TDA4AL-Q1: How to completely stop the tx function
Part Number: TDA4AL-Q1
In the single_cam app's app_create_graph, I added the TX function. I set the program to automatically exit the single_cam after save 5 images.
However, after exiting, I found that the TX function may not have fully terminated, causing the single_cam to repeatedly execute until it gets stuck around the 23rd iteration.
How can I ensure that the TX function completely exits upon exiting the single_cam?
Test LOG:
test case = 23
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
  1506.383147 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
  1506.383240 s:  VX_ZONE_INIT:Enabled
  1506.383251 s:  VX_ZONE_ERROR:Enabled
  1506.383258 s:  VX_ZONE_WARNING:Enabled
  1506.384273 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
  1506.385668 s:  VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
sensor_selection = [11]
ldc_enable = [0]
channel = [1]
channel_number = [7]
num_frames_to_run = [1000000000]
is_interactive = [0]
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
  1506.393521 s: ISS: Enumerating sensors ... !!!
 NETWORK: Opened at IP Addr = 1.4.16.64, socket port=5000!!!
[MCU2_0]   1205.115007 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_ENUMERATE
[MCU2_0]   1205.115063 s: setupI2CInst start
[MCU2_0]   1205.115086 s: read open i2c inst 0
[MCU2_0]   1205.115112 s: read open i2c inst 1
[MCU2_0]   1205.115177 s: read open i2c inst 2
[MCU2_0]   1205.115202 s: setupI2CInst end
[MCU2_0]   1205.115222 s: max96712 config start : slaveAddr = 0x6b
[MCU2_0]   1205.115698 s:  max96712 Reg Write Sucess for regAddr 0x13, regValue 0x40
[MCU2_0]   1205.130599 s:  max96712 Reg READ Sucess for regAddr 0x13, regValue 0x35
[MCU2_0]   1205.135467 s:  max96712 Reg Write Sucess for regAddr 0x18, regValue 0xff
[MCU2_0]   1205.150593 s:  max96712 Reg READ Sucess for regAddr 0x18, regValue 0xf0
[MCU2_0]   1205.155466 s:  max96712 Reg Write Sucess for regAddr 0x18, regValue 0x0
[MCU2_0]   1205.170592 s:  max96712 Reg READ Sucess for regAddr 0x18, regValue 0x0
[MCU2_0]   1205.175466 s:  max96712 Reg Write Sucess for regAddr 0x6, regValue 0xf0
[MCU2_0]   1205.190592 s:  max96712 Reg READ Sucess for regAddr 0x6, regValue 0xf0
[MCU2_0]   1205.191053 s:  max96712 Reg Write Sucess for regAddr 0x10, regValue 0x22
[MCU2_0]   1205.206592 s:  max96712 Reg READ Sucess for regAddr 0x10, regValue 0x22
[MCU2_0]   1205.207054 s:  max96712 Reg Write Sucess for regAddr 0x11, regValue 0x22
[MCU2_0]   1205.222595 s:  max96712 Reg READ Sucess for regAddr 0x11, regValue 0x22
[MCU2_0]   1205.223056 s:  max96712 Reg Write Sucess for regAddr 0x17, regValue 0x14
[MCU2_0]   1205.238591 s:  max96712 Reg READ Sucess for regAddr 0x17, regValue 0x14
[MCU2_0]   1205.239053 s:  max96712 Reg Write Sucess for regAddr 0x19, regValue 0x94
[MCU2_0]   1205.254592 s:  max96712 Reg READ Sucess for regAddr 0x19, regValue 0x94
[MCU2_0]   1205.255054 s:  max96712 Reg Write Sucess for regAddr 0x40b, regValue 0x0
[MCU2_0]   1205.270592 s:  max96712 Reg READ Sucess for regAddr 0x40b, regValue 0x0
[MCU2_0]   1205.271053 s:  max96712 Reg Write Sucess for regAddr 0x6c2, regValue 0x10
[MCU2_0]   1205.286592 s:  max96712 Reg READ Sucess for regAddr 0x6c2, regValue 0x10
[MCU2_0]   1205.287053 s:  max96712 Reg Write Sucess for regAddr 0x1445, regValue 0x0
[MCU2_0]   1205.302593 s:  max96712 Reg READ Sucess for regAddr 0x1445, regValue 0x0
[MCU2_0]   1205.303056 s:  max96712 Reg Write Sucess for regAddr 0x1545, regValue 0x0
[MCU2_0]   1205.318592 s:  max96712 Reg READ Sucess for regAddr 0x1545, regValue 0x0
[MCU2_0]   1205.319055 s:  max96712 Reg Write Sucess for regAddr 0x1645, regValue 0x0
[MCU2_0]   1205.334592 s:  max96712 Reg READ Sucess for regAddr 0x1645, regValue 0x0
[MCU2_0]   1205.335054 s:  max96712 Reg Write Sucess for regAddr 0x1745, regValue 0x0
[MCU2_0]   1205.350593 s:  max96712 Reg READ Sucess for regAddr 0x1745, regValue 0x0
[MCU2_0]   1205.351055 s:  max96712 Reg Write Sucess for regAddr 0xf0, regValue 0x26
[MCU2_0]   1205.366592 s:  max96712 Reg READ Sucess for regAddr 0xf0, regValue 0x26
[MCU2_0]   1205.367054 s:  max96712 Reg Write Sucess for regAddr 0xf1, regValue 0xae
[MCU2_0]   1205.382595 s:  max96712 Reg READ Sucess for regAddr 0xf1, regValue 0xae
[MCU2_0]   1205.383058 s:  max96712 Reg Write Sucess for regAddr 0xf2, regValue 0x62
[MCU2_0]   1205.398592 s:  max96712 Reg READ Sucess for regAddr 0xf2, regValue 0x62
[MCU2_0]   1205.399053 s:  max96712 Reg Write Sucess for regAddr 0xf3, regValue 0xea
[MCU2_0]   1205.414592 s:  max96712 Reg READ Sucess for regAddr 0xf3, regValue 0xea
[MCU2_0]   1205.415053 s:  max96712 Reg Write Sucess for regAddr 0xf4, regValue 0xff
[MCU2_0]   1205.430592 s:  max96712 Reg READ Sucess for regAddr 0xf4, regValue 0xff
[MCU2_0]   1205.431052 s:  max96712 Reg Write Sucess for regAddr 0x9b1, regValue 0x83
[MCU2_0]   1205.446591 s:  max96712 Reg READ Sucess for regAddr 0x9b1, regValue 0x83
[MCU2_0]   1205.447053 s:  max96712 Reg Write Sucess for regAddr 0x9f1, regValue 0xac
[MCU2_0]   1205.462593 s:  max96712 Reg READ Sucess for regAddr 0x9f1, regValue 0xac
[MCU2_0]   1205.463055 s:  max96712 Reg Write Sucess for regAddr 0xa0b, regValue 0x7
[MCU2_0]   1205.478593 s:  max96712 Reg READ Sucess for regAddr 0xa0b, regValue 0x7
[MCU2_0]   1205.479055 s:  max96712 Reg Write Sucess for regAddr 0xa2d, regValue 0x15
[MCU2_0]   1205.494591 s:  max96712 Reg READ Sucess for regAddr 0xa2d, regValue 0x15
[MCU2_0]   1205.495053 s:  max96712 Reg Write Sucess for regAddr 0xa0d, regValue 0x2c
[MCU2_0]   1205.510591 s:  max96712 Reg READ Sucess for regAddr 0xa0d, regValue 0x2c
[MCU2_0]   1205.511053 s:  max96712 Reg Write Sucess for regAddr 0xa0e, regValue 0x2c
[MCU2_0]   1205.526593 s:  max96712 Reg READ Sucess for regAddr 0xa0e, regValue 0x2c
[MCU2_0]   1205.527056 s:  max96712 Reg Write Sucess for regAddr 0xa0f, regValue 0x0
[MCU2_0]   1205.542594 s:  max96712 Reg READ Sucess for regAddr 0xa0f, regValue 0x0
[MCU2_0]   1205.543054 s:  max96712 Reg Write Sucess for regAddr 0xa10, regValue 0x0
[MCU2_0]   1205.558592 s:  max96712 Reg READ Sucess for regAddr 0xa10, regValue 0x0
[MCU2_0]   1205.559053 s:  max96712 Reg Write Sucess for regAddr 0xa11, regValue 0x1
[MCU2_0]   1205.574592 s:  max96712 Reg READ Sucess for regAddr 0xa11, regValue 0x1
[MCU2_0]   1205.575053 s:  max96712 Reg Write Sucess for regAddr 0xa12, regValue 0x1
[MCU2_0]   1205.590593 s:  max96712 Reg READ Sucess for regAddr 0xa12, regValue 0x1
[MCU2_0]   1205.591054 s:  max96712 Reg Write Sucess for regAddr 0xa4b, regValue 0x7
[MCU2_0]   1205.606591 s:  max96712 Reg READ Sucess for regAddr 0xa4b, regValue 0x7
[MCU2_0]   1205.607053 s:  max96712 Reg Write Sucess for regAddr 0xa6d, regValue 0x15
[MCU2_0]   1205.622593 s:  max96712 Reg READ Sucess for regAddr 0xa6d, regValue 0x15
[MCU2_0]   1205.623054 s:  max96712 Reg Write Sucess for regAddr 0xa4d, regValue 0x2c
[MCU2_0]   1205.638591 s:  max96712 Reg READ Sucess for regAddr 0xa4d, regValue 0x2c
[MCU2_0]   1205.639053 s:  max96712 Reg Write Sucess for regAddr 0xa4e, regValue 0x6c
[MCU2_0]   1205.654592 s:  max96712 Reg READ Sucess for regAddr 0xa4e, regValue 0x6c
[MCU2_0]   1205.655055 s:  max96712 Reg Write Sucess for regAddr 0xa4f, regValue 0x0
[MCU2_0]   1205.670592 s:  max96712 Reg READ Sucess for regAddr 0xa4f, regValue 0x0
[MCU2_0]   1205.671053 s:  max96712 Reg Write Sucess for regAddr 0xa50, regValue 0x40
[MCU2_0]   1205.686591 s:  max96712 Reg READ Sucess for regAddr 0xa50, regValue 0x40
