PROCESSOR-SDK-OMAPL138: procedure for changing MII to RMII
Part Number: PROCESSOR-SDK-OMAPL138
Other Parts Discussed in Thread: OMAPL138
    I made a custom board for OMAPL138. Default ethernet interface in OMAPL138 evaluation board is MII. But I changed that to RMII in my custom board. I changed the .dtsi file, .dts file in kernel and omapl138_lcdk.c for u-boot(only the pinmux configuration). But still I didn't get a ping. I am using SDKv6.03. I have no idea what I have to do next. Is this SDK is not suitable for RMII interface?. Can you please provide me the schematic used for this RMII interface. Please guide me for this. Thanks in advance for every  help.
    The SDK should be suitable to support a RMII configuration. I am not able to find a RMII schematic on the EVM on the product page only MII is used.
    Please attach a boot log and the results of ethtool eth0 and ethtool -S eth0.
    Schuyler
  • U-Boot SPL 2019.01-g333c3e72d3 (Apr 19 2020 - 06:43:52 +0000)
    Trying to boot from MMC1
    U-Boot 2019.01-g333c3e72d3 (Apr 19 2020 - 06:43:52 +0000)
    Model: DA850/AM1808/OMAP-L138 LCDK
    DRAM:  128 MiB
    NAND:  512 MiB
    MMC:   da830-mmc: 0
    Loading Environment from NAND... *** Warning - bad CRC, using default environmet
    In:    serial@10d000
    Out:   serial@10d000
    Err:   serial@10d000
    Invalid MAC address read.
    Net:   DaVinci-EMAC
    Warning: DaVinci-EMAC (eth0) using random MAC address - 76:cc:27:ed:82:00
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    ** Unable to read file boot.scr **
    ** Unable to read file uEnv.txt **
    3472248 bytes read in 888 ms (3.7 MiB/s)
    19970 bytes read in 7 ms (2.7 MiB/s)
    ## Flattened Device Tree blob at c0600000
       Booting using the fdt blob at 0xc0600000
       Loading Device Tree to c7e18000, end c7e1fe01 ... OK
    Starting kernel ...
    Booting Linux on physical CPU 0x0
    Linux version 4.19.94-gbe5389fd85 (spgdd@ubuntu) (gcc version 8.2.0 (GCC)) #1 P4
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
    CPU: VIVT data cache, VIVT instruction cache
    OF: fdt: Machine model: DA850/AM1808/OMAP-L138 LCDK
    Memory policy: Data cache writethrough
    Reserved memory: created CMA memory pool at 0xc3000000, size 16 MiB
    OF: reserved mem: initialized node dsp-memory@c3000000, compatible id shared-dml
    cma: Reserved 24 MiB at 0xc6400000
    DaVinci da850/omap-l138/am18x variant 0x1
    random: get_random_bytes called from start_kernel+0x88/0x424 with crng_init=0
    Built 1 zonelists, mobility grouping on.  Total pages: 32480
    Kernel command line: console=ttyS2,115200n8 root=PARTUUID=4a5b6188-02 rw rootfst
    Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Memory: 78944K/131072K available (6772K kernel code, 349K rwdata, 2156K rodata,)
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xc8800000 - 0xff800000   ( 880 MB)
        lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
        modules : 0xbf000000 - 0xc0000000   (  16 MB)
          .text : 0x(ptrval) - 0x(ptrval)   (6774 kB)
          .init : 0x(ptrval) - 0x(ptrval)   ( 256 kB)
          .data : 0x(ptrval) - 0x(ptrval)   ( 350 kB)
           .bss : 0x(ptrval) - 0x(ptrval)   ( 153 kB)
    SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    rcu: Preemptible hierarchical RCU implementation.
            Tasks RCU enabled.
    NR_IRQS: 245
    clocksource: timer0_1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79s
    sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    Console: colour dummy device 80x30
    Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    CPU: Testing write buffer coherency: ok
    Setting up static identity map for 0xc0008400 - 0xc0008458
    rcu: Hierarchical SRCU implementation.
    devtmpfs: initialized
    VFP support v0.3: not present
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 191s
    futex hash table entries: 256 (order: -1, 3072 bytes)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    cpuidle: using governor ladder
    cpuidle: using governor menu
    mux: initialized RTC_ALARM
    mux: Setting register RTC_ALARM
    mux:    PINMUX0 (0x00000000) = 0x44080000 -> 0x24080000
    gpiochip_add_data_with_key: GPIOs 0..143 (davinci_gpio.0) failed to register, -7
    edma 1e30000.edma: memcpy is disabled
    edma 1e30000.edma: TI EDMA DMA engine driver
    vcc_3v3d: supplied by vcc_5vd
    vcc_1v8d: supplied by vcc_5vd
    SCSI subsystem initialized
    media: Linux media interface: v0.10
    videodev: Linux video capture interface: v2.00
    pps_core: LinuxPPS API ver. 1 registered
    pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@>
    PTP clock support registered
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource timer0_1
    NET: Registered protocol family 2
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
    TCP established hash table entries: 1024 (order: 0, 4096 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    workingset: timestamp_bits=14 max_order=15 bucket_order=1
    Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    io scheduler noop registered (default)
    io scheduler mq-deadline registered
    io scheduler kyber registered
    pinctrl-single 1c14120.pinmux: 160 pins, size 80
    Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    console [ttyS2] disabled
    1d0d000.serial: ttyS2 at MMIO 0x1d0d000 (irq = 61, base_baud = 8250000) is a TIx
    console [ttyS2] enabled
    brd: module loaded
    libphy: Fixed MDIO Bus: probed
    davinci_mdio 1e24000.mdio: davinci mdio revision 1.5, bus freq 2200000
    davinci_mdio 1e24000.mdio: detected phy mask fffffff1
    libphy: 1e24000.mdio: probed
    davinci_mdio 1e24000.mdio: phy[1]: device 1e24000.mdio:01, driver Micrel KSZ886h
    davinci_mdio 1e24000.mdio: phy[2]: device 1e24000.mdio:02, driver Micrel KSZ886h
    davinci_mdio 1e24000.mdio: phy[3]: device 1e24000.mdio:03, driver Micrel KSZ886h
    i2c /dev entries driver
    davinci-wdt 1c21000.wdt: heartbeat 60 sec
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    ti-aemif 68000000.aemif: cannot get clock 'aemif'
    NET: Registered protocol family 10
    Segment Routing with IPv6
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    NET: Registered protocol family 17
    edma 1c00000.edma: memcpy is disabled
    edma 1c00000.edma: TI EDMA DMA engine driver
    davinci_mmc 1c40000.mmc: Got CD GPIO
    davinci_mmc 1c40000.mmc: Using DMA, 4-bit mode
    console [netcon0] enabled
    netconsole: network logging started
    davinci_emac 1e20000.ethernet: incompatible machine/device type for reading macs
    davinci_emac 1e20000.ethernet: using random MAC addr: 72:a4:ca:a3:e6:e3
    mmc0: host does not support reading read-only switch, assuming write-enable
    input: gpio-keys as /devices/platform/gpio-keys/input/input0
    hctosys: unable to open rtc device (rtc0)
    ALSA device list:
    mmc0: new high speed SDHC card at address aaaa
      No soundcards found.
     mmcblk0: p1 p2
    alloc_contig_range: [c6440, c6441) PFNs busy
    random: fast init done
    EXT4-fs (mmcblk0p2): 1 orphan inode deleted
    EXT4-fs (mmcblk0p2): recovery complete
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    VFS: Mounted root (ext4 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel memory: 256K
    This architecture does not have kernel memory protection.
    Run /sbin/init as init process
    systemd[1]: System time before build time, advancing clock.
    systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APP)
    systemd[1]: Detected architecture arm.
    Welcome to Arago 2019.11!
    systemd[1]: Set hostname to <omapl138-lcdk>.
    systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an .
    systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only sho)
    random: systemd: uninitialized urandom read (16 bytes read)
    systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Reached target Slices.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Listening on Journal Socket.
             Starting Create list of required st��…ce nodes for the current kernel..
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Listening on udev Control Socket.
             Mounting Temporary Directory (/tmp)...
             Starting Remount Root and Kernel File Systems...
    [  OK  ] Listening on Journal Socket (/dev/log).
             Starting Journal Service...
             Starting Load Kernel Modules...
    EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
             Mounting Kernel Debug File System...
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on udev Kernel Socket.
    cryptodev: loading out-of-tree module taints kernel.
             Starting udev Coldplug all Devices...
    cryptodev: driver 1.9 loaded.
    systemd[1]: Mounting POSIX Message Queue File System...
    systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    systemd[1]: Started Create list of required static device nodes for the current.
    [  OK  ] Started Create list of required sta��…vice nodes for the current kerne.
    systemd[1]: Mounted Temporary Directory (/tmp).
    [  OK  ] Mounted Temporary Directory (/tmp).
    systemd[1]: Started Remount Root and Kernel File Systems.
    [  OK  ] Started Remount Root and Kernel File Systems.
    systemd[1]: Started Load Kernel Modules.
    [  OK  ] Started Load Kernel Modules.
    systemd[1]: rngd.service: Main process exited, code=exited, status=1/FAILURE
    systemd[1]: rngd.service: Failed with result 'exit-code'.
    systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted POSIX Message Queue File System.
             Starting Apply Kernel Variables...
             Mounting Kernel Configuration File System...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
    [  OK  ] Reached target Containers.
             Mounting /var/volatile...
             Mounting /media/ram...
             Starting udev Kernel Device Manager...
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Load/Save Random Seed.
    systemd-journald[71]: Received request to flush runtime journal from PID 1
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Service...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    davinci-rproc 11800000.dsp: assigned reserved memory node dsp-memory@c3000000
    remoteproc remoteproc0: dsp is available
    nand: device found, Manufacturer ID: 0x01, Chip ID: 0xcc
    nand: AMD/Spansion S34ML04G1
    nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    remoteproc remoteproc0: powering up dsp
    remoteproc remoteproc0: Booting fw image rproc-dsp-fw, size 4100096
    Bad block table not found for chip 0
    Scanning device for bad blocks
    Bad eraseblock 4 at 0x000000080000
    Bad eraseblock 8 at 0x000000100000
    Bad eraseblock 9 at 0x000000120000
    Bad eraseblock 11 at 0x000000160000
    Bad eraseblock 12 at 0x000000180000
    Bad eraseblock 13 at 0x0000001a0000
    Bad eraseblock 14 at 0x0000001c0000
    Bad eraseblock 15 at 0x0000001e0000
    Bad eraseblock 16 at 0x000000200000
    Bad eraseblock 17 at 0x000000220000
    Bad eraseblock 18 at 0x000000240000
    Bad eraseblock 19 at 0x000000260000
    Bad eraseblock 20 at 0x000000280000
    Bad eraseblock 21 at 0x0000002a0000
    Bad eraseblock 22 at 0x0000002c0000
    Bad eraseblock 23 at 0x0000002e0000
    Bad eraseblock 24 at 0x000000300000
    remoteproc remoteproc0: registered virtio0 (type 7)
    remoteproc remoteproc0: remote processor dsp is now up
    Bad eraseblock 25 at 0x000000320000
    Bad eraseblock 26 at 0x000000340000
    Bad eraseblock 27 at 0x000000360000
    Bad eraseblock 28 at 0x000000380000
    Bad eraseblock 29 at 0x0000003a0000
    Bad eraseblock 30 at 0x0000003c0000
    Bad eraseblock 31 at 0x0000003e0000
    Bad eraseblock 32 at 0x000000400000
    Bad eraseblock 33 at 0x000000420000
    Bad eraseblock 34 at 0x000000440000
    Bad eraseblock 35 at 0x000000460000
    Bad eraseblock 36 at 0x000000480000
    Bad eraseblock 37 at 0x0000004a0000
    Bad eraseblock 38 at 0x0000004c0000
    Bad eraseblock 39 at 0x0000004e0000
    Bad eraseblock 40 at 0x000000500000
    Bad eraseblock 41 at 0x000000520000
    Bad eraseblock 42 at 0x000000540000
    Bad eraseblock 43 at 0x000000560000
    Bad eraseblock 44 at 0x000000580000
    Bad eraseblock 45 at 0x0000005a0000
    Bad eraseblock 46 at 0x0000005c0000
    Bad eraseblock 47 at 0x0000005e0000
    Bad eraseblock 48 at 0x000000600000
    Bad eraseblock 49 at 0x000000620000
    Bad eraseblock 50 at 0x000000640000
    Bad eraseblock 51 at 0x000000660000
    Bad eraseblock 52 at 0x000000680000
    Bad eraseblock 53 at 0x0000006a0000
    Bad eraseblock 54 at 0x0000006c0000
    Bad eraseblock 55 at 0x0000006e0000
    Bad eraseblock 56 at 0x000000700000
    Bad eraseblock 57 at 0x000000720000
    Bad eraseblock 58 at 0x000000740000
    Bad eraseblock 59 at 0x000000760000
    omap_rtc 1c23000.rtc: registered as rtc0
    Bad eraseblock 60 at 0x000000780000
    Bad eraseblock 61 at 0x0000007a0000
    Bad eraseblock 62 at 0x0000007c0000
    Bad eraseblock 63 at 0x0000007e0000
    Bad eraseblock 64 at 0x000000800000
    Bad eraseblock 65 at 0x000000820000
    Bad eraseblock 66 at 0x000000840000
    Bad eraseblock 67 at 0x000000860000
    Bad eraseblock 68 at 0x000000880000
    Bad eraseblock 69 at 0x0000008a0000
    Bad eraseblock 70 at 0x0000008c0000
    Bad eraseblock 71 at 0x0000008e0000
    Bad eraseblock 72 at 0x000000900000
    Bad eraseblock 73 at 0x000000920000
    Bad eraseblock 74 at 0x000000940000
    Bad eraseblock 75 at 0x000000960000
    pinctrl-single 1c14120.pinmux: pin PIN114 already requested by 1e20000.etherneto
    Bad eraseblock 76 at 0x000000980000
    Bad eraseblock 77 at 0x0000009a0000
    Bad eraseblock 78 at 0x0000009c0000
    tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.2
    pinctrl-single 1c14120.pinmux: pin-114 (1e17000.video) status -22
    pinctrl-single 1c14120.pinmux: could not request pin 114 (PIN114) from group vpe
    Bad eraseblock 79 at 0x0000009e0000
    Bad eraseblock 80 at 0x000000a00000
    tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.3
    Bad eraseblock 81 at 0x000000a20000
    Bad eraseblock 82 at 0x000000a40000
    Bad eraseblock 83 at 0x000000a60000
    vpif 1e17000.video: Error applying setting, reverse things back
    Bad eraseblock 84 at 0x000000a80000
    Bad eraseblock 85 at 0x000000aa0000
    Bad eraseblock 86 at 0x000000ac0000
    vpif: probe of 1e17000.video failed with error -22
    Bad eraseblock 87 at 0x000000ae0000
    Bad eraseblock 88 at 0x000000b00000
    Bad eraseblock 89 at 0x000000b20000
    Bad eraseblock 90 at 0x000000b40000
    Bad eraseblock 91 at 0x000000b60000
    Bad eraseblock 92 at 0x000000b80000
    Bad eraseblock 93 at 0x000000ba0000
    Bad eraseblock 94 at 0x000000bc0000
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    Bad eraseblock 95 at 0x000000be0000
    Bad eraseblock 96 at 0x000000c00000
    ahci_da850 1e18000.sata: forcing PORTS_IMPL to 0x1
    Bad eraseblock 97 at 0x000000c20000
    Bad eraseblock 98 at 0x000000c40000
    Bad eraseblock 99 at 0x000000c60000
    ahci_da850 1e18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platfoe
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    Bad eraseblock 100 at 0x000000c80000
    Bad eraseblock 101 at 0x000000ca0000
    ahci_da850 1e18000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc
    ohci-da8xx: DA8XX
    ohci-da8xx 1e25000.usb: USB Host Controller
    Bad eraseblock 102 at 0x000000cc0000
    Bad eraseblock 103 at 0x000000ce0000
    alloc_contig_range: [c6440, c6457) PFNs busy
    Bad eraseblock 104 at 0x000000d00000
    Bad eraseblock 105 at 0x000000d20000
    Bad eraseblock 106 at 0x000000d40000
    ohci-da8xx 1e25000.usb: new USB bus registered, assigned bus number 1
    scsi host0: ahci_da850
    ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
    Bad eraseblock 107 at 0x000000d60000
    Bad eraseblock 108 at 0x000000d80000
    usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not fr
    [  OK  hci-da8xx 1e25000.usb: irq 59, io mem 0x01e25000
    m] Started udev Coldplug all Devices.
    Bad eraseblock 109 at 0x000000da0000
    Bad eraseblock 110 at 0x000000dc0000
    Bad eraseblock 111 at 0x000000de0000
    Bad eraseblock 112 at 0x000000e00000
    Bad eraseblock 113 at 0x000000e20000
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
    usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
    Bad eraseblock 114 at 0x000000e40000
    Bad eraseblock 115 at 0x000000e60000
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: USB Host Controller
    Bad eraseblock 116 at 0x000000e80000
    Bad eraseblock 117 at 0x000000ea0000
    usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 ohci_hcd
    usb usb1: SerialNumber: 1e25000.usb
    Bad eraseblock 118 at 0x000000ec0000
    Bad eraseblock 119 at 0x000000ee0000
    hub 1-0:1.0: USB hub found
    Bad eraseblock 120 at 0x000000f00000
    Bad eraseblock 121 at 0x000000f20000
    Bad eraseblock 122 at 0x000000f40000
    musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
    hub 1-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
    Bad eraseblock 123 at 0x000000f60000
    Bad eraseblock 124 at 0x000000f80000
    usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Bad eraseblock 125 at 0x000000fa0000
    Bad eraseblock 126 at 0x000000fc0000
    Bad eraseblock 127 at 0x000000fe0000
    usb usb2: Product: MUSB HDRC host driver
    Bad eraseblock 128 at 0x000001000000
    usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 musb-hcd
    Bad eraseblock 129 at 0x000001020000
    Bad eraseblock 130 at 0x000001040000
    usb usb2: SerialNumber: musb-hdrc.1.auto
    Bad eraseblock 131 at 0x000001060000
    usb 1-1: new low-speed USB device number 2 using ohci-da8xx
    hub 2-0:1.0: USB hub found
    Bad eraseblock 132 at 0x000001080000
    Bad eraseblock 133 at 0x0000010a0000
    Bad eraseblock 134 at 0x0000010c0000
    hub 2-0:1.0: 1 port detected
    Bad eraseblock 135 at 0x0000010e0000
    Bad eraseblock 136 at 0x000001100000
    Bad eraseblock 137 at 0x000001120000
    usb 1-1: device descriptor read/64, error -62
    Bad eraseblock 138 at 0x000001140000
    Bad eraseblock 139 at 0x000001160000
    Bad eraseblock 140 at 0x000001180000
    Bad eraseblock 141 at 0x0000011a0000
    Bad eraseblock 142 at 0x0000011c0000
    Bad eraseblock 143 at 0x0000011e0000
    Bad eraseblock 144 at 0x000001200000
    Bad eraseblock 145 at 0x000001220000
    Bad eraseblock 146 at 0x000001240000
    Bad eraseblock 147 at 0x000001260000
    Bad eraseblock 148 at 0x000001280000
    asoc-simple-card sound: tlv320aic3x-hifi <-> 1d00000.mcasp mapping ok
    Bad eraseblock 149 at 0x0000012a0000
    Bad eraseblock 150 at 0x0000012c0000
    Bad eraseblock 151 at 0x0000012e0000
    usb 1-1: new low-speed USB device number 3 using ohci-da8xx
    ata1: SATA link down (SStatus 0 SControl 300)
    Bad eraseblock 152 at 0x000001300000
    Bad eraseblock 153 at 0x000001320000
    Bad eraseblock 154 at 0x000001340000
    Bad eraseblock 155 at 0x000001360000
    Bad eraseblock 156 at 0x000001380000
    tvp514x 0-005d: Write: retry ... 0
    Bad eraseblock 157 at 0x0000013a0000
    Bad eraseblock 158 at 0x0000013c0000
    tvp514x 0-005d: Write: retry ... 1
    tvp514x 0-005d: Write: retry ... 2
    tvp514x 0-005d: Write: retry ... 3
    Bad eraseblock 159 at 0x0000013e0000
    Bad eraseblock 160 at 0x000001400000
    Bad eraseblock 161 at 0x000001420000
    tvp514x 0-005d: Write: retry ... 4
    tvp514x 0-005d: Write: retry ... 5
    tvp514x 0-005d: tvp514x 0-005d decoder driver registered !!
