AM625: Camera and USB is not working on android 12
Part Number: AM625
Camera and USB is not working in andoid 12.
What changes I need to make?
Sonia
    We are using deafult image of version 08.06.00 on EVM . Camera is still not working.
    Sonia
  • Hi Sonia,
    Can you please post the output of the following 2 commands?
    adb root
    adb shell dumpsys media.camera
    adb root
    adb shell dmesg
  • Hello Mattijis,
    127|console:/ $ adb root
    /system/bin/sh: adb: inaccessible or not found
    127|console:/ $ adb shell dumpsys media.camera
    127|console:/ $ adb shell dmesg
    I am getting these logs.
    Sonia
  • Hi Sonia,
    Please run these commands from your PC, not in the debug console.
    If you want them to run from the debug console, run the following instead:
    su
    su
    dmesg
  • Hi Mattijs,
    As i have booted the android on AM625 board and connected the USB cam to the board so the commands you provided must be executed in debug console of android to check the camera logs.
    sonia
  • Yes, so please run:
    su
    su
    dmesg
    In the debug console and share the output.
  • Hello Mattijs,
    I got the below output from the command
    su
    su
    console:/ # dumpsys media.camera
    == Service global info: ==
    Number of camera devices: 0
    Number of normal camera devices: 0
    Number of public camera devices visible to API1: 0
    Active Camera Clients:
    Allowed user IDs: 0
    == Camera service events log (most recent at top): ==
      03-02 01:28:17 : REMOVE device 100, reason: (Device status changed from 1 to 0)
      03-02 01:28:13 : ADD device 100, reason: (Device added)
      03-02 01:27:32 : REMOVE device 100, reason: (Device status changed from 1 to 0)
      03-02 01:27:28 : ADD device 100, reason: (Device added)
      03-02 01:26:10 : USER_SWITCH previous allowed user IDs: <None>, current allowed user IDs: 0
    == Camera Provider HAL external/0-0 (v2.5, remote) static info: 0 devices: ==
    == Vendor tags: ==
      Dumping vendor tag descriptors for vendor with id 15055940602041719656
      Dumping configured vendor tag descriptors: None set
    == Camera error traces (0): ==
      No camera traces collected.
    **********Dumpsys from previous open session**********
    **********End of Dumpsys from previous open session**********
    su
    dmesg
    console:/ # su
    console:/ # dmesg[  243.089178] sdhci-am654 fa00000.mmc: Power on failed
    [    6.563044] init: Parsing file /system/etc/init/traced_perf.rc...
    [    6.569777] init: Parsing file /system/etc/init/uncrypt.rc...
    [    6.576102] init: Parsing file /system/etc/init/update_engine.rc...
    [    6.582930] init: Parsing file /system/etc/init/update_verifier.rc...
    [    6.589914] init: Parsing file /system/etc/init/usbd.rc...
    [    6.595885] init: Parsing file /system/etc/init/vdc.rc...
    [    6.601803] init: Parsing file /system/etc/init/vendor-464xlat.rc...
    [    6.608728] init: Parsing file /system/etc/init/vold.rc...
    [    6.614778] init: Parsing file /system/etc/init/wait_for_keymaster.rc...
    [    6.621978] init: Parsing file /system/etc/init/wifi.rc...
    [    6.628344] init: Parsing file /system/etc/init/wificond.rc...
    [    6.634881] init: Parsing file /system_ext/etc/init...
    [    6.640087] init: Unable to read config file '/system_ext/etc/init': open() failed: No such file or directory
    [    6.650027] init: Parsing directory /vendor/etc/init...
    [    6.655434] init: Parsing file /vendor/etc/init/android.hardware.atrace@1.0-service.rc...
    [    6.664396] init: Parsing file /vendor/etc/init/android.hardware.audio.service.rc...
    [    6.672808] init: Parsing file /vendor/etc/init/android.hardware.boot@1.2-service.rc...
    [    6.681427] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.4-external-service.rc...
    [    6.691716] init: Parsing file /vendor/etc/init/android.hardware.cas@1.2-service.rc...
    [    6.700122] init: Parsing file /vendor/etc/init/android.hardware.drm@1.4-service.clearkey.rc...
    [    6.709465] init: Parsing file /vendor/etc/init/android.hardware.dumpstate@1.1-service.example.rc...
    [    6.719139] init: Parsing file /vendor/etc/init/android.hardware.gatekeeper@1.0-service.optee.rc...
    [    6.728703] init: Parsing file /vendor/etc/init/android.hardware.graphics.allocator@4.0-service.img.rc...
    [    6.738834] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.4-service.rc...
    [    6.748496] init: Parsing file /vendor/etc/init/android.hardware.health.storage-service.cuttlefish.rc...
    [    6.758546] init: Parsing file /vendor/etc/init/android.hardware.health@2.1-service.rc...
    [    6.767264] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.optee.rc...
    [    6.776787] init: Parsing file /vendor/etc/init/android.hardware.media.omx@1.0-service.rc...
    [    6.785742] init: Parsing file /vendor/etc/init/android.hardware.thermal@2.0-service-ti.rc...
    [    6.794797] init: Parsing file /vendor/etc/init/android.hardware.usb@1.2-service.generic.rc...
    [    6.804048] init: Parsing file /vendor/etc/init/android.hardware.wifi.supplicant-service.rc...
    [    6.813372] init: Parsing file /vendor/etc/init/boringssl_self_test.rc...
    [    6.821106] init: Parsing file /vendor/etc/init/hostapd.android.rc...
    [    6.828377] init: Parsing file /vendor/etc/init/init.am62x.usb.rc...
    [    6.835398] init: Parsing file /vendor/etc/init/init.am62x.zygote_wakelock.rc...
    [    6.843586] init: Parsing file /vendor/etc/init/init.optee.rc...
    [    6.850223] init: Parsing file /vendor/etc/init/memtrack-default.rc...
    [    6.857274] init: Parsing file /vendor/etc/init/power-default.rc...
    [    6.864024] init: Parsing file /vendor/etc/init/vendor_flash_recovery.rc...
    [    6.871448] init: Parsing file /vendor/etc/init/wait_for_keymaster_optee.rc...
    [    6.879296] init: Parsing file /odm/etc/init...
    [    6.883889] init: Unable to read config file '/odm/etc/init': open() failed: No such file or directory
    [    6.893234] init: Parsing file /product/etc/init...
    [    6.898132] init: Unable to read config file '/product/etc/init': open() failed: No such file or directory
    [    6.909048] init: processing action (SetupCgroups) from (<Builtin Action>:0)
    [    6.924524] init: processing action (SetKptrRestrict) from (<Builtin Action>:0)
    [    6.932672] init: processing action (TestPerfEventSelinux) from (<Builtin Action>:0)
    [    6.941428] init: processing action (early-init) from (/system/etc/init/hw/init.rc:15)
    [    6.952600] init: Command 'mkdir /acct/uid' action=early-init (/system/etc/init/hw/init.rc:30) took 1ms and failed: mkdir() failed on /acct/uid: Read-only file system
    [    6.975710] init: starting service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap)'...
    [    6.989699] cgroup: init (1) created nested cgroup for controller "memory" which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
    [    7.004417] cgroup: "memory" requires setting use_hierarchy to 1 on the root
    [    7.009372] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v31: No such file or directory
    [    7.022168] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v31: No such file or directory
    [    7.022229] init: SVC_EXEC service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap)' pid 119 (uid 0 gid 0+0 context default) started; waiting...
    [    7.048452] init: Command 'exec -- /system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap' action=early-init (/system/etc/init/hw/init.rc:59) took 73ms and succeeded
    [    7.064538] init: Service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap)' (pid 119) exited with status 0 waiting took 0.075000 seconds
    [    7.079321] init: Sending signal 9 to service 'exec 1 (/system/bin/bootstrap/linkerconfig --target /linkerconfig/bootstrap)' (pid 119) process group...
    [    7.093209] libprocessgroup: Successfully killed process cgroup uid 0 pid 119 in 0ms
    [    7.103992] init: starting service 'ueventd'...
    [    7.116675] random: ueventd: uninitialized urandom read (40 bytes read)
    [    7.118476] init: starting service 'apexd-bootstrap'...
    [    7.138564] init: SVC_EXEC service 'apexd-bootstrap' pid 121 (uid 0 gid 1000+0 context default) started; waiting...
    [    7.141570] random: apexd: uninitialized urandom read (40 bytes read)
    [    7.147280] random: ueventd: uninitialized urandom read (40 bytes read)
    [    7.194208] ueventd: ueventd started!
    [    7.202650] selinux: SELinux: Loaded file_contexts
    [    7.207558] selinux:
    [    7.210511] ueventd: Parsing file /system/etc/ueventd.rc...
    [    7.217048] ueventd: Added '/vendor/etc/ueventd.rc' to import list
    [    7.223294] ueventd: Added '/odm/etc/ueventd.rc' to import list
    [    7.229854] ueventd: Parsing file /vendor/etc/ueventd.rc...
    [    7.235491] ueventd: Unable to read config file '/vendor/etc/ueventd.rc': open() failed: No such file or directory
    [    7.245874] ueventd: Parsing file /odm/etc/ueventd.rc...
    [    7.251219] ueventd: Unable to read config file '/odm/etc/ueventd.rc': open() failed: No such file or directory
    [    7.261619] ueventd: Parsing file /vendor/ueventd.rc...
    [    7.267858] ueventd: Parsing file /odm/ueventd.rc...
    [    7.273044] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
    [    7.275934] apexd: Bootstrap subcommand detected
    [    7.282897] ueventd: Parsing file /ueventd.am62x.rc...
    [    7.292700] ueventd: Unable to read config file '/ueventd.am62x.rc': open() failed: No such file or directory
    [    7.345814] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.353441] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.361016] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.368591] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.376162] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.383737] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.391308] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.398877] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.406447] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.414017] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.421586] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.429155] ueventd: softdep lines in modules.softdep must have at least 4 entries
    [    7.568371] ueventd: LoadWithAliases was unable to load platform:reg-dummy
    [    7.571681] ueventd: LoadWithAliases was unable to load of:Nregulator-4T(null)Cregulator-gpio
    [    7.574266] ueventd: LoadWithAliases was unable to load of:NopteeT(null)Clinaro,optee-tz
    [    7.577890] ueventd: LoadWithAliases was unable to load of:Nregulator-2T(null)Cregulator-fixed
    [    7.578825] ueventd: LoadWithAliases was unable to load of:Ndmtimer-main-pwm-7T(null)Cti,omap-dmtimer-pwm
    [    7.582034] ueventd: LoadWithAliases was unable to load of:NconnectorT(null)Chdmi-connector
    [    7.584156] ueventd: LoadWithAliases was unable to load platform:snd-soc-dummy
    [    7.587120] ueventd: LoadWithAliases was unable to load platform:ti-cpufreq
    [    7.590101] ueventd: LoadWithAliases was unable to load of:Nl2-cache0T(null)Ccache
    [    7.593222] ueventd: LoadWithAliases was unable to load of:Nregulator-7T(null)Cregulator-fixed
    [    7.595360] ueventd: LoadWithAliases was unable to load of:Nregulator-0T(null)Cregulator-fixed
    [    7.598878] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
    [    7.603162] ueventd: LoadWithAliases was unable to load of:NpsciT(null)Carm,psci-1.0
    [    7.603165] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.613218] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [    7.622905] ueventd: LoadWithAliases was unable to load platform:Fixed MDIO bus
    [    7.629419] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi
    [    7.635936] ueventd: LoadWithAliases was unable to load of:NledsT(null)Cpwm-leds
    [    7.635941] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.638992] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
    [    7.642221] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-ospiCcdns,qspi-nor
    [    7.652612] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.674592] ueventd: LoadWithAliases was unable to load of:Nreset-controllerT(null)Cti,sci-reset
    [    7.678078] ueventd: LoadWithAliases was unable to load of:NphyT(null)Cti,am654-phy-gmii-sel
    [    7.680673] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [    7.685096] ueventd: LoadWithAliases was unable to load of:NsramT(null)Cmmio-sram
    [    7.690551] ueventd: LoadWithAliases was unable to load of:Nsystem-controllerT(null)Cti,k2g-sci
    [    7.692197] ueventd: LoadWithAliases was unable to load of:NmcaspT(null)Cti,am33xx-mcasp-audio
    [    7.697499] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
    [    7.702210] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [    7.711732] ueventd: Loading module /vendor/lib/modules/videobuf2-dma-contig.ko with args ''
    [    7.725839] pvrsrvkm: loading out-of-tree module taints kernel.
