Part Number: TDA4VL-Q1
Hi TI experts,
HW: our custom board
SDK: j721s2, 8.6
The following is our SBL boot flow chart. Sometimes mcu2_0 fails to initialize DMA, How to resolve it?
Below is the running log of SBL.
[20240321_11:32:07:661] NOTICE: BL31: v2.7(release):v2.7.0-359-g1309c6c80
[20240321_11:32:07:661] NOTICE: BL31: Built : 16:21:32, Nov 13 2023
[20240321_11:32:07:778]
[20240321_11:32:07:779] U-Boot SPL 2021.01 (Mar 12 2024 - 16:07:49 +0800)
[20240321_11:32:08:070] ti_sci system-controller@44083000: Message not acknowledgedti_sci system-controller@44083000: Message not acknowledgedSYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara')
[20240321_11:32:08:119] Trying to boot from MMC2
[20240321_11:32:09:504]
[20240321_11:32:09:504] U-Boot 2021.01 (Mar 12 2024 - 16:07:49 +0800)
[20240321_11:32:09:505] DRAM: 2 GiB
[20240321_11:32:09:532] Flash: 0 Bytes
[20240321_11:32:09:550] MMC: mmc@4f80000: 0, mmc@4fb0000: 1
[20240321_11:32:09:551] Loading Environment from SPIFlash... cadence_spi spi@47040000: Can't get reset: -2
[20240321_11:32:09:551] k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
[20240321_11:32:09:562] k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
[20240321_11:32:10:139] SF: Detected gd25lx256e with page size 256 Bytes, erase size 64 KiB, total 32 MiB
[20240321_11:32:10:144] OK
[20240321_11:32:10:144] In: serial@2850000
[20240321_11:32:10:144] Out: serial@2850000
[20240321_11:32:10:144] Err: serial@2850000
[20240321_11:32:10:144] Hello, welcome enter boot__init
[20240321_11:32:10:153] Uboot version changes, reset all env value!
[20240321_11:32:10:153] ## Resetting to default environment
[20240321_11:32:10:153] **** sd card present ****
[20240321_11:32:10:259] **** rootfs from /dev/mmcblk1p2 ****
[20240321_11:32:10:259] Autoboot in 0 seconds
[20240321_11:32:10:275] k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
[20240321_11:32:10:276] k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
[20240321_11:32:10:338] 871560 bytes read in 27 ms (30.8 MiB/s)
[20240321_11:32:10:338] Load Remote Processor 2 with data@addr=0x82000000 871560 bytes: Success!
[20240321_11:32:10:350] 207788 bytes read in 12 ms (16.5 MiB/s)
[20240321_11:32:10:383] Load Remote Processor 3 with data@addr=0x82000000 207788 bytes: Success!
[20240321_11:32:10:700] 14815296 bytes read in 323 ms (43.7 MiB/s)
[20240321_11:32:10:731] Load Remote Processor 6 with data@addr=0x82000000 14815296 bytes: Success!
[20240321_11:32:10:969] 9600896 bytes read in 213 ms (43 MiB/s)
[20240321_11:32:10:969] Load Remote Processor 7 with data@addr=0x82000000 9600896 bytes: Success!
[20240321_11:32:11:362] 19079680 bytes read in 396 ms (45.9 MiB/s)
[20240321_11:32:11:381] 74736 bytes read in 6 ms (11.9 MiB/s)
[20240321_11:32:11:381] ## Flattened Device Tree blob at 88000000
[20240321_11:32:11:382] Booting using the fdt blob at 0x88000000
[20240321_11:32:11:389] Loading Device Tree to 000000008ffea000, end 000000008ffff3ef ... OK
[20240321_11:32:11:390] Starting kernel ...