    Bad eraseblock 162 at 0x000001440000
    Bad eraseblock 163 at 0x000001460000
    Bad eraseblock 164 at 0x000001480000
    vpif_capture vpif_capture: registered sub device tvp514x-0
    usb usb1-port1: attempt power cycle
    Bad eraseblock 165 at 0x0000014a0000
    Bad eraseblock 166 at 0x0000014c0000
    Bad eraseblock 167 at 0x0000014e0000
    Bad eraseblock 168 at 0x000001500000
    Bad eraseblock 169 at 0x000001520000
    Bad eraseblock 170 at 0x000001540000
    Bad eraseblock 171 at 0x000001560000
    Bad eraseblock 172 at 0x000001580000
    Bad eraseblock 173 at 0x0000015a0000
    Bad eraseblock 174 at 0x0000015c0000
    Bad eraseblock 175 at 0x0000015e0000
    usb 1-1: new low-speed USB device number 4 using ohci-da8xx
    davinci_mdio 1e24000.mdio: resetting idled controller
    Bad eraseblock 176 at 0x000001600000
    Bad eraseblock 177 at 0x000001620000
    Bad eraseblock 178 at 0x000001640000
    Bad eraseblock 179 at 0x000001660000
    Bad eraseblock 180 at 0x000001680000
    Micrel KSZ886X Switch 1e24000.mdio:01: attached PHY driver [Micrel KSZ886X Swit)
    Bad eraseblock 181 at 0x0000016a0000
    Bad eraseblock 182 at 0x0000016c0000
    Bad eraseblock 183 at 0x0000016e0000
    IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Bad eraseblock 184 at 0x000001700000
    Bad eraseblock 185 at 0x000001720000
    Bad eraseblock 186 at 0x000001740000
    usb 1-1: device not accepting address 4, error -62
    Bad eraseblock 187 at 0x000001760000
    Bad eraseblock 188 at 0x000001780000
    Bad eraseblock 189 at 0x0000017a0000
    Bad eraseblock 190 at 0x0000017c0000
    Bad eraseblock 191 at 0x0000017e0000
    usb 1-1: new low-speed USB device number 5 using ohci-da8xx
    Bad eraseblock 192 at 0x000001800000
    Bad eraseblock 193 at 0x000001820000
    Bad eraseblock 194 at 0x000001840000
    Bad eraseblock 195 at 0x000001860000
    Bad eraseblock 196 at 0x000001880000
    Bad eraseblock 197 at 0x0000018a0000
    Bad eraseblock 198 at 0x0000018c0000
    Bad eraseblock 199 at 0x0000018e0000
    Bad eraseblock 200 at 0x000001900000
    usb 1-1: device not accepting address 5, error -62
    Bad eraseblock 201 at 0x000001920000
    Bad eraseblock 202 at 0x000001940000
    Bad eraseblock 203 at 0x000001960000
    usb usb1-port1: unable to enumerate USB device
    Bad eraseblock 204 at 0x000001980000
    Bad eraseblock 205 at 0x0000019a0000
    Bad eraseblock 206 at 0x0000019c0000
    Bad eraseblock 207 at 0x0000019e0000
    Bad eraseblock 208 at 0x000001a00000
    Bad eraseblock 209 at 0x000001a20000
    Bad eraseblock 210 at 0x000001a40000
    Bad eraseblock 211 at 0x000001a60000
    Bad eraseblock 212 at 0x000001a80000
    Bad eraseblock 213 at 0x000001aa0000
    Bad eraseblock 214 at 0x000001ac0000
    Bad eraseblock 215 at 0x000001ae0000
    Bad eraseblock 216 at 0x000001b00000
    Bad eraseblock 217 at 0x000001b20000
    Bad eraseblock 218 at 0x000001b40000
    Bad eraseblock 219 at 0x000001b60000
    Bad eraseblock 220 at 0x000001b80000
    Bad eraseblock 221 at 0x000001ba0000
    Bad eraseblock 222 at 0x000001bc0000
    Bad eraseblock 223 at 0x000001be0000
    Bad eraseblock 224 at 0x000001c00000
    Bad eraseblock 225 at 0x000001c20000
    Bad eraseblock 226 at 0x000001c40000
    Bad eraseblock 227 at 0x000001c60000
    Bad eraseblock 228 at 0x000001c80000
    Bad eraseblock 229 at 0x000001ca0000
    Bad eraseblock 230 at 0x000001cc0000
    Bad eraseblock 231 at 0x000001ce0000
    Bad eraseblock 232 at 0x000001d00000
    Bad eraseblock 233 at 0x000001d20000
    Bad eraseblock 234 at 0x000001d40000
    Bad eraseblock 235 at 0x000001d60000
    Bad eraseblock 236 at 0x000001d80000
    Bad eraseblock 237 at 0x000001da0000
    Bad eraseblock 238 at 0x000001dc0000
    Bad eraseblock 239 at 0x000001de0000
    Bad eraseblock 240 at 0x000001e00000
    Bad eraseblock 241 at 0x000001e20000
    Bad eraseblock 242 at 0x000001e40000
    Bad eraseblock 243 at 0x000001e60000
    Bad eraseblock 244 at 0x000001e80000
    Bad eraseblock 245 at 0x000001ea0000
    Bad eraseblock 246 at 0x000001ec0000
    Bad eraseblock 247 at 0x000001ee0000
    Bad eraseblock 248 at 0x000001f00000
    Bad eraseblock 249 at 0x000001f20000
    Bad eraseblock 250 at 0x000001f40000
    Bad eraseblock 251 at 0x000001f60000
    Bad eraseblock 252 at 0x000001f80000
    Bad eraseblock 253 at 0x000001fa0000
    Bad eraseblock 254 at 0x000001fc0000
    Bad eraseblock 255 at 0x000001fe0000
    Bad eraseblock 256 at 0x000002000000
    Bad eraseblock 257 at 0x000002020000
    Bad eraseblock 258 at 0x000002040000
    Bad eraseblock 259 at 0x000002060000
    Bad eraseblock 260 at 0x000002080000
    Bad eraseblock 261 at 0x0000020a0000
    Bad eraseblock 262 at 0x0000020c0000
    Bad eraseblock 263 at 0x0000020e0000
    Bad eraseblock 264 at 0x000002100000
    Bad eraseblock 265 at 0x000002120000
    Bad eraseblock 266 at 0x000002140000
    Bad eraseblock 267 at 0x000002160000
    Bad eraseblock 268 at 0x000002180000
    Bad eraseblock 269 at 0x0000021a0000
    Bad eraseblock 270 at 0x0000021c0000
    Bad eraseblock 271 at 0x0000021e0000
    Bad eraseblock 272 at 0x000002200000
    Bad eraseblock 273 at 0x000002220000
    Bad eraseblock 274 at 0x000002240000
    Bad eraseblock 275 at 0x000002260000
    Bad eraseblock 276 at 0x000002280000
    Bad eraseblock 277 at 0x0000022a0000
    Bad eraseblock 278 at 0x0000022c0000
    Bad eraseblock 279 at 0x0000022e0000
    Bad eraseblock 280 at 0x000002300000
    Bad eraseblock 281 at 0x000002320000
    Bad eraseblock 282 at 0x000002340000
    Bad eraseblock 283 at 0x000002360000
    Bad eraseblock 284 at 0x000002380000
    davinci_emac 1e20000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Bad eraseblock 285 at 0x0000023a0000
    Bad eraseblock 286 at 0x0000023c0000
    Bad eraseblock 287 at 0x0000023e0000
    Bad eraseblock 288 at 0x000002400000
    Bad eraseblock 289 at 0x000002420000
    Bad eraseblock 290 at 0x000002440000
    Bad eraseblock 291 at 0x000002460000
    Bad eraseblock 292 at 0x000002480000
    Bad eraseblock 293 at 0x0000024a0000
    Bad eraseblock 294 at 0x0000024c0000
    Bad eraseblock 295 at 0x0000024e0000
    Bad eraseblock 296 at 0x000002500000
    Bad eraseblock 297 at 0x000002520000
    Bad eraseblock 298 at 0x000002540000
    Bad eraseblock 299 at 0x000002560000
    Bad eraseblock 300 at 0x000002580000
    Bad eraseblock 301 at 0x0000025a0000
    Bad eraseblock 302 at 0x0000025c0000
    Bad eraseblock 303 at 0x0000025e0000
    Bad eraseblock 304 at 0x000002600000
    Bad eraseblock 305 at 0x000002620000
    Bad eraseblock 306 at 0x000002640000
    [*     ] (1 of 2) A start job is running for dev-ttyS2.device (29s / 1min 30s)B0
    Bad eraseblock 308 at 0x000002680000
    Bad eraseblock 309 at 0x0000026a0000
    Bad eraseblock 310 at 0x0000026c0000
    Bad eraseblock 311 at 0x0000026e0000
    Bad eraseblock 312 at 0x000002700000
    Bad eraseblock 313 at 0x000002720000
    Bad eraseblock 314 at 0x000002740000
    Bad eraseblock 315 at 0x000002760000
    Bad eraseblock 316 at 0x000002780000
    Bad eraseblock 317 at 0x0000027a0000
    Bad eraseblock 318 at 0x0000027c0000
    Bad eraseblock 319 at 0x0000027e0000
    Bad eraseblock 320 at 0x000002800000
    Bad eraseblock 321 at 0x000002820000
    Bad eraseblock 322 at 0x000002840000
    Bad eraseblock 323 at 0x000002860000
    Bad eraseblock 324 at 0x000002880000
    Bad eraseblock 325 at 0x0000028a0000
    Bad eraseblock 326 at 0x0000028c0000
    Bad eraseblock 327 at 0x0000028e0000
    Bad eraseblock 328 at 0x000002900000
    Bad eraseblock 329 at 0x000002920000
    Bad eraseblock 330 at 0x000002940000
    Bad eraseblock 331 at 0x000002960000
    Bad eraseblock 332 at 0x000002980000
    Bad eraseblock 333 at 0x0000029a0000
    Bad eraseblock 334 at 0x0000029c0000
    Bad eraseblock 335 at 0x0000029e0000
    Bad eraseblock 336 at 0x000002a00000
    Bad eraseblock 337 at 0x000002a20000
    Bad eraseblock 338 at 0x000002a40000
    Bad eraseblock 339 at 0x000002a60000
    Bad eraseblock 340 at 0x000002a80000
    Bad eraseblock 341 at 0x000002aa0000
    Bad eraseblock 342 at 0x000002ac0000
    Bad eraseblock 343 at 0x000002ae0000
    Bad eraseblock 344 at 0x000002b00000
    Bad eraseblock 345 at 0x000002b20000
    Bad eraseblock 346 at 0x000002b40000
    Bad eraseblock 347 at 0x000002b60000
    Bad eraseblock 348 at 0x000002b80000
    Bad eraseblock 349 at 0x000002ba0000
    Bad eraseblock 350 at 0x000002bc0000
    Bad eraseblock 351 at 0x000002be0000
    Bad eraseblock 352 at 0x000002c00000
    Bad eraseblock 353 at 0x000002c20000
    Bad eraseblock 354 at 0x000002c40000
    Bad eraseblock 355 at 0x000002c60000
    Bad eraseblock 356 at 0x000002c80000
    Bad eraseblock 357 at 0x000002ca0000
    Bad eraseblock 358 at 0x000002cc0000
    Bad eraseblock 359 at 0x000002ce0000
    Bad eraseblock 360 at 0x000002d00000
    Bad eraseblock 361 at 0x000002d20000
    Bad eraseblock 362 at 0x000002d40000
    Bad eraseblock 363 at 0x000002d60000
    Bad eraseblock 364 at 0x000002d80000
    Bad eraseblock 365 at 0x000002da0000
    Bad eraseblock 366 at 0x000002dc0000
    Bad eraseblock 367 at 0x000002de0000
    Bad eraseblock 368 at 0x000002e00000
    Bad eraseblock 369 at 0x000002e20000
    Bad eraseblock 370 at 0x000002e40000
    Bad eraseblock 371 at 0x000002e60000
    Bad eraseblock 372 at 0x000002e80000
    Bad eraseblock 373 at 0x000002ea0000
    Bad eraseblock 374 at 0x000002ec0000
    Bad eraseblock 375 at 0x000002ee0000
    Bad eraseblock 376 at 0x000002f00000
    Bad eraseblock 377 at 0x000002f20000
    Bad eraseblock 378 at 0x000002f40000
    Bad eraseblock 379 at 0x000002f60000
    Bad eraseblock 380 at 0x000002f80000
    random: crng init done
    random: 7 urandom warning(s) missed due to ratelimiting
    Bad eraseblock 381 at 0x000002fa0000
    Bad eraseblock 382 at 0x000002fc0000
    Bad eraseblock 383 at 0x000002fe0000
    Bad eraseblock 384 at 0x000003000000
    Bad eraseblock 385 at 0x000003020000
    Bad eraseblock 386 at 0x000003040000
    Bad eraseblock 387 at 0x000003060000
    Bad eraseblock 388 at 0x000003080000
    Bad eraseblock 389 at 0x0000030a0000
    Bad eraseblock 390 at 0x0000030c0000
    Bad eraseblock 391 at 0x0000030e0000
    Bad eraseblock 392 at 0x000003100000
    Bad eraseblock 393 at 0x000003120000
    Bad eraseblock 394 at 0x000003140000
    Bad eraseblock 395 at 0x000003160000
    Bad eraseblock 396 at 0x000003180000
    Bad eraseblock 397 at 0x0000031a0000
    Bad eraseblock 398 at 0x0000031c0000
    Bad eraseblock 399 at 0x0000031e0000
    Bad eraseblock 400 at 0x000003200000
    virtio_rpmsg_bus virtio0: rpmsg host is online
    virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    alloc_contig_range: 4 callbacks suppressed
    Bad eraseblock 401 at 0x000003220000
    Bad eraseblock 402 at 0x000003240000
    Bad eraseblock 403 at 0x000003260000
    Bad eraseblock 404 at 0x000003280000
    Bad eraseblock 405 at 0x0000032a0000
    Bad eraseblock 406 at 0x0000032c0000
    Bad eraseblock 407 at 0x0000032e0000
    Bad eraseblock 408 at 0x000003300000
    Bad eraseblock 409 at 0x000003320000
    Bad eraseblock 410 at 0x000003340000
    Bad eraseblock 411 at 0x000003360000
    Bad eraseblock 412 at 0x000003380000
    [**    ] (1 of 2) A start job is running for dev-ttyS2.device (33s / 1min 30s)B0
    Bad eraseblock 414 at 0x0000033c0000
    Bad eraseblock 415 at 0x0000033e0000
    Bad eraseblock 416 at 0x000003400000
    Bad eraseblock 417 at 0x000003420000
    Bad eraseblock 418 at 0x000003440000
    Bad eraseblock 419 at 0x000003460000
    Bad eraseblock 420 at 0x000003480000
    Bad eraseblock 421 at 0x0000034a0000
    Bad eraseblock 422 at 0x0000034c0000
    Bad eraseblock 423 at 0x0000034e0000
    Bad eraseblock 424 at 0x000003500000
    Bad eraseblock 425 at 0x000003520000
    Bad eraseblock 426 at 0x000003540000
    Bad eraseblock 427 at 0x000003560000
    Bad eraseblock 428 at 0x000003580000
    Bad eraseblock 429 at 0x0000035a0000
    Bad eraseblock 430 at 0x0000035c0000
    Bad eraseblock 431 at 0x0000035e0000
    Bad eraseblock 432 at 0x000003600000
    Bad eraseblock 433 at 0x000003620000
    Bad eraseblock 434 at 0x000003640000
    Bad eraseblock 435 at 0x000003660000
    Bad eraseblock 436 at 0x000003680000
    Bad eraseblock 437 at 0x0000036a0000
    Bad eraseblock 438 at 0x0000036c0000
    Bad eraseblock 439 at 0x0000036e0000
    Bad eraseblock 440 at 0x000003700000
    Bad eraseblock 441 at 0x000003720000
    Bad eraseblock 442 at 0x000003740000
    Bad eraseblock 443 at 0x000003760000
    Bad eraseblock 444 at 0x000003780000
    Bad eraseblock 445 at 0x0000037a0000
    Bad eraseblock 446 at 0x0000037c0000
    Bad eraseblock 447 at 0x0000037e0000
    Bad eraseblock 448 at 0x000003800000
    Bad eraseblock 449 at 0x000003820000
    Bad eraseblock 450 at 0x000003840000
    Bad eraseblock 451 at 0x000003860000
    Bad eraseblock 452 at 0x000003880000
    Bad eraseblock 453 at 0x0000038a0000
    Bad eraseblock 454 at 0x0000038c0000
    Bad eraseblock 455 at 0x0000038e0000
    Bad eraseblock 456 at 0x000003900000
    Bad eraseblock 457 at 0x000003920000
    Bad eraseblock 458 at 0x000003940000
    Bad eraseblock 459 at 0x000003960000
    Bad eraseblock 460 at 0x000003980000
    Bad eraseblock 461 at 0x0000039a0000
    Bad eraseblock 462 at 0x0000039c0000
    Bad eraseblock 463 at 0x0000039e0000
    Bad eraseblock 464 at 0x000003a00000
    Bad eraseblock 465 at 0x000003a20000
    Bad eraseblock 466 at 0x000003a40000
    Bad eraseblock 467 at 0x000003a60000
    Bad eraseblock 468 at 0x000003a80000
    Bad eraseblock 469 at 0x000003aa0000
    Bad eraseblock 470 at 0x000003ac0000
    Bad eraseblock 471 at 0x000003ae0000
    Bad eraseblock 472 at 0x000003b00000
    Bad eraseblock 473 at 0x000003b20000
    Bad eraseblock 474 at 0x000003b40000
    Bad eraseblock 475 at 0x000003b60000
    Bad eraseblock 476 at 0x000003b80000
    Bad eraseblock 477 at 0x000003ba0000
    Bad eraseblock 478 at 0x000003bc0000
    Bad eraseblock 479 at 0x000003be0000
    Bad eraseblock 480 at 0x000003c00000
    Bad eraseblock 481 at 0x000003c20000
    Bad eraseblock 482 at 0x000003c40000
    Bad eraseblock 483 at 0x000003c60000
    Bad eraseblock 484 at 0x000003c80000
    Bad eraseblock 485 at 0x000003ca0000
    Bad eraseblock 486 at 0x000003cc0000
    Bad eraseblock 487 at 0x000003ce0000
    Bad eraseblock 488 at 0x000003d00000
    Bad eraseblock 489 at 0x000003d20000
    Bad eraseblock 490 at 0x000003d40000
    Bad eraseblock 491 at 0x000003d60000
    Bad eraseblock 492 at 0x000003d80000
    Bad eraseblock 493 at 0x000003da0000
    Bad eraseblock 494 at 0x000003dc0000
    Bad eraseblock 495 at 0x000003de0000
    Bad eraseblock 496 at 0x000003e00000
    Bad eraseblock 497 at 0x000003e20000
    Bad eraseblock 498 at 0x000003e40000
    Bad eraseblock 499 at 0x000003e60000
    Bad eraseblock 500 at 0x000003e80000
    Bad eraseblock 501 at 0x000003ea0000
    Bad eraseblock 502 at 0x000003ec0000
    Bad eraseblock 503 at 0x000003ee0000
    Bad eraseblock 504 at 0x000003f00000
    Bad eraseblock 505 at 0x000003f20000
    Bad eraseblock 506 at 0x000003f40000
    [  OK  ] Found device /dev/ttyS2.
    Bad eraseblock 507 at 0x000003f60000
    Bad eraseblock 508 at 0x000003f80000
    Bad eraseblock 509 at 0x000003fa0000
    Bad eraseblock 510 at 0x000003fc0000
    Bad eraseblock 511 at 0x000003fe0000
    Bad eraseblock 512 at 0x000004000000
    Bad eraseblock 513 at 0x000004020000
    Bad eraseblock 514 at 0x000004040000
    Bad eraseblock 515 at 0x000004060000
    Bad eraseblock 516 at 0x000004080000
    Bad eraseblock 517 at 0x0000040a0000
    Bad eraseblock 518 at 0x0000040c0000
    Bad eraseblock 519 at 0x0000040e0000
    Bad eraseblock 520 at 0x000004100000
    Bad eraseblock 521 at 0x000004120000
    Bad eraseblock 522 at 0x000004140000
    Bad eraseblock 523 at 0x000004160000
    Bad eraseblock 524 at 0x000004180000
    Bad eraseblock 525 at 0x0000041a0000
    Bad eraseblock 526 at 0x0000041c0000
    Bad eraseblock 527 at 0x0000041e0000
    Bad eraseblock 528 at 0x000004200000
    Bad eraseblock 529 at 0x000004220000
    Bad eraseblock 530 at 0x000004240000
    Bad eraseblock 531 at 0x000004260000
    Bad eraseblock 532 at 0x000004280000
    Bad eraseblock 533 at 0x0000042a0000
    Bad eraseblock 534 at 0x0000042c0000
    Bad eraseblock 535 at 0x0000042e0000
    Bad eraseblock 536 at 0x000004300000
    Bad eraseblock 537 at 0x000004320000
    Bad eraseblock 538 at 0x000004340000
    Bad eraseblock 539 at 0x000004360000
    Bad eraseblock 540 at 0x000004380000
    Bad eraseblock 541 at 0x0000043a0000
    Bad eraseblock 542 at 0x0000043c0000
    Bad eraseblock 543 at 0x0000043e0000
    Bad eraseblock 544 at 0x000004400000
    Bad eraseblock 545 at 0x000004420000
    Bad eraseblock 546 at 0x000004440000
    Bad eraseblock 547 at 0x000004460000
    Bad eraseblock 548 at 0x000004480000
    Bad eraseblock 549 at 0x0000044a0000
    Bad eraseblock 550 at 0x0000044c0000
    Bad eraseblock 551 at 0x0000044e0000
    Bad eraseblock 552 at 0x000004500000
    Bad eraseblock 553 at 0x000004520000
    Bad eraseblock 554 at 0x000004540000
    Bad eraseblock 555 at 0x000004560000
    Bad eraseblock 556 at 0x000004580000
    Bad eraseblock 557 at 0x0000045a0000
    Bad eraseblock 558 at 0x0000045c0000
    Bad eraseblock 559 at 0x0000045e0000
    Bad eraseblock 560 at 0x000004600000
    Bad eraseblock 561 at 0x000004620000
    Bad eraseblock 562 at 0x000004640000
    Bad eraseblock 563 at 0x000004660000
    Bad eraseblock 564 at 0x000004680000
    Bad eraseblock 565 at 0x0000046a0000
    Bad eraseblock 566 at 0x0000046c0000
    Bad eraseblock 567 at 0x0000046e0000
    Bad eraseblock 568 at 0x000004700000
    Bad eraseblock 569 at 0x000004720000
    Bad eraseblock 570 at 0x000004740000
    Bad eraseblock 571 at 0x000004760000
    Bad eraseblock 572 at 0x000004780000
    Bad eraseblock 573 at 0x0000047a0000
    Bad eraseblock 574 at 0x0000047c0000
    Bad eraseblock 575 at 0x0000047e0000
    Bad eraseblock 576 at 0x000004800000
    Bad eraseblock 577 at 0x000004820000
    Bad eraseblock 578 at 0x000004840000
    Bad eraseblock 579 at 0x000004860000
    Bad eraseblock 580 at 0x000004880000
    Bad eraseblock 581 at 0x0000048a0000
    Bad eraseblock 582 at 0x0000048c0000
    Bad eraseblock 583 at 0x0000048e0000
    Bad eraseblock 584 at 0x000004900000
    Bad eraseblock 585 at 0x000004920000
    Bad eraseblock 586 at 0x000004940000
    Bad eraseblock 587 at 0x000004960000
    Bad eraseblock 588 at 0x000004980000
    Bad eraseblock 589 at 0x0000049a0000
    Bad eraseblock 590 at 0x0000049c0000
    Bad eraseblock 591 at 0x0000049e0000
    Bad eraseblock 592 at 0x000004a00000
    Bad eraseblock 593 at 0x000004a20000
    Bad eraseblock 594 at 0x000004a40000
    Bad eraseblock 595 at 0x000004a60000
    Bad eraseblock 596 at 0x000004a80000
    Bad eraseblock 597 at 0x000004aa0000
    Bad eraseblock 598 at 0x000004ac0000
    Bad eraseblock 599 at 0x000004ae0000
    Bad eraseblock 600 at 0x000004b00000
    Bad eraseblock 601 at 0x000004b20000
    Bad eraseblock 602 at 0x000004b40000
    Bad eraseblock 603 at 0x000004b60000
    Bad eraseblock 604 at 0x000004b80000
    Bad eraseblock 605 at 0x000004ba0000
    Bad eraseblock 606 at 0x000004bc0000
    Bad eraseblock 607 at 0x000004be0000
    Bad eraseblock 608 at 0x000004c00000
    Bad eraseblock 609 at 0x000004c20000
    Bad eraseblock 610 at 0x000004c40000
    Bad eraseblock 611 at 0x000004c60000
    Bad eraseblock 612 at 0x000004c80000
    Bad eraseblock 613 at 0x000004ca0000
    Bad eraseblock 614 at 0x000004cc0000
    Bad eraseblock 615 at 0x000004ce0000
    Bad eraseblock 616 at 0x000004d00000
    Bad eraseblock 617 at 0x000004d20000
    Bad eraseblock 618 at 0x000004d40000
    Bad eraseblock 619 at 0x000004d60000
    Bad eraseblock 620 at 0x000004d80000
    Bad eraseblock 621 at 0x000004da0000
    Bad eraseblock 622 at 0x000004dc0000
    Bad eraseblock 623 at 0x000004de0000
    Bad eraseblock 624 at 0x000004e00000
    Bad eraseblock 625 at 0x000004e20000
    Bad eraseblock 626 at 0x000004e40000
    Bad eraseblock 627 at 0x000004e60000
    Bad eraseblock 628 at 0x000004e80000
    Bad eraseblock 629 at 0x000004ea0000
    Bad eraseblock 630 at 0x000004ec0000
    Bad eraseblock 631 at 0x000004ee0000
    Bad eraseblock 632 at 0x000004f00000
    Bad eraseblock 633 at 0x000004f20000
    Bad eraseblock 634 at 0x000004f40000
    Bad eraseblock 635 at 0x000004f60000
    Bad eraseblock 636 at 0x000004f80000
    Bad eraseblock 637 at 0x000004fa0000
    Bad eraseblock 638 at 0x000004fc0000
    Bad eraseblock 639 at 0x000004fe0000
    Bad eraseblock 640 at 0x000005000000
    Bad eraseblock 641 at 0x000005020000
    Bad eraseblock 642 at 0x000005040000
    Bad eraseblock 643 at 0x000005060000
    Bad eraseblock 644 at 0x000005080000
    Bad eraseblock 645 at 0x0000050a0000
    Bad eraseblock 646 at 0x0000050c0000
    Bad eraseblock 647 at 0x0000050e0000
    Bad eraseblock 648 at 0x000005100000
    Bad eraseblock 649 at 0x000005120000
    Bad eraseblock 650 at 0x000005140000
    Bad eraseblock 651 at 0x000005160000
    Bad eraseblock 652 at 0x000005180000
    Bad eraseblock 653 at 0x0000051a0000
    Bad eraseblock 654 at 0x0000051c0000
    Bad eraseblock 655 at 0x0000051e0000
    Bad eraseblock 656 at 0x000005200000
    Bad eraseblock 657 at 0x000005220000
    Bad eraseblock 658 at 0x000005240000
    Bad eraseblock 659 at 0x000005260000
    Bad eraseblock 660 at 0x000005280000
    Bad eraseblock 661 at 0x0000052a0000
    Bad eraseblock 662 at 0x0000052c0000
    Bad eraseblock 663 at 0x0000052e0000
    Bad eraseblock 664 at 0x000005300000
    Bad eraseblock 665 at 0x000005320000
    Bad eraseblock 666 at 0x000005340000
    Bad eraseblock 667 at 0x000005360000
    Bad eraseblock 668 at 0x000005380000
