AM625: rpmsg_tty
Genius 13655 points
Part Number: AM625
Other Parts Discussed in Thread: BQ25890, TPS51632, TAS2764, TPS65090, DP83869, TPS65912, BQ24190, TPS65910, ADS7950, CDCE925, LM95241, TVP7002, ADC161S626, SN65DSI83, LM95245, ADS7846, ADC108S102, PCM5102A, TMP117, LP8727, INA238, TMP006, LM63, LMP91000, PCM1681, AMC6821, TLC4541, LM93, LM3639, TUSB320, TLV320AIC23B, TAS5805M, TPD12S015, LM8333, ADS8688, DAC5571, HDC2010, TMP401, TAS2552, PCM3168A, TMP464, TPS65219, TPS65218, SN65DSI86, DAC7612, AFE4404, TPS65217, ADS131E08, DRV2665, DRV2667, TMP513, DAC082S085, ADS7828, TUSB1210, TPS65010, LP3972, LP3971, LM8323, ADC128S052, BQ24257, LM3642, TPS23861, CDCE706, ADS1015, TAS2562, TCA6507, INA3221, LM83, TAS6424, TPS62360, LM80, LM87, THS7303, DAC7311, TPS65086, LM3630A, DP83TC811, THS8200, TAS2770, TPS65023, LP3943, LM95234, HD3SS3220, TFP410, TVP5150, TSC2004, TSC2005, OPT3001, TSC2007, LM77, LM70, LP3944, LM73, LM3530, INA209, ADS8344, TAS2780, PCF8574, ADC084S021, ADS7871, PCM3060, TSC2046, LMK04832, LM3532, LM3533, BQ24735, TCA8418, PMP, TPA6130A2, DLPC3433, TWL6040, TAS5086, AFE4403, TMP102, TMP103, ADC128D818, TS3A227E, DAC124S085, TMP421, ADS124S08, TMP108, TPIC2810, LM3560, PCM1789, BQ25980, TPS65132, LM92, TCA6416, LM90
Hello Champs,
Customer  tried the examples rpmsg_char_simple and rpmsg_char_zerocopy, but their previous products used the way of rpmsg_tty, does TI support rpmsg_tty in the way of inter-core communication? He looked at the kernel code and there was rpmsg_tty.c under /drivers/tty
But he failed to open the rpmsg tty driver in make menuconfig. The ttyRPMSG device does not appear in the /dev directory. Why?
Below is the config:
# Automatically generated file; DO NOT EDIT.
# Linux/arm64 6.1.46 Kernel Configuration
CONFIG_CC_VERSION_TEXT="aarch64-oe-linux-gcc (GCC) 11.3.0"
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=110300
CONFIG_CLANG_VERSION=0
CONFIG_AS_IS_GNU=y
CONFIG_AS_VERSION=20244508
CONFIG_LD_IS_BFD=y
CONFIG_LD_VERSION=20244508
CONFIG_LLD_VERSION=0
CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
CONFIG_PAHOLE_VERSION=0
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_TABLE_SORT=y
CONFIG_THREAD_INFO_IN_TASK=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
# CONFIG_WERROR is not set
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_BUILD_SALT=""
CONFIG_DEFAULT_INIT=""
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_SYSVIPC_COMPAT=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
# CONFIG_WATCH_QUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_IRQ_MIGRATION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_GENERIC_IRQ_IPI=y
CONFIG_GENERIC_MSI_IRQ=y
CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
CONFIG_IRQ_MSI_IOMMU=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
CONFIG_HAVE_POSIX_CPU_TIMERS_TASK_WORK=y
CONFIG_POSIX_CPU_TIMERS_TASK_WORK=y
CONFIG_CONTEXT_TRACKING=y
CONFIG_CONTEXT_TRACKING_IDLE=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_BPF=y
CONFIG_HAVE_EBPF_JIT=y
CONFIG_ARCH_WANT_DEFAULT_BPF_JIT=y
# BPF subsystem
CONFIG_BPF_SYSCALL=y
CONFIG_BPF_JIT=y
# CONFIG_BPF_JIT_ALWAYS_ON is not set
CONFIG_BPF_JIT_DEFAULT_ON=y
CONFIG_BPF_UNPRIV_DEFAULT_OFF=y
# CONFIG_BPF_PRELOAD is not set
# end of BPF subsystem
CONFIG_PREEMPT_BUILD=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
# CONFIG_PREEMPT_DYNAMIC is not set
# CONFIG_SCHED_CORE is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_SCHED_AVG_IRQ=y
CONFIG_SCHED_THERMAL_PRESSURE=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
# CONFIG_TASK_DELAY_ACCT is not set
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
CONFIG_PREEMPT_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_TASKS_RCU_GENERIC=y
CONFIG_TASKS_RCU=y
CONFIG_TASKS_TRACE_RCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
# CONFIG_PRINTK_INDEX is not set
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# CONFIG_UCLAMP_TASK is not set
# end of Scheduler features
CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y
CONFIG_CC_HAS_INT128=y
CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5"
CONFIG_GCC11_NO_ARRAY_BOUNDS=y
CONFIG_CC_NO_ARRAY_BOUNDS=y
CONFIG_ARCH_SUPPORTS_INT128=y
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
# CONFIG_CGROUP_FAVOR_DYNMODS is not set
CONFIG_MEMCG=y
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_CGROUP_PIDS=y
# CONFIG_CGROUP_RDMA is not set
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_MISC is not set
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_TIME_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_RD_ZSTD=y
# CONFIG_BOOT_CONFIG is not set
CONFIG_INITRAMFS_PRESERVE_MTIME=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_LD_ORPHAN_WARN=y
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_SYSCTL_EXCEPTION_TRACE=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_KCMP=y
CONFIG_RSEQ=y
# CONFIG_DEBUG_RSEQ is not set
CONFIG_EMBEDDED=y
CONFIG_HAVE_PERF_EVENTS=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
# end of General setup
CONFIG_ARM64=y
CONFIG_GCC_SUPPORTS_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_64BIT=y
CONFIG_MMU=y
CONFIG_ARM64_PAGE_SHIFT=12
CONFIG_ARM64_CONT_PTE_SHIFT=4
CONFIG_ARM64_CONT_PMD_SHIFT=4
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=33
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CSUM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_MHP_MEMMAP_ON_MEMORY_ENABLE=y
CONFIG_SMP=y
CONFIG_KERNEL_MODE_NEON=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_PGTABLE_LEVELS=4
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARCH_PROC_KCORE_TEXT=y
# Platform selection
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_APPLE is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_BITMAIN is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_SPARX5 is not set
CONFIG_ARCH_K3=y
# CONFIG_ARCH_LG1K is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_KEEMBAY is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NXP is not set
# CONFIG_ARCH_NPCM is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_REALTEK is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_SEATTLE is not set
# CONFIG_ARCH_INTEL_SOCFPGA is not set
# CONFIG_ARCH_SYNQUACER is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_SPRD is not set
# CONFIG_ARCH_THUNDER is not set
# CONFIG_ARCH_THUNDER2 is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_VISCONTI is not set
# CONFIG_ARCH_XGENE is not set
# CONFIG_ARCH_ZYNQMP is not set
# end of Platform selection
# Kernel Features
# ARM errata workarounds via the alternatives framework
CONFIG_AMPERE_ERRATUM_AC03_CPU_38=y
CONFIG_ARM64_WORKAROUND_CLEAN_CACHE=y
CONFIG_ARM64_ERRATUM_826319=y
CONFIG_ARM64_ERRATUM_827319=y
CONFIG_ARM64_ERRATUM_824069=y
CONFIG_ARM64_ERRATUM_819472=y
CONFIG_ARM64_ERRATUM_832075=y
CONFIG_ARM64_ERRATUM_1742098=y
CONFIG_ARM64_ERRATUM_845719=y
CONFIG_ARM64_ERRATUM_843419=y
CONFIG_ARM64_LD_HAS_FIX_ERRATUM_843419=y
CONFIG_ARM64_ERRATUM_1024718=y
CONFIG_ARM64_ERRATUM_1418040=y
CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT=y
CONFIG_ARM64_ERRATUM_1165522=y
CONFIG_ARM64_ERRATUM_1319367=y
CONFIG_ARM64_ERRATUM_1530923=y
CONFIG_ARM64_WORKAROUND_REPEAT_TLBI=y
CONFIG_ARM64_ERRATUM_2441007=y
CONFIG_ARM64_ERRATUM_1286807=y
CONFIG_ARM64_ERRATUM_1463225=y
CONFIG_ARM64_ERRATUM_1542419=y
CONFIG_ARM64_ERRATUM_1508412=y
CONFIG_ARM64_ERRATUM_2051678=y
CONFIG_ARM64_ERRATUM_2077057=y
CONFIG_ARM64_ERRATUM_2658417=y
CONFIG_ARM64_WORKAROUND_TSB_FLUSH_FAILURE=y
CONFIG_ARM64_ERRATUM_2054223=y
CONFIG_ARM64_ERRATUM_2067961=y
CONFIG_ARM64_ERRATUM_2441009=y
CONFIG_ARM64_ERRATUM_2457168=y
# CONFIG_CAVIUM_ERRATUM_22375 is not set
# CONFIG_CAVIUM_ERRATUM_23154 is not set
# CONFIG_CAVIUM_ERRATUM_27456 is not set
# CONFIG_CAVIUM_ERRATUM_30115 is not set
CONFIG_CAVIUM_TX2_ERRATUM_219=y
CONFIG_FUJITSU_ERRATUM_010001=y
# CONFIG_HISILICON_ERRATUM_161600802 is not set
# CONFIG_QCOM_FALKOR_ERRATUM_1003 is not set
# CONFIG_QCOM_FALKOR_ERRATUM_1009 is not set
# CONFIG_QCOM_QDF2400_ERRATUM_0065 is not set
# CONFIG_QCOM_FALKOR_ERRATUM_E1041 is not set
CONFIG_NVIDIA_CARMEL_CNP_ERRATUM=y
CONFIG_SOCIONEXT_SYNQUACER_PREITS=y
# end of ARM errata workarounds via the alternatives framework
CONFIG_ARM64_4K_PAGES=y
# CONFIG_ARM64_16K_PAGES is not set
# CONFIG_ARM64_64K_PAGES is not set
# CONFIG_ARM64_VA_BITS_39 is not set
CONFIG_ARM64_VA_BITS_48=y
CONFIG_ARM64_VA_BITS=48
CONFIG_ARM64_PA_BITS_48=y
CONFIG_ARM64_PA_BITS=48
# CONFIG_CPU_BIG_ENDIAN is not set
CONFIG_CPU_LITTLE_ENDIAN=y
CONFIG_SCHED_MC=y
# CONFIG_SCHED_CLUSTER is not set
CONFIG_SCHED_SMT=y
CONFIG_NR_CPUS=256
CONFIG_HOTPLUG_CPU=y
# CONFIG_NUMA is not set
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_SCHED_HRTICK=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_PARAVIRT=y
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
CONFIG_KEXEC=y
CONFIG_KEXEC_FILE=y
# CONFIG_KEXEC_SIG is not set
CONFIG_CRASH_DUMP=y
CONFIG_TRANS_TABLE=y
# CONFIG_XEN is not set
CONFIG_ARCH_FORCE_MAX_ORDER=11
CONFIG_UNMAP_KERNEL_AT_EL0=y
CONFIG_MITIGATE_SPECTRE_BRANCH_HISTORY=y
CONFIG_RODATA_FULL_DEFAULT_ENABLED=y
# CONFIG_ARM64_SW_TTBR0_PAN is not set
CONFIG_ARM64_TAGGED_ADDR_ABI=y
CONFIG_COMPAT=y
CONFIG_KUSER_HELPERS=y
# CONFIG_COMPAT_ALIGNMENT_FIXUPS is not set
# CONFIG_ARMV8_DEPRECATED is not set
# ARMv8.1 architectural features
CONFIG_ARM64_HW_AFDBM=y
CONFIG_ARM64_PAN=y
CONFIG_AS_HAS_LDAPR=y
CONFIG_AS_HAS_LSE_ATOMICS=y
CONFIG_ARM64_LSE_ATOMICS=y
CONFIG_ARM64_USE_LSE_ATOMICS=y
# end of ARMv8.1 architectural features
# ARMv8.2 architectural features
CONFIG_AS_HAS_ARMV8_2=y
CONFIG_AS_HAS_SHA3=y
# CONFIG_ARM64_PMEM is not set
CONFIG_ARM64_RAS_EXTN=y
CONFIG_ARM64_CNP=y
# end of ARMv8.2 architectural features
# ARMv8.3 architectural features
CONFIG_ARM64_PTR_AUTH=y
CONFIG_ARM64_PTR_AUTH_KERNEL=y
CONFIG_CC_HAS_BRANCH_PROT_PAC_RET=y
CONFIG_CC_HAS_SIGN_RETURN_ADDRESS=y
CONFIG_AS_HAS_PAC=y
CONFIG_AS_HAS_CFI_NEGATE_RA_STATE=y
# end of ARMv8.3 architectural features
# ARMv8.4 architectural features
CONFIG_ARM64_AMU_EXTN=y
CONFIG_AS_HAS_ARMV8_4=y
CONFIG_ARM64_TLB_RANGE=y
# end of ARMv8.4 architectural features
# ARMv8.5 architectural features
CONFIG_AS_HAS_ARMV8_5=y
CONFIG_ARM64_BTI=y
CONFIG_CC_HAS_BRANCH_PROT_PAC_RET_BTI=y
CONFIG_ARM64_E0PD=y
CONFIG_ARM64_AS_HAS_MTE=y
CONFIG_ARM64_MTE=y
# end of ARMv8.5 architectural features
# ARMv8.7 architectural features
CONFIG_ARM64_EPAN=y
# end of ARMv8.7 architectural features
CONFIG_ARM64_SVE=y
CONFIG_ARM64_SME=y
CONFIG_ARM64_MODULE_PLTS=y
# CONFIG_ARM64_PSEUDO_NMI is not set
CONFIG_RELOCATABLE=y
CONFIG_RANDOMIZE_BASE=y
CONFIG_RANDOMIZE_MODULE_REGION_FULL=y
CONFIG_CC_HAVE_STACKPROTECTOR_SYSREG=y
CONFIG_STACKPROTECTOR_PER_TASK=y
CONFIG_ARCH_NR_GPIO=0
# end of Kernel Features
# Boot options
CONFIG_CMDLINE=""
CONFIG_EFI_STUB=y
CONFIG_EFI=y
CONFIG_DMI=y
# end of Boot options
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_SUSPEND_SKIP_SYNC is not set
CONFIG_HIBERNATE_CALLBACKS=y
CONFIG_HIBERNATION=y
CONFIG_HIBERNATION_SNAPSHOT_DEV=y
CONFIG_PM_STD_PARTITION=""
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_USERSPACE_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_CPU_PM=y
CONFIG_ENERGY_MODEL=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_ARCH_HIBERNATION_HEADER=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
# end of Power management options
# CPU Power Management
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
# CONFIG_CPU_IDLE_GOV_LADDER is not set
CONFIG_CPU_IDLE_GOV_MENU=y
# CONFIG_CPU_IDLE_GOV_TEO is not set
CONFIG_DT_IDLE_STATES=y
CONFIG_DT_IDLE_GENPD=y
# ARM CPU Idle Drivers
CONFIG_ARM_PSCI_CPUIDLE=y
CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y
# end of ARM CPU Idle Drivers
# end of CPU Idle
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
CONFIG_ARM_SCMI_CPUFREQ=y
CONFIG_ARM_TI_CPUFREQ=y
# end of CPU Frequency scaling
# end of CPU Power Management
CONFIG_ARCH_SUPPORTS_ACPI=y
# CONFIG_ACPI is not set
CONFIG_IRQ_BYPASS_MANAGER=y
CONFIG_HAVE_KVM=y
CONFIG_VIRTUALIZATION=y
# CONFIG_KVM is not set
# General architecture-dependent options
CONFIG_CRASH_CORE=y
CONFIG_KEXEC_CORE=y
CONFIG_ARCH_HAS_SUBPAGE_FAULTS=y
# CONFIG_KPROBES is not set
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_HAVE_IOREMAP_PROT=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_ARCH_CORRECT_STACKTRACE_ON_KRETPROBE=y
CONFIG_HAVE_FUNCTION_ERROR_INJECTION=y
CONFIG_HAVE_NMI=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_NMI_SUPPORT=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_ARCH_HAS_SET_DIRECT_MAP=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_WANTS_NO_INSTR=y
CONFIG_HAVE_ASM_MODVERSIONS=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_FUNCTION_ARG_ACCESS_API=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_HAVE_ARCH_JUMP_LABEL_RELATIVE=y
CONFIG_MMU_GATHER_TABLE_FREE=y
CONFIG_MMU_GATHER_RCU_TABLE_FREE=y
CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
CONFIG_HAVE_ALIGNED_STRUCT_PAGE=y
CONFIG_HAVE_CMPXCHG_LOCAL=y
CONFIG_HAVE_CMPXCHG_DOUBLE=y
CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP=y
CONFIG_SECCOMP_FILTER=y
# CONFIG_SECCOMP_CACHE_DEBUG is not set
CONFIG_HAVE_ARCH_STACKLEAK=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_ARCH_SUPPORTS_LTO_CLANG=y
CONFIG_ARCH_SUPPORTS_LTO_CLANG_THIN=y
CONFIG_LTO_NONE=y
CONFIG_ARCH_SUPPORTS_CFI_CLANG=y
CONFIG_HAVE_CONTEXT_TRACKING_USER=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOVE_PUD=y
CONFIG_HAVE_MOVE_PMD=y
CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y
CONFIG_HAVE_ARCH_HUGE_VMAP=y
CONFIG_HAVE_ARCH_HUGE_VMALLOC=y
CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_RELA=y
CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y
CONFIG_SOFTIRQ_ON_OWN_STACK=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_ARCH_MMAP_RND_BITS=18
CONFIG_HAVE_ARCH_MMAP_RND_COMPAT_BITS=y
CONFIG_ARCH_MMAP_RND_COMPAT_BITS=11
CONFIG_PAGE_SIZE_LESS_THAN_64KB=y
CONFIG_PAGE_SIZE_LESS_THAN_256KB=y
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_COMPAT_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_HAVE_ARCH_VMAP_STACK=y
CONFIG_VMAP_STACK=y
CONFIG_HAVE_ARCH_RANDOMIZE_KSTACK_OFFSET=y
CONFIG_RANDOMIZE_KSTACK_OFFSET=y
# CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT is not set
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_HAVE_ARCH_COMPILER_H=y
CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y
CONFIG_ARCH_USE_MEMREMAP_PROT=y
# CONFIG_LOCK_EVENT_COUNTS is not set
CONFIG_ARCH_HAS_RELR=y
CONFIG_HAVE_PREEMPT_DYNAMIC=y
CONFIG_HAVE_PREEMPT_DYNAMIC_KEY=y
CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
CONFIG_ARCH_SUPPORTS_PAGE_TABLE_CHECK=y
CONFIG_ARCH_HAVE_TRACE_MMIO_ACCESS=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_HAVE_GCC_PLUGINS=y
CONFIG_GCC_PLUGINS=y
# CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
CONFIG_MODULE_COMPRESS_NONE=y
# CONFIG_MODULE_COMPRESS_GZIP is not set
# CONFIG_MODULE_COMPRESS_XZ is not set
# CONFIG_MODULE_COMPRESS_ZSTD is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
CONFIG_MODPROBE_PATH="/sbin/modprobe"
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLOCK_LEGACY_AUTOLOAD=y
CONFIG_BLK_CGROUP_RWSTAT=y
CONFIG_BLK_DEV_BSG_COMMON=y
CONFIG_BLK_DEV_BSGLIB=y
CONFIG_BLK_DEV_INTEGRITY=y
CONFIG_BLK_DEV_INTEGRITY_T10=y
# CONFIG_BLK_DEV_ZONED is not set
CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_BLK_DEV_THROTTLING_LOW is not set
# CONFIG_BLK_WBT is not set
# CONFIG_BLK_CGROUP_IOLATENCY is not set
# CONFIG_BLK_CGROUP_IOCOST is not set
# CONFIG_BLK_CGROUP_IOPRIO is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# CONFIG_BLK_INLINE_ENCRYPTION is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLOCK_COMPAT=y
CONFIG_BLK_MQ_PCI=y
CONFIG_BLK_MQ_VIRTIO=y
CONFIG_BLK_PM=y
CONFIG_BLOCK_HOLDER_DEPRECATED=y
CONFIG_BLK_MQ_STACKING=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_UNINLINE_SPIN_UNLOCK=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y
CONFIG_QUEUED_SPINLOCKS=y
CONFIG_ARCH_USE_QUEUED_RWLOCKS=y
CONFIG_QUEUED_RWLOCKS=y
CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
CONFIG_ARCH_HAS_SYSCALL_WRAPPER=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_COMPAT_BINFMT_ELF=y
CONFIG_ARCH_BINFMT_ELF_STATE=y
CONFIG_ARCH_BINFMT_ELF_EXTRA_PHDRS=y
CONFIG_ARCH_HAVE_ELF_PROT=y
CONFIG_ARCH_USE_GNU_PROPERTY=y
CONFIG_ELFCORE=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_BINFMT_SCRIPT=y
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_SWAP=y
# CONFIG_ZSWAP is not set
# SLAB allocator options
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SLUB_STATS is not set
CONFIG_SLUB_CPU_PARTIAL=y
# end of SLAB allocator options
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
# CONFIG_COMPAT_BRK is not set
CONFIG_SPARSEMEM=y
CONFIG_SPARSEMEM_EXTREME=y
CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y
CONFIG_SPARSEMEM_VMEMMAP=y
CONFIG_HAVE_FAST_GUP=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_EXCLUSIVE_SYSTEM_RAM=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y
CONFIG_MEMORY_HOTPLUG=y
# CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE is not set
CONFIG_MEMORY_HOTREMOVE=y
CONFIG_MHP_MEMMAP_ON_MEMORY=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_ARCH_ENABLE_SPLIT_PMD_PTLOCK=y
CONFIG_MEMORY_BALLOON=y
CONFIG_BALLOON_COMPACTION=y
CONFIG_COMPACTION=y
CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1
CONFIG_PAGE_REPORTING=y
CONFIG_MIGRATION=y
CONFIG_ARCH_ENABLE_HUGEPAGE_MIGRATION=y
CONFIG_ARCH_ENABLE_THP_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_PHYS_ADDR_T_64BIT=y
CONFIG_KSM=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y
CONFIG_MEMORY_FAILURE=y
# CONFIG_HWPOISON_INJECT is not set
CONFIG_ARCH_WANTS_THP_SWAP=y
CONFIG_TRANSPARENT_HUGEPAGE=y
CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y
# CONFIG_TRANSPARENT_HUGEPAGE_MADVISE is not set
CONFIG_THP_SWAP=y
# CONFIG_READ_ONLY_THP_FOR_FS is not set
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
# CONFIG_CMA_SYSFS is not set
CONFIG_CMA_AREAS=19
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_DEFERRED_STRUCT_PAGE_INIT is not set
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y
CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y
CONFIG_ARCH_HAS_PTE_DEVMAP=y
CONFIG_ARCH_HAS_ZONE_DMA_SET=y
CONFIG_ZONE_DMA=y
CONFIG_ZONE_DMA32=y
# CONFIG_ZONE_DEVICE is not set
CONFIG_ARCH_USES_HIGH_VMA_FLAGS=y
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_TEST is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
# CONFIG_ANON_VMA_NAME is not set
# CONFIG_USERFAULTFD is not set
# CONFIG_LRU_GEN is not set
CONFIG_LOCK_MM_AND_FIND_VMA=y