[20240321_11:32:11:483] [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[20240321_11:32:11:484] [ 0.000000] Linux version 5.10.162-g76b3e88d56 (zhubing@RD17) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Dec 27 15:14:14 CST 2023
[20240321_11:32:11:484] [ 0.000000] Machine model: Texas Instruments J721S2 EVM
[20240321_11:32:11:497] [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002850000 (options '')
[20240321_11:32:11:497] [ 0.000000] printk: bootconsole [ns16550a0] enabled
[20240321_11:32:13:068] INIT: version 2.96 booting
[20240321_11:32:13:111] INIT: Entering runlevel: 5
[20240321_11:32:14:171] Populating /dev/ using udev: done
[20240321_11:32:15:034] Loaded PowerVR consumer services.
[20240321_11:32:15:428] [MCU2_0] 5.984648 s: CIO: Init ... Done !!!
[20240321_11:32:15:428] [MCU2_0] 5.984713 s: ### CPU Frequency = 1000000000 Hz
[20240321_11:32:15:428] [MCU2_0] 5.984748 s: CPU is running FreeRTOS
[20240321_11:32:15:428] [MCU2_0] 5.984772 s: APP: Init ... !!!
[20240321_11:32:15:429] [MCU2_0] 5.984793 s: SCICLIENT: Init ... !!!
[20240321_11:32:15:429] [MCU2_0] 5.986065 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
[20240321_11:32:15:429] [MCU2_0] 5.986105 s: SCICLIENT: DMSC FW revision 0x8
[20240321_11:32:15:429] [MCU2_0] 5.986137 s: SCICLIENT: DMSC FW ABI revision 3.1
[20240321_11:32:15:429] [MCU2_0] 5.986172 s: SCICLIENT: Init ... Done !!!
[20240321_11:32:15:429] [MCU2_0] 5.986198 s: UDMA: Init ... !!!
[20240321_11:32:15:429] [MCU2_0] 5.997051 s: UDMA: Init ... Done !!!
[20240321_11:32:15:429] [MCU2_0] 5.997098 s: UDMA: Init ... !!!
[20240321_11:32:15:429] [MCU2_0] 6.002582 s: UDMA: Init for CSITX/CSIRX ... Done !!!
[20240321_11:32:15:430] [MCU2_0] 6.002648 s: MEM: Init ... !!!
[20240321_11:32:15:430] [MCU2_0] 6.002686 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d5000000 of size 16777216 bytes !!!
[20240321_11:32:15:430] [MCU2_0] 6.002754 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 262144 bytes !!!
[20240321_11:32:15:430] [MCU2_0] 6.002812 s: MEM: Init ... Done !!!
[20240321_11:32:15:430] [MCU2_0] 6.002841 s: IPC: Init ... !!!
[20240321_11:32:15:430] [MCU2_0] 6.002898 s: IPC: 4 CPUs participating in IPC !!!
[20240321_11:32:15:430] [MCU2_0] 6.002941 s: IPC: Waiting for HLOS to be ready ... !!!
[20240321_11:32:15:430] [MCU2_0] 8.920002 s: IPC: HLOS is ready !!!
[20240321_11:32:15:430] [MCU2_0] 8.934696 s: IPC: Init ... Done !!!
[20240321_11:32:15:430] [MCU2_0] 8.934747 s: APP: Syncing with 3 CPUs ... !!!
[20240321_11:32:15:431] [MCU2_0] 8.965903 s: APP: Syncing with 3 CPUs ... Done !!!
[20240321_11:32:15:431] [MCU2_0] 8.965944 s: REMOTE_SERVICE: Init ... !!!
[20240321_11:32:15:431] [MCU2_0] 8.967236 s: REMOTE_SERVICE: Init ... Done !!!
[20240321_11:32:15:431] [MCU2_0] 8.967285 s: FVID2: Init ... !!!
[20240321_11:32:15:431] [MCU2_0] 8.967354 s: FVID2: Init ... Done !!!
