HI,
I have a custom board based on AM625 and needed to get console output in UART2. I tried this following patch specified in below thread. Basically I get few lines output. After that it stops. Please let me know what would be the probable issue?
output from UART-2:
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:36:12 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Ca2c)
k3_ddrss memorycontroller@f300000: clk get failed-2
the following patch has been applied.
diff --git a/arch/arm/dts/k3-am62x-r5-sk-common.dtsi b/arch/arm/dts/k3-am62x-r5-sk-common.dtsi
index b4a5e3cfa1..d5976095e9 100644
--- a/arch/arm/dts/k3-am62x-r5-sk-common.dtsi
+++ b/arch/arm/dts/k3-am62x-r5-sk-common.dtsi
@@ -13,7 +13,7 @@
chosen {
- stdout-path = "serial2:115200n8";
+ stdout-path = "serial4:115200n8";
tick-timer = &timer1;
diff --git a/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi b/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
index b57d9563d8..acc064337a 100644
--- a/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
+++ b/arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi
@@ -6,7 +6,7 @@
chosen {
diff --git a/arch/arm/dts/k3-am62x-sk-common.dtsi b/arch/arm/dts/k3-am62x-sk-common.dtsi
index 72ebb1400f..58a3bc713e 100644
--- a/arch/arm/dts/k3-am62x-sk-common.dtsi
+++ b/arch/arm/dts/k3-am62x-sk-common.dtsi
@@ -14,7 +14,7 @@
aliases {
- serial2 = &main_uart0;
+ serial4 = &main_uart2;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
@@ -25,8 +25,8 @@
chosen {
- bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
+ bootargs = "console=ttyS4,115200n8 earlycon=ns16550a,mmio32,0x02820000";
memory@80000000 {
@@ -154,10 +154,17 @@
&main_pmx0 {
- main_uart0_pins_default: main-uart0-pins-default {
+ // main_uart0_pins_default: main-uart0-pins-default {
+ // pinctrl-single,pins = <
+ // AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
+ // AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
+ main_uart2_pins_default: main-uart2-pins-default {
- AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
- AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
+ AM62X_IOPAD(0x01d0, PIN_INPUT, 3) /* (B14) UART0_CTSn.UART2_RXD */
+ AM62X_IOPAD(0x01d4, PIN_OUTPUT, 3) /* (C13) UART0_RTSn.UART2_TXD */
@@ -301,8 +308,7 @@
&main_uart0 {
- pinctrl-names = "default";
- pinctrl-0 = <&main_uart0_pins_default>;
+ status = "disabled";
&main_uart1 {
@@ -311,7 +317,9 @@
&main_uart2 {
- status = "disabled";
+ pinctrl-names = "default";
+ pinctrl-0 = <&main_uart2_pins_default>;
+ status = "okay";
&main_uart3 {
diff --git a/arch/arm/mach-k3/am62x/clk-data.c b/arch/arm/mach-k3/am62x/clk-data.c
index 47ea973197..9f8d7d7e6f 100644
--- a/arch/arm/mach-k3/am62x/clk-data.c
+++ b/arch/arm/mach-k3/am62x/clk-data.c
@@ -115,11 +115,16 @@ static const char * const wkup_clksel_out0_parents[] = {
"hsdiv4_16fft_mcu_0_hsdivout0_clk",
-static const char * const main_usart0_fclk_sel_out0_parents[] = {
- "usart_programmable_clock_divider_out0",
+static const char * const main_usart2_fclk_sel_out0_parents[] = {
+ "usart_programmable_clock_divider_out2",
"hsdiv4_16fft_main_1_hsdivout1_clk",
+// static const char * const main_usart0_fclk_sel_out0_parents[] = {
+// "usart_programmable_clock_divider_out0",
+// "hsdiv4_16fft_main_1_hsdivout1_clk",
static const struct clk_data clk_list[] = {
CLK_FIXED_RATE("osc_26_mhz", 26000000, 0),
CLK_FIXED_RATE("osc_25_mhz", 25000000, 0),
@@ -199,10 +204,12 @@ static const struct clk_data clk_list[] = {
CLK_MUX("main_gpmc_fclk_sel_out0", main_gpmc_fclk_sel_out0_parents, 2, 0x108180, 0, 1, 0),
CLK_MUX("main_gtcclk_sel_out0", main_gtcclk_sel_out0_parents, 8, 0x43008030, 0, 3, 0),
CLK_MUX("main_ospi_ref_clk_sel_out0", main_ospi_ref_clk_sel_out0_parents, 2, 0x108500, 0, 1, 0),
- CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108240, 0, 2, 0, 0, 48000000),
+ CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out2", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108248, 0, 2, 0, 0, 48000000),
+ //CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108240, 0, 2, 0, 0, 48000000),
CLK_MUX("wkup_clkout_sel_out0", wkup_clkout_sel_out0_parents, 8, 0x43008020, 0, 3, 0),
CLK_MUX("wkup_clksel_out0", wkup_clksel_out0_parents, 2, 0x43008010, 0, 1, 0),
- CLK_MUX("main_usart0_fclk_sel_out0", main_usart0_fclk_sel_out0_parents, 2, 0x108280, 0, 1, 0),
+ CLK_MUX("main_usart2_fclk_sel_out0", main_usart2_fclk_sel_out0_parents, 2, 0x108288, 0, 1, 0),
+ //CLK_MUX("main_usart0_fclk_sel_out0", main_usart0_fclk_sel_out0_parents, 2, 0x108280, 0, 1, 0),
CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout1_clk", "pllfracf2_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040084, 0, 7, 0, 0),
CLK_FIXED_RATE("mshsi2c_wkup_0_porscl", 0, 0),
CLK_DIV("sam62_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0),
@@ -297,10 +304,14 @@ static const struct dev_clk soc_dev_clk_data[] = {
DEV_CLK(136, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"),
DEV_CLK(140, 0, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"),
DEV_CLK(140, 1, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"),
- DEV_CLK(146, 0, "main_usart0_fclk_sel_out0"),
- DEV_CLK(146, 1, "usart_programmable_clock_divider_out0"),
- DEV_CLK(146, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"),
- DEV_CLK(146, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
+ // DEV_CLK(146, 0, "main_usart0_fclk_sel_out0"),
+ // DEV_CLK(146, 1, "usart_programmable_clock_divider_out0"),
+ // DEV_CLK(146, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"),
+ // DEV_CLK(146, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
+ DEV_CLK(153, 0, "main_usart2_fclk_sel_out0"),
+ DEV_CLK(153, 1, "usart_programmable_clock_divider_out2"),
+ DEV_CLK(153, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"),
+ DEV_CLK(153, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"),
DEV_CLK(157, 20, "clkout0_ctrl_out0"),
DEV_CLK(157, 21, "hsdiv4_16fft_main_2_hsdivout1_clk"),
DEV_CLK(157, 22, "hsdiv4_16fft_main_2_hsdivout1_clk"),
diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/am62x/dev-data.c
index f413313533..a1954d5ca2 100644
--- a/arch/arm/mach-k3/am62x/dev-data.c
+++ b/arch/arm/mach-k3/am62x/dev-data.c
@@ -62,7 +62,8 @@ static struct ti_dev soc_dev_list[] = {
PSC_DEV(162, &soc_lpsc_list[10]),
PSC_DEV(75, &soc_lpsc_list[11]),
PSC_DEV(102, &soc_lpsc_list[12]),
- PSC_DEV(146, &soc_lpsc_list[12]),
+ PSC_DEV(153, &soc_lpsc_list[12]),
+ // PSC_DEV(146, &soc_lpsc_list[12]),
PSC_DEV(13, &soc_lpsc_list[13]),
PSC_DEV(166, &soc_lpsc_list[14]),
PSC_DEV(135, &soc_lpsc_list[15]),
diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h
index a598607ead..4f4c8bba1d 100644
--- a/include/environment/ti/boot.h
+++ b/include/environment/ti/boot.h
@@ -12,7 +12,8 @@
#include <linux/stringify.h>
#ifndef CONSOLEDEV
-#define CONSOLEDEV "ttyS2"
+// #define CONSOLEDEV "ttyS2"
+#define CONSOLEDEV "ttyS4"
#endif
#ifndef PARTS_DEFAULT
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h
index 97bd7c1fd7..70004fbb79 100644
--- a/include/configs/am62x_evm.h
+++ b/include/configs/am62x_evm.h
@@ -129,9 +129,9 @@
"setenv name_fdt k3-am62x-lp-sk.dtb; fi;" \
"setenv fdtfile ${name_fdt}\0" \
"name_kern=Image\0" \
- "console=ttyS2,115200n8\0" \
+ "console=ttyS4,115200n8\0" \
"args_all=setenv optargs ${optargs} " \
- "earlycon=ns16550a,mmio32,0x02800000 ${mtdparts}\0" \
+ "earlycon=ns16550a,mmio32,0x02820000 ${mtdparts}\0" \
"run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0"
/* U-Boot MMC-specific configuration */
thanks,
siva.
