TDA4VE-Q1: DSI cannot output with UART3 (AB26 & AD28)
Part Number: TDA4VE-Q1
Hi Expert,
We use J721S2 and PSDK8.4,
Currently our target board can display via DSI, And originally the AB26 & AD28 pin are configured to I2C.
After configuring AB26 & AD28 to the UART of A72 Linux, the user application access the UART linux device normally, but the DSI doesn't work well.
Are there any additional settings or any restrictions for this usecase ??
Eten
  • Hi Eten,
    DSI displays have a I2C interface that could be used for initializing DSI controller and touch. Below schematic is an example of the connection from TI's common processor board.
    Most likely there is a resource conflict between UART and DSI on your board, so you would have to use different pins for either UART or DSI.
    Takuma
  • Hi Takuma,
    Because our target board is connected another MCU to control DSI output panel, we don't need this I2C pins of DSI.
    Is there a way to modify the DSI driver to disable the I2C control and then adjust the use of these pins, AB26 & AD28, from I2C to UART ?
    Thank you !!
    Eten
  • Hi Eten,
    If the DSI panel is connected to a different MCU and not to the TDA4VE, then changing pins on TDA4VE-side should not affect DSI behavior on the separate MCU.
    Can you confirm whether on your schematic that DSI panel has no connections to TDA4VE?
    Takuma
  • Hi Takuma,
    The external MCU is connected to TDA4VE via the UART3 (AB26 & AD28) to control the DSI pannel.
    TDA4VE is responsible for transmitting video data through DSI.
    Eten
  • Hi Eten,
    Are AB26 and AD28 connected to DSI panel in anyway?
    If they are not connected, which I2C pins are connected to DSI instead of AB26 and AD28?
    Takuma
  • Hi Takuma,
    The following is the simple diagram.
    Eten
  • Hi Eten,
    Ah, I see. Thank you for the diagram. That clears up my misunderstandings.
    Could you share dmesg logs for when the AB26 and AD28 pins are configured for I2C and DSI is functional? Additionally, could you share logs for when AB26 and AD28 pins are configured for UART and DSI is nonfunctional?
    Takuma
  • Hi Takuma,
    I2C :
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.120-g95b90aa828 (eten@eten-Parallels-Virtual-Platform) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Apr 16 16:56:14 CST 2024
    [    0.000000] Machine model: Texas Instruments J721S2 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 111 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@b2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000df800000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@df800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 736 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009fffeffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b0ffffff]
    [    0.000000]   node   0: [mem 0x00000000b1000000-0x00000000b1ffffff]
    [    0.000000]   node   0: [mem 0x00000000b2000000-0x00000000b9ffffff]
    [    0.000000]   node   0: [mem 0x00000000ba000000-0x00000000df7fffff]
    [    0.000000]   node   0: [mem 0x00000000df800000-0x00000000e37fffff]
    [    0.000000]   node   0: [mem 0x00000000e3800000-0x00000000fffeffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008adffffff]
    [    0.000000]   node   0: [mem 0x00000008ae000000-0x00000009fffeffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009fffeffff]
    [    0.000000] On node 0 totalpages: 131070
    [    0.000000]   DMA zone: 32 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 32767 pages, LIFO batch:3
    [    0.000000]   Normal zone: 96 pages used for memmap
    [    0.000000]   Normal zone: 98303 pages, LIFO batch:3
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s50008 r8192 d72872 u131072
    [    0.000000] pcpu-alloc: s50008 r8192 d72872 u131072 alloc=2*65536
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 130942
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=4e18bf44-2a26-a44b-a74c-4b40c7b46ef4 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 7, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbff0000-0x00000000ffff0000] (64MB)
    [    0.000000] Memory: 6412608K/8388480K available (10944K kernel code, 1366K rwdata, 4352K rodata, 1856K init, 737K bss, 1975872K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c00b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00c0000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008369] Console: colour dummy device 80x25
    [    0.012935] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023606] pid_max: default: 32768 minimum: 301
    [    0.028356] LSM: Security Framework initializing
    [    0.033110] Mount-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.040862] Mountpoint-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.050124] rcu: Hierarchical SRCU implementation.
    [    0.055205] Platform MSI: msi-controller@1820000 domain created
    [    0.061387] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070682] EFI services will not be available.
    [    0.075449] smp: Bringing up secondary CPUs ...
    [    0.088591] Detected PIPT I-cache on CPU1
    [    0.088616] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088628] GICv3: CPU1: using allocated LPI pending table @0x00000008c00d0000
    [    0.088669] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088735] smp: Brought up 1 node, 2 CPUs
    [    0.118084] SMP: Total of 2 processors activated.
    [    0.122889] CPU features: detected: 32-bit EL0 Support
    [    0.128145] CPU features: detected: CRC32 instructions
    [    0.142483] CPU: All CPU(s) started at EL2
    [    0.146687] alternatives: patching kernel code
    [    0.151768] devtmpfs: initialized
    [    0.158632] KASLR disabled due to lack of seed
    [    0.163306] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.173273] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.180417] pinctrl core: initialized pinctrl subsystem
    [    0.185992] DMI not present or invalid.
    [    0.190290] NET: Registered protocol family 16
    [    0.195201] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.202691] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.210864] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.219246] thermal_sys: Registered thermal governor 'step_wise'
    [    0.219249] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.225825] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.239474] ASID allocator initialised with 65536 entries
    [    0.256434] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.263293] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.270050] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278052] cryptd: max_cpu_qlen set to 1000
    [    0.284320] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.293218] vsys_3v3: supplied by evm_12v0
    [    0.297584] vsys_5v0: supplied by evm_12v0
    [    0.301940] vdd_mmc1: supplied by vsys_3v3
    [    0.306315] vdd_sd_dv_alt: supplied by vsys_3v3
    [    0.311429] iommu: Default domain type: Translated
    [    0.316577] SCSI subsystem initialized
    [    0.320639] mc: Linux media interface: v0.10
    [    0.325014] videodev: Linux video capture interface: v2.00
    [    0.330644] pps_core: LinuxPPS API ver. 1 registered
    [    0.335714] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.345051] PTP clock support registered
    [    0.349070] EDAC MC: Ver: 3.0.0
    [    0.352845] FPGA manager framework
    [    0.356352] Advanced Linux Sound Architecture Driver Initialized.
    [    0.363031] clocksource: Switched to clocksource arch_sys_counter
    [    0.369454] VFS: Disk quotas dquot_6.6.0
    [    0.373506] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.383319] Carveout Heap: Exported 600 MiB at 0x00000000ba000000
    [    0.389617] NET: Registered protocol family 2
    [    0.394296] IP idents hash table entries: 131072 (order: 4, 1048576 bytes, linear)
    [    0.403908] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.412678] TCP established hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.420981] TCP bind hash table entries: 65536 (order: 4, 1048576 bytes, linear)
    [    0.428999] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.435803] UDP hash table entries: 4096 (order: 1, 131072 bytes, linear)
    [    0.442832] UDP-Lite hash table entries: 4096 (order: 1, 131072 bytes, linear)
    [    0.450377] NET: Registered protocol family 1
    [    0.455182] RPC: Registered named UNIX socket transport module.
    [    0.461257] RPC: Registered udp transport module.
    [    0.466062] RPC: Registered tcp transport module.
    [    0.470865] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.477449] PCI: CLS 0 bytes, default 64
    [    0.481848] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.492463] Initialise system trusted keyrings
    [    0.497100] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.505358] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.511674] NFS: Registering the id_resolver key type
    [    0.516876] Key type id_resolver registered
    [    0.521147] Key type id_legacy registered
    [    0.525269] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.532116] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.539760] 9p: Installing v9fs 9p2000 file system support
    [    0.564685] Key type asymmetric registered
    [    0.568874] Asymmetric key parser 'x509' registered
    [    0.573873] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.581433] io scheduler mq-deadline registered
    [    0.586057] io scheduler kyber registered
    [    0.591295] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.597443] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.605416] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.611701] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.619501] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.631686] brd: module loaded
    [    0.637769] loop: module loaded
    [    0.641334] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [    0.649263] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.120-g95b90aa828 #1
    [    0.656551] Hardware name: Texas Instruments J721S2 EVM (DT)
    [    0.662328] Call trace:
    [    0.664830]  dump_backtrace+0x0/0x1a0
    [    0.668566]  show_stack+0x18/0x68
    [    0.671949]  dump_stack+0xd0/0x12c
    [    0.675419]  sysfs_warn_dup+0x60/0x80
    [    0.679153]  sysfs_create_dir_ns+0xe0/0xf8
    [    0.683335]  kobject_add_internal+0x98/0x288
    [    0.687691]  kobject_add+0x94/0x100
    [    0.691250]  device_add+0xe0/0x740
    [    0.694720]  platform_device_add+0x100/0x238
    [    0.699077]  platform_device_register_full+0xcc/0x150
    [    0.704237]  dma_buf_phys_init+0x6c/0x9c
    [    0.708238]  do_one_initcall+0x54/0x1b8
    [    0.712153]  kernel_init_freeable+0x220/0x2a0
    [    0.716600]  kernel_init+0x14/0x114
    [    0.720156]  ret_from_fork+0x10/0x34
    [    0.723818] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
    [    0.737013] megasas: 07.714.04.00-rc1
    [    0.742529] tun: Universal TUN/TAP device driver, 1.6
    [    0.747961] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.754369] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.760439] sky2: driver version 1.30
    [    0.764742] VFIO - User Level meta-driver version: 0.3
    [    0.770479] i2c /dev entries driver
    [    0.774647] sdhci: Secure Digital Host Controller Interface driver
    [    0.780977] sdhci: Copyright(c) Pierre Ossman
    [    0.785671] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.791909] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.798253] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.805369] optee: probing for conduit method.
