Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
We are planning to use 3 SGMII Ethernet PHY IC. Is this possible to use with TDA4VH-Q1?
This thread is assigned to our engineer in the India office. Due to a regional holiday, half of our team is out of the office. Please expect a 1~2 day delay in responses.
Apologies for the delay, and thank you for your patience.
Thanks.
TDA4VH supports CPSW9G, which has 8 Serial external Ports. We can connect 8 Serial PHYs using the same MDIO lines.
Do you mean, want to use 3 SGMII PHYs and connect to TDA4VH? If so, yes it is possible all 8 External ports are independent.
Sudheer
Yes I want to use 3 SGMII PHYs and connect to TDA4VH
As mentioned above you can use 3 PHYs but MDIO lines are common for all PHYs from TDA4VH as it is single instance of CPSW which is CPSW9G.
Sudheer
Will be closing this thread, if you need any support please reply back.
Sudheer
