Part Number: SK-AM62P-LP
I've bee following this procedure https://software-dl.ti.com/processor-sdk-android/esd/AM62PX/09_01_00/docs/android/Overview_Building_the_SDK.html to build a custom SDK for android.
I've chenged some things on Defconfig/menuconfig, and then when i tried to rebuild my kernel i got some error as shown bellow.
tools/bazel run --config=fast //common:ti_dist -- --dist_dir=$DIST_DIR
INFO: Analyzed target //common:ti_dist (0 packages loaded, 0 targets configured).
INFO: Found 1 target...
ERROR: /home/bsp/builder/09_01_00/ti-kernel-aosp/common/BUILD.bazel:705:13: Building kernel (lto=fast;notrim) @//common:ti failed: (Exit 1): bash failed: error executing KernelBuild command (from target //common:ti) /bin/bash -c ... (remaining 1 argument skipped)
/home/bsp/builder/09_01_00/ti-kernel-aosp/common/arch/arm64/boot/dts/ti/k3-am62x-sk-csi2-ov5640.dtso:57.13-66.3: Warning (graph_port): /fragment@2/__overlay__: graph port node name should be 'port'
/home/bsp/builder/09_01_00/ti-kernel-aosp/common/arch/arm64/boot/dts/ti/k3-am62x-sk-csi2-tevi-ov5640.dtso:57.13-66.3: Warning (graph_port): /fragment@2/__overlay__: graph port node name should be 'port'
/home/bsp/builder/09_01_00/ti-kernel-aosp/common/arch/arm64/boot/dts/ti/k3-am625-beagleplay-csi2-ov5640.dtso:52.13-61.3: Warning (graph_port): /fragment@3/__overlay__: graph port node name should be 'port'
/home/bsp/builder/09_01_00/ti-kernel-aosp/common/arch/arm64/boot/dts/ti/k3-am625-beagleplay-csi2-tevi-ov5640.dtso:52.13-61.3: Warning (graph_port): /fragment@3/__overlay__: graph port node name should be 'port'
ERROR: Unable to find lib/crypto/libarc4.ko in any of the following directories:
bazel-out/k8-fastbuild/bin/common/ti/staging/lib/modules/6.1.43-android14-11-maybe-dirty/kernel
Unable to find net/rfkill/rfkill.ko in any of the following directories:
Unable to find net/mac80211/mac80211.ko in any of the following directories:
Unable to find net/wireless/cfg80211.ko in any of the following directories:
Unable to find lib/math/cordic.ko in any of the following directories:
Unable to find drivers/net/wireless/broadcom/b43/b43.ko in any of the following directories:
Unable to find drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko in any of the following directories:
Unable to find drivers/bcma/bcma.ko in any of the following directories:
Unable to find drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko in any of the following directories:
Unable to find drivers/ssb/ssb.ko in any of the following directories:
Target //common:ti_dist failed to build
Use --verbose_failures to see the command lines of failed build steps.
ERROR: /home/bsp/builder/09_01_00/ti-kernel-aosp/common/BUILD.bazel:947:17 Middleman _middlemen/common_Sti_Udist-runfiles failed: (Exit 1): bash failed: error executing KernelBuild command (from target //common:ti) /bin/bash -c ... (remaining 1 argument skipped)
INFO: Elapsed time: 795.590s, Critical Path: 794.35s
INFO: 2 processes: 2 internal.