    [    0.809944] optee: revision 3.17 (15a746d2)
    [    0.810084] optee: dynamic shared memory is enabled
    [    0.824906] optee: initialized driver
    [    0.829747] NET: Registered protocol family 17
    [    0.834370] 9pnet: Installing 9P2000 support
    [    0.838769] Key type dns_resolver registered
    [    0.843238] Loading compiled-in X.509 certificates
    [    0.850836] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.857212] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.865176] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.891828] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.897967] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.904079] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.910436] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.917257] pca953x 3-0020: using no AI
    [    0.943568] pca953x 3-0027: supply vcc not found, using dummy regulator
    [    0.950373] pca953x 3-0027: using no AI
    [    0.954342] pca953x 3-0027: failed writing register
    [    0.959384] pca953x: probe of 3-0027 failed with error -121
    [    0.965145] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.971546] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    0.980140] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    0.989504] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    0.998095] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    1.007092] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.016969] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.023731] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.032534] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.042691] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.049450] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.057144] omap8250 40a00000.serial: failed to get alias
    [    1.063208] printk: console [ttyS2] disabled
    [    1.067605] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 22, base_baud = 3000000) is a 8250
    [    1.076348] printk: console [ttyS2] enabled
    [    1.084784] printk: bootconsole [ns16550a0] disabled
    [    1.097190] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.143040] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.152667] dp83812_read_straps: Strap is 0x4280
    [    1.385941] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
    [    1.394840] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.408537] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
    [    1.455034] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.463907] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    1.472031] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.485806] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
    [    1.595528] mmc0: CQHCI version 5.10
    [    1.599587] mmc1: CQHCI version 5.10
    [    1.604512] davinci_gpio 42100000.gpio: IRQ index 0 not found
    [    1.610268] davinci_gpio 42100000.gpio: error -ENXIO: IRQ not populated
    [    1.618795] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.625614] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.632429] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.639234] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.640139] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.653245] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.661148] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.671077] ti-udma 31150000.dma-controller: Channels: 48 (tchan: 24, rchan: 24, gp-rflow: 16)
    [    1.682391] spi-nor spi0.0: unrecognized JEDEC id bytes: 2c 5b 19 10 41 00
    [    1.689283] spi-nor: probe of spi0.0 failed with error -2
    [    1.695356] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.738536] mmc0: Command Queue Engine enabled
    [    1.739041] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.742977] mmc0: new HS200 MMC card at address 0001
    [    1.752622] dp83812_read_straps: Strap is 0x4280
    [    1.755948] mmcblk0: mmc0:0001 S0J59X 119 GiB
    [    1.764818] mmcblk0boot0: mmc0:0001 S0J59X partition 1 31.5 MiB
    [    1.770849] mmcblk0boot1: mmc0:0001 S0J59X partition 2 31.5 MiB
    [    1.776923] mmcblk0rpmb: mmc0:0001 S0J59X partition 3 4.00 MiB, chardev (237:0)
    [    1.786292] GPT:Primary header thinks Alt. header is not at the end of the disk.
    [    1.793754] GPT:8388607 != 248643583
    [    1.797372] GPT:Alternate GPT header not at the end of the disk.
    [    1.803417] GPT:8388607 != 248643583
    [    1.807038] GPT: Use GNU Parted to correct GPT errors.
    [    1.812179]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
    [    1.988973] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
    [    1.997894] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.011229] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.018033] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.025252] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.031633] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    2.042027] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
    [    2.087034] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.095933] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    2.104062] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.117335] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [    2.124105] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    2.130372] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    2.137501] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    2.143738] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.153907] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
    [    2.161708] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    2.172909] ALSA device list:
    [    2.175879]   No soundcards found.
    [    2.185564] EXT4-fs (mmcblk0p4): recovery complete
    [    2.190361] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
    [    2.198472] VFS: Mounted root (ext4 filesystem) on device 179:4.
    [    2.204908] devtmpfs: mounted
    [    2.208175] Freeing unused kernel memory: 1856K
    [    2.212736] Run /sbin/init as init process
    [    2.216823]   with arguments:
    [    2.216825]     /sbin/init
    [    2.216827]   with environment:
    [    2.216829]     HOME=/
    [    2.216831]     TERM=linux
    [    2.271579] systemd[1]: System time before build time, advancing clock.
    [    2.299593] NET: Registered protocol family 10
    [    2.304623] Segment Routing with IPv6
    [    2.316933] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.338702] systemd[1]: Detected architecture arm64.
    [    2.375397] systemd[1]: Set hostname to <j721s2-evm>.
    [    2.522932] systemd[1]: Configuration file /etc/systemd/system/can_rec_250.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.571688] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.578461] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.590793] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.600755] systemd[1]: Created slice system-getty.slice.
    [    2.623124] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.630260] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    2.651102] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.658127] systemd[1]: Created slice User and Session Slice.
    [    2.679243] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    2.703167] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.727158] systemd[1]: Reached target Paths.
    [    2.743103] systemd[1]: Reached target Remote File Systems.
    [    2.763082] systemd[1]: Reached target Slices.
    [    2.779090] systemd[1]: Reached target Swap.
    [    2.795506] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    2.819122] systemd[1]: Reached target RPC Port Mapper.
    [    2.843557] systemd[1]: Listening on Process Core Dump Socket.
    [    2.867245] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.898579] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    2.906967] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.927424] systemd[1]: Listening on Journal Socket.
    [    2.947429] systemd[1]: Listening on Network Service Netlink Socket.
    [    2.971311] systemd[1]: Listening on udev Control Socket.
    [    2.991230] systemd[1]: Listening on udev Kernel Socket.
    [    3.014176] systemd[1]: Mounting Huge Pages File System...
    [    3.037860] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.065542] systemd[1]: Mounting Kernel Debug File System...
    [    3.092777] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.118362] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    3.146064] systemd[1]: Starting ab partition setup...
    [    3.167436] systemd[1]: Starting RPC Bind...
    [    3.185853] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.199715] systemd[1]: Starting Journal Service...
    [    3.220611] systemd[1]: Starting Load Kernel Modules...
    [    3.242195] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.255394] EXT4-fs (mmcblk0p2): recovery complete
    [    3.262356] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.267332] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
    [    3.278409] systemd[1]: Starting udev Coldplug all Devices...
    [    3.302993] systemd[1]: Started RPC Bind.
    [    3.307871] EXT4-fs (mmcblk0p6): recovery complete
    [    3.317085] systemd[1]: Started Journal Service.
    [    3.322015] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
    [    3.360904] EXT4-fs (mmcblk0p8): recovery complete
    [    3.366755] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
    [    3.393517] EXT4-fs (mmcblk0p10): recovery complete
    [    3.398981] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
    [    3.429777] EXT4-fs (mmcblk0p12): recovery complete
    [    3.435286] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    3.549554] systemd-journald[165]: Received client request to flush runtime journal.