[20240321_11:32:15:431] [MCU2_0] 8.967387 s: SCICLIENT: Sciclient_pmSetModuleState module=214 state=2
[20240321_11:32:15:431] [MCU2_0] 8.968462 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:431] [MCU2_0] 8.968498 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2
[20240321_11:32:15:431] [MCU2_0] 8.971076 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:432] [MCU2_0] 8.971125 s: DSS: Init ... !!!
[20240321_11:32:15:432] [MCU2_0] 8.971151 s: DSS: Display type is HDMI !!!
[20240321_11:32:15:432] [MCU2_0] 8.971179 s: DSS: M2M Path is enabled !!!
[20240321_11:32:15:432] [MCU2_0] 8.971206 s: DSS: SoC init ... !!!
[20240321_11:32:15:432] [MCU2_0] 8.971230 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
[20240321_11:32:15:432] [MCU2_0] 8.973198 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:432] [MCU2_0] 8.973231 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
[20240321_11:32:15:432] [MCU2_0] 8.974420 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:432] [MCU2_0] 8.974450 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=2
[20240321_11:32:15:432] [MCU2_0] 8.976513 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:432] [MCU2_0] 8.976543 s: DSS: SoC init ... Done !!!
[20240321_11:32:15:433] [MCU2_0] 8.976569 s: DSS: Board init ... !!!
[20240321_11:32:15:433] [MCU2_0] 8.976593 s: DSS: Board init ... Done !!!
[20240321_11:32:15:433] [MCU2_0] 8.979093 s: DSS: Init ... Done !!!
[20240321_11:32:15:433] [MCU2_0] 8.979138 s: VHWA: VPAC Init ... !!!
[20240321_11:32:15:433] [MCU2_0] 8.979164 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=361 clk=2 freq=600000000
[20240321_11:32:15:433] [MCU2_0] 9.005773 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[20240321_11:32:15:433] [MCU2_0] 9.005808 s: SCICLIENT: Sciclient_pmSetModuleState module=361 state=2
[20240321_11:32:15:433] [MCU2_0] 9.007593 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:433] [MCU2_0] 9.007625 s: VHWA: LDC Init ... !!!
[20240321_11:32:15:433] [MCU2_0] 9.021976 s: VHWA: LDC Init ... Done !!!
[20240321_11:32:15:434] [MCU2_0] 9.022031 s: VHWA: MSC Init ... !!!
[20240321_11:32:15:434] [MCU2_0] 9.065683 s: VHWA: MSC Init ... Done !!!
[20240321_11:32:15:434] [MCU2_0] 9.065733 s: VHWA: NF Init ... !!!
[20240321_11:32:15:434] [MCU2_0] 9.071974 s: VHWA: NF Init ... Done !!!
[20240321_11:32:15:434] [MCU2_0] 9.072016 s: VHWA: VISS Init ... !!!
[20240321_11:32:15:434] [MCU2_0] 9.096422 s: [UDMA]
[20240321_11:32:15:434] [MCU2_0] 9.096457 s: [Error] Ring config failed!!!
[20240321_11:32:15:434] [MCU2_0] 9.096492 s: [UDMA]
[20240321_11:32:15:434] [MCU2_0] 9.096513 s: [Error] CQ ring alloc failed!!!
[20240321_11:32:15:435] [MCU2_0] 9.096554 s: [UDMA]
[20240321_11:32:15:772] [MCU2_0] 9.096573 s: [Error] Channel resource allocation failed!!
[20240321_11:32:15:772] [MCU2_0] 9.107609 s: VHWA: VISS Init ... Done !!!
[20240321_11:32:15:772] [MCU2_0] 9.107658 s: VHWA: VPAC Init ... Done !!!
