Hi TI,
I want to enable networking on a custom board in U-Boot. Our hardware looks the following:
- Ethernet Ports are all connected to Main Domain Ethernet Switch (CPSW0)
- We are using SGMII interface for all connected PHYs.
- We are using only TI DP83867 Ethernet PHYs.
- In specific: SGMII5 is connected to Phy with adress 0x0; SGMII6 is connected to Phy with adress 0x1; SGMII7 is connected to Phy with adress 0x2
I applied the following patches mentioned in this thread (https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1266033/dra829v-enable-cpsw0-main-domain-ethernet-switch-in-u-boot/4805685): 0001, 0002, 0003, 0010, 0011, 0012, 0013 0014.
At the moment, I am only interested in the PHY connected to SGMII7 interface with hardware defined address 0x2.
The relevant device tree files are the following:
Board Specific Device Tree:
// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/ */ /dts-v1/; #include "k3-j721e-som-p0.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/net/ti-dp83867.h> #include <dt-bindings/phy/phy-cadence.h> / { chosen { stdout-path = "serial8:115200n8"; bootargs = "console=ttyS8,115200n8 earlycon=ns16550a,mmio32,0x02860000"; }; evm_12v0: fixedregulator-evm12v0 { /* main supply */ compatible = "regulator-fixed"; regulator-name = "evm_12v0"; regulator-min-microvolt = <12000000>; regulator-max-microvolt = <12000000>; regulator-always-on; regulator-boot-on; }; vsys_3v3: fixedregulator-vsys3v3 { /* Output of LMS140 */ compatible = "regulator-fixed"; regulator-name = "vsys_3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&evm_12v0>; regulator-always-on; regulator-boot-on; }; vsys_5v0: fixedregulator-vsys5v0 { /* Output of LM5140 */ compatible = "regulator-fixed"; regulator-name = "vsys_5v0"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; vin-supply = <&evm_12v0>; regulator-always-on; regulator-boot-on; }; }; &main_pmx0 { mycpts0_pins_default: mycpts0-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x228, PIN_INPUT, 1) /* (Y6) I2C1_SCL.CPTS0_HW1TSPUSH */ J721E_IOPAD(0x22c, PIN_INPUT, 1) /* (AA6) I2C1_SDA.CPTS0_HW2TSPUSH */ J721E_IOPAD(0x230, PIN_INPUT, 2) /* (U2) ECAP0_IN_APWM_OUT.CPTS0_RFT_CLK */ J721E_IOPAD(0x1c4, PIN_INPUT, 1) /* (Y4) SPI0_CS1.CPTS0_TS_COMP */ J721E_IOPAD(0x1d8, PIN_INPUT, 1) /* (W4) SPI1_CS1.CPTS0_TS_SYNC */ >; }; mymdio1_pins_default: mymdio1-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x1bc, PIN_OUTPUT, 0) /* (V24) MDIO0_MDC */ J721E_IOPAD(0x1b8, PIN_INPUT, 0) /* (V26) MDIO0_MDIO */ >; }; myuart6_main_pins_default: myuart6_main-default-pins { pinctrl-single,pins = < J721E_IOPAD(0xd0, PIN_INPUT, 14) /* (AC27) PRG0_PRU0_GPO8.UART6_RXD */ J721E_IOPAD(0xd4, PIN_OUTPUT, 14) /* (AB26) PRG0_PRU0_GPO9.UART6_TXD */ >; }; myusb0_spare_pins_default: myusb0_spare-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x210, PIN_OUTPUT, 3) /* (W3) MCAN1_RX.USB0_DRVVBUS */ >; }; mygpio0_pins_default: mygpio0-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x18, PIN_INPUT, 7) /* (AD20) PRG1_PRU0_GPO5.GPIO0_6 */ J721E_IOPAD(0x20, PIN_OUTPUT, 7) /* (AE20) PRG1_PRU0_GPO7.GPIO0_8 */ J721E_IOPAD(0x2c, PIN_INPUT, 7) /* (AD21) PRG1_PRU0_GPO10.GPIO0_11 */ J721E_IOPAD(0x4c, PIN_OUTPUT, 7) /* (AJ21) PRG1_PRU0_GPO17.GPIO0_18 */ J721E_IOPAD(0x50, PIN_OUTPUT, 7) /* (AE21) PRG1_PRU0_GPO18.GPIO0_19 */ J721E_IOPAD(0x54, PIN_INPUT, 7) /* (AH21) PRG1_PRU0_GPO19.GPIO0_20 */ J721E_IOPAD(0x58, PIN_INPUT, 7) /* (AE22) PRG1_PRU1_GPO0.GPIO0_21 */ J721E_IOPAD(0x5c, PIN_INPUT, 7) /* (AG23) PRG1_PRU1_GPO1.GPIO0_22 */ J721E_IOPAD(0x60, PIN_INPUT, 7) /* (AF23) PRG1_PRU1_GPO2.GPIO0_23 */ J721E_IOPAD(0x6c, PIN_INPUT, 7) /* (AG21) PRG1_PRU1_GPO5.GPIO0_26 */ J721E_IOPAD(0x70, PIN_INPUT, 7) /* (AE23) PRG1_PRU1_GPO6.GPIO0_27 */ J721E_IOPAD(0x78, PIN_INPUT, 7) /* (Y23) PRG1_PRU1_GPO8.GPIO0_29 */ J721E_IOPAD(0x88, PIN_INPUT_PULLUP, 7) /* (AH25) PRG1_PRU1_GPO12.GPIO0_33 */ J721E_IOPAD(0x8c, PIN_INPUT_PULLUP, 7) /* (AG25) PRG1_PRU1_GPO13.GPIO0_34 */ J721E_IOPAD(0x90, PIN_INPUT_PULLUP, 7) /* (AH26) PRG1_PRU1_GPO14.GPIO0_35 */ J721E_IOPAD(0x94, PIN_INPUT, 7) /* (AJ27) PRG1_PRU1_GPO15.GPIO0_36 */ J721E_IOPAD(0x98, PIN_INPUT, 7) /* (AJ26) PRG1_PRU1_GPO16.GPIO0_37 */ J721E_IOPAD(0xac, PIN_OUTPUT, 7) /* (AD18) PRG1_MDIO0_MDC.GPIO0_42 */ J721E_IOPAD(0xc4, PIN_INPUT, 7) /* (AC29) PRG0_PRU0_GPO5.GPIO0_48 */ J721E_IOPAD(0xd8, PIN_INPUT, 7) /* (AB25) PRG0_PRU0_GPO10.GPIO0_53 */ J721E_IOPAD(0xfc, PIN_INPUT, 7) /* (AB28) PRG0_PRU0_GPO19.GPIO0_62 */ J721E_IOPAD(0x114, PIN_INPUT, 7) /* (AB27) PRG0_PRU1_GPO5.GPIO0_68 */ J721E_IOPAD(0x120, PIN_INPUT, 7) /* (AA28) PRG0_PRU1_GPO8.GPIO0_71 */ J721E_IOPAD(0x124, PIN_INPUT, 7) /* (Y24) PRG0_PRU1_GPO9.GPIO0_72 */ J721E_IOPAD(0x128, PIN_INPUT, 7) /* (AA25) PRG0_PRU1_GPO10.GPIO0_73 */ J721E_IOPAD(0x1a4, PIN_INPUT, 7) /* (W26) RGMII6_RXC.GPIO0_104 */ >; }; }; &wkup_pmx0 { mywkup_gpio0_pins_default: mywkup_gpio0-default-pins { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 7) /* (C21) MCU_OSPI0_LBCLKO.WKUP_GPIO0_17 */ J721E_WKUP_IOPAD(0x8, PIN_OUTPUT, 7) /* (D21) MCU_OSPI0_DQS.WKUP_GPIO0_18 */ J721E_WKUP_IOPAD(0x1c, PIN_OUTPUT, 7) /* (F21) MCU_OSPI0_D4.WKUP_GPIO0_23 */ J721E_WKUP_IOPAD(0x20, PIN_OUTPUT, 7) /* (E21) MCU_OSPI0_D5.WKUP_GPIO0_24 */ J721E_WKUP_IOPAD(0x24, PIN_OUTPUT, 7) /* (B22) MCU_OSPI0_D6.WKUP_GPIO0_25 */ J721E_WKUP_IOPAD(0x28, PIN_OUTPUT, 7) /* (G21) MCU_OSPI0_D7.WKUP_GPIO0_26 */ J721E_WKUP_IOPAD(0x58, PIN_INPUT, 7) /* (B27) MCU_RGMII1_TX_CTL.WKUP_GPIO0_38 */ J721E_WKUP_IOPAD(0x5c, PIN_INPUT, 7) /* (C25) MCU_RGMII1_RX_CTL.WKUP_GPIO0_39 */ J721E_WKUP_IOPAD(0x6c, PIN_OUTPUT, 7) /* (B25) MCU_RGMII1_TD0.WKUP_GPIO0_43 */ J721E_WKUP_IOPAD(0x70, PIN_INPUT, 7) /* (B26) MCU_RGMII1_TXC.WKUP_GPIO0_44 */ J721E_WKUP_IOPAD(0x74, PIN_INPUT, 7) /* (C24) MCU_RGMII1_RXC.WKUP_GPIO0_45 */ J721E_WKUP_IOPAD(0x7c, PIN_OUTPUT, 7) /* (D24) MCU_RGMII1_RD2.WKUP_GPIO0_47 */ J721E_WKUP_IOPAD(0x84, PIN_INPUT, 7) /* (B24) MCU_RGMII1_RD0.WKUP_GPIO0_49 */ J721E_WKUP_IOPAD(0x88, PIN_INPUT, 7) /* (E23) MCU_MDIO0_MDIO.WKUP_GPIO0_50 */ >; }; }; &main_cpsw0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mymdio1_pins_default>; }; &main_cpsw0_mdio { //reset-gpios = <&wkup_gpio1 50 GPIO_ACTIVE_LOW>; reset-port-delay-us = <120000>; cpsw9g_phy0: ethernet-phy@0 { reg = <0>; }; cpsw9g_phy1: ethernet-phy@1 { reg = <1>; }; cpsw9g_phy2: ethernet-phy@2 { reg = <2>; }; }; //&main_cpsw0_port5 { // phy-mode = "sgmii"; // mac-address = [00 00 00 00 00 00]; // phys = <&main_phy_gmii_sel 5>; // phy-handle = <&cpsw9g_phy0>; //}; //&main_cpsw0_port6 { // phy-mode = "sgmii"; // mac-address = [00 00 00 00 00 00]; // phys = <&main_phy_gmii_sel 6>; // phy-names = "portmode", "serdes-phy"; // phy-handle = <&cpsw9g_phy1>; //}; &main_cpsw0_port7 { phy-mode = "sgmii"; mac-address = [00 00 00 00 00 00]; phys = <&main_phy_gmii_sel 7>; phy-handle = <&cpsw9g_phy2>; }; &wkup_uart0 { /* Wakeup UART is used by System firmware */ status = "reserved"; }; &main_uart0 { /* UART not brought out */ status = "disabled"; }; &main_uart3 { /* UART not brought out */ status = "disabled"; }; &main_uart4 { status = "disabled"; }; &main_uart5 { /* UART not brought out */ status = "disabled"; }; &main_uart6 { pinctrl-names = "default"; pinctrl-0 = <&myuart6_main_pins_default>; status = "okay"; power-domains = <&k3_pds 283 TI_SCI_PD_SHARED>; }; &main_uart7 { /* UART not brought out */ status = "disabled"; }; &main_uart8 { /* UART not brought out */ status = "disabled"; }; &main_uart9 { /* UART not brought out */ status = "disabled"; }; &main_gpio2 { status = "disabled"; }; &main_gpio3 { status = "disabled"; }; &main_gpio4 { status = "disabled"; }; &main_gpio5 { status = "disabled"; }; &main_gpio6 { status = "disabled"; }; &main_gpio7 { status = "disabled"; }; &wkup_gpio1 { status = "disabled"; }; &main_sdhci0 { /* eMMC */ non-removable; ti,driver-strength-ohm = <50>; disable-wp; }; &main_sdhci1 { /* Unused */ status = "disabled"; }; &main_sdhci2 { /* Unused */ status = "disabled"; }; &usb_serdes_mux { idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */ }; &serdes_ln_ctrl { idle-states = <J721E_SERDES0_LANE0_PCIE0_LANE0>, <J721E_SERDES0_LANE1_QSGMII_LANE2>, <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>, <J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>, <J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>, <J721E_SERDES4_LANE0_QSGMII_LANE5>, <J721E_SERDES4_LANE1_QSGMII_LANE6>, <J721E_SERDES4_LANE2_QSGMII_LANE7>, <J721E_SERDES4_LANE3_QSGMII_LANE8>; }; &serdes_wiz3 { typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>; typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */ }; &serdes3 { serdes3_usb_link: phy@0 { reg = <0>; cdns,num-lanes = <2>; #phy-cells = <0>; cdns,phy-type = <PHY_TYPE_USB3>; resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>; }; }; &usbss0 { pinctrl-names = "default"; pinctrl-0 = <&myusb0_spare_pins_default>; ti,vbus-divider; }; &usb0 { dr_mode = "otg"; maximum-speed = "super-speed"; phys = <&serdes3_usb_link>; phy-names = "cdns3,usb3-phy"; }; &usbss1 { status = "disabled"; }; &usb1 { status = "disabled"; }; &mcu_cpsw { status = "disabled"; pinctrl-names = "default"; //pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; }; &davinci_mdio { status = "disabled"; phy0: ethernet-phy@0 { reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; }; }; &cpsw_port1 { status = "disabled"; phy-mode = "rgmii-rxid"; phy-handle = <&phy0>; }; &mcasp0 { status = "disabled"; }; &mcasp1 { status = "disabled"; }; &mcasp2 { status = "disabled"; }; &mcasp3 { status = "disabled"; }; &mcasp4 { status = "disabled"; }; &mcasp5 { status = "disabled"; }; &mcasp6 { status = "disabled"; }; &mcasp7 { status = "disabled"; }; &mcasp8 { status = "disabled"; }; &mcasp9 { status = "disabled"; }; &mcasp10 { status = "disabled"; }; &mcasp11 { status = "disabled"; }; &cmn_refclk1 { clock-frequency = <100000000>; }; &wiz0_pll1_refclk { assigned-clocks = <&wiz0_pll1_refclk>; assigned-clock-parents = <&cmn_refclk1>; }; &wiz0_refclk_dig { assigned-clocks = <&wiz0_refclk_dig>; assigned-clock-parents = <&cmn_refclk1>; }; &serdes0 { assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>, <&serdes0 CDNS_SIERRA_PLL_CMNLC1>; assigned-clock-parents = <&wiz0_pll1_refclk>, <&wiz0_pll1_refclk>; serdes0_qsgmii_link: phy@1 { reg = <1>; cdns,num-lanes = <1>; #phy-cells = <0>; cdns,phy-type = <PHY_TYPE_QSGMII>; resets = <&serdes_wiz0 2>; }; }; &pcie0_rc { status = "disabled"; }; &pcie1_rc { status = "disabled"; }; &pcie2_rc { status = "disabled"; }; &pcie0_ep { status = "disabled"; }; &pcie1_ep { status = "disabled"; }; &pcie2_ep { status = "disabled"; }; &pcie3_rc { status = "disabled"; }; &pcie3_ep { status = "disabled"; }; &dss { status = "disabled"; }; &icssg0_mdio { status = "disabled"; }; &icssg1_mdio { status = "disabled"; };
k3-j721e-main.dtsi:
// SPDX-License-Identifier: GPL-2.0 /* * Device Tree Source for J721E SoC Family Main Domain peripherals * * Copyright (C) 2016-2020 Texas Instruments Incorporated - https://www.ti.com/ */ #include <dt-bindings/phy/phy.h> #include <dt-bindings/mux/mux.h> #include <dt-bindings/mux/ti-serdes.h> / { cmn_refclk: clock-cmnrefclk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <0>; }; cmn_refclk1: clock-cmnrefclk1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <0>; }; }; &cbass_main { msmc_ram: sram@70000000 { compatible = "mmio-sram"; reg = <0x0 0x70000000 0x0 0x800000>; #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x0 0x70000000 0x800000>; atf-sram@0 { reg = <0x0 0x20000>; }; }; scm_conf: scm-conf@100000 { compatible = "ti,j721e-system-controller", "syscon", "simple-mfd"; reg = <0 0x00100000 0 0x1c000>; /* excludes pinctrl region */ #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x0 0x00100000 0x1c000>; serdes_ln_ctrl: mux@4080 { compatible = "mmio-mux"; reg = <0x00004080 0x50>; #mux-control-cells = <1>; mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */ <0x4090 0x3>, <0x4094 0x3>, /* SERDES1 lane0/1 select */ <0x40a0 0x3>, <0x40a4 0x3>, /* SERDES2 lane0/1 select */ <0x40b0 0x3>, <0x40b4 0x3>, /* SERDES3 lane0/1 select */ <0x40c0 0x3>, <0x40c4 0x3>, /* SERDES4 lane0/1/2/3 select */ <0x40c8 0x3>, <0x40cc 0x3>; /* SERDES4 lane0/1/2/3 select */ idle-states = <J721E_SERDES0_LANE0_PCIE0_LANE0>, <J721E_SERDES0_LANE1_PCIE0_LANE1>, <J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>, <J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>, <MUX_IDLE_AS_IS>, <J721E_SERDES3_LANE1_USB3_0>, <J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>, <J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>; }; usb_serdes_mux: mux-controller@4000 { compatible = "mmio-mux"; #mux-control-cells = <1>; mux-reg-masks = <0x4000 0x8000000>, /* USB0 to SERDES0/3 mux */ <0x4010 0x8000000>; /* USB1 to SERDES1/2 mux */ }; main_phy_gmii_sel: phy@4044 { compatible = "ti,am654-phy-gmii-sel"; reg = <0x4044 0x20>; #phy-cells = <1>; }; }; gic500: interrupt-controller@1800000 { compatible = "arm,gic-v3"; #address-cells = <2>; #size-cells = <2>; ranges; #interrupt-cells = <3>; interrupt-controller; reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ <0x00 0x01900000 0x00 0x100000>; /* GICR */ /* vcpumntirq: virtual CPU interface maintenance interrupt */ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; gic_its: msi-controller@1820000 { compatible = "arm,gic-v3-its"; reg = <0x00 0x01820000 0x00 0x10000>; socionext,synquacer-pre-its = <0x1000000 0x400000>; msi-controller; #msi-cells = <1>; }; }; main_gpio_intr: interrupt-controller@a00000 { compatible = "ti,sci-intr"; reg = <0x00 0x00a00000 0x00 0x800>; ti,intr-trigger-type = <1>; interrupt-controller; interrupt-parent = <&gic500>; #interrupt-cells = <1>; ti,sci = <&dmsc>; ti,sci-dev-id = <131>; ti,interrupt-ranges = <8 392 56>; }; main_navss: bus@30000000 { compatible = "simple-mfd"; #address-cells = <2>; #size-cells = <2>; ranges = <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>; dma-coherent; dma-ranges; ti,sci-dev-id = <199>; main_navss_intr: interrupt-controller@310e0000 { compatible = "ti,sci-intr"; reg = <0x0 0x310e0000 0x0 0x4000>; ti,intr-trigger-type = <4>; interrupt-controller; interrupt-parent = <&gic500>; #interrupt-cells = <1>; ti,sci = <&dmsc>; ti,sci-dev-id = <213>; ti,interrupt-ranges = <0 64 64>, <64 448 64>, <128 672 64>; }; main_udmass_inta: interrupt-controller@33d00000 { compatible = "ti,sci-inta"; reg = <0x0 0x33d00000 0x0 0x100000>; interrupt-controller; interrupt-parent = <&main_navss_intr>; msi-controller; #interrupt-cells = <0>; ti,sci = <&dmsc>; ti,sci-dev-id = <209>; ti,interrupt-ranges = <0 0 256>; }; secure_proxy_main: mailbox@32c00000 { compatible = "ti,am654-secure-proxy"; #mbox-cells = <1>; reg-names = "target_data", "rt", "scfg"; reg = <0x00 0x32c00000 0x00 0x100000>, <0x00 0x32400000 0x00 0x100000>, <0x00 0x32800000 0x00 0x100000>; interrupt-names = "rx_011"; interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; }; smmu0: iommu@36600000 { compatible = "arm,smmu-v3"; reg = <0x0 0x36600000 0x0 0x100000>; interrupt-parent = <&gic500>; interrupts = <GIC_SPI 772 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 768 IRQ_TYPE_EDGE_RISING>; interrupt-names = "eventq", "gerror"; #iommu-cells = <1>; }; hwspinlock: spinlock@30e00000 { compatible = "ti,am654-hwspinlock"; reg = <0x00 0x30e00000 0x00 0x1000>; #hwlock-cells = <1>; }; mailbox0_cluster0: mailbox@31f80000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f80000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster1: mailbox@31f81000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f81000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster2: mailbox@31f82000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f82000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster3: mailbox@31f83000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f83000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster4: mailbox@31f84000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f84000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster5: mailbox@31f85000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f85000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster6: mailbox@31f86000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f86000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster7: mailbox@31f87000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f87000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster8: mailbox@31f88000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f88000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster9: mailbox@31f89000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f89000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster10: mailbox@31f8a000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f8a000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; mailbox0_cluster11: mailbox@31f8b000 { compatible = "ti,am654-mailbox"; reg = <0x00 0x31f8b000 0x00 0x200>; #mbox-cells = <1>; ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; }; main_ringacc: ringacc@3c000000 { compatible = "ti,am654-navss-ringacc"; reg = <0x0 0x3c000000 0x0 