    [    3.575165] urandom_read_iter: 56 callbacks suppressed
    [    3.575169] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    3.683624] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.707125] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.227742] pvrsrvkm: disagrees about version of symbol module_layout
    [    4.247765] wave5: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.273192] vdec 4210000.video-codec: sram-size not found
    [    4.278770] vdec 4210000.video-codec: sram node not found
    [    4.316764] pinctrl-single 11c000.pinctrl: pin PIN46 already requested by c200000.ethernet; cannot claim for a000000.dp-bridge
    [    4.385671] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    4.396822] pvrsrvkm: disagrees about version of symbol module_layout
    [    4.420185] pinctrl-single 11c000.pinctrl: pin-46 (a000000.dp-bridge) status -22
    [    4.484541] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    4.519528] CAN device driver interface
    [    4.589272] pinctrl-single 11c000.pinctrl: could not request pin 46 (PIN46) from group dp0-pins-default  on device pinctrl-single
    [    4.647687] remoteproc remoteproc0: 64800000.dsp is available
    [    4.651496] cdns-mhdp8546 a000000.dp-bridge: Error applying setting, reverse things back
    [    4.662769] cdns-mhdp8546: probe of a000000.dp-bridge failed with error -22
    [    4.710246] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    4.730164] remoteproc remoteproc0: attaching to 64800000.dsp
    [    4.841314] remoteproc remoteproc0: unsupported resource 65538
    [    4.883183] platform 41000000.r5f: configured R5F for IPC-only mode
    [    4.940344] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    4.992446] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [    5.016602] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.135294] remoteproc remoteproc1: 41000000.r5f is available
    [    5.175381] urandom_read_iter: 32 callbacks suppressed
    [    5.175385] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.195678]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    5.205845] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.214001] dp83812_read_straps: Strap is 0x4280
    [    5.358713] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.366127] remoteproc remoteproc1: attaching to 41000000.r5f
    [    5.395529] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.401067] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    5.450169] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.487758]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.534390]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    5.572626] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [    5.621217] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    5.632665] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    5.663086] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    5.684242] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.703199] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
    [    5.717289] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.724889] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    5.743724]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    5.755084] random: crng init done
    [    5.758488] random: 23 urandom warning(s) missed due to ratelimiting
    [    5.759576] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    5.792563] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    5.854059] remoteproc remoteproc2: 65800000.dsp is available
    [    5.871167] remoteproc remoteproc2: attaching to 65800000.dsp
    [    5.888590] remoteproc remoteproc2: unsupported resource 65538
    [    5.901111] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    5.936043] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    5.954022] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.016213]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
    [    6.035729] remoteproc remoteproc3: 5c00000.r5f is available
    [    6.116484] remoteproc remoteproc3: attaching to 5c00000.r5f
    [    6.131511] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.137107] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    6.173977] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    6.191431]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.232151]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.261841] remoteproc remoteproc2: remote processor 65800000.dsp is now attached
    [    6.342188] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.355435] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    6.414148]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    6.479086] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [    6.545121] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    6.592764] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.630880] remoteproc remoteproc4: 5d00000.r5f is available
    [    6.656134] remoteproc remoteproc4: attaching to 5d00000.r5f
    [    6.690250] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.732263]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.753088] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    6.766100] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    6.781127]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    6.787442] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
    [    6.799618] usbcore: registered new interface driver usbfs
    [    6.810223] platform 5e00000.r5f: configured R5F for IPC-only mode
    [    6.812945] usbcore: registered new interface driver hub
    [    6.825741] usbcore: registered new device driver usb
    [    6.831552] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    6.845570] remoteproc remoteproc5: 5e00000.r5f is available
    [    6.853594] remoteproc remoteproc5: attaching to 5e00000.r5f
    [    6.863316] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [    6.870677]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    6.885217] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    6.893787]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    6.899950] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    6.910868] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
    [    6.920512] platform 5f00000.r5f: configured R5F for IPC-only mode
    [    6.927398] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    6.940189] remoteproc remoteproc6: 5f00000.r5f is available
    [    6.945933] remoteproc remoteproc6: attaching to 5f00000.r5f
    [    6.951751] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [    6.958531]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    6.968292] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    6.973892]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    6.980010] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached
    [    6.980673] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    6.993014] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    7.001553] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.011393] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [    7.016126] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    7.023306] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [    7.034519] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.042717] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    7.055323] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.065688] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    7.075430] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.078940] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [    7.088787] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    7.103126] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    7.111512] xhci-hcd xhci-hcd.0.auto: irq 428, io mem 0x06010000
    [    7.130460] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    7.141445] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.148861] usb usb1: Product: xHCI Host Controller
    [    7.167083] usb usb1: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [    7.176861] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    7.195290] hub 1-0:1.0: USB hub found
    [    7.199370] hub 1-0:1.0: 1 port detected
    [    7.203571] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    7.215136] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    7.242008] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [    7.249941] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    7.259557] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    7.268719] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    7.275964] usb usb2: Product: xHCI Host Controller
    [    7.280887] usb usb2: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [    7.287502] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    7.292705] hub 2-0:1.0: USB hub found
    [    7.296493] hub 2-0:1.0: 1 port detected
    [    7.332427] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.579528] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.779007] pvrsrvkm: disagrees about version of symbol module_layout
    [    7.828584] Bluetooth: Core ver 2.22
    [    7.847946] NET: Registered protocol family 31
    [    7.866734] Bluetooth: HCI device and connection manager initialized
    [    7.929958] Bluetooth: HCI socket layer initialized
    [    7.949051] Bluetooth: L2CAP socket layer initialized
    [    7.979110] Bluetooth: SCO socket layer initialized
    [    8.135015] pvrsrvkm: loading out-of-tree module taints kernel.
    [    8.254193] PVR_K:  946: Read BVNC 36.53.104.796 from HW device registers
    [    8.353899] PVR_K:  946: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    8.398651] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    8.692114] EXT4-fs (mmcblk0p11): recovery complete
    [    8.710451] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
    [    8.723929] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [    8.756988] ext4 filesystem being mounted at /log supports timestamps until 2038 (0x7fffffff)
    [    8.869620] EXT4-fs (mmcblk0p13): recovery complete
    [    8.880600] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
    [    8.918536] ext4 filesystem being mounted at /Data supports timestamps until 2038 (0x7fffffff)
    [    9.084004] EXT4-fs (mmcblk0p14): recovery complete
    [    9.101508] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
    [    9.729379] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [    9.741104] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    [    9.768448] can: controller area network core
    [    9.808848] NET: Registered protocol family 29
    [    9.850266] can: raw protocol
    [   11.566877] PVR_K:  919: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   11.590033] PVR_K:  919: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   16.000201] am65-cpsw-nuss c200000.ethernet eth1: Link is Down
    [   16.042757] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   16.059295] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   16.218365] dp83812_read_straps: Strap is 0x4280
    [   16.572116] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [   18.446267] dp83812_read_straps: Strap is 0x4280
    [   18.836944] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [   20.157368] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [   20.164666] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    [  124.218054] Initializing XFRM netlink socket
    UART :
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=4eb4e7fa-b4bf-4f48-9659-74dad57a14bf rw rootfstype=ext4 rootwait
    [    0.008370] Console: colour dummy device 80x25
    [    0.012936] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023607] pid_max: default: 32768 minimum: 301
    [    0.028357] LSM: Security Framework initializing
    [    0.033112] Mount-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.040866] Mountpoint-cache hash table entries: 16384 (order: 1, 131072 bytes, linear)
    [    0.050118] rcu: Hierarchical SRCU implementation.
    [    0.055199] Platform MSI: msi-controller@1820000 domain created
    [    0.061394] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070690] EFI services will not be available.
    [    0.075462] smp: Bringing up secondary CPUs ...
    [    0.088602] Detected PIPT I-cache on CPU1
    [    0.088628] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088640] GICv3: CPU1: using allocated LPI pending table @0x00000008c00d0000
    [    0.088680] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088755] smp: Brought up 1 node, 2 CPUs
    [    0.118107] SMP: Total of 2 processors activated.
    [    0.122913] CPU features: detected: 32-bit EL0 Support
    [    0.128167] CPU features: detected: CRC32 instructions
    [    0.142517] CPU: All CPU(s) started at EL2
    [    0.146721] alternatives: patching kernel code
    [    0.151806] devtmpfs: initialized
    [    0.158646] KASLR disabled due to lack of seed
    [    0.163319] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.173285] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.180425] pinctrl core: initialized pinctrl subsystem
    [    0.186005] DMI not present or invalid.
    [    0.190300] NET: Registered protocol family 16
    [    0.195212] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.202702] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.210869] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.219250] thermal_sys: Registered thermal governor 'step_wise'
    [    0.219254] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.225838] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.239486] ASID allocator initialised with 65536 entries
    [    0.256616] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.263474] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.270231] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.278246] cryptd: max_cpu_qlen set to 1000
    [    0.284511] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.293408] vsys_3v3: supplied by evm_12v0
    [    0.297774] vsys_5v0: supplied by evm_12v0
    [    0.302121] vdd_mmc1: supplied by vsys_3v3
    [    0.306507] vdd_sd_dv_alt: supplied by vsys_3v3
    [    0.311622] iommu: Default domain type: Translated
    [    0.316766] SCSI subsystem initialized
    [    0.320834] mc: Linux media interface: v0.10
    [    0.325211] videodev: Linux video capture interface: v2.00
    [    0.330841] pps_core: LinuxPPS API ver. 1 registered
    [    0.335911] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.345249] PTP clock support registered
    [    0.349268] EDAC MC: Ver: 3.0.0
    [    0.353019] FPGA manager framework
    [    0.356542] Advanced Linux Sound Architecture Driver Initialized.
    [    0.363230] clocksource: Switched to clocksource arch_sys_counter
    [    0.369659] VFS: Disk quotas dquot_6.6.0
    [    0.373716] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.383519] Carveout Heap: Exported 600 MiB at 0x00000000ba000000
    [    0.389816] NET: Registered protocol family 2
    [    0.394492] IP idents hash table entries: 131072 (order: 4, 1048576 bytes, linear)
    [    0.404072] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.412865] TCP established hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.421167] TCP bind hash table entries: 65536 (order: 4, 1048576 bytes, linear)
    [    0.429183] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.435985] UDP hash table entries: 4096 (order: 1, 131072 bytes, linear)
    [    0.443011] UDP-Lite hash table entries: 4096 (order: 1, 131072 bytes, linear)
    [    0.450561] NET: Registered protocol family 1
    [    0.455358] RPC: Registered named UNIX socket transport module.