ERROR: Build did NOT complete successfully
ERROR: Build failed. Not running target
My ti_gki_defconfig is the following
CONFIG_UAPI_HEADER_TEST=y CONFIG_AUDIT=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_BPF_SYSCALL=y CONFIG_BPF_JIT=y CONFIG_BPF_JIT_ALWAYS_ON=y # CONFIG_BPF_UNPRIV_DEFAULT_OFF is not set CONFIG_PREEMPT=y CONFIG_IRQ_TIME_ACCOUNTING=y CONFIG_TASKSTATS=y CONFIG_TASK_XACCT=y CONFIG_TASK_IO_ACCOUNTING=y CONFIG_PSI=y CONFIG_RCU_EXPERT=y CONFIG_RCU_BOOST=y CONFIG_RCU_NOCB_CPU=y CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_IKHEADERS=m CONFIG_UCLAMP_TASK=y CONFIG_UCLAMP_BUCKETS_COUNT=20 CONFIG_CGROUPS=y CONFIG_MEMCG=y CONFIG_BLK_CGROUP=y CONFIG_CGROUP_SCHED=y CONFIG_UCLAMP_TASK_GROUP=y CONFIG_CGROUP_FREEZER=y CONFIG_CPUSETS=y CONFIG_CGROUP_CPUACCT=y CONFIG_CGROUP_BPF=y CONFIG_NAMESPACES=y # CONFIG_PID_NS is not set CONFIG_RT_SOFTIRQ_AWARE_SCHED=y # CONFIG_RD_BZIP2 is not set # CONFIG_RD_LZMA is not set # CONFIG_RD_XZ is not set # CONFIG_RD_LZO is not set CONFIG_BOOT_CONFIG=y # CONFIG_SYSFS_SYSCALL is not set # CONFIG_FHANDLE is not set CONFIG_KALLSYMS_ALL=y # CONFIG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_PROFILING=y CONFIG_ARCH_SUNXI=y CONFIG_ARCH_K3=y CONFIG_ARCH_HISI=y CONFIG_ARCH_QCOM=y CONFIG_SCHED_MC=y CONFIG_NR_CPUS=32 CONFIG_PARAVIRT_TIME_ACCOUNTING=y CONFIG_ARM64_SW_TTBR0_PAN=y CONFIG_COMPAT=y CONFIG_ARMV8_DEPRECATED=y CONFIG_SWP_EMULATION=y CONFIG_CP15_BARRIER_EMULATION=y CONFIG_SETEND_EMULATION=y # CONFIG_ARM64_BTI_KERNEL is not set CONFIG_RANDOMIZE_BASE=y # CONFIG_RANDOMIZE_MODULE_REGION_FULL is not set CONFIG_UNWIND_PATCH_PAC_INTO_SCS=y CONFIG_CMDLINE="console=ttynull stack_depot_disable=on cgroup_disable=pressure kasan.page_alloc.sample=10 kasan.stacktrace=off kvm-arm.mode=protected bootconfig ioremap_guard" CONFIG_CMDLINE_EXTEND=y # CONFIG_DMI is not set CONFIG_HIBERNATION=y CONFIG_PM_WAKELOCKS=y CONFIG_PM_WAKELOCKS_LIMIT=0 # CONFIG_PM_WAKELOCKS_GC is not set CONFIG_ENERGY_MODEL=y CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_GOV_MENU=y CONFIG_CPU_IDLE_GOV_TEO=y CONFIG_ARM_PSCI_CPUIDLE=y CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_STAT=y CONFIG_CPU_FREQ_TIMES=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y CONFIG_ARM_SCPI_CPUFREQ=y CONFIG_ARM_SCMI_CPUFREQ=y CONFIG_VIRTUALIZATION=y CONFIG_KVM=y CONFIG_PKVM_MODULE_PATH="/lib/modules/" CONFIG_KPROBES=y CONFIG_JUMP_LABEL=y CONFIG_SHADOW_CALL_STACK=y CONFIG_CFI_CLANG=y CONFIG_MODULES=y CONFIG_MODULE_UNLOAD=y CONFIG_MODVERSIONS=y CONFIG_MODULE_SCMVERSION=y CONFIG_MODULE_SIG=y CONFIG_MODULE_SIG_PROTECT=y CONFIG_MODPROBE_PATH="/system/bin/modprobe" CONFIG_BLK_DEV_ZONED=y CONFIG_BLK_DEV_THROTTLING=y CONFIG_BLK_CGROUP_IOCOST=y CONFIG_BLK_CGROUP_IOPRIO=y CONFIG_BLK_INLINE_ENCRYPTION=y