Part Number: AM625
Hi Team,
I am following the below document to create DFU images.
After replacing the defconfig files, How to generate tiboot3.bin, tispl.bin and u-boot.img images using yocto build for TI SDK?
Abhishek Lakhara
Part Number: AM625
Hi Team,
Abhishek Lakhara
You need to change the Yocto configuration to use the new R5 defconfig file as discussed here: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1323103/am625-how-to-find-dts-file-for-u-boot/5033277#5033277
Then, you can just do a regular Yocto build, and the U-Boot files will be generated as part of the build. If you ONLY want to build U-Boot using Yocto you should be able to do it with the below two commands:
# Build and deploy "tiboot3.bin" (and it's device-specific variants) $ MACHINE=am62xx-evm bitbake -c deploy mc:k3r5:u-boot # Build and deploy "tispl.bin" and "u-boot.img" $ MACHINE=am62xx-evm bitbake -c deploy u-boot
Regards, Andreas
