PROCESSOR-SDK-J784S4: TIOVX failing as not found "stdint.h"
Part Number: PROCESSOR-SDK-J784S4
Similar to the issue read for SDKJ784S4, I see error compiling TIOVX in SDK 9.01.00.06 for J721e.
After running setup_psdk_rtos.sh with no errors, and doing make in Tiovx, I receive an error :
But this file is present in compiler:
It seems some path configurations are failing, but  I don't know. Could you indicate how to solve it?
BR.
  • I have solved it.
    The problem was not having targetFs folder and I did not have it because I execute
    ./sdk_builder/scripts/setup_psdk_rtos.sh
    from ${PSDKR_PATH} as is required
    After executing correctly, make for tiovx does not fail
    BR