0x400000>, <0x0 0x38000000 0x0 0x400000>, <0x0 0x31120000 0x0 0x100>, <0x0 0x33000000 0x0 0x40000>; reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; ti,num-rings = <1024>; ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ ti,sci = <&dmsc>; ti,sci-dev-id = <211>; msi-parent = <&main_udmass_inta>; }; main_udmap: dma-controller@31150000 { compatible = "ti,j721e-navss-main-udmap"; reg = <0x0 0x31150000 0x0 0x100>, <0x0 0x34000000 0x0 0x100000>, <0x0 0x35000000 0x0 0x100000>; reg-names = "gcfg", "rchanrt", "tchanrt"; msi-parent = <&main_udmass_inta>; #dma-cells = <1>; ti,sci = <&dmsc>; ti,sci-dev-id = <212>; ti,ringacc = <&main_ringacc>; ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ <0x0f>, /* TX_HCHAN */ <0x10>; /* TX_UHCHAN */ ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ <0x0b>, /* RX_HCHAN */ <0x0c>; /* RX_UHCHAN */ ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ }; cpts@310d0000 { compatible = "ti,j721e-cpts"; reg = <0x0 0x310d0000 0x0 0x400>; reg-names = "cpts"; clocks = <&k3_clks 201 1>; clock-names = "cpts"; interrupts-extended = <&main_navss_intr 391>; interrupt-names = "cpts"; ti,cpts-periodic-outputs = <6>; ti,cpts-ext-ts-inputs = <8>; }; }; main_crypto: crypto@4e00000 { compatible = "ti,j721e-sa2ul"; reg = <0x0 0x4e00000 0x0 0x1200>; power-domains = <&k3_pds 264 TI_SCI_PD_EXCLUSIVE>; #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x04e00000 0x00 0x04e00000 0x0 0x30000>; dmas = <&main_udmap 0xc000>, <&main_udmap 0x4000>, <&main_udmap 0x4001>; dma-names = "tx", "rx1", "rx2"; dma-coherent; rng: rng@4e10000 { compatible = "inside-secure,safexcel-eip76"; reg = <0x0 0x4e10000 0x0 0x7d>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; clocks = <&k3_clks 264 1>; }; }; main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ reg = <0x0 0x11c000 0x0 0x2b4>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; }; serdes_wiz0: wiz@5000000 { compatible = "ti,j721e-wiz-16g"; #address-cells = <1>; #size-cells = <1>; power-domains = <&k3_pds 292 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 292 5>, <&k3_clks 292 11>, <&cmn_refclk>; clock-names = "fck", "core_ref_clk", "ext_ref_clk"; assigned-clocks = <&k3_clks 292 11>, <&k3_clks 292 0>; assigned-clock-parents = <&k3_clks 292 15>, <&k3_clks 292 4>; num-lanes = <2>; #reset-cells = <1>; ranges = <0x5000000 0x0 0x5000000 0x10000>; wiz0_pll0_refclk: pll0-refclk { clocks = <&k3_clks 292 11>, <&cmn_refclk>; #clock-cells = <0>; assigned-clocks = <&wiz0_pll0_refclk>; assigned-clock-parents = <&k3_clks 292 11>; }; wiz0_pll1_refclk: pll1-refclk { clocks = <&k3_clks 292 0>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz0_pll1_refclk>; assigned-clock-parents = <&k3_clks 292 0>; }; wiz0_refclk_dig: refclk-dig { clocks = <&k3_clks 292 11>, <&k3_clks 292 0>, <&cmn_refclk>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz0_refclk_dig>; assigned-clock-parents = <&k3_clks 292 11>; }; wiz0_cmn_refclk_dig_div: cmn-refclk-dig-div { clocks = <&wiz0_refclk_dig>; #clock-cells = <0>; }; wiz0_cmn_refclk1_dig_div: cmn-refclk1-dig-div { clocks = <&wiz0_pll1_refclk>; #clock-cells = <0>; }; serdes0: serdes@5000000 { compatible = "ti,sierra-phy-t0"; reg-names = "serdes"; reg = <0x5000000 0x10000>; #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; resets = <&serdes_wiz0 0>; reset-names = "sierra_reset"; clocks = <&wiz0_cmn_refclk_dig_div>, <&wiz0_cmn_refclk1_dig_div>, <&wiz0_pll0_refclk>, <&wiz0_pll1_refclk>; clock-names = "cmn_refclk_dig_div", "cmn_refclk1_dig_div", "pll0_refclk", "pll1_refclk"; }; }; serdes_wiz1: wiz@5010000 { compatible = "ti,j721e-wiz-16g"; #address-cells = <1>; #size-cells = <1>; power-domains = <&k3_pds 293 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 293 5>, <&k3_clks 293 13>, <&cmn_refclk>; clock-names = "fck", "core_ref_clk", "ext_ref_clk"; assigned-clocks = <&k3_clks 293 13>, <&k3_clks 293 0>; assigned-clock-parents = <&k3_clks 293 17>, <&k3_clks 293 4>; num-lanes = <2>; #reset-cells = <1>; ranges = <0x5010000 0x0 0x5010000 0x10000>; wiz1_pll0_refclk: pll0-refclk { clocks = <&k3_clks 293 13>, <&cmn_refclk>; #clock-cells = <0>; assigned-clocks = <&wiz1_pll0_refclk>; assigned-clock-parents = <&k3_clks 293 13>; }; wiz1_pll1_refclk: pll1-refclk { clocks = <&k3_clks 293 0>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz1_pll1_refclk>; assigned-clock-parents = <&k3_clks 293 0>; }; wiz1_refclk_dig: refclk-dig { clocks = <&k3_clks 293 13>, <&k3_clks 293 0>, <&cmn_refclk>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz1_refclk_dig>; assigned-clock-parents = <&k3_clks 293 13>; }; wiz1_cmn_refclk_dig_div: cmn-refclk-dig-div{ clocks = <&wiz1_refclk_dig>; #clock-cells = <0>; }; wiz1_cmn_refclk1_dig_div: cmn-refclk1-dig-div { clocks = <&wiz1_pll1_refclk>; #clock-cells = <0>; }; serdes1: serdes@5010000 { compatible = "ti,sierra-phy-t0"; reg-names = "serdes"; reg = <0x5010000 0x10000>; #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; resets = <&serdes_wiz1 0>; reset-names = "sierra_reset"; clocks = <&wiz1_cmn_refclk_dig_div>, <&wiz1_cmn_refclk1_dig_div>, <&wiz1_pll0_refclk>, <&wiz1_pll1_refclk>; clock-names = "cmn_refclk_dig_div", "cmn_refclk1_dig_div", "pll0_refclk", "pll1_refclk"; }; }; serdes_wiz2: wiz@5020000 { compatible = "ti,j721e-wiz-16g"; #address-cells = <1>; #size-cells = <1>; power-domains = <&k3_pds 294 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 294 5>, <&k3_clks 294 11>, <&cmn_refclk>; clock-names = "fck", "core_ref_clk", "ext_ref_clk"; assigned-clocks = <&k3_clks 294 11>, <&k3_clks 294 0>; assigned-clock-parents = <&k3_clks 294 15>, <&k3_clks 294 4>; num-lanes = <2>; #reset-cells = <1>; ranges = <0x5020000 0x0 0x5020000 0x10000>; wiz2_pll0_refclk: pll0-refclk { clocks = <&k3_clks 294 11>, <&cmn_refclk>; #clock-cells = <0>; assigned-clocks = <&wiz2_pll0_refclk>; assigned-clock-parents = <&k3_clks 294 11>; }; wiz2_pll1_refclk: pll1-refclk { clocks = <&k3_clks 294 0>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz2_pll1_refclk>; assigned-clock-parents = <&k3_clks 294 0>; }; wiz2_refclk_dig: refclk-dig { clocks = <&k3_clks 294 11>, <&k3_clks 294 0>, <&cmn_refclk>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz2_refclk_dig>; assigned-clock-parents = <&k3_clks 294 11>; }; wiz2_cmn_refclk_dig_div: cmn-refclk-dig-div { clocks = <&wiz2_refclk_dig>; #clock-cells = <0>; }; wiz2_cmn_refclk1_dig_div: cmn-refclk1-dig-div { clocks = <&wiz2_pll1_refclk>; #clock-cells = <0>; }; serdes2: serdes@5020000 { compatible = "ti,sierra-phy-t0"; reg-names = "serdes"; reg = <0x5020000 0x10000>; #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; resets = <&serdes_wiz2 0>; reset-names = "sierra_reset"; clocks = <&wiz2_cmn_refclk_dig_div>, <&wiz2_cmn_refclk1_dig_div>, <&wiz2_pll0_refclk>, <&wiz2_pll1_refclk>; clock-names = "cmn_refclk_dig_div", "cmn_refclk1_dig_div", "pll0_refclk", "pll1_refclk"; }; }; serdes_wiz3: wiz@5030000 { compatible = "ti,j721e-wiz-16g"; #address-cells = <1>; #size-cells = <1>; power-domains = <&k3_pds 295 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 295 5>, <&k3_clks 295 9>, <&cmn_refclk>; clock-names = "fck", "core_ref_clk", "ext_ref_clk"; assigned-clocks = <&k3_clks 295 9>, <&k3_clks 295 0>; assigned-clock-parents = <&k3_clks 295 13>, <&k3_clks 295 4>; num-lanes = <2>; #reset-cells = <1>; ranges = <0x5030000 0x0 0x5030000 0x10000>; wiz3_pll0_refclk: pll0-refclk { clocks = <&k3_clks 295 9>, <&cmn_refclk>; #clock-cells = <0>; assigned-clocks = <&wiz3_pll0_refclk>; assigned-clock-parents = <&k3_clks 295 9>; }; wiz3_pll1_refclk: pll1-refclk { clocks = <&k3_clks 295 0>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz3_pll1_refclk>; assigned-clock-parents = <&k3_clks 295 0>; }; wiz3_refclk_dig: refclk-dig { clocks = <&k3_clks 295 9>, <&k3_clks 295 0>, <&cmn_refclk>, <&cmn_refclk1>; #clock-cells = <0>; assigned-clocks = <&wiz3_refclk_dig>; assigned-clock-parents = <&k3_clks 295 9>; }; wiz3_cmn_refclk_dig_div: cmn-refclk-dig-div { clocks = <&wiz3_refclk_dig>; #clock-cells = <0>; }; wiz3_cmn_refclk1_dig_div: cmn-refclk1-dig-div { clocks = <&wiz3_pll1_refclk>; #clock-cells = <0>; }; serdes3: serdes@5030000 { compatible = "ti,sierra-phy-t0"; reg-names = "serdes"; reg = <0x5030000 0x10000>; #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; resets = <&serdes_wiz3 0>; reset-names = "sierra_reset"; clocks = <&wiz3_cmn_refclk_dig_div>, <&wiz3_cmn_refclk1_dig_div>, <&wiz3_pll0_refclk>, <&wiz3_pll1_refclk>; clock-names = "cmn_refclk_dig_div", "cmn_refclk1_dig_div", "pll0_refclk", "pll1_refclk"; }; }; serdes_wiz4: wiz@5050000 { compatible = "ti,j721e-wiz-16g"; #address-cells = <1>; #size-cells = <1>; power-domains = <&k3_pds 297 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 297 1>, <&k3_clks 297 9>, <&cmn_refclk>; clock-names = "fck", "core_ref_clk", "ext_ref_clk"; assigned-clocks = <&k3_clks 297 9>; assigned-clock-parents = <&k3_clks 297 10>; assigned-clock-rates = <19200000>; num-lanes = <4>; #reset-cells = <1>; ranges = <0x5050000 0x0 0x5050000 0x10000>, <0xa030a00 0x0 0xa030a00 0x40>; wiz4_pll0_refclk: pll0-refclk { clocks = <&k3_clks 297 9>, <&cmn_refclk>; clock-output-names = "wiz4_pll0_refclk"; #clock-cells = <0>; assigned-clocks = <&wiz4_pll0_refclk>; assigned-clock-parents = <&k3_clks 297 9>; }; wiz4_pll1_refclk: pll1-refclk { clocks = <&k3_clks 297 9>, <&cmn_refclk>; clock-output-names = "wiz4_pll1_refclk"; #clock-cells = <0>; assigned-clocks = <&wiz4_pll1_refclk>; assigned-clock-parents = <&k3_clks 297 9>; }; wiz4_refclk_dig: refclk-dig { clocks = <&k3_clks 297 9>, <&cmn_refclk>; clock-output-names = "wiz4_refclk_dig"; #clock-cells = <0>; assigned-clocks = <&wiz4_refclk_dig>; assigned-clock-parents = <&k3_clks 297 9>; }; wiz4_cmn_refclk_dig_div: cmn-refclk-dig-div { clocks = <&wiz4_refclk_dig>; #clock-cells = <0>; }; wiz4_cmn_refclk1_dig_div: cmn-refclk1-dig-div { clocks = <&wiz4_pll1_refclk>; #clock-cells = <0>; }; serdes4: serdes@5050000 { /* * Note: we also map DPTX PHY registers as the Torrent * needs to manage those. */ compatible = "ti,j721e-serdes-10g"; reg = <0x5050000 0x10000>, <0xa030a00 0x40>; /* DPTX PHY */ reg-names = "torrent_phy", "dptx_phy"; resets = <&serdes_wiz4 0>; reset-names = "torrent_reset"; clocks = <&wiz4_pll0_refclk>; clock-names = "refclk"; #address-cells = <1>; #size-cells = <0>; serdes4_sgmii_link: phy@0 { reg = <0>; resets = <&serdes_wiz4 1>, <&serdes_wiz4 2>, <&serdes_wiz4 3>, <&serdes_wiz4 4>; cdns,phy-type = <PHY_TYPE_SGMII>; cdns,num-lanes = <4>; #phy-cells = <0>; }; }; }; pcie0_rc: pcie@2900000 { compatible = "ti,j721e-pcie-host"; reg = <0x00 0x02900000 0x00 0x1000>, <0x00 0x02907000 0x00 0x400>, <0x00 0x0d000000 0x00 0x00800000>, <0x00 0x10000000 0x00 0x00001000>; reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; interrupt-names = "link_state"; interrupts = <GIC_SPI 318 IRQ_TYPE_EDGE_RISING>; device_type = "pci"; ti,syscon-pcie-ctrl = <&scm_conf 0x4070>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 239 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 239 1>; clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; bus-range = <0x0 0xf>; vendor-id = <0x104c>; device-id = <0xb00d>; msi-map = <0x0 &gic_its 0x0 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x10001000 0x0 0x10001000 0x0 0x0010000>, <0x02000000 0x0 0x10011000 0x0 0x10011000 0x0 0x7fef000>; dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; }; pcie0_ep: pcie-ep@2900000 { compatible = "ti,j721e-pcie-ep"; reg = <0x00 0x02900000 0x00 0x1000>, <0x00 0x02907000 0x00 0x400>, <0x00 0x0d000000 0x00 0x00800000>, <0x00 0x10000000 0x00 0x08000000>; reg-names = "intd_cfg", "user_cfg", "reg", "mem"; interrupt-names = "link_state"; interrupts = <GIC_SPI 318 IRQ_TYPE_EDGE_RISING>; ti,syscon-pcie-ctrl = <&scm_conf 0x4070>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 239 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 239 1>; clock-names = "fck"; max-functions = /bits/ 8 <6>; max-virtual-functions = /bits/ 16 <4 4 4 4 0 0>; dma-coherent; }; pcie1_rc: pcie@2910000 { compatible = "ti,j721e-pcie-host"; reg = <0x00 0x02910000 0x00 0x1000>, <0x00 0x02917000 0x00 0x400>, <0x00 0x0d800000 0x00 0x00800000>, <0x00 0x18000000 0x00 0x00001000>; reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; interrupt-names = "link_state"; interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>; device_type = "pci"; ti,syscon-pcie-ctrl = <&scm_conf 0x4074>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 240 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 240 1>; clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; bus-range = <0x0 0xf>; vendor-id = <0x104c>; device-id = <0xb00d>; msi-map = <0x0 &gic_its 0x10000 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x18001000 0x0 0x18001000 0x0 0x0010000>, <0x02000000 0x0 0x18011000 0x0 0x18011000 0x0 0x7fef000>; dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; }; pcie1_ep: pcie-ep@2910000 { compatible = "ti,j721e-pcie-ep"; reg = <0x00 0x02910000 0x00 0x1000>, <0x00 0x02917000 0x00 0x400>, <0x00 0x0d800000 0x00 0x00800000>, <0x00 0x18000000 0x00 0x08000000>; reg-names = "intd_cfg", "user_cfg", "reg", "mem"; interrupt-names = "link_state"; interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>; ti,syscon-pcie-ctrl = <&scm_conf 0x4074>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 240 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 240 1>; clock-names = "fck"; max-functions = /bits/ 8 <6>; max-virtual-functions = /bits/ 16 <4 4 4 4 0 0>; dma-coherent; }; pcie2_rc: pcie@2920000 { compatible = "ti,j721e-pcie-host"; reg = <0x00 0x02920000 0x00 0x1000>, <0x00 0x02927000 0x00 0x400>, <0x00 0x0e000000 0x00 0x00800000>, <0x44 0x00000000 0x00 0x00001000>; reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; interrupt-names = "link_state"; interrupts = <GIC_SPI 342 IRQ_TYPE_EDGE_RISING>; device_type = "pci"; ti,syscon-pcie-ctrl = <&scm_conf 0x4078>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 241 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 241 1>; clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; bus-range = <0x0 0xf>; vendor-id = <0x104c>; device-id = <0xb00d>; msi-map = <0x0 &gic_its 0x20000 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x00001000 0x44 0x00001000 0x0 0x0010000>, <0x02000000 0x0 0x00011000 0x44 0x00011000 0x0 0x7fef000>; dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; }; pcie2_ep: pcie-ep@2920000 { compatible = "ti,j721e-pcie-ep"; reg = <0x00 0x02920000 0x00 0x1000>, <0x00 0x02927000 0x00 0x400>, <0x00 0x0e000000 0x00 0x00800000>, <0x44 0x00000000 0x00 0x08000000>; reg-names = "intd_cfg", "user_cfg", "reg", "mem"; interrupt-names = "link_state"; interrupts = <GIC_SPI 342 IRQ_TYPE_EDGE_RISING>; ti,syscon-pcie-ctrl = <&scm_conf 0x4078>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 241 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 241 1>; clock-names = "fck"; max-functions = /bits/ 8 <6>; max-virtual-functions = /bits/ 16 <4 4 4 4 0 0>; dma-coherent; }; pcie3_rc: pcie@2930000 { compatible = "ti,j721e-pcie-host"; reg = <0x00 0x02930000 0x00 0x1000>, <0x00 0x02937000 0x00 0x400>, <0x00 0x0e800000 0x00 0x00800000>, <0x44 0x10000000 0x00 0x00001000>; reg-names = "intd_cfg", "user_cfg", "reg", "cfg"; interrupt-names = "link_state"; interrupts = <GIC_SPI 354 IRQ_TYPE_EDGE_RISING>; device_type = "pci"; ti,syscon-pcie-ctrl = <&scm_conf 0x407c>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 242 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 242 1>; clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; bus-range = <0x0 0xf>; vendor-id = <0x104c>; device-id = <0xb00d>; msi-map = <0x0 &gic_its 0x30000 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x00001000 0x44 0x10001000 0x0 0x0010000>, <0x02000000 0x0 0x00011000 0x44 0x10011000 0x0 0x7fef000>; dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>; }; pcie3_ep: pcie-ep@2930000 { compatible = "ti,j721e-pcie-ep"; reg = <0x00 0x02930000 0x00 0x1000>, <0x00 0x02937000 0x00 0x400>, <0x00 0x0e800000 0x00 0x00800000>, <0x44 0x10000000 0x00 0x08000000>; reg-names = "intd_cfg", "user_cfg", "reg", "mem"; interrupt-names = "link_state"; interrupts = <GIC_SPI 354 IRQ_TYPE_EDGE_RISING>; ti,syscon-pcie-ctrl = <&scm_conf 0x407c>; max-link-speed = <3>; num-lanes = <2>; power-domains = <&k3_pds 242 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 242 1>; clock-names = "fck"; max-functions = /bits/ 8 <6>; max-virtual-functions = /bits/ 16 <4 4 4 4 0 0>; dma-coherent; #address-cells = <2>; #size-cells = <2>; }; main_uart0: serial@2800000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02800000 0x00 0x100>; interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 0>; clock-names = "fclk"; }; main_uart1: serial@2810000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02810000 0x00 0x100>; interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 278 0>; clock-names = "fclk"; }; main_uart2: serial@2820000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02820000 0x00 0x100>; interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 