SK-AM62A-LP: Facing error in MCU-R5 firmware(program) loading with Linux during boot-up time. (Failed to load program segments: -22) when tried to run "EPWM Duty Cycle" example on our EVK (SK-AM62A-LP) with Linux running on EVK (SK-AM62A-LP
Part Number: SK-AM62A-LP
Hello Team,
We have followed below Link for this "EPWM Duty Cycle" example on our EVK (SK-AM62A-LP) (Example Path: mcu_plus_sdk_am62ax_09_01_00_39\examples\drivers\epwm\epwm_duty_cycle\am62ax-sk\r5fss0-0_freertos)
1) https://software-dl.ti.com/mcu-plus-sdk/esd/AM62AX/09_01_00_39/exports/docs/api_guide_am62ax/EXAMPLES_DRIVERS_EPWM_DUTY_CYCLE.html
2) https://dev.ti.com/tirex/explore/node?node=A__AeO-0ljXOpe7uiPS6ozGxg__AM62A-ACADEMY__WeZ9SsL__LATEST
We have tried to run "EPWM Duty Cycle" example on our EVK (SK-AM62A-LP) but we are facing error in R5 firmware loading with Linux during boot-up time. (Failed to load program segments: -22)
Processor SDK: Version: 09.01.00.02 (PROCESSOR-SDK-LINUX-RT-AM62A)
MCU-SDK: Version: 09.01.00.39 (MCU-PLUS-SDK-AM62A — MCU+ SDK for AM62A)
Error message during Linux boot-up time on EVK:
[ 4.283608] remoteproc remoteproc1: powering up 79000000.r5f
[ 4.283629] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 1318400
[ 4.288046] remoteproc remoteproc1: bad phdr da 0x9ca08000 mem 0x26360
Starting Weston socket...
[ 4.288062] remoteproc remoteproc1: Failed to load program segments: -22
8551.Boot-Up-Log-firmware-load-failed.txt
[  OK  ] Removed slice Slice /system/modprobe.
[  OK  ] Removed slice Slice /system/systemd-coredump.
[  OK  ] Stopped target Graphical Interface.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
[  OK  ] Stopped target RPC Port Mapper.
[  OK  ] Stopped target Sound Card.
[  OK  ] Stopped target Timer Units.
[  OK  ] Stopped Daily rotation of log files.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped target System Time Set.
[  OK  ] Stopped target Hardware activated USB gadget.
[  OK  ] Closed Process Co         Stopping Serial Getty on ttyS2...
         Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
         Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf...
         Stopping User Login Management...
         Stopping Load/Save Random Seed...
         Stopping TEE Supplicant...
         Stopping Telnet Server...
[  OK  ] Stopped Job spooling tools.
[  OK  ] Stopped Periodic Command Scheduler.
[  OK  ] Stopped irqbalance daemon.
[  OK  ] Stopped Telephony service.
[  OK  ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
[  OK  ] Stopped User Login Management.
[  OK  ] Stopped TEE Supplicant.
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped Netperf Benchmark Server.
[  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
[  OK  ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Stopped containerd container runtime.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyS2.
[  OK  ] Stopped SSH Per-Connection Server (10.70.226.207:56145).
[  OK  ] Stopped Save/Restore Sound Card State.
[  OK  ] Stopped Reboot and dump vmcore via kexec.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Telnet Server.
[  OK  ] Removed slice Slice /system/dropbear.
[  OK  ] Removed slice Slice /system/getty.
[  OK  ] Removed slice Slice /system/serial-getty.
[  OK  ] Stopped target Host and Network Name Lookups.
         Stopping Permit User Sessions...
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Network.
[  OK  ] Stopped target Remote File Systems.
         Stopping Network Name Resolution...
[  OK  ] Stopped Network Name Resolution.
         Stopping Network Configuration...
[  OK  ] Stopped Network Configuration.
[  OK  ] Stopped target Preparation for Network.
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Path Units.
[  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Stopped target Slice Units.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Socket Units.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed Docker Socket for the API.
[  OK  ] Closed dropbear.socket.
[  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
[  OK  ] Closed Network Service Netlink Socket.
[  OK  ] Closed Weston socket.
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
         Starting Console System Reboot Logging...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
         Stopping Network Time Synchronization...
[  OK  ] Finished Console System Reboot Logging.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /media/ram...
         Unmounting /run/media/BOOT-mmcblk1p1...
         Unmounting /run/media/rootfs-mmcblk0p1...
         Unmounting Temporary Directory /tmp...
[ 1371.698961] EXT4-fs (mmcblk0p1): unmounting filesystem.
         Unmounting /var/volatile...
[  OK  ] Unmounted /media/ram.
[  OK  ] Unmounted /run/media/BOOT-mmcblk1p1.
[  OK  ] Unmounted /run/media/rootfs-mmcblk0p1.
[  OK  ] Unmounted Temporary Directory /tmp.
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Swaps.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped File System Check on /dev/mmcblk0p1.
[  OK  ] Stopped File System Check on /dev/mmcblk1p1.
[  OK  ] Removed slice Slice /system/systemd-fsck.
[  OK  ] Stopped target Preparation for Local File Systems.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target System Shutdown.
[  OK  ] Reached target Late Shutdown Services.
[  OK  ] Finished System Reboot.
[  OK  ] Reached target System Reboot.
[ 1371.950007] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 1371.968467] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 1371.980700] systemd-journald[190]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 1371.982453] audit: type=1335 audit(1712747104.499:5): pid=190 uid=0 auid=4294967295 tty=(none) ses=4294967295 comm="systemd-journal" exe="/lib/systemd/systemd-journald" nl-mcgrp=1 op=disconnect res=1
[ 1372.015035] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 1372.026038] systemd-shutdown[1]: Unmounting file systems.
[ 1372.028385] [1515]: Remounting '/' read-only with options 'n/a'.
[ 1372.057074] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[ 1372.064702] systemd-shutdown[1]: All filesystems unmounted.
[ 1372.064722] systemd-shutdown[1]: Deactivating swaps.
[ 1372.064891] systemd-shutdown[1]: All swaps deactivated.
[ 1372.064901] systemd-shutdown[1]: Detaching loop devices.
[ 1372.068516] systemd-shutdown[1]: All loop devices detached.
[ 1372.068530] systemd-shutdown[1]: Stopping MD devices.
[ 1372.068826] systemd-shutdown[1]: All MD devices stopped.
[ 1372.068836] systemd-shutdown[1]: Detaching DM devices.
[ 1372.069052] systemd-shutdown[1]: All DM devices detached.
[ 1372.069061] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[ 1372.079163] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 1372.080016] systemd-shutdown[1]: Rebooting.
[ 1372.161156] reboot: Restarting system
U-Boot SPL 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
am62a_init: board_init_f done
SPL initial stack usage: 17040 bytes
am62a_init: spl_boot_device: devstat = 0x243 bootmedia = 0x8 bootindex = 0
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
NOTICE:  BL31: Built : 09:34:15, Aug 24 2023
U-Boot 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
SoC:   AM62AX SR1.0 HS-FS
Model: Texas Instruments AM62A7 SK
DRAM:  2 GiB (effective 4 GiB)
Core:  58 devices, 28 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
639 bytes read in 24 ms (25.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
## Error: "main_cpsw0_qsgmii_phyinit" not defined
16169472 bytes read in 695 ms (22.2 MiB/s)
57175 bytes read in 30 ms (1.8 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
Working FDT set to 8feef000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.46-rt13-gb871cdee8c (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Thu Dec  7 23:52:13 UTC 2023
[    0.000000] Machine model: Texas Instruments AM62A7 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000997fffff]
[    0.000000]   node   0: [mem 0x0000000099800000-0x000000009b7fefff]
[    0.000000]   node   0: [mem 0x000000009b800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a2ffffff]
[    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s44928 r8192 d28800 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032191
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=83c21bb6-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 2819264K/4194300K available (10368K kernel code, 1198K rwdata, 2328K rodata, 1792K init, 420K bss, 785212K reserved, 589824K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: 0xffff80000840dd70
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000227] Console: colour dummy device 80x25
[    0.590326] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
[    0.590335] pid_max: default: 32768 minimum: 301
[    0.590405] LSM: Security Framework initializing
[    0.590500] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.590517] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.591813] rcu: Hierarchical SRCU implementation.
[    0.591818] rcu:     Max phase no-delay instances is 400.
[    0.591854] printk: bootconsole [ns16550a0] printing thread started
[    0.644257] Platform MSI: msi-controller@1820000 domain created
[    0.644433] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.644508] EFI services will not be available.
[    0.644692] smp: Bringing up secondary CPUs ...
[    0.645251] Detected VIPT I-cache on CPU1
[    0.645335] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.645350] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
[    0.645391] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.695378] Detected VIPT I-cache on CPU2
[    0.695449] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.695461] GICv3: CPU2: using allocated LPI pending table @0x0000000880060000
[    0.695490] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.721246] Detected VIPT I-cache on CPU3
[    0.721320] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.721332] GICv3: CPU3: using allocated LPI pending table @0x0000000880070000
[    0.721359] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.721410] smp: Brought up 1 node, 4 CPUs
[    0.721416] SMP: Total of 4 processors activated.