[MCU2_0]   1205.687054 s:  max96712 Reg Write Sucess for regAddr 0xa51, regValue 0x1
[MCU2_0]   1205.702593 s:  max96712 Reg READ Sucess for regAddr 0xa51, regValue 0x1
[MCU2_0]   1205.703055 s:  max96712 Reg Write Sucess for regAddr 0xa52, regValue 0x41
[MCU2_0]   1205.718591 s:  max96712 Reg READ Sucess for regAddr 0xa52, regValue 0x41
[MCU2_0]   1205.719052 s:  max96712 Reg Write Sucess for regAddr 0xa8b, regValue 0x7
[MCU2_0]   1205.734591 s:  max96712 Reg READ Sucess for regAddr 0xa8b, regValue 0x7
[MCU2_0]   1205.735053 s:  max96712 Reg Write Sucess for regAddr 0xaad, regValue 0x15
[MCU2_0]   1205.750592 s:  max96712 Reg READ Sucess for regAddr 0xaad, regValue 0x15
[MCU2_0]   1205.751054 s:  max96712 Reg Write Sucess for regAddr 0xa8d, regValue 0x2c
[MCU2_0]   1205.766592 s:  max96712 Reg READ Sucess for regAddr 0xa8d, regValue 0x2c
[MCU2_0]   1205.767052 s:  max96712 Reg Write Sucess for regAddr 0xa8e, regValue 0xac
[MCU2_0]   1205.782595 s:  max96712 Reg READ Sucess for regAddr 0xa8e, regValue 0xac
[MCU2_0]   1205.783057 s:  max96712 Reg Write Sucess for regAddr 0xa8f, regValue 0x0
[MCU2_0]   1205.798592 s:  max96712 Reg READ Sucess for regAddr 0xa8f, regValue 0x0
[MCU2_0]   1205.799053 s:  max96712 Reg Write Sucess for regAddr 0xa90, regValue 0x80
[MCU2_0]   1205.814591 s:  max96712 Reg READ Sucess for regAddr 0xa90, regValue 0x80
[MCU2_0]   1205.815054 s:  max96712 Reg Write Sucess for regAddr 0xa91, regValue 0x1
[MCU2_0]   1205.830593 s:  max96712 Reg READ Sucess for regAddr 0xa91, regValue 0x1
[MCU2_0]   1205.831054 s:  max96712 Reg Write Sucess for regAddr 0xa92, regValue 0x81
[MCU2_0]   1205.846592 s:  max96712 Reg READ Sucess for regAddr 0xa92, regValue 0x81
[MCU2_0]   1205.847053 s:  max96712 Reg Write Sucess for regAddr 0xacb, regValue 0x7
[MCU2_0]   1205.862594 s:  max96712 Reg READ Sucess for regAddr 0xacb, regValue 0x7
[MCU2_0]   1205.863054 s:  max96712 Reg Write Sucess for regAddr 0xaed, regValue 0x15
[MCU2_0]   1205.878592 s:  max96712 Reg READ Sucess for regAddr 0xaed, regValue 0x15
[MCU2_0]   1205.879054 s:  max96712 Reg Write Sucess for regAddr 0xacd, regValue 0x2c
[MCU2_0]   1205.894591 s:  max96712 Reg READ Sucess for regAddr 0xacd, regValue 0x2c
[MCU2_0]   1205.895054 s:  max96712 Reg Write Sucess for regAddr 0xace, regValue 0xec
[MCU2_0]   1205.910592 s:  max96712 Reg READ Sucess for regAddr 0xace, regValue 0xec
[MCU2_0]   1205.911054 s:  max96712 Reg Write Sucess for regAddr 0xacf, regValue 0x0
[MCU2_0]   1205.926591 s:  max96712 Reg READ Sucess for regAddr 0xacf, regValue 0x0
[MCU2_0]   1205.927053 s:  max96712 Reg Write Sucess for regAddr 0xad0, regValue 0xc0
[MCU2_0]   1205.942594 s:  max96712 Reg READ Sucess for regAddr 0xad0, regValue 0xc0
[MCU2_0]   1205.943055 s:  max96712 Reg Write Sucess for regAddr 0xad1, regValue 0x1
[MCU2_0]   1205.958592 s:  max96712 Reg READ Sucess for regAddr 0xad1, regValue 0x1
[MCU2_0]   1205.959053 s:  max96712 Reg Write Sucess for regAddr 0xad2, regValue 0xc1
[MCU2_0]   1205.974592 s:  max96712 Reg READ Sucess for regAddr 0xad2, regValue 0xc1
[MCU2_0]   1205.975054 s:  max96712 Reg Write Sucess for regAddr 0x8a0, regValue 0x8
[MCU2_0]   1205.990592 s:  max96712 Reg READ Sucess for regAddr 0x8a0, regValue 0x8
[MCU2_0]   1205.991054 s:  max96712 Reg Write Sucess for regAddr 0x8a3, regValue 0xe4
[MCU2_0]   1206.006593 s:  max96712 Reg READ Sucess for regAddr 0x8a3, regValue 0xe4
[MCU2_0]   1206.007056 s:  max96712 Reg Write Sucess for regAddr 0x8a4, regValue 0x44
[MCU2_0]   1206.022594 s:  max96712 Reg READ Sucess for regAddr 0x8a4, regValue 0x44
[MCU2_0]   1206.023056 s:  max96712 Reg Write Sucess for regAddr 0x90a, regValue 0xc0
[MCU2_0]   1206.038592 s:  max96712 Reg READ Sucess for regAddr 0x90a, regValue 0xc0
[MCU2_0]   1206.039053 s:  max96712 Reg Write Sucess for regAddr 0x94a, regValue 0xc0
[MCU2_0]   1206.054592 s:  max96712 Reg READ Sucess for regAddr 0x94a, regValue 0xc0
[MCU2_0]   1206.055053 s:  max96712 Reg Write Sucess for regAddr 0x98a, regValue 0x40
[MCU2_0]   1206.070593 s:  max96712 Reg READ Sucess for regAddr 0x98a, regValue 0x40
[MCU2_0]   1206.071054 s:  max96712 Reg Write Sucess for regAddr 0x9ca, regValue 0x40
[MCU2_0]   1206.086593 s:  max96712 Reg READ Sucess for regAddr 0x9ca, regValue 0x40
[MCU2_0]   1206.087054 s:  max96712 Reg Write Sucess for regAddr 0x983, regValue 0x80
[MCU2_0]   1206.102593 s:  max96712 Reg READ Sucess for regAddr 0x983, regValue 0x80
[MCU2_0]   1206.103054 s:  max96712 Reg Write Sucess for regAddr 0x9c3, regValue 0x80
[MCU2_0]   1206.118591 s:  max96712 Reg READ Sucess for regAddr 0x9c3, regValue 0x80
[MCU2_0]   1206.119055 s:  max96712 Reg Write Sucess for regAddr 0x8a2, regValue 0xf4
[MCU2_0]   1206.134591 s:  max96712 Reg READ Sucess for regAddr 0x8a2, regValue 0xf4
[MCU2_0]   1206.135052 s:  max96712 Reg Write Sucess for regAddr 0x1c00, regValue 0xf4
[MCU2_0]   1206.150592 s:  max96712 Reg READ Sucess for regAddr 0x1c00, regValue 0xf4
[MCU2_0]   1206.151054 s:  max96712 Reg Write Sucess for regAddr 0x1d00, regValue 0xf4
[MCU2_0]   1206.166592 s:  max96712 Reg READ Sucess for regAddr 0x1d00, regValue 0xf4
[MCU2_0]   1206.167054 s:  max96712 Reg Write Sucess for regAddr 0x1e00, regValue 0xf4
[MCU2_0]   1206.182595 s:  max96712 Reg READ Sucess for regAddr 0x1e00, regValue 0xf4
[MCU2_0]   1206.183056 s:  max96712 Reg Write Sucess for regAddr 0x1f00, regValue 0xf4
[MCU2_0]   1206.198592 s:  max96712 Reg READ Sucess for regAddr 0x1f00, regValue 0xf4
[MCU2_0]   1206.199056 s:  max96712 Reg Write Sucess for regAddr 0x415, regValue 0x34
[MCU2_0]   1206.214593 s:  max96712 Reg READ Sucess for regAddr 0x415, regValue 0x34
[MCU2_0]   1206.215054 s:  max96712 Reg Write Sucess for regAddr 0x418, regValue 0x34
[MCU2_0]   1206.230593 s:  max96712 Reg READ Sucess for regAddr 0x418, regValue 0x34
[MCU2_0]   1206.231055 s:  max96712 Reg Write Sucess for regAddr 0x41b, regValue 0x34
[MCU2_0]   1206.246591 s:  max96712 Reg READ Sucess for regAddr 0x41b, regValue 0x34
[MCU2_0]   1206.247054 s:  max96712 Reg Write Sucess for regAddr 0x41e, regValue 0x34
[MCU2_0]   1206.262594 s:  max96712 Reg READ Sucess for regAddr 0x41e, regValue 0x34
[MCU2_0]   1206.263057 s:  max96712 Reg Write Sucess for regAddr 0x1c00, regValue 0xf5
[MCU2_0]   1206.278593 s:  max96712 Reg READ Sucess for regAddr 0x1c00, regValue 0xf5
[MCU2_0]   1206.279055 s:  max96712 Reg Write Sucess for regAddr 0x1d00, regValue 0xf5
[MCU2_0]   1206.294592 s:  max96712 Reg READ Sucess for regAddr 0x1d00, regValue 0xf5
[MCU2_0]   1206.295054 s:  max96712 Reg Write Sucess for regAddr 0x1e00, regValue 0xf5
[MCU2_0]   1206.310592 s:  max96712 Reg READ Sucess for regAddr 0x1e00, regValue 0xf5
[MCU2_0]   1206.311054 s:  max96712 Reg Write Sucess for regAddr 0x1f00, regValue 0xf5
[MCU2_0]   1206.326593 s:  max96712 Reg READ Sucess for regAddr 0x1f00, regValue 0xf5
[MCU2_0]   1206.326630 s: End of max96712 config
[MCU2_0]   1206.326652 s: maxDesSerCfg config start
[MCU2_0]   1206.327101 s:  maxDesSerCfg Reg Write Success for regAddr 0x6 regValue 0xf1
[MCU2_0]   1206.342590 s:  maxDesSerCfg Reg READ Success for regAddr 0x6 regValue 0xf1
[MCU2_0]   1206.342628 s:  End of maxDesSerCfg config
[MCU2_0]   1206.372626 s: Link 0 ok, count = 2
[MCU2_0]   1206.372656 s: maxDesSerCfg config start
[MCU2_0]   1206.372821 s:  maxDesSerCfg Error: Reg Write Failed for regAddr 0, slaveI2cAddr = 40
[MCU2_0]   1206.372860 s:  End of maxDesSerCfg config
[MCU2_0]   1206.372882 s: max96712DesSerCfgI2CAddr failed!