279 0>; clock-names = "fclk"; }; main_uart3: serial@2830000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02830000 0x00 0x100>; interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 280 0>; clock-names = "fclk"; }; main_uart4: serial@2840000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02840000 0x00 0x100>; interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 281 0>; clock-names = "fclk"; }; main_uart5: serial@2850000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02850000 0x00 0x100>; interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 282 0>; clock-names = "fclk"; }; main_uart6: serial@2860000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02860000 0x00 0x100>; interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 283 0>; clock-names = "fclk"; }; main_uart7: serial@2870000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02870000 0x00 0x100>; interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 284 0>; clock-names = "fclk"; }; main_uart8: serial@2880000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02880000 0x00 0x100>; interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 285 0>; clock-names = "fclk"; }; main_uart9: serial@2890000 { compatible = "ti,j721e-uart", "ti,am654-uart"; reg = <0x00 0x02890000 0x00 0x100>; interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <48000000>; current-speed = <115200>; power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 286 0>; clock-names = "fclk"; }; main_gpio0: gpio@600000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00600000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <256>, <257>, <258>, <259>, <260>, <261>, <262>, <263>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <128>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 105 0>; clock-names = "gpio"; }; main_gpio1: gpio@601000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00601000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <288>, <289>, <290>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <36>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 106 0>; clock-names = "gpio"; }; main_gpio2: gpio@610000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00610000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <264>, <265>, <266>, <267>, <268>, <269>, <270>, <271>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <128>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 107 0>; clock-names = "gpio"; }; main_gpio3: gpio@611000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00611000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <292>, <293>, <294>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <36>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 108 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 108 0>; clock-names = "gpio"; }; main_gpio4: gpio@620000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00620000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <272>, <273>, <274>, <275>, <276>, <277>, <278>, <279>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <128>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 109 0>; clock-names = "gpio"; }; main_gpio5: gpio@621000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00621000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <296>, <297>, <298>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <36>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 110 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 110 0>; clock-names = "gpio"; }; main_gpio6: gpio@630000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00630000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <280>, <281>, <282>, <283>, <284>, <285>, <286>, <287>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <128>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 111 0>; clock-names = "gpio"; }; main_gpio7: gpio@631000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x0 0x00631000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <300>, <301>, <302>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <36>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 112 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 112 0>; clock-names = "gpio"; }; main_sdhci0: mmc@4f80000 { compatible = "ti,j721e-sdhci-8bit"; reg = <0x0 0x4f80000 0x0 0x1000>, <0x0 0x4f88000 0x0 0x400>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>; clock-names = "clk_ahb", "clk_xin"; clocks = <&k3_clks 91 0>, <&k3_clks 91 1>; assigned-clocks = <&k3_clks 91 1>; assigned-clock-parents = <&k3_clks 91 2>; bus-width = <8>; mmc-hs200-1_8v; mmc-ddr-1_8v; ti,otap-del-sel-legacy = <0xf>; ti,otap-del-sel-mmc-hs = <0xf>; ti,otap-del-sel-ddr52 = <0x5>; ti,otap-del-sel-hs200 = <0x6>; ti,otap-del-sel-hs400 = <0x0>; ti,itap-del-sel-legacy = <0x10>; ti,itap-del-sel-mmc-hs = <0xa>; ti,itap-del-sel-ddr52 = <0x3>; ti,trm-icp = <0x8>; ti,strobe-sel = <0x77>; dma-coherent; }; main_sdhci1: mmc@4fb0000 { compatible = "ti,j721e-sdhci-4bit"; reg = <0x0 0x04fb0000 0x0 0x1000>, <0x0 0x4fb8000 0x0 0x400>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&k3_pds 92 TI_SCI_PD_EXCLUSIVE>; clock-names = "clk_ahb", "clk_xin"; clocks = <&k3_clks 92 5>, <&k3_clks 92 0>; assigned-clocks = <&k3_clks 92 0>; assigned-clock-parents = <&k3_clks 92 1>; ti,otap-del-sel-legacy = <0x0>; ti,otap-del-sel-sd-hs = <0xf>; ti,otap-del-sel-sdr12 = <0xf>; ti,otap-del-sel-sdr25 = <0xf>; ti,otap-del-sel-sdr50 = <0xc>; ti,otap-del-sel-ddr50 = <0xc>; ti,itap-del-sel-legacy = <0x0>; ti,itap-del-sel-sd-hs = <0x0>; ti,itap-del-sel-sdr12 = <0x0>; ti,itap-del-sel-sdr25 = <0x0>; ti,itap-del-sel-ddr50 = <0x2>; ti,trm-icp = <0x8>; ti,clkbuf-sel = <0x7>; dma-coherent; sdhci-caps-mask = <0x2 0x0>; }; main_sdhci2: mmc@4f98000 { compatible = "ti,j721e-sdhci-4bit"; reg = <0x0 0x4f98000 0x0 0x1000>, <0x0 0x4f90000 0x0 0x400>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&k3_pds 93 TI_SCI_PD_EXCLUSIVE>; clock-names = "clk_ahb", "clk_xin"; clocks = <&k3_clks 93 5>, <&k3_clks 93 0>; assigned-clocks = <&k3_clks 93 0>; assigned-clock-parents = <&k3_clks 93 1>; ti,otap-del-sel-legacy = <0x0>; ti,otap-del-sel-sd-hs = <0xf>; ti,otap-del-sel-sdr12 = <0xf>; ti,otap-del-sel-sdr25 = <0xf>; ti,otap-del-sel-sdr50 = <0xc>; ti,otap-del-sel-ddr50 = <0xc>; ti,itap-del-sel-legacy = <0x0>; ti,itap-del-sel-sd-hs = <0x0>; ti,itap-del-sel-sdr12 = <0x0>; ti,itap-del-sel-sdr25 = <0x0>; ti,itap-del-sel-ddr50 = <0x2>; ti,trm-icp = <0x8>; ti,clkbuf-sel = <0x7>; dma-coherent; sdhci-caps-mask = <0x2 0x0>; }; usbss0: cdns-usb@4104000 { compatible = "ti,j721e-usb"; reg = <0x00 0x4104000 0x00 0x100>; dma-coherent; power-domains = <&k3_pds 288 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 288 15>, <&k3_clks 288 3>; clock-names = "ref", "lpm"; assigned-clocks = <&k3_clks 288 15>; /* USB2_REFCLK */ assigned-clock-parents = <&k3_clks 288 16>; /* HFOSC0 */ #address-cells = <2>; #size-cells = <2>; ranges; usb0: usb@6000000 { compatible = "cdns,usb3"; reg = <0x00 0x6000000 0x00 0x10000>, <0x00 0x6010000 0x00 0x10000>, <0x00 0x6020000 0x00 0x10000>; reg-names = "otg", "xhci", "dev"; interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */ <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; /* otgirq.0 */ interrupt-names = "host", "peripheral", "otg"; maximum-speed = "super-speed"; dr_mode = "otg"; }; }; usbss1: cdns-usb@4114000 { compatible = "ti,j721e-usb"; reg = <0x00 0x4114000 0x00 0x100>; dma-coherent; power-domains = <&k3_pds 289 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 289 15>, <&k3_clks 289 3>; clock-names = "ref", "lpm"; assigned-clocks = <&k3_clks 289 15>; /* USB2_REFCLK */ assigned-clock-parents = <&k3_clks 289 16>; /* HFOSC0 */ #address-cells = <2>; #size-cells = <2>; ranges; usb1: usb@6400000 { compatible = "cdns,usb3"; reg = <0x00 0x6400000 0x00 0x10000>, <0x00 0x6410000 0x00 0x10000>, <0x00 0x6420000 0x00 0x10000>; reg-names = "otg", "xhci", "dev"; interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */ <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; /* otgirq.0 */ interrupt-names = "host", "peripheral", "otg"; maximum-speed = "super-speed"; dr_mode = "otg"; }; }; main_i2c0: i2c@2000000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2000000 0x0 0x100>; interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 187 0>; power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>; }; main_i2c1: i2c@2010000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2010000 0x0 0x100>; interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 188 