    Bad eraseblock 669 at 0x0000053a0000
    Bad eraseblock 670 at 0x0000053c0000
    Bad eraseblock 671 at 0x0000053e0000
    Bad eraseblock 672 at 0x000005400000
    Bad eraseblock 673 at 0x000005420000
    Bad eraseblock 674 at 0x000005440000
    Bad eraseblock 675 at 0x000005460000
    Bad eraseblock 676 at 0x000005480000
    Bad eraseblock 677 at 0x0000054a0000
    Bad eraseblock 678 at 0x0000054c0000
    Bad eraseblock 679 at 0x0000054e0000
    Bad eraseblock 680 at 0x000005500000
    Bad eraseblock 681 at 0x000005520000
    Bad eraseblock 682 at 0x000005540000
    Bad eraseblock 683 at 0x000005560000
    Bad eraseblock 684 at 0x000005580000
    Bad eraseblock 685 at 0x0000055a0000
    Bad eraseblock 686 at 0x0000055c0000
    Bad eraseblock 687 at 0x0000055e0000
    Bad eraseblock 688 at 0x000005600000
    Bad eraseblock 689 at 0x000005620000
    Bad eraseblock 690 at 0x000005640000
    Bad eraseblock 691 at 0x000005660000
    Bad eraseblock 692 at 0x000005680000
    Bad eraseblock 693 at 0x0000056a0000
    Bad eraseblock 694 at 0x0000056c0000
    Bad eraseblock 695 at 0x0000056e0000
    Bad eraseblock 696 at 0x000005700000
    Bad eraseblock 697 at 0x000005720000
    Bad eraseblock 698 at 0x000005740000
    Bad eraseblock 699 at 0x000005760000
    Bad eraseblock 700 at 0x000005780000
    Bad eraseblock 701 at 0x0000057a0000
    Bad eraseblock 702 at 0x0000057c0000
    Bad eraseblock 703 at 0x0000057e0000
    Bad eraseblock 704 at 0x000005800000
    Bad eraseblock 705 at 0x000005820000
    Bad eraseblock 706 at 0x000005840000
    Bad eraseblock 707 at 0x000005860000
    Bad eraseblock 708 at 0x000005880000
    Bad eraseblock 709 at 0x0000058a0000
    Bad eraseblock 710 at 0x0000058c0000
    Bad eraseblock 711 at 0x0000058e0000
    Bad eraseblock 712 at 0x000005900000
    Bad eraseblock 713 at 0x000005920000
    Bad eraseblock 714 at 0x000005940000
    Bad eraseblock 715 at 0x000005960000
    Bad eraseblock 716 at 0x000005980000
    Bad eraseblock 717 at 0x0000059a0000
    Bad eraseblock 718 at 0x0000059c0000
    Bad eraseblock 719 at 0x0000059e0000
    Bad eraseblock 720 at 0x000005a00000
    Bad eraseblock 721 at 0x000005a20000
    Bad eraseblock 722 at 0x000005a40000
    Bad eraseblock 723 at 0x000005a60000
    Bad eraseblock 724 at 0x000005a80000
    Bad eraseblock 725 at 0x000005aa0000
    Bad eraseblock 726 at 0x000005ac0000
    Bad eraseblock 727 at 0x000005ae0000
    Bad eraseblock 728 at 0x000005b00000
    Bad eraseblock 729 at 0x000005b20000
    Bad eraseblock 730 at 0x000005b40000
    Bad eraseblock 731 at 0x000005b60000
    Bad eraseblock 732 at 0x000005b80000
    Bad eraseblock 733 at 0x000005ba0000
    Bad eraseblock 734 at 0x000005bc0000
    Bad eraseblock 735 at 0x000005be0000
    Bad eraseblock 736 at 0x000005c00000
    Bad eraseblock 737 at 0x000005c20000
    Bad eraseblock 738 at 0x000005c40000
    Bad eraseblock 739 at 0x000005c60000
    Bad eraseblock 740 at 0x000005c80000
    Bad eraseblock 741 at 0x000005ca0000
    Bad eraseblock 742 at 0x000005cc0000
    Bad eraseblock 743 at 0x000005ce0000
    Bad eraseblock 744 at 0x000005d00000
    Bad eraseblock 745 at 0x000005d20000
    Bad eraseblock 746 at 0x000005d40000
    Bad eraseblock 747 at 0x000005d60000
    Bad eraseblock 748 at 0x000005d80000
    Bad eraseblock 749 at 0x000005da0000
    Bad eraseblock 750 at 0x000005dc0000
    Bad eraseblock 751 at 0x000005de0000
    Bad eraseblock 752 at 0x000005e00000
    Bad eraseblock 753 at 0x000005e20000
    Bad eraseblock 754 at 0x000005e40000
    Bad eraseblock 755 at 0x000005e60000
    Bad eraseblock 756 at 0x000005e80000
    Bad eraseblock 757 at 0x000005ea0000
    Bad eraseblock 758 at 0x000005ec0000
    Bad eraseblock 759 at 0x000005ee0000
    Bad eraseblock 760 at 0x000005f00000
    Bad eraseblock 761 at 0x000005f20000
    Bad eraseblock 762 at 0x000005f40000
    Bad eraseblock 763 at 0x000005f60000
    Bad eraseblock 764 at 0x000005f80000
    Bad eraseblock 765 at 0x000005fa0000
    Bad eraseblock 766 at 0x000005fc0000
    Bad eraseblock 767 at 0x000005fe0000
    NET: Registered protocol family 45
    Bad eraseblock 768 at 0x000006000000
    Bad eraseblock 769 at 0x000006020000
    Bad eraseblock 770 at 0x000006040000
    Bad eraseblock 771 at 0x000006060000
    Bad eraseblock 772 at 0x000006080000
    Bad eraseblock 773 at 0x0000060a0000
    Bad eraseblock 774 at 0x0000060c0000
    Bad eraseblock 775 at 0x0000060e0000
    Bad eraseblock 776 at 0x000006100000
    Bad eraseblock 777 at 0x000006120000
    Bad eraseblock 778 at 0x000006140000
    Bad eraseblock 779 at 0x000006160000
    Bad eraseblock 780 at 0x000006180000
    Bad eraseblock 781 at 0x0000061a0000
    Bad eraseblock 782 at 0x0000061c0000
    Bad eraseblock 783 at 0x0000061e0000
    Bad eraseblock 784 at 0x000006200000
    Bad eraseblock 785 at 0x000006220000
    Bad eraseblock 786 at 0x000006240000
    Bad eraseblock 787 at 0x000006260000
    Bad eraseblock 788 at 0x000006280000
    Bad eraseblock 789 at 0x0000062a0000
    Bad eraseblock 790 at 0x0000062c0000
    Bad eraseblock 791 at 0x0000062e0000
    Bad eraseblock 792 at 0x000006300000
    Bad eraseblock 793 at 0x000006320000
    Bad eraseblock 794 at 0x000006340000
    Bad eraseblock 795 at 0x000006360000
    Bad eraseblock 796 at 0x000006380000
    Bad eraseblock 797 at 0x0000063a0000
    Bad eraseblock 798 at 0x0000063c0000
    Bad eraseblock 799 at 0x0000063e0000
    Bad eraseblock 800 at 0x000006400000
    Bad eraseblock 801 at 0x000006420000
    Bad eraseblock 802 at 0x000006440000
    Bad eraseblock 803 at 0x000006460000
    Bad eraseblock 804 at 0x000006480000
    Bad eraseblock 805 at 0x0000064a0000
    Bad eraseblock 806 at 0x0000064c0000
    Bad eraseblock 807 at 0x0000064e0000
    Bad eraseblock 808 at 0x000006500000
    Bad eraseblock 809 at 0x000006520000
    Bad eraseblock 810 at 0x000006540000
    Bad eraseblock 811 at 0x000006560000
    Bad eraseblock 812 at 0x000006580000
    Bad eraseblock 813 at 0x0000065a0000
    Bad eraseblock 814 at 0x0000065c0000
    Bad eraseblock 815 at 0x0000065e0000
    Bad eraseblock 816 at 0x000006600000
    Bad eraseblock 817 at 0x000006620000
    Bad eraseblock 818 at 0x000006640000
    Bad eraseblock 819 at 0x000006660000
    Bad eraseblock 820 at 0x000006680000
    Bad eraseblock 821 at 0x0000066a0000
    Bad eraseblock 822 at 0x0000066c0000
    Bad eraseblock 823 at 0x0000066e0000
    Bad eraseblock 824 at 0x000006700000
    Bad eraseblock 825 at 0x000006720000
    Bad eraseblock 826 at 0x000006740000
    Bad eraseblock 827 at 0x000006760000
    Bad eraseblock 828 at 0x000006780000
    Bad eraseblock 829 at 0x0000067a0000
    Bad eraseblock 830 at 0x0000067c0000
    Bad eraseblock 831 at 0x0000067e0000
    [***   ] A start jBad eraseblock 832 at 0x000006800000
    ob is running for Wait for��… to be Configured (45s / no limit)Bad eraseblock 80
    Bad eraseblock 834 at 0x000006840000
    Bad eraseblock 835 at 0x000006860000
    Bad eraseblock 836 at 0x000006880000
    Bad eraseblock 837 at 0x0000068a0000
    Bad eraseblock 838 at 0x0000068c0000
    Bad eraseblock 839 at 0x0000068e0000
    Bad eraseblock 840 at 0x000006900000
    Bad eraseblock 841 at 0x000006920000
    Bad eraseblock 842 at 0x000006940000
    Bad eraseblock 843 at 0x000006960000
    Bad eraseblock 844 at 0x000006980000
    Bad eraseblock 845 at 0x0000069a0000
    Bad eraseblock 846 at 0x0000069c0000
    Bad eraseblock 847 at 0x0000069e0000
    Bad eraseblock 848 at 0x000006a00000
    Bad eraseblock 849 at 0x000006a20000
    Bad eraseblock 850 at 0x000006a40000
    Bad eraseblock 851 at 0x000006a60000
    Bad eraseblock 852 at 0x000006a80000
    Bad eraseblock 853 at 0x000006aa0000
    Bad eraseblock 854 at 0x000006ac0000
    Bad eraseblock 855 at 0x000006ae0000
    Bad eraseblock 856 at 0x000006b00000
    Bad eraseblock 857 at 0x000006b20000
    Bad eraseblock 858 at 0x000006b40000
    Bad eraseblock 859 at 0x000006b60000
    Bad eraseblock 860 at 0x000006b80000
    Bad eraseblock 861 at 0x000006ba0000
    Bad eraseblock 862 at 0x000006bc0000
    Bad eraseblock 863 at 0x000006be0000
    Bad eraseblock 864 at 0x000006c00000
    Bad eraseblock 865 at 0x000006c20000
    Bad eraseblock 866 at 0x000006c40000
    Bad eraseblock 867 at 0x000006c60000
    Bad eraseblock 868 at 0x000006c80000
    Bad eraseblock 869 at 0x000006ca0000
    Bad eraseblock 870 at 0x000006cc0000
    Bad eraseblock 871 at 0x000006ce0000
    Bad eraseblock 872 at 0x000006d00000
    Bad eraseblock 873 at 0x000006d20000
    Bad eraseblock 874 at 0x000006d40000
    Bad eraseblock 875 at 0x000006d60000
    Bad eraseblock 876 at 0x000006d80000
    Bad eraseblock 877 at 0x000006da0000
    Bad eraseblock 878 at 0x000006dc0000
    Bad eraseblock 879 at 0x000006de0000
    Bad eraseblock 880 at 0x000006e00000
    Bad eraseblock 881 at 0x000006e20000
    Bad eraseblock 882 at 0x000006e40000
    Bad eraseblock 883 at 0x000006e60000
    Bad eraseblock 884 at 0x000006e80000
    Bad eraseblock 885 at 0x000006ea0000
    Bad eraseblock 886 at 0x000006ec0000
    Bad eraseblock 887 at 0x000006ee0000
    Bad eraseblock 888 at 0x000006f00000
    Bad eraseblock 889 at 0x000006f20000
    Bad eraseblock 890 at 0x000006f40000
    Bad eraseblock 891 at 0x000006f60000
    Bad eraseblock 892 at 0x000006f80000
    Bad eraseblock 893 at 0x000006fa0000
    Bad eraseblock 894 at 0x000006fc0000
    Bad eraseblock 895 at 0x000006fe0000
    Bad eraseblock 896 at 0x000007000000
    Bad eraseblock 897 at 0x000007020000
    Bad eraseblock 898 at 0x000007040000
    Bad eraseblock 899 at 0x000007060000
    Bad eraseblock 900 at 0x000007080000
    Bad eraseblock 901 at 0x0000070a0000
    Bad eraseblock 902 at 0x0000070c0000
    Bad eraseblock 903 at 0x0000070e0000
    Bad eraseblock 904 at 0x000007100000
    Bad eraseblock 905 at 0x000007120000
    Bad eraseblock 906 at 0x000007140000
    Bad eraseblock 907 at 0x000007160000
    Bad eraseblock 908 at 0x000007180000
    Bad eraseblock 909 at 0x0000071a0000
    Bad eraseblock 910 at 0x0000071c0000
    Bad eraseblock 911 at 0x0000071e0000
    Bad eraseblock 912 at 0x000007200000
    Bad eraseblock 913 at 0x000007220000
    Bad eraseblock 914 at 0x000007240000
    Bad eraseblock 915 at 0x000007260000
    Bad eraseblock 916 at 0x000007280000
    Bad eraseblock 917 at 0x0000072a0000
    Bad eraseblock 918 at 0x0000072c0000
    Bad eraseblock 919 at 0x0000072e0000
    Bad eraseblock 920 at 0x000007300000
    Bad eraseblock 921 at 0x000007320000
    Bad eraseblock 922 at 0x000007340000
    Bad eraseblock 923 at 0x000007360000
    Bad eraseblock 924 at 0x000007380000
    Bad eraseblock 925 at 0x0000073a0000
    Bad eraseblock 926 at 0x0000073c0000
    Bad eraseblock 927 at 0x0000073e0000
    Bad eraseblock 928 at 0x000007400000
    Bad eraseblock 929 at 0x000007420000
    Bad eraseblock 930 at 0x000007440000
    Bad eraseblock 931 at 0x000007460000
    Bad eraseblock 932 at 0x000007480000
    Bad eraseblock 933 at 0x0000074a0000
    Bad eraseblock 934 at 0x0000074c0000
    Bad eraseblock 935 at 0x0000074e0000
    Bad eraseblock 936 at 0x000007500000
    Bad eraseblock 937 at 0x000007520000
    Bad eraseblock 938 at 0x000007540000
    Bad eraseblock 939 at 0x000007560000
    Bad eraseblock 940 at 0x000007580000
    Bad eraseblock 941 at 0x0000075a0000
    Bad eraseblock 942 at 0x0000075c0000
    Bad eraseblock 943 at 0x0000075e0000
    Bad eraseblock 944 at 0x000007600000
    Bad eraseblock 945 at 0x000007620000
    Bad eraseblock 946 at 0x000007640000
    Bad eraseblock 947 at 0x000007660000
    Bad eraseblock 948 at 0x000007680000
    Bad eraseblock 949 at 0x0000076a0000
    Bad eraseblock 950 at 0x0000076c0000
    Bad eraseblock 951 at 0x0000076e0000
    Bad eraseblock 952 at 0x000007700000
    Bad eraseblock 953 at 0x000007720000
    Bad eraseblock 954 at 0x000007740000
    Bad eraseblock 955 at 0x000007760000
    Bad eraseblock 956 at 0x000007780000
    Bad eraseblock 957 at 0x0000077a0000
    Bad eraseblock 958 at 0x0000077c0000
    Bad eraseblock 959 at 0x0000077e0000
    Bad eraseblock 960 at 0x000007800000
    Bad eraseblock 961 at 0x000007820000
    Bad eraseblock 962 at 0x000007840000
    Bad eraseblock 963 at 0x000007860000
    Bad eraseblock 964 at 0x000007880000
    Bad eraseblock 965 at 0x0000078a0000
    Bad eraseblock 966 at 0x0000078c0000
    Bad eraseblock 967 at 0x0000078e0000
    Bad eraseblock 968 at 0x000007900000
    Bad eraseblock 969 at 0x000007920000
    Bad eraseblock 970 at 0x000007940000
    Bad eraseblock 971 at 0x000007960000
    Bad eraseblock 972 at 0x000007980000
    Bad eraseblock 973 at 0x0000079a0000
    Bad eraseblock 974 at 0x0000079c0000
    Bad eraseblock 975 at 0x0000079e0000
    Bad eraseblock 976 at 0x000007a00000
    Bad eraseblock 977 at 0x000007a20000
    Bad eraseblock 978 at 0x000007a40000
    Bad eraseblock 979 at 0x000007a60000
    Bad eraseblock 980 at 0x000007a80000
    Bad eraseblock 981 at 0x000007aa0000
    Bad eraseblock 982 at 0x000007ac0000
    Bad eraseblock 983 at 0x000007ae0000
    Bad eraseblock 984 at 0x000007b00000
    Bad eraseblock 985 at 0x000007b20000
    Bad eraseblock 986 at 0x000007b40000
    Bad eraseblock 987 at 0x000007b60000
    Bad eraseblock 988 at 0x000007b80000
    Bad eraseblock 989 at 0x000007ba0000
    Bad eraseblock 990 at 0x000007bc0000
    Bad eraseblock 991 at 0x000007be0000
    Bad eraseblock 992 at 0x000007c00000
    Bad eraseblock 993 at 0x000007c20000
    Bad eraseblock 994 at 0x000007c40000
    Bad eraseblock 995 at 0x000007c60000
    Bad eraseblock 996 at 0x000007c80000
    Bad eraseblock 997 at 0x000007ca0000
    Bad eraseblock 998 at 0x000007cc0000
    Bad eraseblock 999 at 0x000007ce0000
    Bad eraseblock 1000 at 0x000007d00000
    Bad eraseblock 1001 at 0x000007d20000
    Bad eraseblock 1002 at 0x000007d40000
    Bad eraseblock 1003 at 0x000007d60000
    Bad eraseblock 1004 at 0x000007d80000
    Bad eraseblock 1005 at 0x000007da0000
    Bad eraseblock 1006 at 0x000007dc0000
    Bad eraseblock 1007 at 0x000007de0000
    Bad eraseblock 1008 at 0x000007e00000
    Bad eraseblock 1009 at 0x000007e20000
    Bad eraseblock 1010 at 0x000007e40000
    Bad eraseblock 1011 at 0x000007e60000
    Bad eraseblock 1012 at 0x000007e80000
    Bad eraseblock 1013 at 0x000007ea0000
    Bad eraseblock 1014 at 0x000007ec0000
    Bad eraseblock 1015 at 0x000007ee0000
    Bad eraseblock 1016 at 0x000007f00000
    Bad eraseblock 1017 at 0x000007f20000
    Bad eraseblock 1018 at 0x000007f40000
    Bad eraseblock 1019 at 0x000007f60000
    Bad eraseblock 1020 at 0x000007f80000
    Bad eraseblock 1021 at 0x000007fa0000
    Bad eraseblock 1022 at 0x000007fc0000
    Bad eraseblock 1023 at 0x000007fe0000
    Bad eraseblock 1024 at 0x000008000000
    Bad eraseblock 1025 at 0x000008020000
    Bad eraseblock 1026 at 0x000008040000
    Bad eraseblock 1027 at 0x000008060000
    Bad eraseblock 1028 at 0x000008080000
    Bad eraseblock 1029 at 0x0000080a0000
    Bad eraseblock 1030 at 0x0000080c0000
    Bad eraseblock 1031 at 0x0000080e0000
    Bad eraseblock 1032 at 0x000008100000
    Bad eraseblock 1033 at 0x000008120000
    Bad eraseblock 1034 at 0x000008140000
    Bad eraseblock 1035 at 0x000008160000
    Bad eraseblock 1036 at 0x000008180000
    Bad eraseblock 1037 at 0x0000081a0000
    Bad eraseblock 1038 at 0x0000081c0000
    Bad eraseblock 1039 at 0x0000081e0000
    Bad eraseblock 1040 at 0x000008200000
    Bad eraseblock 1041 at 0x000008220000
    Bad eraseblock 1042 at 0x000008240000
    Bad eraseblock 1043 at 0x000008260000
    Bad eraseblock 1044 at 0x000008280000
    Bad eraseblock 1045 at 0x0000082a0000
    Bad eraseblock 1046 at 0x0000082c0000
    Bad eraseblock 1047 at 0x0000082e0000
    Bad eraseblock 1048 at 0x000008300000
    Bad eraseblock 1049 at 0x000008320000
    Bad eraseblock 1050 at 0x000008340000
    Bad eraseblock 1051 at 0x000008360000
    Bad eraseblock 1052 at 0x000008380000
    Bad eraseblock 1053 at 0x0000083a0000
    Bad eraseblock 1054 at 0x0000083c0000
    Bad eraseblock 1055 at 0x0000083e0000
    Bad eraseblock 1056 at 0x000008400000
    Bad eraseblock 1057 at 0x000008420000
    Bad eraseblock 1058 at 0x000008440000
    Bad eraseblock 1059 at 0x000008460000
    Bad eraseblock 1060 at 0x000008480000
    Bad eraseblock 1061 at 0x0000084a0000
    Bad eraseblock 1062 at 0x0000084c0000
    Bad eraseblock 1063 at 0x0000084e0000
    Bad eraseblock 1064 at 0x000008500000
    Bad eraseblock 1065 at 0x000008520000
    Bad eraseblock 1066 at 0x000008540000
    Bad eraseblock 1067 at 0x000008560000
    Bad eraseblock 1068 at 0x000008580000
    Bad eraseblock 1069 at 0x0000085a0000
    Bad eraseblock 1070 at 0x0000085c0000
    Bad eraseblock 1071 at 0x0000085e0000
    Bad eraseblock 1072 at 0x000008600000
    Bad eraseblock 1073 at 0x000008620000
    Bad eraseblock 1074 at 0x000008640000
    Bad eraseblock 1075 at 0x000008660000
    Bad eraseblock 1076 at 0x000008680000
    Bad eraseblock 1077 at 0x0000086a0000
    Bad eraseblock 1078 at 0x0000086c0000
    Bad eraseblock 1079 at 0x0000086e0000
    Bad eraseblock 1080 at 0x000008700000
    Bad eraseblock 1081 at 0x000008720000
    Bad eraseblock 1082 at 0x000008740000
    Bad eraseblock 1083 at 0x000008760000
    Bad eraseblock 1084 at 0x000008780000
    Bad eraseblock 1085 at 0x0000087a0000
    Bad eraseblock 1086 at 0x0000087c0000
    Bad eraseblock 1087 at 0x0000087e0000
    Bad eraseblock 1088 at 0x000008800000
    Bad eraseblock 1089 at 0x000008820000
    Bad eraseblock 1090 at 0x000008840000
    Bad eraseblock 1091 at 0x000008860000
    Bad eraseblock 1092 at 0x000008880000
    Bad eraseblock 1093 at 0x0000088a0000
    Bad eraseblock 1094 at 0x0000088c0000
    Bad eraseblock 1095 at 0x0000088e0000
    Bad eraseblock 1096 at 0x000008900000
    Bad eraseblock 1097 at 0x000008920000
    Bad eraseblock 1098 at 0x000008940000
    Bad eraseblock 1099 at 0x000008960000
    Bad eraseblock 1100 at 0x000008980000
    Bad eraseblock 1101 at 0x0000089a0000
    Bad eraseblock 1102 at 0x0000089c0000
    Bad eraseblock 1103 at 0x0000089e0000
    Bad eraseblock 1104 at 0x000008a00000
    Bad eraseblock 1105 at 0x000008a20000
    Bad eraseblock 1106 at 0x000008a40000
    Bad eraseblock 1107 at 0x000008a60000
    Bad eraseblock 1108 at 0x000008a80000
    Bad eraseblock 1109 at 0x000008aa0000
    Bad eraseblock 1110 at 0x000008ac0000
    Bad eraseblock 1111 at 0x000008ae0000
    Bad eraseblock 1112 at 0x000008b00000
    Bad eraseblock 1113 at 0x000008b20000
    Bad eraseblock 1114 at 0x000008b40000
    Bad eraseblock 1115 at 0x000008b60000
    Bad eraseblock 1116 at 0x000008b80000
    Bad eraseblock 1117 at 0x000008ba0000
    Bad eraseblock 1118 at 0x000008bc0000
    Bad eraseblock 1119 at 0x000008be0000
    Bad eraseblock 1120 at 0x000008c00000
    Bad eraseblock 1121 at 0x000008c20000
    Bad eraseblock 1122 at 0x000008c40000
    Bad eraseblock 1123 at 0x000008c60000
    Bad eraseblock 1124 at 0x000008c80000
    Bad eraseblock 1125 at 0x000008ca0000
    Bad eraseblock 1126 at 0x000008cc0000
    Bad eraseblock 1127 at 0x000008ce0000
    Bad eraseblock 1128 at 0x000008d00000
    Bad eraseblock 1129 at 0x000008d20000
    Bad eraseblock 1130 at 0x000008d40000
    Bad eraseblock 1131 at 0x000008d60000
    Bad eraseblock 1132 at 0x000008d80000
    Bad eraseblock 1133 at 0x000008da0000
    Bad eraseblock 1134 at 0x000008dc0000
    Bad eraseblock 1135 at 0x000008de0000
    Bad eraseblock 1136 at 0x000008e00000
    Bad eraseblock 1137 at 0x000008e20000
    Bad eraseblock 1138 at 0x000008e40000
    [ ***  ] A start job is running for Wait for��… to be Configured (50s / no limi0
    Bad eraseblock 1140 at 0x000008e80000
    Bad eraseblock 1141 at 0x000008ea0000
    Bad eraseblock 1142 at 0x000008ec0000
    Bad eraseblock 1143 at 0x000008ee0000
    Bad eraseblock 1144 at 0x000008f00000
    Bad eraseblock 1145 at 0x000008f20000
    Bad eraseblock 1146 at 0x000008f40000
    Bad eraseblock 1147 at 0x000008f60000
    Bad eraseblock 1148 at 0x000008f80000
    Bad eraseblock 1149 at 0x000008fa0000
    Bad eraseblock 1150 at 0x000008fc0000
    Bad eraseblock 1151 at 0x000008fe0000
    Bad eraseblock 1152 at 0x000009000000
    Bad eraseblock 1153 at 0x000009020000
    Bad eraseblock 1154 at 0x000009040000
    Bad eraseblock 1155 at 0x000009060000
    Bad eraseblock 1156 at 0x000009080000
    Bad eraseblock 1157 at 0x0000090a0000
    Bad eraseblock 1158 at 0x0000090c0000
    Bad eraseblock 1159 at 0x0000090e0000
    Bad eraseblock 1160 at 0x000009100000
    Bad eraseblock 1161 at 0x000009120000
    Bad eraseblock 1162 at 0x000009140000
    Bad eraseblock 1163 at 0x000009160000
    Bad eraseblock 1164 at 0x000009180000
    Bad eraseblock 1165 at 0x0000091a0000
    Bad eraseblock 1166 at 0x0000091c0000
    Bad eraseblock 1167 at 0x0000091e0000
    Bad eraseblock 1168 at 0x000009200000
    Bad eraseblock 1169 at 0x000009220000
    Bad eraseblock 1170 at 0x000009240000
    Bad eraseblock 1171 at 0x000009260000
    Bad eraseblock 1172 at 0x000009280000
    Bad eraseblock 1173 at 0x0000092a0000
    Bad eraseblock 1174 at 0x0000092c0000
    Bad eraseblock 1175 at 0x0000092e0000
    Bad eraseblock 1176 at 0x000009300000
    Bad eraseblock 1177 at 0x000009320000
    Bad eraseblock 1178 at 0x000009340000
    Bad eraseblock 1179 at 0x000009360000
    Bad eraseblock 1180 at 0x000009380000
    Bad eraseblock 1181 at 0x0000093a0000
    Bad eraseblock 1182 at 0x0000093c0000
    Bad eraseblock 1183 at 0x0000093e0000
    Bad eraseblock 1184 at 0x000009400000
    Bad eraseblock 1185 at 0x000009420000
    Bad eraseblock 1186 at 0x000009440000
    Bad eraseblock 1187 at 0x000009460000
    Bad eraseblock 1188 at 0x000009480000
    Bad eraseblock 1189 at 0x0000094a0000
    Bad eraseblock 1190 at 0x0000094c0000
    Bad eraseblock 1191 at 0x0000094e0000
    Bad eraseblock 1192 at 0x000009500000
    Bad eraseblock 1193 at 0x000009520000