[MCU2_0]   1206.372905 s: max96712 config start : slaveAddr = 0x6b
[MCU2_0]   1206.373372 s:  max96712 Reg Write Sucess for regAddr 0x6, regValue 0xff
[MCU2_0]   1206.388625 s:  max96712 Reg READ Sucess for regAddr 0x6, regValue 0xff
[MCU2_0]   1206.388662 s: End of max96712 config
[MCU2_0]   1206.389266 s: Link 0 ok, count = 0
[MCU2_0]   1206.389295 s: AA550
[MCU2_0]   1206.389326 s: AA551
[MCU2_0]   1206.389344 s: Fusion2 Board Detected, using Fusion2 configuration
[MCU2_0]   1206.389392 s: Get CSI 1 i2c addr 0@107
[MCU2_0]   1206.389415 s: read open i2c inst 0
[MCU2_0]   1206.389447 s:  I2C status 0
[MCU2_0]   1206.389473 s: Do nothing 0
[MCU2_0]   1206.389500 s: max96712_cfgScript
[MCU2_0]   1206.389537 s: Get CSI 1 i2c addr 0@107
[MCU2_0]   1206.389558 s: MAX96712 config start
[MCU2_0]   1206.389581 s: CSI 1
[MCU2_0]   1206.390075 s: write Board_gmslMax96712DesInit 1@0x49: 0x040b=0x0000 0
[MCU2_0]   1206.390574 s: write Board_gmslMax96712DesInit 1@0x49: 0x0006=0x0000 0
[MCU2_0]   1206.391066 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a0=0x0004 0
[MCU2_0]   1206.391555 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a2=0x0000 0
[MCU2_0]   1206.392046 s: write Board_gmslMax96712DesInit 1@0x49: 0x04ab=0x0000 0
[MCU2_0]   1206.392538 s: write Board_gmslMax96712DesInit 1@0x49: 0x04aa=0x0000 0
[MCU2_0]   1206.393027 s: write Board_gmslMax96712DesInit 1@0x49: 0x04af=0x005f 0
[MCU2_0]   1206.393518 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a7=0x000f 0
[MCU2_0]   1206.394008 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a6=0x0042 0
[MCU2_0]   1206.394499 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a5=0x0040 0
[MCU2_0]   1206.394989 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b08=0x0071 0
[MCU2_0]   1206.395480 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c08=0x0071 0
[MCU2_0]   1206.395972 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d08=0x0071 0
[MCU2_0]   1206.396463 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e08=0x0071 0
[MCU2_0]   1206.396953 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b06=0x00ef 0
[MCU2_0]   1206.397445 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c06=0x00ef 0
[MCU2_0]   1206.397934 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d06=0x00ef 0
[MCU2_0]   1206.398426 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e06=0x00ef 0
[MCU2_0]   1206.398916 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b0f=0x0001 0
[MCU2_0]   1206.399405 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c0f=0x0001 0
[MCU2_0]   1206.399895 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d0f=0x0001 0
[MCU2_0]   1206.400386 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e0f=0x0001 0
[MCU2_0]   1206.400875 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b07=0x0084 0
[MCU2_0]   1206.401367 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c07=0x0084 0
[MCU2_0]   1206.401856 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d07=0x0084 0
[MCU2_0]   1206.402349 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e07=0x0084 0
[MCU2_0]   1206.407506 s: write Board_gmslMax96712DesInit 1@0x49: 0x041a=0x00f0 0
[MCU2_0]   1206.407996 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b0d=0x0080 0
[MCU2_0]   1206.408487 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c0d=0x0080 0
[MCU2_0]   1206.408977 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d0d=0x0080 0
[MCU2_0]   1206.409470 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e0d=0x0080 0
[MCU2_0]   1206.409959 s: write Board_gmslMax96712DesInit 1@0x49: 0x08a3=0x00e4 0
[MCU2_0]   1206.410450 s: write Board_gmslMax96712DesInit 1@0x49: 0x040b=0x0042 0
[MCU2_0]   1206.410940 s: write Board_gmslMax96712DesInit 1@0x49: 0x040c=0x0000 0
[MCU2_0]   1206.411431 s: write Board_gmslMax96712DesInit 1@0x49: 0x040d=0x0000 0
[MCU2_0]   1206.411921 s: write Board_gmslMax96712DesInit 1@0x49: 0x040e=0x005e 0
[MCU2_0]   1206.412410 s: write Board_gmslMax96712DesInit 1@0x49: 0x040f=0x007e 0
[MCU2_0]   1206.412900 s: write Board_gmslMax96712DesInit 1@0x49: 0x0410=0x007a 0
[MCU2_0]   1206.413391 s: write Board_gmslMax96712DesInit 1@0x49: 0x0411=0x0048 0
[MCU2_0]   1206.413881 s: write Board_gmslMax96712DesInit 1@0x49: 0x0412=0x0020 0
[MCU2_0]   1206.414373 s: write Board_gmslMax96712DesInit 1@0x49: 0x0415=0x00ea 0
[MCU2_0]   1206.414863 s: write Board_gmslMax96712DesInit 1@0x49: 0x0418=0x00ea 0
[MCU2_0]   1206.415354 s: write Board_gmslMax96712DesInit 1@0x49: 0x090b=0x0007 0
[MCU2_0]   1206.415845 s: write Board_gmslMax96712DesInit 1@0x49: 0x092d=0x0015 0
[MCU2_0]   1206.416338 s: write Board_gmslMax96712DesInit 1@0x49: 0x090d=0x001e 0
[MCU2_0]   1206.416828 s: write Board_gmslMax96712DesInit 1@0x49: 0x090e=0x001e 0
[MCU2_0]   1206.417320 s: write Board_gmslMax96712DesInit 1@0x49: 0x090f=0x0000 0
[MCU2_0]   1206.417809 s: write Board_gmslMax96712DesInit 1@0x49: 0x0910=0x0000 0
[MCU2_0]   1206.418301 s: write Board_gmslMax96712DesInit 1@0x49: 0x0911=0x0001 0
[MCU2_0]   1206.418789 s: write Board_gmslMax96712DesInit 1@0x49: 0x0912=0x0001 0
[MCU2_0]   1206.419280 s: write Board_gmslMax96712DesInit 1@0x49: 0x094b=0x0007 0
[MCU2_0]   1206.419770 s: write Board_gmslMax96712DesInit 1@0x49: 0x096d=0x0015 0
[MCU2_0]   1206.420263 s: write Board_gmslMax96712DesInit 1@0x49: 0x094d=0x001e 0
[MCU2_0]   1206.420753 s: write Board_gmslMax96712DesInit 1@0x49: 0x094e=0x005e 0
[MCU2_0]   1206.421244 s: write Board_gmslMax96712DesInit 1@0x49: 0x094f=0x0000 0
[MCU2_0]   1206.421734 s: write Board_gmslMax96712DesInit 1@0x49: 0x0950=0x0040 0
[MCU2_0]   1206.422225 s: write Board_gmslMax96712DesInit 1@0x49: 0x0951=0x0001 0
[MCU2_0]   1206.422716 s: write Board_gmslMax96712DesInit 1@0x49: 0x0952=0x0041 0
[MCU2_0]   1206.423207 s: write Board_gmslMax96712DesInit 1@0x49: 0x098b=0x0007 0
[MCU2_0]   1206.423697 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ad=0x0015 0
[MCU2_0]   1206.424188 s: write Board_gmslMax96712DesInit 1@0x49: 0x098d=0x001e 0
[MCU2_0]   1206.424678 s: write Board_gmslMax96712DesInit 1@0x49: 0x098e=0x009e 0
[MCU2_0]   1206.425169 s: write Board_gmslMax96712DesInit 1@0x49: 0x098f=0x0000 0
[MCU2_0]   1206.425658 s: write Board_gmslMax96712DesInit 1@0x49: 0x0990=0x0080 0
[MCU2_0]   1206.426151 s: write Board_gmslMax96712DesInit 1@0x49: 0x0991=0x0001 0
[MCU2_0]   1206.426641 s: write Board_gmslMax96712DesInit 1@0x49: 0x0992=0x0081 0
[MCU2_0]   1206.427132 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cb=0x0007 0
[MCU2_0]   1206.427621 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ed=0x0015 0
[MCU2_0]   1206.428112 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cd=0x001e 0
[MCU2_0]   1206.428602 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ce=0x00de 0
[MCU2_0]   1206.429091 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cf=0x0000 0
[MCU2_0]   1206.429581 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d0=0x00c0 0
[MCU2_0]   1206.430072 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d1=0x0001 0
[MCU2_0]   1206.430562 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d2=0x00c1 0
[MCU2_0]   1206.431053 s: write Board_gmslMax96712DesInit 1@0x49: 0x00fa=0x0033 0
[MCU2_0]   1206.431543 s: write Board_gmslMax96712DesInit 1@0x49: 0x0018=0x000f 0
[MCU2_0]   1206.462507 s: write Board_gmslMax96712DesInit 1@0x49: 0x040b=0x0040 0
[MCU2_0]   1206.462997 s: write Board_gmslMax96712DesInit 1@0x49: 0x0006=0x000f 0
[MCU2_0]   1206.472510 s: write Board_gmslMax96712DesInit 1@0x49: 0x0903=0x0080 0
[MCU2_0]   1206.473007 s: write Board_gmslMax96712DesInit 1@0x49: 0x0943=0x0080 0
[MCU2_0]   1206.473504 s: write Board_gmslMax96712DesInit 1@0x49: 0x0983=0x0080 0
[MCU2_0]   1206.474000 s: write Board_gmslMax96712DesInit 1@0x49: 0x09c3=0x0080 0
[MCU2_0]   1206.474495 s: write Board_gmslMax96712DesInit 1@0x49: 0x1c00=0x00f4 0
[MCU2_0]   1206.474991 s: write Board_gmslMax96712DesInit 1@0x49: 0x1d00=0x00f4 0
[MCU2_0]   1206.475488 s: write Board_gmslMax96712DesInit 1@0x49: 0x1e00=0x00f4 0
[MCU2_0]   1206.475982 s: write Board_gmslMax96712DesInit 1@0x49: 0x1f00=0x00f4 0
[MCU2_0]   1206.476477 s: write Board_gmslMax96712DesInit 1@0x49: 0x1c00=0x00f5 0
[MCU2_0]   1206.476973 s: write Board_gmslMax96712DesInit 1@0x49: 0x1d00=0x00f5 0
[MCU2_0]   1206.477468 s: write Board_gmslMax96712DesInit 1@0x49: 0x1e00=0x00f5 0
[MCU2_0]   1206.477964 s: write Board_gmslMax96712DesInit 1@0x49: 0x1f00=0x00f5 0
[MCU2_0]   1206.477994 s: setting_96717_loopback
[MCU2_0]   1208.477514 s: write Board_gmslMax96712DesInit 1@0x42: 0x02d3=0x0000 0
[MCU2_0]   1208.478011 s: write Board_gmslMax96712DesInit 1@0x42: 0x0330=0x0000 0
[MCU2_0]   1208.478510 s: write Board_gmslMax96712DesInit 1@0x42: 0x0383=0x0000 0
[MCU2_0]   1208.479005 s: write Board_gmslMax96712DesInit 1@0x42: 0x0331=0x0033 0
[MCU2_0]   1208.479500 s: write Board_gmslMax96712DesInit 1@0x42: 0x0332=0x00e0 0
[MCU2_0]   1208.480261 s: write Board_gmslMax96712DesInit 1@0x42: 0x0333=0x0004 0
[MCU2_0]   1208.480758 s: write Board_gmslMax96712DesInit 1@0x42: 0x0308=0x0064 0
[MCU2_0]   1208.481253 s: write Board_gmslMax96712DesInit 1@0x42: 0x0311=0x0040 0
[MCU2_0]   1208.481749 s: write Board_gmslMax96712DesInit 1@0x42: 0x0318=0x006c 0
[MCU2_0]   1208.482246 s: write Board_gmslMax96712DesInit 1@0x42: 0x0002=0x0043 0
[MCU2_0]   1208.482742 s: write Board_gmslMax96712DesInit 1@0x42: 0x03f1=0x0001 0
  1510.608074 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
  1510.608100 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
  1510.608109 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
  1510.608116 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
  1510.608124 s: ISS: Enumerating sensors ... found 4 : OX03C-MAX9295E
  1510.608131 s: ISS: Enumerating sensors ... found 5 : OX08B-MAX96717
  1510.608138 s: ISS: Enumerating sensors ... found 6 : OX08BA-MAX96701
  1510.608145 s: ISS: Enumerating sensors ... found 7 : MAX96712_RAW_TESTPAT
  1510.608152 s: ISS: Enumerating sensors ... found 8 : AR0233-MAX9295E
  1510.608159 s: ISS: Enumerating sensors ... found 9 : UB96x_UYVY_TESTPATTERN
  1510.608165 s: ISS: Enumerating sensors ... found 10 : GW_AR0233_UYVY
  1510.608172 s: ISS: Enumerating sensors ... found 11 : OX08B_UB971_R1D
Set cam test port = 7
12 registered sensor drivers
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
d : UB9xxx_RAW12_TESTPATTERN
e : OX03C-MAX9295E
f : OX08B-MAX96717
g : OX08BA-MAX96701
h : MAX96712_RAW_TESTPAT
i : AR0233-MAX9295E
j : UB96x_UYVY_TESTPATTERN
k : GW_AR0233_UYVY
l : OX08B_UB971_R1D
Select a sensor above or press '0' to autodetect the sensor : Sensor selected : OX08B_UB971_R1D
Querying OX08B_UB971_R1D
  1510.608260 s: ISS: Querying sensor [OX08B_UB971_R1D] ... !!!
