TDA4AL-Q1: TDA4AL-Q1
Part Number: TDA4AL-Q1
Hello. TI Expert.
SEE : https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1227640/faq-tda4vm-tda4vl-tda4al-tda4vh-dra821-how-can-we-make-the-jacinto-sdk-compatible-for-device-variants-yxz
I am currently working on modifying the SDK for TDA4AL based on the referenced document.
According to the document, ENABLE_DSS_EDP, ENABLE_DSS_HDMI, and ENABLE_DSS_DSI are all undefined for TDA4AL.
Additionally, ENABLE_DSS_SINGLE and ENABLE_DSS_DUAL are also undefined.
In this scenario, how can we verify the output of the Vision Apps demo(app_tidl_od_cam, app_single_cam, ...)?
JK
  • Hi JK,
    In the SDK of the superset device, eDP is the default display output, hence the macro ENABLE_DSS_EDP and ENABLE_DSS_SINGLE  were enabled. Now since TDA4AL does not have eDP, the FAQ had disabled it.
    But I believe there is DSI and DPI still available at your end right? You could enable the same and test the vision_apps demos.
    Nikhil
  • Hello Nikhil,
    Running the Vision App is not possible with ENABLE_DSS_SINGLE and ENABLE_DSS_DSI.
    The attached log has more information.
    There are two DP ports on the EVK. Is there a way to confirm DP output using the Bridge IC that switches from DSI?
    JK
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.03.19 15:43:35 =~=~=~=~=~=~=~=~=~=~=~=
    U-Boot SPL 2021.01-dirty (Mar 18 2024 - 11:49:23 +0900)
    ti_sci system-controller@44083000: Message not acknowledgedti_sci system-controller@44083000: Message not acknowledgedSYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
    SPL initial stack usage: 13472 bytes
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 16:16:51, May  2 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue May  2 16:17:10 UTC 2023 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-dirty (Mar 18 2024 - 11:49:11 +0900)
    U-Boot 2021.01-dirty (Mar 18 2024 - 11:49:11 +0900)
    SoC:   J721S2 SR1.0 GP
    Model: Texas Instruments J721S2 EVM
    Board: J721S2X-PM1-SOM rev E3
    DRAM:  8 GiB
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    56 bytes read in 5 ms (10.7 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    896136 bytes read in 28 ms (30.5 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 896136 bytes: Success!
    306060 bytes read in 16 ms (18.2 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 306060 bytes: Success!
    Failed to load '/lib/firmware/j721s2-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j721s2-main-r5f1_1-fw'
    14815296 bytes read in 150 ms (94.2 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 14815296 bytes: Success!
    9760696 bytes read in 48 ms (193.9 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 9760696 bytes: Success!
    19079680 bytes read in 410 ms (44.4 MiB/s)
    80937 bytes read in 8 ms (9.6 MiB/s)
    10142 bytes read in 6 ms (1.6 MiB/s)
       Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (mobase@TI-u1804) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon Mar 18 11:17:28 KST 2024
    [    0.000000] Machine model: Texas Instruments J721S2 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b0100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 704 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000008ac000000, size 896 MiB
    [    0.000000] OF: reserved mem: initialized node linux-cma-buffers@8ac000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000dbffffff]
    [    0.000000]   node   0: [mem 0x00000000dc000000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008abffffff]
    [    0.000000]   node   0: [mem 0x00000008ac000000-0x00000009ffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064382
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=c6fe6429-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 5499484K/8388600K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1971612K reserved, 917504K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: RCU event tracing is enabled.
    [    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] Trampoline variant of Tasks RCU enabled.
    [    0.000000] Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8e4800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008e4030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008e4040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008388] Console: colour dummy device 80x25
    [    0.012957] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023628] pid_max: default: 32768 minimum: 301
    [    0.028389] LSM: Security Framework initializing
    [    0.033169] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.040947] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.050081] rcu: Hierarchical SRCU implementation.
    [    0.055173] Platform MSI: msi-controller@1820000 domain created
    [    0.061391] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070698] EFI services will not be available.
    [    0.075437] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.088536] Detected PIPT I-cache on CPU1
    [    0.088564] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088576] GICv3: CPU1: using allocated LPI pending table @0x00000008e4050000
    [    0.088618] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088678] smp: Brought up 1 node, 2 CPUs
    [    0.118025] SMP: Total of 2 processors activated.
    [    0.122831] CPU features: detected: 32-bit EL0 Support
    [    0.128087] CPU features: detected: CRC32 instructions
    [    0.142816] CPU: All CPU(s) started at EL2
    [    0.147021] alternatives: patching kernel code
    [    0.152120] devtmpfs: initialized
    [    0.159933] KASLR disabled due to lack of seed
    [    0.164598] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.174568] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.195505] pinctrl core: initialized pinctrl subsystem
    [    0.201208] DMI not present or invalid.
    [    0.205498] NET: Registered protocol family 16
    [    0.211005] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.218494] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.226678] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.235109] thermal_sys: Registered thermal governor 'step_wise'
    [    0.235112] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.241754] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.255408] ASID allocator initialised with 65536 entries
    [    0.275742] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.282601] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.289448] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.296294] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.303823] cryptd: max_cpu_qlen set to 1000
    [    0.310108] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.319202] vsys_3v3: supplied by evm_12v0
    [    0.323595] vsys_5v0: supplied by evm_12v0
    [    0.328432] iommu: Default domain type: Translated
    [    0.333574] SCSI subsystem initialized
    [    0.337683] mc: Linux media interface: v0.10
    [    0.342062] videodev: Linux video capture interface: v2.00
    [    0.347699] pps_core: LinuxPPS API ver. 1 registered
    [    0.352770] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.362108] PTP clock support registered
    [    0.366128] EDAC MC: Ver: 3.0.0
    [    0.369928] FPGA manager framework
    [    0.373449] Advanced Linux Sound Architecture Driver Initialized.
    [    0.380119] clocksource: Switched to clocksource arch_sys_counter
    [    0.386466] VFS: Disk quotas dquot_6.6.0
    [    0.390505] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.400318] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.406618] NET: Registered protocol family 2
    [    0.411639] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.421257] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.430043] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.438356] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.446573] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.453462] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.460492] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.468054] NET: Registered protocol family 1
    [    0.472844] RPC: Registered named UNIX socket transport module.
    [    0.478909] RPC: Registered udp transport module.
