AM625: Bitbake build failed with exit code '1'
Part Number: AM625
Following the steps in https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_02_01_09/exports/docs/linux/Overview_Building_the_SDK.html#build-steps
and building tisdk-default-image for am62xx-evm (MACHINE=am62xx-evm bitbake -k tisdk-default-image) on ubuntu 22.04 LTS(Using Vmware 32GB RAM,8core) I get the following errors in meta-ti:
ERROR: Task (/home/User/tisdk/sources/meta-arago/meta-arago-distro/recipes-graphics/vk-gl-cts/opengl-es-cts_3.2.9.3.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 10843 tasks of which 10841 didn't need to be rerun and 2 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 2 seconds
Summary: 2 tasks failed:
  /home/User/tisdk/sources/meta-clang/recipes-devtools/clang/llvm-project-source.bb:do_unpack
Summary: There were 6 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
I attached the full error logs.
Could you please let me know how to fix these recipies.
Thank you in advance.
  • log.do_compile.8782.txt
    DEBUG: Executing python function do_unpack
    DEBUG: Executing python function base_do_unpack
    DEBUG: Running 'export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/User/tisdk/sources/oe-core/scripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/bin:/home/User/tisdk/sources/bitbake/bin:/home/User/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/User"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat branch --contains d28af7c654d8db0b68c175db5ce212d74fb5e9bc --list release/12.x 2> /dev/null | wc -l' in /home/User/tisdk/downloads/git2/github.com.llvm.llvm-project
    DEBUG: Running export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/User/tisdk/sources/oe-core/scripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/bin:/home/User/tisdk/sources/bitbake/bin:/home/User/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/User"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone -n -s /home/User/tisdk/downloads/git2/github.com.llvm.llvm-project/ /home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/git/
    ERROR: Bitbake Fetcher Error: FetchError('Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/User/tisdk/sources/oe-core/scripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/bin:/home/User/tisdk/sources/bitbake/bin:/home/User/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/User"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone -n -s /home/User/tisdk/downloads/git2/github.com.llvm.llvm-project/ /home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/git/ failed with exit code 128, output:\nfatal: repository \'/home/User/tisdk/downloads/git2/github.com.llvm.llvm-project/\' does not exist\n', None)
    DEBUG: Python function base_do_unpack finished
    DEBUG: Python function do_unpack finished
  • This could be a transient error or race condition of some kind. Try the following:
    $ MACHINE=am62xx-evm bitbake -c cleansstate llvm-project-source-12.0.0 opengl-es-cts
    $ MACHINE=am62xx-evm bitbake -k tisdk-default-image
    If this doesn't help, try activating/setting the following option in your conf/local.conf file. I've run out of memory before during builds even with 64GB of RAM (sometimes when you have a machine with a large number of CPU cores the algorithm that assigns BB_NUMBER_THREADS automatically picks a value that is too large)
    BB_NUMBER_THREADS = "4"
    Then, you can also try out the steps under Steps to Run Yocto Builds inside Container (https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_02_01_09/exports/docs/linux/Overview_Building_the_SDK.html#steps-to-run-yocto-builds-inside-container) in the SDK documentation. This usually greatly simplifies the setup and maximizes success especially in the context of setup and build dependency related issues. I don't think this is what your issue is about, but it's nevertheless a good idea to try the containerized build as part of trouble-shooting.
    Regards, Andreas
  • Hi Andreas,
    Thank you for your advice,
    I set up the
    But I could not finish the build,with this error 1;
    WARNING: Duplicate inclusion for /home/User/tisdk/sources/meta-arago/meta-arago-distro/conf/distro/include/branding-core.inc in /home/User/tisdk/sources/meta-arago/meta-arago-distro/conf/distro/arago.conf
    NOTE: Started PRServer with DBfile: /home/User/tisdk/build/cache/prserv.sqlite3, Address: 127.0.0.1:45279, PID: 6728
    Loading cache: 100% |############################################| Time: 0:00:01
    Loaded 9458 entries from dependency cache.