# Data Access Monitoring
# CONFIG_DAMON is not set
# end of Data Access Monitoring
# end of Memory Management options
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_AF_UNIX_OOB=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=y
# CONFIG_XFRM_INTERFACE is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_XFRM_ESP=y
# CONFIG_NET_KEY is not set
CONFIG_XDP_SOCKETS=y
# CONFIG_XDP_SOCKETS_DIAG is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
CONFIG_NET_IP_TUNNEL=m
# CONFIG_IP_MROUTE is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
CONFIG_NET_UDP_TUNNEL=m
# CONFIG_NET_FOU is not set
# CONFIG_NET_FOU_IP_TUNNELS is not set
# CONFIG_INET_AH is not set
CONFIG_INET_ESP=y
# CONFIG_INET_ESP_OFFLOAD is not set
# CONFIG_INET_ESPINTCP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_INET_TABLE_PERTURB_ORDER=16
CONFIG_INET_TUNNEL=m
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=m
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_IPV6_ILA is not set
# CONFIG_IPV6_VTI is not set
CONFIG_IPV6_SIT=m
# CONFIG_IPV6_SIT_6RD is not set
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_IPV6_RPL_LWTUNNEL is not set
# CONFIG_IPV6_IOAM6_LWTUNNEL is not set
# CONFIG_NETLABEL is not set
# CONFIG_MPTCP is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_EGRESS=y
CONFIG_NETFILTER_SKIP_EGRESS=y
CONFIG_NETFILTER_FAMILY_BRIDGE=y
# CONFIG_NETFILTER_NETLINK_ACCT is not set
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
# CONFIG_NETFILTER_NETLINK_LOG is not set
# CONFIG_NETFILTER_NETLINK_OSF is not set
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_SYSLOG=m
# CONFIG_NF_CONNTRACK_MARK is not set
# CONFIG_NF_CONNTRACK_ZONES is not set
# CONFIG_NF_CONNTRACK_PROCFS is not set
CONFIG_NF_CONNTRACK_EVENTS=y
# CONFIG_NF_CONNTRACK_TIMEOUT is not set
# CONFIG_NF_CONNTRACK_TIMESTAMP is not set
# CONFIG_NF_CONNTRACK_LABELS is not set
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
# CONFIG_NF_CONNTRACK_AMANDA is not set
CONFIG_NF_CONNTRACK_FTP=m
# CONFIG_NF_CONNTRACK_H323 is not set
# CONFIG_NF_CONNTRACK_IRC is not set
# CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
# CONFIG_NF_CONNTRACK_SNMP is not set
# CONFIG_NF_CONNTRACK_PPTP is not set
# CONFIG_NF_CONNTRACK_SANE is not set
# CONFIG_NF_CONNTRACK_SIP is not set
CONFIG_NF_CONNTRACK_TFTP=m
# CONFIG_NF_CT_NETLINK is not set
CONFIG_NF_NAT=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_NAT_MASQUERADE=y
# CONFIG_NF_TABLES is not set
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XTABLES_COMPAT=y
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
# CONFIG_NETFILTER_XT_CONNMARK is not set
# Xtables targets
# CONFIG_NETFILTER_XT_TARGET_AUDIT is not set
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
# CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
# CONFIG_NETFILTER_XT_TARGET_DSCP is not set
# CONFIG_NETFILTER_XT_TARGET_HL is not set
# CONFIG_NETFILTER_XT_TARGET_HMARK is not set
# CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
# CONFIG_NETFILTER_XT_TARGET_LED is not set
CONFIG_NETFILTER_XT_TARGET_LOG=m
# CONFIG_NETFILTER_XT_TARGET_MARK is not set
CONFIG_NETFILTER_XT_NAT=m
# CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
# CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
# CONFIG_NETFILTER_XT_TARGET_TEE is not set
# CONFIG_NETFILTER_XT_TARGET_TPROXY is not set
# CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
# CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
# CONFIG_NETFILTER_XT_MATCH_BPF is not set
# CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
# CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
# CONFIG_NETFILTER_XT_MATCH_CPU is not set
# CONFIG_NETFILTER_XT_MATCH_DCCP is not set
# CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
# CONFIG_NETFILTER_XT_MATCH_DSCP is not set
# CONFIG_NETFILTER_XT_MATCH_ECN is not set
# CONFIG_NETFILTER_XT_MATCH_ESP is not set
# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_HELPER is not set
# CONFIG_NETFILTER_XT_MATCH_HL is not set
# CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
CONFIG_NETFILTER_XT_MATCH_IPVS=m
# CONFIG_NETFILTER_XT_MATCH_L2TP is not set
# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_MAC is not set
# CONFIG_NETFILTER_XT_MATCH_MARK is not set
# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
# CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
# CONFIG_NETFILTER_XT_MATCH_OSF is not set
# CONFIG_NETFILTER_XT_MATCH_OWNER is not set
# CONFIG_NETFILTER_XT_MATCH_POLICY is not set
# CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
# CONFIG_NETFILTER_XT_MATCH_REALM is not set
# CONFIG_NETFILTER_XT_MATCH_RECENT is not set
# CONFIG_NETFILTER_XT_MATCH_SCTP is not set
# CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
# CONFIG_NETFILTER_XT_MATCH_STATE is not set
# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
# CONFIG_NETFILTER_XT_MATCH_STRING is not set
# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
# CONFIG_NETFILTER_XT_MATCH_TIME is not set
# CONFIG_NETFILTER_XT_MATCH_U32 is not set
# end of Core Netfilter Configuration
# CONFIG_IP_SET is not set
CONFIG_IP_VS=m
# CONFIG_IP_VS_IPV6 is not set
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
# CONFIG_IP_VS_PROTO_ESP is not set
# CONFIG_IP_VS_PROTO_AH is not set
# CONFIG_IP_VS_PROTO_SCTP is not set
# IPVS scheduler
CONFIG_IP_VS_RR=m
# CONFIG_IP_VS_WRR is not set
# CONFIG_IP_VS_LC is not set
# CONFIG_IP_VS_WLC is not set
# CONFIG_IP_VS_FO is not set
# CONFIG_IP_VS_OVF is not set
# CONFIG_IP_VS_LBLC is not set
# CONFIG_IP_VS_LBLCR is not set
# CONFIG_IP_VS_DH is not set
# CONFIG_IP_VS_SH is not set
# CONFIG_IP_VS_MH is not set
# CONFIG_IP_VS_SED is not set
# CONFIG_IP_VS_NQ is not set
# CONFIG_IP_VS_TWOS is not set
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS MH scheduler
CONFIG_IP_VS_MH_TAB_INDEX=12
# IPVS application helper
# CONFIG_IP_VS_FTP is not set
CONFIG_IP_VS_NFCT=y
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
# CONFIG_NF_SOCKET_IPV4 is not set
# CONFIG_NF_TPROXY_IPV4 is not set
# CONFIG_NF_DUP_IPV4 is not set
# CONFIG_NF_LOG_ARP is not set
# CONFIG_NF_LOG_IPV4 is not set
CONFIG_NF_REJECT_IPV4=m
CONFIG_IP_NF_IPTABLES=m
# CONFIG_IP_NF_MATCH_AH is not set
# CONFIG_IP_NF_MATCH_ECN is not set
# CONFIG_IP_NF_MATCH_RPFILTER is not set
# CONFIG_IP_NF_MATCH_TTL is not set
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
# CONFIG_IP_NF_TARGET_SYNPROXY is not set
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
# CONFIG_IP_NF_TARGET_NETMAP is not set
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
# CONFIG_IP_NF_TARGET_CLUSTERIP is not set
# CONFIG_IP_NF_TARGET_ECN is not set
# CONFIG_IP_NF_TARGET_TTL is not set
# CONFIG_IP_NF_RAW is not set
# CONFIG_IP_NF_SECURITY is not set
# CONFIG_IP_NF_ARPTABLES is not set
# end of IP: Netfilter Configuration
# IPv6: Netfilter Configuration
# CONFIG_NF_SOCKET_IPV6 is not set
# CONFIG_NF_TPROXY_IPV6 is not set
# CONFIG_NF_DUP_IPV6 is not set
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
# CONFIG_IP6_NF_MATCH_AH is not set
# CONFIG_IP6_NF_MATCH_EUI64 is not set
# CONFIG_IP6_NF_MATCH_FRAG is not set
# CONFIG_IP6_NF_MATCH_OPTS is not set
# CONFIG_IP6_NF_MATCH_HL is not set
# CONFIG_IP6_NF_MATCH_IPV6HEADER is not set
# CONFIG_IP6_NF_MATCH_MH is not set
# CONFIG_IP6_NF_MATCH_RPFILTER is not set
# CONFIG_IP6_NF_MATCH_RT is not set
# CONFIG_IP6_NF_MATCH_SRH is not set
# CONFIG_IP6_NF_TARGET_HL is not set
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
# CONFIG_IP6_NF_TARGET_SYNPROXY is not set
CONFIG_IP6_NF_MANGLE=m
# CONFIG_IP6_NF_RAW is not set
# CONFIG_IP6_NF_SECURITY is not set
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
# CONFIG_IP6_NF_TARGET_NPT is not set
# end of IPv6: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV6=m
# CONFIG_NF_CONNTRACK_BRIDGE is not set
# CONFIG_BRIDGE_NF_EBTABLES is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_MRP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_BRIDGE_VLAN_FILTERING=y
# CONFIG_BRIDGE_MRP is not set
# CONFIG_BRIDGE_CFM is not set
CONFIG_NET_DSA=m
# CONFIG_NET_DSA_TAG_AR9331 is not set
CONFIG_NET_DSA_TAG_BRCM_COMMON=m
CONFIG_NET_DSA_TAG_BRCM=m
CONFIG_NET_DSA_TAG_BRCM_LEGACY=m
CONFIG_NET_DSA_TAG_BRCM_PREPEND=m
# CONFIG_NET_DSA_TAG_HELLCREEK is not set
# CONFIG_NET_DSA_TAG_GSWIP is not set
# CONFIG_NET_DSA_TAG_DSA is not set
# CONFIG_NET_DSA_TAG_EDSA is not set
# CONFIG_NET_DSA_TAG_MTK is not set
# CONFIG_NET_DSA_TAG_KSZ is not set
CONFIG_NET_DSA_TAG_OCELOT=m
CONFIG_NET_DSA_TAG_OCELOT_8021Q=m
# CONFIG_NET_DSA_TAG_QCA is not set
# CONFIG_NET_DSA_TAG_RTL4_A is not set
# CONFIG_NET_DSA_TAG_RTL8_4 is not set
# CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set
# CONFIG_NET_DSA_TAG_LAN9303 is not set
# CONFIG_NET_DSA_TAG_SJA1105 is not set
# CONFIG_NET_DSA_TAG_TRAILER is not set
# CONFIG_NET_DSA_TAG_XRS700X is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_LLC=m
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_6LOWPAN is not set
# CONFIG_IEEE802154 is not set
CONFIG_NET_SCHED=y
# Queueing/Scheduling
# CONFIG_NET_SCH_CBQ is not set
# CONFIG_NET_SCH_HTB is not set
# CONFIG_NET_SCH_HFSC is not set
# CONFIG_NET_SCH_PRIO is not set
# CONFIG_NET_SCH_MULTIQ is not set
# CONFIG_NET_SCH_RED is not set
# CONFIG_NET_SCH_SFB is not set
# CONFIG_NET_SCH_SFQ is not set
# CONFIG_NET_SCH_TEQL is not set
# CONFIG_NET_SCH_TBF is not set
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
CONFIG_NET_SCH_TAPRIO=m
# CONFIG_NET_SCH_GRED is not set
# CONFIG_NET_SCH_DSMARK is not set
# CONFIG_NET_SCH_NETEM is not set
# CONFIG_NET_SCH_DRR is not set
CONFIG_NET_SCH_MQPRIO=m
# CONFIG_NET_SCH_SKBPRIO is not set
# CONFIG_NET_SCH_CHOKE is not set
# CONFIG_NET_SCH_QFQ is not set
# CONFIG_NET_SCH_CODEL is not set
# CONFIG_NET_SCH_FQ_CODEL is not set
# CONFIG_NET_SCH_CAKE is not set
# CONFIG_NET_SCH_FQ is not set
# CONFIG_NET_SCH_HHF is not set
# CONFIG_NET_SCH_PIE is not set
CONFIG_NET_SCH_INGRESS=m
# CONFIG_NET_SCH_PLUG is not set
# CONFIG_NET_SCH_ETS is not set
# CONFIG_NET_SCH_DEFAULT is not set
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
# CONFIG_NET_CLS_BPF is not set
CONFIG_NET_CLS_FLOWER=m
# CONFIG_NET_CLS_MATCHALL is not set
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
# CONFIG_NET_EMATCH_CANID is not set
# CONFIG_NET_EMATCH_IPT is not set
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
# CONFIG_NET_ACT_SAMPLE is not set
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
# CONFIG_NET_ACT_MPLS is not set
# CONFIG_NET_ACT_VLAN is not set
# CONFIG_NET_ACT_BPF is not set
# CONFIG_NET_ACT_SKBMOD is not set
# CONFIG_NET_ACT_IFE is not set
# CONFIG_NET_ACT_TUNNEL_KEY is not set
CONFIG_NET_ACT_GATE=m
# CONFIG_NET_TC_SKB_EXT is not set
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
CONFIG_HSR=m
CONFIG_NET_SWITCHDEV=y
CONFIG_NET_L3_MASTER_DEV=y
CONFIG_QRTR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
CONFIG_QRTR_MHI=m
# CONFIG_NET_NCSI is not set
CONFIG_PCPU_DEV_REFCNT=y
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_SOCK_RX_QUEUE_MAPPING=y
CONFIG_XPS=y
CONFIG_CGROUP_NET_PRIO=y
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_STREAM_PARSER is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
# CONFIG_CAN_J1939 is not set
# CONFIG_CAN_ISOTP is not set
CONFIG_BT=m
CONFIG_BT_BREDR=y
# CONFIG_BT_RFCOMM is not set
# CONFIG_BT_BNEP is not set
CONFIG_BT_HIDP=m
# CONFIG_BT_HS is not set
# CONFIG_BT_LE is not set
CONFIG_BT_LEDS=y
# CONFIG_BT_MSFTEXT is not set
# CONFIG_BT_AOSPEXT is not set
# CONFIG_BT_DEBUGFS is not set
# CONFIG_BT_SELFTEST is not set
# CONFIG_BT_FEATURE_DEBUG is not set
# Bluetooth device drivers
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=m
CONFIG_BT_RTL=m
CONFIG_BT_QCA=m
CONFIG_BT_HCIBTUSB=m
# CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set
CONFIG_BT_HCIBTUSB_BCM=y
# CONFIG_BT_HCIBTUSB_MTK is not set
CONFIG_BT_HCIBTUSB_RTL=y
# CONFIG_BT_HCIBTSDIO is not set
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_SERDEV=y
CONFIG_BT_HCIUART_H4=y
# CONFIG_BT_HCIUART_NOKIA is not set
# CONFIG_BT_HCIUART_BCSP is not set
# CONFIG_BT_HCIUART_ATH3K is not set
CONFIG_BT_HCIUART_LL=y
# CONFIG_BT_HCIUART_3WIRE is not set
# CONFIG_BT_HCIUART_INTEL is not set
CONFIG_BT_HCIUART_BCM=y
# CONFIG_BT_HCIUART_RTL is not set
CONFIG_BT_HCIUART_QCA=y
# CONFIG_BT_HCIUART_AG6XX is not set
CONFIG_BT_HCIUART_MRVL=y
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
# CONFIG_BT_HCIBFUSB is not set
# CONFIG_BT_HCIVHCI is not set
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
# CONFIG_BT_ATH3K is not set
# CONFIG_BT_MTKSDIO is not set
# CONFIG_BT_MTKUART is not set
# CONFIG_BT_VIRTIO is not set
# end of Bluetooth device drivers
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
# CONFIG_MCTP is not set
CONFIG_WIRELESS=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
# CONFIG_CFG80211_WEXT is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_RFKILL=m
CONFIG_RFKILL_LEDS=y
# CONFIG_RFKILL_INPUT is not set
# CONFIG_RFKILL_GPIO is not set
CONFIG_NET_9P=y
CONFIG_NET_9P_FD=y
CONFIG_NET_9P_VIRTIO=y
# CONFIG_NET_9P_DEBUG is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
CONFIG_NFC=m
# CONFIG_NFC_DIGITAL is not set
CONFIG_NFC_NCI=m
# CONFIG_NFC_NCI_SPI is not set
# CONFIG_NFC_NCI_UART is not set
# CONFIG_NFC_HCI is not set
# Near Field Communication (NFC) devices
# CONFIG_NFC_VIRTUAL_NCI is not set
# CONFIG_NFC_FDP is not set
# CONFIG_NFC_PN533_USB is not set
# CONFIG_NFC_PN533_I2C is not set
# CONFIG_NFC_PN532_UART is not set
# CONFIG_NFC_MRVL_USB is not set
# CONFIG_NFC_ST_NCI_I2C is not set
# CONFIG_NFC_ST_NCI_SPI is not set
# CONFIG_NFC_NXP_NCI is not set
CONFIG_NFC_S3FWRN5=m
CONFIG_NFC_S3FWRN5_I2C=m
# CONFIG_NFC_S3FWRN82_UART is not set
# end of Near Field Communication (NFC) devices
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_NET_SELFTESTS=y
CONFIG_NET_SOCK_MSG=y
CONFIG_NET_DEVLINK=y
CONFIG_PAGE_POOL=y
CONFIG_PAGE_POOL_STATS=y
CONFIG_FAILOVER=y
CONFIG_ETHTOOL_NETLINK=y
# Device Drivers
CONFIG_ARM_AMBA=y
CONFIG_HAVE_PCI=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
CONFIG_PCIEPORTBUS=y
# CONFIG_HOTPLUG_PCI_PCIE is not set
CONFIG_PCIEAER=y
# CONFIG_PCIEAER_INJECT is not set
# CONFIG_PCIE_ECRC is not set
CONFIG_PCIEASPM=y
CONFIG_PCIEASPM_DEFAULT=y
# CONFIG_PCIEASPM_POWERSAVE is not set
# CONFIG_PCIEASPM_POWER_SUPERSAVE is not set
# CONFIG_PCIEASPM_PERFORMANCE is not set
CONFIG_PCIE_PME=y
# CONFIG_PCIE_DPC is not set
# CONFIG_PCIE_PTM is not set
CONFIG_PCI_MSI=y
CONFIG_PCI_MSI_IRQ_DOMAIN=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
# CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
# CONFIG_PCI_STUB is not set
# CONFIG_PCI_PF_STUB is not set
CONFIG_PCI_ATS=y
CONFIG_PCI_ECAM=y
CONFIG_PCI_IOV=y
# CONFIG_PCI_PRI is not set
CONFIG_PCI_PASID=y
CONFIG_PCI_LABEL=y
# CONFIG_PCIE_BUS_TUNE_OFF is not set
CONFIG_PCIE_BUS_DEFAULT=y
# CONFIG_PCIE_BUS_SAFE is not set
# CONFIG_PCIE_BUS_PERFORMANCE is not set
# CONFIG_PCIE_BUS_PEER2PEER is not set
# CONFIG_VGA_ARB is not set
CONFIG_HOTPLUG_PCI=y
# CONFIG_HOTPLUG_PCI_CPCI is not set
# CONFIG_HOTPLUG_PCI_SHPC is not set
# PCI controller drivers
# CONFIG_PCI_FTPCI100 is not set
CONFIG_PCI_HOST_COMMON=y
CONFIG_PCI_HOST_GENERIC=y
# CONFIG_PCIE_XILINX is not set
# CONFIG_PCI_XGENE is not set
CONFIG_PCIE_ALTERA=y
CONFIG_PCIE_ALTERA_MSI=y
CONFIG_PCI_HOST_THUNDER_PEM=y
CONFIG_PCI_HOST_THUNDER_ECAM=y
# CONFIG_PCIE_MICROCHIP_HOST is not set
# DesignWare PCI Core Support
CONFIG_PCIE_DW=y
CONFIG_PCIE_DW_HOST=y
CONFIG_PCIE_DW_EP=y
# CONFIG_PCIE_DW_PLAT_HOST is not set
# CONFIG_PCIE_DW_PLAT_EP is not set
CONFIG_PCI_KEYSTONE=y
CONFIG_PCI_KEYSTONE_HOST=y
CONFIG_PCI_KEYSTONE_EP=y
# CONFIG_PCI_HISI is not set
# CONFIG_PCIE_KIRIN is not set
CONFIG_PCI_MESON=m
# CONFIG_PCIE_AL is not set
# end of DesignWare PCI Core Support
# Mobiveil PCIe Core Support
# end of Mobiveil PCIe Core Support
# Cadence PCIe controllers support
CONFIG_PCIE_CADENCE=m
CONFIG_PCIE_CADENCE_HOST=m
CONFIG_PCIE_CADENCE_EP=m
# CONFIG_PCIE_CADENCE_PLAT_HOST is not set
# CONFIG_PCIE_CADENCE_PLAT_EP is not set
CONFIG_PCI_J721E=m
CONFIG_PCI_J721E_HOST=m
CONFIG_PCI_J721E_EP=m
# end of Cadence PCIe controllers support
# end of PCI controller drivers
# PCI Endpoint
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=y
CONFIG_PCI_EPF_NTB=y
# end of PCI Endpoint
# PCI switch controller drivers
# CONFIG_PCI_SW_SWITCHTEC is not set
# end of PCI switch controller drivers
# CONFIG_CXL_BUS is not set
# CONFIG_PCCARD is not set
# CONFIG_RAPIDIO is not set
# Generic Driver Options
CONFIG_AUXILIARY_BUS=y
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
# CONFIG_DEVTMPFS_SAFE is not set
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_FW_LOADER_PAGED_BUF=y
CONFIG_FW_LOADER_SYSFS=y
CONFIG_EXTRA_FIRMWARE=""
CONFIG_FW_LOADER_USER_HELPER=y
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
# CONFIG_FW_LOADER_COMPRESS is not set
CONFIG_FW_CACHE=y
# CONFIG_FW_UPLOAD is not set
# end of Firmware loader
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_GENERIC_CPU_VULNERABILITIES=y
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SLIMBUS=m
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_SPMI=m
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_REGMAP_SOUNDWIRE=m
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# end of Generic Driver Options
# Bus devices
CONFIG_ARM_CCI=y
CONFIG_ARM_CCI400_COMMON=y
CONFIG_BRCMSTB_GISB_ARB=y
# CONFIG_MOXTET is not set
CONFIG_VEXPRESS_CONFIG=y
CONFIG_MHI_BUS=m
# CONFIG_MHI_BUS_DEBUG is not set
# CONFIG_MHI_BUS_PCI_GENERIC is not set
# CONFIG_MHI_BUS_EP is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# Firmware Drivers
# ARM System Control and Management Interface Protocol
CONFIG_ARM_SCMI_PROTOCOL=y
CONFIG_ARM_SCMI_HAVE_TRANSPORT=y
CONFIG_ARM_SCMI_HAVE_SHMEM=y
CONFIG_ARM_SCMI_HAVE_MSG=y
CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y
CONFIG_ARM_SCMI_TRANSPORT_OPTEE=y
CONFIG_ARM_SCMI_TRANSPORT_SMC=y
# CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set
# CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set
CONFIG_ARM_SCMI_POWER_DOMAIN=y
# CONFIG_ARM_SCMI_POWER_CONTROL is not set
# end of ARM System Control and Management Interface Protocol
# CONFIG_ARM_SCPI_PROTOCOL is not set
# CONFIG_FIRMWARE_MEMMAP is not set
CONFIG_DMIID=y
# CONFIG_DMI_SYSFS is not set
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_SYSFB_SIMPLEFB is not set
CONFIG_TI_SCI_PROTOCOL=y
# CONFIG_ARM_FFA_TRANSPORT is not set
# CONFIG_GOOGLE_FIRMWARE is not set
# EFI (Extensible Firmware Interface) Support
CONFIG_EFI_ESRT=y
CONFIG_EFI_VARS_PSTORE=y
# CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set
CONFIG_EFI_PARAMS_FROM_FDT=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_GENERIC_STUB=y