    [    0.461431] RPC: Registered udp transport module.
    [    0.466236] RPC: Registered tcp transport module.
    [    0.471038] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.477622] PCI: CLS 0 bytes, default 64
    [    0.482010] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.492586] Initialise system trusted keyrings
    [    0.497243] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.505515] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.511795] NFS: Registering the id_resolver key type
    [    0.516988] Key type id_resolver registered
    [    0.521261] Key type id_legacy registered
    [    0.525382] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.532230] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.539874] 9p: Installing v9fs 9p2000 file system support
    [    0.565051] Key type asymmetric registered
    [    0.569240] Asymmetric key parser 'x509' registered
    [    0.574241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.581800] io scheduler mq-deadline registered
    [    0.586425] io scheduler kyber registered
    [    0.591740] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.597845] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.605815] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.612095] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.619855] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.632232] brd: module loaded
    [    0.638330] loop: module loaded
    [    0.641924] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [    0.649854] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.120-g95b90aa828 #1
    [    0.657142] Hardware name: Texas Instruments J721S2 EVM (DT)
    [    0.662920] Call trace:
    [    0.665423]  dump_backtrace+0x0/0x1a0
    [    0.669159]  show_stack+0x18/0x68
    [    0.672542]  dump_stack+0xd0/0x12c
    [    0.676013]  sysfs_warn_dup+0x60/0x80
    [    0.679747]  sysfs_create_dir_ns+0xe0/0xf8
    [    0.683930]  kobject_add_internal+0x98/0x288
    [    0.688286]  kobject_add+0x94/0x100
    [    0.691845]  device_add+0xe0/0x740
    [    0.695314]  platform_device_add+0x100/0x238
    [    0.699671]  platform_device_register_full+0xcc/0x150
    [    0.704832]  dma_buf_phys_init+0x6c/0x9c
    [    0.708833]  do_one_initcall+0x54/0x1b8
    [    0.712748]  kernel_init_freeable+0x220/0x2a0
    [    0.717194]  kernel_init+0x14/0x114
    [    0.720750]  ret_from_fork+0x10/0x34
    [    0.724419] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
    [    0.737610] megasas: 07.714.04.00-rc1
    [    0.743133] tun: Universal TUN/TAP device driver, 1.6
    [    0.748565] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.754972] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.761041] sky2: driver version 1.30
    [    0.765342] VFIO - User Level meta-driver version: 0.3
    [    0.771065] i2c /dev entries driver
    [    0.775260] sdhci: Secure Digital Host Controller Interface driver
    [    0.781576] sdhci: Copyright(c) Pierre Ossman
    [    0.786180] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.792397] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.798752] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.805854] optee: probing for conduit method.
    [    0.810424] optee: revision 3.17 (15a746d2)
    [    0.810559] optee: dynamic shared memory is enabled
    [    0.825384] optee: initialized driver
    [    0.830198] NET: Registered protocol family 17
    [    0.834812] 9pnet: Installing 9P2000 support
    [    0.839211] Key type dns_resolver registered
    [    0.843675] Loading compiled-in X.509 certificates
    [    0.851320] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.857679] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.865775] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [    0.892765] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.898897] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.904976] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.911321] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.918135] pca953x 3-0020: using no AI
    [    0.943774] pca953x 3-0027: supply vcc not found, using dummy regulator
    [    0.950579] pca953x 3-0027: using no AI
    [    0.954547] pca953x 3-0027: failed writing register
    [    0.959588] pca953x: probe of 3-0027 failed with error -121
    [    0.965347] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.971811] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    0.980412] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    0.989760] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    0.998347] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    1.007350] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.017225] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.023986] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.032761] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.042918] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.049677] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.057380] omap8250 40a00000.serial: failed to get alias
    [    1.063490] 2830000.serial: ttyS3 at MMIO 0x2830000 (irq = 22, base_baud = 3000000) is a 8250
    [    1.072814] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 23, base_baud = 3000000) is a 8250
    [    1.081566] printk: console [ttyS2] enabled
    [    1.090005] printk: bootconsole [ns16550a0] disabled
    [    1.102311] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.147241] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.156868] dp83812_read_straps: Strap is 0x280
    [    1.390152] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
    [    1.399053] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.412717] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
    [    1.459233] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.468105] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    1.476228] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.489992] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
    [    1.599666] mmc0: CQHCI version 5.10
    [    1.603542] mmc1: CQHCI version 5.10
    [    1.608760] davinci_gpio 42100000.gpio: IRQ index 0 not found
    [    1.614526] davinci_gpio 42100000.gpio: error -ENXIO: IRQ not populated
    [    1.623028] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.629855] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.636657] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.643457] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.648004] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.657451] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.665384] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.675326] ti-udma 31150000.dma-controller: Channels: 48 (tchan: 24, rchan: 24, gp-rflow: 16)
    [    1.686686] spi-nor spi0.0: unrecognized JEDEC id bytes: 2c 5b 19 10 41 00
    [    1.693585] spi-nor: probe of spi0.0 failed with error -2
    [    1.699655] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.743239] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.743679] mmc0: Command Queue Engine enabled
    [    1.752834] dp83812_read_straps: Strap is 0x280
    [    1.755393] mmc0: new HS200 MMC card at address 0001
    [    1.765153] mmcblk0: mmc0:0001 S0J59X 119 GiB
    [    1.769713] mmcblk0boot0: mmc0:0001 S0J59X partition 1 31.5 MiB
    [    1.775805] mmcblk0boot1: mmc0:0001 S0J59X partition 2 31.5 MiB
    [    1.781871] mmcblk0rpmb: mmc0:0001 S0J59X partition 3 4.00 MiB, chardev (237:0)
    [    1.791176] GPT:Primary header thinks Alt. header is not at the end of the disk.
    [    1.798627] GPT:8388607 != 248643583
    [    1.802258] GPT:Alternate GPT header not at the end of the disk.
    [    1.808304] GPT:8388607 != 248643583
    [    1.811867] GPT: Use GNU Parted to correct GPT errors.
    [    1.817006]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
    [    1.988690] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TC812CS2.0
    [    1.997609] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.010913] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.017725] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.024948] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.031334] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    2.041679] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode
    [    2.087234] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.096133] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [    2.104259] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.117515] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [    2.124275] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    2.130542] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    2.137668] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    2.143910] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.154017] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
    [    2.161763] debugfs: Directory 'pd:357' with parent 'pm_genpd' already present!
    [    2.169121] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    2.180307] ALSA device list:
    [    2.183277]   No soundcards found.
    [    2.193129] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [    2.201263] VFS: Mounted root (ext4 filesystem) on device 179:3.
    [    2.207666] devtmpfs: mounted
    [    2.210911] Freeing unused kernel memory: 1856K
    [    2.215478] Run /sbin/init as init process
    [    2.219570]   with arguments:
    [    2.219572]     /sbin/init
    [    2.219574]   with environment:
    [    2.219576]     HOME=/
    [    2.219577]     TERM=linux
    [    2.274101] systemd[1]: System time before build time, advancing clock.
    [    2.302452] NET: Registered protocol family 10
    [    2.307471] Segment Routing with IPv6
    [    2.319837] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    2.341605] systemd[1]: Detected architecture arm64.
    [    2.375621] systemd[1]: Set hostname to <j721s2-evm>.
    [    2.383286] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.389913] systemd[1]: Initializing machine ID from random generator.
    [    2.543405] systemd[1]: Configuration file /etc/systemd/system/can_rec_250.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.592757] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.599527] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    2.611857] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    2.621687] systemd[1]: Created slice system-getty.slice.
    [    2.643321] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.650507] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    2.671725] systemd[1]: Created slice User and Session Slice.
    [    2.691447] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    2.715373] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.739355] systemd[1]: Reached target Paths.
    [    2.755298] systemd[1]: Reached target Remote File Systems.
    [    2.775285] systemd[1]: Reached target Slices.
    [    2.791287] systemd[1]: Reached target Swap.
    [    2.807705] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    2.831327] systemd[1]: Reached target RPC Port Mapper.
    [    2.855755] systemd[1]: Listening on Process Core Dump Socket.
    [    2.879451] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.910722] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    2.919116] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.939560] systemd[1]: Listening on Journal Socket.
    [    2.955601] systemd[1]: Listening on Network Service Netlink Socket.
    [    2.979512] systemd[1]: Listening on udev Control Socket.
    [    2.999419] systemd[1]: Listening on udev Kernel Socket.
    [    3.022409] systemd[1]: Mounting Huge Pages File System...
    [    3.041706] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.066288] systemd[1]: Mounting Kernel Debug File System...
    [    3.088298] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    3.106072] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    3.133530] systemd[1]: Starting ab partition setup...