[    0.755597] CPU features: detected: 32-bit EL0 Support
[    0.755601] CPU features: detected: CRC32 instructions
[    0.755639] CPU: All CPU(s) started at EL2
[    0.755641] alternatives: applying system-wide alternatives
[    0.756763] devtmpfs: initialized
[    0.767301] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.767319] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.780836] pinctrl core: initialized pinctrl subsystem
[    0.781355] DMI not present or invalid.
[    0.781770] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.786457] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.786638] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.786798] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.786859] audit: initializing netlink subsys (disabled)
[    0.786961] audit: type=2000 audit(0.784:1): state=initialized audit_enabled=0 res=1
[    0.787453] thermal_sys: Registered thermal governor 'step_wise'
[    0.787623] ASID allocator initialised with 65536 entries
[    0.799287] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.801340] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.809543] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.809551] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.809555] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.809557] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.809561] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.809564] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.809568] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.809570] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.812882] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
[    0.814445] iommu: Default domain type: Translated
[    0.814452] iommu: DMA domain TLB invalidation policy: strict mode
[    0.814742] SCSI subsystem initialized
[    0.815076] usbcore: registered new interface driver usbfs
[    0.815113] usbcore: registered new interface driver hub
[    0.815140] usbcore: registered new device driver usb
[    0.815569] pps_core: LinuxPPS API ver. 1 registered
[    0.815572] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.815586] PTP clock support registered
[    0.815717] EDAC MC: Ver: 3.0.0
[    0.816388] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.816567] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.816718] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.816775] omap-mailbox 29030000.mailbox: no available mbox devices found
[    0.817070] FPGA manager framework
[    0.817163] Advanced Linux Sound Architecture Driver Initialized.
[    0.817996] clocksource: Switched to clocksource arch_sys_counter
[    0.818194] VFS: Disk quotas dquot_6.6.0
[    1.042[214] printk: console [ttyS2] printing thread started
    0.818225] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.042229] printk: console [ttyS2] enabled
[    1.042233] printk: bootconsole [ns16550a0] disabled
[    1.054808] printk: bootconsole [ns16550a0] printing thread stopped
[    1.057463] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.057472] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[    1.057689] 7 fixed-partitions partitions found on MTD device spi0.0
[    1.057697] Creating 7 MTD partitions on "spi0.0":
[    1.057702] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
[    1.059212] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
[    1.061278] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
[    1.064133] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
[    1.065486] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
[    1.066776] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[    1.113134] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[    1.149029] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.150548] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.150590] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.150708] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.150714] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.151162] pps pps0: new PPS source ptp0
[    1.151397] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.178396] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.181025] mmc0: CQHCI version 5.10
[    1.222330] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.303552] mmc0: Command Queue Engine enabled
[    1.303569] mmc0: new HS200 MMC card at address 0001
[    1.304268] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.308790]  mmcblk0: p1
[    1.309447] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.310831] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.312104] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[    1.372920] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    1.373814] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2024-04-10T11:05:13 UTC (1712747113)
[    1.374088] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.374209] pca953x 1-0022: using AI
[   1.380066] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.380741] mmc1: CQHCI version 5.10
[    1.381511] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.381521] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.388264] ALSA device list:
[    1.388273]   No soundcards found.
[    1.421963] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.437878] Waiting for root device PARTUUID=83c21bb6-02...
[    1.477290] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    1.477788] mmcblk1: mmc1:aaaa SS32G 29.7 GiB
[    1.480827]  mmcblk1: p1 p2
[    1.497220] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    1.497283] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    1.499420] devtmpfs: mounted
[    1.500023] Freeing unused kernel memory: 1792K
[    1.500119] Run /sbin/init as init process
[    1.788476] NET: Registered PF_INET6 protocol family
[    1.789412] Segment Routing with IPv6
[    1.789443] In-situ OAM (IOAM) with IPv6
[    1.821486] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    1.822035] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    1.868113] systemd[1]: Hostname set to <am62axx-evm>.
[    1.957842] systemd-sysv-generator[173]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    1.958899] systemd-sysv-generator[173]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    1.959961] systemd-sysv-generator[173]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    1.960212] systemd-sysv-generator[173]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    2.213251] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.267129] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.330461] systemd[1]: Queued start job for default target Graphical Interface.
[  OK  ] Created slice Slice /system/getty    2.333300] systemd[1]: Created slice Slice /system/getty.
0m.
[  OK  ] Created slice Slice /system/modprob[    2.353204] systemd[1]: Created slice Slice /system/modprobe.
e.
[  OK  ] Created slice Slice /system/serial-[    2.369131] systemd[1]: Created slice Slice /system/serial-getty.
getty.
[  OK  ] Created slice User and Session Slic[    2.383614] systemd[1]: Created slice User and Session Slice.
e.
[  OK  ] Started Dispatch Password …ts to [    2.398423] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Forward Password R…uests [    2.415328] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Path Units.
[    2.434453] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
[0m.
[  OK  ] Reached target Slice Units.
[    2.459143] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Swaps.
[    2.469673] systemd[1]: Reached target Swaps.
[  OK  ] Listening on RPCbind Server Activat[    2.491453] systemd[1]: Listening on RPCbind Server Activation Socket.
ion Socket.
[  OK  ] Reached target RPC Port Mapper.[    2.506194] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Listening on Process Core Dump Sock[    2.530262] systemd[1]: Listening on Process Core Dump Socket.
et.
[  OK  ] Listening on initctl Compatibility [    2.544462] systemd[1]: Listening on initctl Compatibility Named Pipe.
Named Pipe.
[  OK  ] Listening on Journal Audit Socket    2.559821] systemd[1]: Listening on Journal Audit Socket.
0m.
[  OK  ] Listening on Journal Socket (/dev/l[    2.574629] systemd[1]: Listening on Journal Socket (/dev/log).
og).
[  OK  ] Listening on Journal Socket.
[    2.589702] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Network Service Netlin[    2.601138] systemd[1]: Listening on Network Service Netlink Socket.
k Socket.
[  OK  ] Listening on udev Control Socket    2.622262] systemd[1]: Listening on udev Control Socket.
m.
[  OK  ] Listening on udev Kernel Socket[    2.636564] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on User Database Manager [    2.650600] systemd[1]: Listening on User Database Manager Socket.
Socket.
         Mounting Huge Pages File System...
[    2.679413] systemd[1]: Mounting Huge Pages File System...
[    2.692895] systemd[1]: Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
[    2.729395] systemd[1]: Mounting Kernel Debug File System...
[    2.741087] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
         Mounting Temporary Directory /tmp...[    2.747587] systemd[1]: Mounting Temporary Directory /tmp...
[    2.771933] systemd[1]: Starting Create List of Static Device Nodes...
         Starting Load Kernel Module configfs...
[    2.790456] systemd[1]: Starting Load Kernel Module configfs...
         Starting Load Kernel Module drm...
[    2.805501] systemd[1]: Starting Load Kernel Module drm...
         Starting Load Kernel Module fuse...
[    2.819757] systemd[1]: Starting Load Kernel Module fuse...
[    2.847926] fuse: init (API version 7.37)
         Starting Start psplash boot splash screen.[    2.873721] systemd[1]: Starting Start psplash boot splash screen...
         Starting RPC Bind...[    2.910697] systemd[1]: Starting RPC Bind...
[    2.921353] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
         Starting Journal Service...[    2.922334] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    2.922348] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    2.924553] systemd[1]: Starting Journal Service...
         Starting Load Kernel Modules...
[    2.974699] systemd[1]: Starting Load Kernel Modules...
         Starting Generate network …ts from Kernel co[    2.988242] systemd[1]: Starting Generate network units from Kernel command line...
mmand line...
[    2.999871] cryptodev: loading out-of-tree module taints kernel.
[    3.000873] cryptodev: driver 1.12 loaded.
         Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems...
[0m...
[    3.032829] systemd[1]: Starting Coldplug All udev Devices...
[    3.033851] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[  OK  ] Started RPC Bind.[    3.059510] systemd[1]: Started RPC Bind.
[  OK  ] Started Journal Service.
[    3.072614] systemd[1]: Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    3.303279] systemd-journald[186]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[    3.671050] random: crng init done
[  OK  ] Finished Load/Save Random Seed.
[    3.864377] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
[  OK  ] Found device /dev/ttyS2.
[    3.895454] mc: Linux media interface: v0.10
[    3.920299] videodev: Linux video capture interface: v2.00
[    3.966821] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
[    3.976107] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
[    3.979597] platform 79000000.r5f: configured R5F for remoteproc mode
[  OK  ] Started Network Time Synchronizatio[    3.979932] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
n.
[    3.984137] remoteproc remoteproc0: 7e000000.dsp is available
[    3.996855] remoteproc remoteproc1: 79000000.r5f is available
[    4.002519] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[  OK  ] Reached target System Initializatio[    4.003609] platform 78000000.r5f: configured R5F for IPC-only mode
n.
[    4.003736] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
[  OK  ] Started Daily Cleanup of Temporary [    4.005981] remoteproc remoteproc2: 78000000.r5f is available
Directories.