  1510.608626 s: ISS: Querying sensor [OX08B_UB971_R1D] ... Done !!!
  1510.608641 s: ISS: Initializing sensor [OX08B_UB971_R1D], doing IM_SENSOR_CMD_PWRON ... !!!
  1510.609031 s: ISS: Initializing sensor [OX08B_UB971_R1D], doing IM_SENSOR_CMD_CONFIG ... !!!
  1510.610281 s: ISS: Initializing sensor [OX08B_UB971_R1D] ... Done !!!
Test data path is NULL. Defaulting to current folder
read_test_image_raw : Unable to open file .//img_test.raw
app_create_viss : sensor_dcc_id = 840
Initializing Transmit Buffers...
vxGetObjectArrayItem success
raw12:img_width = 3840 	img_height = 2160
[MCU2_0]   1208.483237 s: write Board_gmslMax96712DesInit 1@0x42: 0x03f0=0x0051 0
[MCU2_0]   1208.483734 s: write Board_gmslMax96712DesInit 1@0x42: 0x0570=0x0001 0
[MCU2_0]   1208.484228 s: write Board_gmslMax96712DesInit 1@0x42: 0x0570=0x0000 0
[MCU2_0]   1208.484725 s: write Board_gmslMax96712DesInit 1@0x42: 0x0006=0x00b1 0
[MCU2_0]   1208.485219 s: write Board_gmslMax96712DesInit 1@0x42: 0x02bf=0x0060 0
[MCU2_0]   1208.485715 s: write Board_gmslMax96712DesInit 1@0x42: 0x02be=0x0090 0
[MCU2_0]   1208.486211 s: write Board_gmslMax96712DesInit 1@0x42: 0x02d3=0x0090 0
[MCU2_0]   1208.486238 s: End of MAX96712 config
[MCU2_0]   1208.486276 s: Error : max96712_cfgScript returned 0 while configuring DES 0
[MCU2_0]   1208.486746 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
[MCU2_0]   1208.486777 s: Received Query for OX08B_UB971_R1D
[MCU2_0]   1208.487033 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
[MCU2_0]   1208.487065 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x80
[MCU2_0]   1208.487112 s: OX08B40_PowerOn : chId = 0x7
[MCU2_0]   1208.487345 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
[MCU2_0]   1208.487374 s: Application requested features = 0x358
[MCU2_0]
[MCU2_0]   1208.487404 s: IM_SENSOR_CMD_CONFIG channel_mask = 80
raw12:imgaddr_width = 3840 	imgaddr_height = 2160 	imgaddr_stride = 7680
[MCU2_0]   1208.487441 s: Configuring camera # 0
[MCU2_0]   1208.487470 s: Configuring camera # 1
[MCU2_0]   1208.487499 s: Configuring camera # 2
[MCU2_0]   1208.487527 s: Configuring camera # 3
[MCU2_0]   1208.487556 s: Configuring camera # 4
[MCU2_0]   1208.487585 s: Configuring camera # 5
[MCU2_0]   1208.487614 s: Configuring camera # 6
[MCU2_0]   1208.487642 s: Configuring camera # 7
[MCU2_0]   1208.487673 s: OX08B40_Probe chId: 0x7
[MCU2_0]   1208.487694 s: Configuring camera # 7
[MCU2_0]   1208.487738 s: OX08B40_Config chId: 0x7, sensor_features_requested = 856
[MCU2_0]   1208.487792 s: OX08B40_Config:pCreatePrms->i2cAddrSer[7] : 114,linear_mode : 0
[MCU2_0]   1208.487822 s: max96717 config start : slaveAddr = 0x72
[MCU2_0]   1208.487994 s:  max96717 Error: Reg Write Failed for regAddr 302
[MCU2_0]   1208.488024 s:  End of max96717 config
[MCU2_0]   1208.488074 s: OX08B40_Config chId: 0x7, sensor_features_requested = 856, status = -1
[MCU2_0]   1208.488105 s: IM_SENSOR_CMD_CONFIG returning status = 0
Initializing Transmit Buffers Done.
Csitx graph done!
[MCU2_0]   1208.871314 s:  VX_ZONE_ERROR:[tivxCaptureCreate:1231] : Failed to set Event Parameters!!!
single_cam source code:
 * Copyright (c) 2018 Texas Instruments Incorporated
 * All rights reserved not granted herein.
 * Limited License.
 * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
 * license under copyrights and patents it now or hereafter owns or controls to make,
 * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
 * terms herein.  With respect to the foregoing patent license, such license is granted
 * solely to the extent that any such patent is necessary to Utilize the software alone.
 * The patent license shall not apply to any combinations which include this software,
 * other than combinations with devices manufactured by or for TI ("TI Devices").
 * No hardware patent is licensed hereunder.
 * Redistributions must preserve existing copyright notices and reproduce this license
 * (including the above copyright notice and the disclaimer and (if applicable) source
 * code license limitations below) in the documentation and/or other materials provided
 * with the distribution
 * Redistribution and use in binary form, without modification, are permitted provided
 * that the following conditions are met:
 * *       No reverse engineering, decompilation, or disassembly of this software is
 * permitted with respect to any software provided in binary form.
 * *       any redistribution and use are licensed by TI for use only with TI Devices.
 * *       Nothing shall obligate TI to provide you with source code for the software
 * licensed and provided to you in object code.
 * If software source code is provided to you, modification and redistribution of the
 * source code are permitted provided that the following conditions are met:
 * *       any redistribution and use of the source code, including any resulting derivative
 * works, are licensed by TI for use only with TI Devices.
 * *       any redistribution and use of any object code compiled from the source code
 * and any resulting derivative works, are licensed by TI for use only with TI Devices.
 * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
 * may be used to endorse or promote products derived from this software without
 * specific prior written permission.
 * DISCLAIMER.
 * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
 * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
 * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
 * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
 * OF THE POSSIBILITY OF SUCH DAMAGE.
#include "app_single_cam_main.h"
#include <utils/iss/include/app_iss.h>
#include "app_test.h"
#ifdef A72
#if defined(LINUX)
/*ITT server is supported only in target mode and only on Linux*/
#include <itt_server.h>
#endif
#endif
static char availableSensorNames[ISS_SENSORS_MAX_SUPPORTED_SENSOR][ISS_SENSORS_MAX_NAME];
static vx_uint8 num_sensors_found;
static IssSensor_CreateParams sensorParams;
uint32_t close_loop = 0;
uint32_t done = 0;
char menu_ch = 0;
uint32_t csitx_status = 0;
#define NUM_CAPT_CHANNELS   (4u)
#ifdef _APP_DEBUG_
static char *app_get_test_file_path()
    char *tivxPlatformGetEnv(char *env_var);
    #if defined(SYSBIOS)
    return tivxPlatformGetEnv("VX_TEST_DATA_PATH");
    #else
    return getenv("VX_TEST_DATA_PATH");
    #endif
#endif //_APP_DEBUG_
#ifdef USE_CSITX
vx_object_array tx_frame = 0;
static tivx_raw_image raw_image_exemplar;
#endif
 * Utility API used to add a graph parameter from a node, node parameter index
void add_graph_parameter_by_node_index(vx_graph graph, vx_node node, vx_uint32 node_parameter_index)
    vx_parameter parameter = vxGetParameterByIndex(node, node_parameter_index);
    vxAddParameterToGraph(graph, parameter);
    vxReleaseParameter(&parameter);
vx_status app_init(AppObj *obj)
    vx_status status = VX_SUCCESS;
    char* sensor_list[ISS_SENSORS_MAX_SUPPORTED_SENSOR];
    vx_uint8 count = 0;
    char ch = 0xFF;
    vx_uint8 selectedSensor = 0xFF;
    vx_uint8 detectedSensors[ISS_SENSORS_MAX_CHANNEL];
#ifdef A72
#if defined(LINUX)
    status = itt_server_init((void*)obj, (void*)save_debug_images, (void*)appSingleCamUpdateVpacDcc);
    if(status != 0)
        printf("Warning : Failed to initialize ITT server. Live tuning will not work \n");
#endif
#endif
    for(count=0;count<ISS_SENSORS_MAX_CHANNEL;count++)
        detectedSensors[count] = 0xFF;
    for(count=0;count<ISS_SENSORS_MAX_SUPPORTED_SENSOR;count++)
        sensor_list[count] = NULL;
    obj->stop_task = 0;
    obj->stop_task_done = 0;
    obj->selectedCam = 0xFF;
    if(status == VX_SUCCESS)
        obj->context = vxCreateContext();
        status = vxGetStatus((vx_reference) obj->context);
        tivxHwaLoadKernels(obj->context);
        tivxImagingLoadKernels(obj->context);
        APP_PRINTF("tivxImagingLoadKernels done\n");
    /*memset(availableSensorNames, 0, ISS_SENSORS_MAX_SUPPORTED_SENSOR*ISS_SENSORS_MAX_NAME);*/
        availableSensorNames[count][0] = '\0';
        sensor_list[count] = availableSensorNames[count];
        status = appEnumerateImageSensor(sensor_list, &num_sensors_found);
    if(obj->channel)
        int32_t channel_num = obj->channel_number;
        obj->selectedCam = channel_num;
	if (obj->selectedCam == 7)
	    csitx_status = 1;
        printf("Set cam test port = %d  \n", obj->selectedCam);
        while(obj->selectedCam == 0xFF)
            if(channel_num >= ISS_SENSORS_MAX_CHANNEL)
                printf("Invalid entry %c. Please choose between 0 and %d \n", ch, ISS_SENSORS_MAX_CHANNEL-1);
                channel_num = 0xFF;
        while ((channel_num != 0xFF) && (selectedSensor > (num_sensors_found-1)))
            printf("%d registered sensor drivers\n", num_sensors_found);
            for(count=0;count<num_sensors_found;count++)
                printf("%c : %s \n", count+'a', sensor_list[count]);
            printf("Select a sensor above or press '0' to autodetect the sensor : ");
            selectedSensor = 'l' - 'a';