CONFIG_BLK_INLINE_ENCRYPTION_FALLBACK=y CONFIG_IOSCHED_BFQ=y CONFIG_BFQ_GROUP_IOSCHED=y CONFIG_GKI_HACKS_TO_FIX=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_BINFMT_MISC=y # CONFIG_SLAB_MERGE_DEFAULT is not set CONFIG_SLAB_FREELIST_RANDOM=y CONFIG_SLAB_FREELIST_HARDENED=y CONFIG_SHUFFLE_PAGE_ALLOCATOR=y # CONFIG_COMPAT_BRK is not set CONFIG_MEMORY_HOTPLUG=y CONFIG_MEMORY_HOTREMOVE=y CONFIG_DEFAULT_MMAP_MIN_ADDR=32768 CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y CONFIG_CLEANCACHE=y CONFIG_CMA=y CONFIG_CMA_DEBUGFS=y CONFIG_CMA_AREAS=32 # CONFIG_ZONE_DMA is not set CONFIG_ZONE_DEVICE=y CONFIG_ANON_VMA_NAME=y CONFIG_USERFAULTFD=y CONFIG_LRU_GEN=y CONFIG_LRU_GEN_ENABLED=y CONFIG_NET=y CONFIG_PACKET=y CONFIG_UNIX=y CONFIG_XFRM_USER=y CONFIG_XFRM_INTERFACE=y CONFIG_XFRM_MIGRATE=y CONFIG_XFRM_STATISTICS=y CONFIG_NET_KEY=y CONFIG_XDP_SOCKETS=y CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y CONFIG_IP_MULTIPLE_TABLES=y CONFIG_NET_IPIP=y CONFIG_NET_IPGRE_DEMUX=y CONFIG_NET_IPGRE=y CONFIG_NET_IPVTI=y CONFIG_NET_RFKILL=y #CONFIG_NET_MAC80211=y CONFIG_INET_ESP=y CONFIG_INET_UDP_DIAG=y CONFIG_INET_DIAG_DESTROY=y CONFIG_IPV6_ROUTER_PREF=y CONFIG_IPV6_ROUTE_INFO=y CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_ESP=y CONFIG_INET6_IPCOMP=y CONFIG_IPV6_MIP6=y CONFIG_IPV6_VTI=y CONFIG_IPV6_GRE=y CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_IPV6_MROUTE=y CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y CONFIG_NETFILTER=y CONFIG_NF_CONNTRACK=y CONFIG_NF_CONNTRACK_SECMARK=y CONFIG_NF_CONNTRACK_PROCFS=y CONFIG_NF_CONNTRACK_EVENTS=y CONFIG_NF_CONNTRACK_AMANDA=y CONFIG_NF_CONNTRACK_FTP=y CONFIG_NF_CONNTRACK_H323=y CONFIG_NF_CONNTRACK_IRC=y CONFIG_NF_CONNTRACK_NETBIOS_NS=y CONFIG_NF_CONNTRACK_PPTP=y CONFIG_NF_CONNTRACK_SANE=y CONFIG_NF_CONNTRACK_TFTP=y CONFIG_NF_CT_NETLINK=y CONFIG_NETFILTER_XT_TARGET_CLASSIFY=y CONFIG_NETFILTER_XT_TARGET_CONNMARK=y CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=y CONFIG_NETFILTER_XT_TARGET_DSCP=y CONFIG_NETFILTER_XT_TARGET_IDLETIMER=y CONFIG_NETFILTER_XT_TARGET_MARK=y CONFIG_NETFILTER_XT_TARGET_NFLOG=y CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y CONFIG_NETFILTER_XT_TARGET_NOTRACK=y CONFIG_NETFILTER_XT_TARGET_TEE=y CONFIG_NETFILTER_XT_TARGET_TPROXY=y CONFIG_NETFILTER_XT_TARGET_TRACE=y CONFIG_NETFILTER_XT_TARGET_SECMARK=y CONFIG_NETFILTER_XT_TARGET_TCPMSS=y CONFIG_NETFILTER_XT_MATCH_BPF=y CONFIG_NETFILTER_XT_MATCH_COMMENT=y CONFIG_NETFILTER_XT_MATCH_CONNBYTES=y CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=y CONFIG_NETFILTER_XT_MATCH_CONNMARK=y CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y CONFIG_NETFILTER_XT_MATCH_DSCP=y CONFIG_NETFILTER_XT_MATCH_ESP=y CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=y