# CONFIG_EFI_ZBOOT is not set
CONFIG_EFI_ARMSTUB_DTB_LOADER=y
# CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set
# CONFIG_EFI_BOOTLOADER_CONTROL is not set
CONFIG_EFI_CAPSULE_LOADER=y
# CONFIG_EFI_TEST is not set
# CONFIG_RESET_ATTACK_MITIGATION is not set
# CONFIG_EFI_DISABLE_PCI_DMA is not set
CONFIG_EFI_EARLYCON=y
# CONFIG_EFI_DISABLE_RUNTIME is not set
# CONFIG_EFI_COCO_SECRET is not set
# end of EFI (Extensible Firmware Interface) Support
CONFIG_ARM_PSCI_FW=y
# CONFIG_ARM_PSCI_CHECKER is not set
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y
CONFIG_ARM_SMCCC_SOC_ID=y
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
CONFIG_GNSS=m
CONFIG_GNSS_SERIAL=m
CONFIG_GNSS_MTK_SERIAL=m
# CONFIG_GNSS_SIRF_SERIAL is not set
# CONFIG_GNSS_UBX_SERIAL is not set
# CONFIG_GNSS_USB is not set
CONFIG_MTD=y
CONFIG_MTD_TESTS=m
# Partition parsers
# CONFIG_MTD_AR7_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK.
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_NOSWAP=y
# CONFIG_MTD_CFI_BE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_LE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_GEOMETRY is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_OTP is not set
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_CFI_UTIL=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=y
# CONFIG_MTD_PHYSMAP_COMPAT is not set
CONFIG_MTD_PHYSMAP_OF=y
# CONFIG_MTD_PHYSMAP_VERSATILE is not set
# CONFIG_MTD_PHYSMAP_GEMINI is not set
# CONFIG_MTD_PHYSMAP_GPIO_ADDR is not set
# CONFIG_MTD_PCI is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
CONFIG_MTD_DATAFLASH=y
# CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
# CONFIG_MTD_DATAFLASH_OTP is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_MCHP48L640 is not set
CONFIG_MTD_SST25L=y
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# NAND
CONFIG_MTD_NAND_CORE=y
# CONFIG_MTD_ONENAND is not set
CONFIG_MTD_RAW_NAND=y
# Raw/parallel NAND flash controllers
CONFIG_MTD_NAND_DENALI=y
# CONFIG_MTD_NAND_DENALI_PCI is not set
CONFIG_MTD_NAND_DENALI_DT=y
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_OMAP_BCH=y
CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
# CONFIG_MTD_NAND_CAFE is not set
CONFIG_MTD_NAND_BRCMNAND=m
# CONFIG_MTD_NAND_BRCMNAND_BCM63XX is not set
CONFIG_MTD_NAND_BRCMNAND_BCMBCA=m
CONFIG_MTD_NAND_BRCMNAND_BRCMSTB=m
CONFIG_MTD_NAND_BRCMNAND_IPROC=m
# CONFIG_MTD_NAND_MXIC is not set
# CONFIG_MTD_NAND_GPIO is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_NAND_CADENCE is not set
# CONFIG_MTD_NAND_ARASAN is not set
# CONFIG_MTD_NAND_INTEL_LGM is not set
# Misc
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_RICOH is not set
# CONFIG_MTD_NAND_DISKONCHIP is not set
CONFIG_MTD_SPI_NAND=y
# ECC engine support
CONFIG_MTD_NAND_ECC=y
CONFIG_MTD_NAND_ECC_SW_HAMMING=y
# CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
# CONFIG_MTD_NAND_ECC_SW_BCH is not set
# CONFIG_MTD_NAND_ECC_MXIC is not set
# end of ECC engine support
# end of NAND
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set
CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y
# CONFIG_MTD_SPI_NOR_SWP_KEEP is not set
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
CONFIG_MTD_HYPERBUS=m
CONFIG_HBMC_AM654=m
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
# CONFIG_ZRAM is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_DRBD is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_VIRTIO_BLK=y
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_BLK_DEV_UBLK is not set
# NVME Support
CONFIG_NVME_CORE=m
CONFIG_BLK_DEV_NVME=m
# CONFIG_NVME_MULTIPATH is not set
# CONFIG_NVME_VERBOSE_ERRORS is not set
# CONFIG_NVME_HWMON is not set
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TCP is not set
# CONFIG_NVME_AUTH is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_PHANTOM is not set
# CONFIG_TIFM_CORE is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_HI6421V600_IRQ is not set
# CONFIG_HP_ILO is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
CONFIG_SRAM=y
CONFIG_SRAM_DMA_HEAP=y
# CONFIG_DW_XDATA_PCIE is not set
CONFIG_PCI_ENDPOINT_TEST=m
# CONFIG_XILINX_SDFEC is not set
# CONFIG_HISI_HIKEY_USB is not set
# CONFIG_OPEN_DICE is not set
# CONFIG_VCPU_STALL_DETECTOR is not set
CONFIG_DMA_BUF_PHYS=y
CONFIG_TPS6594_ESM=y
CONFIG_TPS6594_PFSM=y
# CONFIG_C2PORT is not set
# EEPROM support
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# CONFIG_CB710_CORE is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# CONFIG_VMWARE_VMCI is not set
# CONFIG_GENWQE is not set
# CONFIG_ECHO is not set
# CONFIG_BCM_VK is not set
# CONFIG_MISC_ALCOR_PCI is not set
# CONFIG_MISC_RTSX_PCI is not set
# CONFIG_MISC_RTSX_USB is not set
# CONFIG_HABANA_AI is not set
CONFIG_UACCE=m
# CONFIG_PVPANIC is not set
# CONFIG_GP_PCI1XXXX is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
CONFIG_RAID_ATTRS=m
CONFIG_SCSI_COMMON=y
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_PROC_FS is not set
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
CONFIG_BLK_DEV_BSG=y
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
CONFIG_SCSI_SAS_ATTRS=y
CONFIG_SCSI_SAS_LIBSAS=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_SAS_HOST_SMP=y
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_CXGB3_ISCSI is not set
# CONFIG_SCSI_CXGB4_ISCSI is not set
# CONFIG_SCSI_BNX2_ISCSI is not set
# CONFIG_BE2ISCSI is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_HPSA is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_3W_SAS is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC94XX is not set
CONFIG_SCSI_HISI_SAS=y
# CONFIG_SCSI_HISI_SAS_DEBUGFS_DEFAULT_ENABLE is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_MVUMI is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_ARCMSR is not set
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
CONFIG_MEGARAID_SAS=y
CONFIG_SCSI_MPT3SAS=m
CONFIG_SCSI_MPT2SAS_MAX_SGE=128
CONFIG_SCSI_MPT3SAS_MAX_SGE=128
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_MPI3MR is not set
# CONFIG_SCSI_SMARTPQI is not set
# CONFIG_SCSI_HPTIOP is not set
# CONFIG_SCSI_BUSLOGIC is not set
# CONFIG_SCSI_MYRB is not set
# CONFIG_SCSI_MYRS is not set
# CONFIG_SCSI_SNIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_FDOMAIN_PCI is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_STEX is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_IPR is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_ISCSI is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_AM53C974 is not set
# CONFIG_SCSI_WD719X is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_PMCRAID is not set
# CONFIG_SCSI_PM8001 is not set
# CONFIG_SCSI_VIRTIO is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
CONFIG_ATA=y
CONFIG_SATA_HOST=y
CONFIG_ATA_VERBOSE_ERROR=y
CONFIG_ATA_FORCE=y
CONFIG_SATA_PMP=y
# Controllers with non-SFF native interface
CONFIG_SATA_AHCI=y
CONFIG_SATA_MOBILE_LPM_POLICY=0
CONFIG_SATA_AHCI_PLATFORM=y
# CONFIG_AHCI_DWC is not set
CONFIG_AHCI_CEVA=y
CONFIG_AHCI_XGENE=y
CONFIG_AHCI_QORIQ=y
# CONFIG_SATA_INIC162X is not set
# CONFIG_SATA_ACARD_AHCI is not set
CONFIG_SATA_SIL24=y
CONFIG_ATA_SFF=y
# SFF controllers with custom DMA interface
# CONFIG_PDC_ADMA is not set
# CONFIG_SATA_QSTOR is not set
# CONFIG_SATA_SX4 is not set
CONFIG_ATA_BMDMA=y
# SATA SFF controllers with BMDMA
# CONFIG_ATA_PIIX is not set
# CONFIG_SATA_DWC is not set
# CONFIG_SATA_MV is not set
# CONFIG_SATA_NV is not set
# CONFIG_SATA_PROMISE is not set
# CONFIG_SATA_SIL is not set
# CONFIG_SATA_SIS is not set
# CONFIG_SATA_SVW is not set
# CONFIG_SATA_ULI is not set
# CONFIG_SATA_VIA is not set
# CONFIG_SATA_VITESSE is not set
# PATA SFF controllers with BMDMA
# CONFIG_PATA_ALI is not set
# CONFIG_PATA_AMD is not set
# CONFIG_PATA_ARTOP is not set
# CONFIG_PATA_ATIIXP is not set
# CONFIG_PATA_ATP867X is not set
# CONFIG_PATA_CMD64X is not set
# CONFIG_PATA_CYPRESS is not set
# CONFIG_PATA_EFAR is not set
# CONFIG_PATA_HPT366 is not set
# CONFIG_PATA_HPT37X is not set
# CONFIG_PATA_HPT3X2N is not set
# CONFIG_PATA_HPT3X3 is not set
# CONFIG_PATA_IT8213 is not set
# CONFIG_PATA_IT821X is not set
# CONFIG_PATA_JMICRON is not set
# CONFIG_PATA_MARVELL is not set
# CONFIG_PATA_NETCELL is not set
# CONFIG_PATA_NINJA32 is not set
# CONFIG_PATA_NS87415 is not set
# CONFIG_PATA_OLDPIIX is not set
# CONFIG_PATA_OPTIDMA is not set
# CONFIG_PATA_PDC2027X is not set
# CONFIG_PATA_PDC_OLD is not set
# CONFIG_PATA_RADISYS is not set
# CONFIG_PATA_RDC is not set
# CONFIG_PATA_SCH is not set
# CONFIG_PATA_SERVERWORKS is not set
# CONFIG_PATA_SIL680 is not set
# CONFIG_PATA_SIS is not set
# CONFIG_PATA_TOSHIBA is not set
# CONFIG_PATA_TRIFLEX is not set
# CONFIG_PATA_VIA is not set
# CONFIG_PATA_WINBOND is not set
# PIO-only SFF controllers
# CONFIG_PATA_CMD640_PCI is not set
# CONFIG_PATA_MPIIX is not set
# CONFIG_PATA_NS87410 is not set
# CONFIG_PATA_OPTI is not set
CONFIG_PATA_PLATFORM=y
CONFIG_PATA_OF_PLATFORM=y
# CONFIG_PATA_RZ1000 is not set
# Generic fallback / legacy drivers
# CONFIG_ATA_GENERIC is not set
# CONFIG_PATA_LEGACY is not set
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
# CONFIG_MD_LINEAR is not set
# CONFIG_MD_RAID0 is not set
# CONFIG_MD_RAID1 is not set
# CONFIG_MD_RAID10 is not set
# CONFIG_MD_RAID456 is not set
# CONFIG_MD_MULTIPATH is not set
# CONFIG_MD_FAULTY is not set
# CONFIG_BCACHE is not set
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_DEBUG is not set
CONFIG_DM_BUFIO=m
# CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
# CONFIG_DM_UNSTRIPED is not set
# CONFIG_DM_CRYPT is not set
# CONFIG_DM_SNAPSHOT is not set
CONFIG_DM_THIN_PROVISIONING=m
# CONFIG_DM_CACHE is not set
# CONFIG_DM_WRITECACHE is not set
# CONFIG_DM_EBS is not set
# CONFIG_DM_ERA is not set
# CONFIG_DM_CLONE is not set
CONFIG_DM_MIRROR=m
# CONFIG_DM_LOG_USERSPACE is not set
# CONFIG_DM_RAID is not set
CONFIG_DM_ZERO=m
# CONFIG_DM_MULTIPATH is not set
# CONFIG_DM_DELAY is not set
# CONFIG_DM_DUST is not set
# CONFIG_DM_UEVENT is not set
# CONFIG_DM_FLAKEY is not set
# CONFIG_DM_VERITY is not set
# CONFIG_DM_SWITCH is not set
# CONFIG_DM_LOG_WRITES is not set
# CONFIG_DM_INTEGRITY is not set
# CONFIG_DM_AUDIT is not set
# CONFIG_TARGET_CORE is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_FIREWIRE is not set
# CONFIG_FIREWIRE_NOSY is not set
# end of IEEE 1394 (FireWire) support
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
CONFIG_DUMMY=m
# CONFIG_WIREGUARD is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_FC is not set
# CONFIG_IFB is not set
# CONFIG_NET_TEAM is not set
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN_L3S=y
CONFIG_IPVLAN=m
# CONFIG_IPVTAP is not set
CONFIG_VXLAN=m
# CONFIG_GENEVE is not set
# CONFIG_BAREUDP is not set
# CONFIG_GTP is not set
# CONFIG_AMT is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
CONFIG_TUN=y
CONFIG_TAP=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
# CONFIG_NLMON is not set
# CONFIG_MHI_NET is not set
# CONFIG_ARCNET is not set
# Distributed Switch Architecture drivers
CONFIG_B53=m
# CONFIG_B53_SPI_DRIVER is not set
# CONFIG_B53_MDIO_DRIVER is not set
# CONFIG_B53_MMAP_DRIVER is not set
CONFIG_B53_SRAB_DRIVER=m
# CONFIG_B53_SERDES is not set
CONFIG_NET_DSA_BCM_SF2=m
# CONFIG_NET_DSA_LOOP is not set
# CONFIG_NET_DSA_HIRSCHMANN_HELLCREEK is not set
# CONFIG_NET_DSA_LANTIQ_GSWIP is not set
# CONFIG_NET_DSA_MT7530 is not set
# CONFIG_NET_DSA_MV88E6060 is not set
# CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set
# CONFIG_NET_DSA_MV88E6XXX is not set
# CONFIG_NET_DSA_MSCC_SEVILLE is not set
# CONFIG_NET_DSA_AR9331 is not set
# CONFIG_NET_DSA_QCA8K is not set
# CONFIG_NET_DSA_SJA1105 is not set
# CONFIG_NET_DSA_XRS700X_I2C is not set
# CONFIG_NET_DSA_XRS700X_MDIO is not set
# CONFIG_NET_DSA_REALTEK is not set
# CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
# CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
# CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
# CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_MDIO=m
CONFIG_NET_VENDOR_3COM=y
# CONFIG_VORTEX is not set
# CONFIG_TYPHOON is not set
CONFIG_NET_VENDOR_ADAPTEC=y
# CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_NET_VENDOR_AGERE=y
# CONFIG_ET131X is not set
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_SLICOSS is not set
CONFIG_NET_VENDOR_ALTEON=y
# CONFIG_ACENIC is not set
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
# CONFIG_ENA_ETHERNET is not set
CONFIG_NET_VENDOR_AMD=y
# CONFIG_AMD8111_ETH is not set
# CONFIG_PCNET32 is not set
CONFIG_AMD_XGBE=y
CONFIG_NET_VENDOR_AQUANTIA=y
# CONFIG_AQTION is not set
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_ASIX=y
# CONFIG_SPI_AX88796C is not set
CONFIG_NET_VENDOR_ATHEROS=y
# CONFIG_ATL2 is not set
# CONFIG_ATL1 is not set
# CONFIG_ATL1E is not set
CONFIG_ATL1C=m
# CONFIG_ALX is not set
CONFIG_NET_VENDOR_BROADCOM=y
# CONFIG_B44 is not set
CONFIG_BCMGENET=m
# CONFIG_BNX2 is not set
# CONFIG_CNIC is not set
# CONFIG_TIGON3 is not set
CONFIG_BNX2X=m
CONFIG_BNX2X_SRIOV=y
CONFIG_SYSTEMPORT=m
# CONFIG_BNXT is not set
CONFIG_NET_VENDOR_CADENCE=y
CONFIG_MACB=y
CONFIG_MACB_USE_HWSTAMP=y
# CONFIG_MACB_PCI is not set
CONFIG_NET_VENDOR_CAVIUM=y
CONFIG_THUNDER_NIC_PF=y
# CONFIG_THUNDER_NIC_VF is not set
CONFIG_THUNDER_NIC_BGX=y
CONFIG_THUNDER_NIC_RGX=y
# CONFIG_CAVIUM_PTP is not set
# CONFIG_LIQUIDIO is not set
# CONFIG_LIQUIDIO_VF is not set
CONFIG_NET_VENDOR_CHELSIO=y
# CONFIG_CHELSIO_T1 is not set
# CONFIG_CHELSIO_T3 is not set
# CONFIG_CHELSIO_T4 is not set
# CONFIG_CHELSIO_T4VF is not set
CONFIG_NET_VENDOR_CISCO=y
# CONFIG_ENIC is not set
CONFIG_NET_VENDOR_CORTINA=y
# CONFIG_GEMINI_ETHERNET is not set
CONFIG_NET_VENDOR_DAVICOM=y
# CONFIG_DM9051 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_DEC=y
# CONFIG_NET_TULIP is not set
CONFIG_NET_VENDOR_DLINK=y
# CONFIG_DL2K is not set
# CONFIG_SUNDANCE is not set
CONFIG_NET_VENDOR_EMULEX=y
# CONFIG_BE2NET is not set
CONFIG_NET_VENDOR_ENGLEDER=y
# CONFIG_TSNEP is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_FUNGIBLE=y
# CONFIG_FUN_ETH is not set
CONFIG_NET_VENDOR_GOOGLE=y
# CONFIG_GVE is not set
CONFIG_NET_VENDOR_HISILICON=y
CONFIG_HIX5HD2_GMAC=y
# CONFIG_HISI_FEMAC is not set
# CONFIG_HIP04_ETH is not set
CONFIG_HNS_MDIO=y
CONFIG_HNS=y
CONFIG_HNS_DSAF=y
CONFIG_HNS_ENET=y
CONFIG_HNS3=y
CONFIG_HNS3_HCLGE=y
# CONFIG_HNS3_HCLGEVF is not set
CONFIG_HNS3_ENET=y
CONFIG_NET_VENDOR_HUAWEI=y
# CONFIG_HINIC is not set
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
# CONFIG_E100 is not set
CONFIG_E1000=y
CONFIG_E1000E=y
CONFIG_IGB=y
CONFIG_IGB_HWMON=y
CONFIG_IGBVF=y
# CONFIG_IXGB is not set
# CONFIG_IXGBE is not set
# CONFIG_IXGBEVF is not set
# CONFIG_I40E is not set
# CONFIG_I40EVF is not set
# CONFIG_ICE is not set
# CONFIG_FM10K is not set
# CONFIG_IGC is not set
CONFIG_NET_VENDOR_WANGXUN=y
# CONFIG_NGBE is not set
# CONFIG_TXGBE is not set
# CONFIG_JME is not set
CONFIG_NET_VENDOR_ADI=y
# CONFIG_ADIN1110 is not set
CONFIG_NET_VENDOR_LITEX=y
# CONFIG_LITEX_LITEETH is not set
CONFIG_NET_VENDOR_MARVELL=y
CONFIG_MVMDIO=y
# CONFIG_SKGE is not set
CONFIG_SKY2=y
# CONFIG_SKY2_DEBUG is not set
# CONFIG_OCTEONTX2_AF is not set
# CONFIG_OCTEONTX2_PF is not set
# CONFIG_OCTEON_EP is not set
# CONFIG_PRESTERA is not set
CONFIG_NET_VENDOR_MELLANOX=y
CONFIG_MLX4_EN=m
CONFIG_MLX4_CORE=m
CONFIG_MLX4_DEBUG=y
CONFIG_MLX4_CORE_GEN2=y
CONFIG_MLX5_CORE=m
# CONFIG_MLX5_FPGA is not set
CONFIG_MLX5_CORE_EN=y
CONFIG_MLX5_EN_ARFS=y
CONFIG_MLX5_EN_RXNFC=y
CONFIG_MLX5_MPFS=y
CONFIG_MLX5_ESWITCH=y
CONFIG_MLX5_BRIDGE=y
CONFIG_MLX5_CLS_ACT=y
CONFIG_MLX5_TC_SAMPLE=y
# CONFIG_MLX5_CORE_IPOIB is not set
CONFIG_MLX5_SW_STEERING=y
# CONFIG_MLX5_SF is not set
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_KSZ884X_PCI is not set
CONFIG_NET_VENDOR_MICROCHIP=y
# CONFIG_ENC28J60 is not set
# CONFIG_ENCX24J600 is not set
# CONFIG_LAN743X is not set
# CONFIG_LAN966X_SWITCH is not set
CONFIG_NET_VENDOR_MICROSEMI=y
# CONFIG_MSCC_OCELOT_SWITCH is not set
CONFIG_NET_VENDOR_MICROSOFT=y
CONFIG_NET_VENDOR_MYRI=y
# CONFIG_MYRI10GE is not set
# CONFIG_FEALNX is not set
CONFIG_NET_VENDOR_NI=y
# CONFIG_NI_XGE_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_NATSEMI=y
# CONFIG_NATSEMI is not set
# CONFIG_NS83820 is not set
CONFIG_NET_VENDOR_NETERION=y
# CONFIG_S2IO is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_NFP is not set
CONFIG_NET_VENDOR_8390=y
# CONFIG_NE2K_PCI is not set
CONFIG_NET_VENDOR_NVIDIA=y
# CONFIG_FORCEDETH is not set
CONFIG_NET_VENDOR_OKI=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_PACKET_ENGINES=y
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
CONFIG_NET_VENDOR_PENSANDO=y
# CONFIG_IONIC is not set
CONFIG_NET_VENDOR_QLOGIC=y
# CONFIG_QLA3XXX is not set
# CONFIG_QLCNIC is not set
# CONFIG_NETXEN_NIC is not set
# CONFIG_QED is not set
CONFIG_NET_VENDOR_BROCADE=y
# CONFIG_BNA is not set
CONFIG_NET_VENDOR_QUALCOMM=y
# CONFIG_QCA7000_SPI is not set
# CONFIG_QCA7000_UART is not set
CONFIG_QCOM_EMAC=m
CONFIG_RMNET=m
CONFIG_NET_VENDOR_RDC=y
# CONFIG_R6040 is not set
CONFIG_NET_VENDOR_REALTEK=y
# CONFIG_8139CP is not set
# CONFIG_8139TOO is not set
CONFIG_R8169=m
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
# CONFIG_ROCKER is not set
CONFIG_NET_VENDOR_SAMSUNG=y
# CONFIG_SXGBE_ETH is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SILAN=y
# CONFIG_SC92031 is not set
CONFIG_NET_VENDOR_SIS=y
# CONFIG_SIS900 is not set
# CONFIG_SIS190 is not set
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_SFC is not set
# CONFIG_SFC_FALCON is not set
# CONFIG_SFC_SIENA is not set
CONFIG_NET_VENDOR_SMSC=y
CONFIG_SMC91X=y
# CONFIG_EPIC100 is not set
CONFIG_SMSC911X=y
# CONFIG_SMSC9420 is not set
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
CONFIG_STMMAC_ETH=m
# CONFIG_STMMAC_SELFTESTS is not set
CONFIG_STMMAC_PLATFORM=m
# CONFIG_DWMAC_DWC_QOS_ETH is not set
CONFIG_DWMAC_GENERIC=m
# CONFIG_DWMAC_INTEL_PLAT is not set
# CONFIG_DWMAC_LOONGSON is not set
# CONFIG_STMMAC_PCI is not set
CONFIG_NET_VENDOR_SUN=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NIU is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_NET_VENDOR_TEHUTI=y
# CONFIG_TEHUTI is not set
CONFIG_NET_VENDOR_TI=y
CONFIG_TI_DAVINCI_MDIO=y
# CONFIG_TI_CPSW_PHY_SEL is not set
CONFIG_TI_K3_AM65_CPSW_NUSS=y
CONFIG_TI_K3_AM65_CPSW_SWITCHDEV=y
CONFIG_TI_K3_AM65_CPTS=y
CONFIG_TI_AM65_CPSW_TAS=y
# CONFIG_TLAN is not set
CONFIG_TI_RDEV_ETH_SWITCH_VIRT_EMAC=m
CONFIG_TI_ICSSG_PRUETH=m
CONFIG_TI_ICSS_IEP=m
CONFIG_NET_VENDOR_VERTEXCOM=y
# CONFIG_MSE102X is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
# CONFIG_WIZNET_W5100 is not set
# CONFIG_WIZNET_W5300 is not set
CONFIG_NET_VENDOR_XILINX=y
# CONFIG_XILINX_EMACLITE is not set
# CONFIG_XILINX_AXI_EMAC is not set
# CONFIG_XILINX_LL_TEMAC is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_PHYLINK=y
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_SFP is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_ADIN_PHY is not set
# CONFIG_ADIN1100_PHY is not set
CONFIG_AQUANTIA_PHY=y
CONFIG_AX88796B_PHY=m
CONFIG_BROADCOM_PHY=m
CONFIG_BCM54140_PHY=m
CONFIG_BCM7XXX_PHY=m
# CONFIG_BCM84881_PHY is not set
# CONFIG_BCM87XX_PHY is not set
CONFIG_BCM_NET_PHYLIB=m
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
CONFIG_MARVELL_PHY=m
CONFIG_MARVELL_10G_PHY=m
# CONFIG_MARVELL_88X2222_PHY is not set
# CONFIG_MAXLINEAR_GPHY is not set
# CONFIG_MEDIATEK_GE_PHY is not set
CONFIG_MICREL_PHY=y
CONFIG_MICROCHIP_PHY=m
# CONFIG_MICROCHIP_T1_PHY is not set
CONFIG_MICROSEMI_PHY=y
CONFIG_MOTORCOMM_PHY=y
# CONFIG_NATIONAL_PHY is not set
# CONFIG_NXP_C45_TJA11XX_PHY is not set
# CONFIG_NXP_TJA11XX_PHY is not set
CONFIG_AT803X_PHY=y
# CONFIG_QSEMI_PHY is not set
CONFIG_REALTEK_PHY=y
# CONFIG_RENESAS_PHY is not set
CONFIG_ROCKCHIP_PHY=y
CONFIG_SMSC_PHY=m
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
CONFIG_DP83867_PHY=y
CONFIG_DP83869_PHY=y
CONFIG_DP83TD510_PHY=y
CONFIG_VITESSE_PHY=y