    Bad eraseblock 1194 at 0x000009540000
    Bad eraseblock 1195 at 0x000009560000
    Bad eraseblock 1196 at 0x000009580000
    Bad eraseblock 1197 at 0x0000095a0000
    Bad eraseblock 1198 at 0x0000095c0000
    Bad eraseblock 1199 at 0x0000095e0000
    Bad eraseblock 1200 at 0x000009600000
    Bad eraseblock 1201 at 0x000009620000
    Bad eraseblock 1202 at 0x000009640000
    Bad eraseblock 1203 at 0x000009660000
    Bad eraseblock 1204 at 0x000009680000
    Bad eraseblock 1205 at 0x0000096a0000
    Bad eraseblock 1206 at 0x0000096c0000
    Bad eraseblock 1207 at 0x0000096e0000
    Bad eraseblock 1208 at 0x000009700000
    Bad eraseblock 1209 at 0x000009720000
    Bad eraseblock 1210 at 0x000009740000
    Bad eraseblock 1211 at 0x000009760000
    Bad eraseblock 1212 at 0x000009780000
    Bad eraseblock 1213 at 0x0000097a0000
    Bad eraseblock 1214 at 0x0000097c0000
    Bad eraseblock 1215 at 0x0000097e0000
    Bad eraseblock 1216 at 0x000009800000
    Bad eraseblock 1217 at 0x000009820000
    Bad eraseblock 1218 at 0x000009840000
    Bad eraseblock 1219 at 0x000009860000
    Bad eraseblock 1220 at 0x000009880000
    Bad eraseblock 1221 at 0x0000098a0000
    Bad eraseblock 1222 at 0x0000098c0000
    Bad eraseblock 1223 at 0x0000098e0000
    Bad eraseblock 1224 at 0x000009900000
    Bad eraseblock 1225 at 0x000009920000
    Bad eraseblock 1226 at 0x000009940000
    Bad eraseblock 1227 at 0x000009960000
    Bad eraseblock 1228 at 0x000009980000
    Bad eraseblock 1229 at 0x0000099a0000
    Bad eraseblock 1230 at 0x0000099c0000
    Bad eraseblock 1231 at 0x0000099e0000
    Bad eraseblock 1232 at 0x000009a00000
    Bad eraseblock 1233 at 0x000009a20000
    Bad eraseblock 1234 at 0x000009a40000
    Bad eraseblock 1235 at 0x000009a60000
    Bad eraseblock 1236 at 0x000009a80000
    Bad eraseblock 1237 at 0x000009aa0000
    Bad eraseblock 1238 at 0x000009ac0000
    [  *ad eraseblock 1239 at 0x000009ae0000
    ;31m** ] A start job is running fBad eraseblock 1240 at 0x000009b00000
    or Wait for��… to be Configured (51s / no limit)Bad eraseblock 1241 at 0x0000090
    Bad eraseblock 1242 at 0x000009b40000
    Bad eraseblock 1243 at 0x000009b60000
    Bad eraseblock 1244 at 0x000009b80000
    Bad eraseblock 1245 at 0x000009ba0000
    Bad eraseblock 1246 at 0x000009bc0000
    Bad eraseblock 1247 at 0x000009be0000
    Bad eraseblock 1248 at 0x000009c00000
    Bad eraseblock 1249 at 0x000009c20000
    Bad eraseblock 1250 at 0x000009c40000
    Bad eraseblock 1251 at 0x000009c60000
    Bad eraseblock 1252 at 0x000009c80000
    Bad eraseblock 1253 at 0x000009ca0000
    Bad eraseblock 1254 at 0x000009cc0000
    Bad eraseblock 1255 at 0x000009ce0000
    Bad eraseblock 1256 at 0x000009d00000
    Bad eraseblock 1257 at 0x000009d20000
    Bad eraseblock 1258 at 0x000009d40000
    Bad eraseblock 1259 at 0x000009d60000
    Bad eraseblock 1260 at 0x000009d80000
    Bad eraseblock 1261 at 0x000009da0000
    Bad eraseblock 1262 at 0x000009dc0000
    Bad eraseblock 1263 at 0x000009de0000
    Bad eraseblock 1264 at 0x000009e00000
    Bad eraseblock 1265 at 0x000009e20000
    Bad eraseblock 1266 at 0x000009e40000
    Bad eraseblock 1267 at 0x000009e60000
    Bad eraseblock 1268 at 0x000009e80000
    Bad eraseblock 1269 at 0x000009ea0000
    Bad eraseblock 1270 at 0x000009ec0000
    Bad eraseblock 1271 at 0x000009ee0000
    Bad eraseblock 1272 at 0x000009f00000
    Bad eraseblock 1273 at 0x000009f20000
    Bad eraseblock 1274 at 0x000009f40000
    Bad eraseblock 1275 at 0x000009f60000
    Bad eraseblock 1276 at 0x000009f80000
    Bad eraseblock 1277 at 0x000009fa0000
    Bad eraseblock 1278 at 0x000009fc0000
    Bad eraseblock 1279 at 0x000009fe0000
    Bad eraseblock 1280 at 0x00000a000000
    Bad eraseblock 1281 at 0x00000a020000
    Bad eraseblock 1282 at 0x00000a040000
    Bad eraseblock 1283 at 0x00000a060000
    Bad eraseblock 1284 at 0x00000a080000
    Bad eraseblock 1285 at 0x00000a0a0000
    Bad eraseblock 1286 at 0x00000a0c0000
    Bad eraseblock 1287 at 0x00000a0e0000
    Bad eraseblock 1288 at 0x00000a100000
    Bad eraseblock 1289 at 0x00000a120000
    Bad eraseblock 1290 at 0x00000a140000
    Bad eraseblock 1291 at 0x00000a160000
    Bad eraseblock 1292 at 0x00000a180000
    Bad eraseblock 1293 at 0x00000a1a0000
    Bad eraseblock 1294 at 0x00000a1c0000
    Bad eraseblock 1295 at 0x00000a1e0000
    Bad eraseblock 1296 at 0x00000a200000
    Bad eraseblock 1297 at 0x00000a220000
    Bad eraseblock 1298 at 0x00000a240000
    Bad eraseblock 1299 at 0x00000a260000
    Bad eraseblock 1300 at 0x00000a280000
    Bad eraseblock 1301 at 0x00000a2a0000
    Bad eraseblock 1302 at 0x00000a2c0000
    Bad eraseblock 1303 at 0x00000a2e0000
    Bad eraseblock 1304 at 0x00000a300000
    Bad eraseblock 1305 at 0x00000a320000
    Bad eraseblock 1306 at 0x00000a340000
    Bad eraseblock 1307 at 0x00000a360000
    Bad eraseblock 1308 at 0x00000a380000
    Bad eraseblock 1309 at 0x00000a3a0000
    Bad eraseblock 1310 at 0x00000a3c0000
    Bad eraseblock 1311 at 0x00000a3e0000
    Bad eraseblock 1312 at 0x00000a400000
    Bad eraseblock 1313 at 0x00000a420000
    Bad eraseblock 1314 at 0x00000a440000
    Bad eraseblock 1315 at 0x00000a460000
    Bad eraseblock 1316 at 0x00000a480000
    Bad eraseblock 1317 at 0x00000a4a0000
    Bad eraseblock 1318 at 0x00000a4c0000
    Bad eraseblock 1319 at 0x00000a4e0000
    Bad eraseblock 1320 at 0x00000a500000
    Bad eraseblock 1321 at 0x00000a520000
    Bad eraseblock 1322 at 0x00000a540000
    Bad eraseblock 1323 at 0x00000a560000
    Bad eraseblock 1324 at 0x00000a580000
    Bad eraseblock 1325 at 0x00000a5a0000
    Bad eraseblock 1326 at 0x00000a5c0000
    Bad eraseblock 1327 at 0x00000a5e0000
    Bad eraseblock 1328 at 0x00000a600000
    Bad eraseblock 1329 at 0x00000a620000
    Bad eraseblock 1330 at 0x00000a640000
    Bad eraseblock 1331 at 0x00000a660000
    Bad eraseblock 1332 at 0x00000a680000
    Bad eraseblock 1333 at 0x00000a6a0000
    Bad eraseblock 1334 at 0x00000a6c0000
    Bad eraseblock 1335 at 0x00000a6e0000
    Bad eraseblock 1336 at 0x00000a700000
    Bad eraseblock 1337 at 0x00000a720000
    Bad eraseblock 1338 at 0x00000a740000
    Bad eraseblock 1339 at 0x00000a760000
    Bad eraseblock 1340 at 0x00000a780000
    Bad eraseblock 1341 at 0x00000a7a0000
    Bad eraseblock 1342 at 0x00000a7c0000
    Bad eraseblock 1343 at 0x00000a7e0000
    Bad eraseblock 1344 at 0x00000a800000
    Bad eraseblock 1345 at 0x00000a820000
    Bad eraseblock 1346 at 0x00000a840000
    Bad eraseblock 1347 at 0x00000a860000
    Bad eraseblock 1348 at 0x00000a880000
    Bad eraseblock 1349 at 0x00000a8a0000
    Bad eraseblock 1350 at 0x00000a8c0000
    [   *ad eraseblock 1351 at 0x00000a8e0000
    1;31m**] A start job is running fBad eraseblock 1352 at 0x00000a900000
    or Wait for��… to be Configured (52s / no limit)Bad eraseblock 1353 at 0x00000a0
    Bad eraseblock 1354 at 0x00000a940000
    Bad eraseblock 1355 at 0x00000a960000
    Bad eraseblock 1356 at 0x00000a980000
    Bad eraseblock 1357 at 0x00000a9a0000
    Bad eraseblock 1358 at 0x00000a9c0000
    Bad eraseblock 1359 at 0x00000a9e0000
    Bad eraseblock 1360 at 0x00000aa00000
    Bad eraseblock 1361 at 0x00000aa20000
    Bad eraseblock 1362 at 0x00000aa40000
    Bad eraseblock 1363 at 0x00000aa60000
    Bad eraseblock 1364 at 0x00000aa80000
    Bad eraseblock 1365 at 0x00000aaa0000
    Bad eraseblock 1366 at 0x00000aac0000
    Bad eraseblock 1367 at 0x00000aae0000
    Bad eraseblock 1368 at 0x00000ab00000
    Bad eraseblock 1369 at 0x00000ab20000
    Bad eraseblock 1370 at 0x00000ab40000
    Bad eraseblock 1371 at 0x00000ab60000
    Bad eraseblock 1372 at 0x00000ab80000
    Bad eraseblock 1373 at 0x00000aba0000
    Bad eraseblock 1374 at 0x00000abc0000
    Bad eraseblock 1375 at 0x00000abe0000
    Bad eraseblock 1376 at 0x00000ac00000
    Bad eraseblock 1377 at 0x00000ac20000
    Bad eraseblock 1378 at 0x00000ac40000
    Bad eraseblock 1379 at 0x00000ac60000
    Bad eraseblock 1380 at 0x00000ac80000
    Bad eraseblock 1381 at 0x00000aca0000
    Bad eraseblock 1382 at 0x00000acc0000
    Bad eraseblock 1383 at 0x00000ace0000
    Bad eraseblock 1384 at 0x00000ad00000
    Bad eraseblock 1385 at 0x00000ad20000
    Bad eraseblock 1386 at 0x00000ad40000
    Bad eraseblock 1387 at 0x00000ad60000
    Bad eraseblock 1388 at 0x00000ad80000
    Bad eraseblock 1389 at 0x00000ada0000
    Bad eraseblock 1390 at 0x00000adc0000
    Bad eraseblock 1391 at 0x00000ade0000
    Bad eraseblock 1392 at 0x00000ae00000
    Bad eraseblock 1393 at 0x00000ae20000
    Bad eraseblock 1394 at 0x00000ae40000
    Bad eraseblock 1395 at 0x00000ae60000
    Bad eraseblock 1396 at 0x00000ae80000
    Bad eraseblock 1397 at 0x00000aea0000
    Bad eraseblock 1398 at 0x00000aec0000
    Bad eraseblock 1399 at 0x00000aee0000
    Bad eraseblock 1400 at 0x00000af00000
    Bad eraseblock 1401 at 0x00000af20000
    Bad eraseblock 1402 at 0x00000af40000
    Bad eraseblock 1403 at 0x00000af60000
    Bad eraseblock 1404 at 0x00000af80000
    Bad eraseblock 1405 at 0x00000afa0000
    Bad eraseblock 1406 at 0x00000afc0000
    Bad eraseblock 1407 at 0x00000afe0000
    Bad eraseblock 1408 at 0x00000b000000
    Bad eraseblock 1409 at 0x00000b020000
    Bad eraseblock 1410 at 0x00000b040000
    Bad eraseblock 1411 at 0x00000b060000
    Bad eraseblock 1412 at 0x00000b080000
    Bad eraseblock 1413 at 0x00000b0a0000
    Bad eraseblock 1414 at 0x00000b0c0000
    Bad eraseblock 1415 at 0x00000b0e0000
    Bad eraseblock 1416 at 0x00000b100000
    Bad eraseblock 1417 at 0x00000b120000
    Bad eraseblock 1418 at 0x00000b140000
    Bad eraseblock 1419 at 0x00000b160000
    Bad eraseblock 1420 at 0x00000b180000
    Bad eraseblock 1421 at 0x00000b1a0000
    Bad eraseblock 1422 at 0x00000b1c0000
    Bad eraseblock 1423 at 0x00000b1e0000
    Bad eraseblock 1424 at 0x00000b200000
    Bad eraseblock 1425 at 0x00000b220000
    Bad eraseblock 1426 at 0x00000b240000
    Bad eraseblock 1427 at 0x00000b260000
    Bad eraseblock 1428 at 0x00000b280000
    Bad eraseblock 1429 at 0x00000b2a0000
    Bad eraseblock 1430 at 0x00000b2c0000
    Bad eraseblock 1431 at 0x00000b2e0000
    Bad eraseblock 1432 at 0x00000b300000
    Bad eraseblock 1433 at 0x00000b320000
    Bad eraseblock 1434 at 0x00000b340000
    Bad eraseblock 1435 at 0x00000b360000
    Bad eraseblock 1436 at 0x00000b380000
    Bad eraseblock 1437 at 0x00000b3a0000
    Bad eraseblock 1438 at 0x00000b3c0000
    Bad eraseblock 1439 at 0x00000b3e0000
    Bad eraseblock 1440 at 0x00000b400000
    Bad eraseblock 1441 at 0x00000b420000
    Bad eraseblock 1442 at 0x00000b440000
    Bad eraseblock 1443 at 0x00000b460000
    Bad eraseblock 1444 at 0x00000b480000
    Bad eraseblock 1445 at 0x00000b4a0000
    Bad eraseblock 1446 at 0x00000b4c0000
    Bad eraseblock 1447 at 0x00000b4e0000
    [    *ad eraseblock 1448 at 0x00000b500000
    ;1;31m*] A sBad eraseblock 1449 at 0x00000b520000
    tart job is running for Wait for��… to be Configured (53s / no limit)Bad eraseb0
    Bad eraseblock 1451 at 0x00000b560000
    Bad eraseblock 1452 at 0x00000b580000
    Bad eraseblock 1453 at 0x00000b5a0000
    Bad eraseblock 1454 at 0x00000b5c0000
    Bad eraseblock 1455 at 0x00000b5e0000
    Bad eraseblock 1456 at 0x00000b600000
    Bad eraseblock 1457 at 0x00000b620000
    Bad eraseblock 1458 at 0x00000b640000
    Bad eraseblock 1459 at 0x00000b660000
    Bad eraseblock 1460 at 0x00000b680000
    Bad eraseblock 1461 at 0x00000b6a0000
    Bad eraseblock 1462 at 0x00000b6c0000
    Bad eraseblock 1463 at 0x00000b6e0000
    Bad eraseblock 1464 at 0x00000b700000
    Bad eraseblock 1465 at 0x00000b720000
    Bad eraseblock 1466 at 0x00000b740000
    Bad eraseblock 1467 at 0x00000b760000
    Bad eraseblock 1468 at 0x00000b780000
    Bad eraseblock 1469 at 0x00000b7a0000
    Bad eraseblock 1470 at 0x00000b7c0000
    Bad eraseblock 1471 at 0x00000b7e0000
    Bad eraseblock 1472 at 0x00000b800000
    Bad eraseblock 1473 at 0x00000b820000
    Bad eraseblock 1474 at 0x00000b840000
    Bad eraseblock 1475 at 0x00000b860000
    Bad eraseblock 1476 at 0x00000b880000
    Bad eraseblock 1477 at 0x00000b8a0000
    Bad eraseblock 1478 at 0x00000b8c0000
    Bad eraseblock 1479 at 0x00000b8e0000
    Bad eraseblock 1480 at 0x00000b900000
    Bad eraseblock 1481 at 0x00000b920000
    Bad eraseblock 1482 at 0x00000b940000
    Bad eraseblock 1483 at 0x00000b960000
    Bad eraseblock 1484 at 0x00000b980000
    Bad eraseblock 1485 at 0x00000b9a0000
    Bad eraseblock 1486 at 0x00000b9c0000
    Bad eraseblock 1487 at 0x00000b9e0000
    Bad eraseblock 1488 at 0x00000ba00000
    Bad eraseblock 1489 at 0x00000ba20000
    Bad eraseblock 1490 at 0x00000ba40000
    Bad eraseblock 1491 at 0x00000ba60000
    Bad eraseblock 1492 at 0x00000ba80000
    Bad eraseblock 1493 at 0x00000baa0000
    Bad eraseblock 1494 at 0x00000bac0000
    Bad eraseblock 1495 at 0x00000bae0000
    Bad eraseblock 1496 at 0x00000bb00000
    Bad eraseblock 1497 at 0x00000bb20000
    Bad eraseblock 1498 at 0x00000bb40000
    Bad eraseblock 1499 at 0x00000bb60000
    Bad eraseblock 1500 at 0x00000bb80000
    Bad eraseblock 1501 at 0x00000bba0000
    Bad eraseblock 1502 at 0x00000bbc0000
    Bad eraseblock 1503 at 0x00000bbe0000
    Bad eraseblock 1504 at 0x00000bc00000
    Bad eraseblock 1505 at 0x00000bc20000
    Bad eraseblock 1506 at 0x00000bc40000
    Bad eraseblock 1507 at 0x00000bc60000
    Bad eraseblock 1508 at 0x00000bc80000
    Bad eraseblock 1509 at 0x00000bca0000
    Bad eraseblock 1510 at 0x00000bcc0000
    Bad eraseblock 1511 at 0x00000bce0000
    Bad eraseblock 1512 at 0x00000bd00000
    Bad eraseblock 1513 at 0x00000bd20000
    Bad eraseblock 1514 at 0x00000bd40000
    Bad eraseblock 1515 at 0x00000bd60000
    Bad eraseblock 1516 at 0x00000bd80000
    Bad eraseblock 1517 at 0x00000bda0000
    Bad eraseblock 1518 at 0x00000bdc0000
    Bad eraseblock 1519 at 0x00000bde0000
    Bad eraseblock 1520 at 0x00000be00000
    Bad eraseblock 1521 at 0x00000be20000
    Bad eraseblock 1522 at 0x00000be40000
    Bad eraseblock 1523 at 0x00000be60000
    Bad eraseblock 1524 at 0x00000be80000
    Bad eraseblock 1525 at 0x00000bea0000
    Bad eraseblock 1526 at 0x00000bec0000
    Bad eraseblock 1527 at 0x00000bee0000
    Bad eraseblock 1528 at 0x00000bf00000
    Bad eraseblock 1529 at 0x00000bf20000
    Bad eraseblock 1530 at 0x00000bf40000
    Bad eraseblock 1531 at 0x00000bf60000
    Bad eraseblock 1532 at 0x00000bf80000
    Bad eraseblock 1533 at 0x00000bfa0000
    Bad eraseblock 1534 at 0x00000bfc0000
    Bad eraseblock 1535 at 0x00000bfe0000
    Bad eraseblock 1536 at 0x00000c000000
    Bad eraseblock 1537 at 0x00000c020000
    Bad eraseblock 1538 at 0x00000c040000
    Bad eraseblock 1539 at 0x00000c060000
    Bad eraseblock 1540 at 0x00000c080000
    Bad eraseblock 1541 at 0x00000c0a0000
    Bad eraseblock 1542 at 0x00000c0c0000
    Bad eraseblock 1543 at 0x00000c0e0000
    [     *ad eraseblock 1544 at 0x00000c100000
    0m] A start job is running for Wait for��… to beBad eraseblock 1545 at 0x00000c0
     Configured (54s / no limit)Bad eraseblock 1546 at 0x00000c140000
    Bad eraseblock 1547 at 0x00000c160000
    Bad eraseblock 1548 at 0x00000c180000
    Bad eraseblock 1549 at 0x00000c1a0000
    Bad eraseblock 1550 at 0x00000c1c0000
    Bad eraseblock 1551 at 0x00000c1e0000
    Bad eraseblock 1552 at 0x00000c200000
    Bad eraseblock 1553 at 0x00000c220000
    Bad eraseblock 1554 at 0x00000c240000
    Bad eraseblock 1555 at 0x00000c260000
    Bad eraseblock 1556 at 0x00000c280000
    Bad eraseblock 1557 at 0x00000c2a0000
    Bad eraseblock 1558 at 0x00000c2c0000
    Bad eraseblock 1559 at 0x00000c2e0000
    Bad eraseblock 1560 at 0x00000c300000
    Bad eraseblock 1561 at 0x00000c320000
    Bad eraseblock 1562 at 0x00000c340000
    Bad eraseblock 1563 at 0x00000c360000
    Bad eraseblock 1564 at 0x00000c380000
    Bad eraseblock 1565 at 0x00000c3a0000
    Bad eraseblock 1566 at 0x00000c3c0000
    Bad eraseblock 1567 at 0x00000c3e0000
    Bad eraseblock 1568 at 0x00000c400000
    Bad eraseblock 1569 at 0x00000c420000
    Bad eraseblock 1570 at 0x00000c440000
    Bad eraseblock 1571 at 0x00000c460000
    Bad eraseblock 1572 at 0x00000c480000
    Bad eraseblock 1573 at 0x00000c4a0000
    Bad eraseblock 1574 at 0x00000c4c0000
    Bad eraseblock 1575 at 0x00000c4e0000
    Bad eraseblock 1576 at 0x00000c500000
    Bad eraseblock 1577 at 0x00000c520000
    Bad eraseblock 1578 at 0x00000c540000
    Bad eraseblock 1579 at 0x00000c560000
    Bad eraseblock 1580 at 0x00000c580000
    Bad eraseblock 1581 at 0x00000c5a0000
    Bad eraseblock 1582 at 0x00000c5c0000
    Bad eraseblock 1583 at 0x00000c5e0000
    Bad eraseblock 1584 at 0x00000c600000
    Bad eraseblock 1585 at 0x00000c620000
    Bad eraseblock 1586 at 0x00000c640000
    Bad eraseblock 1587 at 0x00000c660000
    Bad eraseblock 1588 at 0x00000c680000
    Bad eraseblock 1589 at 0x00000c6a0000
    Bad eraseblock 1590 at 0x00000c6c0000
    Bad eraseblock 1591 at 0x00000c6e0000
    Bad eraseblock 1592 at 0x00000c700000
    Bad eraseblock 1593 at 0x00000c720000
    Bad eraseblock 1594 at 0x00000c740000
    Bad eraseblock 1595 at 0x00000c760000
    Bad eraseblock 1596 at 0x00000c780000
    [    *ad eraseblock 1597 at 0x00000c7a0000
    ;1;31m*] A start job is running for Wait forBad eraseblock 1598 at 0x00000c7c000
    ��… to be Configured (55s / no limit)Bad eraseblock 1599 at 0x00000c7e0000
    Bad eraseblock 1600 at 0x00000c800000
    Bad eraseblock 1601 at 0x00000c820000
    Bad eraseblock 1602 at 0x00000c840000
    Bad eraseblock 1603 at 0x00000c860000
    Bad eraseblock 1604 at 0x00000c880000
    Bad eraseblock 1605 at 0x00000c8a0000
    Bad eraseblock 1606 at 0x00000c8c0000
    Bad eraseblock 1607 at 0x00000c8e0000
    Bad eraseblock 1608 at 0x00000c900000
    Bad eraseblock 1609 at 0x00000c920000
    Bad eraseblock 1610 at 0x00000c940000
    Bad eraseblock 1611 at 0x00000c960000
    Bad eraseblock 1612 at 0x00000c980000
    Bad eraseblock 1613 at 0x00000c9a0000
    Bad eraseblock 1614 at 0x00000c9c0000
    Bad eraseblock 1615 at 0x00000c9e0000
    Bad eraseblock 1616 at 0x00000ca00000
    Bad eraseblock 1617 at 0x00000ca20000
    Bad eraseblock 1618 at 0x00000ca40000
    Bad eraseblock 1619 at 0x00000ca60000
    Bad eraseblock 1620 at 0x00000ca80000
    Bad eraseblock 1621 at 0x00000caa0000
    Bad eraseblock 1622 at 0x00000cac0000
    Bad eraseblock 1623 at 0x00000cae0000
    Bad eraseblock 1624 at 0x00000cb00000
    Bad eraseblock 1625 at 0x00000cb20000
    Bad eraseblock 1626 at 0x00000cb40000
    Bad eraseblock 1627 at 0x00000cb60000
    Bad eraseblock 1628 at 0x00000cb80000
    Bad eraseblock 1629 at 0x00000cba0000
    Bad eraseblock 1630 at 0x00000cbc0000
    Bad eraseblock 1631 at 0x00000cbe0000
    Bad eraseblock 1632 at 0x00000cc00000
    Bad eraseblock 1633 at 0x00000cc20000
    Bad eraseblock 1634 at 0x00000cc40000
    Bad eraseblock 1635 at 0x00000cc60000
    Bad eraseblock 1636 at 0x00000cc80000
    Bad eraseblock 1637 at 0x00000cca0000
    Bad eraseblock 1638 at 0x00000ccc0000
    Bad eraseblock 1639 at 0x00000cce0000
    Bad eraseblock 1640 at 0x00000cd00000
    Bad eraseblock 1641 at 0x00000cd20000
    Bad eraseblock 1642 at 0x00000cd40000
    Bad eraseblock 1643 at 0x00000cd60000
    Bad eraseblock 1644 at 0x00000cd80000
    Bad eraseblock 1645 at 0x00000cda0000
    Bad eraseblock 1646 at 0x00000cdc0000
    Bad eraseblock 1647 at 0x00000cde0000
    Bad eraseblock 1648 at 0x00000ce00000
    Bad eraseblock 1649 at 0x00000ce20000
    Bad eraseblock 1650 at 0x00000ce40000
    Bad eraseblock 1651 at 0x00000ce60000
    Bad eraseblock 1652 at 0x00000ce80000
    Bad eraseblock 1653 at 0x00000cea0000
    Bad eraseblock 1654 at 0x00000cec0000
    Bad eraseblock 1655 at 0x00000cee0000
    Bad eraseblock 1656 at 0x00000cf00000
    Bad eraseblock 1657 at 0x00000cf20000
    Bad eraseblock 1658 at 0x00000cf40000
    Bad eraseblock 1659 at 0x00000cf60000
    Bad eraseblock 1660 at 0x00000cf80000
    Bad eraseblock 1661 at 0x00000cfa0000
    Bad eraseblock 1662 at 0x00000cfc0000
    Bad eraseblock 1663 at 0x00000cfe0000
    Bad eraseblock 1664 at 0x00000d000000
    Bad eraseblock 1665 at 0x00000d020000
    Bad eraseblock 1666 at 0x00000d040000
    Bad eraseblock 1667 at 0x00000d060000
    Bad eraseblock 1668 at 0x00000d080000
    Bad eraseblock 1669 at 0x00000d0a0000
    Bad eraseblock 1670 at 0x00000d0c0000
    Bad eraseblock 1671 at 0x00000d0e0000
    Bad eraseblock 1672 at 0x00000d100000
    Bad eraseblock 1673 at 0x00000d120000
    Bad eraseblock 1674 at 0x00000d140000
    Bad eraseblock 1675 at 0x00000d160000
    Bad eraseblock 1676 at 0x00000d180000
    Bad eraseblock 1677 at 0x00000d1a0000
    Bad eraseblock 1678 at 0x00000d1c0000
    Bad eraseblock 1679 at 0x00000d1e0000
    Bad eraseblock 1680 at 0x00000d200000
    Bad eraseblock 1681 at 0x00000d220000
    Bad eraseblock 1682 at 0x00000d240000
    Bad eraseblock 1683 at 0x00000d260000
    Bad eraseblock 1684 at 0x00000d280000
    Bad eraseblock 1685 at 0x00000d2a0000
    Bad eraseblock 1686 at 0x00000d2c0000
    Bad eraseblock 1687 at 0x00000d2e0000
    Bad eraseblock 1688 at 0x00000d300000
    Bad eraseblock 1689 at 0x00000d320000
    Bad eraseblock 1690 at 0x00000d340000
    Bad eraseblock 1691 at 0x00000d360000
    [   *ad eraseblock 1692 at 0x00000d380000
    1;31m*ad eraseblock 1693 at 0x00000d3a0000
    m*] A start Bad eraseblock 1694 at 0x00000d3c0000
    job is running for Wait for��… to be Configured (55s / no limit)Bad eraseblock 0
    Bad eraseblock 1696 at 0x00000d400000
    Bad eraseblock 1697 at 0x00000d420000
    Bad eraseblock 1698 at 0x00000d440000
    Bad eraseblock 1699 at 0x00000d460000
    Bad eraseblock 1700 at 0x00000d480000
    Bad eraseblock 1701 at 0x00000d4a0000
    Bad eraseblock 1702 at 0x00000d4c0000