[    4.006079] remoteproc remoteproc2: attaching to 78000000.r5f
[    4.007310] platform 78000000.r5f: R5F core initialized in IPC-only mode
[  OK  ] Reached target System Time Set.[    4.007340] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@9c800000
[    4.013686] virtio_rpmsg_bus virtio0: rpmsg host is online
[    4.013729] rproc-virtio rproc-virtio.5.auto: registered virtio0 (type 7)
[    4.013736] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
[    4.014467] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[  OK  ] Started Daily rotation of log files[    4.025953] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
[    4.025970] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
[    4.099288] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[  OK  ] Reached target Timer Units.
[    4.100178] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    4.103468] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[    4.104439] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[  OK  ] Listening on D-Bus System Message B[    4.108406] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
us Socket.
[    4.119047] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[    4.119750] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    4.192124] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
         Starting Docker Socket for the API...
[    4.193885] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    4.196952] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    4.210073] i2c i2c-1: Added multiplexed i2c bus 3
[  OK  ] Listening on dropbear.socket.
[    4.238484] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[  OK  ] Listening on PC/SC Smart Card Daemo[    4.246455] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    4.247102] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    4.248204] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    4.273847] e5010 fd20000.e5010: Device registered as /dev/video2
[    4.362167] remoteproc remoteproc0: powering up 7e000000.dsp
[    4.362189] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11046992
[    4.370727] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
[    4.380111] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node c7x-dma-memory@99800000
[    4.380791] virtio_rpmsg_bus virtio1: rpmsg host is online
[    4.380824] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
[    4.380831] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
[    4.388219] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    4.388459] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
         Starting Console System Startup Logging...[    4.388600] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    4.391054] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    4.395209] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
         Starting D-Bus System Message Bus...
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[    4.720640] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[  OK  ] Finished Console System Startup Logging.
[    4.769180] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[    4.838254] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    4.838290] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1
[    4.840852] xhci-hcd xhci-hcd.9.auto: USB3 root hub has no ports
[    4.840869] xhci-hcd xhci-hcd.9.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[    4.842627] xhci-hcd xhci-hcd.9.auto: irq 549, io mem 0x31100000
[  OK  ] Finished Reboot and dump vmcore via[    4.845515] hub 1-0:1.0: USB hub found
 kexec.
[    4.845555] hub 1-0:1.0: 1 port detected
[  OK  ] Started D-Bus System Message Bus.
[    5.125378] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
[  OK  ] Reached target Hardware activated U[    5.158283] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
SB gadget.
         Starting Save/Restore Sound Card State...
[  OK  ] Started Job spooling tools.
[    5.201819] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[    5.216148] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[  OK  ] Started Periodic Command Scheduler.
[    5.240177] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
         Starting DEMO...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
         Starting Expand the rootfs…ll size of the bo[    5.324334] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
ot device....
[  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
[    5.347415] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
         Starting User Login Management...
[  OK  ] Started TEE Supplicant.
         Starting Telnet Server...
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Reached target Preparation for Network.
[  OK  ] Reached target Sound Card.
         Starting Network Configuration...
[  OK  ] Started DEMO.
[  OK  ] Started Telephony service.
[  OK  ] Finished Expand the rootfs…full size of the boot device..
[  OK  ] Started User Login Management.
[  OK  ] Listening on [    5.685557] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Load/Save RF …itch Status /dev/rfkill Watch.
[    5.694885] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.704376] Bluetooth: Core ver 2.22
[    5.704488] NET: Registered PF_BLUETOOTH protocol family
[    5.704491] Bluetooth: HCI device and connection manager initialized
[    5.704508] Bluetooth: HCI socket layer initialized
[    5.704517] Bluetooth: L2CAP socket layer initialized
[    5.704533] Bluetooth: SCO socket layer initialized
[  OK  ] Started Network Configuration.
         Starting Network Name Resolution...
[    5.841555] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    5.841578] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    6.018428] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[    6.047826] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland…ositor, as a system service...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Found device /dev/mmcblk0p1.
         Starting File System Check on /dev/mmcblk0p1...
         Starting User Database Manager...
[  OK  ] Started User Database Manager.
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
         Mounting /run/media/rootfs-mmcblk0p1...
[    6.876171] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Mounted /run/media/rootfs-mmcblk0p1.
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[    7.082327] audit: type=1006 audit(1712747119.208:2): pid=707 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    7.082348] audit: type=1300 audit(1712747119.208:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc0041de8 a2=4 a3=ffff974ef020 items=0 ppid=1 pid=707 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[    7.082360] audit: type=1327 audit(1712747119.208:2): proctitle="(systemd)"
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
         Mounting /run/media/BOOT-mmcblk1p1...
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston.
[    7.854549] audit: type=1006 audit(1712747119.980:3): pid=665 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[    7.854571] audit: type=1300 audit(1712747119.980:3): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc0041de8 a2=4 a3=ffff974ef020 items=0 ppid=1 pid=665 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[    7.854585] audit: type=1327 audit(1712747119.980:3): proctitle="(weston)"
[  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
[    8.932598] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  OK  ] Started containerd container runtim[    8.932648] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
e.
[  OK  ] Started Weston, a Wayland …mpositor, as a system service.
         Starting EdgeAI OOB demos...
         Stopping Weston, a Wayland…ositor, as a system service...
[  OK  ] Stopped Weston, a Wayland …mpositor, as a system service.
[  OK  ] Started EdgeAI OOB demos.
[   11.022363] audit: type=1701 audit(1712747123.148:4): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=830 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
[  OK  ] Created slice Slice /system/systemd-coredump.
[  OK  ] Started Process Core Dump (PID 882/UID 0).
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libeigen-dev
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5sensors-plugins
        libqt5sensors-qmlplugins
        libqt5sensors5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libqt5webchannel-plugins
        libqt5webchannel-qmlplugins
        libqt5webchannel5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquick3d-plugins
        qtquick3d-qmlplugins
        qtquick3d
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am62axx-evm -
Arago 2023.10 am62axx-evm -
am62axx-evm login:
As per TI-Forum suggestion, we have checked the "RAT" data in the "syscfg" file for the project and checked, but still we get a failure in firmware loading during the Linux board boot-up time
TI-Forum link: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1340174/sk-am62a-lp-sk-am62a-lp-real-time-core-usecase/5136718#5136718
I am also attaching our "linker.cmd" file for your reference.
1526.linker.zip
Please check above details and let us know if missed any steps or data in above details. Also, kindly provide appropriate RAT details for our EVK: SK-AM62A-LP to run this "EPWM Duty Cycle" example along with Linux.
We need to run/test an ePWM sample example from MCU-R5-Core along with Linux running A-53-Core (SK-AM62A-LP EVK). Please help on it.
Nisarg
  • Hello Nisarg,
    Did you add the resource table to your linker.cmd file, as documented on that page you linked to? I do not see a resource table section in your linker.cmd file.
    Refer to section "Update the linker.cmd file"
    FYI, I am currently working on restructuring that page so that it is a bit easier to follow (based on feedback like your thread here). One of the changes I'm making is to move section "Option 2: Manually add an empty resource table to the MCU+ Project" to another page, so that the linker.cmd file updates show up right below section "Option 1: Add Linux IPC to an MCU+ Project".
    Nick
  • Did you add the resource table to your linker.cmd file, as documented on that page you linked to? I do not see a resource table section in your linker.cmd file.
    Hello Nick,
    As per your suggestions, I have updated the "linker.cmd" file in  "EPWM Duty Cycle" example and rebuild the firmware. I tried to run the "EPWM Duty Cycle" example on our EVK (SK-AM62A-LP), but we are facing the same error in R5 firmware loading with Linux during boot-up time. (Failed to load program segments: -22)
    Please check the below attachment (the updated "linker.cmd" file) and let us know if any other changes are required apart from this for our EVK (SK-AM62A-LP). Please check and provide your input on it.
    1803.linker.zip
    Boot-Up log:-
    Boot-up-Log-Firmware-load-programm-failed-Final-log.txt
             Stopping Session c2 of User root...
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Save/Restore Sound Card State...
             Stopping Job spooling tools...
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping containerd container runtime...
             Stopping Periodic Command Scheduler...
    [  OK  ] Stopped DEMO.
             Stopping SSH Per-Connectio…erver (10.70.226.207:62882)...
             Stopping Getty on tty1...
             Stopping irqbalance daemon...
             Stopping Reboot and dump vmcore via kexec...
             Stopping Netperf Benchmark Server...
             Stopping NFS status monitor for NFSv2/3 locking....
             Stopping Telephony service...
    [  OK  ] Stopped Expand the rootfs …full size of the boot device..
    [  OK  ] Stopped SSH Per-Connection Server (10.70.226.207:62882).
    [  OK  ] Stopped Session c2 of User root.
             Stopping User Manager for UID 0...
    [  OK  ] Stopped User Manager for UID 0.
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
    [ 1134.969262] EXT4-fs (mmcblk0p1): unmounting filesystem.
    [ 1135.226046] systemd-shutdown[1]: Syncing filesystems and block devices.
    [ 1135.253266] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [ 1135.266012] systemd-journald[189]: Received SIGTERM from PID 1 (systemd-shutdow).
    [ 1135.267826] audit: type=1335 audit(1713271935.800:6): pid=189 uid=0 auid=4294967295 tty=(none) ses=4294967295 comm="systemd-journal" exe="/lib/systemd/systemd-journald" nl-mcgrp=1 op=disconnect res=1
    [ 1135.296456] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [ 1135.307503] systemd-shutdown[1]: Unmounting file systems.