    [    7.727249] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-tlv320aic3x.ko
    [    7.730825] ueventd: LoadWithAliases was unable to load of:Ninterrupt-controllerT(null)Cti,sci-intr
    [    7.741782] ueventd: Loaded kernel module /vendor/lib/modules/rti_wdt.ko
    [    7.750955] ueventd: LoadWithAliases was unable to load of:Nmemory-controllerT(null)Cti,am64-gpmc
    [    7.758368] ueventd: LoadWithAliases was unable to load mmc:block
    [    7.768047] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-pktdma
    [    7.772682] ueventd: Loaded kernel module /vendor/lib/modules/videobuf2-dma-contig.ko
    [    7.783507] ueventd: LoadWithAliases was unable to load of:Ndma-controllerT(null)Cti,am64-dmss-bcdma
    [    7.788755] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
    [    7.800819] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [    7.802054] ueventd: LoadWithAliases was unable to load of:NmailboxT(null)Cti,am64-mailbox
    [    7.805172] ueventd: LoadWithAliases was unable to load of:Ndss-oldi-io-ctrlT(null)Csyscon
    [    7.805661] sdhci-am654 fa00000.mmc: Power on failed
    [    7.808779] PVR_K:  124: Device: fd00000.gpu
    [    7.816567] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
    [    7.821750] PVR_K:  124: Read BVNC 33.15.11.3 from HW device registers
    [    7.832335] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [    7.835655] PVR_K:  124: RGX Device registered with BVNC 33.15.11.3
    [    7.847606] ueventd: LoadWithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gpio
    [    7.848040] ueventd: LoadWithAliases was unable to load of:Npower-controllerT(null)Cti,sci-pm-domain
    [    7.851132] ueventd: LoadWithAliases was unable to load of:Ni2cT(null)Cti,am64-i2cCti,omap4-i2c
    [    7.852074] [drm] Initialized pvr 1.18.6276027 20170530 for fd00000.gpu on minor 1
    [    7.853120] ueventd: Loaded kernel module /vendor/lib/modules/pvrsrvkm.ko
    [    7.856961] ueventd: LoadWithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gpio
    [    7.859592] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [    7.863754] ueventd: LoadWithAliases was unable to load of:NgpioT(null)Cti,am64-gpioCti,keystone-gpio
    [    7.871934] ueventd: Loaded kernel module /vendor/lib/modules/j721e-csi2rx.ko
    [    7.878449] ueventd: LoadWithAliases was unable to load of:NdssT(null)Cti,am625-dss
    [    7.885985] ueventd: LoadWithAliases was unable to load platform:hdmi-audio-codec
    [    7.894736] ueventd: LoadWithAliases was unable to load of:NmmcT(null)Cti,am62-sdhci
    [    7.894740] ueventd: LoadWithAliases was unable to load of:NclockT(null)Cti,am62-epwm-tbclkCsyscon
    [    7.898193] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [    7.900518] ueventd: LoadWithAliases was unable to load spi:spi-nor
    [    7.908839] ueventd: LoadWithAliases was unable to load of:Ngpi[  244.838763] sdhci-am654 fa00000.mmc: Power on failed
    oT(null)Cti,tca6424
    [    7.910340] ueventd: Loading module /vendor/lib/modules/wlcore_sdio.ko with args ''
    [    7.927497] ueventd: LoadWithAliases was unable to load of:Nclock-controllerT(null)Cti,k2g-sci-clk
    [    7.929704] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
    [    7.932833] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.936022] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi
    [    7.936025] ueventd: LoadWithAliases was unable to load of:Nsii9022T(null)Csil,sii9022
    [    7.939680] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.944875] ueventd: LoadWithAliases was unable to load of:NmailboxT(null)Cti,am654-secure-proxy
    [    7.950646] ueventd: LoadWithAliases was unable to load of:NethernetT(null)Cti,am642-cpsw-nuss
    [    7.958900] ueventd: LoadWithAliases was unable to load of:NmdioT(null)Cti,cpsw-mdioCti,davinci_mdio
    [    7.958923] ueventd: Loaded kernel module /vendor/lib/modules/dwc3-am62.ko
    [    7.961481] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-mfd
    [    7.964144] ueventd: LoadWithAliases was unable to load of:Ninterrupt-controllerT(null)Cti,sci-inta
    [    7.964147] ueventd: LoadWithAliases was unable to load of:Nethernet-phyT(null)
    [    7.966695] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctrl-single
    [    7.968805] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [    7.971351] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi
    [    7.973787] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.976510] ueventd: Loading module /vendor/lib/modules/ti_k3_m4_remoteproc.ko with args ''
    [    7.981013] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    7.983036] ueventd: LoadWithAliases was unable to load of:NeccT(null)Cti,am3352-elm
    [    7.985467] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    7.988091] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi
    [    7.990875] ueventd: LoadWithAliases was unable to load of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi
    [    7.994384] ueventd: Loading module /vendor/lib/modules/wlcore_sdio.ko with args ''
    [    7.996803] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    8.006251] ueventd: LoadWithAliases was unable to load of:NpinctrlT(null)Cpinctrl-single
    [    8.020151] ueventd: Loaded kernel module /vendor/lib/modules/wlcore_sdio.ko
    [    8.020604] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    8.023597] ueventd: LoadWithAliases was unable to load of:Ninterrupt-controllerT(null)Cti,sci-intr
    [    8.025670] ueventd: LoadWithAliases was unable to load of:Ndwc3-usbT(null)Cti,am62-usb
    [    8.025699] ueventd: Loading module /vendor/lib/modules/roles.ko with args ''
    [    8.028865] ueventd: LoadWithAliases was unable to load of:NserialT(null)Cti,am64-uartCti,am654-uart
    [    8.030212] ueventd: Loaded kernel module /vendor/lib/modules/roles.ko
    [    8.031720] ueventd: LoadWithAliases was unable to load of:Ni2cT(null)Cti,am64-i2cCti,omap4-i2c
    [    8.032075] ueventd: Loading module /vendor/lib/modules/sa2ul.ko with args ''
    [    8.035063] ueventd: Loading module /vendor/lib/modules/cdns-dphy.ko with args ''
    [    8.037311] remoteproc remoteproc0: 5000000.m4fss is available
    [    8.047005] ueventd: Loading module /vendor/lib/modules/typec.ko with args ''
    [    8.052660] ueventd: Loaded kernel module /vendor/lib/modules/sa2ul.ko
    [    8.052793] ueventd: Loaded kernel module /vendor/lib/modules/cdns-dphy.ko
    [    8.052832] ueventd: Loaded kernel module /vendor/lib/modules/ti_k3_m4_remoteproc.ko
    [    8.055859] ueventd: LoadWithAliases was unable to load of:NspinlockT(null)Cti,am64-hwspinlock
    [    8.057322] ueventd: Loading module /vendor/lib/modules/pruss.ko with args ''
    [    8.058563] ueventd: LoadWithAliases was unable to load of:NsysconT(null)CsysconCsimple-mfd
    [    8.061525] ueventd: Loading module /vendor/lib/modules/ti_k3_r5_remoteproc.ko with args ''
    [    8.071624] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
    [    8.077731] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [    8.083396] ueventd: Loaded kernel module /vendor/lib/modules/typec.ko
    [    8.090510] remoteproc remoteproc0: Falling back to sysfs fallback for: am62-mcu-m4f0_0-fw
    [    8.098067] ueventd: Loading module /vendor/lib/modules/tps6598x.ko with args ''
    [    8.108118] ueventd: Loaded kernel module /vendor/lib/modules/mcrc.ko
    [    8.498781] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.501603] ueventd: LoadWithAliases was unable to load of:NchipidT(null)Cti,am654-chipid
    [    8.503185] ueventd: Loaded kernel module /vendor/lib/modules/pruss.ko
    [    8.506055] ueventd: LoadWithAliases was unable to load of:NtimerT(null)Cti,am654-timer
    [    8.510273] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.510730] platform 78000000.r5f: configured R5F for IPC-only mode
    [    8.513313] ueventd: LoadWithAliases was unable to load of:Ntemperature-sensorT(null)Cti,j7200-vtm
    [    8.515961] ueventd: LoadWithAliases was unable to load of:Nregulator-1T(null)Cregulator-fixed
    [    8.521729] ueventd: Loading module /vendor/lib/modules/crct10dif-ce.ko with args ''
    [    8.523341] ueventd: LoadWithAliases was unable to load of:Ntimer-cl0-cpu0T(null)Carm,armv8-timer
    [    8.525519] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
    [    8.526190] ueventd: LoadWithAliases was unable to load of:Nregulator-3T(null)Cregulator-fixed
    [    8.530938] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
    [    8.531535] ueventd: Loaded kernel module /vendor/lib/modules/tps6598x.ko
    [    8.535534] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.542014] remoteproc remoteproc1: 78000000.r5f is available
    [    8.542111] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card-utils.ko
    [    8.542247] ueventd: Loaded kernel module /vendor/lib/modules/crct10dif-ce.ko
    [    8.542255] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
    [    8.547424] apexd: wait for '/dev/loop-control' took 1227ms
    [    8.547758] apexd: Pre-allocated 14 loopback devices
    [    8.547929] apexd: Scanning /system/apex for pre-installed ApexFiles
    [    8.548564] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
    [    8.551326] ueventd: LoadWithAliases was unable to load of:NbusT(null)Csimple-bus
    [    8.554374] ueventd: LoadWithAliases was unable to load of:NrtcT(null)Cti,am62-rtc
    [    8.556838] ueventd: LoadWithAliases was unable to load platform:alarmtimer
    [    8.557144] remoteproc remoteproc1: attaching to 78000000.r5f
    [    8.560427] ueventd: LoadWithAliases was unable to load of:Nregulator-5T(null)Cregulator-fixed
    [    8.562532] ueventd: LoadWithAliases was unable to load platform:serial8250
    [    8.568072] ueventd: LoadWithAliases was unable to load of:Nregulator-6T(null)Cregulator-fixed
    [    8.573747] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    8.584014] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
    [    8.585623] ueventd: Loading module /vendor/lib/modules/crct10dif-ce.ko with args ''
    [    8.590562] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@9da00000
    [    8.600090] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
    [    8.608237] remoteproc1#vdev0buffer: registered virtio0 (type 7)
    [    8.615863] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
    [    8.623023] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    8.627864] ueventd: Loaded kernel module /vendor/lib/modules/snd-soc-simple-card.ko
    [    8.633465] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
    [    8.633952] ueventd: LoadWithAliases was unable to load of:NpmuT(null)Carm,cortex-a53-pmu
    [    8.636455] ueventd: Loading module /vendor/lib/modules/crct10dif-ce.ko with args ''
    [    8.638102] ueventd: Loaded kernel module /vendor/lib/modules/ti_k3_r5_remoteproc.ko
    [    8.645986] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
    [    8.656010] ueventd: LoadWithAliases was unable to load of:Nopp-tableT(null)Coperating-points-v2-ti-cpu
    [    8.662944] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
    [    8.667632] ueventd: LoadWithAliases was unable to load platform:cpufreq-dt
    [    8.670948] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
    [    8.679692] ueventd: Loading module /vendor/lib/modules/crct10dif-ce.ko with args ''
    [    8.685685] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
    [    8.712332] ueventd: Coldboot took 1.271 seconds
    [    8.719880] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
    [    8.735839] ueventd: Loading module /vendor/lib/modules/rti_wdt.ko with args ''
    [    8.740598] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
    [    8.751874] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.763524] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
    [    8.775762] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.781789] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
    [    8.793810] ueventd: Loading module /vendor/lib/modules/snd-soc-tlv320aic3x.ko with args ''
    [    8.799711] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
    [    8.816687] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.824228] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
    [    8.835947] ueventd: LoadWithAliases was unable to load of:NwatchdogT(null)Cti,j7-rti-wdt
    [    8.846021] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.apex
    [    8.874092] ueventd: Loading module /vendor/lib/modules/pvrsrvkm.ko with args ''
    [    8.875895] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
    [    8.904580] ueventd: Loading module /vendor/lib/modules/v4l2-fwnode.ko with args ''
    [    8.916194] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
    [    8.926368] ueventd: Loaded kernel module /vendor/lib/modules/v4l2-fwnode.ko
    [    8.937871] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
    [    8.941307] ueventd: Loading module /vendor/lib/modules/cdns-csi2rx.ko with args ''
    [    8.950239] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
    [    8.966323] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    8.975966] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
    [    8.981152] ueventd: Loaded kernel module /vendor/lib/modules/cdns-csi2rx.ko
    [    8.989151] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
    [    9.008427] ueventd: Loading module /vendor/lib/modules/videobuf2-dma-contig.ko with args ''
    [    9.015096] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
    [    9.020180] ueventd: Loading module /vendor/lib/modules/j721e-csi2rx.ko with args ''
    [    9.026895] apexd: /system_ext/apex does not exist. Skipping
    [    9.045505] ueventd: Loading module /vendor/lib/modules/roles.ko with args ''
    [    9.049684] apexd: Scanning /vendor/apex for pre-installed ApexFiles
    [    9.056972] ueventd: Loading module /vendor/lib/modules/dwc3.ko with args ''
    [    9.064641] apexd: /vendor/apex does not exist. Skipping
    [    9.102422] ueventd: Loaded kernel module /vendor/lib/modules/dwc3.ko
    [    9.103024] apexd: Scanning /system/apex looking for APEX packages.
    [    9.113879] ueventd: Loading module /vendor/lib/modules/dwc3-am62.ko with args ''
    [    9.120820] apexd: Scanning /system_ext/apex looking for APEX packages.
    [    9.123689] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    9.129052] apexd: ... does not exist. Skipping
    [    9.129402] ueventd: LoadWithAliases was unable to load of:Ndwc3-usbT(null)Cti,am62-usb
    [    9.134169] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
    [    9.139350] ueventd: LoadWithAliases was unable to load of:Ndwc3-usbT(null)Cti,am62-usb
    [    9.140775] apexd: Scanning /vendor/apex looking for APEX packages.
    [    9.153959] ueventd: LoadWithAliases was unable to load of:Ndwc3-usbT(null)Cti,am62-usb
    [    9.154579] apexd: ... does not exist. Skipping
    [    9.174363] ueventd: Loading module /vendor/lib/modules/rfkill.ko with args ''
    [    9.190717] EXT4-fs (loop1): mounted filesystem without journal. Opts: (null)
    [    9.194322] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
    [    9.195738] apexd: Successfully mounted package /system/apex/com.android.vndk.current.apex on /apex/com.android.vndk.v31@1 duration=13
    [    9.203520] ueventd: Loaded kernel module /vendor/lib/modules/rfkill.ko
    [    9.211125] apexd: Successfully mounted package /system/apex/com.android.i18n.apex on /apex/com.android.i18n@1 duration=29
    [    9.211677] EXT4-fs (loop2): mounted filesystem without journal. Opts: (null)
    [    9.211856] apexd: Successfully mounted package /system/apex/com.android.tzdata.apex on /apex/com.android.tzdata@319999900 duration=10
    [    9.217657] ueventd: Loading module /vendor/lib/modules/cfg80211.ko with args ''
    [    9.221958] EXT4-fs (loop3): mounted filesystem without journal. Opts: (null)
    [    9.222184] apexd: Successfully mounted package /system/apex/com.android.runtime.apex on /apex/com.android.runtime@1 duration=8
    [    9.224512] apexd: Activated 4 packages.
    [    9.287553] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    9.304898] apexd: OnBootstrap done, duration=2017
    [    9.312975] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.320141] init: Service 'apexd-bootstrap' (pid 121) exited with status 0 waiting took 2.188000 seconds
    [    9.324906] ueventd: Loaded kernel module /vendor/lib/modules/cfg80211.ko
    [    9.328409] init: Sending signal 9 to service 'apexd-bootstrap' (pid 121) process group...
    [    9.337681] ueventd: Loading module /vendor/lib/modules/mac80211.ko with args ''
    [    9.344738] libprocessgroup: Successfully killed process cgroup uid 0 pid 121 in 0ms
    [    9.397264] random: linkerconfig: uninitialized urandom read (40 bytes read)
    [    9.397314] ueventd: Loaded kernel module /vendor/lib/modules/mac80211.ko
    [    9.413923] ueventd: Loading module /vendor/lib/modules/wlcore.ko with args ''
    [    9.432894] ueventd: Loaded kernel module /vendor/lib/modules/wlcore.ko
    [    9.439818] ueventd: Loading module /vendor/lib/modules/wl18xx.ko with args ''
    [    9.456409] sdhci-am654 fa00000.mmc: Power on failed
    [    9.465901] init: linkerconfig generated /linkerconfig with mounted APEX modules info
    [    9.473866] init: Command 'update_linker_config' action=early-init (/system/etc/init/hw/init.rc:[  246.400825] sdhci-am654 fa00000.mmc: Power on failed
    75) took 96ms and succeeded
    [    9.490485] init: processing action (ro.product.cpu.abilist32=* && early-init) from (/system/etc/init/hw/init.rc:90)
    [    9.501692] init: starting service 'boringssl_self_test32'...
    [    9.508725] ueventd: Loaded kernel module /vendor/lib/modules/wl18xx.ko
    [    9.515566] wl18xx_driver wl18xx.2.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
    [    9.517103] init: SVC_EXEC service 'boringssl_self_test32' pid 146 (uid 0 gid 0+0 context default) started; waiting...
    [    9.526290] wl18xx_driver wl18xx.2.auto: Falling back to sysfs fallback for: ti-connectivity/wl1271-nvs.bin
    [    9.535645] ueventd: Loading module /vendor/lib/modules/wlcore_sdio.ko with args ''
    [    9.560043] ueventd: Loading module /vendor/lib/modules/ti_k3_m4_remoteproc.ko with args ''
    [    9.574377] ueventd: Loading module /vendor/lib/modules/cdns-dphy.ko with args ''
    [    9.603545] ueventd: firmware: loading 'am62-mcu-m4f0_0-fw' for '/devices/platform/bus@f0000/bus@f0000:bus@4000000/5000000.m4fss/remoteproc/remoteproc0/am62-mcu-m4f0_0-fw'
    [    9.608533] ueventd: LoadWithAliases was unable to load of:Nr5fT(null)Cti,am62-r5f
    [    9.631278] ueventd: Loading module /vendor/lib/modules/mcrc.ko with args ''
    [    9.648830] init: Service 'boringssl_self_test32' (pid 146) exited with status 0 waiting took 0.138000 seconds
    [    9.650010] ueventd: LoadWithAliases was unable to load of:NcfgT(null)Cti,pruss-cfgCsyscon
    [    9.658914] init: Sending signal 9 to service 'boringssl_self_test32' (pid 146) process group...
    [    9.675271] ueventd: Loading module /vendor/lib/modules/irq-pruss-intc.ko with args ''
    [    9.676198] libprocessgroup: Successfully killed process cgroup uid 0 pid 146 in 0ms
    [    9.693078] ueventd: Loaded kernel module /vendor/lib/modules/irq-pruss-intc.ko
    [    9.693601] init: processing action (ro.product.cpu.abilist64=* && early-init) from (/system/etc/init/hw/init.rc:92)
    [    9.707455] ueventd: Loading module /vendor/lib/modules/pruss.ko with args ''
    [    9.711547] init: starting service 'boringssl_self_test64'...
    [    9.718484] ueventd: Loading module /vendor/lib/modules/pru_rproc.ko with args ''
    [    9.733515] init: SVC_EXEC service 'boringssl_self_test64' pid 148 (uid 0 gid 0+0 context default) started; waiting...
    [    9.734796] remoteproc remoteproc2: 30074000.pru is available
    [    9.751116] remoteproc remoteproc3: 30078000.pru is available
    [    9.757877] ueventd: Loaded kernel module /vendor/lib/modules/pru_rproc.ko
    [    9.770437] ueventd: LoadWithAliases was unable to load of:NpruT(null)Cti,am625-pru
    [    9.783917] ueventd: LoadWithAliases was unable to load of:NprussT(null)Cti,am625-pruss
    [    9.815343] ueventd: Loading module /vendor/lib/modules/virtio_rpmsg_bus.ko with args ''
    [    9.825878] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.831555] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.832782] ueventd: Loaded kernel module /vendor/lib/modules/virtio_rpmsg_bus.ko
    [    9.839283] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.864976] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card-utils.ko with args ''
    [    9.873084] init: Service 'boringssl_self_test64' (pid 148) exited with status 0 waiting took 0.146000 seconds
    [    9.874439] ueventd: Loading module /vendor/lib/modules/snd-soc-simple-card.ko with args ''
    [    9.883920] init: Sending signal 9 to service 'boringssl_self_test64' (pid 148) process group...