    Bad eraseblock 1703 at 0x00000d4e0000
    Bad eraseblock 1704 at 0x00000d500000
    Bad eraseblock 1705 at 0x00000d520000
    Bad eraseblock 1706 at 0x00000d540000
    Bad eraseblock 1707 at 0x00000d560000
    Bad eraseblock 1708 at 0x00000d580000
    Bad eraseblock 1709 at 0x00000d5a0000
    Bad eraseblock 1710 at 0x00000d5c0000
    Bad eraseblock 1711 at 0x00000d5e0000
    Bad eraseblock 1712 at 0x00000d600000
    Bad eraseblock 1713 at 0x00000d620000
    Bad eraseblock 1714 at 0x00000d640000
    Bad eraseblock 1715 at 0x00000d660000
    Bad eraseblock 1716 at 0x00000d680000
    Bad eraseblock 1717 at 0x00000d6a0000
    Bad eraseblock 1718 at 0x00000d6c0000
    Bad eraseblock 1719 at 0x00000d6e0000
    Bad eraseblock 1720 at 0x00000d700000
    Bad eraseblock 1721 at 0x00000d720000
    Bad eraseblock 1722 at 0x00000d740000
    Bad eraseblock 1723 at 0x00000d760000
    Bad eraseblock 1724 at 0x00000d780000
    Bad eraseblock 1725 at 0x00000d7a0000
    Bad eraseblock 1726 at 0x00000d7c0000
    Bad eraseblock 1727 at 0x00000d7e0000
    Bad eraseblock 1728 at 0x00000d800000
    Bad eraseblock 1729 at 0x00000d820000
    Bad eraseblock 1730 at 0x00000d840000
    Bad eraseblock 1731 at 0x00000d860000
    Bad eraseblock 1732 at 0x00000d880000
    Bad eraseblock 1733 at 0x00000d8a0000
    Bad eraseblock 1734 at 0x00000d8c0000
    Bad eraseblock 1735 at 0x00000d8e0000
    Bad eraseblock 1736 at 0x00000d900000
    Bad eraseblock 1737 at 0x00000d920000
    Bad eraseblock 1738 at 0x00000d940000
    Bad eraseblock 1739 at 0x00000d960000
    Bad eraseblock 1740 at 0x00000d980000
    Bad eraseblock 1741 at 0x00000d9a0000
    Bad eraseblock 1742 at 0x00000d9c0000
    Bad eraseblock 1743 at 0x00000d9e0000
    Bad eraseblock 1744 at 0x00000da00000
    Bad eraseblock 1745 at 0x00000da20000
    Bad eraseblock 1746 at 0x00000da40000
    Bad eraseblock 1747 at 0x00000da60000
    Bad eraseblock 1748 at 0x00000da80000
    Bad eraseblock 1749 at 0x00000daa0000
    Bad eraseblock 1750 at 0x00000dac0000
    Bad eraseblock 1751 at 0x00000dae0000
    Bad eraseblock 1752 at 0x00000db00000
    Bad eraseblock 1753 at 0x00000db20000
    Bad eraseblock 1754 at 0x00000db40000
    Bad eraseblock 1755 at 0x00000db60000
    Bad eraseblock 1756 at 0x00000db80000
    Bad eraseblock 1757 at 0x00000dba0000
    Bad eraseblock 1758 at 0x00000dbc0000
    Bad eraseblock 1759 at 0x00000dbe0000
    Bad eraseblock 1760 at 0x00000dc00000
    Bad eraseblock 1761 at 0x00000dc20000
    Bad eraseblock 1762 at 0x00000dc40000
    Bad eraseblock 1763 at 0x00000dc60000
    Bad eraseblock 1764 at 0x00000dc80000
    Bad eraseblock 1765 at 0x00000dca0000
    Bad eraseblock 1766 at 0x00000dcc0000
    Bad eraseblock 1767 at 0x00000dce0000
    Bad eraseblock 1768 at 0x00000dd00000
    Bad eraseblock 1769 at 0x00000dd20000
    Bad eraseblock 1770 at 0x00000dd40000
    Bad eraseblock 1771 at 0x00000dd60000
    Bad eraseblock 1772 at 0x00000dd80000
    Bad eraseblock 1773 at 0x00000dda0000
    Bad eraseblock 1774 at 0x00000ddc0000
    Bad eraseblock 1775 at 0x00000dde0000
    Bad eraseblock 1776 at 0x00000de00000
    Bad eraseblock 1777 at 0x00000de20000
    Bad eraseblock 1778 at 0x00000de40000
    Bad eraseblock 1779 at 0x00000de60000
    Bad eraseblock 1780 at 0x00000de80000
    Bad eraseblock 1781 at 0x00000dea0000
    Bad eraseblock 1782 at 0x00000dec0000
    Bad eraseblock 1783 at 0x00000dee0000
    Bad eraseblock 1784 at 0x00000df00000
    Bad eraseblock 1785 at 0x00000df20000
    Bad eraseblock 1786 at 0x00000df40000
    [  *ad eraseblock 1787 at 0x00000df60000
    ;31m** ] A start job is running fBad eraseblock 1788 at 0x00000df80000
    or Wait for��… to be Configured (56s / no limit)Bad eraseblock 1789 at 0x00000d0
    Bad eraseblock 1790 at 0x00000dfc0000
    Bad eraseblock 1791 at 0x00000dfe0000
    Bad eraseblock 1792 at 0x00000e000000
    Bad eraseblock 1793 at 0x00000e020000
    Bad eraseblock 1794 at 0x00000e040000
    Bad eraseblock 1795 at 0x00000e060000
    Bad eraseblock 1796 at 0x00000e080000
    Bad eraseblock 1797 at 0x00000e0a0000
    Bad eraseblock 1798 at 0x00000e0c0000
    Bad eraseblock 1799 at 0x00000e0e0000
    Bad eraseblock 1800 at 0x00000e100000
    Bad eraseblock 1801 at 0x00000e120000
    Bad eraseblock 1802 at 0x00000e140000
    Bad eraseblock 1803 at 0x00000e160000
    Bad eraseblock 1804 at 0x00000e180000
    Bad eraseblock 1805 at 0x00000e1a0000
    Bad eraseblock 1806 at 0x00000e1c0000
    Bad eraseblock 1807 at 0x00000e1e0000
    Bad eraseblock 1808 at 0x00000e200000
    Bad eraseblock 1809 at 0x00000e220000
    Bad eraseblock 1810 at 0x00000e240000
    Bad eraseblock 1811 at 0x00000e260000
    Bad eraseblock 1812 at 0x00000e280000
    Bad eraseblock 1813 at 0x00000e2a0000
    Bad eraseblock 1814 at 0x00000e2c0000
    Bad eraseblock 1815 at 0x00000e2e0000
    Bad eraseblock 1816 at 0x00000e300000
    Bad eraseblock 1817 at 0x00000e320000
    Bad eraseblock 1818 at 0x00000e340000
    Bad eraseblock 1819 at 0x00000e360000
    Bad eraseblock 1820 at 0x00000e380000
    Bad eraseblock 1821 at 0x00000e3a0000
    Bad eraseblock 1822 at 0x00000e3c0000
    Bad eraseblock 1823 at 0x00000e3e0000
    Bad eraseblock 1824 at 0x00000e400000
    Bad eraseblock 1825 at 0x00000e420000
    Bad eraseblock 1826 at 0x00000e440000
    Bad eraseblock 1827 at 0x00000e460000
    Bad eraseblock 1828 at 0x00000e480000
    Bad eraseblock 1829 at 0x00000e4a0000
    Bad eraseblock 1830 at 0x00000e4c0000
    Bad eraseblock 1831 at 0x00000e4e0000
    Bad eraseblock 1832 at 0x00000e500000
    Bad eraseblock 1833 at 0x00000e520000
    Bad eraseblock 1834 at 0x00000e540000
    Bad eraseblock 1835 at 0x00000e560000
    Bad eraseblock 1836 at 0x00000e580000
    Bad eraseblock 1837 at 0x00000e5a0000
    Bad eraseblock 1838 at 0x00000e5c0000
    Bad eraseblock 1839 at 0x00000e5e0000
    Bad eraseblock 1840 at 0x00000e600000
    Bad eraseblock 1841 at 0x00000e620000
    Bad eraseblock 1842 at 0x00000e640000
    Bad eraseblock 1843 at 0x00000e660000
    Bad eraseblock 1844 at 0x00000e680000
    Bad eraseblock 1845 at 0x00000e6a0000
    Bad eraseblock 1846 at 0x00000e6c0000
    Bad eraseblock 1847 at 0x00000e6e0000
    Bad eraseblock 1848 at 0x00000e700000
    Bad eraseblock 1849 at 0x00000e720000
    Bad eraseblock 1850 at 0x00000e740000
    Bad eraseblock 1851 at 0x00000e760000
    Bad eraseblock 1852 at 0x00000e780000
    Bad eraseblock 1853 at 0x00000e7a0000
    Bad eraseblock 1854 at 0x00000e7c0000
    Bad eraseblock 1855 at 0x00000e7e0000
    Bad eraseblock 1856 at 0x00000e800000
    Bad eraseblock 1857 at 0x00000e820000
    Bad eraseblock 1858 at 0x00000e840000
    Bad eraseblock 1859 at 0x00000e860000
    Bad eraseblock 1860 at 0x00000e880000
    Bad eraseblock 1861 at 0x00000e8a0000
    Bad eraseblock 1862 at 0x00000e8c0000
    Bad eraseblock 1863 at 0x00000e8e0000
    Bad eraseblock 1864 at 0x00000e900000
    Bad eraseblock 1865 at 0x00000e920000
    Bad eraseblock 1866 at 0x00000e940000
    Bad eraseblock 1867 at 0x00000e960000
    Bad eraseblock 1868 at 0x00000e980000
    Bad eraseblock 1869 at 0x00000e9a0000
    Bad eraseblock 1870 at 0x00000e9c0000
    Bad eraseblock 1871 at 0x00000e9e0000
    Bad eraseblock 1872 at 0x00000ea00000
    Bad eraseblock 1873 at 0x00000ea20000
    Bad eraseblock 1874 at 0x00000ea40000
    Bad eraseblock 1875 at 0x00000ea60000
    Bad eraseblock 1876 at 0x00000ea80000
    Bad eraseblock 1877 at 0x00000eaa0000
    Bad eraseblock 1878 at 0x00000eac0000
    Bad eraseblock 1879 at 0x00000eae0000
    Bad eraseblock 1880 at 0x00000eb00000
    Bad eraseblock 1881 at 0x00000eb20000
    Bad eraseblock 1882 at 0x00000eb40000
    Bad eraseblock 1883 at 0x00000eb60000
    [ *ad eraseblock 1884 at 0x00000eb80000
    31m**  ] A start job is running fBad eraseblock 1885 at 0x00000eba0000
    or Wait for��… tBad eraseblock 1886 at 0x00000ebc0000
    o be Configured (57s / no limit)Bad eraseblock 1887 at 0x00000ebe0000
    Bad eraseblock 1888 at 0x00000ec00000
    Bad eraseblock 1889 at 0x00000ec20000
    Bad eraseblock 1890 at 0x00000ec40000
    Bad eraseblock 1891 at 0x00000ec60000
    Bad eraseblock 1892 at 0x00000ec80000
    Bad eraseblock 1893 at 0x00000eca0000
    Bad eraseblock 1894 at 0x00000ecc0000
    Bad eraseblock 1895 at 0x00000ece0000
    Bad eraseblock 1896 at 0x00000ed00000
    Bad eraseblock 1897 at 0x00000ed20000
    Bad eraseblock 1898 at 0x00000ed40000
    Bad eraseblock 1899 at 0x00000ed60000
    Bad eraseblock 1900 at 0x00000ed80000
    Bad eraseblock 1901 at 0x00000eda0000
    Bad eraseblock 1902 at 0x00000edc0000
    Bad eraseblock 1903 at 0x00000ede0000
    Bad eraseblock 1904 at 0x00000ee00000
    Bad eraseblock 1905 at 0x00000ee20000
    Bad eraseblock 1906 at 0x00000ee40000
    Bad eraseblock 1907 at 0x00000ee60000
    Bad eraseblock 1908 at 0x00000ee80000
    Bad eraseblock 1909 at 0x00000eea0000
    Bad eraseblock 1910 at 0x00000eec0000
    Bad eraseblock 1911 at 0x00000eee0000
    Bad eraseblock 1912 at 0x00000ef00000
    Bad eraseblock 1913 at 0x00000ef20000
    Bad eraseblock 1914 at 0x00000ef40000
    Bad eraseblock 1915 at 0x00000ef60000
    Bad eraseblock 1916 at 0x00000ef80000
    Bad eraseblock 1917 at 0x00000efa0000
    Bad eraseblock 1918 at 0x00000efc0000
    Bad eraseblock 1919 at 0x00000efe0000
    Bad eraseblock 1920 at 0x00000f000000
    Bad eraseblock 1921 at 0x00000f020000
    Bad eraseblock 1922 at 0x00000f040000
    Bad eraseblock 1923 at 0x00000f060000
    Bad eraseblock 1924 at 0x00000f080000
    Bad eraseblock 1925 at 0x00000f0a0000
    Bad eraseblock 1926 at 0x00000f0c0000
    Bad eraseblock 1927 at 0x00000f0e0000
    Bad eraseblock 1928 at 0x00000f100000
    Bad eraseblock 1929 at 0x00000f120000
    Bad eraseblock 1930 at 0x00000f140000
    Bad eraseblock 1931 at 0x00000f160000
    Bad eraseblock 1932 at 0x00000f180000
    Bad eraseblock 1933 at 0x00000f1a0000
    Bad eraseblock 1934 at 0x00000f1c0000
    Bad eraseblock 1935 at 0x00000f1e0000
    Bad eraseblock 1936 at 0x00000f200000
    Bad eraseblock 1937 at 0x00000f220000
    Bad eraseblock 1938 at 0x00000f240000
    Bad eraseblock 1939 at 0x00000f260000
    Bad eraseblock 1940 at 0x00000f280000
    Bad eraseblock 1941 at 0x00000f2a0000
    Bad eraseblock 1942 at 0x00000f2c0000
    Bad eraseblock 1943 at 0x00000f2e0000
    Bad eraseblock 1944 at 0x00000f300000
    Bad eraseblock 1945 at 0x00000f320000
    Bad eraseblock 1946 at 0x00000f340000
    Bad eraseblock 1947 at 0x00000f360000
    Bad eraseblock 1948 at 0x00000f380000
    Bad eraseblock 1949 at 0x00000f3a0000
    Bad eraseblock 1950 at 0x00000f3c0000
    Bad eraseblock 1951 at 0x00000f3e0000
    Bad eraseblock 1952 at 0x00000f400000
    Bad eraseblock 1953 at 0x00000f420000
    Bad eraseblock 1954 at 0x00000f440000
    Bad eraseblock 1955 at 0x00000f460000
    Bad eraseblock 1956 at 0x00000f480000
    Bad eraseblock 1957 at 0x00000f4a0000
    Bad eraseblock 1958 at 0x00000f4c0000
    Bad eraseblock 1959 at 0x00000f4e0000
    Bad eraseblock 1960 at 0x00000f500000
    Bad eraseblock 1961 at 0x00000f520000
    Bad eraseblock 1962 at 0x00000f540000
    Bad eraseblock 1963 at 0x00000f560000
    Bad eraseblock 1964 at 0x00000f580000
    Bad eraseblock 1965 at 0x00000f5a0000
    Bad eraseblock 1966 at 0x00000f5c0000
    Bad eraseblock 1967 at 0x00000f5e0000
    Bad eraseblock 1968 at 0x00000f600000
    Bad eraseblock 1969 at 0x00000f620000
    Bad eraseblock 1970 at 0x00000f640000
    Bad eraseblock 1971 at 0x00000f660000
    Bad eraseblock 1972 at 0x00000f680000
    Bad eraseblock 1973 at 0x00000f6a0000
    Bad eraseblock 1974 at 0x00000f6c0000
    Bad eraseblock 1975 at 0x00000f6e0000
    Bad eraseblock 1976 at 0x00000f700000
    [*ad eraseblock 1977 at 0x00000f720000
    1m**   ] A start job is running fBad eraseblock 1978 at 0x00000f740000
    or Wait for��… tBad eraseblock 1979 at 0x00000f760000
    o be Configured (58s / no limit)Bad eraseblock 1980 at 0x00000f780000
    Bad eraseblock 1981 at 0x00000f7a0000
    Bad eraseblock 1982 at 0x00000f7c0000
    Bad eraseblock 1983 at 0x00000f7e0000
    Bad eraseblock 1984 at 0x00000f800000
    Bad eraseblock 1985 at 0x00000f820000
    Bad eraseblock 1986 at 0x00000f840000
    Bad eraseblock 1987 at 0x00000f860000
    Bad eraseblock 1988 at 0x00000f880000
    Bad eraseblock 1989 at 0x00000f8a0000
    Bad eraseblock 1990 at 0x00000f8c0000
    Bad eraseblock 1991 at 0x00000f8e0000
    Bad eraseblock 1992 at 0x00000f900000
    Bad eraseblock 1993 at 0x00000f920000
    Bad eraseblock 1994 at 0x00000f940000
    Bad eraseblock 1995 at 0x00000f960000
    Bad eraseblock 1996 at 0x00000f980000
    Bad eraseblock 1997 at 0x00000f9a0000
    Bad eraseblock 1998 at 0x00000f9c0000
    Bad eraseblock 1999 at 0x00000f9e0000
    Bad eraseblock 2000 at 0x00000fa00000
    Bad eraseblock 2001 at 0x00000fa20000
    Bad eraseblock 2002 at 0x00000fa40000
    Bad eraseblock 2003 at 0x00000fa60000
    Bad eraseblock 2004 at 0x00000fa80000
    Bad eraseblock 2005 at 0x00000faa0000
    Bad eraseblock 2006 at 0x00000fac0000
    Bad eraseblock 2007 at 0x00000fae0000
    Bad eraseblock 2008 at 0x00000fb00000
    Bad eraseblock 2009 at 0x00000fb20000
    Bad eraseblock 2010 at 0x00000fb40000
    Bad eraseblock 2011 at 0x00000fb60000
    Bad eraseblock 2012 at 0x00000fb80000
    Bad eraseblock 2013 at 0x00000fba0000
    Bad eraseblock 2014 at 0x00000fbc0000
    Bad eraseblock 2015 at 0x00000fbe0000
    Bad eraseblock 2016 at 0x00000fc00000
    Bad eraseblock 2017 at 0x00000fc20000
    Bad eraseblock 2018 at 0x00000fc40000
    Bad eraseblock 2019 at 0x00000fc60000
    Bad eraseblock 2020 at 0x00000fc80000
    Bad eraseblock 2021 at 0x00000fca0000
    Bad eraseblock 2022 at 0x00000fcc0000
    Bad eraseblock 2023 at 0x00000fce0000
    Bad eraseblock 2024 at 0x00000fd00000
    Bad eraseblock 2025 at 0x00000fd20000
    Bad eraseblock 2026 at 0x00000fd40000
    Bad eraseblock 2027 at 0x00000fd60000
    Bad eraseblock 2028 at 0x00000fd80000
    Bad eraseblock 2029 at 0x00000fda0000
    Bad eraseblock 2030 at 0x00000fdc0000
    Bad eraseblock 2031 at 0x00000fde0000
    Bad eraseblock 2032 at 0x00000fe00000
    Bad eraseblock 2033 at 0x00000fe20000
    Bad eraseblock 2034 at 0x00000fe40000
    Bad eraseblock 2035 at 0x00000fe60000
    Bad eraseblock 2036 at 0x00000fe80000
    Bad eraseblock 2037 at 0x00000fea0000
    Bad eraseblock 2038 at 0x00000fec0000
    Bad eraseblock 2039 at 0x00000fee0000
    Bad eraseblock 2040 at 0x00000ff00000
    Bad eraseblock 2041 at 0x00000ff20000
    Bad eraseblock 2042 at 0x00000ff40000
    Bad eraseblock 2043 at 0x00000ff60000
    Bad eraseblock 2044 at 0x00000ff80000
    Bad eraseblock 2045 at 0x00000ffa0000
    Bad eraseblock 2046 at 0x00000ffc0000
    Bad eraseblock 2047 at 0x00000ffe0000
    Bad eraseblock 2048 at 0x000010000000
    Bad eraseblock 2049 at 0x000010020000
    Bad eraseblock 2050 at 0x000010040000
    Bad eraseblock 2051 at 0x000010060000
    Bad eraseblock 2052 at 0x000010080000
    Bad eraseblock 2053 at 0x0000100a0000
    Bad eraseblock 2054 at 0x0000100c0000
    Bad eraseblock 2055 at 0x0000100e0000
    Bad eraseblock 2056 at 0x000010100000
    Bad eraseblock 2057 at 0x000010120000
    Bad eraseblock 2058 at 0x000010140000
    Bad eraseblock 2059 at 0x000010160000
    Bad eraseblock 2060 at 0x000010180000
    Bad eraseblock 2061 at 0x0000101a0000
    Bad eraseblock 2062 at 0x0000101c0000
    Bad eraseblock 2063 at 0x0000101e0000
    Bad eraseblock 2064 at 0x000010200000
    Bad eraseblock 2065 at 0x000010220000
    Bad eraseblock 2066 at 0x000010240000
    Bad eraseblock 2067 at 0x000010260000
    Bad eraseblock 2068 at 0x000010280000
    Bad eraseblock 2069 at 0x0000102a0000
    [*ad eraseblock 2070 at 0x0000102c0000
    [0;31m*    ] A start job is running for WaitBad eraseblock 2071 at 0x0000102e000
     for��… to be CoBad eraseblock 2072 at 0x000010300000
    nfigured (59s / no limit)Bad eraseblock 2073 at 0x000010320000
    Bad eraseblock 2074 at 0x000010340000
    Bad eraseblock 2075 at 0x000010360000
    Bad eraseblock 2076 at 0x000010380000
    Bad eraseblock 2077 at 0x0000103a0000
    Bad eraseblock 2078 at 0x0000103c0000
    Bad eraseblock 2079 at 0x0000103e0000
    Bad eraseblock 2080 at 0x000010400000
    Bad eraseblock 2081 at 0x000010420000
    Bad eraseblock 2082 at 0x000010440000
    Bad eraseblock 2083 at 0x000010460000
    Bad eraseblock 2084 at 0x000010480000
    Bad eraseblock 2085 at 0x0000104a0000
    Bad eraseblock 2086 at 0x0000104c0000
    Bad eraseblock 2087 at 0x0000104e0000
    Bad eraseblock 2088 at 0x000010500000
    Bad eraseblock 2089 at 0x000010520000
    Bad eraseblock 2090 at 0x000010540000
    Bad eraseblock 2091 at 0x000010560000
    Bad eraseblock 2092 at 0x000010580000
    Bad eraseblock 2093 at 0x0000105a0000
    Bad eraseblock 2094 at 0x0000105c0000
    Bad eraseblock 2095 at 0x0000105e0000
    Bad eraseblock 2096 at 0x000010600000
    Bad eraseblock 2097 at 0x000010620000
    Bad eraseblock 2098 at 0x000010640000
    Bad eraseblock 2099 at 0x000010660000
    Bad eraseblock 2100 at 0x000010680000
    Bad eraseblock 2101 at 0x0000106a0000
    Bad eraseblock 2102 at 0x0000106c0000
    Bad eraseblock 2103 at 0x0000106e0000
    Bad eraseblock 2104 at 0x000010700000
    Bad eraseblock 2105 at 0x000010720000
    Bad eraseblock 2106 at 0x000010740000
    Bad eraseblock 2107 at 0x000010760000
    Bad eraseblock 2108 at 0x000010780000
    Bad eraseblock 2109 at 0x0000107a0000
    Bad eraseblock 2110 at 0x0000107c0000
    Bad eraseblock 2111 at 0x0000107e0000
    Bad eraseblock 2112 at 0x000010800000
    Bad eraseblock 2113 at 0x000010820000
    Bad eraseblock 2114 at 0x000010840000
    Bad eraseblock 2115 at 0x000010860000
    Bad eraseblock 2116 at 0x000010880000
    Bad eraseblock 2117 at 0x0000108a0000
    Bad eraseblock 2118 at 0x0000108c0000
    Bad eraseblock 2119 at 0x0000108e0000
    Bad eraseblock 2120 at 0x000010900000
    Bad eraseblock 2121 at 0x000010920000
    Bad eraseblock 2122 at 0x000010940000
    Bad eraseblock 2123 at 0x000010960000
    Bad eraseblock 2124 at 0x000010980000
    Bad eraseblock 2125 at 0x0000109a0000
    Bad eraseblock 2126 at 0x0000109c0000
    Bad eraseblock 2127 at 0x0000109e0000
    Bad eraseblock 2128 at 0x000010a00000
    Bad eraseblock 2129 at 0x000010a20000
    Bad eraseblock 2130 at 0x000010a40000
    Bad eraseblock 2131 at 0x000010a60000
    Bad eraseblock 2132 at 0x000010a80000
    Bad eraseblock 2133 at 0x000010aa0000
    Bad eraseblock 2134 at 0x000010ac0000
    Bad eraseblock 2135 at 0x000010ae0000
    Bad eraseblock 2136 at 0x000010b00000
    Bad eraseblock 2137 at 0x000010b20000
    Bad eraseblock 2138 at 0x000010b40000
    Bad eraseblock 2139 at 0x000010b60000
    Bad eraseblock 2140 at 0x000010b80000
    Bad eraseblock 2141 at 0x000010ba0000
    Bad eraseblock 2142 at 0x000010bc0000
    Bad eraseblock 2143 at 0x000010be0000
    Bad eraseblock 2144 at 0x000010c00000
    Bad eraseblock 2145 at 0x000010c20000
    Bad eraseblock 2146 at 0x000010c40000
    Bad eraseblock 2147 at 0x000010c60000
    Bad eraseblock 2148 at 0x000010c80000
    Bad eraseblock 2149 at 0x000010ca0000
    Bad eraseblock 2150 at 0x000010cc0000
    Bad eraseblock 2151 at 0x000010ce0000
    Bad eraseblock 2152 at 0x000010d00000
    Bad eraseblock 2153 at 0x000010d20000
    Bad eraseblock 2154 at 0x000010d40000
    Bad eraseblock 2155 at 0x000010d60000
    Bad eraseblock 2156 at 0x000010d80000
    Bad eraseblock 2157 at 0x000010da0000
    Bad eraseblock 2158 at 0x000010dc0000
    Bad eraseblock 2159 at 0x000010de0000
    Bad eraseblock 2160 at 0x000010e00000
    Bad eraseblock 2161 at 0x000010e20000
    Bad eraseblock 2162 at 0x000010e40000
    [*   Bad eraseblock 2163 at 0x000010e60000
      ] A start job is running for Wait for��…toBad eraseblock 2164 at 0x000010e8000
     be Configured (1min / no limit)Bad eraseblock 2165 at 0x000010ea0000
    Bad eraseblock 2166 at 0x000010ec0000
    Bad eraseblock 2167 at 0x000010ee0000
    Bad eraseblock 2708 at 0x000015280000
    Bad eraseblock 2709 at 0x0000152a0000
    Bad eraseblock 2712 at 0x000015300000
    Bad eraseblock 2713 at 0x000015320000
    Bad eraseblock 2714 at 0x000015340000
    Bad eraseblock 2715 at 0x000015360000
    Bad eraseblock 2716 at 0x000015380000
    Bad eraseblock 2717 at 0x0000153a0000
    Bad eraseblock 2718 at 0x0000153c0000
    Bad eraseblock 2719 at 0x0000153e0000
    Bad eraseblock 2720 at 0x000015400000
    Bad eraseblock 2721 at 0x000015420000
    Bad eraseblock 2722 at 0x000015440000
    Bad eraseblock 2723 at 0x000015460000
    Bad eraseblock 2724 at 0x000015480000
    Bad eraseblock 2725 at 0x0000154a0000
    Bad eraseblock 2726 at 0x0000154c0000
    Bad eraseblock 2727 at 0x0000154e0000
    Bad eraseblock 2728 at 0x000015500000
    Bad eraseblock 2729 at 0x000015520000
    Bad eraseblock 2730 at 0x000015540000
    Bad eraseblock 2731 at 0x000015560000
    Bad eraseblock 2732 at 0x000015580000
    Bad eraseblock 2733 at 0x0000155a0000
    Bad eraseblock 2734 at 0x0000155c0000
    Bad eraseblock 2735 at 0x0000155e0000
    Bad eraseblock 2736 at 0x000015600000
    Bad eraseblock 2737 at 0x000015620000
    Bad eraseblock 2738 at 0x000015640000
    Bad eraseblock 2739 at 0x000015660000
    Bad eraseblock 2740 at 0x000015680000
    Bad eraseblock 2741 at 0x0000156a0000
    Bad eraseblock 2742 at 0x0000156c0000
    Bad eraseblock 2743 at 0x0000156e0000
    Bad eraseblock 2744 at 0x000015700000
    Bad eraseblock 2745 at 0x000015720000
    Bad eraseblock 2746 at 0x000015740000
    Bad eraseblock 2747 at 0x000015760000
    Bad eraseblock 2748 at 0x000015780000
    Bad eraseblock 2749 at 0x0000157a0000
    Bad eraseblock 2750 at 0x0000157c0000
    Bad eraseblock 2751 at 0x0000157e0000
    Bad eraseblock 2752 at 0x000015800000
    Bad eraseblock 2753 at 0x000015820000
    Bad eraseblock 2754 at 0x000015840000