    [ 1135.309751] [1597]: Remounting '/' read-only with options 'n/a'.
    [ 1135.338003] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [ 1135.346351] systemd-shutdown[1]: All filesystems unmounted.
    [ 1135.346369] systemd-shutdown[1]: Deactivating swaps.
    [ 1135.346531] systemd-shutdown[1]: All swaps deactivated.
    [ 1135.346540] systemd-shutdown[1]: Detaching loop devices.
    [ 1135.350085] systemd-shutdown[1]: All loop devices detached.
    [ 1135.350098] systemd-shutdown[1]: Stopping MD devices.
    [ 1135.350372] systemd-shutdown[1]: All MD devices stopped.
    [ 1135.350381] systemd-shutdown[1]: Detaching DM devices.
    [ 1135.350594] systemd-shutdown[1]: All DM devices detached.
    [ 1135.350604] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [ 1135.360698] systemd-shutdown[1]: Syncing filesystems and block devices.
    [ 1135.361588] systemd-shutdown[1]: Rebooting.
    [ 1135.442147] reboot: Restarting system
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    639 bytes read in 25 ms (24.4 KiB/s)
    16169472 bytes read in 696 ms (22.2 MiB/s)
    55447 bytes read in 30 ms (1.8 MiB/s)
    Starting kernel ...
    [    0.000000] Memory: 2819276K/4194300K available (10368K kernel code, 1198K rwdata, 2328K rodata, 1792K init, 420K bss, 785200K reserved, 589824K cma-reserved)
    [    0.000212] Console: colour dummy device 80x25
    [    0.590321] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.590330] pid_max: default: 32768 minimum: 301
    [    0.590401] LSM: Security Framework initializing
    [    0.590498] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.590514] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.591814] rcu: Hierarchical SRCU implementation.
    [    0.591819] rcu:     Max phase no-delay instances is 400.
    [    0.644251] Platform MSI: msi-controller@1820000 domain created
    [    0.644422] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.644493] EFI services will not be available.
    [    0.644677] smp: Bringing up secondary CPUs ...
    [    0.645240] Detected VIPT I-cache on CPU1
    [    0.645325] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.645340] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.645381] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.695363] Detected VIPT I-cache on CPU2
    [    0.695435] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.695448] GICv3: CPU2: using allocated LPI pending table @0x0000000880060000
    [    0.695479] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.721229] Detected VIPT I-cache on CPU3
    [    0.721305] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.721318] GICv3: CPU3: using allocated LPI pending table @0x0000000880070000
    [    0.721345] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.721399] smp: Brought up 1 node, 4 CPUs
    [    0.721406] SMP: Total of 4 processors activated.
    [    0.755588] CPU features: detected: 32-bit EL0 Support
    [    0.755592] CPU features: detected: CRC32 instructions
    [    0.755633] CPU: All CPU(s) started at EL2
    [    0.755635] alternatives: applying system-wide alternatives
    [    0.756753] devtmpfs: initialized
    [    0.767028] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.767047] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.781225] pinctrl core: initialized pinctrl subsystem
    [    0.781717] DMI not present or invalid.
    [    0.782155] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.790516] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.790764] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.790939] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.791003] audit: initializing netlink subsys (disabled)
    [    0.791106] audit: type=2000 audit(0.788:1): state=initialized audit_enabled=0 res=1
    [    0.791598] thermal_sys: Registered thermal governor 'step_wise'
    [    0.791773] ASID allocator initialised with 65536 entries
    [    0.802694] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.804696] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.812892] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.812900] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.812904] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.812907] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.812911] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.812913] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.812917] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.812920] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.820147] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.821671] iommu: Default domain type: Translated
    [    0.821679] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.821971] SCSI subsystem initialized
    [    0.822264] usbcore: registered new interface driver usbfs
    [    0.822306] usbcore: registered new interface driver hub
    [    0.822334] usbcore: registered new device driver usb
    [    0.822743] pps_core: LinuxPPS API ver. 1 registered
    [    0.822746] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.822763] PTP clock support registered
    [    0.822889] EDAC MC: Ver: 3.0.0
    [    0.823536] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.823720] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.823869] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.823925] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    0.824187] FPGA manager framework
    [ [   1.026192] printk: console [ttyS2] printing thread started
        0.824276] Advanced Linux Sound Architecture Driver Initialized.
    [    1.026206] printk: console [ttyS2] enabled
    [    1.026211] printk: bootconsole [ns16550a0] disabled
    [    1.037990] printk: bootconsole [ns16550a0] printing thread stopped
    [    1.040624] spi-nand spi0.0: Winbond SPI NAND was found.
    [    1.040633] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
    [    1.040851] 7 fixed-partitions partitions found on MTD device spi0.0
    [    1.040859] Creating 7 MTD partitions on "spi0.0":
    [    1.040864] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.042378] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.044413] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.047466] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.048733] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.050001] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
    [    1.096427] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.133130] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.134623] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.134666] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.134782] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.134787] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.135244] pps pps0: new PPS source ptp0
    [    1.135477] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.162504] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.164977] mmc0: CQHCI version 5.10
    [    1.170772] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.170886] pca953x 1-0022: using AI
    [    1.176686] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.177394] mmc1: CQHCI version 5.10
    [    1.178142] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.178154] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [   1.184772] ALSA device list:
    [    1.184781]   No soundcards found.
    [    1.206319] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.211888] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.255217] Waiting for root device PARTUUID=83c21bb6-02...
    [    1.267105] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.267637] mmcblk1: mmc1:aaaa SS32G 29.7 GiB
    [    1.270645]  mmcblk1: p1 p2
    [    1.287091] mmc0: Command Queue Engine enabled
    [    1.287120] mmc0: new HS200 MMC card at address 0001
    [    1.287395] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.287462] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.287579] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.289827] devtmpfs: mounted
    [    1.290526] Freeing unused kernel memory: 1792K
    [    1.290650] Run /sbin/init as init process
    [    1.291765]  mmcblk0: p1
    [    1.292300] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.293352] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.294284] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
    [    1.536968] systemd[1]: System time before build time, advancing clock.
    [    1.585642] NET: Registered PF_INET6 protocol family
    [    1.586677] Segment Routing with IPv6
    [    1.586709] In-situ OAM (IOAM) with IPv6
    [    1.609341] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    1.609849] systemd[1]: Detected architecture arm64.
    [    1.653727] systemd[1]: Hostname set to <am62axx-evm>.
    [    1.745640] systemd-sysv-generator[174]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.747181] systemd-sysv-generator[174]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.748248] systemd-sysv-generator[174]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.748425] systemd-sysv-generator[174]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.004718] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.059198] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.122731] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    2.125674] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    2.145307] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    2.160169] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    2.174714] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password …ts to [    2.189509] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password R…uests [    2.206425] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.225549] systemd[1]: Reached target Path Units.
    [0m.
    [    2.250254] systemd[1]: Reached target Slice Units.
    [    2.260797] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    2.282317] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    2.297296] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    2.320399] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    2.334573] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    2.350919] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    2.365758] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [    2.380783] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    2.392224] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [  OK  ] Listening on udev Control Socket    2.413267] systemd[1]: Listening on udev Control Socket.
    m.
    [  OK  ] Listening on udev Kernel Socket[    2.427679] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    2.441708] systemd[1]: Listening on User Database Manager Socket.
    Socket.
    [    2.470537] systemd[1]: Mounting Huge Pages File System...
    [    2.484024] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.501823] systemd[1]: Mounting Kernel Debug File System...
    [    2.513531] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    2.544576] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    2.559556] systemd[1]: Starting Create List of Static Device Nodes...
    m...
    [    2.577522] systemd[1]: Starting Load Kernel Module configfs...
    [    2.592620] systemd[1]: Starting Load Kernel Module drm...
    [    2.606819] systemd[1]: Starting Load Kernel Module fuse...
    [    2.646805] fuse: init (API version 7.37)
             Starting Start psplash boot splash screen.[    2.652812] systemd[1]: Starting Start psplash boot splash screen...
    [    2.674543] systemd[1]: Starting RPC Bind...
    [    2.683269] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
             Starting Journal Service...[    2.684342] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.684357] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.686664] systemd[1]: Starting Journal Service...
    [    2.735758] systemd[1]: Starting Load Kernel Modules...
             Starting Generate network …ts from Kernel co[    2.749231] systemd[1]: Starting Generate network units from Kernel command line...
    mmand line...
    [    2.759757] cryptodev: loading out-of-tree module taints kernel.
    [    2.760768] cryptodev: driver 1.12 loaded.
    [0m...
             Starting Coldplug All udev Devices...[    2.796882] systemd[1]: Starting Coldplug All udev Devices...
    [    2.797683] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    2.822918] systemd[1]: Started RPC Bind.
    [    2.832326] systemd[1]: Started Journal Service.
    [    3.057072] systemd-journald[188]: Received client request to flush runtime journal.
    [    3.498177] random: crng init done
    [    3.626249] systemd-journald[188]: Oldest entry in /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [  OK  ] Started Network Time Synchronizatio[    3.626272] systemd-journald[188]: /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal: Journal header limits reached or header out-of-date, rotating.
    n.