    Parsing recipes: 100% |##########################################| Time: 0:00:01
    Parsing of 6360 .bb files complete (6356 cached, 4 parsed). 9462 targets, 1117 skipped, 0 masked, 0 errors.
    NOTE: Resolving any missing task queue dependencies
    Build Configuration (mc:default):
    BB_VERSION           = "2.0.0"
    BUILD_SYS            = "x86_64-linux"
    NATIVELSBSTRING      = "ubuntu-22.04"
    TARGET_SYS           = "aarch64-oe-linux"
    MACHINE              = "am62xx-evm"
    DISTRO               = "arago"
    DISTRO_VERSION       = "2023.10"
    TUNE_FEATURES        = "aarch64"
    TARGET_FPU           = ""
    meta-tisdk           = "HEAD:e2d81f687261309de3441917c53c5a282a4f3e1b"
    meta-arago-distro
    meta-arago-extras
    meta-arago-demos
    meta-arago-test      = "HEAD:98f178314931635c8641d1394dfd4341b86b6be2"
    meta-chromium        = "HEAD:d3d16b47e17dc899e5298cff698dc32e5e639ab4"
    meta-qt5             = "HEAD:fe0bf7f0e5408aac6cc89ff3b19b1b1941df4f64"
    meta-virtualization  = "HEAD:cb2bc17e96552cdfc141d27bd9f4dbd95a872846"
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-filesystems     = "HEAD:fda737ec0cc1d2a5217548a560074a8e4d5ec580"
    meta-ti-extras
    meta-ti-bsp          = "HEAD:376a2143533c6497b4e79304eccca2a630784436"
    meta-arm
    meta-arm-toolchain   = "HEAD:b187fb9232ca0a6b5f8f90b4715958546fc41d73"
    meta-clang           = "HEAD:c2e89dc7e1dfcc1bbe432afca2dc43d6560cb007"
    meta                 = "HEAD:2501534c9581c6c3439f525d630be11554a57d24"
    meta-edgeai          = "HEAD:80b2a8ea999c39f4ee7a951a67b218c3e0a1d6c4"
    Build Configuration:
    TARGET_SYS           = "arm-oe-eabi"
    MACHINE              = "am62xx-evm-k3r5"
    DISTRO               = "arago"
    TUNE_FEATURES        = "arm armv7a vfp thumb callconvention-hard"
    TARGET_FPU           = "hard"
    meta-arago-distro
    meta-arago-extras
    meta-arago-demos
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-ti-extras
    meta-arm
    Initialising tasks: 100% |#######################################| Time: 0:00:06
    Sstate summary: Wanted 117 Local 80 Mirrors 0 Missed 37 Current 4134 (68% match, 99% complete)
    NOTE: Executing Tasks
    ERROR: llvm-project-source-12.0.0-12.0.0-r0 do_unpack: Bitbake Fetcher Error: FetchError('Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/User/tisdk/sources/oe-core/scripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/usr/bin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/sbin:/home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/recipe-sysroot-native/bin:/home/User/tisdk/sources/bitbake/bin:/home/User/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/User"; git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone -n -s /home/User/tisdk/downloads/git2/github.com.llvm.llvm-project/ /home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/git/ failed with exit code 128, output:\nfatal: repository \'/home/User/tisdk/downloads/git2/github.com.llvm.llvm-project/\' does not exist\n', None)
    ERROR: Logfile of failure stored in: /home/User/tisdk/build/arago-tmp-default-glibc/work-shared/llvm-project-source-12.0.0-r0/temp/log.do_unpack.6849
    ERROR: Task (/home/User/tisdk/sources/meta-clang/recipes-devtools/clang/llvm-project-source.bb:do_unpack) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 10850 tasks of which 10831 didn't need to be rerun and 1 failed.
    NOTE: Writing buildhistory took: 3 seconds
    Summary: 1 task failed:
    Summary: There were 8 WARNING messages.