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PSE_CONTROLLER is not set
CONFIG_CAN_DEV=m
# CONFIG_CAN_VCAN is not set
# CONFIG_CAN_VXCAN is not set
CONFIG_CAN_NETLINK=y
CONFIG_CAN_CALC_BITTIMING=y
CONFIG_CAN_RX_OFFLOAD=y
# CONFIG_CAN_CAN327 is not set
CONFIG_CAN_FLEXCAN=m
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_KVASER_PCIEFD is not set
# CONFIG_CAN_SLCAN is not set
# CONFIG_CAN_XILINXCAN is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_CTUCANFD_PCI is not set
# CONFIG_CAN_CTUCANFD_PLATFORM is not set
# CONFIG_CAN_IFI_CANFD is not set
CONFIG_CAN_M_CAN=m
# CONFIG_CAN_M_CAN_PCI is not set
CONFIG_CAN_M_CAN_PLATFORM=m
# CONFIG_CAN_M_CAN_TCAN4X5X is not set
# CONFIG_CAN_PEAK_PCIEFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
# CONFIG_CAN_MCP251X is not set
CONFIG_CAN_MCP251XFD=m
# CONFIG_CAN_MCP251XFD_SANITY is not set
# end of CAN SPI interfaces
# CAN USB interfaces
# CONFIG_CAN_8DEV_USB is not set
# CONFIG_CAN_EMS_USB is not set
# CONFIG_CAN_ESD_USB is not set
# CONFIG_CAN_ETAS_ES58X is not set
# CONFIG_CAN_GS_USB is not set
# CONFIG_CAN_KVASER_USB is not set
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_PEAK_USB is not set
# CONFIG_CAN_UCAN is not set
# end of CAN USB interfaces
# CONFIG_CAN_DEBUG_DEVICES is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_FWNODE_MDIO=y
CONFIG_OF_MDIO=y
CONFIG_MDIO_DEVRES=y
CONFIG_MDIO_BITBANG=y
CONFIG_MDIO_BCM_UNIMAC=m
CONFIG_MDIO_CAVIUM=y
CONFIG_MDIO_GPIO=y
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MVUSB is not set
# CONFIG_MDIO_MSCC_MIIM is not set
# CONFIG_MDIO_OCTEON is not set
# CONFIG_MDIO_IPQ4019 is not set
# CONFIG_MDIO_IPQ8064 is not set
CONFIG_MDIO_THUNDER=y
# MDIO Multiplexers
CONFIG_MDIO_BUS_MUX=y
# CONFIG_MDIO_BUS_MUX_GPIO is not set
CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
CONFIG_MDIO_BUS_MUX_MMIOREG=y
# PCS device drivers
CONFIG_PCS_XPCS=m
# end of PCS device drivers
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOE=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
# CONFIG_SLIP is not set
CONFIG_SLHC=y
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
# CONFIG_USB_NET_CDC_EEM is not set
CONFIG_USB_NET_CDC_NCM=m
# CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
# CONFIG_USB_NET_CDC_MBIM is not set
CONFIG_USB_NET_DM9601=m
# CONFIG_USB_NET_SR9700 is not set
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
# CONFIG_USB_NET_GL620A is not set
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
# CONFIG_USB_NET_RNDIS_HOST is not set
CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
CONFIG_USB_NET_CDC_SUBSET=m
# CONFIG_USB_ALI_M5632 is not set
# CONFIG_USB_AN2720 is not set
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
# CONFIG_USB_EPSON2888 is not set
# CONFIG_USB_KC2190 is not set
CONFIG_USB_NET_ZAURUS=m
# CONFIG_USB_NET_CX82310_ETH is not set
# CONFIG_USB_NET_KALMIA is not set
CONFIG_USB_NET_QMI_WWAN=m
# CONFIG_USB_HSO is not set
# CONFIG_USB_NET_INT51X1 is not set
# CONFIG_USB_IPHETH is not set
# CONFIG_USB_SIERRA_NET is not set
# CONFIG_USB_VL600 is not set
# CONFIG_USB_NET_CH9200 is not set
# CONFIG_USB_NET_AQC111 is not set
CONFIG_USB_RTL8153_ECM=m
CONFIG_WLAN=y
CONFIG_WLAN_VENDOR_ADMTEK=y
# CONFIG_ADM8211 is not set
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
# CONFIG_ATH5K is not set
# CONFIG_ATH5K_PCI is not set
# CONFIG_ATH9K is not set
# CONFIG_ATH9K_HTC is not set
# CONFIG_CARL9170 is not set
# CONFIG_ATH6KL is not set
# CONFIG_AR5523 is not set
# CONFIG_WIL6210 is not set
CONFIG_ATH10K=m
CONFIG_ATH10K_CE=y
CONFIG_ATH10K_PCI=m
# CONFIG_ATH10K_AHB is not set
# CONFIG_ATH10K_SDIO is not set
# CONFIG_ATH10K_USB is not set
# CONFIG_ATH10K_DEBUG is not set
# CONFIG_ATH10K_DEBUGFS is not set
CONFIG_WCN36XX=m
# CONFIG_WCN36XX_DEBUGFS is not set
CONFIG_ATH11K=m
CONFIG_ATH11K_AHB=m
CONFIG_ATH11K_PCI=m
# CONFIG_ATH11K_DEBUG is not set
CONFIG_WLAN_VENDOR_ATMEL=y
# CONFIG_ATMEL is not set
# CONFIG_AT76C50X_USB is not set
CONFIG_WLAN_VENDOR_BROADCOM=y
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
CONFIG_BRCMUTIL=m
# CONFIG_BRCMSMAC is not set
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
# CONFIG_BRCMFMAC_USB is not set
# CONFIG_BRCMFMAC_PCIE is not set
# CONFIG_BRCM_TRACING is not set
# CONFIG_BRCMDBG is not set
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
# CONFIG_IPW2100 is not set
# CONFIG_IPW2200 is not set
# CONFIG_IWL4965 is not set
# CONFIG_IWL3945 is not set
CONFIG_IWLWIFI=m
CONFIG_IWLWIFI_LEDS=y
CONFIG_IWLDVM=m
CONFIG_IWLMVM=m
CONFIG_IWLWIFI_OPMODE_MODULAR=y
# Debugging Options
# CONFIG_IWLWIFI_DEBUG is not set
# end of Debugging Options
CONFIG_WLAN_VENDOR_INTERSIL=y
# CONFIG_HOSTAP is not set
# CONFIG_HERMES is not set
# CONFIG_P54_COMMON is not set
CONFIG_WLAN_VENDOR_MARVELL=y
# CONFIG_LIBERTAS is not set
# CONFIG_LIBERTAS_THINFIRM is not set
# CONFIG_MWIFIEX is not set
# CONFIG_MWL8K is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
# CONFIG_MT7601U is not set
# CONFIG_MT76x0U is not set
# CONFIG_MT76x0E is not set
# CONFIG_MT76x2E is not set
# CONFIG_MT76x2U is not set
# CONFIG_MT7603E is not set
# CONFIG_MT7615E is not set
# CONFIG_MT7663U is not set
# CONFIG_MT7663S is not set
# CONFIG_MT7915E is not set
# CONFIG_MT7921E is not set
# CONFIG_MT7921S is not set
# CONFIG_MT7921U is not set
CONFIG_WLAN_VENDOR_MICROCHIP=y
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
CONFIG_WLAN_VENDOR_PURELIFI=y
# CONFIG_PLFXLC is not set
CONFIG_WLAN_VENDOR_RALINK=y
# CONFIG_RT2X00 is not set
CONFIG_WLAN_VENDOR_REALTEK=y
# CONFIG_RTL8180 is not set
# CONFIG_RTL8187 is not set
CONFIG_RTL_CARDS=m
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
# CONFIG_RTL8192CU is not set
# CONFIG_RTL8XXXU is not set
# CONFIG_RTW88 is not set
# CONFIG_RTW89 is not set
CONFIG_WLAN_VENDOR_RSI=y
# CONFIG_RSI_91X is not set
CONFIG_WLAN_VENDOR_SILABS=y
# CONFIG_WFX is not set
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
# CONFIG_WL1251 is not set
# CONFIG_WL12XX is not set
CONFIG_WL18XX=m
CONFIG_WLCORE=m
# CONFIG_WLCORE_SPI is not set
CONFIG_WLCORE_SDIO=m
CONFIG_WILINK_PLATFORM_DATA=y
CONFIG_WLAN_VENDOR_ZYDAS=y
# CONFIG_USB_ZD1201 is not set
# CONFIG_ZD1211RW is not set
CONFIG_WLAN_VENDOR_QUANTENNA=y
# CONFIG_QTNFMAC_PCIE is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_VIRT_WIFI is not set
# CONFIG_WAN is not set
# Wireless WAN
# CONFIG_WWAN is not set
# end of Wireless WAN
# CONFIG_VMXNET3 is not set
# CONFIG_NETDEVSIM is not set
CONFIG_NET_FAILOVER=y
# CONFIG_ISDN is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=m
# CONFIG_INPUT_SPARSEKMAP is not set
CONFIG_INPUT_MATRIXKMAP=y
CONFIG_INPUT_VIVALDIFMAP=y
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ADC=m
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_PINEPHONE is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
CONFIG_KEYBOARD_CROS_EC=y
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_KEYBOARD_MTK_PMIC is not set
# CONFIG_KEYBOARD_CYPRESS_SF is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_BYD=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y
CONFIG_MOUSE_PS2_CYPRESS=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
# CONFIG_MOUSE_PS2_ELANTECH is not set
# CONFIG_MOUSE_PS2_SENTELIC is not set
# CONFIG_MOUSE_PS2_TOUCHKIT is not set
CONFIG_MOUSE_PS2_FOCALTECH=y
CONFIG_MOUSE_PS2_SMBUS=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_APPLETOUCH is not set
# CONFIG_MOUSE_BCM5974 is not set
# CONFIG_MOUSE_CYAPA is not set
# CONFIG_MOUSE_ELAN_I2C is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_MOUSE_GPIO is not set
# CONFIG_MOUSE_SYNAPTICS_I2C is not set
# CONFIG_MOUSE_SYNAPTICS_USB is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_ADC is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
# CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set
CONFIG_TOUCHSCREEN_ILI210X=m
# CONFIG_TOUCHSCREEN_ILITEK is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MSG2638 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMAGIS is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
# CONFIG_TOUCHSCREEN_ZINITIX is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_TPS65219_PWRBUTTON=m
# CONFIG_INPUT_AXP20X_PEK is not set
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
CONFIG_INPUT_PWM_BEEPER=m
CONFIG_INPUT_PWM_VIBRA=m
# CONFIG_INPUT_RK805_PWRKEY is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_DA7280_HAPTICS is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IBM_PANEL is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_IQS269A is not set
# CONFIG_INPUT_IQS626A is not set
# CONFIG_INPUT_IQS7222 is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_SERPORT is not set
CONFIG_SERIO_AMBAKMI=y
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_LDISC_AUTOLOAD=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
CONFIG_SERIAL_8250_16550A_VARIANTS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_EXAR=y
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
# CONFIG_SERIAL_8250_RSA is not set
CONFIG_SERIAL_8250_FSL=y
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_8250_OMAP=y
CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
CONFIG_SERIAL_8250_PERICOM=y
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_AMBA_PL010 is not set
# CONFIG_SERIAL_AMBA_PL011 is not set
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_RP2 is not set
CONFIG_SERIAL_FSL_LPUART=y
CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
CONFIG_SERIAL_FSL_LINFLEXUART=y
CONFIG_SERIAL_FSL_LINFLEXUART_CONSOLE=y
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_SPRD is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_NOZOMI is not set
# CONFIG_NULL_TTY is not set
CONFIG_HVC_DRIVER=y
# CONFIG_HVC_DCC is not set
CONFIG_RPMSG_TTY=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
# CONFIG_TTY_PRINTK is not set
CONFIG_VIRTIO_CONSOLE=y
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_DMI_DECODE=y
CONFIG_IPMI_PLAT_DATA=y
# CONFIG_IPMI_PANIC_EVENT is not set
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
# CONFIG_IPMI_SSIF is not set
# CONFIG_IPMI_IPMB is not set
# CONFIG_IPMI_WATCHDOG is not set
# CONFIG_IPMI_POWEROFF is not set
# CONFIG_IPMB_DEVICE_INTERFACE is not set
CONFIG_HW_RANDOM=m
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_HW_RANDOM_BA431 is not set
CONFIG_HW_RANDOM_OMAP=m
# CONFIG_HW_RANDOM_VIRTIO is not set
CONFIG_HW_RANDOM_OPTEE=m
# CONFIG_HW_RANDOM_CCTRNG is not set
# CONFIG_HW_RANDOM_XIPHERA is not set
CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=m
CONFIG_HW_RANDOM_CN10K=m
# CONFIG_APPLICOM is not set
CONFIG_DEVMEM=y
CONFIG_DEVPORT=y
CONFIG_TCG_TPM=y
# CONFIG_TCG_TIS is not set
# CONFIG_TCG_TIS_SPI is not set
# CONFIG_TCG_TIS_I2C is not set
# CONFIG_TCG_TIS_I2C_CR50 is not set
# CONFIG_TCG_TIS_I2C_ATMEL is not set
CONFIG_TCG_TIS_I2C_INFINEON=y
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_FTPM_TEE is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
# CONFIG_XILLYBUS is not set
# CONFIG_XILLYUSB is not set
CONFIG_RANDOM_TRUST_CPU=y
CONFIG_RANDOM_TRUST_BOOTLOADER=y
# end of Character devices
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
CONFIG_I2C_MUX_PCA954x=y
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_ATR=m
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# PC SMBus host controller drivers
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_ISCH is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_NVIDIA_GPU is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_CADENCE=m
# CONFIG_I2C_CBUS_GPIO is not set
CONFIG_I2C_DESIGNWARE_CORE=y
# CONFIG_I2C_DESIGNWARE_SLAVE is not set
CONFIG_I2C_DESIGNWARE_PLATFORM=y
# CONFIG_I2C_DESIGNWARE_PCI is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
# CONFIG_I2C_NOMADIK is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_PCA_PLATFORM is not set
CONFIG_I2C_RK3X=y
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_THUNDERX is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_CP2615 is not set
# CONFIG_I2C_PCI1XXXX is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
CONFIG_I2C_CROS_EC_TUNNEL=y
# CONFIG_I2C_VIRTIO is not set
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
CONFIG_I2C_SLAVE=y
# CONFIG_I2C_SLAVE_EEPROM is not set
# CONFIG_I2C_SLAVE_TESTUNIT is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_CADENCE is not set
CONFIG_SPI_CADENCE_QUADSPI=y
# CONFIG_SPI_CADENCE_XSPI is not set
CONFIG_SPI_DESIGNWARE=m
CONFIG_SPI_DW_DMA=y
# CONFIG_SPI_DW_PCI is not set
CONFIG_SPI_DW_MMIO=m
CONFIG_SPI_NXP_FLEXSPI=y
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_MICROCHIP_CORE is not set
# CONFIG_SPI_MICROCHIP_CORE_QSPI is not set
# CONFIG_SPI_OC_TINY is not set
CONFIG_SPI_OMAP24XX=m
CONFIG_SPI_PL022=y
# CONFIG_SPI_PXA2XX is not set
CONFIG_SPI_ROCKCHIP=y
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_THUNDERX is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# CONFIG_SPI_AMD is not set
# SPI Multiplexer support
# CONFIG_SPI_MUX is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
CONFIG_SPI_SLAVE=y
# CONFIG_SPI_SLAVE_TIME is not set
# CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set
CONFIG_SPI_DYNAMIC=y
CONFIG_SPMI=y
# CONFIG_SPMI_HISI3670 is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PTP_1588_CLOCK_KVM=y
# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# CONFIG_PTP_1588_CLOCK_OCP is not set
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_GENERIC_PINCTRL_GROUPS=y
CONFIG_PINMUX=y
CONFIG_GENERIC_PINMUX_FUNCTIONS=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AXP209 is not set
# CONFIG_PINCTRL_CY8C95X0 is not set
CONFIG_PINCTRL_MAX77620=y
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
# CONFIG_PINCTRL_OCELOT is not set
# CONFIG_PINCTRL_RK805 is not set
CONFIG_PINCTRL_SINGLE=y
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_SX150X is not set
CONFIG_PINCTRL_TPS6594=y
# Renesas pinctrl drivers
# end of Renesas pinctrl drivers
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
CONFIG_GPIO_AT9555=y
CONFIG_DEBUG_GPIO=y
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_CDEV=y
CONFIG_GPIO_CDEV_V1=y
CONFIG_GPIO_GENERIC=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
CONFIG_GPIO_ALTERA=m
# CONFIG_GPIO_CADENCE is not set
CONFIG_GPIO_DAVINCI=y
CONFIG_GPIO_DWAPB=y
# CONFIG_GPIO_EXAR is not set
# CONFIG_GPIO_FTGPIO010 is not set
CONFIG_GPIO_GENERIC_PLATFORM=y
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
CONFIG_GPIO_MB86S7X=y
CONFIG_GPIO_PL061=y
# CONFIG_GPIO_SIFIVE is not set
# CONFIG_GPIO_SYSCON is not set
CONFIG_GPIO_WCD934X=m
CONFIG_GPIO_XGENE=y
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
CONFIG_GPIO_MAX732X=y
# CONFIG_GPIO_MAX732X_IRQ is not set
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
# CONFIG_GPIO_PCA9570 is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
# CONFIG_GPIO_WM8994 is not set
# end of MFD GPIO expanders
# PCI GPIO expanders
# CONFIG_GPIO_BT8XX is not set
# CONFIG_GPIO_PCI_IDIO_16 is not set
# CONFIG_GPIO_PCIE_IDIO_24 is not set
# CONFIG_GPIO_RDC321X is not set
# end of PCI GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# Virtual GPIO drivers
# CONFIG_GPIO_AGGREGATOR is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_VIRTIO is not set
# CONFIG_GPIO_SIM is not set
# end of Virtual GPIO drivers
# CONFIG_W1 is not set
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_BRCMSTB=y
# CONFIG_POWER_RESET_GPIO is not set
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_MT6323 is not set
# CONFIG_POWER_RESET_REGULATOR is not set
# CONFIG_POWER_RESET_RESTART is not set
# CONFIG_POWER_RESET_VEXPRESS is not set
CONFIG_POWER_RESET_XGENE=y
CONFIG_POWER_RESET_SYSCON=y
# CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
CONFIG_REBOOT_MODE=y
CONFIG_SYSCON_REBOOT_MODE=y
# CONFIG_NVMEM_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_POWER_SUPPLY_HWMON=y
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_IP5XXX_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_CW2015 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SAMSUNG_SDI is not set
CONFIG_BATTERY_SBS=m
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
CONFIG_BATTERY_BQ27XXX=y
CONFIG_BATTERY_BQ27XXX_I2C=y
# CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
# CONFIG_AXP20X_POWER is not set
# CONFIG_BATTERY_MAX17040 is not set
CONFIG_BATTERY_MAX17042=m
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_LTC4162L is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_MAX77976 is not set
CONFIG_CHARGER_MT6360=m
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ2515X is not set
CONFIG_CHARGER_BQ25890=m
CONFIG_CHARGER_BQ25980=m
# CONFIG_CHARGER_BQ256XX is not set
# CONFIG_CHARGER_RK817 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_BATTERY_GOLDFISH is not set
# CONFIG_BATTERY_RT5033 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_CROS_USBPD is not set
CONFIG_CHARGER_CROS_PCHG=y
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_CHARGER_BD99954 is not set
# CONFIG_BATTERY_UG3105 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM1177 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_AHT10 is not set
# CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set
# CONFIG_SENSORS_AS370 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_AXI_FAN_CONTROL is not set
CONFIG_SENSORS_ARM_SCMI=y
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_CORSAIR_CPRO is not set
# CONFIG_SENSORS_CORSAIR_PSU is not set
# CONFIG_SENSORS_DRIVETEMP is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_I5K_AMB is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
CONFIG_SENSORS_GPIO_FAN=m
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IBMAEM is not set
# CONFIG_SENSORS_IBMPEX is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
CONFIG_SENSORS_JC42=m
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2947_I2C is not set
# CONFIG_SENSORS_LTC2947_SPI is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC2992 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX127 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX31730 is not set
# CONFIG_SENSORS_MAX31760 is not set
# CONFIG_SENSORS_MAX6620 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_TPS23861 is not set
# CONFIG_SENSORS_MR75203 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
CONFIG_SENSORS_LM75=m
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
CONFIG_SENSORS_LM90=m
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT6775_I2C is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_NZXT_KRAKEN2 is not set
# CONFIG_SENSORS_NZXT_SMART2 is not set
# CONFIG_SENSORS_OCC_P8_I2C is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
CONFIG_SENSORS_PWM_FAN=m
# CONFIG_SENSORS_SBTSI is not set
# CONFIG_SENSORS_SBRMI is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHT4x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_SIS5595 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC2305 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
CONFIG_SENSORS_INA2XX=m
# CONFIG_SENSORS_INA238 is not set
CONFIG_SENSORS_INA3221=m
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_TMP464 is not set
# CONFIG_SENSORS_TMP513 is not set
# CONFIG_SENSORS_VEXPRESS is not set
# CONFIG_SENSORS_VIA686A is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_VT8231 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_NETLINK is not set
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_CPU_FREQ_THERMAL=y
CONFIG_DEVFREQ_THERMAL=y
CONFIG_THERMAL_EMULATION=y
# CONFIG_THERMAL_MMIO is not set
CONFIG_K3_THERMAL=m
# CONFIG_MAX77620_THERMAL is not set
# CONFIG_GENERIC_ADC_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
# CONFIG_WATCHDOG_SYSFS is not set
# CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
CONFIG_ARM_SP805_WATCHDOG=y
CONFIG_ARM_SBSA_WATCHDOG=y
# CONFIG_CADENCE_WATCHDOG is not set
CONFIG_DW_WATCHDOG=y
CONFIG_K3_RTI_WATCHDOG=m
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MAX77620_WATCHDOG is not set
CONFIG_ARM_SMC_WATCHDOG=y
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
