Part Number: PROCESSOR-SDK-AM62X
Hi TI expert,
Is there a non-volatile memory area on the AM62X SOC?
If so, can you provide me with relevant documents?
FPT-Huy
Hi TI expert,
FPT-Huy
Hello FPT-Huy
Thank you for the query.
Could you elaborate the use case for the non-volatile memory including the size.
Sreenivasa
Hello Sreenivasa,
I want to save hardware version number with 8bit non-volatile memory.
FPT-Huy
Hello FPT-Huy
Thank you for the inputs.
I guess the use case is non volatile and not really secure.
This should be feasible.
Is this a custom board. Do you have the provision to enable the VPP supply for programming.
Sreenivasa
Hello Sreenivasa,
yes, It is a custom board, This requirement did not mention VPP supply, but with this case, how to use it?, Do you have relevant documents for me?
FPT-Huy
Hello FPT-Huy
Thank you.
Please elaborate your query?
Sreenivasa
Hello FPT-Huy
Please refer below link.
This assume the VPP is available and stable within the ROC.
Sreenivasa
