5f: configured R5F for remoteproc mode
[ 5.229217] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
Starting [0;1;39mD-Bus System Message Bus[0m...
[ 5.229683] remoteproc remoteproc3: 78400000.r5f is available
[ 5.230800] platform 78600000.r5f: configured R5F for remoteproc mode
[ 5.231313] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[ 5.231767] remoteproc remoteproc4: 78600000.r5f is available
[ 5.236476] remoteproc remoteproc4: powering up 78600000.r5f
[ 5.236505] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
[ 5.236705] remoteproc remoteproc3: powering up 78400000.r5f
[ 5.236720] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
Starting [0;1;39mReboot and dump vmcore via kexec[0m.[ 5.259411] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@a1000000
[ 5.260186] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 5.260219] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[ 5.260284] remoteproc remoteproc2: remote processor 78200000.r5f is now up
[ 5.261340] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[[0;32m OK [0m] Listening on [0;1;39mDocker Socket for the API[0m.
[[0;32m OK [0m] Finished [0;1;39mConsole System Startup Log[ 5.287775] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@a0000000
ging[0m.
[ 5.288792] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 5.288847] rproc-virtio rproc-virtio.1.auto: registered virtio2 (type 7)
[ 5.288856] remoteproc remoteproc1: remote processor 78000000.r5f is now up
[ 5.289219] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 5.315771] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a2000000
[ 5.316950] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 5.317016] rproc-virtio rproc-virtio.4.auto: registered virtio3 (type 7)
[[0;32m OK [0m] Finished [0;1;39mReboot and dump vmcore via[ 5.317026] remoteproc remoteproc3: remote processor 78400000.r5f is now up
kexec[0m.
[ 5.317214] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[ 5.324603] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a3000000
[ 5.325624] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 5.325674] rproc-virtio rproc-virtio.3.auto: registered virtio4 (type 7)
[ 5.325683] remoteproc remoteproc4: remote processor 78600000.r5f is now up
[ 5.326160] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
[ 5.756935] remoteproc remoteproc5: 3000a000.txpru is available
[ 5.760698] remoteproc remoteproc6: 3000c000.txpru is available
[ 5.763223] remoteproc remoteproc7: 3008a000.txpru is available
[ 5.768741] remoteproc remoteproc8: 3008c000.txpru is available
[ 6.211710] j721e-pcie-host f102000.pcie: PCI host bridge to bus 0000:00
[ 6.211735] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.211747] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff])
[ 6.211755] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
[ 6.211800] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
[ 6.211820] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
[ 6.211907] pci 0000:00:00.0: supports D1
[ 6.211913] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 6.216768] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.217074] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 6.217118] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
[ 6.217128] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
[ 6.217139] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 6.237355] pcieport 0000:00:00.0: PME: Signaling with IRQ 510
[[0;32m OK [0m] Started [0;1;39mD-Bus System Message Bus[0[ 6.258022] pcieport 0000:00:00.0: AER: enabled with IRQ 510
m.
[ 7.249800] remoteproc remoteproc9: 30086000.rtu is available
[ 7.254297] remoteproc remoteproc10: 30034000.pru is available
[ 7.254994] remoteproc remoteproc11: 30004000.rtu is available
[ 7.258076] remoteproc remoteproc12: 30038000.pru is available
[ 7.263211] remoteproc remoteproc13: 30006000.rtu is available
[ 7.273502] remoteproc remoteproc14: 300b4000.pru is available
[ 7.284137] remoteproc remoteproc15: 30084000.rtu is available
[ 7.290988] remoteproc remoteproc16: 300b8000.pru is available
[[0;32m OK [0m] Reached target [0;1;39mSocket Units[0m.
[[0;32m OK [0m] Reached target [0;1;39mBasic System[0m.
[[0;32m OK [0m] Started [0;1;39mJob spooling tools[0m.
[[0;32m OK [0m] Started [0;1;39mPeriodic Command Scheduler[0m.
Starting [0;1;39mDEMO[0m...
Starting [0;1;39mPrint notice about GPLv3 packages[0m...
Starting [0;1;39mIPv6 Packet Filtering Framework[0m...
Starting [0;1;39mIPv4 Packet Filtering Framework[0m...
[[0;32m OK [0m] Started [0;1;39mirqbalance daemon[0m.
Starting [0;1;39mTelephony service[0m...
Starting [0;1;39mExpand the rootfs…ll size of the boot device.[0m...
Starting [0;1;39mUser Login Management[0m...
[[0;32m OK [0m] Started [0;1;39mTEE Supplicant[0m.
Starting [0;1;39mTelnet Server[0m...
[[0;32m OK [0m] Started [0;1;39mDEMO[0m.
[[0;32m OK [0m] Finished [0;1;39mIPv6 Packet Filtering Framework[0m.