0>; power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; }; main_i2c2: i2c@2020000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2020000 0x0 0x100>; interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 189 0>; power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; }; main_i2c3: i2c@2030000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2030000 0x0 0x100>; interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 190 0>; power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; }; main_i2c4: i2c@2040000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2040000 0x0 0x100>; interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 191 0>; power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; }; main_i2c5: i2c@2050000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2050000 0x0 0x100>; interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 192 0>; power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; }; main_i2c6: i2c@2060000 { compatible = "ti,j721e-i2c", "ti,omap4-i2c"; reg = <0x0 0x2060000 0x0 0x100>; interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clock-names = "fck"; clocks = <&k3_clks 193 0>; power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; }; ufs_wrapper: ufs-wrapper@4e80000 { compatible = "ti,j721e-ufs"; reg = <0x0 0x4e80000 0x0 0x100>; power-domains = <&k3_pds 277 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 277 1>; assigned-clocks = <&k3_clks 277 1>; assigned-clock-parents = <&k3_clks 277 4>; ranges; #address-cells = <2>; #size-cells = <2>; ufs@4e84000 { compatible = "cdns,ufshc-m31-16nm", "jedec,ufs-2.0"; reg = <0x0 0x4e84000 0x0 0x10000>; interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; freq-table-hz = <250000000 250000000>, <19200000 19200000>, <19200000 19200000>; clocks = <&k3_clks 277 0>, <&k3_clks 277 1>, <&k3_clks 277 1>; clock-names = "core_clk", "phy_clk", "ref_clk"; dma-coherent; }; }; dss: dss@4a00000 { compatible = "ti,j721e-dss"; reg = <0x00 0x04a00000 0x00 0x10000>, /* common_m */ <0x00 0x04a10000 0x00 0x10000>, /* common_s0*/ <0x00 0x04b00000 0x00 0x10000>, /* common_s1*/ <0x00 0x04b10000 0x00 0x10000>, /* common_s2*/ <0x00 0x04a20000 0x00 0x10000>, /* vidl1 */ <0x00 0x04a30000 0x00 0x10000>, /* vidl2 */ <0x00 0x04a50000 0x00 0x10000>, /* vid1 */ <0x00 0x04a60000 0x00 0x10000>, /* vid2 */ <0x00 0x04a70000 0x00 0x10000>, /* ovr1 */ <0x00 0x04a90000 0x00 0x10000>, /* ovr2 */ <0x00 0x04ab0000 0x00 0x10000>, /* ovr3 */ <0x00 0x04ad0000 0x00 0x10000>, /* ovr4 */ <0x00 0x04a80000 0x00 0x10000>, /* vp1 */ <0x00 0x04aa0000 0x00 0x10000>, /* vp2 */ <0x00 0x04ac0000 0x00 0x10000>, /* vp3 */ <0x00 0x04ae0000 0x00 0x10000>, /* vp4 */ <0x00 0x04af0000 0x00 0x10000>; /* wb */ reg-names = "common_m", "common_s0", "common_s1", "common_s2", "vidl1", "vidl2","vid1","vid2", "ovr1", "ovr2", "ovr3", "ovr4", "vp1", "vp2", "vp3", "vp4", "wb"; clocks = <&k3_clks 152 0>, <&k3_clks 152 1>, <&k3_clks 152 4>, <&k3_clks 152 9>, <&k3_clks 152 13>; clock-names = "fck", "vp1", "vp2", "vp3", "vp4"; power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "common_m", "common_s0", "common_s1", "common_s2"; dss_ports: ports { #address-cells = <1>; #size-cells = <0>; }; }; mcasp0: mcasp@2b00000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b00000 0x0 0x2000>, <0x0 0x02b08000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 544 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 545 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc400>, <&main_udmap 0x4400>; dma-names = "tx", "rx"; clocks = <&k3_clks 174 1>; clock-names = "fck"; power-domains = <&k3_pds 174 TI_SCI_PD_EXCLUSIVE>; }; mcasp1: mcasp@2b10000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b10000 0x0 0x2000>, <0x0 0x02b18000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 546 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 547 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc401>, <&main_udmap 0x4401>; dma-names = "tx", "rx"; clocks = <&k3_clks 175 1>; clock-names = "fck"; power-domains = <&k3_pds 175 TI_SCI_PD_EXCLUSIVE>; }; mcasp2: mcasp@2b20000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b20000 0x0 0x2000>, <0x0 0x02b28000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 548 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 549 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc402>, <&main_udmap 0x4402>; dma-names = "tx", "rx"; clocks = <&k3_clks 176 1>; clock-names = "fck"; power-domains = <&k3_pds 176 TI_SCI_PD_EXCLUSIVE>; }; mcasp3: mcasp@2b30000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b30000 0x0 0x2000>, <0x0 0x02b38000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 550 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 551 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc500>, <&main_udmap 0x4500>; dma-names = "tx", "rx"; clocks = <&k3_clks 177 1>; clock-names = "fck"; power-domains = <&k3_pds 177 TI_SCI_PD_EXCLUSIVE>; }; mcasp4: mcasp@2b40000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b40000 0x0 0x2000>, <0x0 0x02b48000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 552 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 553 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc501>, <&main_udmap 0x4501>; dma-names = "tx", "rx"; clocks = <&k3_clks 178 1>; clock-names = "fck"; power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>; }; mcasp5: mcasp@2b50000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b50000 0x0 0x2000>, <0x0 0x02b58000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 554 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 555 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc502>, <&main_udmap 0x4502>; dma-names = "tx", "rx"; clocks = <&k3_clks 179 1>; clock-names = "fck"; power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>; }; mcasp6: mcasp@2b60000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b60000 0x0 0x2000>, <0x0 0x02b68000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 556 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 557 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc503>, <&main_udmap 0x4503>; dma-names = "tx", "rx"; clocks = <&k3_clks 180 1>; clock-names = "fck"; power-domains = <&k3_pds 180 TI_SCI_PD_EXCLUSIVE>; }; mcasp7: mcasp@2b70000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b70000 0x0 0x2000>, <0x0 0x02b78000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 558 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 559 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc504>, <&main_udmap 0x4504>; dma-names = "tx", "rx"; clocks = <&k3_clks 181 1>; clock-names = "fck"; power-domains = <&k3_pds 181 TI_SCI_PD_EXCLUSIVE>; }; mcasp8: mcasp@2b80000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b80000 0x0 0x2000>, <0x0 0x02b88000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 560 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 561 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc505>, <&main_udmap 0x4505>; dma-names = "tx", "rx"; clocks = <&k3_clks 182 1>; clock-names = "fck"; power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>; }; mcasp9: mcasp@2b90000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02b90000 0x0 0x2000>, <0x0 0x02b98000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 562 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 563 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc506>, <&main_udmap 0x4506>; dma-names = "tx", "rx"; clocks = <&k3_clks 183 1>; clock-names = "fck"; power-domains = <&k3_pds 183 TI_SCI_PD_EXCLUSIVE>; }; mcasp10: mcasp@2ba0000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02ba0000 0x0 0x2000>, <0x0 0x02ba8000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 564 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 565 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc507>, <&main_udmap 0x4507>; dma-names = "tx", "rx"; clocks = <&k3_clks 184 1>; clock-names = "fck"; power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>; }; mcasp11: mcasp@2bb0000 { compatible = "ti,am33xx-mcasp-audio"; reg = <0x0 0x02bb0000 0x0 0x2000>, <0x0 0x02bb8000 0x0 0x1000>; reg-names = "mpu","dat"; interrupts = <GIC_SPI 566 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 567 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "tx", "rx"; dmas = <&main_udmap 0xc508>, <&main_udmap 0x4508>; dma-names = "tx", "rx"; clocks = <&k3_clks 185 1>; clock-names = "fck"; power-domains = <&k3_pds 185 TI_SCI_PD_EXCLUSIVE>; }; watchdog0: watchdog@2200000 { compatible = "ti,j7-rti-wdt"; reg = <0x0 0x2200000 0x0 0x100>; clocks = <&k3_clks 252 1>; power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>; assigned-clocks = <&k3_clks 252 1>; assigned-clock-parents = <&k3_clks 252 5>; }; watchdog1: watchdog@2210000 { compatible = "ti,j7-rti-wdt"; reg = <0x0 0x2210000 0x0 0x100>; clocks = <&k3_clks 253 1>; power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>; assigned-clocks = <&k3_clks 253 1>; assigned-clock-parents = <&k3_clks 253 5>; }; main_r5fss0: r5fss@5c00000 { compatible = "ti,j721e-r5fss"; ti,cluster-mode = <1>; #address-cells = <1>; #size-cells = <1>; ranges = <0x5c00000 0x00 0x5c00000 0x20000>, <0x5d00000 0x00 0x5d00000 0x20000>; power-domains = <&k3_pds 243 TI_SCI_PD_EXCLUSIVE>; main_r5fss0_core0: r5f@5c00000 { compatible = "ti,j721e-r5f"; reg = <0x5c00000 0x00008000>, <0x5c10000 0x00008000>; reg-names = "atcm", "btcm"; ti,sci = <&dmsc>; ti,sci-dev-id = <245>; ti,sci-proc-ids = <0x06 0xff>; resets = <&k3_reset 245 1>; firmware-name = "j7-main-r5f0_0-fw"; ti,atcm-enable = <1>; ti,btcm-enable = <1>; ti,loczrama = <1>; }; main_r5fss0_core1: r5f@5d00000 { compatible = "ti,j721e-r5f"; reg = <0x5d00000 0x00008000>, <0x5d10000 0x00008000>; reg-names = "atcm", "btcm"; ti,sci = <&dmsc>; ti,sci-dev-id = <246>; ti,sci-proc-ids = <0x07 0xff>; resets = <&k3_reset 246 1>; firmware-name = "j7-main-r5f0_1-fw"; ti,atcm-enable = <1>; ti,btcm-enable = <1>; ti,loczrama = <1>; }; }; main_r5fss1: r5fss@5e00000 { compatible = "ti,j721e-r5fss"; ti,cluster-mode = <1>; #address-cells = <1>; #size-cells = <1>; ranges = <0x5e00000 0x00 0x5e00000 0x20000>, <0x5f00000 0x00 0x5f00000 0x20000>; power-domains = <&k3_pds 244 TI_SCI_PD_EXCLUSIVE>; main_r5fss1_core0: r5f@5e00000 { compatible = "ti,j721e-r5f"; reg = <0x5e00000 0x00008000>, <0x5e10000 0x00008000>; reg-names = "atcm", "btcm"; ti,sci = <&dmsc>; ti,sci-dev-id = <247>; ti,sci-proc-ids = <0x08 0xff>; resets = <&k3_reset 247 1>; firmware-name = "j7-main-r5f1_0-fw"; ti,atcm-enable = <1>; ti,btcm-enable = <1>; ti,loczrama = <1>; }; main_r5fss1_core1: r5f@5f00000 { compatible = "ti,j721e-r5f"; reg = <0x5f00000 0x00008000>, <0x5f10000 0x00008000>; reg-names = "atcm", "btcm"; ti,sci = <&dmsc>; ti,sci-dev-id = <248>; ti,sci-proc-ids = <0x09 0xff>; resets = <&k3_reset 248 1>; firmware-name = "j7-main-r5f1_1-fw"; ti,atcm-enable = <1>; ti,btcm-enable = <1>; ti,loczrama = <1>; }; }; c66_0: dsp@4d80800000 { compatible = "ti,j721e-c66-dsp"; reg = <0x4d 0x80800000 0x00 0x00048000>, <0x4d 0x80e00000 0x00 0x00008000>, <0x4d 0x80f00000 0x00 0x00008000>; reg-names = "l2sram", "l1pram", "l1dram"; ti,sci = <&dmsc>; ti,sci-dev-id = <142>; ti,sci-proc-ids = <0x03 0xff>; resets = <&k3_reset 142 1>; firmware-name = "j7-c66_0-fw"; }; c66_1: dsp@4d81800000 { compatible = "ti,j721e-c66-dsp"; reg = <0x4d 0x81800000 0x00 0x00048000>, <0x4d 0x81e00000 0x00 0x00008000>, <0x4d 0x81f00000 0x00 0x00008000>; reg-names = "l2sram", "l1pram", "l1dram"; ti,sci = <&dmsc>; ti,sci-dev-id = <143>; ti,sci-proc-ids = <0x04 0xff>; resets = <&k3_reset 143 1>; firmware-name = "j7-c66_1-fw"; }; c71_0: dsp@64800000 { compatible = "ti,j721e-c71-dsp"; reg = <0x00 0x64800000 0x00 0x00080000>, <0x00 0x64e00000 0x00 0x0000c000>; reg-names = "l2sram", "l1dram"; ti,sci = <&dmsc>; ti,sci-dev-id = <15>; ti,sci-proc-ids = <0x30 0xff>; resets = <&k3_reset 15 1>; firmware-name = "j7-c71_0-fw"; }; main_cpsw0: ethernet@c000000 { compatible = "ti,j721e-cpsw-nuss"; #address-cells = <2>; #size-cells = <2>; reg = <0x0 0xc000000 0x0 0x200000>; reg-names = "cpsw_nuss"; ranges = <0x0 0x0 0x0 0xc000000 0x0 0x200000>; dma-coherent; clocks = <&k3_clks 19 89>; clock-names = "fck"; power-domains = <&k3_pds 19 TI_SCI_PD_EXCLUSIVE>; dmas = <&main_udmap 0xca00>, <&main_udmap 0xca01>, <&main_udmap 0xca02>, <&main_udmap 0xca03>, <&main_udmap 0xca04>, <&main_udmap 0xca05>, <&main_udmap 0xca06>, <&main_udmap 0xca07>, <&main_udmap 0x4a00>; dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7", "rx"; ethernet-ports { #address-cells = <1>; #size-cells = <0>; //main_cpsw0_port5: port@5 { // reg = <5>; // ti,mac-only; // label = "port5"; // phys = <&main_phy_gmii_sel 5>; //}; //main_cpsw0_port6: port@6 { // reg = <6>; // ti,mac-only; // label = "port6"; // phys = <&main_phy_gmii_sel 6>; //}; main_cpsw0_port7: port@7 { reg = <7>; ti,mac-only; label = "port7"; phys = <&main_phy_gmii_sel 7>; }; }; main_cpsw0_mdio: mdio@f00 { compatible = "ti,cpsw-mdio", "ti,davinci_mdio"; reg = <0x0 0xf00 0x0 0x100>; #address-cells = <1>; #size-cells = <0>; clocks = <&k3_clks 19 89>; clock-names = "fck"; bus_freq = <1000000>; }; cpts@3d000 { compatible = "ti,j721e-cpts"; reg = <0x0 0x3d000 0x0 0x400>; clocks = <&k3_clks 19 16>; clock-names = "cpts"; interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cpts"; ti,cpts-ext-ts-inputs = <4>; ti,cpts-periodic-outputs = <2>; }; }; icssg0: icssg@b000000 { compatible = "ti,j721e-icssg"; reg = <0x00 0xb000000 0x00 0x80000>; power-domains = <&k3_pds 119 TI_SCI_PD_EXCLUSIVE>; #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x00 0x0b000000 0x100000>; icssg0_mem: memories@0 { reg = <0x0 0x2000>, <0x2000 0x2000>, <0x10000 0x10000>; reg-names = "dram0", "dram1", "shrdram2"; }; icssg0_cfg: cfg@26000 { compatible = "ti,pruss-cfg", "syscon"; reg = <0x26000 0x200>; #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x26000 0x2000>; clocks { #address-cells = <1>; #size-cells = <0>; icssg0_coreclk_mux: coreclk-mux@3c { reg = <0x3c>; #clock-cells = <0>; clocks = <&k3_clks 119 24>, /* icssg0_core_clk */ <&k3_clks 119 1>; /* icssg0_iclk */ assigned-clocks = <&icssg0_coreclk_mux>; assigned-clock-parents = <&k3_clks 119 1>; }; icssg0_iepclk_mux: iepclk-mux@30 { reg = <0x30>; #clock-cells = <0>; clocks = <&k3_clks 119 3>, /* icssg0_iep_clk */ <&icssg0_coreclk_mux>; /* core_clk */ assigned-clocks = <&icssg0_iepclk_mux>; assigned-clock-parents = <&icssg0_coreclk_mux>; }; }; }; icssg0_mii_rt: mii-rt@32000 { compatible = "ti,pruss-mii", "syscon"; reg = <0x32000 0x100>; }; icssg0_mii_g_rt: mii-g-rt@33000 { compatible = "ti,pruss-mii-g", "syscon"; reg = <0x33000 0x1000>; }; icssg0_intc: interrupt-controller@20000 { compatible = "ti,icssg-intc"; reg = <0x20000 0x2000>; interrupt-controller; #interrupt-cells = <3>; interrupts = <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "host_intr0", "host_intr1", "host_intr2", "host_intr3", "host_intr4", "host_intr5", "host_intr6", "host_intr7"; }; pru0_0: pru@34000 { compatible = "ti,j721e-pru"; reg = <0x34000 0x3000>, <0x22000 0x100>, <0x22400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-pru0_0-fw"; }; rtu0_0: rtu@4000 { compatible = "ti,j721e-rtu"; reg = <0x4000 0x2000>, <0x23000 0x100>, <0x23400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-rtu0_0-fw"; }; tx_pru0_0: txpru@a000 { compatible = "ti,j721e-tx-pru"; reg = <0xa000 0x1800>, <0x25000 0x100>, <0x25400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-txpru0_0-fw"; }; pru0_1: pru@38000 { compatible = "ti,j721e-pru"; reg = <0x38000 0x3000>, <0x24000 0x100>, <0x24400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-pru0_1-fw"; }; rtu0_1: rtu@6000 { compatible = "ti,j721e-rtu"; reg = <0x6000 0x2000>, <0x23800 0x100>, <0x23c00 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-rtu0_1-fw"; }; tx_pru0_1: txpru@c000 { compatible = "ti,j721e-tx-pru"; reg = <0xc000 0x1800>, <0x25800 0x100>, <0x25c00 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-txpru0_1-fw"; }; icssg0_mdio: mdio@32400 { compatible = "ti,davinci_mdio"; reg = <0x32400 0x100>; clocks = <&k3_clks 119 1>; clock-names = "fck"; #address-cells = <1>; #size-cells = <0>; bus_freq = <1000000>; }; }; icssg1: icssg@b100000 { compatible = "ti,j721e-icssg"; reg = <0x00 0xb100000 0x00 0x80000>; power-domains = <&k3_pds 120 TI_SCI_PD_EXCLUSIVE>; #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x00 0x0b100000 0x100000>; icssg1_mem: memories@b100000 { reg = <0x0 0x2000>, <0x2000 0x2000>, <0x10000 0x10000>; reg-names = "dram0", "dram1", "shrdram2"; }; icssg1_cfg: cfg@26000 { compatible = "ti,pruss-cfg", "syscon"; reg = <0x26000 0x200>; #address-cells = <1>; #size-cells = <1>; ranges = <0x0 0x26000 0x2000>; clocks { #address-cells = <1>; #size-cells = <0>; icssg1_coreclk_mux: coreclk-mux@3c { reg = <0x3c>; #clock-cells = <0>; clocks = <&k3_clks 120 54>, /* icssg1_core_clk */ <&k3_clks 120 4>; /* icssg1_iclk */ assigned-clocks = <&icssg1_coreclk_mux>; assigned-clock-parents = <&k3_clks 120 4>; }; icssg1_iepclk_mux: iepclk-mux@30 { reg = <0x30>; #clock-cells = <0>; clocks = <&k3_clks 120 9>, /* icssg1_iep_clk */ <&icssg1_coreclk_mux>; /* core_clk */ assigned-clocks = <&icssg1_iepclk_mux>; assigned-clock-parents = <&icssg1_coreclk_mux>; }; }; }; icssg1_mii_rt: mii-rt@32000 { compatible = "ti,pruss-mii", "syscon"; reg = <0x32000 0x100>; }; icssg1_mii_g_rt: mii-g-rt@33000 { compatible = "ti,pruss-mii-g", "syscon"; reg = <0x33000 0x1000>; }; icssg1_intc: interrupt-controller@20000 { compatible = "ti,icssg-intc"; reg = <0x20000 0x2000>; interrupt-controller; #interrupt-cells = <3>; interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "host_intr0", "host_intr1", "host_intr2", "host_intr3", "host_intr4", "host_intr5", "host_intr6", "host_intr7"; }; pru1_0: pru@34000 { compatible = "ti,j721e-pru"; reg = <0x34000 0x4000>, <0x22000 0x100>, <0x22400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-pru1_0-fw"; }; rtu1_0: rtu@4000 { compatible = "ti,j721e-rtu"; reg = <0x4000 0x2000>, <0x23000 0x100>, <0x23400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-rtu1_0-fw"; }; tx_pru1_0: txpru@a000 { compatible = "ti,j721e-tx-pru"; reg = <0xa000 0x1800>, <0x25000 0x100>, <0x25400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-txpru1_0-fw"; }; pru1_1: pru@38000 { compatible = "ti,j721e-pru"; reg = <0x38000 0x4000>, <0x24000 0x100>, <0x24400 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-pru1_1-fw"; }; rtu1_1: rtu@6000 { compatible = "ti,j721e-rtu"; reg = <0x6000 0x2000>, <0x23800 0x100>, <0x23c00 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-rtu1_1-fw"; }; tx_pru1_1: txpru@c000 { compatible = "ti,j721e-tx-pru"; reg = <0xc000 0x1800>, <0x25800 0x100>, <0x25c00 0x100>; reg-names = "iram", "control", "debug"; firmware-name = "j7-txpru1_1-fw"; }; icssg1_mdio: mdio@32400 { compatible = "ti,davinci_mdio"; reg = <0x32400 0x100>; clocks = <&k3_clks 120 4>; clock-names = "fck"; #address-cells = <1>; #size-cells = <0>; bus_freq = <1000000>; }; }; main_esm: esm@700000 { compatible = "ti,j721e-esm"; reg = <0x0 0x700000 0x0 0x1000>; ti,esm-pins = <344>, <345>; bootph-pre-ram; }; };
The boot log for U-Boot is the following (Booted via USB Boot):
U-Boot SPL 2023.04-r5-initial-gb0f0c0fb4d-dirty (Mar 22 2024 - 10:48:35 +0100) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)') Trying to boot from DFU #################################################DOWNLOAD ... OK Ctrl+C to exit ... Loading Environment from nowhere... OK init_env from device 18 not supported! Starting ATF on ARM64 core... DM Built On: Mar 14 2024 14:05:26 Sciserver Version: v2023.10.0.0 RM_PM_HAL Version: Starting Sciserver..... PASSED U-Boot SPL 2023.04-a72-initial-gb0f0c0fb4d-dirty (Mar 22 2024 - 10:48:30 +0100) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)') Trying to boot from DFU cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret -61) cdns-usb3-peripheral usb@6000000: Unable to get USB3 phy (ret -22) cdns-usb3-peripheral usb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200) cdns-usb3-peripheral usb@6000000: Initialized ep0 support: cdns-usb3-peripheral usb@6000000: Initialized ep1out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep2out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep3out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep4out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep5out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep6out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep7out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep8out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep9out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep10out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep11out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep12out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep13out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep14out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep15out support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep1in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep2in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep3in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep4in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep5in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep6in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep7in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep8in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep9in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep10in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep11in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep12in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep13in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep14in support: BULK, INT ISO cdns-usb3-peripheral usb@6000000: Initialized ep15in support: BULK, INT ISO ##########DOWNLOAD ... OK Ctrl+C to exit ... U-Boot 2023.04-a72-initial-gb0f0c0fb4d-dirty (Mar 22 2024 - 10:48:30 +0100) SoC: J721E SR1.1 GP Model: Texas Instruments K3 J721E SoC DRAM: 4 GiB Core: 115 devices, 34 uclasses, devicetree: separate Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07! Flash: 0 Bytes MMC: mmc@4f80000: 0 Loading Environment from MMC... OK In: serial@2860000 Out: serial@2860000 Err: serial@2860000 am65_cpsw_nuss ethernet@c000000: K3 CPSW: nuss_ver: 0x6BA01901 cpsw_ver: 0x6BA80101 ale_ver: 0x00294104 Ports:1 mdio_freq:1000000 Net: Warning: ethernet@c000000port@7 (eth0) using random MAC address - e2:c6:b5:1a:10:68 eth0: ethernet@c000000port@7 Hit any key to stop autoboot: 0 =>
I am able to access the PHY via MDIO interface. Ethernet cable is plugged in on the according RJ45 port. The link is up. I am getting the following output when calling mdio, net and mii commands:
=> mdio list mdio@f00: ethernet@c000000port@7: 2 - TI DP83867 <--> ethernet@c000000port@7 => net list eth0 : ethernet@c000000port@7 e2:c6:b5:1a:10:68 active => mii dump 2 1 1. (796d) -- PHY status register -- (8000:0000) 1.15 = 0 100BASE-T4 able (4000:4000) 1.14 = 1 100BASE-X full duplex able (2000:2000) 1.13 = 1 100BASE-X half duplex able (1000:1000) 1.12 = 1 10 Mbps full duplex able (0800:0800) 1.11 = 1 10 Mbps half duplex able (0400:0000) 1.10 = 0 100BASE-T2 full duplex able (0200:0000) 1. 9 = 0 100BASE-T2 half duplex able (0100:0100) 1. 8 = 1 extended status (0080:0000) 1. 7 = 0 (reserved) (0040:0040) 1. 6 = 1 MF preamble suppression (0020:0020) 1. 5 = 1 A/N complete (0010:0000) 1. 4 = 0 remote fault (0008:0008) 1. 3 = 1 A/N able (0004:0004) 1. 2 = 1 link status (0002:0000) 1. 1 = 0 jabber detect (0001:0001) 1. 0 = 1 extended capabilities
So I think everything looks fine until now. However, when calling dhcp to get a valid IP address, I get the following output:
=> dhcp k3-navss-ringacc ringacc@3c000000: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 k3-navss-ringacc ringacc@3c000000: dma-ring-reset-quirk: disabled am65_cpsw_nuss_port ethernet@c000000port@7: K3 CPSW: rflow_id_base: 16 link up on port 7, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12 BOOTP broadcast 13 BOOTP broadcast 14 BOOTP broadcast 15 BOOTP broadcast 16 BOOTP broadcast 17 Retry time exceeded; starting again
Additionally, no packets sent or received from the custom board can be seen on Wireshark. However, the CPSW_STAT registers shows, that there where good frames received:
=> md 0x0c03a000 0c03a000: 00000011 00000011 00000000 00000000 ................ 0c03a010: 00000000 00000000 00000000 00000000 ................ 0c03a020: 00000000 00000000 00000000 00000000 ................ 0c03a030: 000016fa 00000000 00000000 00000000 ................ 0c03a040: 00000000 00000000 00000000 00000000 ................ 0c03a050: 00000000 00000000 00000000 00000000 ................ 0c03a060: 00000000 00000000 00000000 00000000 ................ 0c03a070: 00000000 00000011 00000000 00000000 ................ 0c03a080: 000016fa 00000000 00000000 00000000 ................ 0c03a090: 00000000 00000000 00000000 00000000 ................ 0c03a0a0: 00000000 00000000 00000000 00000000 ................ 0c03a0b0: 00000000 00000000 00000011 000016fa ................ 0c03a0c0: 00000000 00000000 00000000 00000000 ................ 0c03a0d0: 00000000 00000000 00000000 00000000 ................ 0c03a0e0: 00000000 00000000 00000000 00000000 ................ 0c03a0f0: 00000000 00000000 00000000 00000000 ................
I suspect that there is something wrong with SGMII. MDIO Interface works fine.
Do you have any hint on where I should investigate further?
Thanks for your help and best regards,
Felix