# CONFIG_HP_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
# PCI-based Watchdog Cards
# CONFIG_PCIPCWATCHDOG is not set
# CONFIG_WDTPCI is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
CONFIG_MFD_BD9571MWV=y
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_CROS_EC_DEV=y
# CONFIG_MFD_MADERA is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_GATEWORKS_GSC is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_MP2629 is not set
CONFIG_MFD_HI6421_PMIC=y
# CONFIG_MFD_HI6421_SPMI is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_LPC_ICH is not set
# CONFIG_LPC_SCH is not set
# CONFIG_MFD_IQS62X is not set
# CONFIG_MFD_JANZ_CMODIO is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
CONFIG_MFD_MAX77620=y
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77714 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
CONFIG_MFD_MT6360=y
# CONFIG_MFD_MT6370 is not set
CONFIG_MFD_MT6397=y
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_MFD_OCELOT is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_NTXEC is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_SY7636A is not set
# CONFIG_MFD_RDC321X is not set
# CONFIG_MFD_RT4831 is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RT5120 is not set
# CONFIG_MFD_RC5T583 is not set
CONFIG_MFD_RK808=y
# CONFIG_MFD_RN5T618 is not set
CONFIG_MFD_SEC_CORE=y
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SYSCON=y
CONFIG_MFD_TI_AM335X_TSCADC=m
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
CONFIG_MFD_TPS65219=y
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
CONFIG_MFD_TPS6594=y
CONFIG_MFD_TPS6594_I2C=y
# CONFIG_MFD_TPS6594_SPI is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_VX855 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
CONFIG_MFD_WM8994=m
CONFIG_MFD_ROHM_BD718XX=y
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_ROHM_BD957XMUF is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
CONFIG_MFD_WCD934X=m
# CONFIG_MFD_ATC260X_I2C is not set
# CONFIG_MFD_QCOM_PM8008 is not set
CONFIG_MFD_VEXPRESS_SYSREG=y
# CONFIG_RAVE_SP_CORE is not set
# CONFIG_MFD_INTEL_M10_BMC is not set
# CONFIG_MFD_RSMU_I2C is not set
# CONFIG_MFD_RSMU_SPI is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ARM_SCMI is not set
CONFIG_REGULATOR_AXP20X=y
CONFIG_REGULATOR_BD718XX=y
CONFIG_REGULATOR_BD9571MWV=y
# CONFIG_REGULATOR_CROS_EC is not set
# CONFIG_REGULATOR_DA9121 is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
CONFIG_REGULATOR_FAN53555=y
# CONFIG_REGULATOR_FAN53880 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_HI6421 is not set
CONFIG_REGULATOR_HI6421V530=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
CONFIG_REGULATOR_MAX77620=y
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8893 is not set
# CONFIG_REGULATOR_MAX8952 is not set
CONFIG_REGULATOR_MAX8973=y
# CONFIG_REGULATOR_MAX20086 is not set
# CONFIG_REGULATOR_MAX77826 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MP5416 is not set
CONFIG_REGULATOR_MP8859=y
# CONFIG_REGULATOR_MP886X is not set
# CONFIG_REGULATOR_MPQ7920 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_MT6315 is not set
# CONFIG_REGULATOR_MT6323 is not set
# CONFIG_REGULATOR_MT6331 is not set
# CONFIG_REGULATOR_MT6332 is not set
CONFIG_REGULATOR_MT6358=y
CONFIG_REGULATOR_MT6359=y
CONFIG_REGULATOR_MT6360=y
CONFIG_REGULATOR_MT6397=y
CONFIG_REGULATOR_PCA9450=y
CONFIG_REGULATOR_PF8X00=y
CONFIG_REGULATOR_PFUZE100=y
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_QCOM_SPMI=y
# CONFIG_REGULATOR_QCOM_USB_VBUS is not set
# CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set
CONFIG_REGULATOR_RK808=y
CONFIG_REGULATOR_ROHM=y
# CONFIG_REGULATOR_RT4801 is not set
# CONFIG_REGULATOR_RT5190A is not set
# CONFIG_REGULATOR_RT5759 is not set
# CONFIG_REGULATOR_RT6160 is not set
# CONFIG_REGULATOR_RT6245 is not set
# CONFIG_REGULATOR_RTQ2134 is not set
# CONFIG_REGULATOR_RTMV20 is not set
# CONFIG_REGULATOR_RTQ6752 is not set
# CONFIG_REGULATOR_S2MPA01 is not set
CONFIG_REGULATOR_S2MPS11=y
# CONFIG_REGULATOR_S5M8767 is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_SY8827N is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS6286X is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
CONFIG_REGULATOR_TPS65132=m
CONFIG_REGULATOR_TPS65219=y
CONFIG_REGULATOR_TPS6594=y
# CONFIG_REGULATOR_TPS6524X is not set
CONFIG_REGULATOR_VCTRL=m
# CONFIG_REGULATOR_VEXPRESS is not set
# CONFIG_REGULATOR_WM8994 is not set
# CONFIG_REGULATOR_QCOM_LABIBB is not set
# CONFIG_RC_CORE is not set
CONFIG_CEC_CORE=m
CONFIG_CEC_NOTIFIER=y
# CEC support
CONFIG_MEDIA_CEC_SUPPORT=y
# CONFIG_CEC_CH7322 is not set
# CONFIG_CEC_CROS_EC is not set
# CONFIG_CEC_GPIO is not set
# CONFIG_USB_PULSE8_CEC is not set
# CONFIG_USB_RAINSHADOW_CEC is not set
# end of CEC support
CONFIG_MEDIA_SUPPORT=m
# CONFIG_MEDIA_SUPPORT_FILTER is not set
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
# Media device types
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
CONFIG_MEDIA_TEST_SUPPORT=y
# end of Media device types
# Media core support
CONFIG_VIDEO_DEV=m
CONFIG_MEDIA_CONTROLLER=y
CONFIG_DVB_CORE=m
# end of Media core support
# Video4Linux options
CONFIG_VIDEO_V4L2_I2C=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_V4L2_MEM2MEM_DEV=m
CONFIG_V4L2_FWNODE=m
CONFIG_V4L2_ASYNC=m
# end of Video4Linux options
# Media controller options
# CONFIG_MEDIA_CONTROLLER_DVB is not set
# end of Media controller options
# Digital TV options
# CONFIG_DVB_MMAP is not set
# CONFIG_DVB_NET is not set
CONFIG_DVB_MAX_ADAPTERS=16
CONFIG_DVB_DYNAMIC_MINORS=y
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
# end of Digital TV options
# Media drivers
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
# CONFIG_USB_GSPCA is not set
# CONFIG_USB_PWC is not set
# CONFIG_USB_S2255 is not set
# CONFIG_VIDEO_USBTV is not set
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
# Analog TV USB devices
# CONFIG_VIDEO_GO7007 is not set
# CONFIG_VIDEO_HDPVR is not set
# CONFIG_VIDEO_PVRUSB2 is not set
# CONFIG_VIDEO_STK1160_COMMON is not set
# Analog/digital TV USB devices
# CONFIG_VIDEO_AU0828 is not set
# CONFIG_VIDEO_CX231XX is not set
# Digital TV USB devices
# CONFIG_DVB_AS102 is not set
# CONFIG_DVB_B2C2_FLEXCOP_USB is not set
# CONFIG_DVB_USB_V2 is not set
# CONFIG_SMS_USB_DRV is not set
# CONFIG_DVB_TTUSB_BUDGET is not set
# CONFIG_DVB_TTUSB_DEC is not set
# Webcam, TV (analog/digital) USB devices
# CONFIG_VIDEO_EM28XX is not set
# Software defined radio USB devices
# CONFIG_USB_AIRSPY is not set
# CONFIG_USB_HACKRF is not set
# CONFIG_USB_MSI2500 is not set
# CONFIG_MEDIA_PCI_SUPPORT is not set
CONFIG_RADIO_ADAPTERS=m
# CONFIG_RADIO_MAXIRADIO is not set
# CONFIG_RADIO_SAA7706H is not set
# CONFIG_RADIO_SHARK is not set
# CONFIG_RADIO_SHARK2 is not set
# CONFIG_RADIO_SI4713 is not set
# CONFIG_RADIO_TEA5764 is not set
# CONFIG_RADIO_TEF6862 is not set
# CONFIG_RADIO_WL1273 is not set
# CONFIG_USB_DSBR is not set
# CONFIG_USB_KEENE is not set
# CONFIG_USB_MA901 is not set
# CONFIG_USB_MR800 is not set
# CONFIG_USB_RAREMONO is not set
# CONFIG_RADIO_SI470X is not set
CONFIG_MEDIA_PLATFORM_DRIVERS=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_SDR_PLATFORM_DRIVERS=y
# CONFIG_DVB_PLATFORM_DRIVERS is not set
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
# CONFIG_VIDEO_MUX is not set
# Allegro DVT media platform drivers
# Amlogic media platform drivers
# Amphion drivers
# Aspeed media platform drivers
# CONFIG_VIDEO_ASPEED is not set
# Atmel media platform drivers
# Cadence media platform drivers
CONFIG_VIDEO_CADENCE_CSI2RX=m
# CONFIG_VIDEO_CADENCE_CSI2TX is not set
# Chips&Media media platform drivers
CONFIG_VIDEO_WAVE_VPU=m
# IMG media platform drivers
CONFIG_VIDEO_IMG_VXD_DEC=m
CONFIG_VIDEO_IMG_VXE_ENC=m
CONFIG_VIDEO_E5010_JPEG_ENC=m
# Intel media platform drivers
# Marvell media platform drivers
# CONFIG_VIDEO_CAFE_CCIC is not set
# Mediatek media platform drivers
# NVidia media platform drivers
# NXP media platform drivers
# Qualcomm media platform drivers
# Renesas media platform drivers
# Rockchip media platform drivers
# Samsung media platform drivers
# STMicroelectronics media platform drivers
# Sunxi media platform drivers
# Texas Instruments drivers
# CONFIG_VIDEO_TI_CAL is not set
CONFIG_VIDEO_TI_J721E_CSI2RX=m
# Verisilicon media platform drivers
# VIA media platform drivers
# Xilinx media platform drivers
# CONFIG_VIDEO_XILINX is not set
# MMC/SDIO DVB adapters
# CONFIG_SMS_SDIO_DRV is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# CONFIG_DVB_TEST_DRIVERS is not set
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_DMA_CONTIG=m
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_VIDEOBUF2_DMA_SG=m
# end of Media drivers
# Media ancillary drivers
CONFIG_MEDIA_ATTACH=y
# Camera sensor devices
# CONFIG_VIDEO_AR0521 is not set
# CONFIG_VIDEO_HI556 is not set
# CONFIG_VIDEO_HI846 is not set
# CONFIG_VIDEO_HI847 is not set
# CONFIG_VIDEO_IMX208 is not set
# CONFIG_VIDEO_IMX214 is not set
CONFIG_VIDEO_IMX219=m
# CONFIG_VIDEO_IMX258 is not set
# CONFIG_VIDEO_IMX274 is not set
# CONFIG_VIDEO_IMX290 is not set
# CONFIG_VIDEO_IMX319 is not set
# CONFIG_VIDEO_IMX334 is not set
# CONFIG_VIDEO_IMX335 is not set
# CONFIG_VIDEO_IMX355 is not set
CONFIG_VIDEO_IMX390=m
# CONFIG_VIDEO_IMX412 is not set
# CONFIG_VIDEO_MT9M001 is not set
# CONFIG_VIDEO_MT9M032 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9P031 is not set
# CONFIG_VIDEO_MT9T001 is not set
# CONFIG_VIDEO_MT9T112 is not set
# CONFIG_VIDEO_MT9V011 is not set
# CONFIG_VIDEO_MT9V032 is not set
# CONFIG_VIDEO_MT9V111 is not set
# CONFIG_VIDEO_NOON010PC30 is not set
# CONFIG_VIDEO_OG01A1B is not set
# CONFIG_VIDEO_OV02A10 is not set
# CONFIG_VIDEO_OV08D10 is not set
# CONFIG_VIDEO_OV13858 is not set
# CONFIG_VIDEO_OV13B10 is not set
CONFIG_VIDEO_OV2312=m
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV2680 is not set
# CONFIG_VIDEO_OV2685 is not set
CONFIG_VIDEO_OV5640=m
CONFIG_VIDEO_OV5645=m
# CONFIG_VIDEO_OV5647 is not set
# CONFIG_VIDEO_OV5648 is not set
# CONFIG_VIDEO_OV5670 is not set
# CONFIG_VIDEO_OV5675 is not set
# CONFIG_VIDEO_OV5693 is not set
# CONFIG_VIDEO_OV5695 is not set
# CONFIG_VIDEO_OV6650 is not set
# CONFIG_VIDEO_OV7251 is not set
# CONFIG_VIDEO_OV7640 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_OV772X is not set
# CONFIG_VIDEO_OV7740 is not set
# CONFIG_VIDEO_OV8856 is not set
# CONFIG_VIDEO_OV8865 is not set
# CONFIG_VIDEO_OV9282 is not set
# CONFIG_VIDEO_OV9640 is not set
# CONFIG_VIDEO_OV9650 is not set
# CONFIG_VIDEO_RDACM20 is not set
# CONFIG_VIDEO_RDACM21 is not set
# CONFIG_VIDEO_RJ54N1 is not set
# CONFIG_VIDEO_S5C73M3 is not set
# CONFIG_VIDEO_S5K4ECGX is not set
# CONFIG_VIDEO_S5K5BAF is not set
# CONFIG_VIDEO_S5K6A3 is not set
# CONFIG_VIDEO_S5K6AA is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_CCS is not set
# CONFIG_VIDEO_ET8EK8 is not set
# CONFIG_VIDEO_M5MOLS is not set
# end of Camera sensor devices
# Lens drivers
# CONFIG_VIDEO_AD5820 is not set
# CONFIG_VIDEO_AK7375 is not set
# CONFIG_VIDEO_DW9714 is not set
# CONFIG_VIDEO_DW9768 is not set
# CONFIG_VIDEO_DW9807_VCM is not set
# end of Lens drivers
# Flash devices
# CONFIG_VIDEO_ADP1653 is not set
# CONFIG_VIDEO_LM3560 is not set
# CONFIG_VIDEO_LM3646 is not set
# end of Flash devices
# Audio decoders, processors and mixers
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_MSP3400 is not set
# CONFIG_VIDEO_SONY_BTF_MPX is not set
# CONFIG_VIDEO_TDA1997X is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_UDA1342 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_WM8775 is not set
# end of Audio decoders, processors and mixers
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# end of RDS decoders
# Video decoders
# CONFIG_VIDEO_ADV7180 is not set
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_ADV748X is not set
# CONFIG_VIDEO_ADV7604 is not set
# CONFIG_VIDEO_ADV7842 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_ISL7998X is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_MAX9286 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_SAA7110 is not set
# CONFIG_VIDEO_SAA711X is not set
# CONFIG_VIDEO_TC358743 is not set
# CONFIG_VIDEO_TVP514X is not set
# CONFIG_VIDEO_TVP5150 is not set
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_TW2804 is not set
# CONFIG_VIDEO_TW9903 is not set
# CONFIG_VIDEO_TW9906 is not set
# CONFIG_VIDEO_TW9910 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
# CONFIG_VIDEO_CX25840 is not set
# end of Video decoders
# Video encoders
# CONFIG_VIDEO_AD9389B is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_ADV7511 is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_THS8200 is not set
# end of Video encoders
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# end of Video improvement chips
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# end of Audio/Video compression chips
# SDR tuner chips
# CONFIG_SDR_MAX2175 is not set
# end of SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_I2C is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_ST_MIPID02 is not set
# CONFIG_VIDEO_THS7303 is not set
# end of Miscellaneous helper chips
# Video serializers and deserializers
# CONFIG_VIDEO_DS90UB913 is not set
CONFIG_VIDEO_DS90UB953=m
CONFIG_VIDEO_DS90UB960=m
# end of Video serializers and deserializers
# Media SPI Adapters
CONFIG_CXD2880_SPI_DRV=m
# CONFIG_VIDEO_GS1662 is not set
# end of Media SPI Adapters
CONFIG_MEDIA_TUNER=m
# Customize TV tuners
CONFIG_MEDIA_TUNER_E4000=m
CONFIG_MEDIA_TUNER_FC0011=m
CONFIG_MEDIA_TUNER_FC0012=m
CONFIG_MEDIA_TUNER_FC0013=m
CONFIG_MEDIA_TUNER_FC2580=m
CONFIG_MEDIA_TUNER_IT913X=m
CONFIG_MEDIA_TUNER_M88RS6000T=m
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_MC44S803=m
CONFIG_MEDIA_TUNER_MSI001=m
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT20XX=m
CONFIG_MEDIA_TUNER_MT2131=m
CONFIG_MEDIA_TUNER_MT2266=m
CONFIG_MEDIA_TUNER_MXL301RF=m
CONFIG_MEDIA_TUNER_MXL5005S=m
CONFIG_MEDIA_TUNER_MXL5007T=m
CONFIG_MEDIA_TUNER_QM1D1B0004=m
CONFIG_MEDIA_TUNER_QM1D1C0042=m
CONFIG_MEDIA_TUNER_QT1010=m
CONFIG_MEDIA_TUNER_R820T=m
CONFIG_MEDIA_TUNER_SI2157=m
CONFIG_MEDIA_TUNER_SIMPLE=m
CONFIG_MEDIA_TUNER_TDA18212=m
CONFIG_MEDIA_TUNER_TDA18218=m
CONFIG_MEDIA_TUNER_TDA18250=m
CONFIG_MEDIA_TUNER_TDA18271=m
CONFIG_MEDIA_TUNER_TDA827X=m
CONFIG_MEDIA_TUNER_TDA8290=m
CONFIG_MEDIA_TUNER_TDA9887=m
CONFIG_MEDIA_TUNER_TEA5761=m
CONFIG_MEDIA_TUNER_TEA5767=m
CONFIG_MEDIA_TUNER_TUA9001=m
CONFIG_MEDIA_TUNER_XC2028=m
CONFIG_MEDIA_TUNER_XC4000=m
CONFIG_MEDIA_TUNER_XC5000=m
# end of Customize TV tuners
# Customise DVB Frontends
# Multistandard (satellite) frontends
CONFIG_DVB_M88DS3103=m
CONFIG_DVB_MXL5XX=m
CONFIG_DVB_STB0899=m
CONFIG_DVB_STB6100=m
CONFIG_DVB_STV090x=m
CONFIG_DVB_STV0910=m
CONFIG_DVB_STV6110x=m
CONFIG_DVB_STV6111=m
# Multistandard (cable + terrestrial) frontends
CONFIG_DVB_DRXK=m
CONFIG_DVB_MN88472=m
CONFIG_DVB_MN88473=m
CONFIG_DVB_SI2165=m
CONFIG_DVB_TDA18271C2DD=m
# DVB-S (satellite) frontends
CONFIG_DVB_CX24110=m
CONFIG_DVB_CX24116=m
CONFIG_DVB_CX24117=m
CONFIG_DVB_CX24120=m
CONFIG_DVB_CX24123=m
CONFIG_DVB_DS3000=m
CONFIG_DVB_MB86A16=m
CONFIG_DVB_MT312=m
CONFIG_DVB_S5H1420=m
CONFIG_DVB_SI21XX=m
CONFIG_DVB_STB6000=m
CONFIG_DVB_STV0288=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_STV0900=m
CONFIG_DVB_STV6110=m
CONFIG_DVB_TDA10071=m
CONFIG_DVB_TDA10086=m
CONFIG_DVB_TDA8083=m
CONFIG_DVB_TDA8261=m
CONFIG_DVB_TDA826X=m
CONFIG_DVB_TS2020=m
CONFIG_DVB_TUA6100=m
CONFIG_DVB_TUNER_CX24113=m
CONFIG_DVB_TUNER_ITD1000=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_ZL10036=m
CONFIG_DVB_ZL10039=m
# DVB-T (terrestrial) frontends
CONFIG_DVB_AF9013=m
CONFIG_DVB_CX22700=m
CONFIG_DVB_CX22702=m
CONFIG_DVB_CXD2820R=m
CONFIG_DVB_CXD2841ER=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
CONFIG_DVB_DIB9000=m
CONFIG_DVB_DRXD=m
CONFIG_DVB_EC100=m
CONFIG_DVB_L64781=m
CONFIG_DVB_MT352=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
CONFIG_DVB_S5H1432=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_STV0367=m
CONFIG_DVB_TDA10048=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_ZD1301_DEMOD=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_CXD2880=m
# DVB-C (cable) frontends
CONFIG_DVB_STV0297=m
CONFIG_DVB_TDA10021=m
CONFIG_DVB_TDA10023=m
CONFIG_DVB_VES1820=m
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_AU8522=m
CONFIG_DVB_AU8522_DTV=m
CONFIG_DVB_AU8522_V4L=m
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LG2160=m
CONFIG_DVB_LGDT3305=m
CONFIG_DVB_LGDT3306A=m
CONFIG_DVB_LGDT330X=m
CONFIG_DVB_MXL692=m
CONFIG_DVB_NXT200X=m
CONFIG_DVB_OR51132=m
CONFIG_DVB_OR51211=m
CONFIG_DVB_S5H1409=m
CONFIG_DVB_S5H1411=m
# ISDB-T (terrestrial) frontends
CONFIG_DVB_DIB8000=m
CONFIG_DVB_MB86A20S=m
CONFIG_DVB_S921=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
CONFIG_DVB_MN88443X=m
CONFIG_DVB_TC90522=m
# Digital terrestrial only tuners/PLL
CONFIG_DVB_PLL=m
CONFIG_DVB_TUNER_DIB0070=m
CONFIG_DVB_TUNER_DIB0090=m
# SEC control devices for DVB-S
CONFIG_DVB_A8293=m
CONFIG_DVB_AF9033=m
CONFIG_DVB_ASCOT2E=m
CONFIG_DVB_ATBM8830=m
CONFIG_DVB_HELENE=m
CONFIG_DVB_HORUS3A=m
CONFIG_DVB_ISL6405=m
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_IX2505V=m
CONFIG_DVB_LGS8GL5=m
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_LNBH25=m
CONFIG_DVB_LNBH29=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
CONFIG_DVB_M88RS2000=m
CONFIG_DVB_TDA665x=m
CONFIG_DVB_DRX39XYJ=m
# Common Interface (EN50221) controller drivers
CONFIG_DVB_CXD2099=m
CONFIG_DVB_SP2=m
# end of Customise DVB Frontends
# Tools to develop new frontends
# CONFIG_DVB_DUMMY_FE is not set
# end of Media ancillary drivers
# Graphics support
CONFIG_DRM=m
CONFIG_DRM_MIPI_DSI=y
CONFIG_DRM_KMS_HELPER=m
# CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
# CONFIG_DRM_DEBUG_MODESET_LOCK is not set
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
CONFIG_DRM_DP_AUX_BUS=m
CONFIG_DRM_DISPLAY_HELPER=m
CONFIG_DRM_DISPLAY_DP_HELPER=y
CONFIG_DRM_DISPLAY_HDCP_HELPER=y
CONFIG_DRM_DISPLAY_HDMI_HELPER=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_DMA_HELPER=m
# I2C encoder or helper chips
CONFIG_DRM_I2C_CH7006=m
CONFIG_DRM_I2C_SIL164=m
CONFIG_DRM_I2C_NXP_TDA998X=m
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
CONFIG_DRM_HDLCD=m
# CONFIG_DRM_HDLCD_SHOW_UNDERRUN is not set
CONFIG_DRM_MALI_DISPLAY=m
CONFIG_DRM_KOMEDA=m
# end of ARM devices
# CONFIG_DRM_RADEON is not set
# CONFIG_DRM_AMDGPU is not set
# CONFIG_DRM_NOUVEAU is not set
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_VMWGFX is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_AST is not set
# CONFIG_DRM_MGAG200 is not set
CONFIG_DRM_RCAR_DW_HDMI=m
CONFIG_DRM_RCAR_USE_LVDS=y
CONFIG_DRM_RCAR_USE_MIPI_DSI=y
# CONFIG_DRM_QXL is not set
# CONFIG_DRM_VIRTIO_GPU is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ABT_Y030XX067A is not set
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
# CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set
# CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
# CONFIG_DRM_PANEL_DSI_CM is not set
CONFIG_DRM_PANEL_LVDS=m
CONFIG_DRM_PANEL_SIMPLE=m
CONFIG_DRM_PANEL_EDP=m
# CONFIG_DRM_PANEL_EBBG_FT8719 is not set
# CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
# CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_JDI_R63452 is not set
# CONFIG_DRM_PANEL_KHADAS_TS050 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set
# CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT35560 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT35950 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
CONFIG_DRM_PANEL_MANTIX_MLAF057WE51=m
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
# CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
CONFIG_DRM_PANEL_RAYDIUM_RM67191=m
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
# CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
CONFIG_DRM_PANEL_SITRONIX_ST7703=m
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set
# CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
# CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
# CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set
# CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_CHIPONE_ICN6211 is not set
# CONFIG_DRM_CHRONTEL_CH7033 is not set
# CONFIG_DRM_CROS_EC_ANX7688 is not set
CONFIG_DRM_DISPLAY_CONNECTOR=m
# CONFIG_DRM_ITE_IT6505 is not set
CONFIG_DRM_LONTIUM_LT8912B=m
# CONFIG_DRM_LONTIUM_LT9211 is not set
CONFIG_DRM_LONTIUM_LT9611=m
CONFIG_DRM_LONTIUM_LT9611UXC=m
CONFIG_DRM_ITE_IT66121=m
# CONFIG_DRM_LVDS_CODEC is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
CONFIG_DRM_NWL_MIPI_DSI=m
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
CONFIG_DRM_PARADE_PS8640=m
# CONFIG_DRM_SIL_SII8620 is not set
CONFIG_DRM_SII902X=m
# CONFIG_DRM_SII9234 is not set
CONFIG_DRM_SIMPLE_BRIDGE=m
CONFIG_DRM_THINE_THC63LVD1024=m
# CONFIG_DRM_TOSHIBA_TC358762 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
# CONFIG_DRM_TOSHIBA_TC358775 is not set
# CONFIG_DRM_TI_DLPC3433 is not set
CONFIG_DRM_TI_TFP410=m
# CONFIG_DRM_TI_SN65DSI83 is not set
CONFIG_DRM_TI_SN65DSI86=m
# CONFIG_DRM_TI_TPD12S015 is not set
# CONFIG_DRM_ANALOGIX_ANX6345 is not set
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_ANALOGIX_ANX7625 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
CONFIG_DRM_CDNS_DSI=m
CONFIG_DRM_CDNS_DSI_J721E=y
CONFIG_DRM_CDNS_MHDP8546=m
CONFIG_DRM_CDNS_MHDP8546_J721E=y
CONFIG_DRM_DW_HDMI=m
CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
CONFIG_DRM_DW_HDMI_I2S_AUDIO=m
# CONFIG_DRM_DW_HDMI_GP_AUDIO is not set
CONFIG_DRM_DW_HDMI_CEC=m
# end of Display Interface Bridges
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_HISI_HIBMC is not set
# CONFIG_DRM_HISI_KIRIN is not set
# CONFIG_DRM_LOGICVC is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
# CONFIG_DRM_GM12U320 is not set
# CONFIG_DRM_PANEL_MIPI_DBI is not set
# CONFIG_DRM_SIMPLEDRM is not set
# CONFIG_TINYDRM_HX8357D is not set
# CONFIG_TINYDRM_ILI9163 is not set
# CONFIG_TINYDRM_ILI9225 is not set
# CONFIG_TINYDRM_ILI9341 is not set
# CONFIG_TINYDRM_ILI9486 is not set
# CONFIG_TINYDRM_MI0283QT is not set
# CONFIG_TINYDRM_REPAPER is not set
# CONFIG_TINYDRM_ST7586 is not set
# CONFIG_TINYDRM_ST7735R is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LIMA is not set
# CONFIG_DRM_PANFROST is not set
CONFIG_DRM_TIDSS=m
# CONFIG_DRM_GUD is not set
# CONFIG_DRM_SSD130X is not set
CONFIG_DRM_LEGACY=y
# CONFIG_DRM_TDFX is not set
# CONFIG_DRM_R128 is not set
# CONFIG_DRM_MGA is not set
# CONFIG_DRM_VIA is not set
# CONFIG_DRM_SAVAGE is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
CONFIG_DRM_NOMODESET=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CFB_FILLRECT=m
CONFIG_FB_CFB_COPYAREA=m
CONFIG_FB_CFB_IMAGEBLIT=m
CONFIG_FB_SYS_FILLRECT=m
CONFIG_FB_SYS_COPYAREA=m
CONFIG_FB_SYS_IMAGEBLIT=m
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=m
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_ARMCLCD is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_EFI is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_NVIDIA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I740 is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_S3 is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_VT8623 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_ARK is not set
# CONFIG_FB_PM3 is not set
# CONFIG_FB_CARMINE is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
# CONFIG_FB_SM712 is not set
# end of Frame buffer Devices
# Backlight & LCD device support
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_KTD253 is not set
CONFIG_BACKLIGHT_PWM=m
# CONFIG_BACKLIGHT_QCOM_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
CONFIG_BACKLIGHT_LP855X=m
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_BACKLIGHT_LED is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_DUMMY_CONSOLE_COLUMNS=80
CONFIG_DUMMY_CONSOLE_ROWS=25
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
# end of Console display driver support
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_LOGO_LINUX_CLUT224=y
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_PCM_ELD=y
CONFIG_SND_PCM_IEC958=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_HWDEP=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_MAX_CARDS=32
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
CONFIG_SND_CTL_FAST_LOOKUP=y
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_CTL_INPUT_VALIDATION is not set
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_SERIAL_GENERIC is not set
# CONFIG_SND_MPU401 is not set
CONFIG_SND_PCI=y
# CONFIG_SND_AD1889 is not set
# CONFIG_SND_ALS300 is not set
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AW2 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_OXYGEN is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CTXFI is not set
# CONFIG_SND_DARLA20 is not set
# CONFIG_SND_GINA20 is not set
# CONFIG_SND_LAYLA20 is not set
# CONFIG_SND_DARLA24 is not set
# CONFIG_SND_GINA24 is not set
# CONFIG_SND_LAYLA24 is not set
# CONFIG_SND_MONA is not set
# CONFIG_SND_MIA is not set
# CONFIG_SND_ECHO3G is not set
# CONFIG_SND_INDIGO is not set
# CONFIG_SND_INDIGOIO is not set
# CONFIG_SND_INDIGODJ is not set
# CONFIG_SND_INDIGOIOX is not set
# CONFIG_SND_INDIGODJX is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
# CONFIG_SND_FM801 is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_HDSPM is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
# CONFIG_SND_INTEL8X0 is not set
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_LOLA is not set
# CONFIG_SND_LX6464ES is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_PCXHR is not set
# CONFIG_SND_RIPTIDE is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_SE6X is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VIRTUOSO is not set
# CONFIG_SND_VX222 is not set
# CONFIG_SND_YMFPCI is not set
# HD-Audio
# CONFIG_SND_HDA_INTEL is not set
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
# CONFIG_SND_SPI is not set
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_ADI is not set
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_AMD_ACP_CONFIG is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
CONFIG_SND_SOC_FSL_ASRC=m
# CONFIG_SND_SOC_FSL_SAI is not set
CONFIG_SND_SOC_FSL_AUDMIX=m
CONFIG_SND_SOC_FSL_SSI=m
CONFIG_SND_SOC_FSL_SPDIF=m
CONFIG_SND_SOC_FSL_ESAI=m
CONFIG_SND_SOC_FSL_MICFIL=m
CONFIG_SND_SOC_FSL_EASRC=m
# CONFIG_SND_SOC_FSL_XCVR is not set
CONFIG_SND_SOC_FSL_UTILS=m
# CONFIG_SND_SOC_FSL_RPMSG is not set
CONFIG_SND_SOC_IMX_AUDMUX=m
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Audio support for Texas Instruments SoCs
CONFIG_SND_SOC_TI_EDMA_PCM=m
CONFIG_SND_SOC_TI_SDMA_PCM=m
CONFIG_SND_SOC_TI_UDMA_PCM=m
# Texas Instruments DAI support for:
CONFIG_SND_SOC_DAVINCI_MCASP=m
# Audio support for boards with Texas Instruments SoCs
CONFIG_SND_SOC_J721E_EVM=m
# end of Audio support for Texas Instruments SoCs
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1372_I2C is not set
# CONFIG_SND_SOC_ADAU1372_SPI is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
CONFIG_SND_SOC_ADAU7002=m
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4375 is not set
# CONFIG_SND_SOC_AK4458 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_AW8738 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
CONFIG_SND_SOC_CROS_EC_CODEC=m
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS35L41_SPI is not set
# CONFIG_SND_SOC_CS35L41_I2C is not set
# CONFIG_SND_SOC_CS35L45_SPI is not set
# CONFIG_SND_SOC_CS35L45_I2C is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS42L83 is not set
# CONFIG_SND_SOC_CS4234 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DA7213 is not set
CONFIG_SND_SOC_DMIC=m
CONFIG_SND_SOC_HDMI_CODEC=m
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8326 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
CONFIG_SND_SOC_GTM601=m
# CONFIG_SND_SOC_HDA is not set
# CONFIG_SND_SOC_ICS43432 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
CONFIG_SND_SOC_MAX98357A=m
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
CONFIG_SND_SOC_MAX98927=m
# CONFIG_SND_SOC_MAX98520 is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
# CONFIG_SND_SOC_MAX98373_SDW is not set
# CONFIG_SND_SOC_MAX98390 is not set
# CONFIG_SND_SOC_MAX98396 is not set
# CONFIG_SND_SOC_MAX9860 is not set
CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m
CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
CONFIG_SND_SOC_PCM3168A=m
CONFIG_SND_SOC_PCM3168A_I2C=m
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM5102A is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RK817 is not set
CONFIG_SND_SOC_RL6231=m
# CONFIG_SND_SOC_RT1308_SDW is not set
# CONFIG_SND_SOC_RT1316_SDW is not set
# CONFIG_SND_SOC_RT1318_SDW is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5640 is not set
CONFIG_SND_SOC_RT5659=m
# CONFIG_SND_SOC_RT5682_SDW is not set
# CONFIG_SND_SOC_RT700_SDW is not set
# CONFIG_SND_SOC_RT711_SDW is not set
# CONFIG_SND_SOC_RT711_SDCA_SDW is not set
# CONFIG_SND_SOC_RT715_SDW is not set
# CONFIG_SND_SOC_RT715_SDCA_SDW is not set
# CONFIG_SND_SOC_RT9120 is not set
# CONFIG_SND_SOC_SDW_MOCKUP is not set
CONFIG_SND_SOC_SGTL5000=y
CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
CONFIG_SND_SOC_SIMPLE_MUX=m
CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_SRC4XXX_I2C is not set
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2518 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2764 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS2780 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS5805M is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TFA989X is not set
# CONFIG_SND_SOC_TLV320ADC3XXX is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
CONFIG_SND_SOC_TLV320AIC31XX=m
CONFIG_SND_SOC_TLV320AIC32X4=m
CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
CONFIG_SND_SOC_TLV320AIC3X=m
CONFIG_SND_SOC_TLV320AIC3X_I2C=m
# CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
# CONFIG_SND_SOC_TLV320ADCX140 is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
CONFIG_SND_SOC_WCD9335=m
CONFIG_SND_SOC_WCD_MBHC=m
CONFIG_SND_SOC_WCD934X=m
CONFIG_SND_SOC_WCD938X=m
CONFIG_SND_SOC_WCD938X_SDW=m
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
CONFIG_SND_SOC_WM8524=m
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731_I2C is not set
# CONFIG_SND_SOC_WM8731_SPI is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
CONFIG_SND_SOC_WM8904=m
# CONFIG_SND_SOC_WM8940 is not set
CONFIG_SND_SOC_WM8960=m
CONFIG_SND_SOC_WM8962=m
# CONFIG_SND_SOC_WM8974 is not set
CONFIG_SND_SOC_WM8978=m
# CONFIG_SND_SOC_WM8985 is not set
CONFIG_SND_SOC_WSA881X=m
# CONFIG_SND_SOC_WSA883X is not set
# CONFIG_SND_SOC_ZL38060 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_MT6660 is not set
# CONFIG_SND_SOC_NAU8315 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8821 is not set
CONFIG_SND_SOC_NAU8822=m
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SOC_LPASS_MACRO_COMMON=m
CONFIG_SND_SOC_LPASS_WSA_MACRO=m
CONFIG_SND_SOC_LPASS_VA_MACRO=m
CONFIG_SND_SOC_LPASS_RX_MACRO=m
CONFIG_SND_SOC_LPASS_TX_MACRO=m
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=m
CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD2=m
# CONFIG_SND_AUDIO_GRAPH_CARD2_CUSTOM_SAMPLE is not set
# CONFIG_SND_TEST_COMPONENT is not set
# CONFIG_SND_VIRTIO is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_BIGBEN_FF is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELAN is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_GLORIOUS is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GOOGLE_HAMMER is not set
# CONFIG_HID_VIVALDI is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_VRC2 is not set
# CONFIG_HID_XIAOMI is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
# CONFIG_HID_ITE is not set
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
# CONFIG_HID_LETSKETCH is not set
# CONFIG_HID_LOGITECH is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
# CONFIG_HID_MEGAWORLD_FF is not set
# CONFIG_HID_REDRAGON is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MONTEREY is not set
CONFIG_HID_MULTITOUCH=m
# CONFIG_HID_NINTENDO is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PLAYSTATION is not set
# CONFIG_HID_PXRC is not set
# CONFIG_HID_RAZER is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SEMITEK is not set
# CONFIG_HID_SIGMAMICRO is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_TOPRE is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_U2FZERO is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# CONFIG_HID_MCP2221 is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# end of USB HID support
# I2C HID support
CONFIG_I2C_HID_OF=m
# CONFIG_I2C_HID_OF_ELAN is not set
# CONFIG_I2C_HID_OF_GOODIX is not set
# end of I2C HID support
CONFIG_I2C_HID_CORE=m
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
# CONFIG_USB_LED_TRIG is not set
CONFIG_USB_ULPI_BUS=y
CONFIG_USB_CONN_GPIO=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_PCI=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_FEW_INIT_RETRIES is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_PRODUCTLIST is not set
# CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set
# CONFIG_USB_OTG_FSM is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
# CONFIG_USB_MON is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_XHCI_HCD=y
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=m
CONFIG_USB_XHCI_PCI_RENESAS=m
CONFIG_USB_XHCI_PLATFORM=m
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_PCI=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PCI=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
# CONFIG_USB_PRINTER is not set
CONFIG_USB_WDM=y
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
CONFIG_USB_CDNS_SUPPORT=m
CONFIG_USB_CDNS_HOST=y
CONFIG_USB_CDNS3=m
CONFIG_USB_CDNS3_GADGET=y
CONFIG_USB_CDNS3_HOST=y
CONFIG_USB_CDNS3_TI=m
# CONFIG_USB_MUSB_HDRC is not set
CONFIG_USB_DWC3=m
# CONFIG_USB_DWC3_ULPI is not set
# CONFIG_USB_DWC3_HOST is not set
# CONFIG_USB_DWC3_GADGET is not set
CONFIG_USB_DWC3_DUAL_ROLE=y
# Platform Glue Driver Support
CONFIG_USB_DWC3_HAPS=m
CONFIG_USB_DWC3_KEYSTONE=m
CONFIG_USB_DWC3_OF_SIMPLE=m
CONFIG_USB_DWC3_AM62=m
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
# CONFIG_USB_SERIAL_GENERIC is not set
# CONFIG_USB_SERIAL_SIMPLE is not set
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
CONFIG_USB_SERIAL_CP210X=m
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=m
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_F81232 is not set
# CONFIG_USB_SERIAL_F8153X is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_METRO is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MXUPORT is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
# CONFIG_USB_SERIAL_PL2303 is not set
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QCAUX is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_XSENS_MT is not set
# CONFIG_USB_SERIAL_WISHBONE is not set
# CONFIG_USB_SERIAL_SSU100 is not set
# CONFIG_USB_SERIAL_QT2 is not set
# CONFIG_USB_SERIAL_UPD78F0730 is not set
# CONFIG_USB_SERIAL_XR is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_APPLE_MFI_FASTCHARGE is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
# CONFIG_USB_ONBOARD_HUB is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
CONFIG_USB_ULPI=y
CONFIG_USB_ULPI_VIEWPORT=y
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
CONFIG_USB_SNP_CORE=y
CONFIG_USB_SNP_UDC_PLAT=y
# CONFIG_USB_M66592 is not set
CONFIG_USB_BDC_UDC=y
# CONFIG_USB_AMD5536UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_NET2280 is not set
# CONFIG_USB_GOKU is not set
# CONFIG_USB_EG20T is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_MAX3420_UDC is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_F_SS_LB=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_NCM=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_EEM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
CONFIG_USB_F_FS=m
CONFIG_USB_CONFIGFS=m
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
# CONFIG_USB_CONFIGFS_F_LB_SS is not set
CONFIG_USB_CONFIGFS_F_FS=y
# CONFIG_USB_CONFIGFS_F_UAC1 is not set
# CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
# CONFIG_USB_CONFIGFS_F_UAC2 is not set
# CONFIG_USB_CONFIGFS_F_MIDI is not set
# CONFIG_USB_CONFIGFS_F_HID is not set
# CONFIG_USB_CONFIGFS_F_UVC is not set
# CONFIG_USB_CONFIGFS_F_PRINTER is not set
# USB Gadget precomposed configurations
CONFIG_USB_ZERO=m
# CONFIG_USB_ZERO_HNPTEST is not set
# CONFIG_USB_AUDIO is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
CONFIG_USB_G_NCM=m
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
CONFIG_USB_CDC_COMPOSITE=m
# CONFIG_USB_G_ACM_MS is not set
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
CONFIG_USB_G_MULTI_CDC=y
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# CONFIG_USB_RAW_GADGET is not set
# end of USB Gadget precomposed configurations
CONFIG_TYPEC=m
CONFIG_TYPEC_TCPM=m
CONFIG_TYPEC_TCPCI=m
# CONFIG_TYPEC_RT1711H is not set
# CONFIG_TYPEC_MT6360 is not set
# CONFIG_TYPEC_TCPCI_MAXIM is not set
CONFIG_TYPEC_FUSB302=m
# CONFIG_TYPEC_UCSI is not set
CONFIG_TYPEC_TPS6598X=m
# CONFIG_TYPEC_ANX7411 is not set
# CONFIG_TYPEC_RT1719 is not set
CONFIG_TYPEC_HD3SS3220=m
# CONFIG_TYPEC_STUSB160X is not set
# CONFIG_TYPEC_WUSB3801 is not set
# USB Type-C Multiplexer/DeMultiplexer Switch support
# CONFIG_TYPEC_MUX_FSA4480 is not set
# CONFIG_TYPEC_MUX_PI3USB30532 is not set
# end of USB Type-C Multiplexer/DeMultiplexer Switch support
# USB Type-C Alternate Mode drivers
# CONFIG_TYPEC_DP_ALTMODE is not set
# end of USB Type-C Alternate Mode drivers
CONFIG_USB_ROLE_SWITCH=y
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
# CONFIG_PWRSEQ_SD8787 is not set
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=32
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_STM32_SDMMC=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_IO_ACCESSORS=y
# CONFIG_MMC_SDHCI_PCI is not set
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
# CONFIG_MMC_SDHCI_OF_AT91 is not set
CONFIG_MMC_SDHCI_OF_DWCMSHC=y
CONFIG_MMC_SDHCI_CADENCE=y
CONFIG_MMC_SDHCI_F_SDH30=y
# CONFIG_MMC_SDHCI_MILBEAUT is not set
# CONFIG_MMC_TIFM_SD is not set
CONFIG_MMC_SPI=y
# CONFIG_MMC_CB710 is not set
# CONFIG_MMC_VIA_SDMMC is not set
CONFIG_MMC_DW=y
CONFIG_MMC_DW_PLTFM=y
# CONFIG_MMC_DW_BLUEFIELD is not set
CONFIG_MMC_DW_EXYNOS=y
CONFIG_MMC_DW_HI3798CV200=y
CONFIG_MMC_DW_K3=y
# CONFIG_MMC_DW_PCI is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_CQHCI=y
# CONFIG_MMC_HSQ is not set
# CONFIG_MMC_TOSHIBA_PCI is not set
CONFIG_MMC_MTK=y
CONFIG_MMC_SDHCI_XENON=y
# CONFIG_MMC_SDHCI_OMAP is not set
CONFIG_MMC_SDHCI_AM654=y
CONFIG_SCSI_UFSHCD=y
CONFIG_SCSI_UFS_BSG=y
# CONFIG_SCSI_UFS_HPB is not set
# CONFIG_SCSI_UFS_HWMON is not set
# CONFIG_SCSI_UFSHCD_PCI is not set
CONFIG_SCSI_UFSHCD_PLATFORM=y
CONFIG_SCSI_UFS_CDNS_PLATFORM=m
# CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set
CONFIG_SCSI_UFS_TI_J721E=m
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
CONFIG_LEDS_CLASS_MULTICOLOR=m
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_AW2013 is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_EL15203000 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
CONFIG_LEDS_LM3692X=m
# CONFIG_LEDS_MT6323 is not set
CONFIG_LEDS_PCA9532=m
# CONFIG_LEDS_PCA9532_GPIO is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP50XX is not set
# CONFIG_LEDS_LP55XX_COMMON is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
CONFIG_LEDS_PWM=y
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
CONFIG_LEDS_SYSCON=y
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# Flash and Torch LED drivers
# RGB LED drivers
# CONFIG_LEDS_PWM_MULTICOLOR is not set
CONFIG_LEDS_QCOM_LPG=m
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
CONFIG_LEDS_TRIGGER_DISK=y