    Bad eraseblock 2755 at 0x000015860000
    Bad eraseblock 2756 at 0x000015880000
    Bad eraseblock 2757 at 0x0000158a0000
    Bad eraseblock 2758 at 0x0000158c0000
    Bad eraseblock 2759 at 0x0000158e0000
    Bad eraseblock 2760 at 0x000015900000
    Bad eraseblock 2761 at 0x000015920000
    Bad eraseblock 2762 at 0x000015940000
    Bad eraseblock 2763 at 0x000015960000
    Bad eraseblock 2764 at 0x000015980000
    Bad eraseblock 2765 at 0x0000159a0000
    Bad eraseblock 2766 at 0x0000159c0000
    Bad eraseblock 2767 at 0x0000159e0000
    Bad eraseblock 2768 at 0x000015a00000
    Bad eraseblock 2769 at 0x000015a20000
    Bad eraseblock 2770 at 0x000015a40000
    Bad eraseblock 2771 at 0x000015a60000
    Bad eraseblock 2772 at 0x000015a80000
    Bad eraseblock 2773 at 0x000015aa0000
    Bad eraseblock 2774 at 0x000015ac0000
    Bad eraseblock 2775 at 0x000015ae0000
    Bad eraseblock 2776 at 0x000015b00000
    Bad eraseblock 2777 at 0x000015b20000
    Bad eraseblock 2778 at 0x000015b40000
    Bad eraseblock 2779 at 0x000015b60000
    Bad eraseblock 2780 at 0x000015b80000
    Bad eraseblock 2781 at 0x000015ba0000
    Bad eraseblock 2782 at 0x000015bc0000
    Bad eraseblock 2783 at 0x000015be0000
    Bad eraseblock 2784 at 0x000015c00000
    Bad eraseblock 2785 at 0x000015c20000
    Bad eraseblock 2786 at 0x000015c40000
    Bad eraseblock 2787 at 0x000015c60000
    Bad eraseblock 2788 at 0x000015c80000
    Bad eraseblock 2789 at 0x000015ca0000
    [*ad eraseblock 2790 at 0x000015cc0000
    [0;31m*    ]Bad eraseblock 2791 at 0x000015ce0000
     A start job is running for Wait for��…be Configured (1min 1s / no limit)Bad er0
    Bad eraseblock 2793 at 0x000015d20000
    Bad eraseblock 2794 at 0x000015d40000
    Bad eraseblock 2795 at 0x000015d60000
    Bad eraseblock 2796 at 0x000015d80000
    Bad eraseblock 2797 at 0x000015da0000
    Bad eraseblock 2798 at 0x000015dc0000
    Bad eraseblock 2799 at 0x000015de0000
    Bad eraseblock 2800 at 0x000015e00000
    Bad eraseblock 2801 at 0x000015e20000
    Bad eraseblock 2802 at 0x000015e40000
    Bad eraseblock 2803 at 0x000015e60000
    Bad eraseblock 2804 at 0x000015e80000
    Bad eraseblock 2805 at 0x000015ea0000
    Bad eraseblock 2806 at 0x000015ec0000
    Bad eraseblock 2807 at 0x000015ee0000
    Bad eraseblock 2808 at 0x000015f00000
    Bad eraseblock 2809 at 0x000015f20000
    Bad eraseblock 2810 at 0x000015f40000
    Bad eraseblock 2811 at 0x000015f60000
    Bad eraseblock 2812 at 0x000015f80000
    Bad eraseblock 2813 at 0x000015fa0000
    Bad eraseblock 2814 at 0x000015fc0000
    Bad eraseblock 2815 at 0x000015fe0000
    Bad eraseblock 2816 at 0x000016000000
    Bad eraseblock 2817 at 0x000016020000
    Bad eraseblock 2818 at 0x000016040000
    Bad eraseblock 2819 at 0x000016060000
    Bad eraseblock 2820 at 0x000016080000
    Bad eraseblock 2821 at 0x0000160a0000
    Bad eraseblock 2822 at 0x0000160c0000
    Bad eraseblock 2823 at 0x0000160e0000
    Bad eraseblock 2824 at 0x000016100000
    Bad eraseblock 2825 at 0x000016120000
    Bad eraseblock 2826 at 0x000016140000
    Bad eraseblock 2827 at 0x000016160000
    Bad eraseblock 2828 at 0x000016180000
    Bad eraseblock 2829 at 0x0000161a0000
    Bad eraseblock 2830 at 0x0000161c0000
    Bad eraseblock 2831 at 0x0000161e0000
    Bad eraseblock 2832 at 0x000016200000
    Bad eraseblock 2833 at 0x000016220000
    Bad eraseblock 2834 at 0x000016240000
    Bad eraseblock 2835 at 0x000016260000
    Bad eraseblock 2836 at 0x000016280000
    Bad eraseblock 2837 at 0x0000162a0000
    Bad eraseblock 2838 at 0x0000162c0000
    Bad eraseblock 2839 at 0x0000162e0000
    Bad eraseblock 2840 at 0x000016300000
    Bad eraseblock 2841 at 0x000016320000
    Bad eraseblock 2842 at 0x000016340000
    Bad eraseblock 2843 at 0x000016360000
    Bad eraseblock 2844 at 0x000016380000
    Bad eraseblock 2845 at 0x0000163a0000
    Bad eraseblock 2846 at 0x0000163c0000
    Bad eraseblock 2847 at 0x0000163e0000
    Bad eraseblock 2848 at 0x000016400000
    Bad eraseblock 2849 at 0x000016420000
    Bad eraseblock 2850 at 0x000016440000
    Bad eraseblock 2851 at 0x000016460000
    Bad eraseblock 2852 at 0x000016480000
    Bad eraseblock 2853 at 0x0000164a0000
    Bad eraseblock 2854 at 0x0000164c0000
    Bad eraseblock 2855 at 0x0000164e0000
    Bad eraseblock 2856 at 0x000016500000
    Bad eraseblock 2857 at 0x000016520000
    Bad eraseblock 2858 at 0x000016540000
    Bad eraseblock 2859 at 0x000016560000
    Bad eraseblock 2860 at 0x000016580000
    Bad eraseblock 2861 at 0x0000165a0000
    Bad eraseblock 2862 at 0x0000165c0000
    Bad eraseblock 2863 at 0x0000165e0000
    Bad eraseblock 2864 at 0x000016600000
    Bad eraseblock 2865 at 0x000016620000
    Bad eraseblock 2866 at 0x000016640000
    Bad eraseblock 2867 at 0x000016660000
    Bad eraseblock 2868 at 0x000016680000
    Bad eraseblock 2869 at 0x0000166a0000
    Bad eraseblock 2870 at 0x0000166c0000
    Bad eraseblock 2871 at 0x0000166e0000
    Bad eraseblock 2872 at 0x000016700000
    Bad eraseblock 2873 at 0x000016720000
    Bad eraseblock 2874 at 0x000016740000
    Bad eraseblock 2875 at 0x000016760000
    Bad eraseblock 2876 at 0x000016780000
    Bad eraseblock 2877 at 0x0000167a0000
    Bad eraseblock 2878 at 0x0000167c0000
    Bad eraseblock 2879 at 0x0000167e0000
    Bad eraseblock 2880 at 0x000016800000
    Bad eraseblock 2881 at 0x000016820000
    Bad eraseblock 2882 at 0x000016840000
    Bad eraseblock 2883 at 0x000016860000
    Bad eraseblock 2884 at 0x000016880000
    Bad eraseblock 2885 at 0x0000168a0000
    [*ad eraseblock 2886 at 0x0000168c0000
    1m**   ] A start job is running fBad eraseblock 2887 at 0x0000168e0000
    or Wait for��…be Configured (1min 2s / no limit)Bad eraseblock 2888 at 0x0000160
    Bad eraseblock 2889 at 0x000016920000
    Bad eraseblock 2890 at 0x000016940000
    Bad eraseblock 2891 at 0x000016960000
    Bad eraseblock 2892 at 0x000016980000
    Bad eraseblock 2893 at 0x0000169a0000
    Bad eraseblock 2894 at 0x0000169c0000
    Bad eraseblock 2895 at 0x0000169e0000
    Bad eraseblock 2896 at 0x000016a00000
    Bad eraseblock 2897 at 0x000016a20000
    Bad eraseblock 2898 at 0x000016a40000
    Bad eraseblock 2899 at 0x000016a60000
    Bad eraseblock 2900 at 0x000016a80000
    Bad eraseblock 2901 at 0x000016aa0000
    Bad eraseblock 2902 at 0x000016ac0000
    Bad eraseblock 2903 at 0x000016ae0000
    Bad eraseblock 2904 at 0x000016b00000
    Bad eraseblock 2905 at 0x000016b20000
    Bad eraseblock 2906 at 0x000016b40000
    Bad eraseblock 2907 at 0x000016b60000
    Bad eraseblock 2908 at 0x000016b80000
    Bad eraseblock 2909 at 0x000016ba0000
    Bad eraseblock 2910 at 0x000016bc0000
    Bad eraseblock 2911 at 0x000016be0000
    Bad eraseblock 2912 at 0x000016c00000
    Bad eraseblock 2913 at 0x000016c20000
    Bad eraseblock 2914 at 0x000016c40000
    Bad eraseblock 2915 at 0x000016c60000
    Bad eraseblock 2916 at 0x000016c80000
    Bad eraseblock 2917 at 0x000016ca0000
    Bad eraseblock 2918 at 0x000016cc0000
    Bad eraseblock 2919 at 0x000016ce0000
    Bad eraseblock 2920 at 0x000016d00000
    Bad eraseblock 2921 at 0x000016d20000
    Bad eraseblock 2922 at 0x000016d40000
    Bad eraseblock 2923 at 0x000016d60000
    Bad eraseblock 2924 at 0x000016d80000
    Bad eraseblock 2925 at 0x000016da0000
    Bad eraseblock 2926 at 0x000016dc0000
    Bad eraseblock 2927 at 0x000016de0000
    Bad eraseblock 2928 at 0x000016e00000
    Bad eraseblock 2929 at 0x000016e20000
    Bad eraseblock 2930 at 0x000016e40000
    Bad eraseblock 2931 at 0x000016e60000
    Bad eraseblock 2932 at 0x000016e80000
    Bad eraseblock 2933 at 0x000016ea0000
    Bad eraseblock 2934 at 0x000016ec0000
    Bad eraseblock 2935 at 0x000016ee0000
    Bad eraseblock 2936 at 0x000016f00000
    Bad eraseblock 2937 at 0x000016f20000
    Bad eraseblock 2938 at 0x000016f40000
    Bad eraseblock 2939 at 0x000016f60000
    Bad eraseblock 2940 at 0x000016f80000
    Bad eraseblock 2941 at 0x000016fa0000
    Bad eraseblock 2942 at 0x000016fc0000
    Bad eraseblock 2943 at 0x000016fe0000
    Bad eraseblock 2944 at 0x000017000000
    Bad eraseblock 2945 at 0x000017020000
    Bad eraseblock 2946 at 0x000017040000
    Bad eraseblock 2947 at 0x000017060000
    Bad eraseblock 2948 at 0x000017080000
    Bad eraseblock 2949 at 0x0000170a0000
    Bad eraseblock 2950 at 0x0000170c0000
    Bad eraseblock 2951 at 0x0000170e0000
    Bad eraseblock 2952 at 0x000017100000
    Bad eraseblock 2953 at 0x000017120000
    Bad eraseblock 2954 at 0x000017140000
    Bad eraseblock 2955 at 0x000017160000
    Bad eraseblock 2956 at 0x000017180000
    Bad eraseblock 2957 at 0x0000171a0000
    Bad eraseblock 2958 at 0x0000171c0000
    Bad eraseblock 2959 at 0x0000171e0000
    Bad eraseblock 2960 at 0x000017200000
    Bad eraseblock 2961 at 0x000017220000
    Bad eraseblock 2962 at 0x000017240000
    Bad eraseblock 2963 at 0x000017260000
    Bad eraseblock 2964 at 0x000017280000
    Bad eraseblock 2965 at 0x0000172a0000
    Bad eraseblock 2966 at 0x0000172c0000
    Bad eraseblock 2967 at 0x0000172e0000
    Bad eraseblock 2968 at 0x000017300000
    Bad eraseblock 2969 at 0x000017320000
    Bad eraseblock 2970 at 0x000017340000
    Bad eraseblock 2971 at 0x000017360000
    Bad eraseblock 2972 at 0x000017380000
    Bad eraseblock 2973 at 0x0000173a0000
    Bad eraseblock 2974 at 0x0000173c0000
    Bad eraseblock 2975 at 0x0000173e0000
    Bad eraseblock 2976 at 0x000017400000
    Bad eraseblock 2977 at 0x000017420000
    Bad eraseblock 2978 at 0x000017440000
    Bad eraseblock 2979 at 0x000017460000
    Bad eraseblock 2980 at 0x000017480000
    Bad eraseblock 2981 at 0x0000174a0000
    Bad eraseblock 2982 at 0x0000174c0000
    [ *ad eraseblock 2983 at 0x0000174e0000
    31m**  ] A start job is running fBad eraseblock 2984 at 0x000017500000
    or Wait for��…beBad eraseblock 2985 at 0x000017520000
     Configured (1min 3s / no limit)Bad eraseblock 2986 at 0x000017540000
    Bad eraseblock 2987 at 0x000017560000
    Bad eraseblock 2988 at 0x000017580000
    Bad eraseblock 2989 at 0x0000175a0000
    Bad eraseblock 2990 at 0x0000175c0000
    Bad eraseblock 2991 at 0x0000175e0000
    Bad eraseblock 2992 at 0x000017600000
    Bad eraseblock 2993 at 0x000017620000
    Bad eraseblock 2994 at 0x000017640000
    Bad eraseblock 2995 at 0x000017660000
    Bad eraseblock 2996 at 0x000017680000
    Bad eraseblock 2997 at 0x0000176a0000
    Bad eraseblock 2998 at 0x0000176c0000
    Bad eraseblock 2999 at 0x0000176e0000
    Bad eraseblock 3000 at 0x000017700000
    Bad eraseblock 3001 at 0x000017720000
    Bad eraseblock 3002 at 0x000017740000
    Bad eraseblock 3003 at 0x000017760000
    Bad eraseblock 3004 at 0x000017780000
    Bad eraseblock 3005 at 0x0000177a0000
    Bad eraseblock 3006 at 0x0000177c0000
    Bad eraseblock 3007 at 0x0000177e0000
    Bad eraseblock 3008 at 0x000017800000
    Bad eraseblock 3009 at 0x000017820000
    Bad eraseblock 3010 at 0x000017840000
    Bad eraseblock 3011 at 0x000017860000
    Bad eraseblock 3012 at 0x000017880000
    Bad eraseblock 3013 at 0x0000178a0000
    Bad eraseblock 3014 at 0x0000178c0000
    Bad eraseblock 3015 at 0x0000178e0000
    Bad eraseblock 3016 at 0x000017900000
    Bad eraseblock 3017 at 0x000017920000
    Bad eraseblock 3018 at 0x000017940000
    Bad eraseblock 3019 at 0x000017960000
    Bad eraseblock 3020 at 0x000017980000
    Bad eraseblock 3021 at 0x0000179a0000
    Bad eraseblock 3022 at 0x0000179c0000
    Bad eraseblock 3023 at 0x0000179e0000
    Bad eraseblock 3024 at 0x000017a00000
    Bad eraseblock 3025 at 0x000017a20000
    Bad eraseblock 3026 at 0x000017a40000
    Bad eraseblock 3027 at 0x000017a60000
    Bad eraseblock 3028 at 0x000017a80000
    Bad eraseblock 3029 at 0x000017aa0000
    Bad eraseblock 3030 at 0x000017ac0000
    Bad eraseblock 3031 at 0x000017ae0000
    Bad eraseblock 3032 at 0x000017b00000
    Bad eraseblock 3033 at 0x000017b20000
    Bad eraseblock 3034 at 0x000017b40000
    Bad eraseblock 3035 at 0x000017b60000
    Bad eraseblock 3036 at 0x000017b80000
    Bad eraseblock 3037 at 0x000017ba0000
    Bad eraseblock 3038 at 0x000017bc0000
    Bad eraseblock 3039 at 0x000017be0000
    Bad eraseblock 3040 at 0x000017c00000
    Bad eraseblock 3041 at 0x000017c20000
    Bad eraseblock 3042 at 0x000017c40000
    Bad eraseblock 3043 at 0x000017c60000
    Bad eraseblock 3044 at 0x000017c80000
    Bad eraseblock 3045 at 0x000017ca0000
    Bad eraseblock 3046 at 0x000017cc0000
    Bad eraseblock 3047 at 0x000017ce0000
    Bad eraseblock 3048 at 0x000017d00000
    Bad eraseblock 3049 at 0x000017d20000
    Bad eraseblock 3050 at 0x000017d40000
    Bad eraseblock 3051 at 0x000017d60000
    Bad eraseblock 3052 at 0x000017d80000
    Bad eraseblock 3053 at 0x000017da0000
    Bad eraseblock 3054 at 0x000017dc0000
    Bad eraseblock 3055 at 0x000017de0000
    Bad eraseblock 3056 at 0x000017e00000
    Bad eraseblock 3057 at 0x000017e20000
    Bad eraseblock 3058 at 0x000017e40000
    Bad eraseblock 3059 at 0x000017e60000
    Bad eraseblock 3060 at 0x000017e80000
    Bad eraseblock 3061 at 0x000017ea0000
    Bad eraseblock 3062 at 0x000017ec0000
    Bad eraseblock 3063 at 0x000017ee0000
    Bad eraseblock 3064 at 0x000017f00000
    Bad eraseblock 3065 at 0x000017f20000
    Bad eraseblock 3066 at 0x000017f40000
    Bad eraseblock 3067 at 0x000017f60000
    Bad eraseblock 3068 at 0x000017f80000
    Bad eraseblock 3069 at 0x000017fa0000
    Bad eraseblock 3070 at 0x000017fc0000
    Bad eraseblock 3071 at 0x000017fe0000
    Bad eraseblock 3072 at 0x000018000000
    Bad eraseblock 3073 at 0x000018020000
    Bad eraseblock 3074 at 0x000018040000
    Bad eraseblock 3075 at 0x000018060000
    [  *ad eraseblock 3076 at 0x000018080000
    ;31m** ] A start job is running fBad eraseblock 3077 at 0x0000180a0000
    or Wait for��…beBad eraseblock 3078 at 0x0000180c0000
     Configured (1min 4s / no limit)Bad eraseblock 3079 at 0x0000180e0000
    Bad eraseblock 3080 at 0x000018100000
    Bad eraseblock 3081 at 0x000018120000
    Bad eraseblock 3082 at 0x000018140000
    Bad eraseblock 3083 at 0x000018160000
    Bad eraseblock 3084 at 0x000018180000
    Bad eraseblock 3085 at 0x0000181a0000
    Bad eraseblock 3086 at 0x0000181c0000
    Bad eraseblock 3087 at 0x0000181e0000
    Bad eraseblock 3088 at 0x000018200000
    Bad eraseblock 3089 at 0x000018220000
    Bad eraseblock 3090 at 0x000018240000
    Bad eraseblock 3091 at 0x000018260000
    Bad eraseblock 3092 at 0x000018280000
    Bad eraseblock 3093 at 0x0000182a0000
    Bad eraseblock 3094 at 0x0000182c0000
    Bad eraseblock 3095 at 0x0000182e0000
    Bad eraseblock 3096 at 0x000018300000
    Bad eraseblock 3097 at 0x000018320000
    Bad eraseblock 3098 at 0x000018340000
    Bad eraseblock 3099 at 0x000018360000
    Bad eraseblock 3100 at 0x000018380000
    Bad eraseblock 3101 at 0x0000183a0000
    Bad eraseblock 3102 at 0x0000183c0000
    Bad eraseblock 3103 at 0x0000183e0000
    Bad eraseblock 3104 at 0x000018400000
    Bad eraseblock 3105 at 0x000018420000
    Bad eraseblock 3106 at 0x000018440000
    Bad eraseblock 3107 at 0x000018460000
    Bad eraseblock 3108 at 0x000018480000
    Bad eraseblock 3109 at 0x0000184a0000
    Bad eraseblock 3110 at 0x0000184c0000
    Bad eraseblock 3111 at 0x0000184e0000
    Bad eraseblock 3112 at 0x000018500000
    Bad eraseblock 3113 at 0x000018520000
    Bad eraseblock 3114 at 0x000018540000
    Bad eraseblock 3115 at 0x000018560000
    Bad eraseblock 3116 at 0x000018580000
    Bad eraseblock 3117 at 0x0000185a0000
    Bad eraseblock 3118 at 0x0000185c0000
    Bad eraseblock 3119 at 0x0000185e0000
    Bad eraseblock 3120 at 0x000018600000
    Bad eraseblock 3121 at 0x000018620000
    Bad eraseblock 3122 at 0x000018640000
    Bad eraseblock 3123 at 0x000018660000
    Bad eraseblock 3124 at 0x000018680000
    Bad eraseblock 3125 at 0x0000186a0000
    Bad eraseblock 3126 at 0x0000186c0000
    Bad eraseblock 3127 at 0x0000186e0000
    Bad eraseblock 3128 at 0x000018700000
    Bad eraseblock 3129 at 0x000018720000
    Bad eraseblock 3130 at 0x000018740000
    Bad eraseblock 3131 at 0x000018760000
    Bad eraseblock 3132 at 0x000018780000
    Bad eraseblock 3133 at 0x0000187a0000
    Bad eraseblock 3134 at 0x0000187c0000
    Bad eraseblock 3135 at 0x0000187e0000
    Bad eraseblock 3136 at 0x000018800000
    Bad eraseblock 3137 at 0x000018820000
    Bad eraseblock 3138 at 0x000018840000
    Bad eraseblock 3139 at 0x000018860000
    Bad eraseblock 3140 at 0x000018880000
    Bad eraseblock 3141 at 0x0000188a0000
    Bad eraseblock 3142 at 0x0000188c0000
    Bad eraseblock 3143 at 0x0000188e0000
    Bad eraseblock 3144 at 0x000018900000
    Bad eraseblock 3145 at 0x000018920000
    Bad eraseblock 3146 at 0x000018940000
    Bad eraseblock 3147 at 0x000018960000
    Bad eraseblock 3148 at 0x000018980000
    Bad eraseblock 3149 at 0x0000189a0000
    Bad eraseblock 3150 at 0x0000189c0000
    Bad eraseblock 3151 at 0x0000189e0000
    Bad eraseblock 3152 at 0x000018a00000
    Bad eraseblock 3153 at 0x000018a20000
    Bad eraseblock 3154 at 0x000018a40000
    Bad eraseblock 3155 at 0x000018a60000
    Bad eraseblock 3156 at 0x000018a80000
    Bad eraseblock 3157 at 0x000018aa0000
    Bad eraseblock 3158 at 0x000018ac0000
    Bad eraseblock 3159 at 0x000018ae0000
    Bad eraseblock 3160 at 0x000018b00000
    Bad eraseblock 3161 at 0x000018b20000
    Bad eraseblock 3162 at 0x000018b40000
    Bad eraseblock 3163 at 0x000018b60000
    Bad eraseblock 3164 at 0x000018b80000
    Bad eraseblock 3165 at 0x000018ba0000
    Bad eraseblock 3166 at 0x000018bc0000
    Bad eraseblock 3167 at 0x000018be0000
    Bad eraseblock 3168 at 0x000018c00000
    [   *ad eraseblock 3169 at 0x000018c20000
    1;31m**] A start job is running fBad eraseblock 3170 at 0x000018c40000
    or Wait for��…be Configured (1min 5s / no limit)Bad eraseblock 3171 at 0x0000180
    Bad eraseblock 3172 at 0x000018c80000
    Bad eraseblock 3173 at 0x000018ca0000
    Bad eraseblock 3174 at 0x000018cc0000
    Bad eraseblock 3175 at 0x000018ce0000
    Bad eraseblock 3176 at 0x000018d00000
    Bad eraseblock 3177 at 0x000018d20000
    Bad eraseblock 3178 at 0x000018d40000
    Bad eraseblock 3179 at 0x000018d60000
    Bad eraseblock 3180 at 0x000018d80000
    Bad eraseblock 3181 at 0x000018da0000
    Bad eraseblock 3182 at 0x000018dc0000
    Bad eraseblock 3183 at 0x000018de0000
    Bad eraseblock 3184 at 0x000018e00000
    Bad eraseblock 3185 at 0x000018e20000
    Bad eraseblock 3186 at 0x000018e40000
    Bad eraseblock 3187 at 0x000018e60000
    Bad eraseblock 3188 at 0x000018e80000
    Bad eraseblock 3189 at 0x000018ea0000
    Bad eraseblock 3190 at 0x000018ec0000
    Bad eraseblock 3191 at 0x000018ee0000
    Bad eraseblock 3192 at 0x000018f00000
    Bad eraseblock 3193 at 0x000018f20000
    Bad eraseblock 3194 at 0x000018f40000
    Bad eraseblock 3195 at 0x000018f60000
    Bad eraseblock 3196 at 0x000018f80000
    Bad eraseblock 3197 at 0x000018fa0000
    Bad eraseblock 3198 at 0x000018fc0000
    Bad eraseblock 3199 at 0x000018fe0000
    Bad eraseblock 3200 at 0x000019000000
    Bad eraseblock 3201 at 0x000019020000
    Bad eraseblock 3202 at 0x000019040000
    Bad eraseblock 3203 at 0x000019060000
    Bad eraseblock 3204 at 0x000019080000
    Bad eraseblock 3205 at 0x0000190a0000
    Bad eraseblock 3206 at 0x0000190c0000
    Bad eraseblock 3207 at 0x0000190e0000
    Bad eraseblock 3208 at 0x000019100000
    Bad eraseblock 3209 at 0x000019120000
    Bad eraseblock 3210 at 0x000019140000
    Bad eraseblock 3211 at 0x000019160000
    Bad eraseblock 3212 at 0x000019180000
    Bad eraseblock 3213 at 0x0000191a0000
    Bad eraseblock 3214 at 0x0000191c0000
    Bad eraseblock 3215 at 0x0000191e0000
    Bad eraseblock 3216 at 0x000019200000
    Bad eraseblock 3217 at 0x000019220000
    Bad eraseblock 3218 at 0x000019240000
    Bad eraseblock 3219 at 0x000019260000
    Bad eraseblock 3220 at 0x000019280000
    Bad eraseblock 3221 at 0x0000192a0000
    Bad eraseblock 3222 at 0x0000192c0000
    Bad eraseblock 3223 at 0x0000192e0000
    Bad eraseblock 3224 at 0x000019300000
    Bad eraseblock 3225 at 0x000019320000
    Bad eraseblock 3226 at 0x000019340000
    Bad eraseblock 3227 at 0x000019360000
    Bad eraseblock 3228 at 0x000019380000
    Bad eraseblock 3229 at 0x0000193a0000
    Bad eraseblock 3230 at 0x0000193c0000
    Bad eraseblock 3231 at 0x0000193e0000
    Bad eraseblock 3232 at 0x000019400000
    Bad eraseblock 3233 at 0x000019420000
    Bad eraseblock 3234 at 0x000019440000
    Bad eraseblock 3235 at 0x000019460000
    Bad eraseblock 3236 at 0x000019480000
    Bad eraseblock 3237 at 0x0000194a0000
    Bad eraseblock 3238 at 0x0000194c0000
    Bad eraseblock 3239 at 0x0000194e0000
    Bad eraseblock 3240 at 0x000019500000
    Bad eraseblock 3241 at 0x000019520000
    Bad eraseblock 3242 at 0x000019540000
    Bad eraseblock 3243 at 0x000019560000
    Bad eraseblock 3244 at 0x000019580000
    Bad eraseblock 3245 at 0x0000195a0000
    Bad eraseblock 3246 at 0x0000195c0000
    Bad eraseblock 3247 at 0x0000195e0000
    Bad eraseblock 3248 at 0x000019600000
    Bad eraseblock 3249 at 0x000019620000
    Bad eraseblock 3250 at 0x000019640000
    Bad eraseblock 3251 at 0x000019660000
    [    **] A start job is running for Wait for��…be Configured (1min 6s / no limi1
    Bad block table written to 0x00001ffc0000, version 0x01
    3 fixed-partitions partitions found on MTD device 62000000.nand
    Creating 3 MTD partitions on "62000000.nand":
    0x000000000000-0x000000020000 : "u-boot env"
    0x000000020000-0x0000000a0000 : "u-boot"
    0x0000000a0000-0x000020000000 : "free space"
    davinci_nand 62000000.nand: controller rev. 2.5
    alloc_contig_range: [c6440, c6441) PFNs busy
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Matrix GUI...