    [    0.483729] RPC: Registered tcp transport module.
    [    0.488533] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.495116] NET: Registered protocol family 44
    [    0.499663] PCI: CLS 0 bytes, default 64
    [    0.504074] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.514681] Initialise system trusted keyrings
    [    0.519333] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.527552] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.533791] NFS: Registering the id_resolver key type
    [    0.539031] Key type id_resolver registered
    [    0.543304] Key type id_legacy registered
    [    0.547429] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.554279] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.561938] 9p: Installing v9fs 9p2000 file system support
    [    0.586810] Key type asymmetric registered
    [    0.591000] Asymmetric key parser 'x509' registered
    [    0.596005] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.603565] io scheduler mq-deadline registered
    [    0.608190] io scheduler kyber registered
    [    0.613751] pinctrl-single 4301c000.pinctrl: 101 pins, size 404
    [    0.619983] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.630563] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.643487] brd: module loaded
    [    0.650561] loop: module loaded
    [    0.654483] megasas: 07.714.04.00-rc1
    [    0.660352] tun: Universal TUN/TAP device driver, 1.6
    [    0.665826] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.672235] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.678309] sky2: driver version 1.30
    [    0.682674] VFIO - User Level meta-driver version: 0.3
    [    0.688520] i2c /dev entries driver
    [    0.692940] sdhci: Secure Digital Host Controller Interface driver
    [    0.699259] sdhci: Copyright(c) Pierre Ossman
    [    0.703907] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.710259] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.716611] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.724022] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.728586] optee: revision 3.20 (8e74d476)
    [    0.745025] optee: dynamic shared memory is enabled
    [    0.754504] optee: initialized driver
    [    0.759653] NET: Registered protocol family 17
    [    0.764296] 9pnet: Installing 9P2000 support
    [    0.768703] Key type dns_resolver registered
    [    0.773179] Loading compiled-in X.509 certificates
    [    0.786106] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
    [    0.820430] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.826616] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.832717] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.839106] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.845941] pca953x 3-0021: using no AI
    [    0.872619] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.879430] pca953x 3-0020: using no AI
    [    0.884061] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.890878] pca953x 3-0022: using AI
    [    0.895213] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.901647] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    0.910244] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    0.919580] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    0.928240] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    0.938125] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.945817] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.954100] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.962377] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    0.971225] j721e-pcie 2910000.pcie: Failed to init phy
    [    0.977272] ti-udma 311a0000.dma-controller: Number of rings: 48
    [    0.984056] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
    [    0.993422] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.003318] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.010078] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.019005] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.029165] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.035926] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.043629] omap8250 40a00000.serial: failed to get alias
    [    1.049774] printk: console [ttyS2] disabled
    [    1.054175] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 27, base_baud = 3000000) is a 8250
    [    1.062930] printk: console [ttyS2] enabled
    [    1.071367] printk: bootconsole [ns16550a0] disabled
    [    1.082504] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available
    [    1.090025] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.094998] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.101598] Creating 7 MTD partitions on "47040000.spi.0":
    [    1.107071] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.113131] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.118892] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.124727] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.130281] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.136457] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.142271] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.150310] cadence-qspi 47050000.spi: error -ENODEV: No Rx DMA available
    [    1.157485] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    1.166593] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.212122] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.220802] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.229108] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.241975] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.249184] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.255506] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.265899] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
    [    1.375730] mmc0: CQHCI version 5.10
    [    1.379648] gpio-mux mux-controller0: 2-way mux-controller registered
    [    1.386580] gpio-mux mux-controller1: 2-way mux-controller registered
    [    1.396680] vdd_mmc1: supplied by vsys_3v3
    [    1.401936] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.408786] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.415599] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.420318] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.429625] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.436469] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.443955] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.452035] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.460119] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.468599] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.474710] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.484767] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
    [    1.495402] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.519280] mmc0: Command Queue Engine enabled
    [    1.523727] mmc0: new HS400 MMC card at address 0001
    [    1.529052] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.533721] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    1.539762] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    1.540145] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.545779] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    1.554417] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.562637]  mmcblk0: p1
    [    1.568990] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.584331] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.591547] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.597893] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.608021] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.616692] mmc1: CQHCI version 5.10
    [    1.616723] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.627773] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.635863] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.643943] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.652435] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.658550] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.666041] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.674126] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.674130] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.689753] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.698295] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.704203] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.711694] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.719838] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.727974] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.736492] j721e-pcie 2910000.pcie: Failed to init phy
    [    1.742025] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
    [    1.749345] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
    [    1.757088] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
    [    1.764942] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    1.777428] ALSA device list:
    [    1.780405]   No soundcards found.
    [    1.784133] Waiting for root device PARTUUID=c6fe6429-02...
    [    1.819291] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.826257] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    1.834887]  mmcblk1: p1 p2
    [    1.838997] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.846512] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.854596] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.862680] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.871170] j721e-pcie 2910000.pcie: Failed to init phy
    [    2.247902] EXT4-fs (mmcblk1p2): recovery complete
    [    2.253586] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.261706] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.275223] devtmpfs: mounted
    [    2.279119] Freeing unused kernel memory: 1856K
    [    2.283760] Run /sbin/init as init process
    [    2.472984] systemd[1]: System time before build time, advancing clock.
    [    2.521396] NET: Registered protocol family 10
    [    2.526432] Segment Routing with IPv6
    [    2.562234] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.584003] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    2.626863] systemd[1]: Set hostname to <j721s2-evm>.
    [    2.807841] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
    [    2.834125] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock  /run/docker.sock; please update the unit file accordingly.
    [    2.906512] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.915043] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    2.936284] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.943799] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    2.964212] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.971532] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.992366] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ts to Console Directory Watch.
    [    3.016272] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Ruests to Wall Directory Watch.
    [    3.040304] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.060199] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.080186] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.100181] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.135875] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.160332] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.184868] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.208375] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.234269] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    3.242717] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.264556] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.284531] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.308442] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.328351] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.350788] systemd[1]: Mounting Huge Pages File System...
    [    3.374885] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.398778] systemd[1]: Mounting Kernel Debug File System...
    [    3.421389] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.439070] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of stodes for the current kernel...
    [    3.474967] systemd[1]: Starting Start psplash boot splash screen...
    [    3.499055] systemd[1]: Starting RPC Bind...