            obj->sensor_name = sensor_list[selectedSensor];
            printf("Sensor selected : %s\n", obj->sensor_name);
        obj->ldc_enable = '0'-'0';
    if(obj->is_interactive)
            printf("Select camera port index 0-%d : ", ISS_SENSORS_MAX_CHANNEL-1);
            ch = getchar();
            obj->selectedCam = ch - '0';
            if(obj->selectedCam >= ISS_SENSORS_MAX_CHANNEL)
            while ((obj->selectedCam != 0xFF) && (selectedSensor > (num_sensors_found-1)))
                ch = getchar();
                if(ch == '0')
                    uint8_t num_sensors_detected = 0;
                    uint8_t channel_mask = (1<<obj->selectedCam);
                    status = appDetectImageSensor(detectedSensors, &num_sensors_detected, channel_mask);
                    if(0 == status)
                        selectedSensor = detectedSensors[obj->selectedCam];
                        if(selectedSensor > ISS_SENSORS_MAX_SUPPORTED_SENSOR)
                            printf("No sensor detected at port %d. Please select another port \n", obj->selectedCam);
                    else
                        printf("sensor detection at port %d returned error . Please try again \n", obj->selectedCam);
                else
                    selectedSensor = ch - 'a';
                    if(selectedSensor > (num_sensors_found-1))
                        printf("Invalid selection %c. Try again \n", ch);
        ch = 0xFF;
        fflush (stdin);
        while ((ch != '0') && (ch != '1'))
            fflush (stdin);
            printf ("LDC Selection Yes(1)/No(0) : ");
            ch = getchar();
        obj->ldc_enable = ch - '0';
    else
        selectedSensor = obj->sensor_sel;
            printf("Invalid sensor selection %d \n", selectedSensor);
            return VX_FAILURE;
    obj->sensor_wdr_mode = 0;
    obj->table_width = LDC_TABLE_WIDTH;
    obj->table_height = LDC_TABLE_HEIGHT;
    obj->ds_factor = LDC_DS_FACTOR;
    /* Display initialization */
    memset(&obj->display_params, 0, sizeof(tivx_display_params_t));
    obj->display_params.opMode = TIVX_KERNEL_DISPLAY_ZERO_BUFFER_COPY_MODE;
    obj->display_params.pipeId = 2;
    obj->display_params.outHeight = 1080;
    obj->display_params.outWidth = 1920;
    obj->display_params.posX = 0;
    obj->display_params.posY = 0;
    obj->scaler_enable = vx_false_e;
    appPerfPointSetName(&obj->total_perf , "TOTAL");
    return status;
vx_status app_deinit(AppObj *obj)
    vx_status status = VX_FAILURE;
    tivxHwaUnLoadKernels(obj->context);
    APP_PRINTF("tivxHwaUnLoadKernels done\n");
    tivxImagingUnLoadKernels(obj->context);
    APP_PRINTF("tivxImagingUnLoadKernels done\n");
    status = vxReleaseContext(&obj->context);
    if(VX_SUCCESS == status)
        APP_PRINTF("vxReleaseContext done\n");
    else
        printf("Error: vxReleaseContext returned 0x%x \n", status);
    return status;
 * Graph,
 *           viss_config
 *               v
 * input_img -> VISS -----> LDC -----> output_img
vx_status app_create_graph(AppObj *obj)
    int32_t sensor_init_status = -1;
    obj->configuration = NULL;
    obj->raw = NULL;
    obj->y12 = NULL;
    obj->uv12_c1 = NULL;
    obj->y8_r8_c2 = NULL;
    obj->uv8_g8_c3 = NULL;
    obj->s8_b8_c4 = NULL;
    obj->histogram = NULL;
    obj->h3a_aew_af = NULL;
    obj->display_image = NULL;
    unsigned int image_width = obj->width_in;
    unsigned int image_height = obj->height_in;
    tivx_raw_image raw_image = 0;
    vx_user_data_object capture_config;
    vx_uint8 num_capture_frames = 1;
    tivx_capture_params_t local_capture_config;
    uint32_t buf_id;
    const vx_char capture_user_data_object_name[] = "tivx_capture_params_t";
    uint32_t sensor_features_enabled = 0;
    uint32_t sensor_features_supported = 0;
    uint32_t sensor_wdr_enabled = 0;
    uint32_t sensor_exp_control_enabled = 0;
    uint32_t sensor_gain_control_enabled = 0;
    vx_bool yuv_cam_input = vx_false_e;
    vx_image viss_out_image = NULL;
    vx_image ldc_in_image = NULL;
    vx_image capt_yuv_image = NULL;
    vx_uint32 params_list_depth = 1;
    if(obj->test_mode == 1)
        params_list_depth = 2;
    vx_graph_parameter_queue_params_t graph_parameters_queue_params_list[params_list_depth];
    printf("Querying %s \n", obj->sensor_name);
    memset(&sensorParams, 0, sizeof(sensorParams));
    status = appQueryImageSensor(obj->sensor_name, &sensorParams);
    if(VX_SUCCESS != status)
        printf("appQueryImageSensor returned %d\n", status);
        return status;
    if(sensorParams.sensorInfo.raw_params.format[0].pixel_container == VX_DF_IMAGE_UYVY)
        yuv_cam_input = vx_true_e;
        printf("YUV Input selected. VISS and AEWB nodes will be bypassed. \n");
    Check for supported sensor features.
    It is upto the application to decide which features should be enabled.
    This demo app enables WDR, DCC and 2A if the sensor supports it.
    sensor_features_supported = sensorParams.sensorInfo.features;
    if(vx_false_e == yuv_cam_input)
        if(ISS_SENSOR_FEATURE_COMB_COMP_WDR_MODE == (sensor_features_supported & ISS_SENSOR_FEATURE_COMB_COMP_WDR_MODE))
            APP_PRINTF("WDR mode is supported \n");
            sensor_features_enabled |= ISS_SENSOR_FEATURE_COMB_COMP_WDR_MODE;
            sensor_wdr_enabled = 1;
            obj->sensor_wdr_mode = 1;
            //Brandon: Use linear mode instead wdr evenif wdr mode supported
            /* sensor_features_enabled |= ISS_SENSOR_FEATURE_LINEAR_MODE; */
            /* sensor_wdr_enabled = 0; */
            /* obj->sensor_wdr_mode = 0; */
        }else
            APP_PRINTF("WDR mode is not supported. Defaulting to linear \n");
        if(ISS_SENSOR_FEATURE_MANUAL_EXPOSURE == (sensor_features_supported & ISS_SENSOR_FEATURE_MANUAL_EXPOSURE))
            APP_PRINTF("Expsoure control is supported \n");
            sensor_features_enabled |= ISS_SENSOR_FEATURE_MANUAL_EXPOSURE;
            sensor_exp_control_enabled = 1;
        if(ISS_SENSOR_FEATURE_MANUAL_GAIN == (sensor_features_supported & ISS_SENSOR_FEATURE_MANUAL_GAIN))
            APP_PRINTF("Gain control is supported \n");
            sensor_features_enabled |= ISS_SENSOR_FEATURE_MANUAL_GAIN;
            sensor_gain_control_enabled = 1;
        if(ISS_SENSOR_FEATURE_CFG_UC1 == (sensor_features_supported & ISS_SENSOR_FEATURE_CFG_UC1))
            APP_PRINTF("CMS Usecase is supported \n");
            sensor_features_enabled |= ISS_SENSOR_FEATURE_CFG_UC1;
        switch(sensorParams.sensorInfo.aewbMode)
            case ALGORITHMS_ISS_AEWB_MODE_NONE:
                obj->aewb_cfg.ae_mode = ALGORITHMS_ISS_AE_DISABLED;
                obj->aewb_cfg.awb_mode = ALGORITHMS_ISS_AWB_DISABLED;
                break;
            case ALGORITHMS_ISS_AEWB_MODE_AWB:
                obj->aewb_cfg.awb_mode = ALGORITHMS_ISS_AWB_AUTO;
                break;
            case ALGORITHMS_ISS_AEWB_MODE_AE:
                obj->aewb_cfg.ae_mode = ALGORITHMS_ISS_AE_AUTO;
                break;
            case ALGORITHMS_ISS_AEWB_MODE_AEWB:
                break;
        if(obj->aewb_cfg.ae_mode == ALGORITHMS_ISS_AE_DISABLED)
            if(sensor_exp_control_enabled || sensor_gain_control_enabled )
                obj->aewb_cfg.ae_mode = ALGORITHMS_ISS_AE_MANUAL;
        APP_PRINTF("obj->aewb_cfg.ae_mode = %d\n", obj->aewb_cfg.ae_mode);
        APP_PRINTF("obj->aewb_cfg.awb_mode = %d\n", obj->aewb_cfg.awb_mode);
    if(ISS_SENSOR_FEATURE_DCC_SUPPORTED == (sensor_features_supported & ISS_SENSOR_FEATURE_DCC_SUPPORTED))
        sensor_features_enabled |= ISS_SENSOR_FEATURE_DCC_SUPPORTED;
        APP_PRINTF("Sensor DCC is enabled \n");
    }else
        APP_PRINTF("Sensor DCC is NOT enabled \n");
    APP_PRINTF("Sensor width = %d\n", sensorParams.sensorInfo.raw_params.width);
    APP_PRINTF("Sensor height = %d\n", sensorParams.sensorInfo.raw_params.height);
    APP_PRINTF("Sensor DCC ID = %d\n", sensorParams.dccId);
    APP_PRINTF("Sensor Supported Features = 0x%x\n", sensor_features_supported);
    APP_PRINTF("Sensor Enabled Features = 0x%x\n", sensor_features_enabled);
    sensor_init_status = appInitImageSensor(obj->sensor_name, sensor_features_enabled, channel_mask);/*Mask = 1 for camera # 0*/
    if(0 != sensor_init_status)
        /* Not returning failure because application may be waiting for
            error/test frame */
        printf("Error initializing sensor %s \n", obj->sensor_name);
    image_width     = sensorParams.sensorInfo.raw_params.width;
    image_height    = sensorParams.sensorInfo.raw_params.height;
    obj->cam_dcc_id = sensorParams.dccId;
    obj->width_in = image_width;
    obj->height_in = image_height;
Assuming same dataformat for all exposures.
This may not be true for staggered HDR. WIll be handled later
    for(count = 0;count<raw_params.num_exposures;count++)
        memcpy(&(raw_params.format[count]), &(sensorProperties.sensorInfo.dataFormat), sizeof(tivx_raw_image_format_t));
Sensor driver does not support metadata yet.