    [    9.901341] ueventd: Loading module /vendor/lib/modules/ti_k3_r5_remoteproc.ko with args ''
    [    9.901386] libprocessgroup: Successfully killed process cgroup uid 0 pid 148 in 0ms
    [    9.919346] init: processing action (early-init) from (/init.environ.rc:2)
    [    9.926596] init: processing action (early-init) from (/vendor/etc/init/hw/init.am62x.rc:1)
    [    9.926646] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
    [    9.940082] init: processing action (ro.product.cpu.abilist32=* && early-init) from (/vendor/etc/init/boringssl_self_test.rc:2)
    [    9.947056] ueventd: Loading module /vendor/lib/modules/xhci-plat-hcd.ko with args ''
    [    9.955339] init: starting service 'boringssl_self_test32_vendor'...
    [    9.969521] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [    9.975127] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
    [    9.977433] init: SVC_EXEC service 'boringssl_self_test32_vendor' pid 150 (uid 0 gid 0+0 context default) started; waiting...
    [    9.983043] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [   10.003693] xhci-hcd xhci-hcd.3.auto: irq 487, io mem 0x31100000
    [   10.010220] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [   10.015803] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
    [   10.018599] init: Service 'boringssl_self_test32_vendor' (pid 150) exited with status 0 waiting took 0.047000 seconds
    [   10.023509] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
    [   10.034163] init: Sending signal 9 to service 'boringssl_self_test32_vendor' (pid 150) process group...
    [   10.040794] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   10.050263] libprocessgroup: Successfully killed process cgroup uid 0 pid 150 in 0ms
    [   10.058254] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.058259] usb usb1: Product: xHCI Host Controller
    [   10.058263] usb usb1: Manufacturer: Linux 5.10.168-android13-4-g1261c57d43aa xhci-hcd
    [   10.058267] usb usb1: SerialNumber: xhci-hcd.3.auto
    [   10.058766] hub 1-0:1.0: USB hub found
    [   10.068027] init: processing action (ro.product.cpu.abilist64=* && early-init) from (/vendor/etc/init/boringssl_self_test.rc:4)
    [   10.073291] hub 1-0:1.0: 1 port detected
    [   10.078848] init: starting service 'boringssl_self_test64_vendor'...
    [   10.086503] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.099674] init: SVC_EXEC service 'boringssl_self_test64_vendor' pid 151 (uid 0 gid 0+0 context default) started; waiting...
    [   10.106340] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   10.144233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.145668] init: Service 'boringssl_self_test64_vendor' (pid 151) exited with status 0 waiting took 0.051000 seconds
    [   10.151465] usb usb2: Product: xHCI Host Controller
    [   10.151470] usb usb2: Manufacturer: Linux 5.10.168-android13-4-g1261c57d43aa xhci-hcd
    [   10.151481] usb usb2: SerialNumber: xhci-hcd.3.auto
    [   10.162110] init: Sending signal 9 to service 'boringssl_self_test64_vendor' (pid 151) process group...
    [   10.167458] hub 2-0:1.0: USB hub found
    [   10.175096] libprocessgroup: Successfully killed process cgroup uid 0 pid 151 in 0ms
    [   10.179693] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
    [   10.190628] init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
    [   10.193421] ueventd: Loaded kernel module /vendor/lib/modules/xhci-plat-hcd.ko
    [   10.200779] init: start_waiting_for_property("ro.cold_boot_done", "true"): already set
    [   10.212657] ueventd: LoadWithAliases was unable to load of:NusbT(null)Csnps,dwc3
    [   10.216304] init: processing action (SetMmapRndBits) from (<Builtin Action>:0)
    [   10.237671] ueventd: Loading module /vendor/lib/modules/typec.ko with args ''
    [   10.238941] init: processing action (KeychordInit) from (<Builtin Action>:0)
    [   10.246097] ueventd: Loading module /vendor/lib/modules/tps6598x.ko with args ''
    [   10.252877] init: processing action (init) from (/system/etc/init/hw/init.rc:119)
    [   10.275621] init: Command 'copy /system/etc/prop.default /dev/urandom' action=init (/system/etc/init/hw/init.rc:124) took 0ms and failed: Could not read input file '/system/etc/prop.default': open() failed: No such file or directory
    [   10.282270] ueventd: LoadWithAliases was unable to load platform:regulatory
    [   10.318667] init: Command 'write /dev/blkio/blkio.weight 1000' action=init (/system/etc/init/hw/init.rc:218) took 0ms and failed: Unable to write to file '/dev/blkio/blkio.weight': open() failed: Permission denied
    [   10.320917] ueventd: LoadWithAliases was unable to load platform:wl18xx
    [   10.338995] init: Command 'write /dev/blkio/background/blkio.weight 200' action=init (/system/etc/init/hw/init.rc:219) took 1ms and failed: Unable to write to file '/dev/blkio/background/blkio.weight': open() failed: Permission denied
    [   10.344384] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   10.353507] ueventd: firmware: loading 'ti-connectivity/wl1271-nvs.bin' for '/devices/platform/bus@f0000/fa20000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18xx.2.auto/firmware/ti-connectivity!wl1271-nvs.bin'
    [   10.359217] ueventd: LoadWithAliases was unable to load of:Ninterrupt-controllerT(null)Cti,pruss-intc
    [   10.366340] init: Command 'write /dev/blkio/background/blkio.bfq.weight 10' action=init (/system/etc/init/hw/init.rc:220) took 1ms and failed: Unable to write to file '/dev/blkio/background/blkio.bfq.weight': open() failed: Permission denied
    [   10.370297] ueventd: LoadWithAliases was unable to load of:NpruT(null)Cti,am625-pru
    [   10.377300] ueventd: LoadWithAliases was unable to load of:NpruT(null)Cti,am625-pru
    [   10.391385] init: Command 'write /dev/blkio/blkio.group_idle 0' action=init (/system/etc/init/hw/init.rc:221) took 1ms and failed: Unable to write to file '/dev/blkio/blkio.group_idle': open() failed: Permission denied
    [   10.407487] ueventd: LoadWithAliases was unable to load virtio:d00000007v00000000
    [   10.422004] init: Command 'write /dev/blkio/background/blkio.group_idle 0' action=init (/system/etc/init/hw/init.rc:222) took 1ms and failed: Unable to write to file '/dev/blkio/background/blkio.group_idle': open() failed: Permission denied
    [   10.437012] ueventd: Loading module /vendor/lib/modules/rpmsg_client_sample.ko with args ''
    [   10.496226] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: new channel: 0x400 -> 0xd!
    [   10.500693] Registered swp emulation handler
    [   10.504737] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 1 (src: 0xd)
    [   10.505023] ueventd: Loaded kernel module /vendor/lib/modules/rpmsg_client_sample.ko
    [   10.510044] ueventd: Loading module /vendor/lib/modules/rpmsg_char.ko with args ''
    [   10.513189] init: starting service 'logd'...
    [   10.513904] init: Created socket '/dev/socket/logd', mode 666, user 1036, group 1036
    [   10.514373] init: Created socket '/dev/socket/logdr', mode 666, user 1036, group 1036
    [   10.514812] init: Created socket '/dev/socket/logdw', mode 222, user 1036, group 1036
    [   10.515018] init: Opened file '/proc/kmsg', flags 0
    [   10.515068] init: Opened file '/dev/kmsg', flags 1
    [   10.518446] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 2 (src: 0xd)
    [   10.527705] init: starting service 'lmkd'...
    [   10.532987] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 3 (src: 0xd)
    [   10.538282] ueventd: Loaded kernel module /vendor/lib/modules/rpmsg_char.ko
    [   10.538824] init: Created socket '/dev/socket/lmkd', mode 660, user 1000, group 1000
    [   10.545774] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 4 (src: 0xd)
    [   10.552350] init: starting service 'servicemanager'...
    [   10.558124] ueventd: LoadWithAliases was unable to load platform:xhci-hcd
    [   10.561465] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
    [   10.561935] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 5 (src: 0xd)
    [   10.561968] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 6 (src: 0xd)
    [   10.562008] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 7 (src: 0xd)
    [   10.568466] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 8 (src: 0xd)
    [   10.575371] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [   10.578333] ueventd: LoadWithAliases was unable to load usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00
    [   10.580798] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 9 (src: 0xd)
    [   10.583999] ueventd: LoadWithAliases was unable to load usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00
    [   10.584220] usb 1-1: Product: USB2.0 HUB
    [   10.587781] init: starting service 'hwservicemanager'...
    [   10.593891] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 10 (src: 0xd)
    [   10.602241] init: Command 'start vndservicemanager' action=init (/system/etc/init/hw/init.rc:450) took 0ms and failed: service vndservicemanager not found
    [   10.610996] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 11 (src: 0xd)
    [   10.615716] init: processing action (ro.debuggable=1 && init) from (/system/etc/init/hw/init.rc:1228)
    [   10.618410] ueventd: LoadWithAliases was unable to load usb:v1D6Bp0003d0510dc09dsc00dp03ic09isc00ip00in00
    [   10.623169] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 12 (src: 0xd)
    [   10.630140] logd.auditd: start
    [   10.632583] ueventd: LoadWithAliases was unable to load platform:xhci-hcd
    [   10.636440] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 13 (src: 0xd)
    [   10.641986] ueventd: LoadWithAliases was unable to load rpmsg:ti.ipc4.ping-pong
    [   10.658210] ueventd: LoadWithAliases was unable to load rpmsg:rpmsg_chrdev
    [   10.661522] hub 1-1:1.0: USB hub found
    [   10.661687] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 14 (src: 0xd)
    [   10.661720] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 15 (src: 0xd)
    [   10.661778] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 16 (src: 0xd)
    [   10.661816] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 17 (src: 0xd)
    [   10.662700] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 18 (src: 0xd)
    [   10.662782] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 19 (src: 0xd)
    [   10.662819] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 20 (src: 0xd)
    [   10.662855] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 21 (src: 0xd)
    [   10.662893] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 22 (src: 0xd)
    [   10.662930] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 23 (src: 0xd)
    [   10.662971] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 24 (src: 0xd)
    [   10.663009] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 25 (src: 0xd)
    [   10.663046] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 26 (src: 0xd)
    [   10.663088] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 27 (src: 0xd)
    [   10.663125] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 28 (src: 0xd)
    [   10.663162] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 29 (src: 0xd)
    [   10.663199] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 30 (src: 0xd)
    [   10.663237] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 31 (src: 0xd)
    [   10.663273] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 32 (src: 0xd)
    [   10.663310] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 33 (src: 0xd)
    [   10.663348] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incomi[  247.958399] sdhci-am654 fa00000.mmc: Power on failed
    ng msg 34 (src: 0xd)
    [   10.663385] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 35 (src: 0xd)
    [   10.663421] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 36 (src: 0xd)
    [   10.663458] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 37 (src: 0xd)
    [   10.663495] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 38 (src: 0xd)
    [   10.663534] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 39 (src: 0xd)
    [   10.663573] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 40 (src: 0xd)
    [   10.663610] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 41 (src: 0xd)
    [   10.663647] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 42 (src: 0xd)
    [   10.663684] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 43 (src: 0xd)
    [   10.663720] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 44 (src: 0xd)
    [   10.663758] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 45 (src: 0xd)
    [   10.663794] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 46 (src: 0xd)
    [   10.663831] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 47 (src: 0xd)
    [   10.663868] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 48 (src: 0xd)
    [   10.663906] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 49 (src: 0xd)
    [   10.663942] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 50 (src: 0xd)
    [   10.663980] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 51 (src: 0xd)
    [   10.664017] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 52 (src: 0xd)
    [   10.664055] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 53 (src: 0xd)
    [   10.664097] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 54 (src: 0xd)
    [   10.664134] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 55 (src: 0xd)
    [   10.664172] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 56 (src: 0xd)
    [   10.664209] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 57 (src: 0xd)
    [   10.664245] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 58 (src: 0xd)
    [   10.664906] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 59 (src: 0xd)
    [   10.664951] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 60 (src: 0xd)
    [   10.664998] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 61 (src: 0xd)
    [   10.665036] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 62 (src: 0xd)
    [   10.665073] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 63 (src: 0xd)
    [   10.665123] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 64 (src: 0xd)
    [   10.665162] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 65 (src: 0xd)
    [   10.665201] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 66 (src: 0xd)
    [   10.665322] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 67 (src: 0xd)
    [   10.665360] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 68 (src: 0xd)
    [   10.665398] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 69 (src: 0xd)
    [   10.665472] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 70 (src: 0xd)
    [   10.665509] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 71 (src: 0xd)
    [   10.665546] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 72 (src: 0xd)
    [   10.665584] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 73 (src: 0xd)
    [   10.665622] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 74 (src: 0xd)
    [   10.665659] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 75 (src: 0xd)
    [   10.665696] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 76 (src: 0xd)
    [   10.665737] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 77 (src: 0xd)
    [   10.665775] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 78 (src: 0xd)
    [   10.665812] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 79 (src: 0xd)
    [   10.666742] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 80 (src: 0xd)
    [   10.666785] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 81 (src: 0xd)
    [   10.666825] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 82 (src: 0xd)
    [   10.666867] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 83 (src: 0xd)
    [   10.667018] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 84 (src: 0xd)
    [   10.667058] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 85 (src: 0xd)
    [   10.667101] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 86 (src: 0xd)
    [   10.667137] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 87 (src: 0xd)
    [   10.667175] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 88 (src: 0xd)
    [   10.667211] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 89 (src: 0xd)
    [   10.667248] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 90 (src: 0xd)
    [   10.667286] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 91 (src: 0xd)
    [   10.667322] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 92 (src: 0xd)
    [   10.667359] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 93 (src: 0xd)
    [   10.667396] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 94 (src: 0xd)
    [   10.667433] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 95 (src: 0xd)
    [   10.667469] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 96 (src: 0xd)
    [   10.667506] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 97 (src: 0xd)
    [   10.667543] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 98 (src: 0xd)
    [   10.667579] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 99 (src: 0xd)
    [   10.667615] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 100 (src: 0xd)
    [   10.667619] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: goodbye!
    [   10.687987] ueventd: LoadWithAliases was unable to load usb:v1A40p0101d0100dc09dsc00dp01ic09isc00ip00in00
    [   10.694252] hub 1-1:1.0: 4 ports detected
    [   11.012296] sdhci-am654 fa00000.mmc: Power on failed
    [   11.070998] ueventd: LoadWithAliases was unable to load usb:v1A40p0101d0100dc09dsc00dp01ic09isc00ip00in00
    [   11.468305] usb 1-1.4: new low-speed USB device number 3 using xhci-hcd
    [   11.574185] init: starting service 'console'...
    [   11.591594] init: Command 'start console' action=ro.debuggable=1 && init (/system/etc/init/hw/init.rc:1229) took 963ms and succeeded
    [   11.603833] init: processing action (init) from (/system/etc/init/hw/init.usb.rc:27)
    [   11.612371] init: processing action (init) from (/vendor/etc/init/hw/init.am62x.rc:5)
    [   11.651830] init: Command 'start watchdogd' action=init (/vendor/etc/init/hw/init.am62x.rc:56) took 0ms and failed: service watchdogd not found
    [   11.664770] init: processing action (init) from (/system/etc/init/audioserver.rc:62)
    [   11.673955] init: processing action (late-init) from (/system/etc/init/hw/init.rc:468)
    [   11.682035] init: processing action (late-init) from (/system/etc/init/atrace.rc:3)
    [   11.702844] init: processing action (late-init) from (/vendor/etc/init/android.hardware.atrace@1.0-service.rc:1)
    [   11.714060] init: processing action (queue_property_triggers) from (<Builtin Action>:0)
    [   11.722485] init: processing action (early-fs) from (/system/etc/init/hw/init.rc:504)
    [   11.731048] init: starting service 'vold'...