    [    3.150341] systemd[1]: Starting RPC Bind...
    [    3.163482] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    3.175972] systemd[1]: Starting Journal Service...
    [    3.196427] systemd[1]: Starting Load Kernel Modules...
    [    3.218866] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.240082] systemd[1]: Starting udev Coldplug all Devices...
    [    3.245025] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
    [    3.261677] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    3.273194] systemd[1]: Started RPC Bind.
    [    3.289801] systemd[1]: Started Journal Service.
    [    3.300653] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    [    3.333064] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    3.369408] EXT4-fs (mmcblk0p10): recovery complete
    [    3.375040] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
    [    3.401353] urandom_read_iter: 45 callbacks suppressed
    [    3.401358] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.414418] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.426217] EXT4-fs (mmcblk0p12): recovery complete
    [    3.433916] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    3.461439] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.533029] systemd-journald[164]: Received client request to flush runtime journal.
    [    4.411442] urandom_read_iter: 48 callbacks suppressed
    [    4.411446] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.451329] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    4.669131] pinctrl-single 11c000.pinctrl: pin PIN46 already requested by c200000.ethernet; cannot claim for a000000.dp-bridge
    [    4.703508] pvrsrvkm: disagrees about version of symbol module_layout
    [    4.735789] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.755484] wave5: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.888088] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    4.910145] pvrsrvkm: disagrees about version of symbol module_layout
    [    5.007807] pinctrl-single 11c000.pinctrl: pin-46 (a000000.dp-bridge) status -22
    [    5.034812] CAN device driver interface
    [    5.275386] pinctrl-single 11c000.pinctrl: could not request pin 46 (PIN46) from group dp0-pins-default  on device pinctrl-single
    [    5.277643] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    5.332009] vdec 4210000.video-codec: sram-size not found
    [    5.441982] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.547313] vdec 4210000.video-codec: sram node not found
    [    5.599280] random: crng init done
    [    5.602683] random: 5 urandom warning(s) missed due to ratelimiting
    [    5.647341] cdns-mhdp8546 a000000.dp-bridge: Error applying setting, reverse things back
    [    5.669034] remoteproc remoteproc0: 64800000.dsp is available
    [    5.679533] cdns-mhdp8546: probe of a000000.dp-bridge failed with error -22
    [    5.725659] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.755374] remoteproc remoteproc0: attaching to 64800000.dsp
    [    5.765800] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    5.801955] remoteproc remoteproc1: 41000000.r5f is available
    [    5.843396] remoteproc remoteproc0: unsupported resource 65538
    [    5.868071] remoteproc remoteproc1: attaching to 41000000.r5f
    [    5.934822] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    5.959496] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    5.995890] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [    6.084388]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.094284] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.099890]  remoteproc1#vdev0buffer: registered virtio0 (type 7)
    [    6.111366] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.119078] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.128180] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    6.136950]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
    [    6.148821] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    6.155521] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.165088] remoteproc remoteproc2: 5c00000.r5f is available
    [    6.171550] remoteproc remoteproc2: attaching to 5c00000.r5f
    [    6.182059] dp83812_read_straps: Strap is 0x280
    [    6.186897] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    6.193759]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    6.203796] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.209735]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.210818] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.215944] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    6.228888] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
    [    6.236539] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    6.247635] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    6.285950] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.384379] remoteproc remoteproc3: 5d00000.r5f is available
    [    6.436878]  remoteproc0#vdev0buffer: registered virtio1 (type 7)
    [    6.482124] remoteproc remoteproc3: attaching to 5d00000.r5f
    [    6.541310] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [    6.583703] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    6.705909] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [    6.714510] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
    [    6.734358]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    6.951750] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    6.964823] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    7.054979]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    7.075731] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    7.139290] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached
    [    7.170928] remoteproc remoteproc4: 65800000.dsp is available
    [    7.211361] remoteproc remoteproc4: attaching to 65800000.dsp
    [    7.218272] platform 5e00000.r5f: configured R5F for IPC-only mode
    [    7.269058] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.296342] remoteproc remoteproc4: unsupported resource 65538
    [    7.333694] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [    7.345405] remoteproc remoteproc5: 5e00000.r5f is available
    [    7.368786] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.381831]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@a8000000
    [    7.390738] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    7.397440] remoteproc remoteproc5: attaching to 5e00000.r5f
    [    7.429517] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    7.435673] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    7.450960]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    7.459001] remoteproc remoteproc4: remote processor 65800000.dsp is now attached
    [    7.499554] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [    7.600492]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.679891] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    7.692896] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    7.726214]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    7.753927] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
    [    7.806030] platform 5f00000.r5f: configured R5F for IPC-only mode
    [    7.842934] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    7.897149] remoteproc remoteproc6: 5f00000.r5f is available
    [    7.927876] remoteproc remoteproc6: attaching to 5f00000.r5f
    [    7.951463] usbcore: registered new interface driver usbfs
    [    7.962231] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [    7.963855] usbcore: registered new interface driver hub
    [    7.979211] usbcore: registered new device driver usb
    [    8.015309]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    8.041258] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    8.047768]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [    8.054296] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [    8.063441] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [    8.071289] remoteproc remoteproc6: remote processor 5f00000.r5f is now attached
    [    8.078895] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.087633] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    8.099515] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.111356] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [    8.121759] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.130782] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    8.141371] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    8.151530] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    8.159918] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.177277] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    8.185109] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    8.195991] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [    8.208591] xhci-hcd xhci-hcd.0.auto: irq 429, io mem 0x06010000
    [    8.215461] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    8.223928] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.236359] usb usb1: Product: xHCI Host Controller
    [    8.241521] usb usb1: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [    8.255287] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    8.271662] hub 1-0:1.0: USB hub found
    [    8.276414] hub 1-0:1.0: 1 port detected
    [    8.283001] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    8.289226] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    8.297634] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [    8.323417] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    8.332101] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    8.343942] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    8.351608] usb usb2: Product: xHCI Host Controller
    [    8.356753] usb usb2: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd
    [    8.363389] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    8.368561] hub 2-0:1.0: USB hub found
    [    8.372364] hub 2-0:1.0: 1 port detected
    [    8.405196] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.646287] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    8.880949] pvrsrvkm: disagrees about version of symbol module_layout
    [    8.930272] Bluetooth: Core ver 2.22
    [    8.957284] NET: Registered protocol family 31
    [    8.983527] Bluetooth: HCI device and connection manager initialized
    [    9.003446] Bluetooth: HCI socket layer initialized
    [    9.059441] Bluetooth: L2CAP socket layer initialized
    [    9.129721] Bluetooth: SCO socket layer initialized
    [    9.231547] pvrsrvkm: loading out-of-tree module taints kernel.
    [    9.328072] PVR_K:  967: Read BVNC 36.53.104.796 from HW device registers
    [    9.406306] PVR_K:  967: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    9.468864] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    9.692082] EXT4-fs (mmcblk0p11): recovery complete
    [    9.718142] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
    [    9.756282] ext4 filesystem being mounted at /log supports timestamps until 2038 (0x7fffffff)
    [    9.776383] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
    [    9.900080] EXT4-fs (mmcblk0p13): recovery complete
    [    9.926081] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
    [    9.980699] ext4 filesystem being mounted at /Data supports timestamps until 2038 (0x7fffffff)
    [   10.126445] EXT4-fs (mmcblk0p14): recovery complete
    [   10.147907] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
    [   10.802037] can: controller area network core
    [   10.840135] NET: Registered protocol family 29
    [   10.887829] can: raw protocol
    [   11.497210] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    [   11.510605] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [   12.059429] PVR_K:  936: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   12.081989] PVR_K:  936: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   17.091571] am65-cpsw-nuss c200000.ethernet eth1: Link is Down
    [   17.126267] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   17.143248] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   17.280357] dp83812_read_straps: Strap is 0x280
    [   17.628410] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [   19.416961] dp83812_read_straps: Strap is 0x280
    [   19.860372] am65-cpsw-nuss 46000000.ethernet eth0: validation of rgmii-rxid with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00002280 failed: -22
    [   21.258294] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [   21.267749] am65-cpsw-nuss c200000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    Eten
  • Hi Eten,
    Comparing the logs, it seems there are no outstanding errors that are unique to pinmuxing for either UART or I2C. Two questions:
    • What is the output from "kmsprint" when pinmuxing for UART? Do you see any difference in kmsprint logs when compared to the kmsprint logs from pinmuxing to I2C?
    • Could you share device tree for when pinmuxed to UART and pinmuxed to I2C?
    J721E, which is a similar platform to J721S2, has a board that has a DSI interface, and their device tree overlay for enabling that display can be found here:
    https://github.com/beagleboard/BeagleBoard-DeviceTrees/blob/5973f30e9acf4e35606c6c39fcd539984e3556c5/src/arm64/overlays/k3-j721e-beagleboneai64-RPi-7inch-panel.dts#L82
    I am expecting there to be some driver that configures your touchscreen through I2C, similar to many off-the-shelf DSI touchscreen as the one used by Beagle. So...