    APP_PRINTF("Creating graph \n");
    obj->graph = vxCreateGraph(obj->context);
        status = vxGetStatus((vx_reference) obj->graph);
    APP_ASSERT(vx_true_e == tivxIsTargetEnabled(TIVX_TARGET_VPAC_VISS1));
    APP_PRINTF("Initializing params for capture node \n");
    /* Setting to num buf of capture node */
    obj->num_cap_buf = NUM_BUFS;
        raw_image = tivxCreateRawImage(obj->context, &sensorParams.sensorInfo.raw_params);
        /* allocate Input and Output refs, multiple refs created to allow pipelining of graph */
        for(buf_id=0; buf_id<obj->num_cap_buf; buf_id++)
                obj->cap_frames[buf_id] = vxCreateObjectArray(obj->context, (vx_reference)raw_image, num_capture_frames);
                status = vxGetStatus((vx_reference) obj->cap_frames[buf_id]);
    else
        capt_yuv_image = vxCreateImage(
                                obj->context,
                                sensorParams.sensorInfo.raw_params.width,
                                sensorParams.sensorInfo.raw_params.height,
                                VX_DF_IMAGE_UYVY
                obj->cap_frames[buf_id] = vxCreateObjectArray(obj->context, (vx_reference)capt_yuv_image, num_capture_frames);
    /* Config initialization */
    tivx_capture_params_init(&local_capture_config);
    local_capture_config.timeout = 33;
    local_capture_config.timeoutInitial = 500;
    local_capture_config.numInst  = 2U;/* Configure both instances */
    local_capture_config.numCh = 1U;/* Single cam. Only 1 channel enabled */
        vx_uint8 ch, id, lane, q;
        for(id = 0; id < local_capture_config.numInst; id++)
            local_capture_config.instId[id]                       = 1 - id;
            /* local_capture_config.instId[id]                       = 1-id; *///if swap buffer
            local_capture_config.instCfg[id].enableCsiv2p0Support = (uint32_t)vx_true_e;
            local_capture_config.instCfg[id].numDataLanes         = sensorParams.sensorInfo.numDataLanes;
            local_capture_config.instCfg[id].laneBandSpeed        = sensorParams.sensorInfo.csi_laneBandSpeed;
            for (lane = 0; lane < local_capture_config.instCfg[id].numDataLanes; lane++)
                local_capture_config.instCfg[id].dataLanesMap[lane] = lane + 1;
            for (q = 0; q < NUM_CAPT_CHANNELS; q++)
                ch = (NUM_CAPT_CHANNELS-1)* id + q;
                local_capture_config.chVcNum[ch]   = q;
                local_capture_config.chInstMap[ch] = id;
                /* local_capture_config.chInstMap[ch] = 1-id; *///if swap buffer
    local_capture_config.chInstMap[0] = 1 - obj->selectedCam/NUM_CAPT_CHANNELS;//swap csi 0/ csi 1
    local_capture_config.chVcNum[0]   = obj->selectedCam%NUM_CAPT_CHANNELS;
    capture_config = vxCreateUserDataObject(obj->context, capture_user_data_object_name, sizeof(tivx_capture_params_t), &local_capture_config);
    APP_PRINTF("capture_config = 0x%p \n", capture_config);
    APP_PRINTF("Creating capture node \n");
    obj->capture_node = tivxCaptureNode(obj->graph, capture_config, obj->cap_frames[0]);
    APP_PRINTF("obj->capture_node = 0x%p \n", obj->capture_node);
        status = vxReleaseUserDataObject(&capture_config);
        status = vxSetNodeTarget(obj->capture_node, VX_TARGET_STRING, TIVX_TARGET_CAPTURE2);
        obj->raw = (tivx_raw_image)vxGetObjectArrayItem(obj->cap_frames[0], 0);
            status = tivxReleaseRawImage(&raw_image);
#ifdef _APP_DEBUG_
        obj->fs_test_raw_image = tivxCreateRawImage(obj->context, &(sensorParams.sensorInfo.raw_params));
        if (NULL != obj->fs_test_raw_image)
                status = read_test_image_raw(NULL, obj->fs_test_raw_image, obj->test_mode);
            else
                status = tivxReleaseRawImage(&obj->fs_test_raw_image);
                obj->fs_test_raw_image = NULL;
        status = app_create_viss(obj, sensor_wdr_enabled);
        vxSetNodeTarget(obj->node_viss, VX_TARGET_STRING, TIVX_TARGET_VPAC_VISS1);
        tivxSetNodeParameterNumBufByIndex(obj->node_viss, 6u, obj->num_cap_buf);
        else
            printf("app_create_viss failed \n");
            return -1;
        status = app_create_aewb(obj, sensor_wdr_enabled);
            printf("app_create_aewb failed \n");
            return -1;
        viss_out_image = obj->y8_r8_c2;
        ldc_in_image = viss_out_image;
    else
        obj->capt_yuv_image = (vx_image)vxGetObjectArrayItem(obj->cap_frames[0], 0);
        ldc_in_image = obj->capt_yuv_image;
        vxReleaseImage(&capt_yuv_image);
    if (obj->ldc_enable)
        printf ("Enabling LDC \n");
        status = app_create_ldc(obj, ldc_in_image);
            status = vxSetNodeTarget(obj->node_ldc, VX_TARGET_STRING, TIVX_TARGET_VPAC_LDC1);
        else
            printf("app_create_ldc returned error \n");
            return status;
            status = tivxSetNodeParameterNumBufByIndex(obj->node_ldc, 7u, obj->num_cap_buf);
        /*Check if resizing is needed for display*/
        if((obj->table_width >= obj->display_params.outWidth) && (obj->table_height >= obj->display_params.outHeight))
            vx_uint16 scaler_out_w, scaler_out_h;
            obj->scaler_enable = vx_true_e;
            appIssGetResizeParams(obj->table_width, obj->table_height, obj->display_params.outWidth, obj->display_params.outHeight, &scaler_out_w, &scaler_out_h);
            obj->scaler_out_img = vxCreateImage(obj->context, scaler_out_w, scaler_out_h, VX_DF_IMAGE_NV12);
            obj->scalerNode = tivxVpacMscScaleNode(obj->graph, obj->ldc_out, obj->scaler_out_img, NULL, NULL, NULL, NULL);
                status = tivxSetNodeParameterNumBufByIndex(obj->scalerNode, 1u, obj->num_cap_buf);
            obj->display_params.outHeight = scaler_out_h;
            obj->display_params.outWidth = scaler_out_w;
            obj->display_image = obj->scaler_out_img;
        }else /*No resize needed*/
            obj->display_image = obj->ldc_out;
            /* MSC can only downsize. If ldc resolution is lower,
               display resolution must be set accordingly
            obj->display_params.outWidth = obj->table_width;
            obj->display_params.outHeight = obj->table_height;
    else /*ldc_enable*/
        if(NULL != obj->capt_yuv_image)
            /*MSC does not support YUV422 input*/
        else
            if ((image_width >= obj->display_params.outWidth) && (image_height >= obj->display_params.outHeight))
            else
                /* MSC can only downsize. If viss resolution is lower,
                obj->display_params.outWidth = image_width;
                obj->display_params.outHeight = image_height;
        if(vx_true_e == obj->scaler_enable)
            appIssGetResizeParams(image_width, image_height, obj->display_params.outWidth, obj->display_params.outHeight, &scaler_out_w, &scaler_out_h);
            obj->scalerNode = tivxVpacMscScaleNode(obj->graph, ldc_in_image, obj->scaler_out_img, NULL, NULL, NULL, NULL);
                status = vxSetNodeTarget(obj->scalerNode, VX_TARGET_STRING, TIVX_TARGET_VPAC_MSC1);
        else
            obj->display_image = ldc_in_image;
#if 0//Brandon
    if(NULL == obj->display_image)
        printf("Error : Display input is uninitialized \n");
        return VX_FAILURE;
    else
        obj->display_params.posX = (1920U - obj->display_params.outWidth)/2;
        obj->display_params.posY = (1080U - obj->display_params.outHeight)/2;
        obj->display_param_obj = vxCreateUserDataObject(obj->context, "tivx_display_params_t", sizeof(tivx_display_params_t), &obj->display_params);
        obj->displayNode = tivxDisplayNode(obj->graph, obj->display_param_obj, obj->display_image);
        status = vxSetNodeTarget(obj->displayNode, VX_TARGET_STRING, TIVX_TARGET_DISPLAY1);//Org
        /* status = vxSetNodeTarget(obj->displayNode, VX_TARGET_STRING, TIVX_TARGET_CSITX);//Brandon */
        /* status = vxSetNodeTarget(obj->displayNode, VX_TARGET_STRING, TIVX_TARGET_DISPLAY_M2M1);//Brandon */
        APP_PRINTF("Display Set Target done\n");
#endif
#ifdef USE_CSITX
    if(csitx_status == 1)
        /* CSI-TX initialization */
        tivx_csitx_params_t local_csitx_config;
        uint32_t loopCnt;
        /* CSITX Config initialization */
        tivx_csitx_params_init(&local_csitx_config);
        local_csitx_config.numInst                          = 1U;
        local_csitx_config.numCh                            = NUM_CHANNELS;
        local_csitx_config.instId[0U]                       = 0;
        local_csitx_config.instCfg[0U].rxCompEnable         = (uint32_t)vx_true_e;
        local_csitx_config.instCfg[0U].rxv1p3MapEnable      = (uint32_t)vx_true_e;
        local_csitx_config.instCfg[0U].laneBandSpeed        = (TIVX_CAPTURE_LANE_BAND_SPEED_880_TO_1040_MBPS);//(TIVX_CAPTURE_LANE_BAND_SPEED_720_TO_800_MBPS);//(TIVX_CAPTURE_LANE_BAND_SPEED_1750_TO_2000_MBPS);//(TIVX_CAPTURE_LANE_BAND_SPEED_720_TO_800_MBPS);
        local_csitx_config.instCfg[0U].laneSpeedMbps        = 1000U;//2000U;//800U;//TIVX_CSITX_LANE_SPEED_MBPS_RESERVED;
        local_csitx_config.instCfg[0U].numDataLanes         = 4U;
        for (loopCnt = 0U ;
             loopCnt < local_csitx_config.instCfg[0U].numDataLanes ;
             loopCnt++)
            local_csitx_config.instCfg[0U].lanePolarityCtrl[loopCnt] = 0u;
        for (loopCnt = 0U; loopCnt < NUM_CHANNELS; loopCnt++)
            local_csitx_config.chVcNum[loopCnt]   = loopCnt;
            local_csitx_config.chInstMap[loopCnt] = 0;
        obj->csitx_config = vxCreateUserDataObject(obj->context, "tivx_csitx_params_t", sizeof(tivx_csitx_params_t), &local_csitx_config);
        uint16_t frmIdx;
        tivx_raw_image tx_frame_array_item=0;
        tivx_raw_image_create_params_t params;
        params.width = 3840;//1920;
        params.height = 2160;//1080;
        params.num_exposures = 1;
        params.line_interleaved = vx_false_e;//vx_true_e;
        params.format[0].pixel_container = TIVX_RAW_IMAGE_16_BIT;
        params.format[0].msb = 11;//13;
        params.meta_height_before = 0;
        params.meta_height_after = 0;
        raw_image_exemplar = tivxCreateRawImage(obj->context, &params);
        tx_frame = vxCreateObjectArray(obj->context, (vx_reference)raw_image_exemplar, NUM_CHANNELS);
        /* tx_frame = vxCreateObjectArray(obj->context, (vx_reference)obj->captureObj.raw_image_arr[0], 4); */
        printf("Initializing Transmit Buffers...\n");
        for (frmIdx = 0U; frmIdx < NUM_CHANNELS; frmIdx++)
            tx_frame_array_item = (tivx_raw_image)vxGetObjectArrayItem(tx_frame , frmIdx);
            if (tx_frame_array_item == NULL)
                printf("%s[%d]vx_frame_array_item create failed\n", __FUNCTION__, __LINE__);
            else
                printf("vxGetObjectArrayItem success\n");
            status = readRAWinput(tx_frame_array_item, "./csitx.raw");