[[0;32m OK [0m] Finished [0;1;39mIPv4 Packet Filtering Framework[0m.
[[0;32m OK [0m] Finished [0;1;39mTelnet Server[0m.
[[0;32m OK [0m] Started [0;1;39mTelephony service[0m.
[ 8.694727] Bluetooth: Core ver 2.22
[ 8.694900] NET: Registered PF_BLUETOOTH protocol family
[ 8.694905] Bluetooth: HCI device and connection manager initialized
[ 8.694930] Bluetooth: HCI socket layer initialized
[ 8.694941] Bluetooth: L2CAP socket layer initialized
[ 8.694964] Bluetooth: SCO socket layer initialized
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/systemd-fsck[0m.
[[0;32m OK [0m] Reached target [0;1;39mPreparation for Network[0m.
[[0;32m OK [0m] Listening on [0;1;39mLoad/Save RF …itch Status /dev/rfkill Watch[0m.
Starting [0;1;39mNetwork Configuration[0m...
[[0;32m OK [0m] Finished [0;1;39mExpand the rootfs…full size of the boot device.[0m.
[[0;32m OK [0m] Found device [0;1;39m/dev/mmcblk1p1[0m.
Starting [0;1;39mFile System Check on /dev/mmcblk1p1[0m...
[ 9.481415] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[[0;32m OK [0m] Started [0;1;39mUser Login Management[0m.
[ 9.522385] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[[0;32m OK [0m] Finished [0;1;39mFile System Check on /dev/mmcblk1p1[0m.
Mounting [0;1;39m/run/media/boot-mmcblk1p1[0m...
[[0;32m OK [0m] Started [0;1;39mNetwork Configuration[0m.
Starting [0;1;39mWait for Network to be Configured[0m...
Starting [0;1;39mNetwork Name Resolution[0m...
[ 9.782116] am65-cpsw-nuss 8000000.ethernet eth1: PHY [mdio_mux-0.1:03] driver [TI DP83869] (irq=POLL)
[[0;32m OK [0m] Mounted [0;1;39m/run/media/boot-mmcblk1p1[[ 9.782154] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
0m.
[ 9.822080] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 9.822114] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[[0;32m OK [0m] Started [0;1;39mNetwork Name Resolution[0m.
[[0;32m OK [0m] Reached target [0;1;39mNetwork[0m.
[[0;32m OK [0m] Reached target [0;1;39mHost and Network Name Lookups[0m.
Starting [0;1;39mAvahi mDNS/DNS-SD Stack[0m...
Starting [0;1;39mEnable and configure wl18xx bluetooth stack[0m...
Starting [0;1;39mcontainerd container runtime[0m...
[[0;32m OK [0m] Started [0;1;39mNetperf Benchmark Server[0m.
[[0;32m OK [0m] Started [0;1;39mNFS status monitor for NFSv2/3 locking.[0m.
Starting [0;1;39mSimple Network Ma…ent Protocol (SNMP) Daemon.[0m...
Starting [0;1;39mPermit User Sessions[0m...
[[0;32m OK [0m] Finished [0;1;39mEnable and configure wl18xx bluetooth stack[0m.
[[0;32m OK [0m] Started [0;1;39mAvahi mDNS/DNS-SD Stack[0m.
[[0;32m OK [0m] Finished [0;1;39mPermit User Sessions[0m.
[[0;32m OK [0m] Started [0;1;39mGetty on tty1[0m.
[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS2[0m.
[[0;32m OK [0m] Reached target [0;1;39mLogin Prompts[0m.
Starting [0;1;39mSynchronize System and HW clocks[0m...
[[0;1;31mFAILED[0m] Failed to start [0;1;39mSynchronize System and HW clocks[0m.
See 'systemctl status sync-clocks.service' for details.
[[0;32m OK [0m] Started [0;1;39mSimple Network Man…ement Protocol (SNMP) Daemon.[0m.
[[0;32m OK [0m] Started [0;1;39mcontainerd container runtime[0m.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
hidapi
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5sensors-plugins
libqt5sensors-qmlplugins
libqt5sensors5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libqt5webchannel-plugins
libqt5webchannel-qmlplugins
libqt5webchannel5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libunistring2
m4-dev
m4
make
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[[0;32m OK [0m] Finished [0;1;39mPrint notice about GPLv3 packages[0m.
