Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Hi team,
Could you please share me the u-boot commands to load kernel and dtb from UFS flash?
Thanks & regards,
Albin Raj R J
Is that working for you on the TDA4VH? Also are you using the custom board or TI EVM?
- Keerthy
Hi Keerthy,
thanks for your response. It's working fine. I need to load kernel and dtb from ufs.
thanks.
U-Boot source directory file: include/environment/ti/ufs.h
Commands:
#define DEFAULT_UFS_TI_ARGS \
"scsirootfstype=ext4 rootwait\0" \
"ufs_finduuid=part uuid scsi ${bootpart} uuid\0" \
"args_ufs=setenv devtype scsi;setenv bootpart 1:1;" \
"run ufs_finduuid;setenv bootargs console = ${console} " \
"${optargs}" \
"root=PARTUUID=${uuid} rw " \
"rootfstype=${scsirootfstype};" \
"setenv devtype scsi;" \
"setenv bootpart 1:1\0" \
"init_ufs=ufs init; scsi scan; run args_ufs\0" \
"get_kern_ufs=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${name_kern}\0" \
"get_fdt_ufs=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \
"get_overlay_ufs=" \
"fdt address ${fdtaddr};" \
"fdt resize 0x100000;" \
"for overlay in $name_overlays;" \
"do;" \
"load scsi ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && " \
"fdt apply ${dtboaddr};" \
"done;\0"
#endif
This was tested a while back. Please check.
- Keerthy
Hi Kreethy,
Thanks for your response, I used the default configuration and try to boot using following u-boot commands.
setenv name_kern Image
setenv get_kern_ufs 'load scsi ${bootpart} ${loadaddr} ${bootdir}/Image'
setenv get_fdt_ufs 'load scsi ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}'
setenv findfdt 'setenv name_fdt ${default_device_tree}; if test $board_name = am69-sk; then setenv name_fdt ti/k3-am69-sk.dtb; fi; if test $board_name = j784s4; then setenv name_fdt dtb/ti/k3-j784s4-evm.dtb; fi;'
setenv bootcmd 'setenv bootpart 1:1; run init_ufs;run findfdt;run get_kern_ufs;run get_fdt_ufs;run run_kern;run ufs_finduuid;run args_ufs'
But it struck in rootfs.
Here I have added the logs,
U-Boot 2023.04-g71b8c840ca (Nov 27 2023 - 08:55:35 +0000)
SoC: J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
Board: J784S4X-EVM rev E4
DRAM: 32 GiB
idle-statesCore: 94 devices, 34 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from nowhere... OK
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
=> setenv name_kern Image
=> setenv get_kern_ufs 'load scsi ${bootpart} ${loadaddr} ${bootdir}/Image'
=> setenv get_fdt_ufs 'load scsi ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}'
=> setenv findfdt 'setenv name_fdt ${default_device_tree}; if test $board_name = am69-sk; then setenv name_fdt ti/k3-am69-sk.dtb; fi; if test $board_name = j784s4; then setenv name_fdt dtb/ti/k3-j784s4-'
=> setenv bootcmd 'setenv bootpart 1:1; run init_ufs;run findfdt;run get_kern_ufs;run get_fdt_ufs;run run_kern;run ufs_finduuid;run args_ufs'
=> boot
Device at ufs@4e84000 up at:cdns-ufs-pltfm ufs@4e84000: [RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
scanning bus for devices...
Device 0: (0:0) Vendor: TOSHIBA Prod.: THGAF8G8T23BAILB Rev: 0300
Type: Hard Disk
Capacity: 31.9 MB = 0.0 GB (8191 x 4096)
Device 1: (0:1) Vendor: TOSHIBA Prod.: THGAF8G8T23BAILB Rev: 0300
Type: Hard Disk
Capacity: 30499.9 MB = 29.7 GB (7807999 x 4096)
20367872 bytes read in 49 ms (396.4 MiB/s)
108306 bytes read in 24 ms (4.3 MiB/s)
Working FDT set to 88000000
Loading Device Tree to 000000008ffe2000, end 000000008ffff711 ... OK
Working FDT set to 8ffe2000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.46-dirty (dlhs4hwt3@dlhs4hwt3-Precision-5820-Tower) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #2 SMP PREEMPT Thu Feb 1 09:37:26 IST 2024
[ 0.000000] Machine model: Texas Instruments J784S4 EVM
[ 0.000000] Malformed early option 'console'
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000fffffefff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x0000000fffffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff]
[ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 32 MiB at 0x00000000fde00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8257534
[ 0.000000] Kernel command line: console = ttyS2,115200n8 root=PARTUUID=265f879d-01 rw rootfstype=ext4 rootwait
[ 0.000000] Unknown kernel command line parameters "console = ttyS2,115200n8", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000f9e00000-0x00000000fde00000] (64MB)
[ 0.000000] Memory: 32573936K/33554424K available (12352K kernel code, 1266K rwdata, 4028K rodata, 2112K init, 432K bss, 947720K reserved, 32768K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880050000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000201] Console: colour dummy device 80x25
[ 0.000622] printk: console [tty0] enabled
[ 0.000652] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000665] pid_max: default: 32768 minimum: 301
[ 0.000693] LSM: Security Framework initializing
[ 0.000796] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000862] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001783] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001794] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.001838] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.001845] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.001929] rcu: Hierarchical SRCU implementation.