    [    3.674983] mc: Linux media interface: v0.10
    [    3.690791] videodev: Linux video capture interface: v2.00
    [    3.720678] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    3.766798] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    3.771846] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [    3.787035] remoteproc remoteproc0: 7e000000.dsp is available
    [    3.795793] platform 79000000.r5f: configured R5F for remoteproc mode
    [    3.797143] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [    3.797161] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    3.801562] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    3.803807] remoteproc remoteproc1: 79000000.r5f is available
    [    3.805739] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    3.807231] platform 78000000.r5f: configured R5F for IPC-only mode
    [  OK  ] Reached target System Time Set.[    3.807344] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    3.809511] remoteproc remoteproc2: 78000000.r5f is available
    [    3.809601] remoteproc remoteproc2: attaching to 78000000.r5f
    [    3.832269] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    3.832460] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    3.833062] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    3.833223] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    3.833232] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [  OK  ] Started Daily rotation of log files[    3.837767] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    3.932040] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [  OK  ] Reached target Timer Units.[    3.941068] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    3.941202] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    3.943375] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    k Activation Socket.
    [    3.943744] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    3.948924] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    3.950213] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [  OK  ] Listening on D-Bus System Message B[    3.955410] i2c i2c-1: Added multiplexed i2c bus 3
    us Socket.
    [    3.963503] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    3.973291] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
    [    4.006431] e5010 fd20000.e5010: Device registered as /dev/video2
    [    4.029373] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    4.029935] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    4.033664] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    4.039497] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    4.040463] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    4.040498] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
    [    4.042192] systemd-journald[188]: Time jumped backwards, rotating.
    [  OK  ] Listening on PC/SC Smart Card Daemo[    4.163837] remoteproc remoteproc0: powering up 7e000000.dsp
    [    4.163857] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11046992
    n Activation Socket.
    [    4.168957] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
    [    4.175871] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    4.177738] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    4.177797] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    4.177806] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
    [    4.181845] remoteproc remoteproc1: powering up 79000000.r5f
             Starting Weston socket...
    [    4.181866] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 1323588
    [    4.182546] remoteproc remoteproc1: bad phdr da 0x9ca08000 mem 0x264e0
    [    4.182559] remoteproc remoteproc1: Failed to load program segments: -22
    [    4.195362] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
             Starting Console System Startup Logging...[    4.195463] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    4.195818] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    4.196180] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    4.196293] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    4.516502] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    4.592462] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    4.643713] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    4.643753] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [  OK  ] Finished Reboot and dump vmcore via[    4.643964] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
     kexec.
    [    4.643973] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [    4.666139] xhci-hcd xhci-hcd.4.auto: irq 427, io mem 0x31100000
    [    4.669283] hub 1-0:1.0: USB hub found
    [    4.669333] hub 1-0:1.0: 1 port detected
    [  OK  ] Reached target Hardware activated U[    4.936691] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    SB gadget.
    [    4.960038] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Periodic Command Scheduler mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [0m.
    [    5.016607] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
             Starting DEMO...
    [    5.047899] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
             Starting Expand the rootfs…ll size of the boot device....
    [  OK  ] Started strongSwan IPsec I…IKEv2 [    5.126026] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    5.145562] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    5.164998] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    5.287430] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [  OK  ] Listening on [    5.458886] Bluetooth: Core ver 2.22
    [    5.459011] NET: Registered PF_BLUETOOTH protocol family
    [    5.459016] Bluetooth: HCI device and connection manager initialized
    [    5.459033] Bluetooth: HCI socket layer initialized
    [    5.459041] Bluetooth: L2CAP socket layer initialized
    [    5.459062] Bluetooth: SCO socket layer initialized
    [    5.495506] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.505148] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.625921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    5.625944] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    5.845995] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    5.865523] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    6.792370] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [    6.884293] audit: type=1006 audit(12.343:2): pid=707 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    6.884315] audit: type=1300 audit(12.343:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffeffc95b8 a2=4 a3=ffff952c9020 items=0 ppid=1 pid=707 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    6.884327] audit: type=1327 audit(12.343:2): proctitle="(systemd)"
    [    7.665626] audit: type=1006 audit(13.124:3): pid=660 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [    7.665648] audit: type=1300 audit(13.124:3): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffeffc95b8 a2=4 a3=ffff952c9020 items=0 ppid=1 pid=660 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    7.666188] audit: type=1327 audit(13.124:3): proctitle="(weston)"
    [  OK  ] Started containerd container runtime.
    [    8.740719] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [    8.740767] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   10.770351] audit: type=1701 audit(16.229:4): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=830 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libeigen-dev
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts5
            libqt5sensors5
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg5
            libqt5webchannel5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring2
            m4-dev
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity
            qtdeclarative-tools
            qtdeclarative
            qtlocation-examples
            qtlocation-plugins
            qtlocation
            qtmultimedia
            qtquick3d-plugins
            qtquick3d
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland
            tar
            which
     _____                    _____           _         _
                  |___|                    |___|
    am62axx-evm login: root
    [   14.340924] audit: type=1006 audit(19.799:5): pid=1349 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   14.340945] audit: type=1300 audit(19.799:5): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffeffc95b8 a2=1 a3=0 items=0 ppid=1 pid=1349 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   14.340957] audit: type=1327 audit(19.799:5): proctitle="(systemd)"
    root@am62axx-evm:/opt/edgeai-gst-apps# cat /sys/kernel/debug/remoteproc/remoteproc1/trace0
    cat: /sys/kernel/debug/remoteproc/remoteproc1/trace0: No such file or directory
    root@am62axx-evm:/opt/edgeai-gst-apps# head /sys/class/remoteproc/remoteproc*/name
    ==> /sys/class/remoteproc/remoteproc0/name <==
    7e000000.dsp
    ==> /sys/class/remoteproc/remoteproc1/name <==
    79000000.r5f
    ==> /sys/class/remoteproc/remoteproc2/name <==
    78000000.r5f
    root@am62axx-evm:/opt/edgeai-gst-apps# [   40.601361] systemd-journald[188]: Oldest entry in /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [   40.601384] systemd-journald[188]: /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal: Journal header limits reached or header out-of-date, rotating.
    root@am62axx-evm:/opt/edgeai-gst-apps# dmesg -n1
    root@am62axx-evm:/opt/edgeai-gst-apps# ls -al /lib/firmware/am62a-mcu-r5f0_0-fw
    lrwxrwxrwx 1 root root 104 Apr 16 12:51 /lib/firmware/am62a-mcu-r5f0_0-fw -> /opt/edgeai-gst-apps/NISARG/ePWM/16-04-2024/epwm_duty_cycle_am62ax-sk_r5fss0-0_freertos_ti-arm-clang.out
    root@am62axx-evm:/opt/edgeai-gst-apps# ls -la /opt/edgeai-gst-apps/NISARG/ePWM/16-04-2024/epwm_duty_cycle_am62ax-sk_r5fss0-0_freertos_ti-arm-clang.out
    -rw-r--r-- 1 root root 1323588 Apr 16 12:51 /opt/edgeai-gst-apps/NISARG/ePWM/16-04-2024/epwm_duty_cycle_am62ax-sk_r5fss0-0_freertos_ti-arm-clang.out
    Lon Snippet:-
    Nisarg
  • Hello Nisarg,
    I am taking a closer look at bad phdr da 0x9ca08000 mem 0x264e0 now. In your linker.cmd file, it looks like you are defining DDR_FS_STUB and DDR at offset 0x9ca0_8000?
    First off, you should not have a DDR_FS_STUB in your MCU R5F if I understand the MCU+ projects properly - that is specifically for the DM R5F core.
    Second, that overlaps with the region of memory that is allocated for the DM R5F core by default. Please double check your memory allocations to make sure that the MCU R5F memory region is NOT and the DM R5F memory region do not overlap (or wkup_r5fss0 in the Linux devicetree). You should also make sure that the memory allocations in your linker.cmd file match up with your memory allocations in Linux.
    Default allocations from the Linux side:
    k3-am62a7-sk.dts
                    wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9c800000 {
                            compatible = "shared-dma-pool";
                            reg = <0x00 0x9c800000 0x00 0x100000>;
                            no-map;
                    wkup_r5fss0_core0_memory_region: r5f-dma-memory@9c900000 {
                            reg = <0x00 0x9c900000 0x00 0x01e00000>;
                            no-map;
                    mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@9b800000 {
                            reg = <0x00 0x9b800000 0x00 0x100000>;
                            no-map;
                    mcu_r5fss0_core0_memory_region: r5f-dma-memory@9b900000 {
                            reg = <0x00 0x9b900000 0x00 0x0f00000>;
                            no-map;
    Nick
  • I am taking a closer look at bad phdr da 0x9ca08000 mem 0x264e0 now. In your linker.cmd file, it looks like you are defining DDR_FS_STUB and DDR at offset 0x9ca0_8000?