[ 13.860019] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.860076] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am64xx-evm -
Arago 2023.10 am64xx-evm -
am64xx-evm login: [ 18.427997] TI DP83869 300b2400.mdio:0f: attached PHY driver (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
[ 18.428046] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
[ 18.549162] remoteproc remoteproc14: powering up 300b4000.pru
[ 18.554275] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 40936
[ 18.554316] remoteproc remoteproc14: unsupported resource 5
[ 18.554345] remoteproc remoteproc14: remote processor 300b4000.pru is now up
[ 18.554386] remoteproc remoteproc15: powering up 30084000.rtu
[ 18.556361] remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30884
[ 18.556416] remoteproc remoteproc15: remote processor 30084000.rtu is now up
[ 18.556457] remoteproc remoteproc7: powering up 3008a000.txpru
[ 18.557652] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36672
[ 18.557709] remoteproc remoteproc7: remote processor 3008a000.txpru is now up
[ 18.559149] pps pps1: new PPS source ptp2
root
[ 30.237864] audit: type=1006 audit(1709926425.862:2): pid=974 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 30.237950] audit: type=1300 audit(1709926425.862:2): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffdd2cba38 a2=1 a3=ffff9fdcc020 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 30.238001] audit: type=1327 audit(1709926425.862:2): proctitle="(systemd)"
7[r[999;999H[6n8root@am64xx-evm:~# ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 1c:63:49:1a:d7:cc txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.97.2.108 netmask 255.255.252.0 broadcast 10.97.3.255
inet6 fe80::72ff:76ff:fe1f:41dc prefixlen 64 scopeid 0x20<link>
ether 70:ff:76:1f:41:dc txqueuelen 1000 (Ethernet)
RX packets 5613 bytes 559208 (546.1 KiB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 56 bytes 6500 (6.3 KiB)
eth2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 70:ff:76:1f:41:dd txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 93 bytes 7714 (7.5 KiB)
TX packets 93 bytes 7714 (7.5 KiB)
root@am64xx-evm:~# mount
/dev/mmcblk1p2 on / type ext4 (rw,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=948536k,nr_inodes=237134,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,size=386328k,nr_inodes=819200,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=1048576)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /media/ram type tmpfs (rw,relatime,size=16384k)
tmpfs on /var/volatile type tmpfs (rw,relatime,size=51200k)
/dev/mmcblk1p1 on /run/media/boot-mmcblk1p1 type vfat (rw,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=193160k,nr_inodes=48290,mode=700)
root@am64xx-evm:~# ls -l /lib/firmware
total 24424
-rw-r--r-- 1 root root 2040 Mar 9 2018 LICENCE.ibt_firmware
-rw-r--r-- 1 root root 2046 Mar 9 2018 LICENCE.iwlwifi_firmware
lrwxrwxrwx 1 root root 55 Mar 9 2018 am64-main-r5f0_0-fw -> /lib/firmware/mcusdk-benchmark_demo/am64-main-r5f0_0-fw
lrwxrwxrwx 1 root root 75 Mar 9 2018 am64-main-r5f0_0-fw-sec -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu1_0_release_strip.xer5f.signed
lrwxrwxrwx 1 root root 55 Mar 9 2018 am64-main-r5f0_1-fw -> /lib/firmware/mcusdk-benchmark_demo/am64-main-r5f0_1-fw
lrwxrwxrwx 1 root root 75 Mar 9 2018 am64-main-r5f0_1-fw-sec -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu1_1_release_strip.xer5f.signed
lrwxrwxrwx 1 root root 55 Mar 9 2018 am64-main-r5f1_0-fw -> /lib/firmware/mcusdk-benchmark_demo/am64-main-r5f1_0-fw
lrwxrwxrwx 1 root root 75 Mar 9 2018 am64-main-r5f1_0-fw-sec -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu2_0_release_strip.xer5f.signed
lrwxrwxrwx 1 root root 55 Mar 9 2018 am64-main-r5f1_1-fw -> /lib/firmware/mcusdk-benchmark_demo/am64-main-r5f1_1-fw
lrwxrwxrwx 1 root root 75 Mar 9 2018 am64-main-r5f1_1-fw-sec -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu2_1_release_strip.xer5f.signed