CONFIG_NETFILTER_XT_MATCH_HELPER=y CONFIG_NETFILTER_XT_MATCH_IPRANGE=y CONFIG_NETFILTER_XT_MATCH_L2TP=y CONFIG_NETFILTER_XT_MATCH_LENGTH=y CONFIG_NETFILTER_XT_MATCH_LIMIT=y CONFIG_NETFILTER_XT_MATCH_MAC=y CONFIG_NETFILTER_XT_MATCH_MARK=y CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y CONFIG_NETFILTER_XT_MATCH_OWNER=y CONFIG_NETFILTER_XT_MATCH_POLICY=y CONFIG_NETFILTER_XT_MATCH_PKTTYPE=y CONFIG_NETFILTER_XT_MATCH_QUOTA=y CONFIG_NETFILTER_XT_MATCH_QUOTA2=y CONFIG_NETFILTER_XT_MATCH_QUOTA2_LOG=y CONFIG_NETFILTER_XT_MATCH_SOCKET=y CONFIG_NETFILTER_XT_MATCH_STATE=y CONFIG_NETFILTER_XT_MATCH_STATISTIC=y CONFIG_NETFILTER_XT_MATCH_STRING=y CONFIG_NETFILTER_XT_MATCH_TIME=y CONFIG_NETFILTER_XT_MATCH_U32=y CONFIG_IP_NF_IPTABLES=y CONFIG_IP_NF_MATCH_ECN=y CONFIG_IP_NF_MATCH_TTL=y CONFIG_IP_NF_FILTER=y CONFIG_IP_NF_TARGET_REJECT=y CONFIG_IP_NF_NAT=y CONFIG_IP_NF_TARGET_MASQUERADE=y CONFIG_IP_NF_TARGET_NETMAP=y CONFIG_IP_NF_TARGET_REDIRECT=y CONFIG_IP_NF_MANGLE=y CONFIG_IP_NF_RAW=y CONFIG_IP_NF_SECURITY=y CONFIG_IP_NF_ARPTABLES=y CONFIG_IP_NF_ARPFILTER=y CONFIG_IP_NF_ARP_MANGLE=y CONFIG_IP6_NF_IPTABLES=y CONFIG_IP6_NF_MATCH_RPFILTER=y CONFIG_IP6_NF_FILTER=y CONFIG_IP6_NF_TARGET_REJECT=y CONFIG_IP6_NF_MANGLE=y CONFIG_IP6_NF_RAW=y CONFIG_TIPC=m CONFIG_L2TP=m CONFIG_BRIDGE=y CONFIG_VLAN_8021Q=m CONFIG_6LOWPAN=m CONFIG_IEEE802154=m CONFIG_IEEE802154_6LOWPAN=m CONFIG_MAC802154=m CONFIG_NET_SCHED=y CONFIG_NET_SCH_HTB=y CONFIG_NET_SCH_PRIO=y CONFIG_NET_SCH_MULTIQ=y CONFIG_NET_SCH_SFQ=y CONFIG_NET_SCH_TBF=y CONFIG_NET_SCH_NETEM=y CONFIG_NET_SCH_CODEL=y CONFIG_NET_SCH_FQ_CODEL=y CONFIG_NET_SCH_FQ=y CONFIG_NET_SCH_INGRESS=y CONFIG_NET_CLS_BASIC=y CONFIG_NET_CLS_FW=y CONFIG_NET_CLS_U32=y CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_FLOW=y CONFIG_NET_CLS_BPF=y CONFIG_NET_CLS_MATCHALL=y CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_CMP=y CONFIG_NET_EMATCH_NBYTE=y CONFIG_NET_EMATCH_U32=y CONFIG_NET_EMATCH_META=y CONFIG_NET_EMATCH_TEXT=y CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=y CONFIG_NET_ACT_GACT=y CONFIG_NET_ACT_MIRRED=y CONFIG_NET_ACT_SKBEDIT=y CONFIG_NET_ACT_BPF=y CONFIG_VSOCKETS=y CONFIG_CGROUP_NET_PRIO=y CONFIG_CAN=m CONFIG_BT=m CONFIG_BT_RFCOMM=m CONFIG_BT_RFCOMM_TTY=y CONFIG_BT_HIDP=m CONFIG_BT_HCIBTSDIO=m CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_LL=y CONFIG_BT_HCIUART_BCM=y CONFIG_BT_HCIUART_QCA=y CONFIG_NFC=m CONFIG_PCI=y CONFIG_PCIEPORTBUS=y CONFIG_PCIEAER=y CONFIG_PCI_IOV=y # CONFIG_VGA_ARB is not set CONFIG_PCI_HOST_GENERIC=y CONFIG_PCIE_DW_PLAT_EP=y CONFIG_PCIE_QCOM=y CONFIG_PCIE_KIRIN=y CONFIG_PCI_ENDPOINT=y CONFIG_FW_LOADER_USER_HELPER=y # CONFIG_FW_CACHE is not set # CONFIG_SUN50I_DE2_BUS is not set # CONFIG_SUNXI_RSB is not set CONFIG_ARM_SCMI_PROTOCOL=y # CONFIG_ARM_SCMI_POWER_DOMAIN is not set CONFIG_ARM_SCPI_PROTOCOL=y # CONFIG_ARM_SCPI_POWER_DOMAIN is not set # CONFIG_EFI_ARMSTUB_DTB_LOADER is not set CONFIG_GNSS=y CONFIG_ZRAM=m CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=16 CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_SIZE=8192 CONFIG_BLK_DEV_UBLK=y CONFIG_BLK_DEV_NVME=y CONFIG_SRAM=y CONFIG_UID_SYS_STATS=y CONFIG_SCSI=y # CONFIG_SCSI_PROC_FS is not set CONFIG_BLK_DEV_SD=y CONFIG_MD=y CONFIG_BLK_DEV_DM=y CONFIG_DM_CRYPT=y CONFIG_DM_DEFAULT_KEY=y CONFIG_DM_SNAPSHOT=y CONFIG_DM_UEVENT=y CONFIG_DM_VERITY=y CONFIG_DM_VERITY_FEC=y CONFIG_NETDEVICES=y CONFIG_DUMMY=y CONFIG_WIREGUARD=y CONFIG_IFB=y CONFIG_MACSEC=y CONFIG_TUN=y CONFIG_VETH=y CONFIG_LED_TRIGGER_PHY=y CONFIG_AX88796B_PHY=y CONFIG_CAN_VCAN=m CONFIG_CAN_SLCAN=m CONFIG_PPP=m CONFIG_PPP_BSDCOMP=m CONFIG_PPP_DEFLATE=m CONFIG_PPP_MPPE=m CONFIG_PPTP=m CONFIG_PPPOL2TP=m CONFIG_USB_NET_DRIVERS=m CONFIG_USB_RTL8150=m CONFIG_USB_RTL8152=m CONFIG_USB_USBNET=m CONFIG_USB_NET_CDC_EEM=m # CONFIG_USB_NET_NET1080 is not set # CONFIG_USB_NET_CDC_SUBSET is not set # CONFIG_USB_NET_ZAURUS is not set CONFIG_USB_NET_AQC111=m CONFIG_WLAN=y # CONFIG_WLAN_VENDOR_ADMTEK is not set # CONFIG_WLAN_VENDOR_ATH is not set # CONFIG_WLAN_VENDOR_ATMEL is not set # CONFIG_WLAN_VENDOR_BROADCOM is not set # CONFIG_WLAN_VENDOR_CISCO is not set # CONFIG_WLAN_VENDOR_INTEL is not set # CONFIG_WLAN_VENDOR_INTERSIL is not set # CONFIG_WLAN_VENDOR_MARVELL is not set # CONFIG_WLAN_VENDOR_MEDIATEK is not set # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set # CONFIG_WLAN_VENDOR_QUANTENNA is not set CONFIG_WWAN=m # CONFIG_WWAN_DEBUGFS is not set CONFIG_INPUT_EVDEV=y CONFIG_KEYBOARD_GPIO=y # CONFIG_MOUSE_PS2 is not set CONFIG_INPUT_JOYSTICK=y CONFIG_JOYSTICK_XPAD=y CONFIG_INPUT_TOUCHSCREEN=y CONFIG_INPUT_MISC=y CONFIG_INPUT_UINPUT=y # CONFIG_VT is not set # CONFIG_LEGACY_PTYS is not set CONFIG_SERIAL_8250=y # CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set CONFIG_SERIAL_8250_CONSOLE=y # CONFIG_SERIAL_8250_EXAR is not set CONFIG_SERIAL_8250_NR_UARTS=32 CONFIG_SERIAL_8250_RUNTIME_UARTS=0 CONFIG_SERIAL_8250_DW=y CONFIG_SERIAL_OF_PLATFORM=y CONFIG_SERIAL_AMBA_PL011=y CONFIG_SERIAL_AMBA_PL011_CONSOLE=y CONFIG_SERIAL_SAMSUNG=y CONFIG_SERIAL_SAMSUNG_CONSOLE=y CONFIG_SERIAL_QCOM_GENI=y CONFIG_SERIAL_QCOM_GENI_CONSOLE=y CONFIG_SERIAL_SPRD=y CONFIG_SERIAL_SPRD_CONSOLE=y CONFIG_NULL_TTY=y CONFIG_HVC_DCC=y CONFIG_SERIAL_DEV_BUS=y CONFIG_HW_RANDOM=y # CONFIG_DEVMEM is not set # CONFIG_DEVPORT is not set # CONFIG_I2C_COMPAT is not set # CONFIG_I2C_HELPER_AUTO is not set CONFIG_I3C=y CONFIG_SPI=y CONFIG_SPI_MEM=y # CONFIG_SPMI_MSM_PMIC_ARB is not set # CONFIG_PINCTRL_SUN8I_H3_R is not set # CONFIG_PINCTRL_SUN50I_A64 