    Hello Nick,
    We are using "epwm_duty_cycle" sample example available in TI MCU+SDK for EVK (SK-AM62A-LP)
    Example Path: "mcu_plus_sdk_am62ax_09_01_00_39\examples\drivers\epwm\epwm_duty_cycle\am62ax-sk\r5fss0-0_freertos\ti-arm-clang"
    Note: "linker.cmd" is already available in the imported project file. ("epwm_duty_cycle" TI sample example project)
    We have tried your suggested changes
    1) Remove "DDR_FS_STUB" entries from existing "linker.cmd" file
    2) Added "DDR_0" entry as per your suggested link
    Also enable "IPC" for the remote core Linux  (We need to run/test an ePWM sample example from MCU-R5-Core along with Linux running A-53-Core (SK-AM62A-LP EVK))
    With the above changes, we built the code and checked the MCU-R5 firmware on boot-up, and we got an error on board boot-up time. ( Failed to load program segments: -22)
    Boot-up log:-
    [ 4.129860] remoteproc remoteproc1: powering up 79000000.r5f
    [ 4.129881] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 1321760
    [ 4.131282] remoteproc remoteproc1: bad phdr da 0x43c00000 mem 0x8000
    [ 4.131298] remoteproc remoteproc1: Failed to load program segments: -22
    Full Log Attached:
    Boot-Up-log-DDR0-entry.txt
    [  OK  ] Removed slice Slice /system/modprobe.
    [  OK  ] Removed slice Slice /system/systemd-coredump.
    [  OK  ] Stopped target Graphical Interface.
    [  OK  ] Stopped target Multi-User System.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Sound Card.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Stopped target Hardware activated USB gadget.
    [.         Stopping Serial Getty on ttyS2...
             Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
             Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf...
             Stopping User Login Management...
             Stopping Load/Save Random Seed...
             Stopping TEE Supplicant...
             Stopping Telnet Server...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped irqbalance daemon.
    [  OK  ] Stopped Telephony service.
    [  OK  ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
    [  OK  ] Stopped User Login Management.
    [  OK  ] Stopped TEE Supplicant.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped Netperf Benchmark Server.
    [  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
    [  OK  ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
    [  OK  ] Stopped containerd container runtime.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped SSH Per-Connection Server (10.70.236.127:52702).
    [  OK  ] Stopped SSH Per-Connection Server (10.70.236.127:52703).
    [  OK  ] Stopped Save/Restore Sound Card State.
    [  OK  ] Stopped Reboot and dump vmcore via kexec.
    [  OK  ] Stopped Load/Save Random Seed.
    [  OK  ] Stopped Telnet Server.
    [  OK  ] Removed slice Slice /system/dropbear.
    [  OK  ] Removed slice Slice /system/getty.
    [  OK  ] Removed slice Slice /system/serial-getty.
    [  OK  ] Stopped target Host and Network Name Lookups.
             Stopping Permit User Sessions...
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Name Resolution...
    [  OK  ] Stopped Network Name Resolution.
             Stopping Network Configuration...
    [  OK  ] Stopped Network Configuration.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
    [  OK  ] Closed Network Service Netlink Socket.
    [  OK  ] Closed Weston socket.
             Stopping D-Bus System Message Bus...
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Stopped target System Initialization.
             Starting Console System Reboot Logging...
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Stopped Load Kernel Modules.
             Stopping Network Time Synchronization...
             Stopping Record System Boot/Shutdown in UTMP...
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Finished Console System Reboot Logging.
    [  OK  ] Stopped Record System Boot/Shutdown in UTMP.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /media/ram...
             Unmounting /run/media/BOOT-mmcblk1p1...
             Unmounting /run/media/rootfs-mmcblk0p1...
             Unmounting Temporary Directory /tmp...
    [  233.037216] EXT4-fs (mmcblk0p1): unmounting filesystem.
             Unmounting /var/volatile...
    [  OK  ] Unmounted /media/ram.
    [  OK  ] Unmounted /run/media/BOOT-mmcblk1p1.
    [  OK  ] Unmounted /run/media/rootfs-mmcblk0p1.
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p1.
    [  OK  ] Stopped File System Check on /dev/mmcblk1p1.
    [  OK  ] Removed slice Slice /system/systemd-fsck.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Reboot.
    [  OK  ] Reached target System Reboot.
    [  233.290757] systemd-shutdown[1]: Syncing filesystems and block devices.
    [  233.316721] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [  233.330663] systemd-journald[189]: Received SIGTERM from PID 1 (systemd-shutdow).
    [  233.332953] audit: type=1335 audit(1713531375.583:5): pid=189 uid=0 auid=4294967295 tty=(none) ses=4294967295 comm="systemd-journal" exe="/lib/systemd/systemd-journald" nl-mcgrp=1 op=disconnect res=1
    [  233.360216] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [  233.372249] systemd-shutdown[1]: Unmounting file systems.
    [  233.374461] [1558]: Remounting '/' read-only with options 'n/a'.
    [  233.403857] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [  233.411026] systemd-shutdown[1]: All filesystems unmounted.
    [  233.411045] systemd-shutdown[1]: Deactivating swaps.
    [  233.411210] systemd-shutdown[1]: All swaps deactivated.
    [  233.411219] systemd-shutdown[1]: Detaching loop devices.
    [  233.414794] systemd-shutdown[1]: All loop devices detached.
    [  233.414809] systemd-shutdown[1]: Stopping MD devices.
    [  233.415084] systemd-shutdown[1]: All MD devices stopped.
    [  233.415094] systemd-shutdown[1]: Detaching DM devices.
    [  233.415307] systemd-shutdown[1]: All DM devices detached.
    [  233.415317] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [  233.425699] systemd-shutdown[1]: Syncing filesystems and block devices.
    [  233.426592] systemd-shutdown[1]: Rebooting.
    [  233.506947] reboot: Restarting system
    U-Boot SPL 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
    am62a_init: board_init_f done
    SPL initial stack usage: 17040 bytes
    am62a_init: spl_boot_device: devstat = 0x243 bootmedia = 0x8 bootindex = 0
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
    NOTICE:  BL31: Built : 09:34:15, Aug 24 2023
    U-Boot 2023.04-gb0d717b732 (Dec 06 2023 - 15:11:45 +0000)
    SoC:   AM62AX SR1.0 HS-FS
    Model: Texas Instruments AM62A7 SK
    DRAM:  2 GiB (effective 4 GiB)
    Core:  58 devices, 28 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    Working FDT set to 88000000
       Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK
    Working FDT set to 8feef000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.46-rt13-gb871cdee8c (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Thu Dec  7 23:52:13 UTC 2023
    [    0.000000] Machine model: Texas Instruments AM62A7 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x00000000997fffff]
    [    0.000000]   node   0: [mem 0x0000000099800000-0x000000009b7fefff]
    [    0.000000]   node   0: [mem 0x000000009b800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a2ffffff]
    [    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
    [    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s44928 r8192 d28800 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032191
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=83c21bb6-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: 0xffff80000840dd70
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000214] Console: colour dummy device 80x25
    [    0.590327] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.590336] pid_max: default: 32768 minimum: 301
    [    0.590407] LSM: Security Framework initializing
    [    0.590502] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.590520] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.591817] rcu: Hierarchical SRCU implementation.
    [    0.591822] rcu:     Max phase no-delay instances is 400.
    [    0.591857] printk: bootconsole [ns16550a0] printing thread started
    [    0.644257] Platform MSI: msi-controller@1820000 domain created
    [    0.644430] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.644499] EFI services will not be available.
    [    0.644682] smp: Bringing up secondary CPUs ...
    [    0.645242] Detected VIPT I-cache on CPU1
    [    0.645327] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.645342] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.645382] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.695364] Detected VIPT I-cache on CPU2
    [    0.695433] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.695446] GICv3: CPU2: using allocated LPI pending table @0x0000000880060000
    [    0.695475] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.721233] Detected VIPT I-cache on CPU3
    [    0.721310] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.721322] GICv3: CPU3: using allocated LPI pending table @0x0000000880070000
    [    0.721349] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.721402] smp: Brought up 1 node, 4 CPUs
    [    0.750787] SMP: Total of 4 processors activated.
    [    0.750792] CPU features: detected: 32-bit EL0 Support
    [    0.750795] CPU features: detected: CRC32 instructions
    [    0.750833] CPU: All CPU(s) started at EL2
    [    0.750835] alternatives: applying system-wide alternatives
    [    0.751960] devtmpfs: initialized
    [    0.762151] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.762169] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.775686] pinctrl core: initialized pinctrl subsystem
    [    0.776211] DMI not present or invalid.
    [    0.776626] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.784447] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.784630] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.784790] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.784853] audit: initializing netlink subsys (disabled)
    [    0.784953] audit: type=2000 audit(0.782:1): state=initialized audit_enabled=0 res=1
    [    0.785458] thermal_sys: Registered thermal governor 'step_wise'
    [    0.785629] ASID allocator initialised with 65536 entries
    [    0.796584] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.798592] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.806794] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.806801] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.806805] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.806808] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.806812] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.806814] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.806818] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.806821] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.812629] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.814168] iommu: Default domain type: Translated
    [    0.814175] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.814494] SCSI subsystem initialized
    [    0.814797] usbcore: registered new interface driver usbfs
    [    0.814837] usbcore: registered new interface driver hub
    [    0.814864] usbcore: registered new device driver usb
    [    0.815255] pps_core: LinuxPPS API ver. 1 registered
    [    0.815258] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.815272] PTP clock support registered
    [    0.815420] EDAC MC: Ver: 3.0.0
    [    0.816055] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.816221] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.816402] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.816459] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    0.816748] FPGA manager framework
    [    1.02577[4] printk: console [ttyS2] printing thread started
        0.816875] Advanced Linux Sound Architecture Driver Initialized.