             Starting Permit User Sessions...
             Starting TI IPC Daemon...
             Starting Avahi mDNS/DNS-SD Stack...
             Starting System Logger Daemon "default" instance...
    [  OK  ] Started Vsftpd ftp daemon.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
    [  OK  ] Started Periodic Command Scheduler.
             Starting telnetd.service...
             Starting Lightning Fast Webserver With Light System Requirements...
    [  OK  ] Started D-Bus System Message Bus.
             Starting Login Service...
             Starting RPC Bind Service...
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
    [  OK  ] Started System Logger Daemon "default" instance.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started Matrix GUI.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started TI IPC Daemon.
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started Lightning Fast Webserver With Light System Requirements.
    [  OK  ] Started RPC Bind Service.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting thttpd.service...
             Starting syslog.service...
    [  OK  ] Reached target Sound Card.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Started thttpd.service.
    [  OK  ] Started Synchronize System and HW clocks.
    [  OK  ] Started Login Service.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started syslog.service.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org omapl138-lcdk ttyS2
    Arago 2019.11 omapl138-lcdk ttyS2
    omapl138-lcdk login: root
    NET: Registered protocol family 15
    Initializing XFRM netlink socket
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash
            bc
            binutils
            cifs-utils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            gstreamer1.0-libav
            gzip
            hidapi
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libreadline7
            libunistring2
            m4
            make
            nettle
            which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    root@omapl138-lcdk:~# 2020 Apr 19 02:12:20 omapl138-lcdk bind 0.0.0.0 - Addresse
    2020 Apr 19 02:12:20 omapl138-lcdk bind 0.0.0.0 - Address already in use
    root@omapl138-lcdk:~# ip addr add 192.168.1.100/24 dev eth0
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
        link/sit 0.0.0.0 brd 0.0.0.0
    3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
        link/ether 72:a4:ca:a3:e6:e3 brd ff:ff:ff:ff:ff:ff
        inet 192.168.1.100/24 scope global eth0
        inet6 fe80::70a4:caff:fea3:e6e3/64 scope link
    root@omapl138-lcdk:~# ethtool eth0
    Settings for eth0:
            Supported ports: [ TP MII ]
            Supported link modes:   10baseT/Half 10baseT/Full
                                    100baseT/Half 100baseT/Full
            Supported pause frame use: Symmetric Receive-only
            Supports auto-negotiation: Yes
            Supported FEC modes: Not reported
            Advertised link modes:  10baseT/Half 10baseT/Full
            Advertised pause frame use: No
            Advertised auto-negotiation: Yes
            Advertised FEC modes: Not reported
            Link partner advertised link modes:  10baseT/Half 10baseT/Full
            Link partner advertised pause frame use: Symmetric
            Link partner advertised auto-negotiation: No
            Link partner advertised FEC modes: Not reported
            Speed: 100Mb/s
            Duplex: Full
            Port: MII
            PHYAD: 1
            Transceiver: internal
            Auto-negotiation: on
            Link detected: yes
    root@omapl138-lcdk:~# ethtool -S eth0
    no stats available
    I am seeing link is up and the switch is up on MDIO. I see ethtool showing that there is a link and a bit rate as well as a static IP address is added. What the ping command look like? Is the address being pinged on the same subnet as your board?
    Schuyler
        There is no ping to outside the board. I am pinging to 192.168.1.101 ie to my laptop. But I am not getting any ping. From my laptop I tried to ping my board but its not getting a good result. I did every changes on SDKv6.03. I don't know this version support RMII interface. What are the changes that I have to make u-boot to work in RMII interface. I think firstly I will try to get the u-boot a successful ping after that I will change the Kernel. If my u-boot get the ping successfully, I can verify that my schematic is good for a healthy communication in RMII interface. Thanks in advance for your help
    I was hoping for ethtool -S to return the MAC statistics so you can see if any packets are being received/transmitted or not. Can you please attach the dts file for your board?
    I looked at the driver source for the device and RMII support was added in the 6.1 SDK. This is the link to the DTS binding document for the emac on the device.
    The document describes this variable that will to be added to your device tree source file. When set the property will tell the driver to use RMII mode.
    ti,davinci-rmii-en
    I don't have an exact example but if you follow the document example I would recommend trying this in the ethernet node:
    ti,davinci-rmii-en = <1>;
    I need to point out that the OMAPL138 is an older device that TI may be limited in the support that can be provided.
    Schuyler
  • Hi Schuyler,
         Here I am attaching my dts file.
     * Copyright (c) 2016 BayLibre, Inc.
     * Licensed under GPLv2.
    /dts-v1/;
    #include "da850.dtsi"
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/input/input.h>
    	model = "DA850/AM1808/OMAP-L138 LCDK";
    	compatible = "ti,da850-lcdk", "ti,da850";
    	aliases {
    		serial2 = &serial2;
    		ethernet0 = &eth0;
    	chosen {
    		stdout-path = "serial2:115200n8";
    	memory {
    		device_type = "memory";
    		reg = <0xc0000000 0x08000000>;
    	reserved-memory {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		ranges;
    		dsp_cma_pool: dsp_cma@c3000000 {
    			compatible = "shared-dma-pool";
    			reg = <0xc3000000 0x1000000>;
    			reusable;
    			status = "okay";
    	sound {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "DA850/OMAP-L138 LCDK";
    		simple-audio-card,widgets =
    			"Line", "Line In",
    			"Line", "Line Out";
    		simple-audio-card,routing =
    			"LINE1L", "Line In",
    			"LINE1R", "Line In",
    			"Line Out", "LLOUT",
    			"Line Out", "RLOUT";
    		simple-audio-card,format = "dsp_b";
    		simple-audio-card,bitclock-master = <&link0_codec>;
    		simple-audio-card,frame-master = <&link0_codec>;
    		simple-audio-card,bitclock-inversion;
    		simple-audio-card,cpu {
    			sound-dai = <&mcasp0>;
    			system-clock-frequency = <24576000>;
    		link0_codec: simple-audio-card,codec {
    			sound-dai = <&tlv320aic3106>;
    	gpio-keys {
    		compatible = "gpio-keys";
    		autorepeat;
    		user1 {
    			label = "GPIO Key USER1";
    			linux,code = <BTN_0>;
    			gpios = <&gpio 36 GPIO_ACTIVE_LOW>;
    		user2 {
    			label = "GPIO Key USER2";
    			linux,code = <BTN_1>;
    			gpios = <&gpio 37 GPIO_ACTIVE_LOW>;
    	vga-bridge {
    		compatible = "ti,ths8135";
    		#size-cells = <0>;
    		ports {
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				vga_bridge_in: endpoint {
    					remote-endpoint = <&lcdc_out_vga>;
    			port@1 {
    				reg = <1>;
    				vga_bridge_out: endpoint {
    					remote-endpoint = <&vga_con_in>;
    	vga {
    		compatible = "vga-connector";
    		ddc-i2c-bus = <&i2c0>;
    		port {
    			vga_con_in: endpoint {
    				remote-endpoint = <&vga_bridge_out>;
    &pmx_core {
    	status = "okay";
    	mcasp0_pins: pinmux_mcasp0_pins {
    		pinctrl-single,bits = <
    			/* AHCLKX AFSX ACLKX */
    			0x00 0x00101010 0x00f0f0f0
    			/* ARX13 ARX14 */
    			0x04 0x00000110 0x00000ff0
    	nand_pins: nand_pins {
    			/* EMA_WAIT[0], EMA_OE, EMA_WE, EMA_CS[3] */
    			0x1c 0x10110010  0xf0ff00f0
    			 * EMA_D[0], EMA_D[1], EMA_D[2],
    			 * EMA_D[3], EMA_D[4], EMA_D[5],
    			 * EMA_D[6], EMA_D[7]
    			0x24 0x11111111  0xffffffff
    			 * EMA_D[8],  EMA_D[9],  EMA_D[10],
    			 * EMA_D[11], EMA_D[12], EMA_D[13],
    			 * EMA_D[14], EMA_D[15]
    			0x20 0x11111111  0xffffffff
    			/* EMA_A[1], EMA_A[2] */
    			0x30 0x01100000  0x0ff00000
    &serial2 {
    	pinctrl-names = "default";
    	pinctrl-0 = <&serial2_rxtx_pins>;
    	status = "okay";
    &wdt {
    	status = "okay";
    &rtc0 {
    	status = "okay";
    &gpio {
    	status = "okay";
    &sata {
    	status = "okay";
    &mdio {
    	pinctrl-0 = <&mdio_pins>;
    	bus_freq = <2200000>;
    	status = "okay";
    &eth0 {
    	pinctrl-0 = <&rmii_pins>;
    	phy-mode = "rmii";
    	phy-connection-type = "rmii";
    	status = "okay";
    &mmc0 {
    	max-frequency = <50000000>;
    	bus-width = <4>;
    	pinctrl-0 = <&mmc0_pins>;
    	cd-gpios = <&gpio 64 GPIO_ACTIVE_LOW>;
    	status = "okay";
    &i2c0 {
    	pinctrl-0 = <&i2c0_pins>;
    	clock-frequency = <100000>;
    	status = "okay";
    	tlv320aic3106: tlv320aic3106@18 {
    		#sound-dai-cells = <0>;
    		compatible = "ti,tlv320aic3106";
    		reg = <0x18>;
    		status = "okay";
    &mcasp0 {
    	pinctrl-0 = <&mcasp0_pins>;
    	status = "okay";
    	op-mode = <0>;   /* DAVINCI_MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	serial-dir = <   /* 0: INACTIVE, 1: TX, 2: RX */
    		0 0 0 0
    		0 0 0 0
    		0 0 0 0
    		0 1 2 0
    	tx-num-evt = <32>;
    	rx-num-evt = <32>;
    &usb_phy {
    	status = "okay";
    &usb0 {
    	status = "okay";
    &usb1 {
    	status = "okay";
    /*&cfgchip {
           //pinctrl-names = "default";
           //pinctrl-0 = <&rmii_en>;
           status = "okay";
           rmii_en: cfgchip3_pins {
                            /* RMII_SEL */
                            0x0c 0x00000100 0x00000100
           //status = "okay";
    &aemif {
    	pinctrl-0 = <&nand_pins>;
    	status = "okay";
    	cs3 {
    		#address-cells = <2>;
    		#size-cells = <1>;
    		clock-ranges;
    		ranges;
    		ti,cs-chipselect = <3>;
    		nand@2000000,0 {
    			compatible = "ti,davinci-nand";
    			#size-cells = <1>;
    			reg = <0 0x02000000 0x02000000
    			       1 0x00000000 0x00008000>;
    			ti,davinci-chipselect = <1>;
    			ti,davinci-mask-ale = <0>;
    			ti,davinci-mask-cle = <0>;
    			ti,davinci-mask-chipsel = <0>;
    			ti,davinci-nand-buswidth = <16>;
    			ti,davinci-ecc-mode = "hw";
    			ti,davinci-ecc-bits = <4>;
    			ti,davinci-nand-use-bbt;
    			 * The OMAP-L132/L138 Bootloader doc SPRAB41E reads:
    			 * "To boot from NAND Flash, the AIS should be written
    			 * to NAND block 1 (NAND block 0 is not used by default)".
    			 * The same doc mentions that for ROM "Silicon Revision 2.1",
    			 * "Updated NAND boot mode to offer boot from block 0 or block 1".
    			 * However the limitaion is left here by default for compatibility
    			 * with older silicon and because it needs new boot pin settings
    			 * not possible in stock LCDK.
    			partitions {
    				compatible = "fixed-partitions";
    				#size-cells = <1>;
    				partition@0 {
    					label = "u-boot env";
    					reg = <0 0x020000>;
    				partition@0x020000 {
    					/* The LCDK defaults to booting from this partition */
    					label = "u-boot";
    					reg = <0x020000 0x080000>;
    				partition@0x0a0000 {
    					label = "free space";
    					reg = <0x0a0000 0>;
    &prictrl {
    	status = "okay";
    &memctrl {
    	status = "okay";
    &lcdc {
    	status = "okay";
    	pinctrl-0 = <&lcd_pins>;
    	port {
    		lcdc_out_vga: endpoint {
    			remote-endpoint = <&vga_bridge_in>;
    &vpif {
    	pinctrl-0 = <&vpif_capture_pins>;
    	status = "okay";
    	/* VPIF capture port */
    	port {
    		vpif_ch0: endpoint {
    			  bus-width = <8>;
    &dsp {
    	status = "okay";
    	memory-region = <&dsp_cma_pool>;
    I can change the pinmux correctly ie  at location 0x01c14158h and 0x01c1415ch. But I don't know how to change the value in 0x01c14188h. This address relate with Chip Configuration 3 Register (CFGCHIP3). In that rmii select bit exist. I added the above mentioned line "ti,davinci-rmii-en = <1>;" in dtsi file. I tried "ti,davinci-rmii-en = /bits/ 8 <1>;"But both ways not working. Is there any way to select that bit to high in CFGCHIP3.
    I am also including my dtsi file into this message.
     * Copyright 2012 DENX Software Engineering GmbH
     * Heiko Schocher <hs@denx.de>
     * This program is free software; you can redistribute  it and/or modify it
     * under  the terms of  the GNU General  Public License as published by the
     * Free Software Foundation;  either version 2 of the  License, or (at your
     * option) any later version.
    #include "skeleton.dtsi"
    #include <dt-bindings/interrupt-controller/irq.h>
    	aliases {
    		rproc0 = &dsp;
    	arm {
    		#size-cells = <1>;
    		ranges;
    		intc: interrupt-controller@fffee000 {
    			compatible = "ti,cp-intc";
    			interrupt-controller;
    			#interrupt-cells = <1>;
    			ti,intc-size = <101>;
    			reg = <0xfffee000 0x2000>;
    	dsp: dsp@11800000 {
    		compatible = "ti,da850-dsp";
    		reg = <0x11800000 0x40000>,
    		      <0x11e00000 0x8000>,
    		      <0x11f00000 0x8000>,
    		      <0x01c14044 0x4>,
    		      <0x01c14174 0x8>;
    		reg-names = "l2sram", "l1pram", "l1dram", "host1cfg", "chipsig";
    		interrupt-parent = <&intc>;
    		interrupts = <28>;
    		status = "disabled";
    	soc@1c00000 {
    		compatible = "simple-bus";
    		model = "da850";
    		#size-cells = <1>;
    		ranges = <0x0 0x01c00000 0x400000>;
    		pmx_core: pinmux@14120 {
    			compatible = "pinctrl-single";
    			reg = <0x14120 0x50>;
    			#size-cells = <0>;
    			#pinctrl-cells = <2>;
    			pinctrl-single,bit-per-mux;
    			pinctrl-single,register-width = <32>;
    			pinctrl-single,function-mask = <0xf>;
    			serial0_rtscts_pins: pinmux_serial0_rtscts_pins {
    					/* UART0_RTS UART0_CTS */
    					0x0c 0x22000000 0xff000000
    			serial0_rxtx_pins: pinmux_serial0_rxtx_pins {
    					/* UART0_TXD UART0_RXD */
    					0x0c 0x00220000 0x00ff0000
    			serial1_rtscts_pins: pinmux_serial1_rtscts_pins {
    					/* UART1_CTS UART1_RTS */
    					0x00 0x00440000 0x00ff0000
    			serial1_rxtx_pins: pinmux_serial1_rxtx_pins {
    					/* UART1_TXD UART1_RXD */
    					0x10 0x22000000 0xff000000
    			serial2_rtscts_pins: pinmux_serial2_rtscts_pins {
    					/* UART2_CTS UART2_RTS */
    					0x00 0x44000000 0xff000000
    			serial2_rxtx_pins: pinmux_serial2_rxtx_pins {
    					/* UART2_TXD UART2_RXD */
    					0x10 0x00220000 0x00ff0000
    			i2c0_pins: pinmux_i2c0_pins {
    					/* I2C0_SDA,I2C0_SCL */
    					0x10 0x00002200 0x0000ff00
    			i2c1_pins: pinmux_i2c1_pins {
    					/* I2C1_SDA, I2C1_SCL */
    					0x10 0x00440000 0x00ff0000
    			mmc0_pins: pinmux_mmc_pins {
    					/* MMCSD0_DAT[3] MMCSD0_DAT[2]
    					 * MMCSD0_DAT[1] MMCSD0_DAT[0]
    					 * MMCSD0_CMD    MMCSD0_CLK
    					0x28 0x00222222  0x00ffffff
    			ehrpwm0a_pins: pinmux_ehrpwm0a_pins {
    					/* EPWM0A */
    					0xc 0x00000002 0x0000000f
    			ehrpwm0b_pins: pinmux_ehrpwm0b_pins {
    					/* EPWM0B */
    					0xc 0x00000020 0x000000f0
    			ehrpwm1a_pins: pinmux_ehrpwm1a_pins {
    					/* EPWM1A */
    					0x14 0x00000002 0x0000000f
    			ehrpwm1b_pins: pinmux_ehrpwm1b_pins {
    					/* EPWM1B */
    					0x14 0x00000020 0x000000f0
    			ecap0_pins: pinmux_ecap0_pins {
    					/* ECAP0_APWM0 */
    					0x8 0x20000000 0xf0000000
    			ecap1_pins: pinmux_ecap1_pins {
    					/* ECAP1_APWM1 */
    					0x4 0x40000000 0xf0000000
    			ecap2_pins: pinmux_ecap2_pins {
    					/* ECAP2_APWM2 */
    					0x4 0x00000004 0x0000000f
    			spi0_pins: pinmux_spi0_pins {
    					/* SIMO, SOMI, CLK */
    					0xc 0x00001101 0x0000ff0f
    			spi0_cs0_pin: pinmux_spi0_cs0 {
    					/* CS0 */
    					0x10 0x00000010 0x000000f0
    			spi1_pins: pinmux_spi1_pins {
    					0x14 0x00110100 0x00ff0f00
    			spi1_cs0_pin: pinmux_spi1_cs0 {
    					/* CS0 */
    					0x14 0x00000010 0x000000f0
    			mdio_pins: pinmux_mdio_pins {
    					/* MDIO_CLK, MDIO_D */
    					0x10 0x00000088 0x000000ff
    			rmii_pins: pinmux_rmii_pins {
    					 * RMII_TXD_1, RMII_TXD_0, RMII_TXEN
    					 * RMII_RXD_1, RMII_RXN_0, RMII_RXER
    					0x38 0x88888800 0xffffff00
    					 * RMII_MHZ_50_CLK, RMII_CRS_DV
    					0x3c 0x00000080 0x000000ff
    			lcd_pins: pinmux_lcd_pins {
    					 * LCD_D[2], LCD_D[3], LCD_D[4], LCD_D[5],
    					 * LCD_D[6], LCD_D[7]
    					0x40 0x22222200 0xffffff00
    					 * LCD_D[10], LCD_D[11], LCD_D[12], LCD_D[13],
    					 * LCD_D[14], LCD_D[15], LCD_D[0], LCD_D[1]
    					0x44 0x22222222 0xffffffff
    					/* LCD_D[8], LCD_D[9] */
    					0x48 0x00000022 0x000000ff
    					/* LCD_PCLK */
    					0x48 0x02000000 0x0f000000
    					/* LCD_AC_ENB_CS, LCD_VSYNC, LCD_HSYNC */
    					0x4c 0x02000022 0x0f0000ff
    			vpif_capture_pins: vpif_capture_pins {
    					/* VP_DIN[2..7], VP_CLKIN1, VP_CLKIN0 */
    					/*0x38 0x11111111 0xffffffff*/
    					/* VP_DIN[10..15,0..1] */
    					/*0x3c 0x11111111 0xffffffff*/
    					/* VP_DIN[8..9] */
    					0x40 0x00000011 0x000000ff
    			vpif_display_pins: vpif_display_pins {
    					/* VP_DOUT[2..7] */
    					0x40 0x11111100 0xffffff00
    					/* VP_DOUT[10..15,0..1] */
    					0x44 0x11111111 0xffffffff
    					/*  VP_DOUT[8..9] */
    					0x48 0x00000011 0x000000ff
    					 * VP_CLKOUT3, VP_CLKIN3,
    					 * VP_CLKOUT2, VP_CLKIN2
    					0x4c 0x00111100 0x00ffff00
    		prictrl: priority-controller@14110 {
    			compatible = "ti,da850-mstpri";
    			reg = <0x14110 0x0c>;
    		cfgchip: chip-controller@1417c {
    			compatible = "ti,da830-cfgchip", "syscon", "simple-mfd";
    			reg = <0x1417c 0x14>;
    			usb_phy: usb-phy {
    				compatible = "ti,da830-usb-phy";
    				#phy-cells = <1>;
    		edma0: edma@0 {
    			compatible = "ti,edma3-tpcc";
    			/* eDMA3 CC0: 0x01c0 0000 - 0x01c0 7fff */
    			reg =	<0x0 0x8000>;
    			reg-names = "edma3_cc";
    			interrupts = <11 12>;
    			interrupt-names = "edma3_ccint", "edma3_ccerrint";
    			#dma-cells = <2>;
    			ti,tptcs = <&edma0_tptc0 7>, <&edma0_tptc1 0>;
    		edma0_tptc0: tptc@8000 {
    			compatible = "ti,edma3-tptc";
    			reg =	<0x8000 0x400>;
    			interrupts = <13>;
    			interrupt-names = "edm3_tcerrint";
    		edma0_tptc1: tptc@8400 {
    			reg =	<0x8400 0x400>;
    			interrupts = <32>;
    		edma1: edma@230000 {
    			/* eDMA3 CC1: 0x01e3 0000 - 0x01e3 7fff */
    			reg =	<0x230000 0x8000>;
    			interrupts = <93 94>;
    			#dma-cells = <2>;
    			ti,tptcs = <&edma1_tptc0 7>;
    		edma1_tptc0: tptc@238000 {
    			reg =	<0x238000 0x400>;
    			interrupts = <95>;
    		serial0: serial@42000 {
    			compatible = "ti,da830-uart", "ns16550a";
    			reg = <0x42000 0x100>;
    			reg-io-width = <4>;
    			reg-shift = <2>;
    			interrupts = <25>;
    		serial1: serial@10c000 {
    			reg = <0x10c000 0x100>;
    			reg-io-width = <4>;
    			reg-shift = <2>;
    			interrupts = <53>;
    		serial2: serial@10d000 {
    			reg = <0x10d000 0x100>;
    			reg-io-width = <4>;
    			reg-shift = <2>;
    			interrupts = <61>;
    		rtc0: rtc@23000 {
    			compatible = "ti,da830-rtc";
    			reg = <0x23000 0x1000>;
    			interrupts = <19
    				      19>;
    		i2c0: i2c@22000 {
    			compatible = "ti,davinci-i2c";
    			reg = <0x22000 0x1000>;
    			interrupts = <15>;
    			#size-cells = <0>;
    		i2c1: i2c@228000 {
    			reg = <0x228000 0x1000>;
    			interrupts = <51>;
    			#size-cells = <0>;
    		wdt: wdt@21000 {
    			compatible = "ti,davinci-wdt";
    			reg = <0x21000 0x1000>;
    		mmc0: mmc@40000 {
    			compatible = "ti,da830-mmc";
    			reg = <0x40000 0x1000>;
    			cap-sd-highspeed;
    			cap-mmc-highspeed;
    			interrupts = <16>;
    			dmas = <&edma0 16 0>, <&edma0 17 0>;
    			dma-names = "rx", "tx";
    		vpif: video@217000 {
    			compatible = "ti,da850-vpif";
    			reg = <0x217000 0x1000>;
    			interrupts = <92>;
    			port@0 {
    				#size-cells = <0>;
    			/* VPIF display port */
    			port@1 {
    				#size-cells = <0>;
    		mmc1: mmc@21b000 {
    			reg = <0x21b000 0x1000>;
    			cap-sd-highspeed;
    			cap-mmc-highspeed;
    			interrupts = <72>;
    			dmas = <&edma1 28 0>, <&edma1 29 0>;
    		ehrpwm0: pwm@300000 {
    			compatible = "ti,da850-ehrpwm", "ti,am3352-ehrpwm",
    				     "ti,am33xx-ehrpwm";
    			#pwm-cells = <3>;
    			reg = <0x300000 0x2000>;
    		ehrpwm1: pwm@302000 {
    				     "ti,am33xx-ehrpwm";
    			#pwm-cells = <3>;
    			reg = <0x302000 0x2000>;
    		ecap0: ecap@306000 {
    			compatible = "ti,da850-ecap", "ti,am3352-ecap",
    				     "ti,am33xx-ecap";
    			#pwm-cells = <3>;
    			reg = <0x306000 0x80>;
    		ecap1: ecap@307000 {
    				     "ti,am33xx-ecap";
    			#pwm-cells = <3>;
    			reg = <0x307000 0x80>;
    		ecap2: ecap@308000 {
    				     "ti,am33xx-ecap";
    			#pwm-cells = <3>;
    			reg = <0x308000 0x80>;
    		spi0: spi@41000 {
    			#size-cells = <0>;
    			compatible = "ti,da830-spi";
    			reg = <0x41000 0x1000>;
    			num-cs = <6>;
    			ti,davinci-spi-intr-line = <1>;
    			interrupts = <20>;
    			dmas = <&edma0 14 0>, <&edma0 15 0>;
    		spi1: spi@30e000 {
    			#size-cells = <0>;
    			reg = <0x30e000 0x1000>;
    			num-cs = <4>;
    			interrupts = <56>;
    			dmas = <&edma0 18 0>, <&edma0 19 0>;
    		usb0: usb@200000 {
    			compatible = "ti,da830-musb";
    			reg = <0x200000 0x1000>;
    			ranges;
    			interrupts = <58>;
    			interrupt-names = "mc";
    			dr_mode = "otg";
    			phys = <&usb_phy 0>;
    			phy-names = "usb-phy";
    			#size-cells = <1>;
    			dmas = <&cppi41dma 0 0 &cppi41dma 1 0
    				&cppi41dma 2 0 &cppi41dma 3 0
    				&cppi41dma 0 1 &cppi41dma 1 1
    				&cppi41dma 2 1 &cppi41dma 3 1>;
    			dma-names =
    				"rx1", "rx2", "rx3", "rx4",
    				"tx1", "tx2", "tx3", "tx4";
    			cppi41dma: dma-controller@201000 {
    				compatible = "ti,da830-cppi41";
    				reg =  <0x201000 0x1000
    					0x202000 0x1000
    					0x204000 0x4000>;
    				reg-names = "controller",
    					    "scheduler", "queuemgr";
    				interrupts = <58>;
    				#dma-cells = <2>;
    				#dma-channels = <4>;
    				status = "okay";
    		sata: sata@218000 {
    			compatible = "ti,da850-ahci";
    			reg = <0x218000 0x2000>, <0x22c018 0x4>;
    			interrupts = <67>;
    		mdio: mdio@224000 {
    			compatible = "ti,davinci_mdio";
    			#size-cells = <0>;
    			reg = <0x224000 0x1000>;
    		eth0: ethernet@220000 {
    			compatible = "ti,davinci-dm6467-emac";
    			reg = <0x220000 0x4000>;
    			ti,davinci-ctrl-reg-offset = <0x3000>;
    			ti,davinci-ctrl-mod-reg-offset = <0x2000>;
    			ti,davinci-ctrl-ram-offset = <0>;
    			ti,davinci-ctrl-ram-size = <0x2000>;
    			local-mac-address = [ 00 00 00 00 00 00 ];
    			interrupts = <33
    					34
    					35
    					36
    		usb1: usb@225000 {
    			compatible = "ti,da830-ohci";
    			reg = <0x225000 0x1000>;
    			interrupts = <59>;
    			phys = <&usb_phy 1>;
    		gpio: gpio@226000 {
    			compatible = "ti,dm6441-gpio";
    			gpio-controller;
    			#gpio-cells = <2>;
    			reg = <0x226000 0x1000>;
    			interrupts = <42 IRQ_TYPE_EDGE_BOTH
    				43 IRQ_TYPE_EDGE_BOTH 44 IRQ_TYPE_EDGE_BOTH
    				45 IRQ_TYPE_EDGE_BOTH 46 IRQ_TYPE_EDGE_BOTH
    				47 IRQ_TYPE_EDGE_BOTH 48 IRQ_TYPE_EDGE_BOTH
    				49 IRQ_TYPE_EDGE_BOTH 50 IRQ_TYPE_EDGE_BOTH>;
    			ti,ngpio = <144>;
    			ti,davinci-gpio-unbanked = <0>;
    		pinconf: pin-controller@22c00c {
    			compatible = "ti,da850-pupd";
    			reg = <0x22c00c 0x8>;
    		mcasp0: mcasp@100000 {
    			compatible = "ti,da830-mcasp-audio";
    			reg = <0x100000 0x2000>,
    			      <0x102000 0x400000>;
    			reg-names = "mpu", "dat";
    			interrupts = <54>;
    			interrupt-names = "common";
    			dmas = <&edma0 1 1>,
    				<&edma0 0 1>;
    			dma-names = "tx", "rx";
    		lcdc: display@213000 {
    			compatible = "ti,da850-tilcdc";
    			reg = <0x213000 0x1000>;
    			interrupts = <52>;
    			max-pixelclock = <37500>;
    	aemif: aemif@68000000 {
    		compatible = "ti,da850-aemif";
    		#size-cells = <1>;
    		reg = <0x68000000 0x00008000>;
    		ranges = <0 0 0x60000000 0x08000000
    			  1 0 0x68000000 0x00008000>;
    	memctrl: memory-controller@b0000000 {
    		compatible = "ti,da850-ddr-controller";
    		reg = <0xb0000000 0xe8>;
    Is there any changes should I made in the menuconfig for kernel and u-boot.