[20240321_11:32:15:772] [MCU2_0] 9.107700 s: VX_ZONE_INIT:Enabled
[20240321_11:32:15:772] [MCU2_0] 9.107727 s: VX_ZONE_ERROR:Enabled
[20240321_11:32:15:772] [MCU2_0] 9.107752 s: VX_ZONE_WARNING:Enabled
[20240321_11:32:15:772] [MCU2_0] 9.109109 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
[20240321_11:32:15:772] [MCU2_0] 9.109312 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
[20240321_11:32:15:772] [MCU2_0] 9.109509 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
[20240321_11:32:15:773] [MCU2_0] 9.109703 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
[20240321_11:32:15:773] [MCU2_0] 9.109901 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
[20240321_11:32:15:773] [MCU2_0] 9.110171 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
[20240321_11:32:15:773] [MCU2_0] 9.110400 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
[20240321_11:32:15:773] [MCU2_0] 9.110621 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
[20240321_11:32:15:773] [MCU2_0] 9.110830 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
[20240321_11:32:15:773] [MCU2_0] 9.111029 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
[20240321_11:32:15:773] [MCU2_0] 9.111207 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
[20240321_11:32:15:773] [MCU2_0] 9.111427 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
[20240321_11:32:15:773] [MCU2_0] 9.111649 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
[20240321_11:32:15:774] [MCU2_0] 9.111859 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
[20240321_11:32:15:774] [MCU2_0] 9.112047 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
[20240321_11:32:15:774] [MCU2_0] 9.112244 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
[20240321_11:32:15:774] [MCU2_0] 9.112473 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
[20240321_11:32:15:774] [MCU2_0] 9.112671 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
[20240321_11:32:15:774] [MCU2_0] 9.112855 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
[20240321_11:32:15:774] [MCU2_0] 9.113043 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
[20240321_11:32:15:774] [MCU2_0] 9.113237 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
[20240321_11:32:15:775] [MCU2_0] 9.113442 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX2
[20240321_11:32:15:775] [MCU2_0] 9.113634 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
[20240321_11:32:15:775] [MCU2_0] 9.113818 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
[20240321_11:32:15:775] [MCU2_0] 9.113867 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[20240321_11:32:15:775] [MCU2_0] 9.113901 s: APP: OpenVX Target kernel init ... !!!
[20240321_11:32:15:775] [MCU2_0] 9.140918 s: APP: OpenVX Target kernel init ... Done !!!
[20240321_11:32:15:775] [MCU2_0] 9.140963 s: CSI2RX: Init ... !!!
[20240321_11:32:15:775] [MCU2_0] 9.140987 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2
[20240321_11:32:15:775] [MCU2_0] 9.141680 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:775] [MCU2_0] 9.141715 s: SCICLIENT: Sciclient_pmSetModuleState module=38 state=2
[20240321_11:32:15:775] [MCU2_0] 9.142283 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:776] [MCU2_0] 9.142314 s: SCICLIENT: Sciclient_pmSetModuleState module=39 state=2
[20240321_11:32:15:776] [MCU2_0] 9.142981 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:776] [MCU2_0] 9.143011 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[20240321_11:32:15:776] [MCU2_0] 9.143662 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:776] [MCU2_0] 9.143692 s: SCICLIENT: Sciclient_pmSetModuleState module=153 state=2
[20240321_11:32:15:776] [MCU2_0] 9.145024 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:15:776] [MCU2_0] 9.145248 s: CSI2RX: Init ... Done !!!
[20240321_11:32:15:776] [MCU2_0] 9.145279 s: CSI2TX: Init ... !!!
[20240321_11:32:15:776] [MCU2_0] 9.145302 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2
[20240321_11:32:15:777] [MCU2_0] 9.145865 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:16:118] [MCU2_0] 9.145896 s: SCICLIENT: Sciclient_pmSetModuleState module=40 state=2
[20240321_11:32:16:118] [MCU2_0] 9.146574 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:16:118] [MCU2_0] 9.146604 s: SCICLIENT: Sciclient_pmSetModuleState module=41 state=2
[20240321_11:32:16:118] [MCU2_0] 9.147251 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:16:118] [MCU2_0] 9.147281 s: SCICLIENT: Sciclient_pmSetModuleState module=363 state=2
[20240321_11:32:16:118] [MCU2_0] 9.147851 s: SCICLIENT: Sciclient_pmSetModuleState success
[20240321_11:32:16:118] [MCU2_0] 9.147928 s: CSI2TX: Init ... Done !!!