    [    1.025790] printk: console [ttyS2] enabled
    [    1.025794] printk: bootconsole [ns16550a0] disabled
    [    1.037567] printk: bootconsole [ns16550a0] printing thread stopped
    [    1.040145] spi-nand spi0.0: Winbond SPI NAND was found.
    [    1.040154] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
    [    1.040370] 7 fixed-partitions partitions found on MTD device spi0.0
    [    1.040378] Creating 7 MTD partitions on "spi0.0":
    [    1.040383] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.041919] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.044077] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.047135] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.048413] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.049668] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
    [    1.095530] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.131743] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.133295] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.133335] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.133448] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.133453] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.133897] pps pps0: new PPS source ptp0
    [    1.134123] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.161118] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.163627] mmc0: CQHCI version 5.10
    [    1.169180] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.169293] pca953x 1-0022: using AI
    [   1.175066] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.175728] mmc1: CQHCI version 5.10
    [    1.176510] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.176523] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.182880] ALSA device list:
    [    1.182889]   No soundcards found.
    [    1.204431] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.216938] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.225264] Waiting for root device PARTUUID=83c21bb6-02...
    [    1.271452] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.271996] mmcblk1: mmc1:aaaa SS32G 29.7 GiB
    [    1.275015]  mmcblk1: p1 p2
    [    1.278353] mmc0: Command Queue Engine enabled
    [    1.278365] mmc0: new HS200 MMC card at address 0001
    [    1.278797] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.282766]  mmcblk0: p1
    [    1.283216] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.284241] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.285160] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
    [    1.301617] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.301679] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.303908] devtmpfs: mounted
    [    1.304495] Freeing unused kernel memory: 1792K
    [    1.304592] Run /sbin/init as init process
    [    1.552286] systemd[1]: System time before build time, advancing clock.
    [    1.599751] NET: Registered PF_INET6 protocol family
    [    1.600661] Segment Routing with IPv6
    [    1.600694] In-situ OAM (IOAM) with IPv6
    [    1.623375] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    1.623936] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    1.669598] systemd[1]: Hostname set to <am62axx-evm>.
    [    1.768343] systemd-sysv-generator[174]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.769372] systemd-sysv-generator[174]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.770427] systemd-sysv-generator[174]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    1.770693] systemd-sysv-generator[174]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.026476] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.080825] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.144470] systemd[1]: Queued start job for default target Graphical Interface.
    [  OK  ] Created slice Slice /system/getty    2.147369] systemd[1]: Created slice Slice /system/getty.
    0m.
    [  OK  ] Created slice Slice /system/modprob[    2.166934] systemd[1]: Created slice Slice /system/modprobe.
    e.
    [  OK  ] Created slice Slice /system/serial-[    2.181855] systemd[1]: Created slice Slice /system/serial-getty.
    getty.
    [  OK  ] Created slice User and Session Slic[    2.196340] systemd[1]: Created slice User and Session Slice.
    e.
    [  OK  ] Started Dispatch Password …ts to [    2.211110] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Forward Password R…uests [    2.228052] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Reached target Path Units.
    [    2.247168] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems.
    [0m.
    [  OK  ] Reached target Slice Units.
    [    2.271858] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Swaps.
    [    2.282368] systemd[1]: Reached target Swaps.
    [  OK  ] Listening on RPCbind Server Activat[    2.304183] systemd[1]: Listening on RPCbind Server Activation Socket.
    ion Socket.
    [  OK  ] Reached target RPC Port Mapper.[    2.318914] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Listening on Process Core Dump Sock[    2.341927] systemd[1]: Listening on Process Core Dump Socket.
    et.
    [  OK  ] Listening on initctl Compatibility [    2.356178] systemd[1]: Listening on initctl Compatibility Named Pipe.
    Named Pipe.
    [  OK  ] Listening on Journal Audit Socket    2.371543] systemd[1]: Listening on Journal Audit Socket.
    0m.
    [  OK  ] Listening on Journal Socket (/dev/l[    2.386352] systemd[1]: Listening on Journal Socket (/dev/log).
    og).
    [  OK  ] Listening on Journal Socket.
    [    2.401386] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Network Service Netlin[    2.412835] systemd[1]: Listening on Network Service Netlink Socket.
    k Socket.
    [    2.433656] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [  OK  ] Listening on udev Kernel Socket[    2.448253] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on User Database Manager [    2.462307] systemd[1]: Listening on User Database Manager Socket.
    Socket.
    [    2.491119] systemd[1]: Mounting Huge Pages File System...
    [    2.504662] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.523528] systemd[1]: Mounting Kernel Debug File System...
    [    2.535297] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    2.553135] systemd[1]: Mounting Temporary Directory /tmp...
             Starting Create List of Static Device Nodes    2.568035] systemd[1]: Starting Create List of Static Device Nodes...
    m...
    [    2.586109] systemd[1]: Starting Load Kernel Module configfs...
    [    2.601137] systemd[1]: Starting Load Kernel Module drm...
    [    2.615379] systemd[1]: Starting Load Kernel Module fuse...
             Starting Start psplash boot splash screen.[    2.643913] systemd[1]: Starting Start psplash boot splash screen...
    [    2.644198] fuse: init (API version 7.37)
    [    2.676391] systemd[1]: Starting RPC Bind...
    [    2.685068] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    2.686026] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.686040] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.688283] systemd[1]: Starting Journal Service...
    [    2.721026] systemd[1]: Starting Load Kernel Modules...
             Starting Generate network …ts from Kernel co[    2.736968] systemd[1]: Starting Generate network units from Kernel command line...
    [    2.744109] cryptodev: loading out-of-tree module taints kernel.
    mmand line...
    [    2.745107] cryptodev: driver 1.12 loaded.
             Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems...
    [0m...
    [    2.788394] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    2.798480] systemd[1]: Starting Coldplug All udev Devices...
    [  OK  ] Started RPC Bind.
    [    2.818388] systemd[1]: Started RPC Bind.
    [  OK  ] Started Journal Service.
    [    2.827891] systemd[1]: Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    3.057410] systemd-journald[187]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [    3.494766] random: crng init done
    [  OK  ] Finished Load/Save Random Seed.
    [    3.640145] mc: Linux media interface: v0.10
    [  OK  ] Found device /dev/ttyS2.
    [    3.682785] videodev: Linux video capture interface: v2.00
    [    3.697746] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    3.735630] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    3.739973] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    3.741768] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    3.759557] remoteproc remoteproc0: 7e000000.dsp is available
    [    3.771181] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
    [    3.778434] platform 79000000.r5f: configured R5F for remoteproc mode
    [    3.778785] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    3.780687] remoteproc remoteproc1: 79000000.r5f is available
    [  OK  ] Started Network Time Synchronizatio[    3.788845] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    n.
    [    3.793229] platform 78000000.r5f: configured R5F for IPC-only mode
    [    3.793345] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    3.793850] remoteproc remoteproc2: 78000000.r5f is available
    [    3.793911] remoteproc remoteproc2: attaching to 78000000.r5f
    [  OK  ] Started Daily rotation of log files[    3.799965] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    3.799996] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    3.800504] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    3.800535] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [    3.800542] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    3.801019] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    3.840536] systemd-journald[187]: Oldest entry in /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [    3.840560] systemd-journald[187]: /run/log/journal/b60c46610d614ddca834e12c472aea88/system.journal: Journal header limits reached or header out-of-date, rotating.
    [    3.865275] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [  OK  ] Listening on D-Bus System Message B[    3.865319] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
    us Socket.
    [    3.870519] systemd-journald[187]: Time jumped backwards, rotating.
    [    3.939403] e5010 fd20000.e5010: Device registered as /dev/video0
    [    3.941397] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
             Starting Docker Socket for the API...
    [    3.951654] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    3.951914] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    3.954550] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [  OK  ] Listening on dropbear.socket.[    3.954568] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    3.957232] i2c i2c-1: Added multiplexed i2c bus 3
    [    3.958405] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    3.963794] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [  OK  ] Listening on PC/SC Smart Card Daemo[    3.970098] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    3.970653] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    3.970847] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    3.972342] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    3.973662] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
             Starting Weston socket...[    3.978998] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    3.985130] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    4.135812] remoteproc remoteproc0: powering up 7e000000.dsp
    [    4.135832] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11046992
             Starting Console System Startup Logging...[    4.148653] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
    [    4.180784] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    4.182099] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    4.182161] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    4.182169] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
    [    4.182939] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    4.183099] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
             Starting D-Bus System Message Bus...[    4.184020] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    4.185964] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    4.190072] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    4.395879] tps6598x 0-003f: Unable to find the interrupt, switching to polling
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.
    [  OK  ] Finished Console System Startup Logging.
    [    4.571111] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    4.603350] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    4.603391] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    4.603596] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
    [    4.603606] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [    4.609405] xhci-hcd xhci-hcd.4.auto: irq 428, io mem 0x31100000
    [    4.611163] hub 1-0:1.0: USB hub found
    [    4.611199] hub 1-0:1.0: 1 port detected
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [  OK  ] Reached target Hardware activated USB gadget.