    [    3.516363] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.529301] systemd[1]: Starting Journal Service...
    [    3.562937] systemd[1]: Starting Load Kernel Modules...
    [    3.583081] cryptodev: loading out-of-tree module taints kernel.
    [    3.590143] cryptodev: driver 1.10 loaded.
    [    3.591946] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.608764] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    3.618896] systemd[1]: Starting udev Coldplug all Devices...
    [    3.643729] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.664706] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Starprogress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    3.897094] systemd-journald[178]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
    [    3.915239] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.922940] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Create Static Device Nodes in /dev    3.934902] random: systemd-journal: uninitialized urandom read (16 bytes read)
    m...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    4.503649] random: crng init done
    [    4.507159] random: 66 urandom warning(s) missed due to ratelimiting
    [    4.512384] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.521778] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.530649] CAN device driver interface
    [    4.534609] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [  OK  ] Started Load/Save Random Seed.[    4.550651] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.563901] j721e-pcie 2910000.pcie: Failed to init phy
    [    4.577166] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.587416] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.600407] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    4.613004] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.630127] j721e-pcie 2910000.pcie: Failed to init phy
    [    4.635627] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
    [    4.658100] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.665906] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    4.672800] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.680983] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    4.695140] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.695157] remoteproc remoteproc0: 64800000.dsp is available
    [    4.708551] j721e-pcie 2910000.pcie: Failed to init phy
    [    4.709238] remoteproc remoteproc0: attaching to 64800000.dsp
    [    4.720649] remoteproc remoteproc0: unsupported resource 65538
    [    4.726578] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    4.727958] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.733309]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b0000000
    [    4.753041] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.753150] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    4.767430] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    4.772433]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    4.781480] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.787994] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    4.795626] j721e-pcie 2910000.pcie: Failed to init phy
    [    4.811582] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.824336] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.836813] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    4.848651] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    4.856945] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.869214] j721e-pcie 2910000.pcie: Failed to init phy
    [    4.875346] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
    [    4.885680] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    4.909500] platform 41000000.r5f: configured R5F for IPC-only mode
    [    4.915905] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    4.922839] remoteproc remoteproc1: 65800000.dsp is available
    [    4.935661] remoteproc remoteproc1: attaching to 65800000.dsp
    [    4.941515] remoteproc remoteproc1: unsupported resource 65538
    [    4.947540] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    4.951960] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.954197]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000
    [    4.968185] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    4.971548] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    4.984892]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    4.986740] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    4.992408] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [    5.000172] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.017227] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.032850] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    5.040200] j721e-pcie 2910000.pcie: Failed to init phy
    [    5.055647] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.066464] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.076963] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.089159] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.102359] j721e-pcie 2910000.pcie: Failed to init phy
    [    5.113390] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [    5.128410] m_can_platform 40568000.can: m_can device registered (irq=21, version=32)
    [    5.142536] m_can_platform 2731000.can: m_can device registered (irq=34, version=32)
    [    5.158179] m_can_platform 2751000.can: m_can device registered (irq=36, version=32)
    [    5.174264] m_can_platform 26a1000.can: m_can device registered (irq=38, version=32)
    [    5.186487] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.195873] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.208275] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.219318] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.230251] j721e-pcie 2910000.pcie: Failed to init phy
    [    5.242514] remoteproc remoteproc2: 41000000.r5f is available
    [    5.319690] remoteproc remoteproc2: attaching to 41000000.r5f
    [    5.392398] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.496305]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.556068] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.573827] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.581482] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    5.659300] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.667763]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    5.673949] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.682120] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.695243] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.707911] j721e-pcie 2910000.pcie: Failed to init phy
    [    5.755564] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [    5.846921] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.857394] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.869668] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.877852] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.892195] j721e-pcie 2910000.pcie: Failed to init phy
    [    5.898447] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    5.918960] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    5.993100] remoteproc remoteproc3: 5c00000.r5f is available
    [    6.031060] remoteproc remoteproc3: attaching to 5c00000.r5f
    [    6.079066] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    6.087985]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.100721] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.109502] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    6.132581]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    6.138990] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.148276] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.157499] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [    6.165067] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.173309] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.184261] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.190997] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    6.200068] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.210961] remoteproc remoteproc4: 5d00000.r5f is available
    [    6.219084] remoteproc remoteproc4: attaching to 5d00000.r5f
    [    6.227527] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.234552]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.253319] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.263795] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.276821] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.287540] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.292215] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.293313]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    6.307509] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    6.314903] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    6.314958] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    6.315053] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.315125] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    6.315174] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.315224] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    6.315267] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.316010] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
    [    6.318564] usbcore: registered new interface driver usbfs
    [    6.318585] usbcore: registered new interface driver hub
    [    6.318614] usbcore: registered new device driver usb
    [    6.319693] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.320859] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.320880] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.320891] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.320902] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.321188] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.322141] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.322161] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.322170] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.322180] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.329583] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.334481] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    6.337420] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    6.337768] remoteproc remoteproc5: 5e00000.r5f is available
    [    6.337898] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
    [    6.337904] remoteproc remoteproc5: powering up 5e00000.r5f
    [    6.337917] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2
    [    6.337920] remoteproc remoteproc5: request_firmware failed: -2
    [    6.346133] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.346164] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.346178] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.346189] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.346379] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    6.346503] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.348038] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    6.348712] remoteproc remoteproc6: 5f00000.r5f is available
    [    6.348826] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2
    [    6.348832] remoteproc remoteproc6: powering up 5f00000.r5f
    [    6.348845] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2
    [    6.348848] remoteproc remoteproc6: request_firmware failed: -2
    [    6.349572] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.349593] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.349603] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.349615] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.350013] j721e-pcie 2910000.pcie: Failed to init phy
    [    6.358637] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.426055] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.426077] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.426088] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.426099] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.426386] j721e-pcie 2910000.pcie: Failed to init phy
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting rc.pvr.service...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini based on the platform name...
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started Update weston ini ge based on the platform name.