[20240321_11:32:16:118] [MCU2_0] 9.147955 s: DSS: Display type is CSITX !!!
[20240321_11:32:16:118] [MCU2_0] 9.152587 s: DSS: Configuring SERDES Max9295A ... !!!
[20240321_11:32:16:118] [MCU2_0] 9.155829 s: DSS: SERDES Max9295A Configuration... Done !!!
[20240321_11:32:16:118] [MCU2_0] 9.155867 s: ISS: Init ... !!!
[20240321_11:32:16:118] [MCU2_0] 9.156724 s: fqf: REMOTE_SERVICE: create RX task Done
[20240321_11:32:16:119] [MCU2_0] 9.156760 s: Found sensor OVX1F_UYVY_96715_96724F at location 0
[20240321_11:32:16:119] [MCU2_0] 9.156801 s: Found sensor ISX019_UYVY_96701_96724F at location 1
[20240321_11:32:16:119] [MCU2_0] 9.156839 s: Found sensor ISX019_UYVY_96715_96724F at location 2
[20240321_11:32:16:119] [MCU2_0] 9.156874 s: IssSensor_Init ... Done !!!
[20240321_11:32:16:119] [MCU2_0] 9.156964 s: IttRemoteServer_Init ... Done !!!
[20240321_11:32:16:119] [MCU2_0] 9.156993 s: VISS REMOTE SERVICE: Init ... !!!
[20240321_11:32:16:119] [MCU2_0] 9.157051 s: VISS REMOTE SERVICE: Init ... Done !!!
[20240321_11:32:16:119] [MCU2_0] 9.157082 s: UDMA Copy: Init ... !!!
[20240321_11:32:16:119] [MCU2_0] 9.165143 s: UDMA Copy: Init ... Done !!!
[20240321_11:32:16:119] [MCU2_0] 9.165230 s: APP: Init ... Done !!!
[20240321_11:32:16:120] [MCU2_0] 9.165261 s: APP: Run ... !!!
[20240321_11:32:16:120] [MCU2_0] 9.165284 s: IPC: Starting echo test ...
[20240321_11:32:16:120] [MCU2_0] 9.166990 s: APP: Run ... Done !!!
[20240321_11:32:16:120] [MCU2_0] 9.167687 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] C7X_1[P] C7X_2[.]
[20240321_11:32:16:120] [MCU2_0] 9.167766 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] C7X_1[P] C7X_2[P]
[20240321_11:32:16:120] [MCU2_1] 5.928901 s: CIO: Init ... Done !!!
[20240321_11:32:16:120] [MCU2_1] 5.928946 s: ### CPU Frequency = 1000000000 Hz
[20240321_11:32:16:120] [MCU2_1] 5.928979 s: CPU is running FreeRTOS
[20240321_11:32:16:121] [MCU2_1] 5.929002 s: APP: Init ... !!!
[20240321_11:32:16:121] [MCU2_1] 5.929024 s: SCICLIENT: Init ... !!!
[20240321_11:32:16:121] [MCU2_1] 5.930369 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
[20240321_11:32:16:121] [MCU2_1] 5.930406 s: SCICLIENT: DMSC FW revision 0x8
[20240321_11:32:16:121] [MCU2_1] 5.930436 s: SCICLIENT: DMSC FW ABI revision 3.1
[20240321_11:32:16:121] [MCU2_1] 5.930470 s: SCICLIENT: Init ... Done !!!
[20240321_11:32:16:121] [MCU2_1] 5.930496 s: UDMA: Init ... !!!
[20240321_11:32:16:121] [MCU2_1] 5.944806 s: UDMA: Init ... Done !!!
[20240321_11:32:16:121] [MCU2_1] 5.944847 s: MEM: Init ... !!!