    [   11.743947] init: processing action (early-fs) from (/vendor/etc/init/hw/init.am62x.rc:71)
    [   11.752914] init: processing action (fs) from (/vendor/etc/init/hw/init.am62x.rc:74)
    [   11.764249] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/platform/bus@f0000/fa10000.mmc/by-name/persist
    [   11.775392] init: [libfs_mgr]Filesystem on /dev/block/platform/bus@f0000/fa10000.mmc/by-name/persist was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
    [   11.791772] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
    [   11.801717] EXT4-fs (mmcblk0p13): recovery complete
    [   11.803575] usb 1-1.4: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00
    [   11.806673] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
    [   11.824360] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [   11.825980] init: [libfs_mgr]check_fs(): mount(/dev/block/platform/bus@f0000/fa10000.mmc/by-name/persist,/mnt/vendor/persist,ext4)=0: Success
    [   11.836568] usb 1-1.4: Product: USB OPTICAL MOUSE
    [   11.854903] init: [libfs_mgr]check_fs(): unmount(/mnt/vendor/persist) succeeded
    [   11.862772] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/mmcblk0p13
    [   11.901000] input: USB OPTICAL MOUSE  as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.4/1-1.4:1.0/0003:275D:0BA6.0001/input/input0
    [   11.917001] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
    [   11.922097] hid-generic 0003:275D:0BA6.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-xhci-hcd.3.auto-1.4/input0
    [   11.922673] e2fsck: Pass 1: Checking inodes, blocks, and sizes
    [   11.941586] e2fsck: Pass 2: Checking directory structure
    [   11.947055] e2fsck: Pass 3: Checking directory connectivity
    [   11.952699] e2fsck: Pass 4: Checking reference counts
    [   11.957809] e2fsck: Pass 5: Checking group summary information
    [   11.963751] e2fsck: /mnt/vendor/pers: 18/8192 files (33.3% non-contiguous), 1570/8192 blocks
    [   11.977618] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nodelalloc,errors=panic
    [   11.989737] init: [libfs_mgr]__mount(source=/dev/block/platform/bus@f0000/fa10000.mmc/by-name/persist,target=/mnt/vendor/persist,type=ext4)=0: Success
    [   12.011447] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --early' action=fs (/vendor/etc/init/hw/init.am62x.rc:75) took 250ms and succeeded
    [   12.026707] init: processing action (fs) from (/system/etc/init/logd.rc:28)
    [   12.034779] init: processing action (fs) from (/system/etc/init/wifi.rc:25)
    [   12.042631] init: processing action (post-fs) from (/system/etc/init/hw/init.rc:508)
    [   12.051279] init: starting service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)'...
    [   12.067455] init: SVC_EXEC service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' pid 172 (uid 1000 gid 1000+0 context default) started; waiting...
    [   12.099723] init: Service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' (pid 172) exited with status 0 waiting took 0.036000 seconds
    [   12.112561] init: Sending signal 9 to service 'exec 2 (/system/bin/vdc checkpoint markBootAttempt)' (pid 172) process group...
    [   12.124522] libprocessgroup: Successfully killed process cgroup uid 1000 pid 172 in 0ms
    [   12.146038] init: Command 'chown system cache /cache' action=post-fs (/system/etc/init/hw/init.rc:524) took 0ms and failed: lchown() failed: Read-only file system
    [   12.157510] ueventd: LoadWithAliases was unable to load usb:v275Dp0BA6d0100dc00dsc00dp00ic03isc01ip02in00
    [   12.160882] init: Command 'chmod 0770 /cache' action=post-fs (/system/etc/init/hw/init.rc:525) took 0ms and failed: fchmodat() failed: Read-only file system
    [   12.183318] ueventd: LoadWithAliases was unable to load hid:b0003g0001v0000275Dp00000BA6
    [   12.189713] selinux: SELinux: Skipping restorecon on directory(/metadata)
    [   12.197367] ueventd: LoadWithAliases was unable to load input:b0003v275Dp0BA6e0111-e0,1,2,4,k110,111,112,r0,1,8,B,am4,lsfw
    [   12.199056] selinux:
    [   12.220506] selinux: SELinux: Skipping restorecon on directory(/metadata/apex)
    [   12.222884] ueventd: LoadWithAliases was unable to load hid:b0003g0001v0000275Dp00000BA6
    [   12.227858] selinux:
    [   12.239170] init: processing action (post-fs) from (/vendor/etc/init/hw/init.am62x.rc:77)
    [   12.241075] ueventd: LoadWithAliases was unable to load usb:v275Dp0BA6d0100dc00dsc00dp00ic03isc01ip02in00
    [   12.248460] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:7)
    [   12.266056] init: processing action (post-fs) from (/system/etc/init/gsid.rc:8)
    [   12.273777] init: processing action (post-fs) from (/system/etc/init/recovery-refresh.rc:1)
    [   12.282643] init: starting service 'exec 3 (/system/bin/recovery-refresh)'...
    [   12.297297] init: processing action (post-fs) from (/vendor/etc/init/init.optee.rc:1)
    [   12.317265] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:581)
    [   12.325526] init: Service 'exec 3 (/system/bin/recovery-refresh)' (pid 173) exited with status 254 oneshot service took 0.032000 seconds in background
    [   12.339034] init: Sending signal 9 to service 'exec 3 (/system/bin/recovery-refresh)' (pid 173) process group...
    [   12.349436] libprocessgroup: Successfully killed process cgroup uid 1000 pid 173 in 0ms
    [   12.361854] init: starting service 'system_suspend'...
    [   12.376544] init: starting service 'keystore2'...
    [   12.396903] init: starting service 'vendor.atrace-hal-1-0'...
    [   12.413923] init: starting service 'vendor.boot-hal-1-2'...
    [   12.431799] init: starting service 'tee-supplicant'...
    [   12.450734] init: Command 'class_start early_hal' action=late-fs (/system/etc/init/hw/init.rc:588) took 92ms and succeeded
    [   12.463108] init: starting service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)'...
    [   12.482017] init: SVC_EXEC service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' pid 181 (uid 0 gid 0+0 context default) started; waiting...
    [   12.516989] init: Service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 181) exited with status 0 waiting took 0.041000 seconds
    [   12.530238] init: Sending signal 9 to service 'exec 4 (/system/bin/fsverity_init --load-verified-keys)' (pid 181) process group...
    [   12.542583] libprocessgroup: Successfully killed process cgroup uid 0 pid 181 in 0ms
    [   12.551827] init: processing action (late-fs) from (/system/etc/init/hw/init.rc:602)
    [   12.560797] init: processing action (late-fs) from (/vendor/etc/init/hw/init.am62x.rc:87)
    [   12.570268] init: starting service 'bootanim'...
    [   12.590573] init: starting service 'surfaceflinger'...
    [   12.596889] init: Could not create socket 'pdx/system/vr/display/client': Failed to bind socket 'pdx/system/vr/display/client': No such file or directory
    [   12.611626] init: Could not create socket 'pdx/system/vr/display/manager': Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory
    [   12.626410] init: Could not create socket 'pdx/system/vr/display/vsync': Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory
    [   12.652215] init: starting service 'vendor.gralloc-4-0'...
    [   12.668849] init: starting service 'vendor.hwcomposer-2-4'...
    [   12.687988] init: Command 'class_start animation' action=late-fs (/vendor/etc/init/hw/init.am62x.rc:90) took 98ms and succeeded
    [   12.701460] init: starting service 'vendor.keymaster-3-0-optee'...
    [   12.726957] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' fr[  249.524383] sdhci-am654 fa00000.mmc: Power on failed
    om pid: 156 (/system/bin/hwservicemanager)
    [   12.743841] init: start_waiting_for_property("hwservicemanager.ready", "true"): already set
    [   12.753148] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' from pid: 156 (/system/bin/hwservicemanager)
    [   12.769525] init: processing action (late-fs) from (/vendor/etc/init/init.optee.rc:4)
    [   12.778861] init: starting service 'wait_for_keymaster_optee'...
    [   12.804169] init: SVC_EXEC service 'wait_for_keymaster_optee' pid 194 (uid 1000 gid 1000+1 context default) started; waiting...
    [   12.832396] sdhci-am654 fa00000.mmc: Power on failed
    [   12.898031] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' from pid: 156 (/system/bin/hwservicemanager)
    [   12.916431] init: Control message: Processed ctl.interface_start for 'android.hardware.keymaster@3.0::IKeymasterDevice/default' from pid: 156 (/system/bin/hwservicemanager)
    [   12.932992] PVR_K:  188: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [   12.949266] PVR_K:  188: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [   13.005503] init: Service 'wait_for_keymaster_optee' (pid 194) exited with status 0 waiting took 0.216000 seconds
    [   13.016058] init: Sending signal 9 to service 'wait_for_keymaster_optee' (pid 194) process group...
    [   13.025805] libprocessgroup: Successfully killed process cgroup uid 1000 pid 194 in 0ms
    [   13.038768] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
    [   13.077489] vdc: Waited 0ms for vold
    [   13.085930] init: [libfs_mgr]Invalid f2fs superblock on '/dev/block/platform/bus@f0000/fa10000.mmc/by-name/userdata'
    [   13.097099] init: [libfs_mgr]mount_with_alternatives(): skipping mount due to invalid magic, mountpoint=/data blk_dev=/dev/block/mmcblk0p14 rec[3].fs_type=f2fs
    [   13.112549] init: Calling: /system/bin/vdc cryptfs mountFstab /dev/block/platform/bus@f0000/fa10000.mmc/by-name/userdata /data
    [   13.159226] vdc: Waited 0ms for vold
    [   13.247336] fsck.f2fs: Info: Fix the reported corruption.
    [   13.254037] fsck.f2fs: \x09Info: No support kernel version!
    [   13.259564] fsck.f2fs: Info: Segments per section = 1
    [   13.265729] fsck.f2fs: Info: Sections per zone = 1
    [   13.270755] fsck.f2fs: Info: sector size = 4096
    [   13.277852] fsck.f2fs: Info: total sectors = 2664923 (10409 MB)
    [   13.283922] fsck.f2fs: Info: MKFS version
    [   13.288330] fsck.f2fs:   "5.15.0-58-generic"
    [   13.293155] fsck.f2fs: Info: FSCK version
    [   13.297502] fsck.f2fs:   from "5.10.168-android13-4-g1261c57d43aa"
    [   13.304175] fsck.f2fs:     to "5.10.168-android13-4-g1261c57d43aa"
    [   13.310607] fsck.f2fs: Info: superblock features = 1499 :  encrypt verity extra_attr project_quota quota_ino casefold
    [   13.321341] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
    [   13.330522] fsck.f2fs: Info: total FS sectors = 2611456 (10201 MB)
    [   13.337338] fsck.f2fs: Info: CKPT version = 714b569
    [   13.368863] fsck.f2fs: Info: checkpoint state = 46 :  crc compacted_summary orphan_inodes sudden-power-off
    [   13.378670] fsck.f2fs: Info: No error was reported
    [   13.383610] fsck.f2fs:
    [   13.386135] fsck.f2fs: c, u, RA, CH, CM, Repl=
    [   13.390664] fsck.f2fs: 10000 1639 6609 4970 1639 0
    [   13.398876] F2FS-fs (dm-4): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
    [   13.502541] F2FS-fs (dm-4): Mounted with checkpoint version = 714b569
    [   13.526159] init: Userdata mounted using /vendor/etc/fstab.am62x result : 7
    [   13.534189] init: Keyring created with id 35869508 in process 1
    [   13.541392] init: Command 'mount_all /vendor/etc/fstab.${ro.hardware} --late' action=late-fs (/vendor/etc/init/init.optee.rc:6) took 504ms and succeeded
    [   13.558370] init: processing action (post-fs-data) from (/system/etc/init/hw/init.rc:616)
    [   13.569291] init: starting service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)'...
    [   13.589828] init: SVC_EXEC service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' pid 238 (uid 1000 gid 1000+0 context default) started; waiting...
    [   13.605059] init: Control message: Processed ctl.start for 'bootanim' from pid: 184 (/system/bin/surfaceflinger)
    [   13.622633] init: Service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' (pid 238) exited with status 0 waiting took 0.040000 seconds
    [   13.635711] init: Sending signal 9 to service 'exec 5 (/system/bin/vdc checkpoint prepareCheckpoint)' (pid 238) process group...
    [   13.647920] libprocessgroup: Successfully killed process cgroup uid 1000 pid 238 in 0ms
    [   13.662015] init: starting service 'exec 6 (/system/bin/vdc --wait cryptfs enablefilecrypto)'...
    [   13.681945] init: SVC_EXEC service 'exec 6 (/system/bin/vdc --wait cryptfs enablefilecrypto)' pid 239 (uid 0 gid 0+0 context default) started; waiting...
    [   13.714686] vdc: Waited 0ms for vold
    [   13.753915] init: Service 'exec 6 (/system/bin/vdc --wait cryptfs enablefilecrypto)' (pid 239) exited with status 0 waiting took 0.079000 seconds
    [   13.767429] init: Sending signal 9 to service 'exec 6 (/system/bin/vdc --wait cryptfs enablefilecrypto)' (pid 239) process group...
    [   13.780255] libprocessgroup: Successfully killed process cgroup uid 0 pid 239 in 0ms
    [   13.792608] init: Verified that /data/bootchart has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   13.805061] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
    [   13.815571] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
    [   13.825328] init: Verified that /data/vendor has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   13.837629] init: Not setting encryption policy on: /data/vendor_ce
    [   13.845491] init: Not setting encryption policy on: /data/vendor_de
    [   13.857395] init: Verified that /data/anr has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   13.873398] init: Verified that /data/tombstones has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   13.889151] init: starting service 'tombstoned'...
    [   13.895546] init: Created socket '/dev/socket/tombstoned_crash', mode 666, user 1000, group 1000
    [   13.905728] init: Created socket '/dev/socket/tombstoned_intercept', mode 666, user 1000, group 1000
    [   13.916584] init: Created socket '/dev/socket/tombstoned_java_trace', mode 666, user 1000, group 1000
    [   13.941593] init: Command 'start tombstoned' action=post-fs-data (/system/etc/init/hw/init.rc:650) took 53ms and succeeded
    [   13.953307] init: Switched to default mount namespace
    [   13.960105] init: Verified that /data/misc has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   13.977951] init: starting service 'exec 7 (/system/bin/vdc keymaster earlyBootEnded)'...
    [   13.996801] init: SVC_EXEC service 'exec 7 (/system/bin/vdc keymaster earlyBootEnded)' pid 248 (uid 1000 gid 1000+0 context default) started; waiting...
    [   14.073995] init: Service 'exec 7 (/system/bin/vdc keymaster earlyBootEnded)' (pid 248) exited with status 0 waiting took 0.083000 seconds
    [   14.087672] init: Sending signal 9 to service 'exec 7 (/system/bin/vdc keymaster earlyBootEnded)' (pid 248) process group...
    [   14.099673] libprocessgroup: Successfully killed process cgroup uid 1000 pid 248 in 0ms
    [   14.109392] init: Not setting encryption policy on: /data/apex
    [   14.120535] init: Inferred action different from explicit one, expected 0 but got 2
    [   14.129534] init: Verified that /data/apex/decompressed has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.144788] init: Inferred action different from explicit one, expected 0 but got 3
    [   14.154196] init: Verified that /data/app-staging has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.166958] init: Inferred action different from explicit one, expected 0 but got 2
    [   14.176733] init: Verified that /data/apex/ota_reserved has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.191827] init: starting service 'apexd'...
    [   14.256214] apexd: Scanning /system/apex for pre-installed ApexFiles
    [   14.263719] apexd: Found pre-installed APEX /system/apex/com.android.media.capex
    [   14.268834] init: Verified that /data/local has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.272985] apexd: Found pre-installed APEX /system/apex/com.android.i18n.apex
    [   14.291747] apexd: Found pre-installed APEX /system/apex/com.android.os.statsd.apex
    [   14.300925] apexd: Found pre-installed APEX /system/apex/com.android.adbd.capex
    [   14.305856] init: Not setting encryption policy on: /data/preloads
    [   14.309603] apexd: Found pre-installed APEX /system/apex/com.android.vndk.current.apex
    [   14.318230] init: Not setting encryption policy on: /data/data
    [   14.323624] apexd: Found pre-installed APEX /system/apex/com.android.permission.capex
    [   14.331378] init: Verified that /data/app-private has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.337615] apexd: Found pre-installed APEX /system/apex/com.android.sdkext.apex
    [   14.350591] init: Verified that /data/app-ephemeral has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.357056] apexd: Found pre-installed APEX /system/apex/com.android.scheduling.apex
    [   14.370341] init: Verified that /data/app-asec has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.376939] apexd: Found pre-installed APEX /system/apex/com.android.ipsec.capex
    [   14.389620] init: Verified that /data/app-lib has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.396940] apexd: Found pre-installed APEX /system/apex/com.android.extservices.capex
    [   14.406951] sdhci-am654 fa00000.mmc: Power on failed
    [   14.415701] apexd: Found pre-installed APEX /system/apex/com.android.tethering.capex
    [   14.421228] init: Verified that /data/app has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.428716] apexd: Found pre-installed APEX /system/apex/com.android.tzdata.apex
    [   14.440181] init: Verified that /data/property has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.447439] apexd: Found pre-installed APEX /system/apex/com.android.art.capex
    [   14.458293] init: Inferred action different from explicit one, expected 0 but got 2
    [   14.466470] apexd: Found pre-installed APEX /system/apex/com.android.wifi.capex
    [   14.474383] init: Verified that /data/fonts/ has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.481584] apexd: Found pre-installed APEX /system/apex/com.android.runtime.apex
    [   14.497345] init: Verified that /data/dalvik-cache has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.500386] apexd: Found pre-installed APEX /system/apex/com.android.conscrypt.apex
    [   14.513426] init: Verified that /data/ota has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.520560] apexd: Found pre-installed APEX /system/apex/com.android.neuralnetworks.capex
    [   14.532949] init: Verified that /data/ota_package has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.539860] apexd: Found pre-installed APEX /system/apex/com.android.mediaprovider.capex
    [   14.552525] init: Verified that /data/resource-cache has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.559758] apexd: Found pre-installed APEX /system/apex/com.android.appsearch.apex
    [   14.571860] init: Not setting encryption policy on: /data/lost+found
    [   14.579678] apexd: Found pre-installed APEX /system/apex/com.android.resolv.capex
    [   14.587497] init: Verified that /data/drm has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.593606] apexd: Found pre-installed APEX /system/apex/com.android.apex.cts.shim.apex
    [   14.605914] init: Verified that /data/mediadrm has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.613063] apexd: Found pre-installed APEX /system/apex/com.android.media.swcodec.capex
    [   14.626228] init: Verified that /data/nfc has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.632981] apexd: Scanning /system_ext/apex for pre-installed ApexFiles
    [   14.647501] init: Verified that /data/backup has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.649796] apexd: /system_ext/apex does not exist. Skipping
    [   14.663051] init: Verified that /data/ss has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.667017] apexd: Scanning /product/apex for pre-installed ApexFiles
    [   14.679148] init: Verified that /data/system has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.684575] apexd: /product/apex does not exist. Skipping
    [   14.701467] apexd: Scanning /vendor/apex for pre-installed ApexFiles
    [   14.701917] init: Not setting encryption policy on: /data/system_de
    [   14.708142] apexd: /vendor/apex does not exist. Skipping
    [   14.715932] init: Not setting encryption policy on: /data/system_ce
    [   14.719692] apexd: Populating APEX database from mounts...