    [  OK  ] Started Telephony service.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [    7.489830] Bluetooth: Core ver 2.22
    [    7.494814] NET: Registered protocol family 31
    [    7.504190] Bluetooth: HCI device and connection manager initialized
    [    7.510690] Bluetooth: HCI socket layer initialized
    [    7.515718] Bluetooth: L2CAP socket layer initialized
    [    7.521019] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF itch Status /dev/rfkill Watch.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [    7.781608] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.843298] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Maent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Simple Network Manement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
    autoconf
    bash-dev
    bash
    bc
    binutils
    cifs-utils
    coreutils-stdbuf
    coreutils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbserver
    gettext
    glmark2
    gstreamer1.0-libav-dev
    gstreamer1.0-libav
    gzip
    less
    libasm1
    libbfd
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm-dev
    libgdbm6
    libgettextlib
    libgettextsrc
    libgmp-dev
    libgmp10
    libgmpxx4
    libidn2-0
    libidn2-dev
    libmpc3
    libmpfr6
    libreadline-dev
    libreadline8
    libunistring-dev
    libunistring2
    m4-dev
    m4
    make
    nettle-dev
    nettle
    parted
    python3-rfc3987
    python3-strict-rfc3339
    tar
    which
    zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting EdgeAI OOB demos...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j721s2-evm ttyS2
    Arago 2021.09 j721s2-evm ttyS2
    j721s2-evm login: root
    root@j721s2-evm:~# cd /opt/vision_apps/
    root@j721s2-evm:/opt/vision_apps# ls
    app_avp.cfg
    app_avp2.cfg
    app_avp3.cfg
    app_avp4.cfg
    app_c7x.cfg
    app_dof.cfg
    app_encode.cfg
    app_multi_cam.cfg
    app_multi_cam_codec.cfg
    app_oc.cfg
    app_oc_16bit.cfg
    app_od.cfg
    app_od_cam.cfg
    app_pcie_video_sink.cfg
    app_pcie_video_source.cfg
    app_seg.cfg
    app_seg_16bit.cfg
    app_seg_cam.cfg
    app_sfm.cfg
    app_single_cam.cfg
    app_srv.cfg
    app_srv_avp_cfg
    app_stereo.cfg
    app_stereo_16bit.cfg
    app_tidl_cam.cfg
    app_vl.cfg
    autorun.sh
    run_app_arm_fd_exchange.sh
    run_app_c7x.sh
    run_app_dof.sh
    run_app_load_test.sh
    run_app_multi_cam.sh
    run_app_multi_cam_codec.sh
    run_app_sfm.sh
    run_app_single_cam.sh
    run_app_srv.sh
    run_app_srv_avp.sh
    run_app_stereo.sh
    run_app_stereo_16bit.sh
    run_app_tidl.sh
    run_app_tidl_16bit.sh
    run_app_tidl_avp.sh
    run_app_tidl_avp2.sh
    run_app_tidl_avp3.sh
    run_app_tidl_avp4.sh
    run_app_tidl_cam.sh
    run_app_tidl_od.sh
    run_app_tidl_od_cam.sh
    run_app_tidl_seg.sh
    run_app_tidl_seg_16bit.sh
    run_app_tidl_seg_cam.sh
    run_app_tidl_vl.sh
    run_app_viss.sh
    run_ptk_demo.sh
    script.exp
    single_cam_graph_1_img.txt
    single_cam_graph_2_pipe_img.txt
    single_cam_graph_3_data_ref_q_img.txt
    single_cam_graph_4_pipe0_img.txt
    test_data
    test_list.txt
    vision_apps_init.sh
    vx_app_arm_fd_exchange_consumer.out
    vx_app_arm_fd_exchange_producer.out
    vx_app_arm_ipc.out
    vx_app_arm_mem.out
    vx_app_arm_opengl_mosaic.out
    vx_app_arm_remote_log.out
    vx_app_c7x_kernel.out
    vx_app_conformance.out
    vx_app_dense_optical_flow.out
    vx_app_heap_stats.out
    vx_app_load_test.out
    vx_app_multi_cam.out
    vx_app_multi_cam_codec.out
    vx_app_sfm.out
    vx_app_single_cam.out
    vx_app_srv_calibration.out
    vx_app_srv_camera.out
    vx_app_srv_fileio.out
    vx_app_stereo_depth.out
    vx_app_test_framework.out
    vx_app_tidl.out
    vx_app_tidl_avp.out
    vx_app_tidl_avp2.out
    vx_app_tidl_avp3.out
    vx_app_tidl_avp4.out
    vx_app_tidl_cam.out
    vx_app_tidl_cam_1_img.txt
    vx_app_tidl_cam_2_pipe_img.txt
    vx_app_tidl_cam_3_data_ref_q_img.txt
    vx_app_tidl_cam_4_pipe0_img.txt
    vx_app_tidl_od.out
    vx_app_tidl_od_cam.out
    vx_app_tidl_od_cam_1_img.txt
    vx_app_tidl_od_cam_2_pipe_img.txt
    vx_app_tidl_od_cam_3_data_ref_q_img.txt
    vx_app_tidl_od_cam_4_pipe0_img.txt
    vx_app_tidl_seg.out
    vx_app_tidl_seg_cam.out
    vx_app_tidl_vl.out
    vx_app_tutorial.out
    vx_app_viss.out
    vx_tutorial_graph_image_gradients_1_img.txt
    vx_tutorial_graph_image_gradients_2_pipe_img.txt
    vx_tutorial_graph_image_gradients_3_data_ref_q_img.txt
    vx_tutorial_graph_image_gradients_4_pipe0_img.txt
    vx_tutorial_graph_user_kernel_1_img.txt
    vx_tutorial_graph_user_kernel_2_pipe_img.txt
    vx_tutorial_graph_user_kernel_3_data_ref_q_img.txt
    vx_tutorial_graph_user_kernel_4_pipe0_img.txt
    vx_tutorial_graph_user_kernel_pytiovx_1_img.txt
    vx_tutorial_graph_user_kernel_pytiovx_2_pipe_img.txt
    vx_tutorial_graph_user_kernel_pytiovx_3_data_ref_q_img.txt
    vx_tutorial_graph_user_kernel_pytiovx_4_pipe0_img.txt
    vx_tutorial_image_color_convert_1_img.txt
    vx_tutorial_image_color_convert_2_pipe_img.txt
    vx_tutorial_image_color_convert_3_data_ref_q_img.txt
    vx_tutorial_image_color_convert_4_pipe0_img.txt
    vx_tutorial_image_histogram_1_img.txt
    vx_tutorial_image_histogram_2_pipe_img.txt
    vx_tutorial_image_histogram_3_data_ref_q_img.txt
    vx_tutorial_image_histogram_4_pipe0_img.txt
    root@j721s2-evm:/opt/vision_apps# ./  . ./vision_apps_init.sh
    root@j721s2-evm:/opt/vision_apps# [MCU2_0]      3.980786 s: CIO: Init ... Done !!!