[20240321_11:32:16:121] [MCU2_1] 5.944882 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d6000000 of size 16777216 bytes !!!
[20240321_11:32:16:121] [MCU2_1] 5.944946 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 60040000 of size 262144 bytes !!!
[20240321_11:32:16:122] [MCU2_1] 5.945004 s: MEM: Init ... Done !!!
[20240321_11:32:16:122] [MCU2_1] 5.945028 s: IPC: Init ... !!!
[20240321_11:32:16:122] [MCU2_1] 5.945072 s: IPC: 3 CPUs participating in IPC !!!
[20240321_11:32:16:122] [MCU2_1] 5.945108 s: IPC: Waiting for HLOS to be ready ... !!!
[20240321_11:32:16:122] [MCU2_1] 8.923232 s: IPC: HLOS is ready !!!
[20240321_11:32:16:122] [MCU2_1] 8.934678 s: appIpcIsCpuEnabled 4 !!!
[20240321_11:32:16:122] [MCU2_1] 8.935890 s: IPC: Init lbx... Done !!!
[20240321_11:32:16:122] [MCU2_1] 8.935922 s: APP: Syncing with 1 CPUs ... !!!
[20240321_11:32:16:122] [MCU2_1] 8.935953 s: APP: Syncing with 1 CPUs ... Done !!!
[20240321_11:32:16:122] [MCU2_1] 8.935985 s: REMOTE_SERVICE: Init ... !!!
[20240321_11:32:16:122] [MCU2_1] 8.937082 s: REMOTE_SERVICE: Init ... Done !!!
[20240321_11:32:16:122] [MCU2_1] 8.937116 s: UDMA Copy: Init ... !!!
[20240321_11:32:16:122] [MCU2_1] 8.943513 s: UDMA Copy: Init ... Done !!!
[20240321_11:32:16:123] [MCU2_1] 8.943550 s: APP: Init ... Done !!!
[20240321_11:32:16:123] [MCU2_1] 8.943576 s: APP: Run ... !!!
[20240321_11:32:16:123] [MCU2_1] 8.943599 s: IPC: Starting echo test ...
[20240321_11:32:16:123] [MCU2_1] 8.944850 s: APP: Run ... Done !!!
[20240321_11:32:16:123] [C7x_1 ] 6.306152 s: CIO: Init ... Done !!!
[20240321_11:32:16:123] [C7x_1 ] 6.306179 s: ### CPU Frequency = 500000000 Hz
[20240321_11:32:16:123] [C7x_1 ] 6.306201 s: CPU is running FreeRTOS
[20240321_11:32:16:123] [C7x_1 ] 6.306217 s: APP: Init ... !!!
[20240321_11:32:16:123] [C7x_1 ] 6.306232 s: SCICLIENT: Init ... !!!
[20240321_11:32:16:462] [C7x_1 ] 6.307548 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
[20240321_11:32:16:462] [C7x_1 ] 6.307579 s: SCICLIENT: DMSC FW revision 0x8
[20240321_11:32:16:462] [C7x_1 ] 6.307600 s: SCICLIENT: DMSC FW ABI revision 3.1
[20240321_11:32:16:462] [C7x_1 ] 6.307621 s: SCICLIENT: Init ... Done !!!
[20240321_11:32:16:462] [C7x_1 ] 6.307639 s: UDMA: Init ... !!!
[20240321_11:32:16:463] [C7x_1 ] 6.321084 s: UDMA: Init ... Done !!!
[20240321_11:32:16:463] [C7x_1 ] 6.321107 s: MEM: Init ... !!!
[20240321_11:32:16:463] [C7x_1 ] 6.321129 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ db000000 of size 335544320 bytes !!!
[20240321_11:32:16:463] [C7x_1 ] 6.321169 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70060000 of size 3702784 bytes !!!