    [   14.727786] init: Not setting encryption policy on: /data/misc_de
    [   14.732946] apexd: 0 packages restored.
    [   14.738698] init: Not setting encryption policy on: /data/misc_ce
    [   14.741951] apexd: Marking APEXd as starting
    [   14.749349] init: Not setting encryption policy on: /data/user
    [   14.759158] init: Not setting encryption policy on: /data/user_de
    [   14.760859] apexd: Scanning /metadata/apex/sessions looking for sessions to be activated.
    [   14.766947] init: Command 'rm /data/user/0' action=post-fs-data (/system/etc/init/hw/init.rc:847) took 0ms and failed: unlink() failed: Is a directory
    [   14.774506] apexd: Scanning /data/apex/active for data ApexFiles
    [   14.793674] apexd: Selecting APEX for activation
    [   14.798536] apexd: Processing compressed APEX
    [   14.803098] apexd: Processing compressed APEX /system/apex/com.android.media.capex
    [   14.809627] init: Verified that /data/cache has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.822410] apexd: Skipping decompression for /system/apex/com.android.media.capex
    [   14.828015] init: Verified that /data/rollback has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.830179] apexd: Processing compressed APEX /system/apex/com.android.mediaprovider.capex
    [   14.843383] init: Verified that /data/rollback-observer has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.861036] apexd: Skipping decompression for /system/apex/com.android.mediaprovider.capex
    [   14.862873] init: Inferred action different from explicit one, expected 2 but got 3
    [   14.870950] apexd: Processing compressed APEX /system/apex/com.android.ipsec.capex
    [   14.879838] init: Verified that /data/rollback-history has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.896168] apexd: Skipping decompression for /system/apex/com.android.ipsec.capex
    [   14.901195] init: Verified that /data/incremental has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   14.906394] apexd: Processing compressed APEX /system/apex/com.android.tethering.capex
    [   14.935912] apexd: Skipping decompression for /system/apex/com.android.tethering.capex
    [   14.944035] apexd: Processing compressed APEX /system/apex/com.android.adbd.capex
    [   14.962545] apexd: Skipping decompression for /system/apex/com.android.adbd.capex
    [   14.970269] apexd: Processing compressed APEX /system/apex/com.android.neuralnetworks.capex
    [   14.990363] apexd: Skipping decompression for /system/apex/com.android.neuralnetworks.capex
    [   14.998989] apexd: Processing compressed APEX /system/apex/com.android.permission.capex
    [   15.017203] apexd: Skipping decompression for /system/apex/com.android.permission.capex
    [   15.025449] apexd: Processing compressed APEX /system/apex/com.android.extservices.capex
    [   15.044687] apexd: Skipping decompression for /system/apex/com.android.extservices.capex
    [   15.052989] apexd: Processing compressed APEX /system/apex/com.android.art.capex
    [   15.075746] apexd: Skipping decompression for /system/apex/com.android.art.capex
    [   15.083487] apexd: Processing compressed APEX /system/apex/com.android.wifi.capex
    [   15.101208] apexd: Skipping decompression for /system/apex/com.android.wifi.capex
    [   15.108908] apexd: Processing compressed APEX /system/apex/com.android.resolv.capex
    [   15.127334] apexd: Skipping decompression for /system/apex/com.android.resolv.capex
    [   15.135288] apexd: Processing compressed APEX /system/apex/com.android.media.swcodec.capex
    [   15.156746] apexd: Skipping decompression for /system/apex/com.android.media.swcodec.capex
    [   15.180484] EXT4-fs (loop4): mounted filesystem without journal. Opts: (null)
    [   15.188216] apexd: Successfully mounted package /system/apex/com.android.os.statsd.apex on /apex/com.android.os.statsd@319999900 duration=19
    [   15.189846] EXT4-fs (loop5): mounted filesystem without journal. Opts: (null)
    [   15.208935] apexd: Successfully mounted package /system/apex/com.android.i18n.apex on /apex/com.android.i[  251.292484] sdhci-am654 fa00000.mmc: Power on failed
    18n@1 duration=37
    [   15.246804] EXT4-fs (loop6): mounted filesystem without journal. Opts: (null)
    [   15.258689] EXT4-fs (loop7): mounted filesystem without journal. Opts: (null)
    [   15.266493] apexd: Successfully mounted package /system/apex/com.android.sdkext.apex on /apex/com.android.sdkext@319999900 duration=41
    [   15.279302] apexd: Successfully mounted package /system/apex/com.android.vndk.current.apex on /apex/com.android.vndk.v31@1 duration=50
    [   15.304521] EXT4-fs (loop8): mounted filesystem without journal. Opts: (null)
    [   15.309535] EXT4-fs (loop9): mounted filesystem without journal. Opts: (null)
    [   15.312021] apexd: Successfully mounted package /system/apex/com.android.tzdata.apex on /apex/com.android.tzdata@319999900 duration=18
    [   15.319261] apexd: Successfully mounted package /system/apex/com.android.scheduling.apex on /apex/com.android.scheduling@319999900 duration=24
    [   15.346347] EXT4-fs (loop10): mounted filesystem without journal. Opts: (null)
    [   15.354247] apexd: Successfully mounted package /system/apex/com.android.conscrypt.apex on /apex/com.android.conscrypt@319999900 duration=21
    [   15.358874] EXT4-fs (loop11): mounted filesystem without journal. Opts: (null)
    [   15.368334] random: crng init done
    [   15.374439] apexd: Successfully mounted package /system/apex/com.android.runtime.apex on /apex/com.android.runtime@1 duration=28
    [   15.377652] random: 165 urandom warning(s) missed due to ratelimiting
    [   15.386972] EXT4-fs (loop12): mounted filesystem without journal. Opts: (null)
    [   15.404010] apexd: Successfully mounted package /system/apex/com.android.appsearch.apex on /apex/com.android.appsearch@300000000 duration=29
    [   15.419507] EXT4-fs (loop13): mounted filesystem without journal. Opts: (null)
    [   15.427214] apexd: Successfully mounted package /system/apex/com.android.apex.cts.shim.apex on /apex/com.android.apex.cts.shim@1 duration=22
    [   15.432767] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.453927] EXT4-fs (dm-5): mounted filesystem without journal. Opts: (null)
    [   15.461676] apexd: Successfully mounted package /data/apex/decompressed/com.android.media@319999900.decompressed.apex on /apex/com.android.media@319999900 duration=41
    [   15.483567] apexd: Loopback device 16 not ready. Waiting 50ms...: No such file or directory
    [   15.485685] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.526001] EXT4-fs (dm-6): mounted filesystem without journal. Opts: (null)
    [   15.533671] apexd: Successfully mounted package /data/apex/decompressed/com.android.mediaprovider@319999910.decompressed.apex on /apex/com.android.mediaprovider@319999910 duration=55
    [   15.559494] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.559677] apexd: Loopback device 17 not ready. Waiting 50ms...: No such file or directory
    [   15.591326] EXT4-fs (dm-7): mounted filesystem without journal. Opts: (null)
    [   15.598843] apexd: Successfully mounted package /data/apex/decompressed/com.android.ipsec@319999900.decompressed.apex on /apex/com.android.ipsec@319999900 duration=117
    [   15.631747] apexd: Loopback device 18 not ready. Waiting 50ms...: No such file or directory
    [   15.636555] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.653433] EXT4-fs (dm-8): mounted filesystem without journal. Opts: (null)
    [   15.660968] apexd: Successfully mounted package /data/apex/decompressed/com.android.tethering@319999900.decompressed.apex on /apex/com.android.tethering@319999900 duration=103
    [   15.696737] apexd: Loopback device 19 not ready. Waiting 50ms...: No such file or directory
    [   15.707673] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.747307] EXT4-fs (dm-9): mounted filesystem without journal. Opts: (null)
    [   15.754920] apexd: Successfully mounted package /data/apex/decompressed/com.android.adbd@319999999.decompressed.apex on /apex/com.android.adbd@319999999 duration=139
    [   15.777479] apexd: Loopback device 20 not ready. Waiting 50ms...: No such file or directory
    [   15.777556] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.799458] EXT4-fs (dm-10): mounted filesystem without journal. Opts: (null)
    [   15.807063] apexd: Successfully mounted package /data/apex/decompressed/com.android.neuralnetworks@319999900.decompressed.apex on /apex/com.android.neuralnetworks@319999900 duration=127
    [   15.840130] apexd: Loopback device 21 not ready. Waiting 50ms...: No such file or directory
    [   15.844235] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.885146] EXT4-fs (dm-11): mounted filesystem without journal. Opts: (null)
    [   15.892886] apexd: Successfully mounted package /data/apex/decompressed/com.android.permission@319999900.decompressed.apex on /apex/com.android.permission@319999900 duration=118
    [   15.914872] apexd: Loopback device 22 not ready. Waiting 50ms...: No such file or directory
    [   15.929069] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.962128] EXT4-fs (dm-12): mounted filesystem without journal. Opts: (null)
    [   15.969749] apexd: Successfully mounted package /data/apex/decompressed/com.android.extservices@319999900.decompressed.apex on /apex/com.android.extservices@319999900 duration=143
    [   15.983743] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   15.991203] apexd: Loopback device 23 not ready. Waiting 50ms...: No such file or directory
    [   16.008418] sdhci-am654 fa00000.mmc: Power on failed
    [   16.018732] EXT4-fs (dm-13): mounted filesystem without journal. Opts: (null)
    [   16.026358] apexd: Successfully mounted package /data/apex/decompressed/com.android.art@319999900.decompressed.apex on /apex/com.android.art@319999900 duration=114
    [   16.054696] apexd: Loopback device 24 not ready. Waiting 50ms...: No such file or directory
    [   16.059352] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   16.082775] EXT4-fs (dm-14): mounted filesystem without journal. Opts: (null)
    [   16.090547] apexd: Successfully mounted package /data/apex/decompressed/com.android.wifi@319999900.decompressed.apex on /apex/com.android.wifi@319999900 duration=101
    [   16.126820] apexd: Loopback device 25 not ready. Waiting 50ms...: No such file or directory
    [   16.136514] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   16.153478] EXT4-fs (dm-15): mounted filesystem without journal. Opts: (null)
    [   16.161008] apexd: Successfully mounted package /data/apex/decompressed/com.android.resolv@319999900.decompressed.apex on /apex/com.android.resolv@319999900 duration=117
    [   16.195437] device-mapper: verity: sha256 using implementation "sha256-ce"
    [   16.230643] EXT4-fs (dm-16): mounted filesystem without journal. Opts: (null)
    [   16.240119] apexd: Successfully mounted package /data/apex/decompressed/com.android.media.swcodec@319999900.decompressed.apex on /apex/com.android.media.swcodec@319999900 duration=131
    [   16.259658] apexd: Activated 22 packages.
    [   16.264334] apexd: OnStart done, duration=1511
    [   16.269236] AidlLazyServiceRegistrar: Registering service apexservice
    [   16.337048] apexd: Can't open /system_ext/apex for reading : No such file or directory
    [   16.345561] apexd: Can't open /product/apex for reading : No such file or directory
    [   16.353693] apexd: Can't open /vendor/apex for reading : No such file or directory
    [   16.375639] apexd: Marking APEXd as activated
    [   16.381179] init: Wait for property 'apexd.status=activated' took 1458ms
    [   16.417218] init: Parsing file /apex/com.android.adbd/etc/init.rc...
    [   16.425490] init: Parsing file /apex/com.android.media.swcodec/etc/init.rc...
    [   16.433995] init: Parsing file /apex/com.android.media/etc/init.rc...
    [   16.441710] init: Parsing file /apex/com.android.os.statsd/etc/init.rc...
    [   16.450398] init: Parsing file /apex/com.android.sdkext/etc/derive_classpath.rc...
    [   16.459945] init: Parsing file /apex/com.android.sdkext/etc/derive_sdk.rc...
    [   16.575123] init: linkerconfig generated /linkerconfig with mounted APEX modules info
    [   16.583354] init: Command 'perform_apex_config' action=post-fs-data (/system/etc/init/hw/init.rc:896) took 194ms and succeeded
    [   16.595314] init: Not setting encryption policy on: /data/media
    [   16.606163] init: starting service 'exec 8 (/system/bin/chattr +F /data/media)'...
    [   16.629227] init: SVC_EXEC service 'exec 8 (/system/bin/chattr +F /data/media)' pid 328 (uid 1023 gid 1023+0 context default) started; waiting...
    [   16.716569] init: Service 'exec 8 (/system/bin/chattr +F /data/media)' (pid 328) exited with status 0 waiting took 0.098000 seconds
    [   16.728615] init: Sending signal 9 to service 'exec 8 (/system/bin/chattr +F /data/media)' (pid 328) process group...
    [   16.740130] libprocessgroup: Successfully killed process cgroup uid 1023 pid 328 in 0ms
    [   16.752019] init: Verified that /data/media/obb has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   16.765704] init: starting service 'derive_sdk'...
    [   16.786033] init: SVC_EXEC service 'derive_sdk' pid 329 (uid 9999 gid 9999+0 context default) started; waiting...
    [   16.826829] init: Service 'derive_sdk' (pid 329) exited with status 0 waiting took 0.052000 seconds
    [   16.836381] init: Sending signal 9 to service 'derive_sdk' (pid 329) process group...
    [   16.845005] libprocessgroup: Successfully killed process cgroup uid 9999 pid 329 in 0ms
    [   16.857021] init: starting service 'exec 9 (/system/bin/vdc --wait cryptfs init_user0)'...
    [   16.877387] init: SVC_EXEC service 'exec 9 (/system/bin/vdc --wait cryptfs init_user0)' pid 330 (uid 0 gid 0+0 context default) started; waiting...
    [   16.913467] vdc: Waited 0ms for vold
    [   17.092674] init: Service 'exec 9 (/system/bin/vdc --wait cryptfs init_user0)' (pid 330) exited with status 0 waiting took 0.223000 seconds
    [   17.105646] init: Sending signal 9 to service 'exec 9 (/system/bin/vdc --wait cryptfs init_user0)' (pid 330) process group...
    [   17.117720] libprocessgroup: Successfully killed process cgroup uid 0 pid 330 in 0ms
    [   17.131254] selinux: SELinux: Skipping restorecon on directory(/data)
    [   17.138012] selinux:
    [   17.141570] init: starting service 'derive_classpath'...
    [   17.164019] init: SVC_EXEC service 'derive_classpath' pid 332 (uid 1000 gid 1000+1 context default) started; waiting...
    [   17.241495] init: Service 'derive_classpath' (pid 332) exited with status 0 waiting took 0.090000 seconds
    [   17.251364] init: Sending signal 9 to service 'derive_classpath' (pid 332) process group...
    [   17.260466] libprocessgroup: Successfully killed process cgroup uid 1000 pid 332 in 0ms
    [   17.273070] init: starting service 'odsign'...