    [MCU2_0]      3.980839 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      3.980873 s: CPU is running FreeRTOS
    [MCU2_0]      3.980894 s: APP: Init ... !!!
    [MCU2_0]      3.980913 s: SCICLIENT: Init ... !!!
    [MCU2_0]      3.981042 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
    [MCU2_0]      3.981075 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_0]      3.981102 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      3.981132 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      3.981155 s: UDMA: Init ... !!!
    [MCU2_0]      3.982009 s: UDMA: Init ... Done !!!
    [MCU2_0]      3.982044 s: UDMA: Init ... !!!
    [MCU2_0]      3.982530 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]      3.982580 s: MEM: Init ... !!!
    [MCU2_0]      3.982616 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
    [MCU2_0]      3.982673 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 524288 bytes !!!
    [MCU2_0]      3.982723 s: MEM: Init ... Done !!!
    [MCU2_0]      3.982744 s: IPC: Init ... !!!
    [MCU2_0]      3.982786 s: IPC: 5 CPUs participating in IPC !!!
    [MCU2_0]      3.982822 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]     11.991042 s: IPC: HLOS is ready !!!
    [MCU2_0]     12.000243 s: IPC: Init ... Done !!!
    [MCU2_0]     12.000283 s: APP: Syncing with 4 CPUs ... !!!
    [MCU2_0]     12.187046 s: APP: Syncing with 4 CPUs ... Done !!!
    [MCU2_0]     12.187078 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]     12.188345 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]     12.188381 s: FVID2: Init ... !!!
    [MCU2_0]     12.188474 s: FVID2: Init ... Done !!!
    [MCU2_0]     12.188498 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2
    [MCU2_0]     12.188635 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.188677 s: DSS: Init ... !!!
    [MCU2_0]     12.188700 s: DSS: Display type is DSI !!!
    [MCU2_0]     12.188721 s: DSS: M2M Path is enabled !!!
    [MCU2_0]     12.188743 s: DSS: SoC init ... !!!
    [MCU2_0]     12.188763 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
    [MCU2_0]     12.188915 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.188943 s: SCICLIENT: Sciclient_pmSetModuleState module=154 state=2
    [MCU2_0]     12.189018 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.189045 s: SCICLIENT: Sciclient_pmSetModuleState module=363 state=2
    [MCU2_0]     12.189137 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.189165 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
    [MCU2_0]     12.189223 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.189249 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=158 clk=14 parent=16
    [MCU2_0]     12.189416 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     12.189444 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=158 clk=16 freq=74250000
    [MCU2_0]     12.190513 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0]     12.190539 s: SCICLIENT: Sciclient_pmModuleClkRequest module=158 clk=16 state=2 flag=2
    [MCU2_0]     12.190704 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0]     12.190729 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=2
    [MCU2_0]     12.190880 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.190904 s: DSS: SoC init ... Done !!!
    [MCU2_0]     12.193227 s: DSS: Display is not connected
    [MCU2_0]     12.193261 s: DSS: Init ... Done !!!
    [MCU2_0]     12.193283 s: VHWA: VPAC Init ... !!!
    [MCU2_0]     12.193304 s: SCICLIENT: Sciclient_pmSetModuleState module=361 state=2
    [MCU2_0]     12.193500 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.193529 s: VHWA: LDC Init ... !!!
    [MCU2_0]     12.196237 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]     12.196270 s: VHWA: MSC Init ... !!!
    [MCU2_0]     12.204634 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]     12.204670 s: VHWA: NF Init ... !!!
    [MCU2_0]     12.205784 s: VHWA: NF Init ... Done !!!
    [MCU2_0]     12.205819 s: VHWA: VISS Init ... !!!
    [MCU2_0]     12.212966 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]     12.213002 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]     12.213036 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]     12.213061 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]     12.213083 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]     12.214076 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
    [MCU2_0]     12.214263 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
    [MCU2_0]     12.214453 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
    [MCU2_0]     12.214629 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
    [MCU2_0]     12.214798 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
    [MCU2_0]     12.215008 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
    [MCU2_0]     12.215193 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
    [MCU2_0]     12.215380 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
    [MCU2_0]     12.215575 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
    [MCU2_0]     12.215770 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
    [MCU2_0]     12.215954 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
    [MCU2_0]     12.216145 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
    [MCU2_0]     12.216337 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
    [MCU2_0]     12.216531 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
    [MCU2_0]     12.216725 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
    [MCU2_0]     12.216913 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
    [MCU2_0]     12.217100 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
    [MCU2_0]     12.217286 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
    [MCU2_0]     12.217475 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
    [MCU2_0]     12.217670 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
    [MCU2_0]     12.217852 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
    [MCU2_0]     12.218034 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX2
    [MCU2_0]     12.218075 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_0]     12.218104 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]     12.244636 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]     12.244669 s: CSI2RX: Init ... !!!
    [MCU2_0]     12.244690 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2
    [MCU2_0]     12.244773 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.244803 s: SCICLIENT: Sciclient_pmSetModuleState module=38 state=2
    [MCU2_0]     12.244885 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.244911 s: SCICLIENT: Sciclient_pmSetModuleState module=39 state=2
    [MCU2_0]     12.244986 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.245012 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
    [MCU2_0]     12.245074 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.245100 s: SCICLIENT: Sciclient_pmSetModuleState module=153 state=2
    [MCU2_0]     12.245158 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     12.245310 s: CSI2RX: Init ... Done !!!
    [MCU2_0]     12.245337 s: ISS: Init ... !!!
    [MCU2_0]     12.245367 s: IssSensor_Init ... Done !!!
    [MCU2_0]     12.245434 s: IttRemoteServer_Init ... Done !!!
    [MCU2_0]     12.245462 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0]     12.245514 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0]     12.245539 s: UDMA Copy: Init ... !!!
    [MCU2_0]     12.246559 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]     12.246621 s: APP: Init ... Done !!!
    [MCU2_0]     12.246645 s: APP: Run ... !!!
    [MCU2_0]     12.246665 s: IPC: Starting echo test ...