lrwxrwxrwx 1 root root 68 Mar 9 2018 am64-mcu-m4f0_0-fw -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu3_0_release_strip.xer5f
lrwxrwxrwx 1 root root 75 Mar 9 2018 am64-mcu-m4f0_0-fw-sec -> /lib/firmware/ti-ipc/am64xx/ipc_echo_test_mcu3_0_release_strip.xer5f.signed
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-pru0_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-pru0_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-pru1_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-pru1_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_1.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-rtu0_0-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-rtu0_1-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-rtu1_0-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx 1 root root 49 Mar 9 2018 am64x-rtu1_1-fw -> /lib/firmware/pru/RTU_RPMsg_Echo_Interrupt1_1.out
lrwxrwxrwx 1 root root 35 Mar 9 2018 am64x-txpru0_0-fw -> /lib/firmware/pru/TX_PRU_Halt_0.out
lrwxrwxrwx 1 root root 35 Mar 9 2018 am64x-txpru0_1-fw -> /lib/firmware/pru/TX_PRU_Halt_1.out
lrwxrwxrwx 1 root root 35 Mar 9 2018 am64x-txpru1_0-fw -> /lib/firmware/pru/TX_PRU_Halt_0.out
lrwxrwxrwx 1 root root 35 Mar 9 2018 am64x-txpru1_1-fw -> /lib/firmware/pru/TX_PRU_Halt_1.out
-rw-r--r-- 1 root root 478536 Mar 9 2018 bl32.bin
-rw-r--r-- 1 root root 4285952 Mar 9 2018 bl32.elf
drwxr-xr-x 2 root root 4096 Mar 9 2018 intel
-rw-r--r-- 1 root root 918268 Mar 9 2018 iwlwifi-3160-17.ucode
-rw-r--r-- 1 root root 2448976 Mar 9 2018 iwlwifi-8000C-34.ucode
-rw-r--r-- 1 root root 2428004 Mar 9 2018 iwlwifi-8000C-36.ucode
-rw-r--r-- 1 root root 2440780 Mar 9 2018 iwlwifi-8265-34.ucode
-rw-r--r-- 1 root root 2436632 Mar 9 2018 iwlwifi-8265-36.ucode
-rw-r--r-- 1 root root 2678092 Mar 9 2018 iwlwifi-9260-th-b0-jf-b0-34.ucode
-rw-r--r-- 1 root root 2521412 Mar 9 2018 iwlwifi-9260-th-b0-jf-b0-38.ucode
-rw-r--r-- 1 root root 1489652 Mar 9 2018 iwlwifi-9260-th-b0-jf-b0-46.ucode
drwxr-xr-x 2 root root 4096 Mar 9 2018 mcusdk-benchmark_demo
drwxr-xr-x 2 root root 4096 Mar 9 2018 pru
-rw-r--r-- 1 root root 4728 Mar 9 2018 regulatory.db
-rw-r--r-- 1 root root 1182 Mar 9 2018 regulatory.db.p7s
-rw-r--r-- 1 root root 28 Mar 9 2018 tee-header_v2.bin
-rw-r--r-- 1 root root 0 Mar 9 2018 tee-pageable_v2.bin
-rw-r--r-- 1 root root 478536 Mar 9 2018 tee-pager_v2.bin
-rw-r--r-- 1 root root 478536 Mar 9 2018 tee-raw.bin
-rw-r--r-- 1 root root 478564 Mar 9 2018 tee.bin
-rw-r--r-- 1 root root 4285952 Mar 9 2018 tee.elf
drwxr-xr-x 2 root root 4096 Mar 9 2018 ti-connectivity
drwxr-xr-x 3 root root 4096 Mar 9 2018 ti-ipc
drwxr-xr-x 2 root root 4096 Mar 9 2018 ti-pruss
root@am64xx-evm:~# head /sys/class/remoteproc/remoteproc*/name
==> /sys/class/remoteproc/remoteproc0/name <==
5000000.m4fss
==> /sys/class/remoteproc/remoteproc1/name <==
78000000.r5f
==> /sys/class/remoteproc/remoteproc10/name <==
30034000.pru
==> /sys/class/remoteproc/remoteproc11/name <==
30004000.rtu
==> /sys/class/remoteproc/remoteproc12/name <==
30038000.pru
==> /sys/class/remoteproc/remoteproc13/name <==
30006000.rtu
==> /sys/class/remoteproc/remoteproc14/name <==
300b4000.pru
==> /sys/class/remoteproc/remoteproc15/name <==
30084000.rtu
==> /sys/class/remoteproc/remoteproc16/name <==
300b8000.pru
==> /sys/class/remoteproc/remoteproc2/name <==
78200000.r5f
==> /sys/class/remoteproc/remoteproc3/name <==
78400000.r5f
==> /sys/class/remoteproc/remoteproc4/name <==
78600000.r5f
==> /sys/class/remoteproc/remoteproc5/name <==
3000a000.txpru
==> /sys/class/remoteproc/remoteproc6/name <==
3000c000.txpru
==> /sys/class/remoteproc/remoteproc7/name <==
3008a000.txpru
==> /sys/class/remoteproc/remoteproc8/name <==
3008c000.txpru
==> /sys/class/remoteproc/remoteproc9/name <==
30086000.rtu
root@am64xx-evm:~# echo stop > /sys/class/remoteproc/remoteproc1/state
-sh: echo: write error: Device or resource busy
[ 700.901391] platform 78000000.r5f: k3_r5_rproc_stop: timeout waiting for rproc completion event
[ 700.901413] remoteproc remoteproc1: can't stop rproc: -16
root@am64xx-evm:~#