    [   17.564412] sdhci-am654 fa00000.mmc: Power on failed
    [   17.692782] init: Wait for property 'odsign.key.done=1' took 402ms
    [   17.700376] init: starting service 'exec 10 (/system/bin/fsverity_init --lock)'...
    [   17.717464] init: SVC_EXEC service 'exec 10 (/system/bin/fsverity_init --lock)' pid 336 (uid 0 gid 0+0 context default) started; waiting...
    [   17.730854] init: Sending signal 9 to service 'odsign' (pid 333) process group...
    [   17.744536] libprocessgroup: Successfully killed process cgroup uid 0 pid 333 in 5ms
    [   17.754280] init: Control message: Processed ctl.stop for 'odsign' from pid: 333 (/system/bin/odsign)
    [   17.764092] init: Service 'odsign' (pid 333) received signal 9
    [   17.772417] init: Service 'exec 10 (/system/bin/fsverity_init --lock)' (pid 336) exited with status 0 waiting took 0.060000 seconds
    [   17.784561] init: Sending signal 9 to service 'exec 10 (/system/bin/fsverity_init --lock)' (pid 336) process group...
    [   17.795812] libprocessgroup: Successfully killed process cgroup uid 0 pid 336 in 0ms
    [   17.807136] init: starting service 'apexd-snapshotde'...
    [   17.824772] init: SVC_EXEC service 'apexd-snapshotde' pid 338 (uid 0 gid 1000+0 context default) started; waiting...
    [   17.869492] apexd: Snapshot DE subcommand detected
    [   17.877716] apexd: Marking APEXd as ready
    [   17.888393] init: Service 'apexd-snapshotde' (pid 338) exited with status 0 waiting took 0.071000 seconds
    [   17.898555] init: Sending signal 9 to service 'apexd-snapshotde' (pid 338) process group...
    [   17.907992] libprocessgroup: Successfully killed process cgroup uid 0 pid 338 in 0ms
    [   17.920915] init: starting service 'exec 11 (/system/bin/tzdatacheck /apex/com.android.tzdata/etc/tz /data/misc/zoneinfo)'...
    [   17.943884] init: SVC_EXEC service 'exec 11 (/system/bin/tzdatacheck /apex/com.android.tzdata/etc/tz /data/misc/zoneinfo)' pid 339 (uid 1000 gid 1000+0 context default) started; waiting...
    [   17.977364] init: Service 'exec 11 (/system/bin/tzdatacheck /apex/com.android.tzdata/etc/tz /data/misc/zoneinfo)' (pid 339) exited with status 0 waiting took 0.040000 seconds
    [   17.993654] init: Sending signal 9 to service 'exec 11 (/system/bin/tzdatacheck /apex/com.android.tzdata/etc/tz /data/misc/zoneinfo)' (pid 339) process group...
    [   18.009066] libprocessgroup: Successfully killed process cgroup uid 1000 pid 339 in 0ms
    [   18.022133] init: processing action (post-fs-data) from (/system/etc/init/hw/init.usb.rc:6)
    [   18.036386] init: Verified that /data/adb has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   18.048011] init: processing action (post-fs-data) from (/vendor/etc/init/hw/init.am62x.rc:97)
    [   18.059509] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:9)
    [   18.081856] init: processing action (ro.debuggable=1 && post-fs-data) from (/system/etc/init/clean_scratch_files.rc:1)
    [   18.093809] init: Command 'exec_background - root root -- /system/bin/clean_scratch_files' action=ro.debuggable=1 && post-fs-data (/system/etc/init/clean_scratch_files.rc:2) took 0ms and failed: Could not start exec background service: File /system/bin/clean_scratch_files(labeled "u:object_r:system_file:s0") has incorrect label or no domain transition from u:r:init:s0 to another SELinux domain defined. Have you configured your service correctly? https://source.android.com/security/selinux/device-policy#label_new_services_and_address_denials. Note: this error shows up even in permissive mode in order to make auditing denials possible.
    [   18.150142] init: processing action (post-fs-data) from (/system/etc/init/gsid.rc:17)
    [   18.162258] init: Not setting encryption policy on: /data/gsi
    [   18.171581] init: processing action (post-fs-data) from (/system/etc/init/incidentd.rc:21)
    [   18.181349] init: processing action (post-fs-data) from (/system/etc/init/iorapd.rc:29)
    [   18.190677] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
    [   18.204656] init: processing action (post-fs-data) from (/system/etc/init/otapreopt.rc:3)
    [   18.213860] init: starting service 'exec 13 (/system/bin/otapreopt_slot)'...
    [   18.229812] init: SVC_EXEC service 'exec 13 (/system/bin/otapreopt_slot)' pid 340 (uid 0 gid 0+0 context default) started; waiting...
    [   18.331097] init: Service 'exec 13 (/system/bin/otapreopt_slot)' (pid 340) exited with status 0 waiting took 0.106000 seconds
    [   18.342677] init: Sending signal 9 to service 'exec 13 (/system/bin/otapreopt_slot)' (pid 340) process group...
    [   18.353352] libprocessgroup: Successfully killed process cgroup uid 0 pid 340 in 0ms
    [   18.368137] selinux: SELinux: Skipping restorecon on directory(/data/dalvik-cache/arm)
    [   18.377012] selinux:
    [   18.382855] selinux: SELinux: Skipping restorecon on directory(/data/dalvik-cache/arm64)
    [   18.391163] selinux:
    [   18.393922] selinux: SELinux:  Could not stat /data/dalvik-cache/mips: No such file or direct[  252.854495] sdhci-am654 fa00000.mmc: Power on failed
    ory.
    [   18.402975] selinux:
    [   18.405813] selinux: SELinux:  Could not stat /data/dalvik-cache/mips64: No such file or directory.
    [   18.414997] selinux:
    [   18.417818] selinux: SELinux:  Could not stat /data/dalvik-cache/x86: No such file or directory.
    [   18.426788] selinux:
    [   18.429609] selinux: SELinux:  Could not stat /data/dalvik-cache/x86_64: No such file or directory.
    [   18.438916] selinux:
    [   18.441560] init: Command 'restorecon_recursive /data/dalvik-cache/arm /data/dalvik-cache/arm64 /data/dalvik-cache/mips /data/dalvik-cache/mips64 /data/dalvik-cache/x86 /data/dalvik-cache/x86_64' action=post-fs-data (/system/etc/init/otapreopt.rc:8) took 79ms and succeeded
    [   18.466041] init: processing action (post-fs-data) from (/system/etc/init/perfetto.rc:73)
    [   18.477958] init: Command 'rm /data/misc/perfetto-traces/.guardraildata' action=post-fs-data (/system/etc/init/perfetto.rc:74) took 3ms and failed: unlink() failed: No such file or directory
    [   18.495583] init: processing action (post-fs-data) from (/system/etc/init/profcollectd.rc:15)
    [   18.508618] init: processing action (post-fs-data) from (/system/etc/init/recovery-persist.rc:1)
    [   18.518601] init: starting service 'exec 14 (/system/bin/recovery-persist)'...
    [   18.534960] init: processing action (post-fs-data) from (/system/etc/init/wifi.rc:18)
    [   18.546040] selinux: SELinux: Skipping restorecon on directory(/data/misc/apexdata/com.android.wifi)
    [   18.555337] selinux:
    [   18.558015] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
    [   18.568721] init: Service 'exec 14 (/system/bin/recovery-persist)' (pid 343) exited with status 0 oneshot service took 0.039000 seconds in background
    [   18.582385] init: Sending signal 9 to service 'exec 14 (/system/bin/recovery-persist)' (pid 343) process group...
    [   18.593398] libprocessgroup: Successfully killed process cgroup uid 1000 pid 343 in 0ms
    [   18.606869] init: processing action (load_persist_props_action) from (/system/etc/init/hw/init.rc:458)
    [   18.617931] init: Couldn't load property file '/data/local.prop': open() failed: No such file or directory: No such file or directory
    [   18.634742] init: Wait for property 'ro.persistent_properties.ready=true' took 17ms
    [   18.643617] init: starting service 'logd-reinit'...
    [   18.660728] init: processing action (load_persist_props_action) from (/system/etc/init/flags_health_check.rc:1)
    [   18.671142] init: Top-level directory needs encryption action, eg mkdir /data/server_configurable_flags <mode> <uid> <gid> encryption=Require
    [   18.685239] logd: logd reinit
    [   18.688207] init: Verified that /data/server_configurable_flags has the encryption policy fd4fbae1f195c3a154607bb6323cf079 v2 modes 1/4 flags 0x2
    [   18.690927] logd: FrameworkListener: read() failed (Connection reset by peer)
    [   18.701726] init: Service 'logd-reinit' (pid 344) exited with status 0 oneshot service took 0.049000 seconds in background
    [   18.720158] init: Sending signal 9 to service 'logd-reinit' (pid 344) process group...
    [   18.728882] libprocessgroup: Successfully killed process cgroup uid 1036 pid 344 in 0ms
    [   18.740462] init: starting service 'exec 15 (/system/bin/flags_health_check BOOT_FAILURE)'...
    [   18.760479] init: SVC_EXEC service 'exec 15 (/system/bin/flags_health_check BOOT_FAILURE)' pid 345 (uid 1000 gid 1000+0 context default) started; waiting...
    [   18.808677] init: Service 'exec 15 (/system/bin/flags_health_check BOOT_FAILURE)' (pid 345) exited with status 0 waiting took 0.055000 seconds
    [   18.821870] init: Sending signal 9 to service 'exec 15 (/system/bin/flags_health_check BOOT_FAILURE)' (pid 345) process group...
    [   18.834407] libprocessgroup: Successfully killed process cgroup uid 1000 pid 345 in 0ms
    [   18.844537] init: processing action (load_persist_props_action) from (/system/etc/init/logcatd.rc:29)
    [   18.856035] init: processing action (load_bpf_programs) from (/system/etc/init/bpfloader.rc:17)
    [   18.868369] init: starting service 'bpfloader'...
    [   18.891107] init: SVC_EXEC service 'bpfloader' pid 346 (uid 0 gid 0+0 context default) started; waiting...
    [   19.240927] init: Service 'bpfloader' (pid 346) exited with status 0 waiting took 0.362000 seconds
    [   19.250294] init: Sending signal 9 to service 'bpfloader' (pid 346) process group...
    [   19.258804] libprocessgroup: Successfully killed process cgroup uid 0 pid 346 in 0ms
    [   19.270439] init: processing action (ro.crypto.state=encrypted && ro.crypto.type=file && zygote-start) from (/system/etc/init/hw/init.rc:980)
    [   19.283515] init: start_waiting_for_property("odsign.verification.done", "1"): already set
    [   19.293094] init: starting service 'update_verifier_nonencrypted'...
    [   19.314644] init: SVC_EXEC service 'update_verifier_nonencrypted' pid 347 (uid 0 gid 2001+1 context default) started; waiting...
    [   19.324446] sdhci-am654 fa00000.mmc: Power on failed
    [   19.365403] update_verifier: Started with arg 1: nonencrypted
    [   19.379963] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
    [   19.386731] update_verifier: Leaving update_verifier.
    [   19.396029] init: Service 'update_verifier_nonencrypted' (pid 347) exited with status 0 waiting took 0.091000 seconds
    [   19.407115] init: Sending signal 9 to service 'update_verifier_nonencrypted' (pid 347) process group...
    [   19.417188] libprocessgroup: Successfully killed process cgroup uid 0 pid 347 in 0ms
    [   19.430462] init: starting service 'statsd'...
    [   19.436523] init: Created socket '/dev/socket/statsdw', mode 222, user 1066, group 1066
    [   19.465138] init: starting service 'netd'...
    [   19.471145] init: Created socket '/dev/socket/dnsproxyd', mode 660, user 0, group 3003
    [   19.480573] init: Created socket '/dev/socket/mdns', mode 660, user 0, group 1000
    [   19.492803] init: Created socket '/dev/socket/fwmarkd', mode 660, user 0, group 3003
    [   19.514092] init: starting service 'zygote'...
    [   19.520414] init: Created socket '/dev/socket/zygote', mode 660, user 0, group 1000
    [   19.529497] init: Created socket '/dev/socket/usap_pool_primary', mode 660, user 0, group 1000
    [   19.577580] init: Command 'start zygote' action=ro.crypto.state=encrypted && ro.crypto.type=file && zygote-start (/system/etc/init/hw/init.rc:986) took 64ms and succeeded
    [   19.597454] init: starting service 'zygote_secondary'...
    [   19.604546] init: Created socket '/dev/socket/zygote_secondary', mode 660, user 0, group 1000
    [   19.614376] init: Created socket '/dev/socket/usap_pool_secondary', mode 660, user 0, group 1000
    [   19.641017] init: processing action (zygote-start) from (/vendor/etc/init/hw/init.am62x.rc:139)
    [   19.654610] init: processing action (firmware_mounts_complete) from (/system/etc/init/hw/init.rc:464)
    [   19.665085] init: processing action (early-boot) from (/vendor/etc/init/hw/init.am62x.rc:58)
    [   19.675092] init: Command 'verity_update_state' action=early-boot (/vendor/etc/init/hw/init.am62x.rc:60) took 1ms and failed: fs_mgr_load_verity_state() failed
    [   19.689814] init: processing action (early-boot) from (/system/etc/init/installd.rc:5)
    [   19.696492] ueventd: firmware: could not find firmware for ti-connectivity/wl1271-nvs.bin
    [   19.707927] ueventd: firmware: could not find firmware for am62-mcu-m4f0_0-fw
    [   19.715563] ueventd: firmware: attempted /etc/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.726471] ueventd: firmware: attempted /odm/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.728606] ueventd: firmware: attempted /etc/firmware/ti-connectivity/wl1271-nvs.bin, open failed: No such file or directory
    [   19.737283] ueventd: firmware: attempted /vendor/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.759246] ueventd: firmware: attempted /firmware/image/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.770089] ueventd: loading /devices/platform/bus@f0000/bus@f0000:bus@4000000/5000000.m4fss/remoteproc/remoteproc0/am62-mcu-m4f0_0-fw took 10166ms
    [   19.770214] remoteproc remoteproc0: powering up 5000000.m4fss
    [   19.783710] ueventd: firmware: attempted /odm/firmware/ti-connectivity/wl1271-nvs.bin, open failed: No such file or directory
    [   19.789644] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
    [   19.824682] ueventd: firmware: attempted /vendor/firmware/ti-connectivity/wl1271-nvs.bin, open failed: No such file or directory
    [   19.836464] ueventd: firmware: attempted /firmware/image/ti-connectivity/wl1271-nvs.bin, open failed: No such file or directory
    [   19.848506] ueventd: loading /devices/platform/bus@f0000/fa20000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:2/wl18xx.2.auto/firmware/ti-connectivity!wl1271-nvs.bin took 9495ms
    [   19.872801] remoteproc remoteproc0: Falling back to sysfs fallback for: am62-mcu-m4f0_0-fw
    [   19.921200] ueventd: firmware: loading 'am62-mcu-m4f0_0-fw' for '/devices/platform/bus@f0000/bus@f0000:bus@4000000/5000000.m4fss/remoteproc/remoteproc0/am62-mcu-m4f0_0-fw'
    [   19.925847] init: processing action (early-boot) from (/vendor/etc/init/init.am62x.usb.rc:1)
    [   19.947807] ueventd: firmware: could not find firmware for am62-mcu-m4f0_0-fw
    [   19.956211] ueventd: firmware: attempted /etc/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.969785] ueventd: firmware: attempted /odm/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.980574] ueventd: firmware: attempted /vendor/firmware/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   19.991612] ueventd: firmware: attempted /firmware/image/am62-mcu-m4f0_0-fw, open failed: No such file or directory
    [   20.001511] file system registered
    [   20.002749] remoteproc remoteproc0: request_firmware failed: -2
    [   20.012509] ueventd: loading /devices/platform/bus@f0000/bus@f0000:bus@4000000/5000000.m4fss/remoteproc/remoteproc0/am62-mcu-m4f0_0-fw took 91ms
    [   20.016005] using random self ethernet address
    [   20.033022] using random host ethernet address
    [   20.078184] init: starting service 'init-gadgethal-sh'...
    [   20.098209] init: processing action (ro.config.low_ram=true && boot) from (/system/etc/init/hw/init.rc:989)
    [   20.111113] init: processing action (boot) from (/system/etc/init/hw/init.rc:994)
    [   20.154865] init: starting service 'hidl_memory'...
    [   20.184686] init: starting service 'vendor.audio-hal'...
    [   20.229673] init: starting service 'vendor.camera-provider-2-4-ext'...