[ 0.001935] rcu: Max phase no-delay instances is 1000.
[ 0.002076] Platform MSI: msi-controller@1820000 domain created
[ 0.002196] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.002356] EFI services will not be available.
[ 0.002562] smp: Bringing up secondary CPUs ...
[ 0.011005] Detected PIPT I-cache on CPU1
[ 0.011059] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.011073] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[ 0.011102] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.019563] Detected PIPT I-cache on CPU2
[ 0.019598] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[ 0.019611] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[ 0.019633] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[ 0.028035] Detected PIPT I-cache on CPU3
[ 0.028078] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[ 0.028090] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[ 0.028113] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[ 0.036559] Detected PIPT I-cache on CPU4
[ 0.036638] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[ 0.036651] GICv3: CPU4: using allocated LPI pending table @0x00000008800a0000
[ 0.036682] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[ 0.045139] Detected PIPT I-cache on CPU5
[ 0.045190] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[ 0.045202] GICv3: CPU5: using allocated LPI pending table @0x00000008800b0000
[ 0.045227] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[ 0.053649] Detected PIPT I-cache on CPU6
[ 0.053699] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[ 0.053711] GICv3: CPU6: using allocated LPI pending table @0x00000008800c0000
[ 0.053735] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[ 0.062152] Detected PIPT I-cache on CPU7
[ 0.062203] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[ 0.062216] GICv3: CPU7: using allocated LPI pending table @0x00000008800d0000
[ 0.062238] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[ 0.062283] smp: Brought up 1 node, 8 CPUs
[ 0.062388] SMP: Total of 8 processors activated.
[ 0.062393] CPU features: detected: 32-bit EL0 Support
[ 0.062399] CPU features: detected: CRC32 instructions
[ 0.062448] CPU: All CPU(s) started at EL2
[ 0.062453] alternatives: applying system-wide alternatives
[ 0.063357] devtmpfs: initialized
[ 0.072773] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.072802] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.073303] pinctrl core: initialized pinctrl subsystem
[ 0.073544] DMI not present or invalid.
[ 0.073858] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.074963] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.075816] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.076557] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.076589] audit: initializing netlink subsys (disabled)
[ 0.076669] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.076842] thermal_sys: Registered thermal governor 'step_wise'
[ 0.076847] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.076871] cpuidle: using governor menu
[ 0.076934] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.077026] ASID allocator initialised with 65536 entries
[ 0.084988] platform 4800000.dsi: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.085010] platform 4800000.dsi: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[ 0.085107] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.087038] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector
[ 0.087344] platform panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[ 0.087885] KASLR disabled due to lack of seed
[ 0.090691] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.090701] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.090708] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.090713] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.090718] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.090723] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.090727] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.090732] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.091405] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[ 0.092221] iommu: Default domain type: Translated
[ 0.092229] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.092338] SCSI subsystem initialized
[ 0.092485] usbcore: registered new interface driver usbfs
[ 0.092503] usbcore: registered new interface driver hub
[ 0.092520] usbcore: registered new device driver usb
[ 0.092712] pps_core: LinuxPPS API ver. 1 registered
[ 0.092718] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.092729] PTP clock support registered
[ 0.092809] EDAC MC: Ver: 3.0.0
[ 0.093264] FPGA manager framework
[ 0.093302] Advanced Linux Sound Architecture Driver Initialized.
[ 0.093700] clocksource: Switched to clocksource arch_sys_counter
[ 0.093800] VFS: Disk quotas dquot_6.6.0
[ 0.093824] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.096588] NET: Registered PF_INET protocol family
[ 0.096902] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.101965] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.102108] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.102128] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.102951] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.103784] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.103885] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.104202] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.104612] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.104887] RPC: Registered named UNIX socket transport module.
[ 0.104898] RPC: Registered udp transport module.
[ 0.104903] RPC: Registered tcp transport module.
[ 0.104907] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.104914] NET: Registered PF_XDP protocol family
[ 0.104927] PCI: CLS 0 bytes, default 64
[ 0.105508] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.106398] Initialise system trusted keyrings
[ 0.106500] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.108444] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.108678] NFS: Registering the id_resolver key type
[ 0.108698] Key type id_resolver registered
[ 0.108703] Key type id_legacy registered
[ 0.108730] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.108738] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.128443] Key type asymmetric registered
[ 0.128451] Asymmetric key parser 'x509' registered
[ 0.128484] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.128555] io scheduler mq-deadline registered
[ 0.128563] io scheduler kyber registered
[ 0.130804] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[ 0.130893] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[ 0.131015] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[ 0.131074] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[ 0.131197] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.134647] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.139135] loop: module loaded
[ 0.139714] megasas: 07.719.03.00-rc1
[ 0.141209] tun: Universal TUN/TAP device driver, 1.6
[ 0.141589] thunder_xcv, ver 1.0
[ 0.141607] thunder_bgx, ver 1.0
[ 0.141622] nicpf, ver 1.0
[ 0.141734] e1000: Intel(R) PRO/1000 Network Driver
[ 0.141739] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.141756] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.141761] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.141778] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.141783] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.141801] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.141806] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.141879] sky2: driver version 1.30
[ 0.142295] VFIO - User Level meta-driver version: 0.3
[ 0.142676] usbcore: registered new interface driver usb-storage
[ 0.142999] i2c_dev: i2c /dev entries driver
[ 0.143563] sdhci: Secure Digital Host Controller Interface driver
[ 0.143569] sdhci: Copyright(c) Pierre Ossman
[ 0.143692] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.144167] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.144262] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.144415] usbcore: registered new interface driver usbhid
[ 0.144420] usbhid: USB HID core driver
[ 0.144910] optee: probing for conduit method.