is not set # CONFIG_PINCTRL_SUN50I_A64_R is not set # CONFIG_PINCTRL_SUN50I_A100 is not set # CONFIG_PINCTRL_SUN50I_A100_R is not set # CONFIG_PINCTRL_SUN50I_H5 is not set # CONFIG_PINCTRL_SUN50I_H6 is not set # CONFIG_PINCTRL_SUN50I_H6_R is not set # CONFIG_PINCTRL_SUN50I_H616 is not set # CONFIG_PINCTRL_SUN50I_H616_R is not set CONFIG_GPIO_GENERIC_PLATFORM=y CONFIG_POWER_RESET_HISI=y CONFIG_POWER_RESET_SYSCON=y # CONFIG_HWMON is not set CONFIG_THERMAL=y CONFIG_THERMAL_NETLINK=y CONFIG_THERMAL_STATISTICS=y CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=100 CONFIG_THERMAL_WRITABLE_TRIPS=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y CONFIG_DEVFREQ_THERMAL=y CONFIG_THERMAL_EMULATION=y CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y CONFIG_MFD_ACT8945A=y CONFIG_REGULATOR=y CONFIG_REGULATOR_FIXED_VOLTAGE=y CONFIG_RC_CORE=y CONFIG_BPF_LIRC_MODE2=y CONFIG_LIRC=y # CONFIG_RC_MAP is not set CONFIG_RC_DECODERS=y CONFIG_RC_DEVICES=y CONFIG_MEDIA_CEC_RC=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_SDR_SUPPORT is not set # CONFIG_MEDIA_TEST_SUPPORT is not set CONFIG_MEDIA_USB_SUPPORT=y CONFIG_USB_GSPCA=y CONFIG_USB_VIDEO_CLASS=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_V4L_MEM2MEM_DRIVERS=y CONFIG_DRM=y CONFIG_BACKLIGHT_CLASS_DEVICE=y CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_HRTIMER=y # CONFIG_SND_SUPPORT_OLD_API is not set # CONFIG_SND_VERBOSE_PROCFS is not set # CONFIG_SND_DRIVERS is not set CONFIG_SND_USB_AUDIO=y CONFIG_SND_SOC=y CONFIG_HID_BATTERY_STRENGTH=y CONFIG_HIDRAW=y CONFIG_UHID=y CONFIG_HID_APPLE=y CONFIG_HID_PRODIKEYS=y CONFIG_HID_ELECOM=y CONFIG_HID_UCLOGIC=y CONFIG_HID_LOGITECH=y CONFIG_HID_LOGITECH_DJ=y CONFIG_HID_MAGICMOUSE=y CONFIG_HID_MICROSOFT=y CONFIG_HID_MULTITOUCH=y CONFIG_HID_NINTENDO=y CONFIG_HID_PICOLCD=y CONFIG_HID_PLANTRONICS=y CONFIG_HID_PLAYSTATION=y CONFIG_PLAYSTATION_FF=y CONFIG_HID_ROCCAT=y CONFIG_HID_SONY=y CONFIG_SONY_FF=y CONFIG_HID_STEAM=y CONFIG_HID_WACOM=y CONFIG_HID_WIIMOTE=y CONFIG_USB_HIDDEV=y CONFIG_USB_ANNOUNCE_NEW_DEVICES=y CONFIG_USB_OTG=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI_RENESAS=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_ROOT_HUB_TT=y CONFIG_USB_EHCI_HCD_PLATFORM=y CONFIG_USB_ACM=m CONFIG_USB_STORAGE=y CONFIG_USB_UAS=y CONFIG_USB_DWC3=y CONFIG_USB_SERIAL=m CONFIG_USB_SERIAL_FTDI_SIO=m CONFIG_USB_GADGET=y CONFIG_USB_CONFIGFS=y CONFIG_USB_CONFIGFS_UEVENT=y CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_F_ACC=y CONFIG_USB_CONFIGFS_F_AUDIO_SRC=y CONFIG_USB_CONFIGFS_F_UAC2=y CONFIG_USB_CONFIGFS_F_MIDI=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_CONFIGFS_F_UVC=y CONFIG_TYPEC=y CONFIG_TYPEC_TCPM=y CONFIG_TYPEC_TCPCI=y CONFIG_TYPEC_UCSI=y CONFIG_TYPEC_DP_ALTMODE=y