    [MCU2_0]     12.248749 s: APP: Run ... Done !!!
    [MCU2_0]     12.249442 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C7X_1[P] C7X_2[.]
    [MCU2_0]     12.249517 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C7X_1[P] C7X_2[P]
    [MCU2_0]     12.249578 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C7X_1[P] C7X_2[P]
    [MCU2_1]      3.971991 s: CIO: Init ... Done !!!
    [MCU2_1]      3.972040 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      3.972072 s: CPU is running FreeRTOS
    [MCU2_1]      3.972092 s: APP: Init ... !!!
    [MCU2_1]      3.972111 s: SCICLIENT: Init ... !!!
    [MCU2_1]      3.972247 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
    [MCU2_1]      3.972280 s: SCICLIENT: DMSC FW revision 0x8
    [MCU2_1]      3.972306 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      3.972336 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      3.972358 s: UDMA: Init ... !!!
    [MCU2_1]      3.973380 s: UDMA: Init ... Done !!!
    [MCU2_1]      3.973427 s: MEM: Init ... !!!
    [MCU2_1]      3.973459 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
    [MCU2_1]      3.973513 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 60080000 of size 524288 bytes !!!
    [MCU2_1]      3.973563 s: MEM: Init ... Done !!!
    [MCU2_1]      3.973584 s: IPC: Init ... !!!
    [MCU2_1]      3.973638 s: IPC: 5 CPUs participating in IPC !!!
    [MCU2_1]      3.973675 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]     12.177848 s: IPC: HLOS is ready !!!
    [MCU2_1]     12.186974 s: IPC: Init ... Done !!!
    [MCU2_1]     12.187012 s: APP: Syncing with 4 CPUs ... !!!
    [MCU2_1]     12.187046 s: APP: Syncing with 4 CPUs ... Done !!!
    [MCU2_1]     12.187076 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]     12.188370 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]     12.188444 s: FVID2: Init ... !!!
    [MCU2_1]     12.188497 s: FVID2: Init ... Done !!!
    [MCU2_1]     12.188519 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]     12.188541 s: SCICLIENT: Sciclient_pmSetModuleState module=58 state=2
    [MCU2_1]     12.188810 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     12.188839 s: SCICLIENT: Sciclient_pmSetModuleState module=62 state=2
    [MCU2_1]     12.188950 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     12.188975 s: VHWA: DOF Init ... !!!
    [MCU2_1]     12.194028 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]     12.194061 s: VHWA: SDE Init ... !!!
    [MCU2_1]     12.196171 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]     12.196200 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]     12.196233 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]     12.196255 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]     12.196277 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]     12.197289 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
    [MCU2_1]     12.197469 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
    [MCU2_1]     12.197648 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
    [MCU2_1]     12.197691 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [MCU2_1]     12.197720 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]     12.197953 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]     12.197983 s: UDMA Copy: Init ... !!!
    [MCU2_1]     12.198964 s: UDMA Copy: Init ... Done !!!
    [MCU2_1]     12.198999 s: APP: Init ... Done !!!
    [MCU2_1]     12.199022 s: APP: Run ... !!!
    [MCU2_1]     12.199041 s: IPC: Starting echo test ...
    [MCU2_1]     12.201105 s: APP: Run ... Done !!!
    [MCU2_1]     12.201649 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[.]
    [MCU2_1]     12.201722 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[P]
    [MCU2_1]     12.249356 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C7X_1[P] C7X_2[P]
    [C7x_1 ]      4.126411 s: CIO: Init ... Done !!!
    [C7x_1 ]      4.126426 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]      4.126437 s: CPU is running FreeRTOS
    [C7x_1 ]      4.126446 s: APP: Init ... !!!
    [C7x_1 ]      4.126454 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      4.126568 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
    [C7x_1 ]      4.126583 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_1 ]      4.126594 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]      4.126605 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      4.126615 s: UDMA: Init ... !!!
    [C7x_1 ]      4.127439 s: UDMA: Init ... Done !!!
    [C7x_1 ]      4.127452 s: MEM: Init ... !!!
    [C7x_1 ]      4.127464 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
    [C7x_1 ]      4.127487 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 3964928 bytes !!!
    [C7x_1 ]      4.127506 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
    [C7x_1 ]      4.127523 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]      4.127541 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!!
    [C7x_1 ]      4.127560 s: MEM: Init ... Done !!!
    [C7x_1 ]      4.127568 s: IPC: Init ... !!!
    [C7x_1 ]      4.127582 s: IPC: 5 CPUs participating in IPC !!!
    [C7x_1 ]      4.127597 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     10.643478 s: IPC: HLOS is ready !!!
    [C7x_1 ]     10.645181 s: IPC: Init ... Done !!!
    [C7x_1 ]     10.645196 s: APP: Syncing with 4 CPUs ... !!!
    [C7x_1 ]     12.187048 s: APP: Syncing with 4 CPUs ... Done !!!
    [C7x_1 ]     12.187066 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     12.187220 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     12.187246 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     12.187284 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     12.187300 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     12.187542 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
    [C7x_1 ]     12.187608 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
    [C7x_1 ]     12.187670 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
    [C7x_1 ]     12.187734 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
    [C7x_1 ]     12.187799 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
    [C7x_1 ]     12.187866 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
    [C7x_1 ]     12.187929 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
    [C7x_1 ]     12.187995 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
    [C7x_1 ]     12.188019 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C7x_1 ]     12.188033 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     12.188163 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     12.188176 s: APP: Init ... Done !!!
    [C7x_1 ]     12.188186 s: APP: Run ... !!!
    [C7x_1 ]     12.188195 s: IPC: Starting echo test ...
    [C7x_1 ]     12.188335 s: APP: Run ... Done !!!
    [C7x_1 ]     12.189321 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[s] C7X_2[P]
    [C7x_1 ]     12.201540 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[s] C7X_2[P]
    [C7x_1 ]     12.249308 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[s] C7X_2[P]
    [C7x_2 ]      4.188317 s: CIO: Init ... Done !!!
    [C7x_2 ]      4.188334 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]      4.188346 s: CPU is running FreeRTOS
    [C7x_2 ]      4.188355 s: APP: Init ... !!!
    [C7x_2 ]      4.188363 s: SCICLIENT: Init ... !!!