    • I suspect that the touchscreen driver had some ties to the I2C interface and disabling the I2C node caused the software to not initialize properly (software issue),
    • or there was actually a physical connection between the TDA4VE and DSI I2C interface (hardware issue)
    It seems strange that only I2C signals are routed to external MCU, since most DSI interfaces are connected via ribbon cable where all of the signals are sent to a single device. Unless, this was an intentional design choice and the MCU is running some sort of driver to configure DSI display through I2C.
    Takuma
  • Hi Takuma,
    Device Tree:
    // SPDX-License-Identifier: GPL-2.0
     * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/
     * Common Processor Board: https://www.ti.com/tool/J721EXCPXEVM
    /dts-v1/;
    #include "k3-j721s2-som-p0.dtsi"
    #include <dt-bindings/net/ti-dp83867.h>
    #include <dt-bindings/phy/phy-cadence.h>
    #include <dt-bindings/phy/phy.h>
    #include <dt-bindings/mux/ti-serdes.h>
    	compatible = "ti,j721s2-evm", "ti,j721s2";
    	model = "Texas Instruments J721S2 EVM";
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000";
    	aliases {
    		serial2 = &main_uart8;
    		serial3 = &main_uart3;
    		mmc0 = &main_sdhci0;
    		mmc1 = &main_sdhci1;
    		spi0 = &ospi0;
    		can0 = &mcu_mcan0;
    //		can1 = &main_mcan0;
    //		can2 = &main_mcan1;
    //		can3 = &main_mcan2;
    		ethernet0 = &cpsw_port1;
    		ethernet1 = &main_cpsw_port1;
    	evm_12v0: fixedregulator-evm12v0 {
    		/* main supply */
    		compatible = "regulator-fixed";
    		regulator-name = "evm_12v0";
    		regulator-min-microvolt = <12000000>;
    		regulator-max-microvolt = <12000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vsys_3v3: fixedregulator-vsys3v3 {
    		/* Output of LM5140 */
    		regulator-name = "vsys_3v3";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		vin-supply = <&evm_12v0>;
    		regulator-boot-on;
    	vsys_5v0: fixedregulator-vsys5v0 {
    		regulator-name = "vsys_5v0";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-boot-on;
    	vdd_mmc1: fixedregulator-sd {
    		regulator-name = "vdd_mmc1";
    		regulator-boot-on;
    		enable-active-high;
    		vin-supply = <&vsys_3v3>;
    	vdd_sd_dv_alt: fixedregulator-sd-dv-alt {
    		regulator-name = "vdd_sd_dv_alt";
    		regulator-boot-on;
    		enable-active-high;
    	transceiver0: can-phy0 {
    		compatible = "ti,tcan1043";
    		#phy-cells = <0>;
    		max-bitrate = <5000000>;
    		standby-gpios = <&wkup_gpio0 5 GPIO_ACTIVE_LOW>;
    		//enable-gpios = <&wkup_gpio0 4 GPIO_ACTIVE_LOW>;
    		enable-gpios = <&wkup_gpio0 4 GPIO_ACTIVE_HIGH>;
    	transceiver1: can-phy1 {
    		#phy-cells = <0>;
    	transceiver2: can-phy2 {
    		#phy-cells = <0>;
    	transceiver3: can-phy3 {
    		#phy-cells = <0>;
    	dp0_pwr_3v3: fixedregulator-dp0-prw {
    		regulator-name = "dp0-pwr";
    		enable-active-high;
    	dp0: dp0-connector {
    		compatible = "dp-connector";
    		label = "DP0";
    		type = "full-size";
    		dp-pwr-supply = <&dp0_pwr_3v3>;
    		port {
    			dp0_connector_in: endpoint {
    				remote-endpoint = <&dp0_out>;
    &main_i2c4 {
    	status = "disabled";
    &main_pmx0 {
    	main_uart8_pins_default: main-uart8-pins-default {
    		pinctrl-single,pins = <
    			J721S2_IOPAD(0x038, PIN_INPUT_PULLUP, 11) /* (AB28) MCASP0_ACLKX.UART8_RXD */
    			J721S2_IOPAD(0x03c, PIN_OUTPUT_PULLUP, 11) /* (U27) MCASP0_AFSX.UART8_TXD */
    	main_uart3_pins_default: main-uart3-pins-default {
    			J721S2_IOPAD(0x0c4, PIN_INPUT_PULLUP, 14) /* (AB26) ECAP0_IN_APWM_OUT.I2C1_SCL->ECAP0_IN_APWM_OUT.UART3_RXD */
    			J721S2_IOPAD(0x0c8, PIN_OUTPUT_PULLUP, 14) /* (AD28) EXT_REFCLK1.I2C1_SDA ->ECAP0_IN_APWM_OUT.UART3_TXD */
    	main_i2c0_pins_default: main-i2c0-pins-default {
    			J721E_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AH25) I2C0_SCL */
    			J721E_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AE24) I2C0_SDA */
    	main_i2c1_pins_default: main-i2c1-pins-default {
    			J721S2_IOPAD(0x0c4, PIN_INPUT_PULLUP, 13) /* (AB26) ECAP0_IN_APWM_OUT.I2C1_SCL */
    			J721S2_IOPAD(0x0c8, PIN_INPUT_PULLUP, 13) /* (AD28) EXT_REFCLK1.I2C1_SDA */
    	main_mmc1_pins_default: main-mmc1-pins-default {
    			J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */
    			J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */
    			J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */
    			J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */
    			J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
    			J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */
    			J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */
    			J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */
    	dp0_pins_default: dp0-pins-default {
    			J721S2_IOPAD(0x0b8, PIN_INPUT, 3) /* (AA24) MCASP1_ACLKX.DP0_HPD */
    	main_cpsw_pins_default: main-cpsw-pins-default {
    			J721S2_IOPAD(0x0b8, PIN_INPUT, 6) /* (AA24) MCASP1_ACLKX.RGMII1_RD0 */
    			J721S2_IOPAD(0x0a0, PIN_INPUT, 6) /* (AB25) MCASP0_AXR12.RGMII1_RD1 */
    			J721S2_IOPAD(0x0a4, PIN_INPUT, 6) /* (T23) MCASP0_AXR13.RGMII1_RD2 */
    			J721S2_IOPAD(0x0a8, PIN_INPUT, 6) /* (U24) MCASP0_AXR14.RGMII1_RD3 */
    			J721S2_IOPAD(0x0b0, PIN_INPUT, 6) /* (AD26) MCASP1_AXR3.RGMII1_RXC */
    			J721S2_IOPAD(0x0ac, PIN_INPUT, 6) /* (AC25) MCASP0_AXR15.RGMII1_RX_CTL */
    			J721S2_IOPAD(0x08c, PIN_OUTPUT, 6) /* (T25) MCASP0_AXR7.RGMII1_TD0 */
    			J721S2_IOPAD(0x090, PIN_OUTPUT, 6) /* (W24) MCASP0_AXR8.RGMII1_TD1 */
    			J721S2_IOPAD(0x094, PIN_OUTPUT, 6) /* (AA25) MCASP0_AXR9.RGMII1_TD2 */
    			J721S2_IOPAD(0x098, PIN_OUTPUT, 6) /* (V25) MCASP0_AXR10.RGMII1_TD3 */
    			J721S2_IOPAD(0x0b4, PIN_OUTPUT, 6) /* (U25) MCASP1_AXR4.RGMII1_TXC */
    			J721S2_IOPAD(0x09c, PIN_OUTPUT, 6) /* (T24) MCASP0_AXR11.RGMII1_TX_CTL */
    	main_mdio_pins_default: main-mdio-pins-default {
    			J721S2_IOPAD(0x0c0, PIN_OUTPUT_PULLUP, 6) /* (T28) MCASP1_AXR0.MDIO0_MDC */
    			J721S2_IOPAD(0x0bc, PIN_INPUT_PULLUP, 6) /* (V28) MCASP1_AFSX.MDIO0_MDIO */
    	main_mcan0_pins_default: main-mcan0-pins-default {
    			J721S2_IOPAD(0x068, PIN_INPUT_PULLUP, 0) /* (U28) MCAN0_RX */
    			J721S2_IOPAD(0x064, PIN_OUTPUT_PULLUP, 0) /* (W28) MCAN0_TX */
    	main_mcan1_pins_default: main-mcan1-pins-default {
    			J721S2_IOPAD(0x070, PIN_INPUT_PULLUP, 0) /* (R27) MCAN1_RX */
    			J721S2_IOPAD(0x06c, PIN_OUTPUT_PULLUP, 0) /* (V26) MCAN1_TX */
    	main_mcan2_pins_default: main-mcan2-pins-default {
    			J721S2_IOPAD(0x078, PIN_INPUT_PULLUP, 0) /* (Y25) MCAN2_RX */
    			J721S2_IOPAD(0x074, PIN_OUTPUT_PULLUP, 0) /* (R28) MCAN2_TX */
    	main_gpio1_pins_default: main-gpio1-pins-default {
    			J721S2_IOPAD(0x000, PIN_INPUT_PULLUP, 7) /* (AG24) EXTINTn.GPIO0_0 */