            if (status != VX_SUCCESS)
                printf("%s[%d] load rawfile failed\n", __FUNCTION__, __LINE__);
            status = tivxReleaseRawImage(&tx_frame_array_item);
                printf("%s[%d] tx_frame_array_item Release failed\n", __FUNCTION__, __LINE__);
        printf("Initializing Transmit Buffers Done.\n");
        obj->csitx_node = tivxCsitxNode(obj->graph, obj->csitx_config, tx_frame);
        vxSetNodeTarget(obj->csitx_node, VX_TARGET_STRING, TIVX_TARGET_CSITX);
        printf("Csitx graph done!\n");
#endif
    int graph_parameter_num = 0;
    /* input @ node index 1, becomes graph parameter 0 */
    add_graph_parameter_by_node_index(obj->graph, obj->capture_node, 1);
    /* set graph schedule config such that graph parameter @ index 0 is enqueuable */
    graph_parameters_queue_params_list[graph_parameter_num].graph_parameter_index = graph_parameter_num;
    graph_parameters_queue_params_list[graph_parameter_num].refs_list_size = obj->num_cap_buf;
    graph_parameters_queue_params_list[graph_parameter_num].refs_list = (vx_reference*)&(obj->cap_frames[0]);
    graph_parameter_num++;
        add_graph_parameter_by_node_index(obj->graph, obj->displayNode, 1);
        graph_parameters_queue_params_list[graph_parameter_num].refs_list_size = 1;
        graph_parameters_queue_params_list[graph_parameter_num].refs_list = (vx_reference*)&(obj->display_image);
        status = tivxSetGraphPipelineDepth(obj->graph, obj->num_cap_buf);
    /* Schedule mode auto is used, here we dont need to call vxScheduleGraph
     * Graph gets scheduled automatically as refs are enqueued to it
        status = vxSetGraphScheduleConfig(obj->graph,
                        VX_GRAPH_SCHEDULE_MODE_QUEUE_AUTO,
                        params_list_depth,
    APP_PRINTF("vxSetGraphScheduleConfig done\n");
        status = vxVerifyGraph(obj->graph);
        tivx_vpac_msc_coefficients_t sc_coeffs;
        vx_reference refs[1];
        printf("Scaler is enabled\n");
        tivx_vpac_msc_coefficients_params_init(&sc_coeffs, VX_INTERPOLATION_BILINEAR);
        obj->sc_coeff_obj = vxCreateUserDataObject(obj->context, "tivx_vpac_msc_coefficients_t", sizeof(tivx_vpac_msc_coefficients_t), NULL);
            status = vxCopyUserDataObject(obj->sc_coeff_obj, 0, sizeof(tivx_vpac_msc_coefficients_t), &sc_coeffs, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST);
        refs[0] = (vx_reference)obj->sc_coeff_obj;
            status = tivxNodeSendCommand(obj->scalerNode, 0u, TIVX_VPAC_MSC_CMD_SET_COEFF, refs, 1u);
    else
        printf("Scaler is disabled\n");
        status = tivxExportGraphToDot(obj->graph, ".", "single_cam_graph");
#ifdef _APP_DEBUG_
        if( (NULL != obj->fs_test_raw_image) && (NULL != obj->capture_node) && (status == VX_SUCCESS))
            status = app_send_test_frame(obj->capture_node, obj->fs_test_raw_image);
    APP_PRINTF("app_create_graph exiting\n");
    return status;
vx_status app_delete_graph(AppObj *obj)
    uint32_t buf_id;
    if(NULL != obj->capture_node)
        APP_PRINTF("releasing capture node\n");
        status |= vxReleaseNode(&obj->capture_node);
    if(NULL != obj->node_viss)
        APP_PRINTF("releasing node_viss\n");
        status |= vxReleaseNode(&obj->node_viss);
    if(NULL != obj->node_aewb)
        APP_PRINTF("releasing node_aewb\n");
        status |= vxReleaseNode(&obj->node_aewb);
    if(NULL != obj->displayNode)
        APP_PRINTF("releasing displayNode\n");
        status |= vxReleaseNode(&obj->displayNode);
    status |= tivxReleaseRawImage(&obj->raw);
    APP_PRINTF("releasing raw image done\n");
       if(NULL != obj->cap_frames[buf_id])
        APP_PRINTF("releasing cap_frame # %d\n", buf_id);
        status |= vxReleaseObjectArray(&(obj->cap_frames[buf_id]));
    for(buf_id=0; buf_id<obj->num_viss_out_buf; buf_id++)
      if(NULL != obj->viss_out_luma[buf_id])
        APP_PRINTF("releasing y8 buffer # %d\n", buf_id);
        status |= vxReleaseImage(&(obj->viss_out_luma[buf_id]));
        APP_PRINTF("releasing capt_yuv_image\n");
        status |= vxReleaseImage(&obj->capt_yuv_image);
    if(NULL != obj->y12)
        APP_PRINTF("releasing y12\n");
        status |= vxReleaseImage(&obj->y12);
    if(NULL != obj->uv12_c1)
        APP_PRINTF("releasing uv12_c1\n");
        status |= vxReleaseImage(&obj->uv12_c1);
    if(NULL != obj->s8_b8_c4)
        APP_PRINTF("releasing s8_b8_c4\n");
        status |= vxReleaseImage(&obj->s8_b8_c4);
    if(NULL != obj->y8_r8_c2)
        APP_PRINTF("releasing y8_r8_c2\n");
        status |= vxReleaseImage(&obj->y8_r8_c2);
    if(NULL != obj->uv8_g8_c3)
        APP_PRINTF("releasing uv8_g8_c3\n");
        status |= vxReleaseImage(&obj->uv8_g8_c3);
    if(NULL != obj->histogram)
        APP_PRINTF("releasing histogram\n");
        status |= vxReleaseDistribution(&obj->histogram);
    if(NULL != obj->configuration)
        APP_PRINTF("releasing configuration\n");
        status |= vxReleaseUserDataObject(&obj->configuration);
    if (NULL != obj->ae_awb_result)
        status |= vxReleaseUserDataObject(&obj->ae_awb_result);
        APP_PRINTF("releasing ae_awb_result done\n");
    if(NULL != obj->h3a_aew_af)
        APP_PRINTF("releasing h3a_aew_af\n");
        status |= vxReleaseUserDataObject(&obj->h3a_aew_af);
    if(NULL != obj->aewb_config)
        APP_PRINTF("releasing aewb_config\n");
        status |= vxReleaseUserDataObject(&obj->aewb_config);
    if(NULL != obj->dcc_param_viss)
        APP_PRINTF("releasing VISS DCC Data Object\n");
        status |= vxReleaseUserDataObject(&obj->dcc_param_viss);
    if(NULL != obj->display_param_obj)
        APP_PRINTF("releasing Display Param Data Object\n");
        status |= vxReleaseUserDataObject(&obj->display_param_obj);
    if(NULL != obj->dcc_param_2a)
        APP_PRINTF("releasing 2A DCC Data Object\n");
        status |= vxReleaseUserDataObject(&obj->dcc_param_2a);
    if(NULL != obj->dcc_param_ldc)
        APP_PRINTF("releasing LDC DCC Data Object\n");
        status |= vxReleaseUserDataObject(&obj->dcc_param_ldc);
        if (NULL != obj->mesh_img)
            APP_PRINTF("releasing LDC Mesh Image \n");
            status |= vxReleaseImage(&obj->mesh_img);
        if (NULL != obj->ldc_out)
            APP_PRINTF("releasing LDC Output Image \n");
            status |= vxReleaseImage(&obj->ldc_out);
        if (NULL != obj->mesh_params_obj)
            APP_PRINTF("releasing LDC Mesh Parameters Object\n");
            status |= vxReleaseUserDataObject(&obj->mesh_params_obj);
        if (NULL != obj->ldc_param_obj)
            APP_PRINTF("releasing LDC Parameters Object\n");
            status |= vxReleaseUserDataObject(&obj->ldc_param_obj);
        if (NULL != obj->region_params_obj)
            APP_PRINTF("releasing LDC Region Parameters Object\n");
            status |= vxReleaseUserDataObject(&obj->region_params_obj);
        if(NULL != obj->node_ldc)
            APP_PRINTF("releasing LDC Node \n");
            status |= vxReleaseNode(&obj->node_ldc);
        if (NULL != obj->scaler_out_img)
            APP_PRINTF("releasing Scaler Output Image \n");
            status |= vxReleaseImage(&obj->scaler_out_img);
        if(NULL != obj->scalerNode)
            APP_PRINTF("releasing Scaler Node \n");
            status |= vxReleaseNode(&obj->scalerNode);
        if (NULL != obj->sc_coeff_obj)
            APP_PRINTF("release Scalar coefficient data object \n");
            status |= vxReleaseUserDataObject(&obj->sc_coeff_obj);
#ifdef _APP_DEBUG_
    if(NULL != obj->fs_test_raw_image)
        APP_PRINTF("releasing test raw image buffer # %d\n", buf_id);
        status |= tivxReleaseRawImage(&obj->fs_test_raw_image);
#endif
    APP_PRINTF("releasing graph\n");
    status |= vxReleaseGraph(&obj->graph);
    APP_PRINTF("releasing graph done\n");
    return status;
vx_status app_run_graph(AppObj *obj)
    vx_uint32 i;
    vx_uint32 frm_loop_cnt;
    uint8_t channel_mask = (1 << obj->selectedCam);
    uint32_t buf_id;
    uint32_t num_refs_capture;
    vx_object_array out_capture_frames;
    if(NULL == obj->sensor_name)
        printf("sensor name is NULL \n");
        return VX_FAILURE;
    status = appStartImageSensor(obj->sensor_name, channel_mask);
    if(status < 0)
        printf("Failed to start sensor %s \n", obj->sensor_name);
            printf("Defaulting to file test mode \n");
            status = 0;
            status = vxGraphParameterEnqueueReadyRef(obj->graph, 0, (vx_reference*)&(obj->cap_frames[buf_id]), 1);
        /* in order for the graph to finish execution, the
            display still needs to be enqueued 4 times for testing */
        if((status == VX_SUCCESS) && (obj->test_mode == 1))
            status = vxGraphParameterEnqueueReadyRef(obj->graph, 1, (vx_reference*)&(obj->display_image), 1);
        The application reads and  processes the same image "frm_loop_cnt" times
        The output may change because on VISS, parameters are updated every frame based on AEWB results
        AEWB result is avaialble after 1 frame and is applied after 2 frames
        Therefore, first 2 output images will have wrong colors
    frm_loop_cnt = obj->num_frames_to_run;
    frm_loop_cnt += obj->num_cap_buf;
        /* in interactive mode loop for ever */
        frm_loop_cnt  = 0xFFFFFFFF;
#ifdef A72
#if defined(LINUX)
    appDccUpdatefromFS(obj->sensor_name, obj->sensor_wdr_mode,
                        obj->node_aewb, 0,
                        obj->node_viss, 0,
                        obj->node_ldc, 0,
                        obj->context);
#endif
#endif
    for(i=0; i<frm_loop_cnt; i++)
        vx_image test_image;
        appPerfPointBegin(&obj->total_perf);
            status = vxGraphParameterDequeueDoneRef(obj->graph, graph_parameter_num, (vx_reference*)&out_capture_frames, 1, &num_refs_capture);
            status = vxGraphParameterDequeueDoneRef(obj->graph, 1, (vx_reference*)&test_image, 1, &num_refs_capture);
        if((obj->test_mode == 1) && (i > TEST_BUFFER) && (status == VX_SUCCESS))
            vx_uint32 actual_checksum = 0;
            if(app_test_check_image(test_image, checksums_expected[obj->sensor_sel][0], &actual_checksum) == vx_false_e)
                test_result = vx_false_e;
            populate_gatherer(obj->sensor_sel, 0, actual_checksum);
        APP_PRINTF(" i %d...\n", i);
            status = vxGraphParameterEnqueueReadyRef(obj->graph, 1, (vx_reference*)&test_image, 1);
            status = vxGraphParameterEnqueueReadyRef(obj->graph, graph_parameter_num, (vx_reference*)&out_capture_frames, 1);
        appPerfPointEnd(&obj->total_perf);
        if (status == VX_SUCCESS)
            //status = app_run_graph_for_one_frame_pipeline(obj, frame_id);
            //every 250 frames to save image
            if ((i % 100) == 0)
                close_loop ++ ;
		printf("Capture_loop_number = %d \r\n", close_loop);