[ 0.144932] optee: revision 4.0 (2a5b1d12)
[ 0.161313] optee: dynamic shared memory is enabled
[ 0.161534] optee: initialized driver
[ 0.162574] Initializing XFRM netlink socket
[ 0.162599] NET: Registered PF_PACKET protocol family
[ 0.162636] Key type dns_resolver registered
[ 0.162799] registered taskstats version 1
[ 0.162817] Loading compiled-in X.509 certificates
[ 0.168595] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)')
[ 0.199403] pca953x 0-0020: supply vcc not found, using dummy regulator
[ 0.199471] pca953x 0-0020: using no AI
[ 0.222345] pca953x 0-0022: supply vcc not found, using dummy regulator
[ 0.222396] pca953x 0-0022: using AI
[ 0.223039] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.223529] pca953x 1-0020: supply vcc not found, using dummy regulator
[ 0.223575] pca953x 1-0020: using no AI
[ 0.246205] omap_i2c 2040000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.246748] pca953x 2-0020: supply vcc not found, using dummy regulator
[ 0.246796] pca953x 2-0020: using no AI
[ 0.270009] omap_i2c 2050000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.270184] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[ 0.270271] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[ 0.270360] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[ 0.270517] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[ 0.274332] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 0.274962] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 0.275741] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[ 0.275753] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.275760] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.277154] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[ 0.277166] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.277172] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 0.277544] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 215, base_baud = 3000000) is a 8250
[ 2.247236] printk: console [ttyS2] enabled
[ 2.251632] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x3c (0x34)
[ 2.259109] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-fss0-ospi0-pins-default 60x
[ 2.269137] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x40 (0x34)
[ 2.276616] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-fss0-ospi1-pins-default 64x
[ 2.286451] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x94 (0x34)
[ 2.293925] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-cpsw-pins-default 148x
[ 2.302963] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x9c (0x34)
[ 2.310431] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-mdio-pins-default 156x
[ 2.357707] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.366514] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.374788] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.387646] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.394859] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.401061] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[ 2.449708] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.458309] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 2.466406] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.479147] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 2.485406] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 2.492527] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 2.498618] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[ 2.508668] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[ 2.517739] mmc0: CQHCI version 5.10
[ 2.521989] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[ 2.528775] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 2.535549] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 2.542323] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[ 2.549098] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 2.555874] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[ 2.560287] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.565901] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[ 2.579774] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[ 2.589639] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x3c (0x34)
[ 2.597116] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-fss0-ospi0-pins-default 60x
[ 2.608965] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 2.614799] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x40 (0x34)
[ 2.622280] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-fss0-ospi1-pins-default 64x
[ 2.633325] spi-nor spi1.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[ 2.640293] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x94 (0x34)
[ 2.647770] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-cpsw-pins-default 148x
[ 2.656808] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0x9c (0x34)
[ 2.664285] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-mdio-pins-default 156x
[ 2.664446] mmc0: Command Queue Engine enabled
[ 2.677763] mmc0: new HS400 MMC card at address 0001
[ 2.683043] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 2.688500] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 2.694081] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 2.699548] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[ 2.709714] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.718523] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.726801] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.739669] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.746882] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.753081] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[ 2.762923] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 2.809710] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.818335] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 2.826432] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 2.839186] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 2.845478] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 2.852604] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 2.858708] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.868493] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 2.876370] mmc1: CQHCI version 5.10
[ 2.920802] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 3.013704] mmc1: new high speed SDHC card at address 5048
[ 3.019499] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[ 3.025737] mmcblk1: p1 p2
[ 3.582306] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present!
[ 3.589542] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
[ 3.596818] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
[ 3.604559] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present!
[ 3.611875] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
[ 3.619195] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
[ 3.636770] ALSA device list:
[ 3.639743] No soundcards found.
[ 3.643332] Waiting for root device PARTUUID=265f879d-01...
could you please help me to solve this?
thanks
Albin Raj R J
Can you make sure that the UFS driver in kernel is probed? Can you add prints in the probe function and check if that returns success aka 0?
- Keerthy
Hi Keerthy,
Thanks for your response. You are correct. Default UFS is in LKM I change to static driver. Now it's working fine. Thanks for your support.