    			J721S2_IOPAD(0x004, PIN_INPUT, 7) /* (W25) MCAN12_TX.GPIO0_1 */
    			J721S2_IOPAD(0x008, PIN_INPUT, 7) /* (AC24) MCAN12_RX.GPIO0_2 */
    			J721S2_IOPAD(0x00c, PIN_INPUT, 7) /* (AE28) MCAN13_TX.GPIO0_3 */
    			J721S2_IOPAD(0x010, PIN_INPUT_PULLUP, 7) /* (AF28) MCAN13_RX.GPIO0_4 */
    			J721S2_IOPAD(0x014, PIN_INPUT_PULLUP, 7) /* (AD25) MCAN14_TX.GPIO0_5 */
    			J721S2_IOPAD(0x018, PIN_INPUT_PULLUP, 7) /* (W23) MCAN14_RX.GPIO0_6 */
    			J721S2_IOPAD(0x01c, PIN_INPUT_PULLUP, 7) /* (Y24) MCAN15_TX.GPIO0_7 */
    			J721S2_IOPAD(0x020, PIN_INPUT_PULLUP, 7) /* (AA23) MCAN15_RX.GPIO0_8 */
    			J721S2_IOPAD(0x024, PIN_INPUT_PULLUP, 7) /* (Y28) MCAN16_TX.GPIO0_9 */
    			J721S2_IOPAD(0x028, PIN_INPUT, 7) /* (AB24) MCAN16_RX.GPIO0_10 */
    			J721S2_IOPAD(0x02c, PIN_INPUT, 7) /* (V23) GPIO0_11 */
    			J721S2_IOPAD(0x030, PIN_OUTPUT_PULLUP, 7) /* (T26) GPIO0_12 */
    			J721S2_IOPAD(0x040, PIN_INPUT_PULLDOWN, 7) /* (AC28) MCASP0_AXR0.GPIO0_16 */
    			J721S2_IOPAD(0x044, PIN_INPUT_PULLDOWN, 7) /* (Y26) MCASP0_AXR1.GPIO0_17 */
    			J721S2_IOPAD(0x048, PIN_INPUT_PULLDOWN, 7) /* (AB27) MCASP0_AXR2.GPIO0_18 */
    			J721S2_IOPAD(0x04c, PIN_INPUT_PULLDOWN, 7) /* (V27) MCASP1_AXR1.GPIO0_19 */
    			J721S2_IOPAD(0x050, PIN_INPUT_PULLDOWN, 7) /* (W27) MCASP1_AXR2.GPIO0_20 */
    			J721S2_IOPAD(0x054, PIN_INPUT_PULLDOWN, 7) /* (Y27) MCASP2_ACLKX.GPIO0_21 */
    			J721S2_IOPAD(0x058, PIN_INPUT_PULLDOWN, 7) /* (AA27) MCASP2_AFSX.GPIO0_22 */
    			J721S2_IOPAD(0x05c, PIN_INPUT_PULLDOWN, 7) /* (AA26) MCASP2_AXR0.GPIO0_23 */
    			J721S2_IOPAD(0x07c, PIN_INPUT, 7) /* (T27) MCASP0_AXR3.GPIO0_31 */
    			J721S2_IOPAD(0x080, PIN_INPUT, 7) /* (U26) MCASP0_AXR4.GPIO0_32 */
    			J721S2_IOPAD(0x088, PIN_OUTPUT_PULLUP, 7) /* (AD27) MCASP0_AXR6.GPIO0_34 */
    			J721S2_IOPAD(0x0d0, PIN_INPUT, 7) /* (AF26) SPI0_CS1.GPIO0_52 */
    			J721S2_IOPAD(0x0ec, PIN_INPUT, 7) /* (AG25) GPIO0_59 */
        spi0_pins_default: spi0-pins-default {
        		J721E_IOPAD(0x0D4, PIN_OUTPUT_PULLDOWN, 0) /* (AH27) PIN_SPI0_CLK */
        		J721E_IOPAD(0x0CC, PIN_OUTPUT_PULLDOWN, 0) /* (AE27) PIN_SPI0_CS0 */
        		J721E_IOPAD(0x0D8, PIN_OUTPUT_PULLDOWN, 0) /* (AG26) PIN_SPI0_D0 */
        		J721E_IOPAD(0x0DC, PIN_INPUT_PULLDOWN, 0) /* (AH26) PIN_SPI0_D1 */
        pwm1_pins_default: pwm1-pins-default {
        		J721E_IOPAD(0x060, PIN_OUTPUT_PULLDOWN, 7) /* (AC27) PIN_MCASP2_AXR1 */
    &wkup_pmx0 {
    	mcu_cpsw_gpio_pins_default: mcu-cpsw-gpio-pins-default {
    			J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT, 7) /* (F28) WKUP_GPIO0_7 */
    			J721S2_WKUP_IOPAD(0x0cc, PIN_INPUT, 7)  /* (C27) WKUP_GPIO0_3 */
    	mcu_cpsw_pins_default: mcu-cpsw-pins-default {
    			J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */
    			J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */
    			J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */
    			J721S2_WKUP_IOPAD(0x088, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */
    			J721S2_WKUP_IOPAD(0x084, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */
    			J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */
    			J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */
    			J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */
    			J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */
    			J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */
    			J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */
    			J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */
    	mcu_mdio_pins_default: mcu-mdio-pins-default {
    			J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT_PULLUP, 0) /* (A21) MCU_MDIO0_MDC */
    			J721S2_WKUP_IOPAD(0x098, PIN_INPUT_PULLUP, 0) /* (A22) MCU_MDIO0_MDIO */
    	mcu_mcan0_pins_default: mcu-mcan0-pins-default {
    			J721S2_WKUP_IOPAD(0x0bc, PIN_INPUT_PULLUP, 0) /* (E28) MCU_MCAN0_RX */
    			J721S2_WKUP_IOPAD(0x0b8, PIN_OUTPUT_PULLUP, 0) /* (E27) MCU_MCAN0_TX */
    	mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-pins-default {
    			J721S2_WKUP_IOPAD(0x0d0, PIN_OUTPUT_PULLUP, 7) 		/* (C23) WKUP_GPIO0_4 */
    			J721S2_WKUP_IOPAD(0x0d4, PIN_OUTPUT_PULLUP, 7) 		/* (F26) WKUP_GPIO0_5 */
    			J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT_PULLUP, 7)	/* (E25) WKUP_GPIO0_6 */
    	wkup_gpio1_pins_default: wkup-gpio1-pins-default {
    			J721S2_WKUP_IOPAD(0x0e0, PIN_INPUT, 7) /* (F24) WKUP_GPIO0_8 */
    			J721S2_WKUP_IOPAD(0x060, PIN_INPUT, 7) /* (C21) MCU_OSPI1_CSn1.WKUP_GPIO0_39 */
    	mcu_uart1_pins_default: mcu-uart1-pins-default {
    			J721S2_WKUP_IOPAD(0x0ec, PIN_INPUT_PULLDOWN, 2) /* (F25) WKUP_GPIO0_11.MCU_UART0_RXD */
    			J721S2_WKUP_IOPAD(0x0e8, PIN_OUTPUT_PULLUP, 2) /* (F27) WKUP_GPIO0_10.MCU_UART0_TXD */
    &main_gpio0 {
    	pinctrl-names = "default";
    	pinctrl-0 = <&main_gpio1_pins_default>;
    &main_gpio2 {
    &main_gpio4 {
    &main_gpio6 {
    &wkup_gpio1 {
    //	status = "disabled";
    	pinctrl-0 = <&wkup_gpio1_pins_default>;
    &wkup_uart0 {
    	status = "reserved";
    &mcu_uart0 {
    	pinctrl-0 = <&mcu_uart1_pins_default>;
    &main_uart0 {
    &main_uart1 {
    &main_uart2 {
    &main_uart3 {
    	pinctrl-0 = <&main_uart3_pins_default>;
    	/* Shared with TFA on this platform */
    	power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>;
    	status = "okay";
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_uart7 {
    &main_uart8 {
    	pinctrl-0 = <&main_uart8_pins_default>;
    &main_uart9 {
    &main_spi0 {
        pinctrl-0 = <&spi0_pins_default>;
    	ti,pindir-d0-out-d1-in = <1>;
        status="okay";
        spidev@0 {
           spi-max-frequency = <24000000>;
           reg = <0>;
           compatible = "linux,spidev";
    &main_i2c0 {
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	clock-frequency = <400000>;
    	exp0: gpio@20 {
    		compatible = "ti,tca6416"; /*Ming++ change pca9535 to tca6416*/
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "CANFD1_EN", "CANFD2_EN", "CANFD3_EN",
    				  "LOCAL_CAN_STBn", "CAN_PWR_EN",
    				  "DSI3_PWR_EN",
    				  "CSI0_TX_PWDN", "CSI1_TX_PWDN",
    				  "PASS_01",
    				  "DES1_PDB", "DES2_PDB",
    				  "GPIO_PRG0_RGMII_RST",
    				  "DSI3_nRESET";
    	gpio@27 {
    		reg = <0x27>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = 	"TCA9535_1_P0", "TCA9535_1_P1", "TCA9535_1_P2",
    							"TCA9535_1_P3", "TCA9535_1_P4", "TCA9535_1_P5",
    							"TCA9535_1_P6", "TCA9535_1_P7", "TCA9535_1_P8",
    							"TCA9535_1_P9", "TCA9535_1_P10","TCA9535_1_P11",
    							"TCA9535_1_P12","TCA9535_1_P12","TCA9535_1_P13",
    							"TCA9535_1_P14","TCA9535_1_P15","TCA9535_1_P16",
    							"TCA9535_1_P17";
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_i2c4 {
    &main_i2c5 {
    &main_i2c6 {
    &main_sdhci0 {
    	/* eMMC */