CONFIG_MMC=y # CONFIG_PWRSEQ_EMMC is not set # CONFIG_PWRSEQ_SIMPLE is not set CONFIG_MMC_CRYPTO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_PLTFM=y CONFIG_SCSI_UFSHCD=y CONFIG_SCSI_UFS_BSG=y CONFIG_SCSI_UFS_CRYPTO=y CONFIG_SCSI_UFSHCD_PCI=y CONFIG_SCSI_UFSHCD_PLATFORM=y CONFIG_SCSI_UFS_DWC_TC_PLATFORM=y CONFIG_SCSI_UFS_HISI=y CONFIG_LEDS_CLASS_FLASH=y CONFIG_LEDS_CLASS_MULTICOLOR=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_TRANSIENT=y CONFIG_EDAC=y CONFIG_RTC_CLASS=y CONFIG_RTC_DRV_PL030=y CONFIG_RTC_DRV_PL031=y CONFIG_DMABUF_HEAPS=y CONFIG_DMABUF_SYSFS_STATS=y CONFIG_DMABUF_HEAPS_DEFERRED_FREE=y CONFIG_DMABUF_HEAPS_PAGE_POOL=y CONFIG_UIO=y CONFIG_VIRT_DRIVERS=y CONFIG_GUNYAH=y # CONFIG_GUNYAH_QCOM_PLATFORM is not set CONFIG_GUNYAH_VCPU=y CONFIG_GUNYAH_IRQFD=y CONFIG_GUNYAH_IOEVENTFD=y CONFIG_MTK_GZVM=m CONFIG_VHOST_VSOCK=y CONFIG_STAGING=y CONFIG_ASHMEM=y CONFIG_COMMON_CLK_SCPI=y # CONFIG_SUNXI_CCU is not set CONFIG_HWSPINLOCK=y # CONFIG_SUN50I_ERRATUM_UNKNOWN1 is not set CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y CONFIG_REMOTEPROC=y CONFIG_REMOTEPROC_CDEV=y CONFIG_RPMSG_CHAR=y CONFIG_QCOM_GENI_SE=y CONFIG_DEVFREQ_GOV_PERFORMANCE=y CONFIG_DEVFREQ_GOV_POWERSAVE=y CONFIG_DEVFREQ_GOV_USERSPACE=y CONFIG_DEVFREQ_GOV_PASSIVE=y CONFIG_PM_DEVFREQ_EVENT=y CONFIG_IIO=y CONFIG_IIO_BUFFER=y CONFIG_IIO_TRIGGER=y CONFIG_PWM=y CONFIG_GENERIC_PHY=y CONFIG_POWERCAP=y CONFIG_ANDROID_BINDER_IPC=y CONFIG_ANDROID_BINDERFS=y CONFIG_ANDROID_DEBUG_SYMBOLS=y CONFIG_ANDROID_VENDOR_HOOKS=y CONFIG_ANDROID_DEBUG_KINFO=y CONFIG_LIBNVDIMM=y CONFIG_INTERCONNECT=y CONFIG_EXT4_FS=y CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y CONFIG_F2FS_FS=y CONFIG_F2FS_FS_SECURITY=y CONFIG_F2FS_FS_COMPRESSION=y CONFIG_F2FS_UNFAIR_RWSEM=y CONFIG_FS_ENCRYPTION=y CONFIG_FS_ENCRYPTION_INLINE_CRYPT=y CONFIG_FS_VERITY=y CONFIG_FS_VERITY_BUILTIN_SIGNATURES=y # CONFIG_DNOTIFY is not set CONFIG_QUOTA=y CONFIG_QFMT_V2=y CONFIG_FUSE_FS=y CONFIG_VIRTIO_FS=y CONFIG_FUSE_BPF=y CONFIG_OVERLAY_FS=y CONFIG_INCREMENTAL_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_EXFAT_FS=y CONFIG_TMPFS=y # CONFIG_EFIVAR_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_CONSOLE=y CONFIG_PSTORE_PMSG=y CONFIG_PSTORE_RAM=y CONFIG_EROFS_FS=y CONFIG_EROFS_FS_PCPU_KTHREAD=y CONFIG_EROFS_FS_PCPU_KTHREAD_HIPRI=y CONFIG_NLS_CODEPAGE_437=y CONFIG_NLS_CODEPAGE_737=y CONFIG_NLS_CODEPAGE_775=y CONFIG_NLS_CODEPAGE_850=y CONFIG_NLS_CODEPAGE_852=y CONFIG_NLS_CODEPAGE_855=y CONFIG_NLS_CODEPAGE_857=y CONFIG_NLS_CODEPAGE_860=y CONFIG_NLS_CODEPAGE_861=y CONFIG_NLS_CODEPAGE_862=y CONFIG_NLS_CODEPAGE_863=y CONFIG_NLS_CODEPAGE_864=y CONFIG_NLS_CODEPAGE_865=y CONFIG_NLS_CODEPAGE_866=y CONFIG_NLS_CODEPAGE_869=y CONFIG_NLS_CODEPAGE_936=y