[20240321_11:32:16:463] [C7x_1 ] 6.321205 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321240 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321273 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d7000000 of size 67108864 bytes !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321310 s: MEM: Init ... Done !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321325 s: IPC: Init ... !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321350 s: IPC: 4 CPUs participating in IPC !!!
[20240321_11:32:16:464] [C7x_1 ] 6.321377 s: IPC: Waiting for HLOS to be ready ... !!!
[20240321_11:32:16:464] [C7x_1 ] 8.949913 s: IPC: HLOS is ready !!!
[20240321_11:32:16:464] [C7x_1 ] 8.957765 s: IPC: Init ... Done !!!
[20240321_11:32:16:464] [C7x_1 ] 8.957791 s: APP: Syncing with 3 CPUs ... !!!
[20240321_11:32:16:464] [C7x_1 ] 8.965905 s: APP: Syncing with 3 CPUs ... Done !!!
[20240321_11:32:16:464] [C7x_1 ] 8.965936 s: REMOTE_SERVICE: Init ... !!!
[20240321_11:32:16:464] [C7x_1 ] 8.966213 s: REMOTE_SERVICE: Init ... Done !!!
[20240321_11:32:16:465] [C7x_1 ] 8.966253 s: VX_ZONE_INIT:Enabled
[20240321_11:32:16:465] [C7x_1 ] 8.966274 s: VX_ZONE_ERROR:Enabled
[20240321_11:32:16:465] [C7x_1 ] 8.966293 s: VX_ZONE_WARNING:Enabled
[20240321_11:32:16:465] [C7x_1 ] 8.966660 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
[20240321_11:32:16:465] [C7x_1 ] 8.966772 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
[20240321_11:32:16:465] [C7x_1 ] 8.966879 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
[20240321_11:32:16:465] [C7x_1 ] 8.966990 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
[20240321_11:32:16:465] [C7x_1 ] 8.967094 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
[20240321_11:32:16:466] [C7x_1 ] 8.967206 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
[20240321_11:32:16:466] [C7x_1 ] 8.967311 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
[20240321_11:32:16:466] [C7x_1 ] 8.967421 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
[20240321_11:32:16:466] [C7x_1 ] 8.967464 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[20240321_11:32:16:466] [C7x_1 ] 8.967491 s: APP: OpenVX Target kernel init ... !!!
[20240321_11:32:16:466] [C7x_1 ] 8.967756 s: APP: OpenVX Target kernel init ... Done !!!
[20240321_11:32:16:466] [C7x_1 ] 8.967782 s: APP: Init ... Done !!!
[20240321_11:32:16:466] [C7x_1 ] 8.967799 s: APP: Run ... !!!
[20240321_11:32:16:466] [C7x_1 ] 8.967814 s: IPC: Starting echo test ...
[20240321_11:32:16:466] [C7x_1 ] 8.967991 s: APP: Run ... Done !!!
[20240321_11:32:16:466] [C7x_1 ] 9.013939 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] C7X_1[s] C7X_2[P]
[20240321_11:32:16:467] [C7x_1 ] 9.167666 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] C7X_1[s] C7X_2[P]
[20240321_11:32:16:467] [C7x_2 ] 6.535303 s: CIO: Init ... Done !!!
[20240321_11:32:16:467] [C7x_2 ] 6.535330 s: ### CPU Frequency = 500000000 Hz
[20240321_11:32:16:467] [C7x_2 ] 6.535352 s: CPU is running FreeRTOS
[20240321_11:32:16:467] [C7x_2 ] 6.535368 s: APP: Init ... !!!
[20240321_11:32:16:467] [C7x_2 ] 6.535382 s: SCICLIENT: Init ... !!!
[20240321_11:32:16:467] [C7x_2 ] 6.536793 s: SCICLIENT: DMSC FW version [8.6.3--1-g2249f (Chill Capybara]
[20240321_11:32:16:467] [C7x_2 ] 6.536822 s: SCICLIENT: DMSC FW revision 0x8
[20240321_11:32:16:467] [C7x_2 ] 6.536843 s: SCICLIENT: DMSC FW ABI revision 3.1
[20240321_11:32:16:467] [C7x_2 ] 6.536864 s: SCICLIENT: Init ... Done !!!