    [   20.261174] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [   20.275464] init: starting service 'vendor.cas-hal-1-2'...
    [   20.286632] wlcore: loaded
    [   20.302815] init: starting service 'vendor.drm-clearkey-hal-1-4'...
    [   20.310946] type=1400 audit(26.160:4): avc: denied { dac_read_search } for comm="chown" capability=2 scontext=u:r:init_gadgethal:s0 tcontext=u:r:init_gadgethal:s0 tclass=capability permissive=0
    [   20.325371] init: starting service 'health-hal-2-1'...
    [   20.333988] init: Opened file '/dev/kmsg', flags 1
    [   20.335900] ueventd: LoadWithAliases was unable to load platform:wl18xx
    [   20.341028] type=1400 audit(26.160:5): avc: denied { dac_override } for comm="chown" capability=1 scontext=u:r:init_gadgethal:s0 tcontext=u:r:init_gadgethal:s0 tclass=capability permissive=0
    [   20.351440] init: starting service 'vendor.thermal-hal-2-0-ti'...
    [   20.388099] init: starting service 'vendor.usb-hal-1-2'...
    [   20.416802] init: starting service 'vendor.memtrack-default'...
    [   20.419764] type=1400 audit(26.160:6): avc: denied { dac_read_search } for comm="chown" capability=2 scontext=u:r:init_gadgethal:s0 tcontext=u:r:init_gadgethal:s0 tclass=capability permissive=0
    [   20.451904] init: starting service 'vendor.power-default'...
    [   20.478487] init: Command 'class_start hal' action=boot (/system/etc/init/hw/init.rc:1096) took 324ms and succeeded
    [   20.500959] init: Service 'init-gadgethal-sh' (pid 360) exited with status 1 oneshot service took 0.413000 seconds in background
    [   20.517587] init: Sending signal 9 to service 'init-gadgethal-sh' (pid 360) process group...
    [   20.527166] libprocessgroup: Successfully killed process cgroup uid 0 pid 360 in 0ms
    [   20.559453] init: starting service 'pvrsrvinit'...
    [   20.572542] type=1400 audit(26.160:7): avc: denied { dac_override } for comm="chown" capability=1 scontext=u:r:init_gadgethal:s0 tcontext=u:r:init_gadgethal:s0 tclass=capability permissive=0
    [   20.588994] init: starting service 'audioserver'...
    [   20.613770] init: starting service 'credstore'...
    [   20.654380] init: starting service 'gpu'...
    [   20.657271] healthd: No battery devices found
    [   20.691464] init: Command 'class_start core' action=boot (/system/etc/init/hw/init.rc:1098) took 132ms and succeeded
    [   20.702520] init: processing action (persist.sys.usb.config=* && boot) from (/system/etc/init/hw/init.usb.rc:108)
    [   20.703001] healthd: battery l=85 v=3600 t=35.0 h=2 st=2 chg=au
    [   20.714089] init: processing action (boot) from (/vendor/etc/init/hw/init.am62x.rc:62)
    [   20.731194] init: processing action (boot) from (/system/etc/init/dumpstate.rc:1)
    [   20.753768] init: Service 'pvrsrvinit' (pid 385) exited with status 1 oneshot service took 0.177000 seconds in background
    [   20.765524] init: Sending signal 9 to service 'pvrsrvinit' (pid 385) process group...
    [   20.777006] libprocessgroup: Successfully killed process cgroup uid 0 pid 385 in 1ms
    [   20.799810] init: processing action (boot) from (/system/etc/init/gsid.rc:25)
    [   20.809308] init: starting service 'exec 16 (/system/bin/gsid run-startup-tasks)'...
    [   20.830463] init: processing action (boot) from (/vendor/etc/init/android.hardware.usb@1.2-service.generic.rc:12)
    [   20.845858] init: processing action (boot) from (/vendor/etc/init/init.am62x.usb.rc:35)
    [   20.860237] init: processing action (enable_property_trigger) from (<Builtin Action>:0)
    [   20.869375] init: processing action (apexd.status=ready && ro.product.cpu.abilist32=*) from (/system/etc/init/hw/init.rc:94)
    [   20.885803] init: starting service 'boringssl_self_test_apex32'...
    [   20.916719] init: SVC_EXEC service 'boringssl_self_test_apex32' pid 399 (uid 0 gid 0+0 context default) started; waiting...
    [   20.937337] sdhci-am654 fa00000.mmc: Power on failed
    [   20.948523] init: Service 'exec 16 (/system/bin/gsid run-startup-tasks)' (pid 396) exited with status 0 oneshot service took 0.126000 seconds in background
    [   20.967085] init: Sending signal 9 to service 'exec 16 (/system/bin/gsid run-startup-tasks)' (pid 396) process group...
    [   20.979432] libprocessgroup: Successfully killed process cgroup uid 0 pid 396 in 0ms
    [   21.029395] init: Service 'boringssl_self_test_apex32' (pid 399) exited with status 0 waiting took 0.124000 seconds
    [   21.048662] init: Sending signal 9 to service 'boringssl_self_test_apex32' (pid 399) process group...
    [   21.060934] libprocessgroup: Successfully killed process cgroup uid 0 pid 399 in 2ms
    [   21.078860] init: processing action (apexd.status=ready && ro.product.cpu.abilist64=*) from (/system/etc/init/hw/init.rc:96)
    [   21.103553] init: starting service 'boringssl_self_test_apex64'...
    [   21.153961] init: SVC_EXEC service 'boringssl_self_test_apex64' pid 402 (uid 0 gid 0+0 context default) started; waiting...
    [   21.166452] init: Command 'exec_start boringssl_self_test_apex64' action=apexd.status=ready && ro.product.cpu.abilist64=* (/system/etc/init/hw/init.rc:97) took 70ms and succeeded
    [   21.230864] init: Serv[  254.409695] sdhci-am654 fa00000.mmc: Power on failed
    ice 'boringssl_self_test_apex64' (pid 402) exited with status 0 waiting took 0.106000 seconds
    [   21.242124] init: Sending signal 9 to service 'boringssl_self_test_apex64' (pid 402) process group...
    [   21.252064] libprocessgroup: Successfully killed process cgroup uid 0 pid 402 in 0ms
    [   21.263543] init: processing action (bootreceiver.enable=1 && ro.product.cpu.abilist64=*) from (/system/etc/init/hw/init.rc:606)
    [   21.415997] init: Command 'mkdir /sys/kernel/tracing/instances/bootreceiver 0700 system system' action=bootreceiver.enable=1 && ro.product.cpu.abilist64=* (/system/etc/init/hw/init.rc:610) took 138ms and succeeded
    [   21.443650] init: processing action (net.tcp_def_init_rwnd=*) from (/system/etc/init/hw/init.rc:1159)
    [   21.454334] init: processing action (sys.init.perf_lsm_hooks=1) from (/system/etc/init/hw/init.rc:1170)
    [   21.465469] init: processing action (security.perf_harden=1) from (/system/etc/init/hw/init.rc:1184)
    [   21.479417] init: processing action (ro.debuggable=1) from (/system/etc/init/hw/init.rc:1219)
    [   21.489441] init: processing action (init.svc.audioserver=running) from (/system/etc/init/audioserver.rc:38)
    [   21.499890] init: Command 'start vendor.audio-hal-4-0-msd' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:40) took 0ms and failed: service vendor.audio-hal-4-0-msd not found
    [   21.517703] init: Command 'start audio_proxy_service' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:41) took 0ms and failed: service audio_proxy_service not found
    [   21.534613] init: Command 'start vendor.audio-hal-2-0' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:43) took 0ms and failed: service vendor.audio-hal-2-0 not found
    [   21.551684] init: Command 'start audio-hal-2-0' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:44) took 0ms and failed: service audio-hal-2-0 not found
    [   21.568216] init: processing action (ro.persistent_properties.ready=true) from (/system/etc/init/bootstat.rc:67)
    [   21.580859] init: processing action (ro.persistent_properties.ready=true) from (/system/etc/init/bootstat.rc:71)
    [   21.592407] init: starting service 'exec 17 (/system/bin/bootstat --set_system_boot_reason)'...
    [   21.611302] init: processing action (persist.heapprofd.enable= && traced.lazy.heapprofd=) from (/system/etc/init/heapprofd.rc:49)
    [   21.626764] init: processing action (ro.debuggable=1) from (/system/etc/init/llkd-debuggable.rc:1)
    [   21.638943] init: processing action (ro.debuggable=*) from (/system/etc/init/llkd.rc:2)
    [   21.649710] init: processing action (debug.atrace.user_initiated= && persist.traced.enable=1) from (/system/etc/init/perfetto.rc:47)
    [   21.662810] init: starting service 'traced_probes'...
    [   21.668487] init: Opened file '/dev/kmsg', flags 1
    [   21.703621] init: processing action (persist.traced.enable=1) from (/system/etc/init/perfetto.rc:50)
    [   21.721158] init: Service 'exec 17 (/system/bin/bootstat --set_system_boot_reason)' (pid 404) exited with status 0 oneshot service took 0.115000 seconds in background
    [   21.739689] init: Sending signal 9 to service 'exec 17 (/system/bin/bootstat --set_system_boot_reason)' (pid 404) process group...
    [   21.754989] libprocessgroup: Successfully killed process cgroup uid 1000 pid 404 in 0ms
    [   21.776546] init: starting service 'traced'...
    [   21.783327] init: Created socket '/dev/socket/traced_consumer', mode 666, user 0, group 0
    [   21.794701] init: Created socket '/dev/socket/traced_producer', mode 666, user 0, group 0
    [   21.823256] init: processing action (persist.traced_perf.enable= && sys.init.perf_lsm_hooks=1 && traced.lazy.traced_perf=) from (/system/etc/init/traced_perf.rc:43)
    [   21.850255] init: processing action (ro.boot.slot_suffix=*) from (/system/etc/init/update_engine.rc:8)
    [   21.861112] init: processing action (nonencrypted) from (/system/etc/init/hw/init.rc:1100)
    [   21.870665] init: starting service 'cameraserver'...
    [   21.893288] init: starting service 'idmap2d'...
    [   21.917093] init: starting service 'incidentd'...
    [   21.942236] init: starting service 'installd'...
    [   21.986195] init: starting service 'mediaextractor'...
    [   22.012959] init: starting service 'mediametrics'...
    [   22.037288] init: starting service 'media'...
    [   22.062810] init: starting service 'storaged'...
    [   22.069578] init: Opened file '/d/mmc0/mmc0:0001/ext_csd', flags 0
    [   22.109544] init: starting service 'wificond'...
    [   22.140801] init: starting service 'vendor.media.omx'...
    [   22.170855] init: Could not start service 'vendor_flash_recovery' as part of class 'main': Cannot find '/vendor/bin/install-recovery.sh': No such file or directory
    [   22.190763] init: starting service 'media.swcodec'...
    [   22.214067] init: Command 'class_start main' action=nonencrypted (/system/etc/init/hw/init.rc:1101) took 344ms and succeeded
    [   22.226802] init: starting service 'gatekeeperd'...
    [   22.246038] init: starting service 'update_engine'...
    [   22.296350] init: starting service 'usbd'...
    [   22.378501] init: Command 'class_start late_start' action=nonencrypted (/system/etc/init/hw/init.rc:1102) took 152ms and succeeded
    [   22.429961] init: starting service 'vendor.gatekeeper-1-0-optee'...
    [   22.455982] init: Control message: Processed ctl.interface_start for 'android.hardware.gatekeeper@1.0::IGatekeeper/default' from pid: 156 (/system/bin/hwservicemanager)
    [   22.473292] init: processing action (llk.enable=1) from (/system/etc/init/llkd.rc:9)
    [   22.483877] init: Control message: Processed ctl.interface_start for 'android.hardware.gatekeeper@1.0::IGatekeeper/default' from pid: 156 (/system/bin/hwservicemanager)
    [   22.492373] sdhci-am654 fa00000.mmc: Power on failed
    [   22.501137] init: processing action (khungtask.enable=1) from (/system/etc/init/llkd.rc:18)
    [   22.514825] init: processing action (llk.enable=0) from (/system/etc/init/llkd.rc:12)
    [   22.527279] init: processing action (khungtask.enable=0) from (/system/etc/init/llkd.rc:21)
    [   22.552590] init: starting service 'adbd'...
    [   22.597685] init: Created socket '/dev/socket/adbd', mode 660, user 1000, group 1000
    [   22.667781] init: Control message: Processed ctl.start for 'adbd' from pid: 434 (/system/bin/usbd)
    [   22.730794] init: processing action (init.svc.media=*) from (/system/etc/init/mediaserver.rc:1)
    [   22.770643] init: Service 'usbd' (pid 434) exited with status 0 oneshot service took 0.423000 seconds in background
    [   22.799384] init: Sending signal 9 to service 'usbd' (pid 434) process group...
    [   22.809757] libprocessgroup: Successfully killed process cgroup uid 0 pid 434 in 1ms
    [   22.858310] init: processing action (llk.enable=true) from (/system/etc/init/llkd.rc:34)
    [   22.898229] init: starting service 'llkd-1'...
    [   22.904047] init: Opened file '/dev/kmsg', flags 1
    [   22.909956] init: Opened file '/proc/sysrq-trigger', flags 1
    [   22.943738] init: processing action (khungtask.enable=true) from (/system/etc/init/llkd.rc:25)
    [   22.988206] init: processing action (khungtask.enable=false) from (/system/etc/init/llkd.rc:31)
    [   23.085217] read descriptors
    [   23.093858] read strings
    [   24.068405] sdhci-am654 fa00000.mmc: Power on failed
    [   25.828417] sdhci-am654 fa00000.mmc: Power on failed
    [   27.388509] sdhci-am654 fa00000.mmc: Power on failed
    [   28.939021] sdhci-am654 fa00000.mmc: Power on failed
    [   30.496743] sdhci-am654 fa00000.mmc: Power on failed
    [   32.256208] sdhci-am654 fa00000.mmc: Power on failed
    [   33.810246] sdhci-am654 fa00000.mmc: Power on failed
    [   33.890777] apexd: Can't open /system_ext/apex for reading : No such file or directory
    [   33.898994] apexd: Can't open /product/apex for reading : No such file or directory
    [   33.906855] apexd: Can't open /vendor/apex for reading : No such file or directory
    [   35.368466] sdhci-am654 fa00000.mmc: Power on failed
    [   35.683686] AidlLazyServiceRegistrar: Process has 1 (of 1 available) client(s) in use after notification apexservice has clients: 1
    [   35.695848] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   35.704333] AidlLazyServiceRegistrar: Process has 0 (of 1 available) client(s) in use after notification apexservice has clients: 0
    [   35.716360] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   36.924491] sdhci-am654 fa00000.mmc: Power on failed
    [   38.684541] sdhci-am654 fa00000.mmc: Power on failed
    [   38.783148] init: Control message: Processed ctl.start for 'idmap2d' from pid: 497 (system_server)
    [   38.887732] healthd: battery l=85 v=3600 t=35.0 h=2 st=2 chg=au
    [   39.838028] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/system/etc/init/hw/init.rc:1150)
    [   40.244482] sdhci-am654 fa00000.mmc: Power on failed
    [   41.585282] read descriptors
    [   41.588215] read strings
    [   41.595260] read descriptors
    [   41.598361] read strings
    [   41.812447] sdhci-am654 fa00000.mmc: Power on failed
    [   42.375107] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [   42.388464] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   42.436509] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   42.446310] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   43.372486] sdhci-am654 fa00000.mmc: Power on failed
    [   45.140419] sdhci-am654 fa00000.mmc: Power on failed
    [   45.683946] AidlLazyServiceRegistrar: Process has 1 (of 1 available) client(s) in use after notification apexservice has clients: 1
    [   45.703867] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   45.717497] AidlLazyServiceRegistrar: Process has 0 (of 1 available) client(s) in use after notification apexservice has clients: 0
    [   45.730462] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   46.696484] sdhci-am654 fa00000.mmc: Power on failed
    [   48.252448] sdhci-am654 fa00000.mmc: Power on failed
    [   48.854274] init: Sending signal 9 to service 'idmap2d' (pid 418) process group...
    [   48.871278] libprocessgroup: Successfully killed process cgroup uid 1000 pid 418 in 7ms
    [   48.888322] init: Control message: Processed ctl.stop for 'idmap2d' from pid: 497 (system_server)
    [   48.899366] init: Service 'idmap2d' (pid 418) received signal 9
    [   49.808521] sdhci-am654 fa00000.mmc: Power on failed
    [   51.580463] sdhci-am654 fa00000.mmc: Power on failed
    [   51.934113] init: Service 'bootanim' (pid 183) exited with status 0 oneshot service took 39.355000 seconds in background
    [   51.946444] init: Sending signal 9 to service 'bootanim' (pid 183) process group...
