When using the command to export the kernel source code, an error message appears.
MACHINE=am62axx-evm detool modify linux-ti-staging
Please help take a look. Or is there any guidance document on how to modify the kernel in the yocto project?
If you look at the red text in your screenshot, bitbake can't find a patch. Provide the patch in the right place (one of your recipes in source/* references it) or remove the SRC_URI that adds it.
This issue seems limited to the linux-ti-staging recipe; other recipes work. I flagged this to the dev team but we don't have a solution for this yet. I suggest you use a different method for kernel development that doesn't use the 'devtool modify' feature.
Regards, Andreas
This has been reported again with another customer, see https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1351405/am625-sdk-09_02_01_09-failed-to-modify-kernel-recipe-using-devtool
Let me follow up with the development team to see if there's perhaps a "quick fix".
Regards, Andreas
I was able to re-create the issue and figure out a workaround, please see this thread here: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1351405/am625-sdk-09_02_01_09-failed-to-modify-kernel-recipe-using-devtool
Regards, Andreas