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
CONFIG_LEDS_TRIGGER_CPU=y
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
CONFIG_LEDS_TRIGGER_PANIC=y
# CONFIG_LEDS_TRIGGER_NETDEV is not set
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
# CONFIG_LEDS_TRIGGER_TTY is not set
# Simple LED drivers
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_SUPPORT=y
CONFIG_EDAC=y
CONFIG_EDAC_LEGACY_SYSFS=y
# CONFIG_EDAC_DEBUG is not set
# CONFIG_EDAC_THUNDERX is not set
# CONFIG_EDAC_XGENE is not set
# CONFIG_EDAC_DMC520 is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
CONFIG_RTC_DRV_HYM8563=m
# CONFIG_RTC_DRV_MAX6900 is not set
CONFIG_RTC_DRV_MAX77686=y
# CONFIG_RTC_DRV_NCT3018Y is not set
CONFIG_RTC_DRV_RK808=m
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
CONFIG_RTC_DRV_PCF85063=m
CONFIG_RTC_DRV_PCF85363=m
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
CONFIG_RTC_DRV_M41T80=m
# CONFIG_RTC_DRV_M41T80_WDT is not set
CONFIG_RTC_DRV_BQ32K=m
CONFIG_RTC_DRV_TPS6594=y
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
CONFIG_RTC_DRV_RX8581=m
# CONFIG_RTC_DRV_RX8025 is not set
CONFIG_RTC_DRV_RX8025T=y
# CONFIG_RTC_DRV_EM3027 is not set
CONFIG_RTC_DRV_RV3028=m
# CONFIG_RTC_DRV_RV3032 is not set
CONFIG_RTC_DRV_RV8803=m
CONFIG_RTC_DRV_S5M=y
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
CONFIG_RTC_DRV_DS3232=y
CONFIG_RTC_DRV_DS3232_HWMON=y
CONFIG_RTC_DRV_PCF2127=m
# CONFIG_RTC_DRV_RV3029C2 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
CONFIG_RTC_DRV_EFI=y
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_OPTEE is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
CONFIG_RTC_DRV_CROS_EC=y
# on-CPU RTC drivers
# CONFIG_RTC_DRV_PL030 is not set
CONFIG_RTC_DRV_PL031=y
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
CONFIG_RTC_DRV_MT6397=m
# CONFIG_RTC_DRV_R7301 is not set
CONFIG_RTC_DRV_TI_K3=m
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_GOLDFISH is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_ASYNC_TX_ENABLE_CHANNEL_SWITCH=y
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_AMBA_PL08X is not set
CONFIG_BCM_SBA_RAID=m
# CONFIG_DW_AXI_DMAC is not set
CONFIG_FSL_EDMA=y
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
CONFIG_MV_XOR_V2=y
CONFIG_PL330_DMA=y
# CONFIG_PLX_DMA is not set
# CONFIG_XILINX_DMA is not set
# CONFIG_XILINX_ZYNQMP_DMA is not set
# CONFIG_XILINX_ZYNQMP_DPDMA is not set
CONFIG_QCOM_HIDMA_MGMT=y
CONFIG_QCOM_HIDMA=y
# CONFIG_DW_DMAC is not set
# CONFIG_DW_DMAC_PCI is not set
# CONFIG_DW_EDMA is not set
# CONFIG_DW_EDMA_PCIE is not set
# CONFIG_SF_PDMA is not set
CONFIG_TI_K3_UDMA=y
CONFIG_TI_K3_UDMA_GLUE_LAYER=y
CONFIG_TI_K3_PSIL=y
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
CONFIG_DMA_ENGINE_RAID=y
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_MOVE_NOTIFY is not set
# CONFIG_DMABUF_DEBUG is not set
# CONFIG_DMABUF_SELFTESTS is not set
CONFIG_DMABUF_HEAPS=y
# CONFIG_DMABUF_SYSFS_STATS is not set
CONFIG_DMABUF_HEAPS_SYSTEM=y
CONFIG_DMABUF_HEAPS_CMA=y
CONFIG_DMABUF_HEAPS_CARVEOUT=y
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
CONFIG_VFIO=y
CONFIG_VFIO_IOMMU_TYPE1=y
CONFIG_VFIO_VIRQFD=y
# CONFIG_VFIO_NOIOMMU is not set
CONFIG_VFIO_PCI_CORE=y
CONFIG_VFIO_PCI_MMAP=y
CONFIG_VFIO_PCI_INTX=y
CONFIG_VFIO_PCI=y
# CONFIG_MLX5_VFIO_PCI is not set
# CONFIG_VFIO_PLATFORM is not set
# CONFIG_VFIO_MDEV is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO_ANCHOR=y
CONFIG_VIRTIO=y
CONFIG_VIRTIO_PCI_LIB=y
CONFIG_VIRTIO_PCI_LIB_LEGACY=y
CONFIG_VIRTIO_MENU=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_PCI_LEGACY=y
CONFIG_VIRTIO_BALLOON=y
# CONFIG_VIRTIO_MEM is not set
# CONFIG_VIRTIO_INPUT is not set
CONFIG_VIRTIO_MMIO=y
# CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
# CONFIG_VDPA is not set
CONFIG_VHOST_MENU=y
# CONFIG_VHOST_NET is not set
# CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
# CONFIG_COMEDI is not set
CONFIG_STAGING=y
# CONFIG_PRISM2_USB is not set
# CONFIG_RTL8192U is not set
# CONFIG_RTLLIB is not set
# CONFIG_RTL8723BS is not set
# CONFIG_R8712U is not set
# CONFIG_R8188EU is not set
# CONFIG_RTS5208 is not set
# CONFIG_VT6655 is not set
# CONFIG_VT6656 is not set
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16240 is not set
# end of Accelerometers
# Analog to digital converters
# CONFIG_AD7816 is not set
# end of Analog to digital converters
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# end of Analog digital bi-direction converters
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# end of Direct Digital Synthesis
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# end of Network Analyzer, Impedance Converters
# Active energy metering IC
# CONFIG_ADE7854 is not set
# end of Active energy metering IC
# Resolver to digital converters
# CONFIG_AD2S1210 is not set
# end of Resolver to digital converters
# end of IIO staging drivers
# CONFIG_FB_SM750 is not set
CONFIG_STAGING_MEDIA=y
CONFIG_VIDEO_MAX96712=m
# CONFIG_STAGING_MEDIA_DEPRECATED is not set
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_FB_TFT is not set
# CONFIG_KS7010 is not set
# CONFIG_PI433 is not set
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_QLGE is not set
# CONFIG_VME_BUS is not set
# CONFIG_GOLDFISH is not set
CONFIG_CHROME_PLATFORMS=y
CONFIG_CROS_EC=y
CONFIG_CROS_EC_I2C=y
# CONFIG_CROS_EC_RPMSG is not set
CONFIG_CROS_EC_SPI=y
CONFIG_CROS_EC_PROTO=y
# CONFIG_CROS_KBD_LED_BACKLIGHT is not set
CONFIG_CROS_EC_CHARDEV=m
CONFIG_CROS_EC_LIGHTBAR=y
CONFIG_CROS_EC_VBC=y
CONFIG_CROS_EC_DEBUGFS=y
CONFIG_CROS_EC_SENSORHUB=y
CONFIG_CROS_EC_SYSFS=y
CONFIG_CROS_EC_TYPEC=m
CONFIG_CROS_USBPD_NOTIFY=y
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_SURFACE_PLATFORMS=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Clock driver for ARM Reference designs
# CONFIG_CLK_ICST is not set
# CONFIG_CLK_SP810 is not set
CONFIG_CLK_VEXPRESS_OSC=y
# end of Clock driver for ARM Reference designs
# CONFIG_LMK04832 is not set
# CONFIG_COMMON_CLK_MAX77686 is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
CONFIG_COMMON_CLK_RK808=y
CONFIG_COMMON_CLK_SCMI=y
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
CONFIG_COMMON_CLK_CS2000_CP=y
CONFIG_COMMON_CLK_S2MPS11=y
# CONFIG_COMMON_CLK_AXI_CLKGEN is not set
CONFIG_COMMON_CLK_XGENE=y
CONFIG_COMMON_CLK_PWM=y
# CONFIG_COMMON_CLK_RS9_PCIE is not set
CONFIG_COMMON_CLK_VC5=y
# CONFIG_COMMON_CLK_VC7 is not set
CONFIG_COMMON_CLK_BD718XX=m
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_TI_SCI_CLK=y
# CONFIG_TI_SCI_CLK_PROBE_FROM_FW is not set
CONFIG_TI_SYSCON_CLK=y
# CONFIG_XILINX_VCU is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_HWSPINLOCK=y
# CONFIG_HWSPINLOCK_OMAP is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_OMAP_DM_TIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_ARM_ARCH_TIMER_OOL_WORKAROUND=y
CONFIG_FSL_ERRATUM_A008585=y
CONFIG_HISILICON_ERRATUM_161010101=y
CONFIG_ARM64_ERRATUM_858921=y
# CONFIG_MICROCHIP_PIT64B is not set
# end of Clock Source drivers
CONFIG_MAILBOX=y
# CONFIG_ARM_MHU is not set
# CONFIG_ARM_MHU_V2 is not set
# CONFIG_PLATFORM_MHU is not set
# CONFIG_PL320_MBOX is not set
CONFIG_OMAP2PLUS_MBOX=y
CONFIG_OMAP_MBOX_KFIFO_SIZE=256
# CONFIG_ALTERA_MBOX is not set
CONFIG_TI_MESSAGE_MANAGER=y
# CONFIG_MAILBOX_TEST is not set
CONFIG_IOMMU_IOVA=y
CONFIG_IOMMU_API=y
CONFIG_IOMMU_SUPPORT=y
# Generic IOMMU Pagetable Support
CONFIG_IOMMU_IO_PGTABLE=y
CONFIG_IOMMU_IO_PGTABLE_LPAE=y
# CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set
CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y
# CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set
CONFIG_IOMMU_IO_PGTABLE_DART=y
# end of Generic IOMMU Pagetable Support
# CONFIG_IOMMU_DEBUGFS is not set
CONFIG_IOMMU_DEFAULT_DMA_STRICT=y
# CONFIG_IOMMU_DEFAULT_DMA_LAZY is not set
# CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
CONFIG_OF_IOMMU=y
CONFIG_IOMMU_DMA=y
CONFIG_ARM_SMMU=y
# CONFIG_ARM_SMMU_LEGACY_DT_BINDINGS is not set
CONFIG_ARM_SMMU_DISABLE_BYPASS_BY_DEFAULT=y
CONFIG_ARM_SMMU_V3=y
# CONFIG_ARM_SMMU_V3_SVA is not set
# CONFIG_VIRTIO_IOMMU is not set
# Remoteproc drivers
CONFIG_REMOTEPROC=y
# CONFIG_REMOTEPROC_CDEV is not set
CONFIG_PRU_REMOTEPROC=m
CONFIG_TI_K3_DSP_REMOTEPROC=m
CONFIG_TI_K3_M4_REMOTEPROC=m
CONFIG_TI_K3_R5_REMOTEPROC=m
# end of Remoteproc drivers
# Rpmsg drivers
CONFIG_RPMSG=y
# CONFIG_RPMSG_CHAR is not set
# CONFIG_RPMSG_CTRL is not set
CONFIG_RPMSG_NS=y
# CONFIG_RPMSG_QCOM_GLINK_RPM is not set
CONFIG_RPMSG_VIRTIO=y
CONFIG_RPMSG_PRU=m
# end of Rpmsg drivers
# Rpmsg virtual device drivers
CONFIG_RPMSG_KDRV=y
# CONFIG_RPMSG_KDRV_DEMO is not set
# CONFIG_RPMSG_KDRV_DISPLAY is not set
CONFIG_RPMSG_KDRV_ETH_SWITCH=y
# end of Rpmsg virtual device drivers
CONFIG_SOUNDWIRE=m
# SoundWire Devices
CONFIG_SOUNDWIRE_QCOM=m
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Broadcom SoC drivers
CONFIG_SOC_BRCMSTB=y
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# CONFIG_QUICC_ENGINE is not set
CONFIG_FSL_RCPM=y
# end of NXP/Freescale QorIQ SoC drivers
# fujitsu SoC drivers
# end of fujitsu SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Enable LiteX SoC Builder specific drivers
# CONFIG_LITEX_SOC_CONTROLLER is not set
# end of Enable LiteX SoC Builder specific drivers
# Qualcomm SoC drivers
CONFIG_QCOM_QMI_HELPERS=m
# end of Qualcomm SoC drivers
CONFIG_SOC_TI=y
CONFIG_TI_SCI_PM_DOMAINS=y
CONFIG_TI_K3_RINGACC=y
CONFIG_TI_K3_SOCINFO=y
CONFIG_TI_PRUSS=m
CONFIG_TI_SCI_INTA_MSI_DOMAIN=y
# Xilinx SoC drivers
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
# CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
# CONFIG_DEVFREQ_GOV_POWERSAVE is not set
CONFIG_DEVFREQ_GOV_USERSPACE=m
# CONFIG_DEVFREQ_GOV_PASSIVE is not set
# DEVFREQ Drivers
# CONFIG_PM_DEVFREQ_EVENT is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
# CONFIG_EXTCON_FSA9480 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
CONFIG_EXTCON_PTN5150=m
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
CONFIG_EXTCON_USB_GPIO=y
CONFIG_EXTCON_USBC_CROS_EC=y
# CONFIG_EXTCON_USBC_TUSB320 is not set
CONFIG_MEMORY=y
# CONFIG_ARM_PL172_MPMC is not set
CONFIG_OMAP_GPMC=y
# CONFIG_OMAP_GPMC_DEBUG is not set
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
# CONFIG_IIO_BUFFER_CB is not set
# CONFIG_IIO_BUFFER_DMA is not set
# CONFIG_IIO_BUFFER_DMAENGINE is not set
# CONFIG_IIO_BUFFER_HW_CONSUMER is not set
CONFIG_IIO_KFIFO_BUF=m
CONFIG_IIO_TRIGGERED_BUFFER=m
# CONFIG_IIO_CONFIGFS is not set
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# CONFIG_IIO_TRIGGERED_EVENT is not set
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_ADXL313_I2C is not set
# CONFIG_ADXL313_SPI is not set
# CONFIG_ADXL345_I2C is not set
# CONFIG_ADXL345_SPI is not set
# CONFIG_ADXL355_I2C is not set
# CONFIG_ADXL355_SPI is not set
# CONFIG_ADXL367_SPI is not set
# CONFIG_ADXL367_I2C is not set
# CONFIG_ADXL372_SPI is not set
# CONFIG_ADXL372_I2C is not set
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMA400 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_BMI088_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_FXLS8962AF_I2C is not set
# CONFIG_FXLS8962AF_SPI is not set
# CONFIG_IIO_CROS_EC_ACCEL_LEGACY is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MSA311 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_SCA3300 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7091R5 is not set
# CONFIG_AD7124 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7280 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7292 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7606_IFACE_PARALLEL is not set
# CONFIG_AD7606_IFACE_SPI is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7768_1 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD7949 is not set
# CONFIG_AD799X is not set
# CONFIG_ADI_AXI_ADC is not set
# CONFIG_AXP20X_ADC is not set
# CONFIG_AXP288_ADC is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2496 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX11205 is not set
# CONFIG_MAX1241 is not set
# CONFIG_MAX1363 is not set
CONFIG_MAX9611=m
# CONFIG_MCP320X is not set
# CONFIG_MCP3422 is not set
# CONFIG_MCP3911 is not set
# CONFIG_MEDIATEK_MT6360_ADC is not set
# CONFIG_NAU7802 is not set
CONFIG_QCOM_VADC_COMMON=m
# CONFIG_QCOM_SPMI_IADC is not set
CONFIG_QCOM_SPMI_VADC=m
CONFIG_QCOM_SPMI_ADC5=m
# CONFIG_RICHTEK_RTQ6056 is not set
# CONFIG_SD_ADC_MODULATOR is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
CONFIG_TI_ADS1015=m
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8344 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_ADS124S08 is not set
# CONFIG_TI_ADS131E08 is not set
CONFIG_TI_AM335X_ADC=m
# CONFIG_TI_TLC4541 is not set
# CONFIG_TI_TSC2046 is not set
# CONFIG_VF610_ADC is not set
# CONFIG_XILINX_XADC is not set
# Analog to digital and digital to analog converters
# CONFIG_AD74413R is not set
# end of Analog to digital and digital to analog converters
# Analog Front Ends
# CONFIG_IIO_RESCALE is not set
# end of Analog Front Ends
# Amplifiers
# CONFIG_AD8366 is not set
# CONFIG_ADA4250 is not set
# CONFIG_HMC425 is not set
# end of Amplifiers
# Capacitance to digital converters
# CONFIG_AD7150 is not set
# CONFIG_AD7746 is not set
# end of Capacitance to digital converters
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_ATLAS_EZO_SENSOR is not set
# CONFIG_BME680 is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_PMS7003 is not set
# CONFIG_SCD30_CORE is not set
# CONFIG_SCD4X is not set
# CONFIG_SENSIRION_SGP30 is not set
# CONFIG_SENSIRION_SGP40 is not set
# CONFIG_SPS30_I2C is not set
# CONFIG_SPS30_SERIAL is not set
# CONFIG_SENSEAIR_SUNRISE_CO2 is not set
# CONFIG_VZ89X is not set
# end of Chemical Sensors
CONFIG_IIO_CROS_EC_SENSORS_CORE=m
CONFIG_IIO_CROS_EC_SENSORS=m
# CONFIG_IIO_CROS_EC_SENSORS_LID_ANGLE is not set
# Hid Sensor IIO Common
# end of Hid Sensor IIO Common
# IIO SCMI Sensors
# CONFIG_IIO_SCMI is not set
# end of IIO SCMI Sensors
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# end of SSP Sensor Common
CONFIG_IIO_ST_SENSORS_I2C=m
CONFIG_IIO_ST_SENSORS_SPI=m
CONFIG_IIO_ST_SENSORS_CORE=m
# Digital to analog converters
# CONFIG_AD3552R is not set
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_LTC2688 is not set
# CONFIG_AD5686_SPI is not set
# CONFIG_AD5696_I2C is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5758 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5766 is not set
# CONFIG_AD5770R is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7293 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_DS4424 is not set
# CONFIG_LTC1660 is not set
# CONFIG_LTC2632 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_TI_DAC082S085 is not set
# CONFIG_TI_DAC5571 is not set
# CONFIG_TI_DAC7311 is not set
# CONFIG_TI_DAC7612 is not set
# CONFIG_VF610_DAC is not set
# end of Digital to analog converters
# IIO dummy driver
# end of IIO dummy driver
# Filters
# CONFIG_ADMV8818 is not set
# end of Filters
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# end of Clock Generator/Distribution
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# CONFIG_ADF4371 is not set
# CONFIG_ADMV1013 is not set
# CONFIG_ADMV1014 is not set
# CONFIG_ADMV4420 is not set
# CONFIG_ADRF6780 is not set
# end of Phase-Locked Loop (PLL) frequency synthesizers
# end of Frequency Synthesizers DDS/PLL
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS290 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_FXAS21002C is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# end of Digital gyroscope sensors
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# end of Heart Rate Monitors
# end of Health Sensors
# Humidity sensors
# CONFIG_AM2315 is not set
# CONFIG_DHT11 is not set
# CONFIG_HDC100X is not set
# CONFIG_HDC2010 is not set
# CONFIG_HTS221 is not set
# CONFIG_HTU21 is not set
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# end of Humidity sensors
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16460 is not set
# CONFIG_ADIS16475 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_BOSCH_BNO055_SERIAL is not set
# CONFIG_BOSCH_BNO055_I2C is not set
# CONFIG_FXOS8700_I2C is not set
# CONFIG_FXOS8700_SPI is not set
# CONFIG_KMX61 is not set
# CONFIG_INV_ICM42600_I2C is not set
# CONFIG_INV_ICM42600_SPI is not set
# CONFIG_INV_MPU6050_I2C is not set
# CONFIG_INV_MPU6050_SPI is not set
CONFIG_IIO_ST_LSM6DSX=m
CONFIG_IIO_ST_LSM6DSX_I2C=m
CONFIG_IIO_ST_LSM6DSX_SPI=m
# CONFIG_IIO_ST_LSM9DS0 is not set
# end of Inertial measurement units
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_ADUX1020 is not set
# CONFIG_AL3010 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_AS73211 is not set
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
# CONFIG_CM36651 is not set
CONFIG_IIO_CROS_EC_LIGHT_PROX=m
# CONFIG_GP2AP002 is not set
# CONFIG_GP2AP020A00F is not set
CONFIG_SENSORS_ISL29018=m
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_LTRF216A is not set
# CONFIG_LV0104CS is not set
# CONFIG_MAX44000 is not set
# CONFIG_MAX44009 is not set
# CONFIG_NOA1305 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1133 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_ST_UVIS25 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL2591 is not set
# CONFIG_TSL2772 is not set
# CONFIG_TSL4531 is not set
# CONFIG_US5182D is not set
CONFIG_VCNL4000=m
# CONFIG_VCNL4035 is not set
# CONFIG_VEML6030 is not set
# CONFIG_VEML6070 is not set
# CONFIG_VL6180 is not set
# CONFIG_ZOPT2201 is not set
# end of Light sensors
# Magnetometer sensors
# CONFIG_AK8974 is not set
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_MMC35240 is not set
CONFIG_IIO_ST_MAGN_3AXIS=m
CONFIG_IIO_ST_MAGN_I2C_3AXIS=m
CONFIG_IIO_ST_MAGN_SPI_3AXIS=m
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# CONFIG_SENSORS_RM3100_I2C is not set
# CONFIG_SENSORS_RM3100_SPI is not set
# CONFIG_YAMAHA_YAS530 is not set
# end of Magnetometer sensors
# Multiplexers
# CONFIG_IIO_MUX is not set
# end of Multiplexers
# Inclinometer sensors
# end of Inclinometer sensors
# Triggers - standalone
# CONFIG_IIO_INTERRUPT_TRIGGER is not set
# CONFIG_IIO_SYSFS_TRIGGER is not set
# end of Triggers - standalone
# Linear and angular position sensors
# end of Linear and angular position sensors
# Digital potentiometers
# CONFIG_AD5110 is not set
# CONFIG_AD5272 is not set
# CONFIG_DS1803 is not set
# CONFIG_MAX5432 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4018 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_MCP41010 is not set
# CONFIG_TPL0102 is not set
# end of Digital potentiometers
# Digital potentiostats
# CONFIG_LMP91000 is not set
# end of Digital potentiostats
# Pressure sensors
# CONFIG_ABP060MG is not set
# CONFIG_BMP280 is not set
CONFIG_IIO_CROS_EC_BARO=m
# CONFIG_DLHL60D is not set
# CONFIG_DPS310 is not set
# CONFIG_HP03 is not set
# CONFIG_ICP10100 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
CONFIG_MPL3115=m
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# end of Pressure sensors
# Lightning sensors
# CONFIG_AS3935 is not set
# end of Lightning sensors
# Proximity and distance sensors
# CONFIG_CROS_EC_MKBP_PROXIMITY is not set
# CONFIG_ISL29501 is not set
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_MB1232 is not set
# CONFIG_PING is not set
# CONFIG_RFD77402 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9310 is not set
# CONFIG_SX9324 is not set
# CONFIG_SX9360 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# CONFIG_VCNL3020 is not set
# CONFIG_VL53L0X_I2C is not set
# end of Proximity and distance sensors
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1200 is not set
# Temperature sensors
# CONFIG_LTC2983 is not set
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_MLX90614 is not set
# CONFIG_MLX90632 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TMP117 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
# CONFIG_MAX31856 is not set
# CONFIG_MAX31865 is not set
# end of Temperature sensors
# CONFIG_NTB is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_DEBUG is not set
# CONFIG_PWM_ATMEL_TCB is not set
# CONFIG_PWM_CLK is not set
CONFIG_PWM_CROS_EC=m