    [C7x_2 ]      4.188474 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
    [C7x_2 ]      4.188490 s: SCICLIENT: DMSC FW revision 0x8
    [C7x_2 ]      4.188501 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_2 ]      4.188513 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]      4.188522 s: UDMA: Init ... !!!
    [C7x_2 ]      4.189370 s: UDMA: Init ... Done !!!
    [C7x_2 ]      4.189385 s: MEM: Init ... !!!
    [C7x_2 ]      4.189396 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 127000000 of size 16777216 bytes !!!
    [C7x_2 ]      4.189418 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
    [C7x_2 ]      4.189437 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
    [C7x_2 ]      4.189455 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 128000000 of size 67108864 bytes !!!
    [C7x_2 ]      4.189475 s: MEM: Init ... Done !!!
    [C7x_2 ]      4.189483 s: IPC: Init ... !!!
    [C7x_2 ]      4.189498 s: IPC: 5 CPUs participating in IPC !!!
    [C7x_2 ]      4.189513 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]     10.861875 s: IPC: HLOS is ready !!!
    [C7x_2 ]     10.863583 s: IPC: Init ... Done !!!
    [C7x_2 ]     10.863598 s: APP: Syncing with 4 CPUs ... !!!
    [C7x_2 ]     12.187048 s: APP: Syncing with 4 CPUs ... Done !!!
    [C7x_2 ]     12.187065 s: REMOTE_SERVICE: Init ... !!!
    [C7x_2 ]     12.187246 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_2 ]     12.187295 s:  VX_ZONE_INIT:Enabled
    [C7x_2 ]     12.187309 s:  VX_ZONE_ERROR:Enabled
    [C7x_2 ]     12.187320 s:  VX_ZONE_WARNING:Enabled
    [C7x_2 ]     12.187829 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP-1
    [C7x_2 ]     12.187853 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
    [C7x_2 ]     12.187866 s: APP: OpenVX Target kernel init ... !!!
    [C7x_2 ]     12.188121 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_2 ]     12.188136 s: UDMA Copy: Init ... !!!
    [C7x_2 ]     12.188896 s: UDMA Copy: Init ... Done !!!
    [C7x_2 ]     12.188912 s: APP: Init ... Done !!!
    [C7x_2 ]     12.188923 s: APP: Run ... !!!
    [C7x_2 ]     12.188931 s: IPC: Starting echo test ...
    [C7x_2 ]     12.189061 s: APP: Run ... Done !!!
    [C7x_2 ]     12.189332 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[P] C7X_2[s]
    [C7x_2 ]     12.201566 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[P] C7X_2[s]
    [C7x_2 ]     12.249329 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[P] C7X_2[s]
    root@j721s2-evm:/opt/vision_apps# ./run_app_single_cam.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    IPC: Init ... !!!
        51.537887 s: GTC Frequency = 200 MHz
        51.543361 s:  VX_ZONE_INIT:Enabled
        51.543377 s:  VX_ZONE_ERROR:Enabled
        51.543384 s:  VX_ZONE_WARNING:Enabled
        51.544343 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
        51.545461 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
    sensor_selection = [0]
    ldc_enable = [0]
    num_frames_to_run = [1000000000]
    is_interactive = [1]
    IttCtrl_registerHandler: command echo registered at location 0
    IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
    IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
    IttCtrl_registerHandler: command iss_raw_save registered at location 3
    IttCtrl_registerHandler: command iss_yuv_save registered at location 4
    IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
    IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
    IttCtrl_registerHandler: command dev_ctrl registered at location 7
    IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
     NETWORK: Opened at IP Addr = 1.4.16.64, socket port=5000!!!
        51.558281 s: ISS: Enumerating sensors ... !!!
        56.067851 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
        56.067901 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
        56.067923 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
        56.067930 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
        56.067935 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
        56.067941 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
    Select camera port index 0-11 : Invalid entry
    . Please choose between 0 and 11
    Select camera port index 0-11 : 0
    6 registered sensor drivers
    a : IMX390-UB953_D3
    b : AR0233-UB953_MARS
    c : AR0820-UB953_LI
    d : UB9xxx_RAW12_TESTPATTERN
    e : UB96x_UYVY_TESTPATTERN
    f : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor : Invalid selection
    . Try again
    a : IMX390-UB953_D3
    c : AR0820-UB953_LI
    f : GW_AR0233_UYVY
    Select a sensor above or press '0' to autodetect the sensor : a
    Sensor selected : IMX390-UB953_D3
    LDC Selection Yes(1)/No(0) : LDC Selection Yes(1)/No(0) : 0
    Querying IMX390-UB953_D3
        62.431724 s: ISS: Querying sensor [IMX390-UB953_D3] ... !!!
        62.431984 s: ISS: Querying sensor [IMX390-UB953_D3] ... Done !!!
        62.431998 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_PWRON ... !!!
        62.432269 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]     62.432148 s: IMX390_PowerOn : chId = 0x0
    [MCU2_0]     62.944553 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]     62.944599 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
    [MCU2_0]     63.332524 s:  Configuring IMX390 imager 0x40.. Please wait till it finishes
        65.410547 s: ISS: Initializing sensor [IMX390-UB953_D3] ... Done !!!
    read_test_image_raw : Unable to open file /opt/vision_apps/test_data/img_test.raw
    app_create_viss : sensor_dcc_id = 390
        65.454683 s:  VX_ZONE_ERROR:[ownContextSendCmd:799] Command ack message returned failure cmd_status: -1
        65.454711 s:  VX_ZONE_ERROR:[ownContextSendCmd:835] tivxEventWait() failed.
        65.454731 s:  VX_ZONE_ERROR:[ownNodeKernelInit:527] Target kernel, TIVX_CMD_NODE_CREATE failed for node node_109
        65.454738 s:  VX_ZONE_ERROR:[ownNodeKernelInit:528] Please be sure the target callbacks have been registered for this core
        65.454745 s:  VX_ZONE_ERROR:[ownNodeKernelInit:529] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
        65.454919 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 4, kernel com.ti.hwa.display ... failed !!!
        65.454932 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
        65.454938 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
    Scaler is enabled
    [MCU2_0]     65.454470 s: src/drv/disp/dss_dispApi.c @ Line 336:
    [MCU2_0]     65.454507 s: Display Controller registration failed for DSS
    [MCU2_0]     65.454563 s:  VX_ZONE_ERROR:[tivxDisplayCreate:545] DISPLAY: ERROR: Display Create Failed!