    [   51.956032] libprocessgroup: Successfully killed process cgroup uid 1003 pid 183 in 0ms
    [   52.352850] init: processing action (sys.boot_completed=1) from (/system/etc/init/hw/init.rc:1141)
    [   52.370334] init: starting service 'exec 18 (/bin/rm -rf /data/per_boot)'...
    [   52.450931] init: SVC_EXEC service 'exec 18 (/bin/rm -rf /data/per_boot)' pid 1055 (uid 1000 gid 1000+0 context default) started; waiting...
    [   52.466126] init: Command 'exec - system system -- /bin/rm -rf /data/per_boot' action=sys.boot_completed=1 (/system/etc/init/hw/init.rc:1144) took 97ms and succeeded
    [   52.533209] init: Service 'exec 18 (/bin/rm -rf /data/per_boot)' (pid 1055) exited with status 0 waiting took 0.141000 seconds
    [   52.538252] selinux: SELinux: Skipping restorecon on directory(/data/system_ce/0)
    [   52.554818] init: Sending signal 9 to service 'exec 18 (/bin/rm -rf /data/per_boot)' (pid 1055) process group...
    [   52.555524] selinux:
    [   52.581828] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1055 in 0ms
    [   52.584443] selinux: SELinux: Skipping restorecon on directory(/data/vendor_ce/0)
    [   52.598024] selinux:
    [   52.611271] selinux: SELinux: Skipping restorecon on directory(/data/misc_ce/0)
    [   52.615945] init: Encryption policy of /data/per_boot set to fdc47329de0d554aa886a04543e611bb v2 modes 1/4 flags 0x2
    [   52.618876] selinux:
    [   52.659049] init: Command 'mkdir /data/per_boot 0700 system system encryption=Require key=per_boot_ref' action=sys.boot_completed=1 (/system/etc/init/hw/init.rc:1145) took 60ms and succeeded
    [   52.677845] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.am62x.rc:100)
    [   52.849537] zram: setup backing device /dev/block/loop26
    [   52.855254] init: [libfs_mgr]Success to set /dev/block/loop26 to /sys/block/zram0/backing_dev
    [   52.868455] zram0: detected capacity change from 0 to 314572800
    [   52.944889] mkswap: Swapspace size: 307196k, UUID=7ec9ef1e-8a7b-4095-86eb-55558f28aa09
    [   52.980894] Adding 307196k swap on /dev/block/zram0.  Priority:-2 extents:1 across:307196k SS
    [   52.991986] init: Command 'swapon_all /vendor/etc/fstab.${ro.hardware}' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.am62x.rc:110) took 296ms and succeeded
    [   53.067620] init: processing action (sys.boot_completed=1 && sys.bootstat.first_boot_completed=0) from (/system/etc/init/bootstat.rc:77)
    [   53.083350] init: starting service 'exec 19 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
    [   53.141520] sdhci-am654 fa00000.mmc: Power on failed
    [   53.206721] init: Command 'exec_background - system log -- /system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l' action=sys.boot_completed=1 && sys.bootstat.first_boot_completed=0 (/system/etc/init/bootstat.rc:82) took 125ms and succeeded
    [   53.256145] init: processing action (sys.boot_completed=1) from (/system/etc/init/flags_health_check.rc:7)
    [   53.288433] init: processing action (sys.boot_completed=1) from (/system/etc/init/logd.rc:33)
    [   53.305833] init: starting service 'logd-auditctl'...
    [   53.361429] init: Command 'start logd-auditctl' action=sys.boot_completed=1 (/system/etc/init/logd.rc:34) took 55ms and succeeded
    [   53.384054] init: Service 'exec 19 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)' (pid 1081) exited with status 0 oneshot service took 0.254000 seconds in background
    [   53.421075] init: Sending signal 9 to service 'exec 19 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)' (pid 1081) process group...
    [   53.448253] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1081 in 4ms
    [   53.465234] init: Service 'logd-auditctl' (pid 1083) exited with status 0 oneshot service took 0.135000 seconds in background
    [   53.478307] init: Sending signal 9 to service 'logd-auditctl' (pid 1083) process group...
    [   53.495379] libprocessgroup: Successfully killed process cgroup uid 1036 pid 1083 in 1ms
    [   53.540981] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi.rc:28)
    [   54.067185] init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi.rc:30) took 478ms and succeeded
    [   54.340964] init: Command 'write /sys/kernel/debug/tracing/instances/wifi/events/net/filter name==${wifi.interface:-wlan0}' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi.rc:69) took 71ms and succeeded
    [   54.411079] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/init.am62x.zygote_wakelock.rc:8)
      255.964893] sdhci-am654 fa00000.mmc: Power on failed
    32m[   54.436057] init: Command 'write /sys/power/wake_unlock zygote_kwl' action=sys.boot_completed=1 (/vendor/etc/init/init.am62x.zygote_wakelock.rc:9) took 12ms and failed: Unable to write to file '/sys/power/wake_unlock': Unable to write file contents: Invalid argument
    [   54.470941] init: processing action (sys.user.0.ce_available=true) from (/system/etc/init/wifi.rc:21)
    [   54.509844] selinux: SELinux: Skipping restorecon on directory(/data/misc_ce/0/apexdata/com.android.wifi)
    [   54.523077] selinux:
    [   54.542540] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=1) from (/vendor/etc/init/hw/init.am62x.rc:133)
    [   54.642767] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=1 && wifi.interface=*) from (/system/etc/init/wifi.rc:98)
    [   54.738920] sdhci-am654 fa00000.mmc: Power on failed
    [   54.809550] init: Command 'write /sys/kernel/debug/tracing/instances/wifi/events/net/filter name==${wifi.interface}' action=sys.boot_completed=1 && sys.wifitracing.started=1 && wifi.interface=* (/system/etc/init/wifi.rc:100) took 100ms and succeeded
    [   54.921375] init: Command 'write /sys/kernel/tracing/instances/wifi/events/net/filter name==${wifi.interface}' action=sys.boot_completed=1 && sys.wifitracing.started=1 && wifi.interface=* (/system/etc/init/wifi.rc:101) took 65ms and succeeded
    [   55.548667] alloc_contig_range: [dd884, dd887) PFNs busy
    [   55.691510] AidlLazyServiceRegistrar: Process has 1 (of 1 available) client(s) in use after notification apexservice has clients: 1
    [   55.730832] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   55.753187] AidlLazyServiceRegistrar: Process has 0 (of 1 available) client(s) in use after notification apexservice has clients: 0
    [   55.772077] AidlLazyServiceRegistrar: Shutdown prevented by forcePersist override flag.
    [   56.340495] sdhci-am654 fa00000.mmc: Power on failed
    [   58.116704] sdhci-am654 fa00000.mmc: Power on failed
    [   59.756901] sdhci-am654 fa00000.mmc: Power on failed
    [   61.348416] sdhci-am654 fa00000.mmc: Power on failed
    [   62.900393] sdhci-am654 fa00000.mmc: Power on failed
    [   64.666471] sdhci-am654 fa00000.mmc: Power on failed
    [   66.222363] sdhci-am654 fa00000.mmc: Power on failed
    [   67.786444] sdhci-am654 fa00000.mmc: Power on failed
    [   69.342430] sdhci-am654 fa00000.mmc: Power on failed
    [   71.107380] sdhci-am654 fa00000.mmc: Power on failed
    [   72.661018] sdhci-am654 fa00000.mmc: Power on failed
    [   74.217493] sdhci-am654 fa00000.mmc: Power on failed
    [   75.777030] sdhci-am654 fa00000.mmc: Power on failed
    [   76.389880] AidlLazyServiceRegistrar: Trying to shut down the service. No clients in use for any service in process.
    [   76.401565] AidlLazyServiceRegistrar: Unregistered all clients and exiting
    [   76.414184] init: Service 'apexd' (pid 251) exited with status 0 oneshot service took 62.213001 seconds in background
    [   76.424948] init: Sending signal 9 to service 'apexd' (pid 251) process group...
    [   76.432973] libprocessgroup: Successfully killed process cgroup uid 0 pid 251 in 0ms
    [   77.542474] sdhci-am654 fa00000.mmc: Power on failed
    [   79.097333] sdhci-am654 fa00000.mmc: Power on failed
    [   80.654528] sdhci-am654 fa00000.mmc: Power on failed
    [   82.216517] sdhci-am654 fa00000.mmc: Power on failed
    [   83.977191] sdhci-am654 fa00000.mmc: Power on failed
    [   85.532453] sdhci-am654 fa00000.mmc: Power on failed
    [   87.087328] sdhci-am654 fa00000.mmc: Power on failed
    [   88.640479] sdhci-am654 fa00000.mmc: Power on failed
    [   90.402597] sdhci-am654 fa00000.mmc: Power on failed
    [   91.957164] sdhci-am654 fa00000.mmc: Power on failed
    [   93.516459] sdhci-am654 fa00000.mmc: Power on failed
    [   95.070331] sdhci-am654 fa00000.mmc: Power on failed
    [   96.826888] sdhci-am654 fa00000.mmc: Power on failed
    [   98.382514] sdhci-am654 fa00000.mmc: Power on failed
    [   99.935177] sdhci-am654 fa00000.mmc: Power on failed
    [  101.496327] sdhci-am654 fa00000.mmc: Power on failed
    [  103.252311] sdhci-am654 fa00000.mmc: Power on failed
    [  104.810402] sdhci-am654 fa00000.mmc: Power on failed
    [  106.364487] sdhci-am654 fa00000.mmc: Power on failed
    [  107.926593] sdhci-am654 fa00000.mmc: Power on failed
    [  109.684832] sdhci-am654 fa00000.mmc: Power on failed
    [  111.236335] sdhci-am654 fa00000.mmc: Power on failed
    [  112.795232] sdhci-am654 fa00000.mmc: Power on failed
    [  114.354465] sdhci-am654 fa00000.mmc: Power on failed
    [  116.114455] sdhci-am654 fa00000.mmc: Power on failed
    [  117.672604] sdhci-am654 fa00000.mmc: Power on failed
    [  119.227526] sdhci-am654 fa00000.mmc: Power on failed
    [  120.788385] sdhci-am654 fa00000.mmc: Power on failed
    [  121.980341] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd
    [  122.238284] usb 1-1.2: New USB device found, idVendor=0c45, idProduct=636b, bcdDevice= 1.00
    [  122.246649] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
    [  122.253949] usb 1-1.2: Product: USB 2.0 Camera
    [  122.258404] usb 1-1.2: Manufacturer: Sonix Technology Co., Ltd.
    [  122.264321] usb 1-1.2: SerialNumber: SN0001
    [  122.337323] ueventd: Loading module /vendor/lib/modules/uvcvideo.ko with args ''
    [  122.354447] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:636b)
    [  122.383778] input: USB 2.0 Camera: USB Camera as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2:1.0/input/input1
    [  122.402170] usbcore: registered new interface driver uvcvideo
    [  122.408159] USB Video Class driver (1.1.1)
    [  122.413524] ueventd: Loaded kernel module /vendor/lib/modules/uvcvideo.ko
    [  122.427184] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc02ip00in01
    [  122.448169] ueventd: Loading module /vendor/lib/modules/snd-usbmidi-lib.ko with args ''
    [  122.463054] ueventd: Loaded kernel module /vendor/lib/modules/snd-usbmidi-lib.ko
    [  122.474656] ueventd: Loading module /vendor/lib/modules/snd-hwdep.ko with args ''
    [  122.486398] ueventd: Loaded kernel module /vendor/lib/modules/snd-hwdep.ko
    [  122.493937] ueventd: Loading module /vendor/lib/modules/snd-usb-audio.ko with args ''
    [  122.525338] usb 1-1.2: 3:1: cannot get freq at ep 0x84
    [  122.549555] sdhci-am654 fa00000.mmc: Power on failed
    [  122.570446] usbcore: registered new interface driver snd-usb-audio
    [  122.578038] ueventd: Loaded kernel module /vendor/lib/modules/snd-usb-audio.ko
    [  122.598401] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic01isc02ip00in03
    [  122.625000] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc02ip00in01
    [  122.690065] ueventd: LoadWithAliases was unable to load input:b0003v0C45p636Be0100-e0,1,kD4,ramlsfw
    [  122.717818] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc01ip00in00
    [  122.757259] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic01isc02ip00in03
    [  122.824696] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic01isc01ip00in02
    [  124.114491] sdhci-am654 fa00000.mmc: Power on failed
    [  125.668369] sdhci-am654 fa00000.mmc: Power on failed
    [  126.520890] usb 1-1.2: USB disconnect, device number 4
    [  126.543657] ueventd: LoadWithAliases was unable to load input:b0003v0C45p636Be0100-e0,1,kD4,ramlsfw
    [  126.557213] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc01ip00in00
    [  126.569970] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc02ip00in01
    [  126.584543] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic01isc01ip00in02
    [  126.597014] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic01isc02ip00in03
    [  127.220337] sdhci-am654 fa00000.mmc: Power on failed
    [  128.980492] sdhci-am654 fa00000.mmc: Power on failed
    [  130.536630] sdhci-am654 fa00000.mmc: Power on failed
    [  132.094428] sdhci-am654 fa00000.mmc: Power on failed
    [  133.647975] sdhci-am654 fa00000.mmc: Power on failed
    [  135.407714] sdhci-am654 fa00000.mmc: Power on failed
    [  136.967399] sdhci-am654 fa00000.mmc: Power on failed
    [  138.521262] sdhci-am654 fa00000.mmc: Power on failed
    [  140.074420] sdhci-am654 fa00000.mmc: Power on failed
    [  141.836360] sdhci-am654 fa00000.mmc: Power on failed
    [  143.397699] sdhci-am654 fa00000.mmc: Power on failed
    [  144.957169] sdhci-am654 fa00000.mmc: Power on failed
    [  146.517815] sdhci-am654 fa00000.mmc: Power on failed
    [  148.284664] sdhci-am654 fa00000.mmc: Power on failed
    [  149.844575] sdhci-am654 fa00000.mmc: Power on failed
    [  151.402405] sdhci-am654 fa00000.mmc: Power on failed
    [  152.957176] sdhci-am654 fa00000.mmc: Power on failed
    [  154.722653] sdhci-am654 fa00000.mmc: Power on failed
    [  156.274687] sdhci-am654 fa00000.mmc: Power on failed
    [  157.832326] sdhci-am654 fa00000.mmc: Power on failed
    [  159.387671] sdhci-am654 fa00000.mmc: Power on failed
    [  161.147384] sdhci-am654 fa00000.mmc: Power on failed
    [  162.702915] sdhci-am654 fa00000.mmc: Power on failed
    [  164.264621] sdhci-am654 fa00000.mmc: Power on failed
    [  165.816428] sdhci-am654 fa00000.mmc: Power on failed
    [  167.292317] usb 1-1.2: new high-speed USB device number 5 using xhci-hcd
    [  167.550744] usb 1-1.2: New USB device found, idVendor=0c45, idProduct=636b, bcdDevice= 1.00
    [  167.559222] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
    [  167.566580] usb 1-1.2: Product: USB 2.0 Camera
    [  167.571048] usb 1-1.2: Manufacturer: Sonix Technology Co., Ltd.
    [  167.576980] usb 1-1.2: SerialNumber: SN0001
    [  167.581207] sdhci-am654 fa00000.mmc: Power on failed
    [  167.642797] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:636b)
    [  167.647904] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc01ip00in00
    [  167.663897] input: USB 2.0 Camera: USB Camera as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
    [  167.681422] ueventd: LoadWithAliases was unable to load input:b0003v0C45p636Be0100-e0,1,kD4,ramlsfw
    [  167.700434] ueventd: LoadWithAliases was unable to load usb:v0C45p636Bd0100dcEFdsc02dp01ic0Eisc01ip00in00
    [  167.709049] usb 1-1.2: 3:1: cannot get freq at ep 0x84
    Sonia
    The dmesg logs show that the camera is detected, but then gets disconnected because of "cannot get freq at ep 0x84":
    I suspect that the webcam might not get enough power supplied through the USB A port.
    Would it be possible to:
    1. Make sure the EVM has both USB-C cable for data and a dedicated power supply plugged
    2. Use a powered USB hub plugged on the USB A port, and connect the webcam on the USB hub.
    Please send the output of
    su
    dumpsys media.camera
    su
    dmesg
    After trying the above.
  • Hello Mattijs,
    Yes I am doing the same as you mentioned above
    Sonia
  • Hi Sonia,
    Is there a reason why the latest Android SDK is not picked up (SDK 9.2 - Android 14)?
    Vishal