# CONFIG_PWM_DWC is not set
# CONFIG_PWM_FSL_FTM is not set
CONFIG_PWM_OMAP_DMTIMER=m
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_TIECAP=m
CONFIG_PWM_TIEHRPWM=m
# CONFIG_PWM_XILINX is not set
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
CONFIG_ARM_GIC_V2M=y
CONFIG_ARM_GIC_V3=y
CONFIG_ARM_GIC_V3_ITS=y
CONFIG_ARM_GIC_V3_ITS_PCI=y
# CONFIG_AL_FIC is not set
# CONFIG_XILINX_INTC is not set
CONFIG_PARTITION_PERCPU=y
CONFIG_TI_SCI_INTR_IRQCHIP=y
CONFIG_TI_SCI_INTA_IRQCHIP=y
CONFIG_TI_PRUSS_INTC=m
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_SCMI=y
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_TI_SCI=y
# CONFIG_RESET_TI_SYSCON is not set
# CONFIG_RESET_TI_TPS380X is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_GENERIC_PHY_MIPI_DPHY=y
CONFIG_PHY_XGENE=y
CONFIG_PHY_CAN_TRANSCEIVER=m
# PHY drivers for Broadcom platforms
# CONFIG_BCM_KONA_USB2_PHY is not set
# end of PHY drivers for Broadcom platforms
CONFIG_PHY_CADENCE_TORRENT=y
CONFIG_PHY_CADENCE_DPHY=m
CONFIG_PHY_CADENCE_DPHY_RX=m
CONFIG_PHY_CADENCE_SIERRA=y
# CONFIG_PHY_CADENCE_SALVO is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_LAN966X_SERDES is not set
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
CONFIG_PHY_QCOM_USB_HS=m
# CONFIG_PHY_QCOM_USB_HSIC is not set
CONFIG_PHY_AM654_SERDES=y
CONFIG_PHY_J721E_WIZ=y
# CONFIG_OMAP_USB2 is not set
# CONFIG_PHY_TUSB1210 is not set
CONFIG_PHY_TI_GMII_SEL=y
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
CONFIG_ARM_CCI_PMU=m
CONFIG_ARM_CCI400_PMU=y
CONFIG_ARM_CCI5xx_PMU=y
CONFIG_ARM_CCN=m
CONFIG_ARM_CMN=m
CONFIG_ARM_PMU=y
CONFIG_ARM_DSU_PMU=m
CONFIG_ARM_SPE_PMU=m
# CONFIG_HISI_PCIE_PMU is not set
# CONFIG_HNS3_PMU is not set
# end of Performance monitor support
CONFIG_RAS=y
# CONFIG_USB4 is not set
# Android
# CONFIG_ANDROID_BINDER_IPC is not set
# end of Android
# CONFIG_LIBNVDIMM is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_RMEM=m
# CONFIG_NVMEM_SPMI_SDAM is not set
# CONFIG_NVMEM_U_BOOT_ENV is not set
# HW tracing support
CONFIG_STM=m
# CONFIG_STM_PROTO_BASIC is not set
# CONFIG_STM_PROTO_SYS_T is not set
# CONFIG_STM_DUMMY is not set
# CONFIG_STM_SOURCE_CONSOLE is not set
# CONFIG_STM_SOURCE_HEARTBEAT is not set
# CONFIG_INTEL_TH is not set
# CONFIG_HISI_PTT is not set
# end of HW tracing support
CONFIG_FPGA=y
# CONFIG_ALTERA_PR_IP_CORE is not set
# CONFIG_FPGA_MGR_ALTERA_PS_SPI is not set
CONFIG_FPGA_MGR_ALTERA_CVP=m
# CONFIG_FPGA_MGR_XILINX_SPI is not set
# CONFIG_FPGA_MGR_ICE40_SPI is not set
# CONFIG_FPGA_MGR_MACHXO2_SPI is not set
CONFIG_FPGA_BRIDGE=m
CONFIG_ALTERA_FREEZE_BRIDGE=m
# CONFIG_XILINX_PR_DECOUPLER is not set
CONFIG_FPGA_REGION=m
CONFIG_OF_FPGA_REGION=m
# CONFIG_FPGA_DFL is not set
# CONFIG_FPGA_MGR_MICROCHIP_SPI is not set
# CONFIG_FSI is not set
CONFIG_TEE=y
CONFIG_OPTEE=y
CONFIG_MULTIPLEXER=y
# Multiplexer drivers
# CONFIG_MUX_ADG792A is not set
# CONFIG_MUX_ADGS1408 is not set
CONFIG_MUX_GPIO=y
CONFIG_MUX_MMIO=y
# end of Multiplexer drivers
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
CONFIG_SLIMBUS=m
CONFIG_SLIM_QCOM_CTRL=m
CONFIG_INTERCONNECT=y
CONFIG_COUNTER=m
# CONFIG_INTERRUPT_CNT is not set
# CONFIG_FTM_QUADDEC is not set
# CONFIG_MICROCHIP_TCB_CAPTURE is not set
# CONFIG_INTEL_QEP is not set
CONFIG_TI_ECAP_CAPTURE=m
# CONFIG_MOST is not set
# CONFIG_PECI is not set
# CONFIG_HTE is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
# CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
# CONFIG_BTRFS_DEBUG is not set
# CONFIG_BTRFS_ASSERT is not set
# CONFIG_BTRFS_FS_REF_VERIFY is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
# CONFIG_QUOTA_NETLINK_INTERFACE is not set
CONFIG_PRINT_QUOTA_WARNING=y
# CONFIG_QUOTA_DEBUG is not set
# CONFIG_QFMT_V1 is not set
# CONFIG_QFMT_V2 is not set
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
# CONFIG_VIRTIO_FS is not set
CONFIG_OVERLAY_FS=m
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
# CONFIG_OVERLAY_FS_INDEX is not set
# CONFIG_OVERLAY_FS_XINO_AUTO is not set
# CONFIG_OVERLAY_FS_METACOPY is not set
# Caches
CONFIG_NETFS_SUPPORT=y
# CONFIG_NETFS_STATS is not set
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/EXFAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_EXFAT_FS is not set
# CONFIG_NTFS_FS is not set
# CONFIG_NTFS3_FS is not set
# end of DOS/FAT/EXFAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_VMCORE=y
# CONFIG_PROC_VMCORE_DEVICE_DUMP is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_TMPFS_INODE64 is not set
CONFIG_ARCH_SUPPORTS_HUGETLBFS=y
CONFIG_HUGETLBFS=y
CONFIG_HUGETLB_PAGE=y
CONFIG_MEMFD_CREATE=y
CONFIG_ARCH_HAS_GIGANTIC_PAGE=y
CONFIG_CONFIGFS_FS=y
CONFIG_EFIVAR_FS=y
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
CONFIG_UBIFS_FS=m
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_UBIFS_FS_AUTHENTICATION is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_FILE_CACHE=y
# CONFIG_SQUASHFS_FILE_DIRECT is not set
CONFIG_SQUASHFS_DECOMP_SINGLE=y
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
# CONFIG_SQUASHFS_XATTR is not set
CONFIG_SQUASHFS_ZLIB=y
# CONFIG_SQUASHFS_LZ4 is not set
# CONFIG_SQUASHFS_LZO is not set
# CONFIG_SQUASHFS_XZ is not set
# CONFIG_SQUASHFS_ZSTD is not set
# CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
CONFIG_PSTORE=y
CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240
CONFIG_PSTORE_DEFLATE_COMPRESS=y
# CONFIG_PSTORE_LZO_COMPRESS is not set
# CONFIG_PSTORE_LZ4_COMPRESS is not set
# CONFIG_PSTORE_LZ4HC_COMPRESS is not set
# CONFIG_PSTORE_842_COMPRESS is not set
# CONFIG_PSTORE_ZSTD_COMPRESS is not set
CONFIG_PSTORE_COMPRESS=y
CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y
CONFIG_PSTORE_COMPRESS_DEFAULT="deflate"
# CONFIG_PSTORE_CONSOLE is not set
# CONFIG_PSTORE_PMSG is not set
# CONFIG_PSTORE_RAM is not set
# CONFIG_PSTORE_BLK is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
CONFIG_NFS_V4=y
# CONFIG_NFS_SWAP is not set
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_PNFS_BLOCK=m
CONFIG_PNFS_FLEXFILE_LAYOUT=y
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_NFS_V4_SECURITY_LABEL=y
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
# CONFIG_NFS_V4_2_READ_PLUS is not set
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_COMMON=y
CONFIG_NFS_V4_2_SSC_HELPER=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_SMB_SERVER is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_9P_FS=y
# CONFIG_9P_FS_POSIX_ACL is not set
# CONFIG_9P_FS_SECURITY is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_TRUSTED_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
CONFIG_SECURITY=y
CONFIG_SECURITYFS=y
# CONFIG_SECURITY_NETWORK is not set
# CONFIG_SECURITY_PATH is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
# CONFIG_SECURITY_SMACK is not set
# CONFIG_SECURITY_TOMOYO is not set
# CONFIG_SECURITY_APPARMOR is not set
# CONFIG_SECURITY_LOADPIN is not set
# CONFIG_SECURITY_YAMA is not set
# CONFIG_SECURITY_SAFESETID is not set
# CONFIG_SECURITY_LOCKDOWN_LSM is not set
# CONFIG_SECURITY_LANDLOCK is not set
CONFIG_INTEGRITY=y
# CONFIG_INTEGRITY_SIGNATURE is not set
CONFIG_INTEGRITY_AUDIT=y
# CONFIG_IMA is not set
# CONFIG_IMA_SECURE_AND_OR_TRUSTED_BOOT is not set
# CONFIG_EVM is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set
# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set
# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set
# CONFIG_GCC_PLUGIN_STACKLEAK is not set
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y
# CONFIG_ZERO_CALL_USED_REGS is not set
# end of Memory initialization
CONFIG_RANDSTRUCT_NONE=y
# CONFIG_RANDSTRUCT_FULL is not set
# CONFIG_RANDSTRUCT_PERFORMANCE is not set
# end of Kernel hardening options
# end of Security options
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_TX_DISABLE_PQ_VAL_DMA=y
CONFIG_ASYNC_TX_DISABLE_XOR_VAL_DMA=y
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=m
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
# CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_ENGINE=m
# end of Crypto core or helper
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
CONFIG_CRYPTO_DH=m
# CONFIG_CRYPTO_DH_RFC7919_GROUPS is not set
CONFIG_CRYPTO_ECC=m
CONFIG_CRYPTO_ECDH=m
# CONFIG_CRYPTO_ECDSA is not set
# CONFIG_CRYPTO_ECRDSA is not set
# CONFIG_CRYPTO_SM2 is not set
CONFIG_CRYPTO_CURVE25519=m
# end of Public-key cryptography
# Block ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_ARIA is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=m
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
CONFIG_CRYPTO_SM4=m
CONFIG_CRYPTO_SM4_GENERIC=m
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# end of Block ciphers
# Length-preserving ciphers and modes
# CONFIG_CRYPTO_ADIANTUM is not set
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_HCTR2 is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
CONFIG_CRYPTO_XTS=m
# end of Length-preserving ciphers and modes
# AEAD (authenticated encryption with associated data) ciphers
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=y
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=y
# CONFIG_CRYPTO_ESSIV is not set
# end of AEAD (authenticated encryption with associated data) ciphers
# Hashes, digests, and MACs
CONFIG_CRYPTO_BLAKE2B=m
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_GHASH=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_MICHAEL_MIC=m
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_RMD160 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_SHA3=m
CONFIG_CRYPTO_SM3=m
CONFIG_CRYPTO_SM3_GENERIC=m
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_VMAC is not set
# CONFIG_CRYPTO_WP512 is not set
# CONFIG_CRYPTO_XCBC is not set
CONFIG_CRYPTO_XXHASH=m
# end of Hashes, digests, and MACs
# CRCs (cyclic redundancy checks)
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
CONFIG_CRYPTO_CRCT10DIF=y
CONFIG_CRYPTO_CRC64_ROCKSOFT=y
# end of CRCs (cyclic redundancy checks)
# Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_LZO=m
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
CONFIG_CRYPTO_ZSTD=m
# end of Compression
# Random number generation
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# end of Random number generation
# Userspace interface
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
CONFIG_CRYPTO_USER_API_RNG=m
# CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y
# end of Userspace interface
CONFIG_CRYPTO_HASH_INFO=y
# CONFIG_CRYPTO_NHPOLY1305_NEON is not set
CONFIG_CRYPTO_CHACHA20_NEON=m
# Accelerated Cryptographic Algorithms for CPU (arm64)
CONFIG_CRYPTO_GHASH_ARM64_CE=y
# CONFIG_CRYPTO_POLY1305_NEON is not set
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA256_ARM64=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_SHA512_ARM64=m
CONFIG_CRYPTO_SHA512_ARM64_CE=m
CONFIG_CRYPTO_SHA3_ARM64=m
# CONFIG_CRYPTO_SM3_NEON is not set
CONFIG_CRYPTO_SM3_ARM64_CE=m
# CONFIG_CRYPTO_POLYVAL_ARM64_CE is not set
# CONFIG_CRYPTO_AES_ARM64 is not set
CONFIG_CRYPTO_AES_ARM64_CE=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
CONFIG_CRYPTO_AES_ARM64_NEON_BLK=m
CONFIG_CRYPTO_AES_ARM64_BS=m
# CONFIG_CRYPTO_SM4_ARM64_CE is not set
# CONFIG_CRYPTO_SM4_ARM64_CE_BLK is not set
# CONFIG_CRYPTO_SM4_ARM64_NEON_BLK is not set
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_CRCT10DIF_ARM64_CE=m
# end of Accelerated Cryptographic Algorithms for CPU (arm64)
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
# CONFIG_CRYPTO_DEV_CCP is not set
# CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set
# CONFIG_CRYPTO_DEV_QAT_C3XXX is not set
# CONFIG_CRYPTO_DEV_QAT_C62X is not set
# CONFIG_CRYPTO_DEV_QAT_4XXX is not set
# CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set
# CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set
# CONFIG_CRYPTO_DEV_QAT_C62XVF is not set
# CONFIG_CRYPTO_DEV_NITROX_CNN55XX is not set
# CONFIG_CRYPTO_DEV_CAVIUM_ZIP is not set
# CONFIG_CRYPTO_DEV_VIRTIO is not set
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
CONFIG_CRYPTO_DEV_CCREE=m
# CONFIG_CRYPTO_DEV_HISI_SEC is not set
CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set
CONFIG_CRYPTO_DEV_SA2UL=m
CONFIG_CRYPTO_DEV_TI_MCRC64=m
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# CONFIG_FIPS_SIGNATURE_SELFTEST is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_RAID6_PQ=m
CONFIG_RAID6_PQ_BENCHMARK=y
CONFIG_LINEAR_RANGES=y
CONFIG_PACKING=y
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
# CONFIG_PRIME_NUMBERS is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_ARCH_HAS_FAST_MULTIPLIER=y
CONFIG_ARCH_USE_SYM_ANNOTATIONS=y
CONFIG_INDIRECT_PIO=y
# Crypto library routines
CONFIG_CRYPTO_LIB_UTILS=y
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_LIB_ARC4=y
CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y
CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
CONFIG_CRYPTO_LIB_CHACHA_GENERIC=m
# CONFIG_CRYPTO_LIB_CHACHA is not set
CONFIG_CRYPTO_LIB_CURVE25519_GENERIC=m
# CONFIG_CRYPTO_LIB_CURVE25519 is not set
CONFIG_CRYPTO_LIB_DES=m
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
# CONFIG_CRYPTO_LIB_POLY1305 is not set
# CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_LIB_SHA1=y
CONFIG_CRYPTO_LIB_SHA256=y
# end of Crypto library routines
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC64_ROCKSOFT=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC64=y
# CONFIG_CRC4 is not set
CONFIG_CRC7=y
CONFIG_LIBCRC32C=m
CONFIG_CRC8=y
CONFIG_XXHASH=y
CONFIG_AUDIT_GENERIC=y
CONFIG_AUDIT_ARCH_COMPAT_GENERIC=y
CONFIG_AUDIT_COMPAT_GENERIC=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMMON=y
CONFIG_ZSTD_COMPRESS=m
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
# CONFIG_XZ_DEC_MICROLZMA is not set
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_DECOMPRESS_ZSTD=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_BCH=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_INTERVAL_TREE=y
CONFIG_XARRAY_MULTI=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_DMA_OPS=y
CONFIG_NEED_SG_DMA_LENGTH=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
CONFIG_ARCH_HAS_DMA_PREP_COHERENT=y
CONFIG_SWIOTLB=y
# CONFIG_DMA_RESTRICTED_POOL is not set
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_COHERENT_POOL=y
CONFIG_DMA_DIRECT_REMAP=y
CONFIG_DMA_CMA=y
CONFIG_DMA_PERNUMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=256
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_DMA_MAP_BENCHMARK is not set
CONFIG_SGL_ALLOC=y
# CONFIG_FORCE_NR_CPUS is not set
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_CLZ_TAB=y
CONFIG_IRQ_POLL=y
CONFIG_MPILIB=y
CONFIG_DIMLIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_UCS2_STRING=y
CONFIG_HAVE_GENERIC_VDSO=y
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_GENERIC_VDSO_TIME_NS=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_SPLIT=y
CONFIG_SG_POOL=y
CONFIG_ARCH_STACKWALK=y
CONFIG_STACKDEPOT=y
CONFIG_SBITMAP=y
# end of Library routines
CONFIG_GENERIC_IOREMAP=y
CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
# CONFIG_STACKTRACE_BUILD_ID is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DYNAMIC_DEBUG_CORE is not set
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Compile-time checks and compiler options
CONFIG_DEBUG_INFO=y
CONFIG_AS_HAS_NON_CONST_LEB128=y
# CONFIG_DEBUG_INFO_NONE is not set
CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y
# CONFIG_DEBUG_INFO_DWARF4 is not set
# CONFIG_DEBUG_INFO_DWARF5 is not set
CONFIG_DEBUG_INFO_REDUCED=y
# CONFIG_DEBUG_INFO_COMPRESSED is not set
# CONFIG_DEBUG_INFO_SPLIT is not set
# CONFIG_GDB_SCRIPTS is not set
CONFIG_FRAME_WARN=2048
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_64B is not set
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
# CONFIG_VMLINUX_MAP is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
# CONFIG_DEBUG_FS_ALLOW_NONE is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y
# CONFIG_UBSAN is not set
CONFIG_HAVE_ARCH_KCSAN=y
CONFIG_HAVE_KCSAN_COMPILER=y
# CONFIG_KCSAN is not set
# end of Generic Kernel Debugging Instruments
# Networking Debugging
# CONFIG_NET_DEV_REFCNT_TRACKER is not set
# CONFIG_NET_NS_REFCNT_TRACKER is not set
# CONFIG_DEBUG_NET is not set
# end of Networking Debugging
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_TABLE_CHECK is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
CONFIG_ARCH_HAS_DEBUG_WX=y
# CONFIG_DEBUG_WX is not set
CONFIG_GENERIC_PTDUMP=y
# CONFIG_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SHRINKER_DEBUG is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_VM_PGTABLE is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_PER_CPU_MAPS is not set
CONFIG_HAVE_ARCH_KASAN=y
CONFIG_HAVE_ARCH_KASAN_SW_TAGS=y
CONFIG_HAVE_ARCH_KASAN_HW_TAGS=y
CONFIG_HAVE_ARCH_KASAN_VMALLOC=y
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_CC_HAS_KASAN_SW_TAGS=y
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
# CONFIG_KASAN is not set
CONFIG_HAVE_ARCH_KFENCE=y
# CONFIG_KFENCE is not set
# end of Memory Debugging
# CONFIG_DEBUG_SHIRQ is not set
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
# CONFIG_SCHED_DEBUG is not set
# CONFIG_SCHEDSTATS is not set
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# CONFIG_DEBUG_PREEMPT is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# CONFIG_SCF_TORTURE_TEST is not set
# CONFIG_CSD_LOCK_WAIT_DEBUG is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_IRQFLAGS is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
# Debug kernel data structures
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_DEBUG_MAPLE_TREE is not set
# end of Debug kernel data structures
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_SCALE_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_REF_SCALE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0
CONFIG_RCU_TRACE=y
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
CONFIG_SAMPLES=y
# CONFIG_SAMPLE_KOBJECT is not set
# CONFIG_SAMPLE_HW_BREAKPOINT is not set
# CONFIG_SAMPLE_KFIFO is not set
CONFIG_SAMPLE_RPMSG_CLIENT=m
# CONFIG_SAMPLE_CONFIGFS is not set
# CONFIG_SAMPLE_VFIO_MDEV_MDPY_FB is not set
# CONFIG_SAMPLE_CORESIGHT_SYSCFG is not set
CONFIG_STRICT_DEVMEM=y
# CONFIG_IO_STRICT_DEVMEM is not set
# arm64 Debugging
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_DEBUG_EFI is not set
# CONFIG_ARM64_RELOC_TEST is not set
CONFIG_CORESIGHT=m
CONFIG_CORESIGHT_LINKS_AND_SINKS=m
CONFIG_CORESIGHT_LINK_AND_SINK_TMC=m
CONFIG_CORESIGHT_CATU=m
CONFIG_CORESIGHT_SINK_TPIU=m
CONFIG_CORESIGHT_SINK_ETBV10=m
# CONFIG_CORESIGHT_SOURCE_ETM4X is not set
CONFIG_CORESIGHT_STM=m
CONFIG_CORESIGHT_CPU_DEBUG=m
# CONFIG_CORESIGHT_CPU_DEBUG_DEFAULT_ON is not set
CONFIG_CORESIGHT_CTI=m
# CONFIG_CORESIGHT_CTI_INTEGRATION_REGS is not set
# end of arm64 Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_MIN_HEAP is not set
# CONFIG_TEST_DIV64 is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_TEST_REF_TRACKER is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_STRING_SELFTEST is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_SCANF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_MAPLE_TREE is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_SIPHASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_BITOPS is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_MEMINIT is not set
# CONFIG_TEST_FREE_PAGES is not set
CONFIG_ARCH_USE_MEMTEST=y
CONFIG_MEMTEST=y
# end of Kernel Testing and Coverage
# Rust hacking
# end of Rust hacking
# end of Kernel hacking
After some tests, he found that opening a ttyRPMSG device requires more than just kernel configuration. It also seems to require the creation of endpoints in the M4F firmware. The endpoints created by the ipc_rpmsg_echo_linux example are rpmsg and rpmsg_ctrl. He didn't find an example of how an endpoint was created for rpmsg_tty?
Shine