[20240321_11:32:16:467] [C7x_2 ] 6.536882 s: UDMA: Init ... !!!
[20240321_11:32:16:467] [C7x_2 ] 6.549706 s: UDMA: Init ... Done !!!
[20240321_11:32:16:467] [C7x_2 ] 6.549729 s: MEM: Init ... !!!
[20240321_11:32:16:468] [C7x_2 ] 6.549750 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ ef000000 of size 16777216 bytes !!!
[20240321_11:32:16:631] [C7x_2 ] 6.549790 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 65800000 of size 458752 bytes !!!
[20240321_11:32:16:631] [C7x_2 ] 6.549827 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 65e00000 of size 16384 bytes !!!
[20240321_11:32:16:631] [C7x_2 ] 6.549861 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ f0000000 of size 67108864 bytes !!!
[20240321_11:32:16:631] [C7x_2 ] 6.549898 s: MEM: Init ... Done !!!
[20240321_11:32:16:632] [C7x_2 ] 6.549914 s: IPC: Init ... !!!
[20240321_11:32:16:632] [C7x_2 ] 6.549937 s: IPC: 4 CPUs participating in IPC !!!
[20240321_11:32:16:632] [C7x_2 ] 6.549969 s: IPC: Waiting for HLOS to be ready ... !!!
[20240321_11:32:16:632] [C7x_2 ] 8.958860 s: IPC: HLOS is ready !!!
[20240321_11:32:16:632] [C7x_2 ] 8.965851 s: IPC: Init ... Done !!!
[20240321_11:32:16:632] [C7x_2 ] 8.965878 s: APP: Syncing with 3 CPUs ... !!!
[20240321_11:32:16:632] [C7x_2 ] 8.965903 s: APP: Syncing with 3 CPUs ... Done !!!
[20240321_11:32:16:632] [C7x_2 ] 8.965925 s: REMOTE_SERVICE: Init ... !!!
[20240321_11:32:16:632] [C7x_2 ] 8.966215 s: REMOTE_SERVICE: Init ... Done !!!
[20240321_11:32:16:632] [C7x_2 ] 8.966255 s: VX_ZONE_INIT:Enabled
[20240321_11:32:16:632] [C7x_2 ] 8.966293 s: VX_ZONE_ERROR:Enabled
[20240321_11:32:16:632] [C7x_2 ] 8.966314 s: VX_ZONE_WARNING:Enabled
[20240321_11:32:16:633] [C7x_2 ] 8.967181 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP-1
[20240321_11:32:16:633] [C7x_2 ] 8.967225 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[20240321_11:32:16:633] [C7x_2 ] 8.967264 s: APP: OpenVX Target kernel init ... !!!
[20240321_11:32:16:633] [C7x_2 ] 8.967603 s: APP: OpenVX Target kernel init ... Done !!!
[20240321_11:32:16:633] [C7x_2 ] 8.967631 s: UDMA Copy: Init ... !!!
[20240321_11:32:16:633] [C7x_2 ] 8.978027 s: UDMA Copy: Init ... Done !!!
[20240321_11:32:16:633] [C7x_2 ] 9.013300 s: APP: Init ... Done !!!
[20240321_11:32:16:633] [C7x_2 ] 9.013330 s: APP: Run ... !!!
[20240321_11:32:16:633] [C7x_2 ] 9.013347 s: IPC: Starting echo test ...
[20240321_11:32:16:633] [C7x_2 ] 9.013534 s: APP: Run ... Done !!!
[20240321_11:32:16:634] [C7x_2 ] 9.013948 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] C7X_1[P] C7X_2[s]
[20240321_11:32:16:646] [C7x_2 ] 9.167691 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] C7X_1[P] C7X_2[s]
quanfeng
