Part Number: AM3352
Error in the log:
tony@ubuntu22:~/ti-processor-sdk-linux-am335x-evm-09.01.00.001$ make u-boot
Building U-boot
mkdir -p /home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/u-boot-build
make -j 4 -C /home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot* ARCH=arm CROSS_COMPILE=/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf- am335x_evm_defconfig \
O=/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/u-boot-build
make[1]: Entering directory '/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2'
make[2]: Entering directory '/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/u-boot-build'
GEN Makefile
# configuration written to .config
make[2]: Leaving directory '/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/u-boot-build'
make[1]: Leaving directory '/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2'
make -j 4 -C /home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot* ARCH=arm CROSS_COMPILE=/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/external-toolchain-dir/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf- \
O=/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/u-boot-build CONFIG_MKIMAGE_DTC_PATH=/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot*/scripts/dtc/dtc
GEN Makefile
scripts/kconfig/conf --syncconfig Kconfig
CFG u-boot.cfg
GEN include/autoconf.mk.dep
CFG spl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN Makefile
UPD include/generated/timestamp_autogenerated.h
ENVC include/generated/env.txt
ENVP include/generated/env.in
ENVT include/generated/environment.h
Using /home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2 as source for U-Boot
CC cmd/version.o
AR cmd/built-in.o
CC env/common.o
CC lib/display_options.o
CC lib/efi_loader/dtbdump.o
/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/lib/display_options.c: In function ‘print_freq’:
/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/lib/display_options.c:59:9: internal compiler error: Illegal instruction
59 | unsigned long d = 1e9;
AR env/built-in.o
CC lib/efi_loader/initrddump.o
0x7fbee39b351f ???
./signal/../sysdeps/unix/sysv/linux/x86_64/libc_sigaction.c:0
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <https://bugs.linaro.org/> for instructions.
make[3]: *** [/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/scripts/Makefile.build:256: lib/display_options.o] Error 1
make[3]: *** Waiting for unfinished jobs....
CC spl/common/spl/spl.o
LD lib/efi_loader/dtbdump_efi.so
LD lib/efi_loader/initrddump_efi.so
OBJCOPY lib/efi_loader/dtbdump.efi
OBJCOPY lib/efi_loader/initrddump.efi
make[2]: *** [/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/Makefile:1847: lib] Error 2
make[2]: *** Waiting for unfinished jobs....
CC spl/env/common.o
CC spl/lib/display_options.o
AR spl/env/built-in.o
AR spl/common/spl/built-in.o
0x7fd05ad7051f ???
make[4]: *** [/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/scripts/Makefile.build:256: spl/lib/display_options.o] Error 1
make[3]: *** [/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/scripts/Makefile.spl:533: spl/lib] Error 2
CC spl/net/arp.o
CC spl/net/bootp.o
CC spl/net/eth-uclass.o
CC spl/net/eth_common.o
CC spl/net/net.o
CC spl/net/nfs.o
CC spl/net/ping.o
CC spl/net/tftp.o
AR spl/net/built-in.o
make[2]: *** [/home/tony/ti-processor-sdk-linux-am335x-evm-09.01.00.001/board-support/ti-u-boot-2023.04+gitAUTOINC+d74d0993e2-gd74d0993e2/Makefile:2043: spl/u-boot-spl] Error 2
make[1]: *** [Makefile:177: sub-make] Error 2
make: *** [makerules/Makefile_u-boot:8: u-boot] Error 2