    Adding with this, I tried to change the chip register value from u-boot and did the ping function. At that time message is like "host 192.168.1.101 is alive". My board ip address is 192.168.1.100. I thing this means that my board can communicate with my laptop in RMII interface. How to set the chip register value in linux.
    After looking at the configuration register you mentioned I think you are on the right track. Looking through the board file there is a Linux kernel config that possibly sets the bit pointed out that needs to be set. Please try this setting this config option and rebuild the kernel, drivers and install.
    DA850_UI_RMII
    Schuyler
       I kernel menuconfig I tried to add RMII in expansion section. But that also didn't work. Anyway I will try this.
       I made the change that suggested, but I didn't get a result.
       Any way to change the register value. I tried using mmap to change the register value but its no use. I checked the memory location 0x01C1 4024h and found that silicon revision is 0x35. So the KICK0 and KICK1 registers are not in use. So we can directly write the values into the System Configuration Module registers. But I can't change that. Can you please provide me a way to change the register value through mmap or through the kernel driver code.
    The only thing I can recommend at the moment is to look at this file try making sure this line is executed based on the kernel config I mentioned.
    Try putting printk around line 364 to make sure this code is being executed. I don't have an mmap example. Is devmem2 in the file system you are using?
    Schuyler
        I tried to change the value devmem2. But that also didn't help. I am not using expansion module. I am using only RMII interface instead of MII interface. According to your reference I put two printk fn() in two location 1. __init da850_evm_config_emac fn() after 1033 line and 2. static inline void da850_evm_setup_emac_rmii after 356 line. Only one print is coming ie the first fn only executing and also rmii_en value is zero. I am using sdk v4.03. I check same thing in sdkv6.03
        I changed some lines in __init da850_evm_config_emac() after that I got the ethernet communication successfully. But while booting it shows some warning or errors. I am attaching the boot log along with this.
    U-Boot 2017.01-00458-g05f88aac84-dirty (Mar 21 2024 - 05:52:04 -0700)
    I2C:   ready
    DRAM:  128 MiB
    WARNING: Caches not enabled
    NAND:  512 MiB
    MMC:   davinci: 0
    *** Warning - bad CRC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Invalid MAC address read.
    Net:   DaVinci-EMAC
    Warning: DaVinci-EMAC (eth0) using random MAC address - 72:34:db:ae:92:d8
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    reading boot.scr
    ** Unable to read file boot.scr **
    reading uEnv.txt
    ** Unable to read file uEnv.txt **
    2383208 bytes read in 2809 ms (828.1 KiB/s)
    13445 bytes read in 58 ms (225.6 KiB/s)
    ## Flattened Device Tree blob at c0600000
       Booting using the fdt blob at 0xc0600000
       Loading Device Tree to c7e21000, end c7e27484 ... OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Booting Linux on physical CPU 0x0
    Linux version 4.9.69-g9ce43c71ae (spgdd@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 PREEMPT Sun Mar 24 23:15:02 PDT 2024
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
    CPU: VIVT data cache, VIVT instruction cache
    OF: fdt:Machine model: DA850/AM1808/OMAP-L138 LCDK
    Reserved memory: created CMA memory pool at 0xc3000000, size 16 MiB
    OF: reserved mem: initialized node dsp_cma@c3000000, compatible id shared-dma-pool
    cma: Reserved 16 MiB at 0xc6c00000
    Memory policy: Data cache writethrough
    DaVinci da850/omap-l138/am18x variant 0x1
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32480
    Kernel command line: console=ttyS2,115200n8 root=PARTUUID=f3fdc285-02 rw rootfstype=ext4 rootwait
    PID hash table entries: 512 (order: -1, 2048 bytes)
    Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Memory: 90120K/131072K available (4564K kernel code, 312K rwdata, 1460K rodata, 224K init, 162K bss, 8184K reserved, 32768K cma-reserved)
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xc8800000 - 0xff800000   ( 880 MB)
        lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
        modules : 0xbf000000 - 0xc0000000   (  16 MB)
          .text : 0xc0008000 - 0xc047d6f0   (4566 kB)
          .init : 0xc05ec000 - 0xc0624000   ( 224 kB)
          .data : 0xc0624000 - 0xc0672030   ( 313 kB)
           .bss : 0xc0672030 - 0xc069ab68   ( 163 kB)
    SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    Preemptible hierarchical RCU implementation.
            Build-time adjustment of leaf fanout to 32.
    NR_IRQS:245
    clocksource: timer0_1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    Console: colour dummy device 80x30
    Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    CPU: Testing write buffer coherency: ok
    Setting up static identity map for 0xc0008400 - 0xc0008458
    devtmpfs: initialized
    VFP support v0.3: not present
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 256 (order: -1, 3072 bytes)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    cpuidle: using governor ladder
    cpuidle: using governor menu
    mux: initialized RTC_ALARM
    mux: Setting register RTC_ALARM
    mux:    PINMUX0 (0x00000000) = 0x44080000 -> 0x24080000
    No ATAGs?
    edma 1c00000.edma: memcpy is disabled
    edma 1c00000.edma: TI EDMA DMA engine driver
    edma 1e30000.edma: memcpy is disabled
    edma 1e30000.edma: TI EDMA DMA engine driver
    i2c_davinci i2c_davinci.1: could not find pctldev for node /soc@1c00000/pinmux@14120/pinmux_i2c0_pins, deferring probe
    clocksource: Switched to clocksource timer0_1
    NET: Registered protocol family 2
    TCP established hash table entries: 1024 (order: 0, 4096 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    ***ETHERNET RMII CONFIG FUNCTION***1
    ***ETHERNET RMII MACHINE CHECK***
    ***ETHERNET RMII BEFORE if***1
    ***ETHERNET RMII Value***65296
    EMAC: RMII PHY configured, MII PHY will not be functional
    mux: initialized GPIO2_6
    mux: Setting register GPIO2_6
    mux:    PINMUX6 (0x00000018) = 0x00000000 -> 0x00000080
    ***ETHERNET RMII Value Again***65296
    ------------[ cut here ]------------
    WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x5c/0x7c
    sysfs: cannot create duplicate filename '/bus/platform/devices/davinci_mdio.0'
    Modules linked in:
    CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.69-g9ce43c71ae #1
    Hardware name: Generic DA850/OMAP-L138/AM18x
    Backtrace:
    [<c0012f70>] (dump_backtrace) from [<c0013214>] (show_stack+0x18/0x1c)
     r7:00000009 r6:00000000 r5:c058f10c r4:c683dd78
    [<c00131fc>] (show_stack) from [<c0236a58>] (dump_stack+0x20/0x28)
    [<c0236a38>] (dump_stack) from [<c0021a94>] (__warn+0xdc/0x104)
    [<c00219b8>] (__warn) from [<c0021afc>] (warn_slowpath_fmt+0x40/0x48)
     r9:c0691db4 r8:ffffffef r7:00000001 r6:c680e7d0 r5:c6921c00 r4:c058f0d8
    [<c0021ac0>] (warn_slowpath_fmt) from [<c0162a6c>] (sysfs_warn_dup+0x5c/0x7c)
     r3:c681c000 r2:c058f0d8
     r4:c681c000
    [<c0162a10>] (sysfs_warn_dup) from [<c0162d98>] (sysfs_do_create_link_sd+0xd8/0xe8)
     r6:c6921c00 r5:c680e7d0 r4:c69263c0
    [<c0162cc0>] (sysfs_do_create_link_sd) from [<c0162dd4>] (sysfs_create_link+0x2c/0x3c)
     r9:c0691db4 r8:00000000 r7:00000000 r6:c0639828 r5:c0664f28 r4:c0639830
    [<c0162da8>] (sysfs_create_link) from [<c02cbc8c>] (bus_add_device+0x100/0x17c)
    [<c02cbb8c>] (bus_add_device) from [<c02c9df0>] (device_add+0x370/0x580)
     r9:c0691db4 r8:00000000 r7:00000000 r6:c0639828 r5:c0664db8 r4:c0639830
    [<c02c9a80>] (device_add) from [<c02ce4dc>] (platform_device_add+0x104/0x218)
     r10:00000000 r9:c05ea480 r8:c0644e54 r7:c0644e34 r6:c0639828 r5:c0639818
     r4:00000001
    [<c02ce3d8>] (platform_device_add) from [<c02cf09c>] (platform_device_register+0x28/0x2c)
     r9:c05ea480 r8:00000000 r7:c0616830 r6:00000000 r5:fec14000 r4:c0639818
    [<c02cf074>] (platform_device_register) from [<c05f4a78>] (da8xx_register_emac+0x14/0x30)
     r5:fec14000 r4:00000000
    [<c05f4a64>] (da8xx_register_emac) from [<c05f65c8>] (da850_evm_config_emac+0xe8/0x144)
    [<c05f64e0>] (da850_evm_config_emac) from [<c00096bc>] (do_one_initcall+0x44/0x180)
     r7:c0616830 r6:c0672040 r5:ffffe000 r4:c05f64e0
    [<c0009678>] (do_one_initcall) from [<c05ecebc>] (kernel_init_freeable+0x190/0x254)
     r8:c05ec5fc r7:c0616830 r6:c0672040 r5:0000006c r4:c0623344
    [<c05ecd2c>] (kernel_init_freeable) from [<c0478968>] (kernel_init+0x10/0xfc)
     r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0478958
     r4:00000000
    [<c0478958>] (kernel_init) from [<c000fa88>] (ret_from_fork+0x14/0x2c)
     r5:c0478958 r4:00000000
    ---[ end trace 9b0d75b1f5facbae ]---
    da850_evm_config_emac: EMAC registration failed: -17
    workingset: timestamp_bits=14 max_order=15 bucket_order=1
    Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    io scheduler noop registered (default)
    pinctrl-single 1c14120.pinmux: 160 pins at pa fec14120 size 80
    Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    console [ttyS2] disabled
    serial8250.2: ttyS2 at MMIO 0x1d0d000 (irq = 61, base_baud = 8250000) is a TI DA8xx/66AK2x
    console [ttyS2] enabled
    brd: module loaded
    libphy: Fixed MDIO Bus: probed
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
    davinci_mdio davinci_mdio.0: detected phy mask fffffff1
    libphy: davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[1]: device davinci_mdio.0:01, driver unknown
    davinci_mdio davinci_mdio.0: phy[2]: device davinci_mdio.0:02, driver unknown
    davinci_mdio davinci_mdio.0: phy[3]: device davinci_mdio.0:03, driver unknown
    i2c /dev entries driver
    davinci_mmc da830-mmc.0: Got CD GPIO
    davinci_mmc da830-mmc.0: Using DMA, 4-bit mode
    NET: Registered protocol family 10
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    NET: Registered protocol family 17
    console [netcon0] enabled
    netconsole: network logging started
    davinci_emac davinci_emac.1: incompatible machine/device type for reading mac address
    davinci_emac davinci_emac.1: using random MAC addr: c6:b2:6a:f4:1d:d4
    input: gpio-keys as /devices/platform/gpio-keys/input/input0
    hctosys: unable to open rtc device (rtc0)
    mmc0: host does not support reading read-only switch, assuming write-enable
    mmc0: new high speed SDHC card at address aaaa
    random: fast init done
    EXT4-fs (mmcblk0p2): recovery complete
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    VFS: Mounted root (ext4 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel memory: 224K
    This architecture does not have kernel memory protection.
    systemd[1]: System time before build time, advancing clock.
    systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    systemd[1]: Detected architecture arm.
    Welcome to Arago 2017.12!
    systemd[1]: Set hostname to <omapl138-lcdk>.
    systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Reached target Slices.
    [  OK  ] Reached target Swap.
    [  OK  ] Listening on Journal Socket.
             Starting Load Kernel Modules...
             Starting Journal Service...
    cryptodev: loading out-of-tree module taints kernel.
    cryptodev: driver 1.8 loaded.
             Mounting Temporary Directory...
             Starting Setup Virtual Console...
             Starting Create list of required st... nodes for the current kernel...
             Mounting Debug File System...
             Starting Remount Root and Kernel File Systems...
             Mounting POSIX Message Queue File System...
    EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Debug File System.
    [  OK  ] Mounted Temporary Directory.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Journal Service.
             Starting udev Coldplug all Devices...
             Starting Flush Journal to Persistent Storage...
             Starting Create Static Device Nodes in /dev...
             Starting Apply Kernel Variables...
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    systemd-journald[55]: Received request to flush runtime journal from PID 1
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
    davinci-rproc davinci-rproc.0: assigned reserved memory node dsp_cma@c3000000
    remoteproc remoteproc0: dsp is available
    remoteproc remoteproc0: powering up dsp
    remoteproc remoteproc0: Booting fw image rproc-dsp-fw, size 3920460
    omap_rtc 1c23000.rtc: rtc core: registered 1c23000.rtc as rtc0
    remoteproc remoteproc0: registered virtio0 (type 7)
    remoteproc remoteproc0: remote processor dsp is now up
    davinci-wdt davinci-wdt: heartbeat 60 sec
    SCSI subsystem initialized
    [  OK  ] Started udev Coldplug all Devices.
    [drm] Initialized
    ahci_da850 ahci_da850: forcing PORTS_IMPL to 0x1
    [  OK  hci_da850 ahci_da850: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    m] Listening on dropbear.socket.
    [  OK  ] Started Dailyahci_da850 ahci_da850: flags: ncq sntf pm led clo only pmp pio slum part ccc
    [  OK  ] Listening on RPCbind Server Ascsi host0: ahci_da850
    ctivation Socket.
    ata1: SATA max UDMA/133 mmio [mem 0x01e18000-0x01e19fff] port 0x100 irq 67
    [  OK  ] Listening on D-Bus System Message Bus Socket.usbcore: registered new interface driver usbfs
    vpif vpif: vpif probe success
    usbcore: registered new interface driver hub
    0-0018 supply IOVDD not found, using dummy regulator
    usbcore: registered new device driver usb
    0-0018 supply DVDD not found, using dummy regulator
    0-0018 supply AVDD not found, using dummy regulator
    0-0018 supply DRVDD not found, using dummy regulator
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    ohci-da8xx: DA8XX
    ohci-da8xx ohci-da8xx: USB Host Controller
    ohci-da8xx ohci-da8xx: new USB bus registered, assigned bus number 1
    asoc-simple-card sound: ASoC: Failed to create card debugfs directory
    asoc-simple-card sound: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
             Starting Etherneohci-da8xx ohci-da8xx: irq 59, io mem 0x01e25000
    [  OK  ] Started System Logger Daemon.
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [drm] No driver support for vblank timestamp query.
    tilcdc da8xx_lcdc.0: tilcdc_crtc_irq(0x00000160): FIFO underflow
    Console: switching to colour frame buffer device 100x37
    Linux video capture interface: v2.00
    usb 1-1: new low-speed USB device number 2 using ohci-da8xx
    usb 1-1: device descriptor read/64, error -62
    ata1: SATA link down (SStatus 0 SControl 300)
    tilcdc da8xx_lcdc.0: fb0:  frame buffer device
    usb_phy_generic.0.auto supply vcc not found, using dummy regulator
    [  OK  ] Started System Logging Service.
    usb 1-1: new low-speed USB device number 3 using ohci-da8xx
    tvp514x 0-005d: Write: retry ... 0
    tvp514x 0-005d: Write: retry ... 1
    tvp514x 0-005d: Write: retry ... 2
    tvp514x 0-005d: Write: retry ... 3
    tvp514x 0-005d: Write: retry ... 4
    tvp514x 0-005d: Write: retry ... 5
    tvp514x 0-005d: tvp514x 0-005d decoder driver registered !!
    usb usb1-port1: attempt power cycle
    vpif_capture vpif_capture: registered sub device tvp514x-0
    usb 1-1: new low-speed USB device number 4 using ohci-da8xx
    usb 1-1: device not accepting address 4, error -62
             Starting tiipclad-daemon.service...
    usb 1-1: new low-speed USB device number 5 using ohci-da8xx
    [  OK  ] Started Kernel Logging Service.
    usb 1-1: device not accepting address 5, error -62
    usb usb1-port1: unable to enumerate USB device
             Starting Network Service...
    [  OK  ] Started tiipclad-daemon.service.
    [  OK  ] Found device /dev/ttyS2.
    random: crng init done
    [  OK  ] Started Network Service.
    davinci_mdio davinci_mdio.0: resetting idled controller
    Generic PHY davinci_mdio.0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=davinci_mdio.0:01, irq=-1)
    [  OK  ] Reached target Network.
    IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
             Starting Network Name Resolution...
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [  OK  ] Started Network Name Resolution.
    virtio_rpmsg_bus virtio0: rpmsg host is online
    virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    nand: device found, Manufacturer ID: 0x01, Chip ID: 0xcc
    nand: AMD/Spansion S34ML04G1
    nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    Bad block table not found for chip 0
    Scanning device for bad blocks
    Bad eraseblock 4 at 0x000000080000
    Bad eraseblock 8 at 0x000000100000
    Bad eraseblock 9 at 0x000000120000
    Bad eraseblock 11 at 0x000000160000
    Bad eraseblock 12 at 0x000000180000
    Bad eraseblock 13 at 0x0000001a0000
    Bad eraseblock 14 at 0x0000001c0000
    ** 51 printk messages dropped ** Bad eraseblock 66 at 0x000000840000
    Bad eraseblock 67 at 0x000000860000
    Bad eraseblock 68 at 0x000000880000
    ** 156 printk messages dropped ** Bad eraseblock 225 at 0x000001c20000
    ** 94 printk messages dropped ** Bad eraseblock 320 at 0x000002800000
    ** 129 printk messages dropped ** Bad eraseblock 444 at 0x000003780000
    Bad eraseblock 445 at 0x0000037a0000
    Bad eraseblock 446 at 0x0000037c0000
    ** 219 printk messages dropped ** Bad eraseblock 665 at 0x000005320000
    Bad eraseblock 666 at 0x000005340000
    ** 130 printk messages dropped ** Bad eraseblock 796 at 0x000006380000
    Bad eraseblock 797 at 0x0000063a0000
    ** 151 printk messages dropped ** Bad eraseblock 948 at 0x000007680000
    Bad eraseblock 949 at 0x0000076a0000
    ** 133 printk messages dropped ** Bad eraseblock 1082 at 0x000008740000
    systemd-journald[55]: /dev/kmsg buffer overrun, some messages lost.
    ** 310 printk messages dropped ** Bad eraseblock 1392 at 0x00000ae00000
    Bad eraseblock 1393 at 0x00000ae20000
    ** 148 printk messages dropped ** Bad eraseblock 1540 at 0x00000c080000
    Bad eraseblock 1541 at 0x00000c0a0000
    ** 149 printk messages dropped ** Bad eraseblock 1690 at 0x00000d340000
    Bad eraseblock 1691 at 0x00000d360000
    ** 88 printk messages dropped ** Bad eraseblock 1780 at 0x00000de80000
    ** 96 printk messages dropped ** Bad eraseblock 1877 at 0x00000eaa0000
    Bad eraseblock 1878 at 0x00000eac0000
    Bad eraseblock 1879 at 0x00000eae0000
    Bad eraseblock 1880 at 0x00000eb00000
    Bad eraseblock 1881 at 0x00000eb20000
    Bad eraseblock 1882 at 0x00000eb40000
    Bad eraseblock 1883 at 0x00000eb60000
    Bad eraseblock 1884 at 0x00000eb80000
    Bad eraseblock 1885 at 0x00000eba0000
    Bad eraseblock 1886 at 0x00000ebc0000
    Bad eraseblock 1887 at 0x00000ebe0000
    Bad eraseblock 1888 at 0x00000ec00000
    Bad eraseblock 1889 at 0x00000ec20000
    Bad eraseblock 1890 at 0x00000ec40000
    Bad eraseblock 1891 at 0x00000ec60000
    ** 10 printk messages dropped ** Bad eraseblock 1902 at 0x00000edc0000
    Bad eraseblock 1903 at 0x00000ede0000
    ** 146 printk messages dropped ** Bad eraseblock 2050 at 0x000010040000
    ** 157 printk messages dropped ** Bad eraseblock 2750 at 0x0000157c0000
    Bad eraseblock 2751 at 0x0000157e0000
    ** 112 printk messages dropped ** Bad eraseblock 2864 at 0x000016600000
    ** 95 printk messages dropped ** Bad eraseblock 2961 at 0x000017220000
    Bad eraseblock 2983 at 0x0000174e0000
            autoconf
            binutils
            cifs-utils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gzip
            libgmp10
            libmpc3
            libmpfr4
            libreadline6
            m4
            make
            which
    the above packaBad eraseblock 3002 at 0x000017740000
    ges prior to disBad eraseblock 3003 at 0x000017760000
    *********Bad eraseblock 3004 at 0x000017780000
    Bad eraseblock 3076 at 0x000018080000
    Bad eraseblock 3169 at 0x000018c20000
    Bad eraseblock 3171 at 0x000018c60000
    Bad block table written to 0x00001ffe0000, version 0x01
    3 ofpart partitions found on MTD device davinci-nand.0
    Creating 3 MTD partitions on "davinci-nand.0":
    davinci_nand davinci-nand.0: controller rev. 2.5
    [  OK  ] Started Print notice about GPLv3 packages.
             Starting rng-tools.service...
    [  OK  ] Started rng-tools.service.
             Starting matrix-gui-2.0.service...
    [  OK  ] Started matrix-gui-2.0.service.
             Starting thermal-zone-init.service...
    [  OK  ] Started thermal-zone-init.service.
    [  OK  ] Reached target Multi-User System.
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Started Update UTMP about System Runlevel Changes.
     _____                    _____           _         _
                  |___|                    |___|
    Arago 2017.12 omapl138-lcdk ttyS2
    will this cause any error?
    The one issue that stands out for moment is the Kernel WARN at line 116. I don't have a recommendation or suggestion for what is causing that.
    Schuyler
       Thank you for your help in this subject.
    I am glad to see you marked the thread as resolved. Your are welcome.
    Schuyler