    Summary: There was 1 ERROR message, returning a non-zero exit code.
    User@User-virtual-machine:~/tisdk/build$
  • I set up the
    Fullscreen
    1
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Looks like the same error regarding llvm-project-source as before.
    Did you try the clean step I pointed out?
    Then, can you confirm you can manually clone that repository into a temporary folder, like this?
    a0797059@dasso:~/tmp
    $ git clone https://github.com/llvm/llvm-project.git
    Cloning into 'llvm-project'...
    remote: Enumerating objects: 5892868, done.
    remote: Counting objects: 100% (761/761), done.
    remote: Compressing objects: 100% (317/317), done.
    remote: Total 5892868 (delta 481), reused 578 (delta 443), pack-reused 5892107
    Receiving objects: 100% (5892868/5892868), 2.27 GiB | 62.96 MiB/s, done.
    Resolving deltas: 100% (4812154/4812154), done.
    Updating files: 100% (142408/142408), done.
    Lastly, try to completely delete/remove your downloadssstate-cache, and build folders, and start the build completely clean.
    Regards, Andreas
  • Yes, I did clean llvm-project-source and opengl-es-cts.
    I confirmed I can clone that repository below
    User@:~/Desktop$ git clone https://github.com/llvm/llvm-project.git
    remote: Enumerating objects: 5894009, done.
    remote: Counting objects: 100% (2340/2340), done.
    remote: Compressing objects: 100% (1079/1079), done.
    remote: Total 5894009 (delta 1586), reused 1695 (delta 1253), pack-reused 5891669
    Receiving objects: 100% (5894009/5894009), 2.28 GiB | 25.29 MiB/s, done.
    Resolving deltas: 100% (4808556/4808556), done.
    Updating files: 100% (142423/142423), done.
    Ok.
    Then next please try what I suggested earlier. First, try completely deleting/removing your downloadssstate-cache, and build folders, and start the build completely clean.
    If this still doesn't work, then try out the steps under Steps to Run Yocto Builds inside Container (https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_02_01_09/exports/docs/linux/Overview_Building_the_SDK.html#steps-to-run-yocto-builds-inside-container) in the SDK documentation.
    Regards, Andreas
  • Hi Andreas,
    I think I completed all the build process.
    User@User-virtual-machine:~/tisdk/build$ MACHINE=am62xx-evm bitbake -k tisdk-default-image
    NOTE: Started PRServer with DBfile: /home/User/tisdk/build/cache/prserv.sqlite3, Address: 127.0.0.1:33147, PID: 254291
    Loading cache: 100% |###############################################| Time: 0:00:06
    Parsing recipes: 100% |#############################################| Time: 0:00:04
    DISTRO               = "arago"
    TARGET_FPU           = ""
    meta-arago-distro
    meta-arago-extras
    meta-arago-demos
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-ti-extras
    meta-arm
    DISTRO               = "arago"
    TARGET_FPU           = "hard"
    meta-arago-distro
    meta-arago-extras
    meta-arago-demos
    meta-networking
    meta-python
    meta-oe
    meta-gnome
    meta-ti-extras
    meta-arm
    Initialising tasks: 100% |##########################################| Time: 0:00:09
    Sstate summary: Wanted 2327 Local 88 Mirrors 0 Missed 2239 Current 1924 (3% match, 47% complete)
    WARNING: erofs-utils-native-1.4-r0 do_fetch: Failed to fetch URL git://git.kernel.org/pub/scm/linux/kernel/git/xiang/erofs-utils.git;branch=master, attempting MIRRORS if available
    WARNING: express-4.18.2-r0 do_populate_lic: QA Issue: express: No generic license file exists for: Unknown in any provider [license-exists]
    NOTE: Tasks Summary: Attempted 10917 tasks of which 8424 didn't need to be rerun and all succeeded.
    NOTE: Writing buildhistory took: 66 seconds
    Summary: There were 12 WARNING messages.
    Thank you so much for your assistance.