    	non-removable;
    	ti,driver-strength-ohm = <50>;
    //	disable-cqe-dcmd;
    	disable-wp;
    &main_sdhci1 {
    	/* SD card */
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv_alt>;
    &mcu_cpsw {
    	pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default &mcu_cpsw_gpio_pins_default>;
    	reset-gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
    	status = "okay";
    &davinci_mdio {
    	cpsw_phy0: ethernet-phy@0 {
    		reg = <0>;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    		ti,min-output-impedance;
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&cpsw_phy0>;
    	//fixed-link {
    	//      speed = <100>;
    	//      full-duplex;
    &main_cpsw {
    	pinctrl-0 = <&main_cpsw_pins_default &main_mdio_pins_default>;
    	reset-gpios = <&exp0 12 GPIO_ACTIVE_LOW>;	/* P12 - GPIO_PRG0_RGMII_RST */
    	status = "okay";
    &main_cpsw_mdio {
    	main_cpsw_phy0: ethernet-phy@0 {
    		reg = <0>;
    &main_cpsw_port1 {
    	phy-handle = <&main_cpsw_phy0>;
    &serdes_ln_ctrl {
    	idle-states = <J721S2_SERDES0_LANE0_PCIE1_LANE0>, <J721S2_SERDES0_LANE1_USB>,
    			<J721S2_SERDES0_LANE2_EDP_LANE2>, <J721S2_SERDES0_LANE3_EDP_LANE3>;
    &serdes_refclk {
    	clock-frequency = <100000000>;
    &serdes0 {
    	serdes0_pcie_link: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_PCIE>;
    		resets = <&serdes_wiz0 1>;
    &usb_serdes_mux {
    	idle-states = <1>; /* USB0 to SERDES lane 1 */
    &edp_serdes_mux {
    	idle-states = <1>; /* EDP0 to SERDES lane 2/3 */
    &usbss0 {
    	ti,vbus-divider;
    	ti,usb2-only;
    &usb0 {
    	dr_mode = "otg";
    	maximum-speed = "high-speed";
    &pcie1_rc {
    	phys = <&serdes0_pcie_link>;
    	phy-names = "pcie-phy";
    	num-lanes = <1>;
    &pcie1_ep {
    	num-lanes = <1>;
    &ospi1 {
    &dss {
    	 * These clock assignments are chosen to enable the following outputs:
    	 * VP0 - DisplayPort SST
    	 * VP1 - DPI0
    	 * VP2 - DSI
    	 * VP3 - DPI1
    	assigned-clocks = <&k3_clks 158 2>,
    			  <&k3_clks 158 5>,
    			  <&k3_clks 158 14>,
    			  <&k3_clks 158 18>;
    	assigned-clock-parents = <&k3_clks 158 3>,
    				 <&k3_clks 158 7>,
    				 <&k3_clks 158 16>,
    				 <&k3_clks 158 22>;
    &dss_ports {
    	port {
    		dpi0_out: endpoint {
    			remote-endpoint = <&dp0_in>;
    &mhdp {
    	pinctrl-0 = <&dp0_pins_default>;
    	cdns,no-hpd;
    &dp0_ports {
    	#address-cells = <1>;
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dp0_in: endpoint {
    			remote-endpoint = <&dpi0_out>;
    	port@4 {
    		reg = <4>;
    		dp0_out: endpoint {
    			remote-endpoint = <&dp0_connector_in>;
    &mcu_mcan0 {
    	pinctrl-0 = <&mcu_mcan0_pins_default &mcu_mcan0_gpio_pins_default>;
    	phys = <&transceiver0>;
    &mcu_mcan1 {
    &main_mcan0 {
    //	pinctrl-names = "default";
    //	pinctrl-0 = <&main_mcan0_pins_default>;
    //	phys = <&transceiver1>;
    &main_mcan1 {
    //	pinctrl-0 = <&main_mcan1_pins_default>;
    //	phys = <&transceiver2>;
    &main_mcan2 {
    //	pinctrl-0 = <&main_mcan2_pins_default>;
    //	phys = <&transceiver3>;
    &main_mcan3 {
    &main_mcan4 {
    &main_mcan5 {
    &main_mcan6 {
    &main_mcan7 {
    &main_mcan8 {
    &main_mcan9 {
    &main_mcan10 {
    &main_mcan11 {
    &main_mcan12 {
    &main_mcan13 {
    &main_mcan14 {
    &main_mcan15 {
    &main_mcan16 {
    &main_mcan17 {
    Another question,
    When enabling 2nd DSI driver, do you have the patch file for the module "psdk_rtos/vision_apps/utils/dss" ?
    Eten
  • Hi Eten,
    For device tree, please only pinmux UART or I2C. I am not sure which will overwrite the other, but one pinmux will overwrite the other pinmux if the shared device tree is used as-is.
    As for 2nd DSI driver, I assumed the Linux driver was being used for display, but could you clarify what/why patch is desired for the RTOS SDK instead of the Linux SDK?
    Takuma
  • Hi Takuma,
    On the Linux side, we have checked the device tree and found nothing incorrect.  So we suspect that something needs to be modified on the RTOS side. ( MCU2_0 is responsible for DSI driver )
    In addition of to modifying the "J721S2_pinmux_data.c" of pdk package to disable I2C (AB26 & AD28), do any files need to be modified ?
    Sorry, I forgot to mention that we got a patch file to enable 2nd DSI driver by the following post.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1216922/tda4ve-q1-support-two-ch-from-dsi-output-on-j721s2/4723808?tisearch=e2e-sitesearch&keymatch=2nd%2520DSI%2520joe#4723808
    So we needs the corresponding dss utils module patch to enable the 2nd DSI.
    Thank you !!
    Eten
  • Hi Eten,
    The below snippet of device tree looks incorrect:
    Please remove main_uart3_pins_default or main_i2c1_pins_default. These both are changing registers at the same offset with different values of 14 or 13, so this will cause a resource conflict (aka, in the end, the register will either have UART or I2C, but not both as one will overwrite the other).
    For the 2nd DSI driver, let me loop in Brijesh to see if he has some context.
    Takuma
  • Hi Eten,
    Are you trying to enable second DSI instance in the Linux? Which patch are you using?
    Brijesh
  • Hi Takuma,
    We have removed the main_i2c1_pins_default element.
    Unfortunately the DSI output still doesn't work.
    Eten
  • Hi Brijesh,
    We are trying to enabled 2nd DSI instance in the FreeRTOS (MCU2_0).
    Eten
  • Hi Eten,
    But i think it is not yet supported in Linux or RTOS. so wondering how you are enabling second instance. Have you added support for it in the driver?
    Brijesh
  • Hi Brjesh,
    Oh !! My former colleagues adjusted the register settings of 2nd DSI driver according to the datasheet.
    Eten
  • Hi Eten,
    Its not yet supported officially in the SDK, so will not be able to help much.
    Brijesh
  • Hi Brijesh,
    It's okay !!
    Can you provide a plan or date for the formal released SDK that provides the 2nd DSI output ?
    Thank you !!
    Eten
  • Hi Eter,
    The request is in the system, but the planning is not yet done and so planned date is not yet available. The main limitation is, its not possible to validated it on EVM.
    Brijesh
  • Hi Brijesh,
    Because our target board has two DSI outputs,  we can do the validation after you complete the patch.
    Eten
  • Hi Eten,
    But are you using Linux or RTOS based display?
    Brijesh
  • Hi Brijesh,
    We are using the RTOS based display !!
    Eten
  • Hi Eten,
    ok, let me check with the dev team.
    Brijesh
  • Hi Takuma,
    Finally I fixed this issue caused by our incorrect settings.
    Thank you !!
    Eten
  • Hi Brijesh,
    How it the progress of 2nd DSI output ?
    Eten
  • Hi Eten,
    I still have not got the chance to check it with the team.
    Brijesh