    [MCU2_0]     65.455121 s: ==========================================================
    [MCU2_0]     65.455177 s:  Capture Status: Instance|0
    [MCU2_0]     65.455203 s: ==========================================================
    [MCU2_0]     65.455239 s:  overflowCount: 0
    [MCU2_0]     65.455267 s:  spuriousUdmaIntrCount: 0
    [MCU2_0]     65.455297 s:  frontFIFOOvflCount: 0
    [MCU2_0]     65.455323 s:  crcCount: 0
    [MCU2_0]     65.455348 s:  eccCount: 0
    [MCU2_0]     65.455374 s:  correctedEccCount: 0
    [MCU2_0]     65.455402 s:  dataIdErrorCount: 0
    [MCU2_0]     65.455438 s:  invalidAccessCount: 0
    [MCU2_0]     65.455466 s:  invalidSpCount: 0
    [MCU2_0]     65.455498 s:  strmFIFOOvflCount[0]: 0
    [MCU2_0]     65.455531 s:  strmFIFOOvflCount[1]: 0
    [MCU2_0]     65.455556 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
    [MCU2_0]     65.455619 s:            0 |                 0 |                    0 |                0 |                 0 |
    [MCU2_0]     65.455970 s: ==========================================================
    [MCU2_0]     65.456019 s:  Capture Status: Instance|1
    [MCU2_0]     65.456043 s: ==========================================================
    [MCU2_0]     65.456079 s:  overflowCount: 0
    [MCU2_0]     65.456107 s:  spuriousUdmaIntrCount: 0
    [MCU2_0]     65.456136 s:  frontFIFOOvflCount: 0
    [MCU2_0]     65.456163 s:  crcCount: 0
    [MCU2_0]     65.456187 s:  eccCount: 0
    [MCU2_0]     65.456213 s:  correctedEccCount: 0
    [MCU2_0]     65.456241 s:  dataIdErrorCount: 0
    [MCU2_0]     65.456270 s:  invalidAccessCount: 0
    [MCU2_0]     65.456297 s:  invalidSpCount: 0
    [MCU2_0]     65.456329 s:  strmFIFOOvflCount[0]: 0
    [MCU2_0]     65.456361 s:  strmFIFOOvflCount[1]: 0
    [MCU2_0]     65.456386 s:  Channel Num | Frame Queue Count | Frame De-queue Count | Frame Drop Count | Error Frame Count |
        65.458331 s: ISS: Starting sensor [IMX390-UB953_D3] ... !!!
     Demo : Single Camera w/ 2A
     p: Print performance statistics
     s: Save Sensor RAW, VISS Output and H3A output images to File System
     e: Export performance statistics
     u: Update DCC from File System
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice: [MCU2_0]     65.970567 s: Error writing 0x1 to UB960 register 0x4c
    [MCU2_0]     65.970619 s:  UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
        66.012603 s: ISS: Starting sensor [IMX390-UB953_D3] ... !!!
    get_dcc_dir_size : Could not open directory or directory is empty /opt/vision_apps/dcc/IMX390-UB953_D3/wdr
    There are two DP ports on the EVK. Is there a way to confirm DP output using the Bridge IC that switches from DSI?
    Is this EVK same as the J721s2 EVM from TI in which there are 2 DP ports, Display port 0 for eDP and Display Port 1 for DSI (Bridged to DP)
    Is this the same one?
    Also, May I know which SDK version are you using?
    Nikhil
    I'm using SDK  ti-processor-sdk-rtos-j721s2-evm-08_06_01_03 and ti-processor-sdk-linux-j721s2-evm-08_06_01_02.
    And I have the same EVK.
    JK
  • Hi JK,
    DSI to eDP bridge is not supported currently in the SDK.
    It will be part of SDK 9.2 release.
    Meanwhile, you could use the below patch to enable the same
    In order to enable DSI to eDP bridge on the J721S2 EVM, there are three changes required, please find below details on them.
    Please Note that this is currently work in progress and the testing is ongoing. The feature however is enabled using below patches
    1.
    please apply attached patch on top of ${PSDK_LINUX}/board-support\ti-u-boot-2023.04+gitAUTOINC+71b8c840ca-g71b8c840ca folder. This patch enables one of the pin output from IO expander. This is required to power on DSI to eDP bridge. After applying the patch, please rebuild uboot and copy uboot components (tiboot3.bin, uboot.img, tispl.bin) files to the SD card.
    /cfs-file/__key/communityserver-discussions-components-files/791/j721s2_5F00_uboot_5F00_mux_5F00_enable.patch
    2.
    Similar patch is also required in the Linux dtb file. Please apply attached patch on ${PSDK_LINUX}/board-support\ti-linux-kernel-6.1.46+gitAUTOINC+5892b80d6b-g5892b80d6b folder, rebuild Linux dtb files and copy generated
    board-support/ti-linux-kernel-6.1.46+gitAUTOINC+5892b80d6b-g5892b80d6b/arch/arm64/boot/dts/ti/k3-j721s2-common-proc-board.dtb
    file to SD card.
    This is also required to enable the output pin from IO expander
    /cfs-file/__key/communityserver-discussions-components-files/791/j721s2_5F00_Linux_5F00_enable_5F00_mux.patch
    3.
    please apply attached patch on ti-processor-sdk-rtos-j721s2-evm-09_01_00_06\vision_apps folder. This enabled dual display output in vision apps. I have by default enabled dual display output in vision apps in this patch, so you can use app_tidl demo and it will start outputting via DSI interface and eDP interface.
    /cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_TIOVX_2D00_1482_2D00_Add_2D00_Dual_2D00_Display_2D00_to_2D00_J7Quad_2D00_in_2D00_TIOVX_2D00_node.patch
    Nikhil
  • Hello. Nikhil.
    SEE : https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1227640/faq-tda4vm-tda4vl-tda4al-tda4vh-dra821-how-can-we-make-the-jacinto-sdk-compatible-for-device-variants-yxz
    As I mentioned before, in the patch for TDA4AL, ENABLE_DSS_EDP, ENABLE_DSS_HDMI, and ENABLE_DSS_DSI are all undefined.
    To enable DSI to eDP output on TDA4AL(NOT j721s2), what steps should we take?
    JK
  • Hi JK,
    You need to enable ENABLE_DSS_DSI for this.
    Nikhil