    [    4.922585] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [    4.961006] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Periodic Command Scheduler.
             Starting DEMO...
             Starting Print notice about GPLv3 packages...
    [    5.011419] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework    5.035318] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    m...
    [    5.046423] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
    [  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
             Starting User Login Management...
    [  OK  ] Started TEE Supplicant.
             Starting Telnet Server...
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Finished IPv6 Packet Filtering Fram[    5.119619] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    ework.
    [  OK  ] Finished IPv4 Packet Filtering Fram[    5.145484] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    ework.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Reached target Preparation for Network.
    [  OK  ] Reached target Sound Card.
             Starting Network Configuration...
    [  OK  ] Started DEMO.
    [  OK  ] Started Telephony service.
    [  OK  ] Finished Expand the rootfs…full size of the boot device..
    [  OK  ] Started User Login Management.
    [    5.446020] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.457383] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.468833] Bluetooth: Core ver 2.22
    [    5.468963] NET: Registered PF_BLUETOOTH protocol family
    [    5.468968] Bluetooth: HCI device and connection manager initialized
    [  OK  ] Listening on Load/Save RF …itch S[    5.468987] Bluetooth: HCI socket layer initialized
    tatus /dev/rfkill Watch.
    [    5.468995] Bluetooth: L2CAP socket layer initialized
    [    5.469014] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Network Configuration.
             Starting Network Name Resolution...
    [    5.596859] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    5.596882] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    5.774586] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    5.794501] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
             Starting User Database Manager...
    [  OK  ] Finished Synchronize System and HW clocks.
    [  OK  ] Started User Database Manager.
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/rootfs-mmcblk0p1...
    [    6.620486] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/rootfs-mmcblk0p1.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [    6.828249] audit: type=1006 audit(12.462:2): pid=708 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    6.828271] audit: type=1300 audit(12.462:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd9fd0488 a2=4 a3=ffffb0832020 items=0 ppid=1 pid=708 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    6.828283] audit: type=1327 audit(12.462:2): proctitle="(systemd)"
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [  OK  ] Started Session c1 of User weston.
    [    7.609884] audit: type=1006 audit(13.244:3): pid=666 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [    7.609905] audit: type=1300 audit(13.244:3): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd9fd0488 a2=4 a3=ffffb0832020 items=0 ppid=1 pid=666 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    7.609917] audit: type=1327 audit(13.244:3): proctitle="(weston)"
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [    8.675326] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [    8.675369] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  OK  ] Started Weston, a Wayland …mpositor, as a system service.
             Starting EdgeAI OOB demos...
             Stopping Weston, a Wayland…ositor, as a system service...
    [  OK  ] Stopped Weston, a Wayland …mpositor, as a system service.
    [  OK  ] Started EdgeAI OOB demos.
    [   10.748730] audit: type=1701 audit(16.382:4): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=831 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
    [  OK  ] Created slice Slice /system/systemd-coredump.
    [  OK  ] Started Process Core Dump (PID 883/UID 0).
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libeigen-dev
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5sensors-plugins
            libqt5sensors-qmlplugins
            libqt5sensors5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libqt5webchannel-plugins
            libqt5webchannel-qmlplugins
            libqt5webchannel5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring2
            m4-dev
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62axx-evm -
    Arago 2023.10 am62axx-evm -
    am62axx-evm login:
    And no trace-log observed in "remoteproc1/trace0"
    "epwm_duty_cycle" TI sample example is still not working directly on the EVK Board (SK-AM62A-LP).
    We need to run/test an ePWM TI sample example ("epwm_duty_cycle") from MCU-R5-Core along with Linux running A-53-Core (SK-AM62A-LP EVK))
    Please provide all the required changes to run this example ("epwm_duty_cycle")  on EVK (SK-AM62A-LP) along with Linux running A-53-Core.
    Attaching the files:
    1) linker.cmd
     6837.linker.zip
    2) Board dts file (k3-am62a7-sk.dts)
     k3-am62a7-sk.zip
    Nisarg
  • Hello Nisarg,
    What is going on?
    You are trying to ask Linux to load a project that was created for the DM R5F, not the MCU R5F. That is why Linux is throwing an error around
    HSM_RAM : ORIGIN = 0x43C00000 LENGTH = 0x3FF00
    You need to load an MCU R5F project into the MCU R5F, not a DM R5F project.
    More details
    The documentation around that examples/drivers/epwm/epwm_duty_cycle/am62ax-sk/r5fss0-0_freertos project is not very clear, but that project was created for the DM R5F, not the MCU R5F.
    If we take a look at the Linux IPC example, you'll see that folder r5fss0-0_freertos is for the DM R5F, while folder mcu-r5fss0-0_freertos is for the MCU R5F:
    mcu_plus_sdk_am62ax_09_01_00_39/examples/drivers/ipc/ipc_rpmsg_echo_linux/am62ax-sk$ ls
    c75ss0-0_freertos  mcu-r5fss0-0_freertos  r5fss0-0_freertos
    It might be easier for you to start with a different project that was built for the MCU R5F.
    The AM62Ax academy's MCU module has some helpful getting started information if you need some guidance:
    https://dev.ti.com/tirex/explore/node?node=A__AJi7DQYi3ubqRUvJuSJ60w__AM62A-ACADEMY__WeZ9SsL__LATEST
    Nick
  • Hello Nick,
    If possible, kindly provide the "EPWM Duty Cycle" TI example for the MCU-R5. We need a TI-Sample example for "EPWM Duty Cycle" on MCU-R5.(EVK (SK-AM62A-LP) along with Linux running A-53-Core.)
    Nisarg
  • Hello Nisarg,
    I am reassigning your thread to one of my MCU+ focused team members to provide additional guidance.
    Nick
  • Hi Nisarg, I will check with my colleagues internally to explore potential solutions.
    One option, I see, is to leverage the existing project “hello_world\am62ax-sk\mcu-r5fss0-0_freertos” as a baseline. From there, you can add/port “epwm_duty_cycle\am62ax-sk\r5fss0-0_freertos” project.
    Thank you,
    Paula
  • Nisarg, also a question, could you explain us or give us more information why do you need to use MCU-R5F for EPWM?
    thank you,
    Paula
    thank you,
    Paula
    Hello Paula,
    We need to generate the PWM for a particular operation, and that PWM signal should be generated for a defined time in microsecond accuracy. Lets say if 100us is configured, then on some event we want to drive PWM for only 100us and not for more time. So we are considering this handling at the MCU-R5 core as it can provide accuracy in microseconds.
    If there are any registers available in PWM and if we can achieve the same functionality from the A53 core, then it will work for us. Please suggest if the same thing is available.
    Nisarg
  • Hi Nisarg, thanks a lot for your reply. I wonder if you see any issues/limitations for your use case if you use DM R5F to drive EPWM.
    Paula
  • Hello Paula,
    Currently, we are using MCU-R5 for our firmware and other interface drivers, so for that reason, we need to use EPWM in the MCU-R5 core.  We want to drive ePWM based on some MCU-GPIO events on MCU-R5 so that we do not prefer to use DM-R5. Additionally, the TRM document also mentioned that ePWM can be access on MCU-R5 via RAT. So we are looking for PWM access sample code on the MCU-R5 core.
    Another option for us is to just enable/disable ePWM through MCU-R5, which is already preconfigured through the A53 core via the Linux driver. Is this case possible?
    Nisarg
  • Hi Nisarg,
    The second option is not supported by TI. We only support a peripheral being controlled by a single software instance. More info in the multicore academy module here: https://dev.ti.com/tirex/explore/node?node=A__ASuOzonPJpyBzKFrqEN1fg__AM62A-ACADEMY__WeZ9SsL__LATEST
    For the first option, as you know, we currently don't have a demo supported and tested inside our MCU-SDK. However, I did a quick porting exercise. Please take below just as a guidance to help you continue. In parallel, I am internally checking if there is any HW limitation for supporting EPWM on MCU-RF5, and, if not, if this demo could be added in a future MCU-SDK.
    Porting Exercise:
    1) Used MCU-RF5 as a baseline.
    • I was able to add EPWM to MCU-RF5 Hello World sysconfig file.
    • I also added "epwm_duty_cycle.c" and "main.c" from DM-RF5 EPWM example.
    • I removed Hello_world files from being built.
    • In new added main.c I commented sciServer_init() inside main_thread().
    • some snapshots below
    2) Add "epwm" to MCU-RF5 driver library
    • In order to add "epwm" to driver "libs". I added below to source\drivers\makefile.am62ax.r5f.ti-arm-clang (similar to what I saw in source\drivers\makefile.am62ax.dm-r5f.ti-arm-clang)
    • Then, I rebuilt all the libs, but, if you prefer, you can check in makefile.am62ax how to only build R5F's drivers lib.
    • For rebuilding libs I did:
    cd C:\ti\mcu_plus_sdk_am62ax_09_02_00_38
    gmake libs PROFILE=debug
    • After above changes I am able to rebuild modified HelloWorld.
    • I tested using a scope, and I see output 1KHz signal in J3's pin 24 (expansion header)
    As mentioned above, I am currently checking internally to confirm, but in the meantime, if you want, you can give a try to above and see if this works for you.
    thank you,
    Paula