CONFIG_NLS_CODEPAGE_950=y CONFIG_NLS_CODEPAGE_932=y CONFIG_NLS_CODEPAGE_949=y CONFIG_NLS_CODEPAGE_874=y CONFIG_NLS_ISO8859_8=y CONFIG_NLS_CODEPAGE_1250=y CONFIG_NLS_CODEPAGE_1251=y CONFIG_NLS_ASCII=y CONFIG_NLS_ISO8859_1=y CONFIG_NLS_ISO8859_2=y CONFIG_NLS_ISO8859_3=y CONFIG_NLS_ISO8859_4=y CONFIG_NLS_ISO8859_5=y CONFIG_NLS_ISO8859_6=y CONFIG_NLS_ISO8859_7=y CONFIG_NLS_ISO8859_9=y CONFIG_NLS_ISO8859_13=y CONFIG_NLS_ISO8859_14=y CONFIG_NLS_ISO8859_15=y CONFIG_NLS_KOI8_R=y CONFIG_NLS_KOI8_U=y CONFIG_NLS_MAC_ROMAN=y CONFIG_NLS_MAC_CELTIC=y CONFIG_NLS_MAC_CENTEURO=y CONFIG_NLS_MAC_CROATIAN=y CONFIG_NLS_MAC_CYRILLIC=y CONFIG_NLS_MAC_GAELIC=y CONFIG_NLS_MAC_GREEK=y CONFIG_NLS_MAC_ICELAND=y CONFIG_NLS_MAC_INUIT=y CONFIG_NLS_MAC_ROMANIAN=y CONFIG_NLS_MAC_TURKISH=y CONFIG_NLS_UTF8=y CONFIG_UNICODE=y CONFIG_SECURITY=y CONFIG_SECURITYFS=y CONFIG_SECURITY_NETWORK=y CONFIG_HARDENED_USERCOPY=y CONFIG_FORTIFY_SOURCE=y CONFIG_STATIC_USERMODEHELPER=y CONFIG_STATIC_USERMODEHELPER_PATH="" CONFIG_SECURITY_SELINUX=y CONFIG_INIT_ON_ALLOC_DEFAULT_ON=y CONFIG_CRYPTO_ECDH=y CONFIG_CRYPTO_DES=y CONFIG_CRYPTO_ADIANTUM=y CONFIG_CRYPTO_HCTR2=y CONFIG_CRYPTO_CHACHA20POLY1305=y CONFIG_CRYPTO_CCM=y CONFIG_CRYPTO_BLAKE2B=y CONFIG_CRYPTO_CMAC=y CONFIG_CRYPTO_MD5=y CONFIG_CRYPTO_XCBC=y CONFIG_CRYPTO_LZO=y CONFIG_CRYPTO_LZ4=y CONFIG_CRYPTO_ZSTD=y CONFIG_CRYPTO_ANSI_CPRNG=y CONFIG_CRYPTO_GHASH_ARM64_CE=y CONFIG_CRYPTO_SHA2_ARM64_CE=y CONFIG_CRYPTO_SHA512_ARM64_CE=y CONFIG_CRYPTO_POLYVAL_ARM64_CE=y CONFIG_CRYPTO_AES_ARM64_CE_BLK=y CONFIG_CRYPTO_LIBARC4=y #sergio CONFIG_TRACE_MMIO_ACCESS=y CONFIG_CRC_CCITT=y CONFIG_XZ_DEC=y CONFIG_DMA_CMA=y CONFIG_PRINTK_TIME=y CONFIG_PRINTK_CALLER=y CONFIG_DYNAMIC_DEBUG_CORE=y CONFIG_DEBUG_INFO_DWARF4=y CONFIG_DEBUG_INFO_BTF=y CONFIG_MODULE_ALLOW_BTF_MISMATCH=y CONFIG_HEADERS_INSTALL=y # CONFIG_SECTION_MISMATCH_WARN_ONLY is not set CONFIG_MAGIC_SYSRQ=y CONFIG_UBSAN=y CONFIG_UBSAN_TRAP=y CONFIG_UBSAN_LOCAL_BOUNDS=y # CONFIG_UBSAN_SHIFT is not set # CONFIG_UBSAN_BOOL is not set # CONFIG_UBSAN_ENUM is not set CONFIG_PAGE_OWNER=y CONFIG_PAGE_PINNER=y CONFIG_PER_VMA_LOCK_STATS=y CONFIG_DEBUG_STACK_USAGE=y CONFIG_DEBUG_MEMORY_INIT=y CONFIG_KASAN=y CONFIG_KASAN_HW_TAGS=y CONFIG_KFENCE=y CONFIG_KFENCE_SAMPLE_INTERVAL=500 CONFIG_KFENCE_NUM_OBJECTS=63 CONFIG_KFENCE_STATIC_KEYS=y CONFIG_PANIC_ON_OOPS=y CONFIG_PANIC_TIMEOUT=-1 CONFIG_SOFTLOCKUP_DETECTOR=y CONFIG_WQ_WATCHDOG=y CONFIG_SCHEDSTATS=y # CONFIG_DEBUG_PREEMPT is not set CONFIG_BUG_ON_DATA_CORRUPTION=y CONFIG_HIST_TRIGGERS=y CONFIG_PID_IN_CONTEXTIDR=y CONFIG_KUNIT=y CONFIG_KUNIT_DEBUGFS=y # CONFIG_KUNIT_DEFAULT_ENABLED is not set # CONFIG_RUNTIME_TESTING_MENU is not set CONFIG_CFG80211=y
I'm trying to enable on the boards m.2 Connector a SDIO WiFi/Bluetooth Module.
BR