                save_debug_images(obj);
            /*if (close_loop == 5)
		close_loop = 0;
                break;
        if((obj->stop_task) || (status != VX_SUCCESS) || (close_loop == 5))
	    csitx_status = 0;
	    close_loop = 0;
            break;
        status = vxWaitGraph(obj->graph);
/* Dequeue buf for pipe down */
#if 0
    for(buf_id=0; buf_id<obj->num_cap_buf-2; buf_id++)
        APP_PRINTF(" Dequeuing capture # %d...\n", buf_id);
#endif
        status = appStopImageSensor(obj->sensor_name, channel_mask);
    return status;
static void app_run_task(void *app_var)
    AppObj *obj = (AppObj *)app_var;
    appPerfStatsCpuLoadResetAll();
    app_run_graph(obj);
    obj->stop_task_done = 1;
static int32_t app_run_task_create(AppObj *obj)
    tivx_task_create_params_t params;
    int32_t status;
    tivxTaskSetDefaultCreateParams(&params);
    params.task_main = app_run_task;
    params.app_var = obj;
    obj->stop_task = 0;
    status = tivxTaskCreate(&obj->task, &params);
    return status;
static void app_run_task_delete(AppObj *obj)
    while(obj->stop_task_done==0)
         tivxTaskWaitMsecs(100);
    tivxTaskDelete(&obj->task);
static char menu[] = {
    "\n"
    "\n =========================="
    "\n Demo : Single Camera w/ 2A"
    "\n"
    "\n p: Print performance statistics"
    "\n"
#ifdef _APP_DEBUG_
    "\n s: Save Sensor RAW, VISS Output and H3A output images to File System"
    "\n"
#endif
    "\n d: sensor debug"
    "\n e: Export performance statistics"
#ifdef A72
#if defined(LINUX)
    "\n"
    "\n u: Update DCC from File System"
    "\n"
    "\n"
#endif
#endif
    "\n r: read register"
    "\n x: Exit"
    "\n"
    "\n Enter Choice: "
static vx_status app_run_graph_interactive(AppObj *obj)
    vx_status status;
    char ch;
    FILE *fp;
    app_perf_point_t *perf_arr[1];
    uint32_t regaddr;
    uint8_t byte_num;
    uint32_t regvalue;
    uint32_t channel_id;
    status = app_run_task_create(obj);
    if(status!=0)
        printf("ERROR: Unable to create task\n");
    else
        appPerfStatsResetAll();
        while(!done && (status == VX_SUCCESS))
            printf(menu);
            ch = getchar();
            printf("\n");
            switch(ch)
                case 'p':
                    appPerfStatsPrintAll();
                    status = tivx_utils_graph_perf_print(obj->graph);
                    appPerfPointPrint(&obj->total_perf);
                    printf("\n");
                    appPerfPointPrintFPS(&obj->total_perf);
                    appPerfPointReset(&obj->total_perf);
                    printf("\n");
                    break;
                case 'd':
                    status = appDebugImageSensor(obj->sensor_name, channel_mask);
                    break;
#ifdef _APP_DEBUG_
                case 's':
                    break;
#endif
                case 'r':
                    memset(&regvalue, 0, sizeof(regvalue));
                    //printf("pleace input readdr: 0x");
                    //scanf("%d",&regaddr);
		            char input[20];
		            printf("Please input regaddr in hexadecimal: 0x");
	                int c;
		            while ((c = getchar()) != '\n' && c != EOF);
		            if (fgets(input, sizeof(input), stdin) != NULL)
		                input[strcspn(input, "\n")] = '\0';
		                if (strlen(input) >= 3 && strncmp(input, "0x", 2) == 0)
		                    if (sscanf(input + 2, "%x", &regaddr) != 1)
		                        printf("Invalid input for regaddr\n");
		                        return 1;
		                } else {
		                    if (sscanf(input, "%x", &regaddr) != 1)
		                        return 1;
		            else
		                printf("Error reading input\n");
		                return 1;
		            printf("Please input byte_num: ");
		                if (sscanf(input, "%hhd", &byte_num) != 1)
		                    printf("Invalid input for byte_num\n");
		                    return 1;
		            else
		                return 1;
		            printf("Please input channel_id: ");
		                if (sscanf(input, "%u", &channel_id) != 1)
		                    printf("Invalid input for channel_id\n");
		                    return 1;
		            else
		                return 1;
                    getSensorOtpFromSensor(regaddr, channel_id, byte_num, &regvalue);
                    printf("regValue = 0x%x\n",regvalue);
                    break;
                case 'e':
                    perf_arr[0] = &obj->total_perf;
                    fp = appPerfStatsExportOpenFile(".", "basic_demos_app_single_cam");
                    if (NULL != fp)
                        appPerfStatsExportAll(fp, perf_arr, 1);
                        status = tivx_utils_graph_perf_export(fp, obj->graph);
                        appPerfStatsExportCloseFile(fp);
                    else
                        printf("fp is null\n");
                    break;
#ifdef A72
#if defined(LINUX)
                case 'u':
                        obj->node_aewb, 0,
                        obj->node_viss, 0,
                        obj->node_ldc, 0,
                        obj->context);
                    break;
#endif
#endif
                case 'x':
                    obj->stop_task = 1;
                    done = 1;
                    break;
                default:
                    printf("Unsupported command %c\n", ch);
                    break;
        app_run_task_delete(obj);
    return status;
static void app_show_usage(int argc, char* argv[])
    printf("\n");
    printf(" Single Camera Demo - (c) Texas Instruments 2019\n");
    printf(" ========================================================\n");
    printf("\n");
    printf(" Usage,\n");
    printf("  %s --cfg <config file>\n", argv[0]);
    printf("\n");
#ifdef A72
#if defined(LINUX)
int appSingleCamUpdateVpacDcc(AppObj *obj, uint8_t* dcc_buf, uint32_t dcc_buf_size)
    int32_t status = 0;
    status = appUpdateVpacDcc(dcc_buf, dcc_buf_size, obj->context,
                obj->node_viss, 0,
                obj->node_aewb, 0,
                obj->node_ldc, 0
    return status;
#endif
#endif
#ifdef _APP_DEBUG_
int save_debug_images(AppObj *obj)
    int num_bytes_io = 0;
    static int file_index = 0;
    //char raw_image_fname[MAX_FNAME];
    char yuv_image_fname[MAX_FNAME];
    //char h3a_image_fname[MAX_FNAME];
    char failsafe_test_data_path[12] = "./test_data";
    //char failsafe_test_data_path[3] = "./";
    char * test_data_path = app_get_test_file_path();
    struct stat s;
    if(NULL == test_data_path)
        printf("Test data path is NULL. Defaulting to current folder \n");
        test_data_path = failsafe_test_data_path;
    if (stat(test_data_path, &s))
        printf("Test data path %s does not exist. Defaulting to current folder \n", test_data_path);
    if(NULL == obj->capt_yuv_image)
        /*snprintf(raw_image_fname, MAX_FNAME, "%s/%s_%04d.raw", test_data_path, "img", file_index);
        printf("RAW file name %s \n", raw_image_fname);
        num_bytes_io = write_output_image_raw(raw_image_fname, obj->raw);
        if(num_bytes_io < 0)
            printf("Error writing to RAW file \n");
            return VX_FAILURE;
	if (channel_num == 4)
            snprintf(yuv_image_fname, MAX_FNAME, "%s/%s_%04d.yuv", test_data_path, "img_viss", file_index);
            printf("YUV file name %s \n", yuv_image_fname);
            num_bytes_io = write_output_image_nv12_8bit(yuv_image_fname, obj->y8_r8_c2);
                printf("Error writing to VISS NV12 file \n");
                return VX_FAILURE;
	else
            snprintf(yuv_image_fname, MAX_FNAME, "%s/%s_%04d_loopback.yuv", test_data_path, "img_viss", file_index);
                return VX_FAILURE;
        /*snprintf(h3a_image_fname, MAX_FNAME, "%s/%s_%04d.bin", test_data_path, "h3a", file_index);
        printf("H3A file name %s \n", h3a_image_fname);
        num_bytes_io = write_h3a_image(h3a_image_fname, obj->h3a_aew_af);
            printf("Error writing to H3A file \n");
            return VX_FAILURE;
    else
        /*vx_image cap_yuv;
        snprintf(raw_image_fname, MAX_FNAME, "%s/%s_%04d.yuv", test_data_path, "cap", file_index);
        printf("YUV file name %s \n", raw_image_fname);
        cap_yuv = (vx_image)vxGetObjectArrayItem(obj->cap_frames[0], 0);
        num_bytes_io = write_output_image_yuv422_8bit(raw_image_fname, cap_yuv);
            printf("Error writing to YUV file \n");
            return VX_FAILURE;
    if(obj->scaler_enable)
        /*snprintf(yuv_image_fname, MAX_FNAME, "%s/%s_%04d.yuv", test_data_path, "img_msc", file_index);
        num_bytes_io = write_output_image_nv12_8bit(yuv_image_fname, obj->scaler_out_img);
            printf("Error writing to MSC NV12 file \n");
            return VX_FAILURE;
    if(obj->ldc_enable)
        snprintf(yuv_image_fname, MAX_FNAME, "%s/%s_%04d.yuv", test_data_path, "img_ldc", file_index);
        num_bytes_io = write_output_image_nv12_8bit(yuv_image_fname, obj->ldc_out);
            printf("Error writing to LDC NV12 file \n");
            return VX_FAILURE;
    file_index++;
    return (file_index-1);
static void app_parse_cfg_file(AppObj *obj, char *cfg_file_name)
    FILE *fp = fopen(cfg_file_name, "r");
    char line_str[1024];
    char *token;
    if(fp==NULL)
        printf("# ERROR: Unable to open config file [%s]. Switching to interactive mode\n", cfg_file_name);
        obj->is_interactive = 1;
    else
        while(fgets(line_str, sizeof(line_str), fp)!=NULL)
            char s[]=" \t";
            if (strchr(line_str, '#'))
                continue;
            /* get the first token */
            token = strtok(line_str, s);
            if (NULL != token)
                if(strcmp(token, "sensor_index")==0)
                    token = strtok(NULL, s);
                    if (NULL != token)
                        obj->sensor_sel = atoi(token);
                        printf("sensor_selection = [%d]\n", obj->sensor_sel);
                else
                if(strcmp(token, "ldc_enable")==0)
                    if (NULL != token)
                        obj->ldc_enable = atoi(token);
                        printf("ldc_enable = [%d]\n", obj->ldc_enable);
                else
                if(strcmp(token, "num_frames_to_run")==0)
                    if (NULL != token)
                        obj->num_frames_to_run = atoi(token);
                        printf("num_frames_to_run = [%d]\n", obj->num_frames_to_run);
                else
                if(strcmp(token, "channel")==0)
                    if(token != NULL)
                        token[strlen(token)-1]=0;
                        obj->channel = atoi(token);
                        printf("channel = [%d]\n", obj->channel);
                if (strcmp(token, "channel_number")==0)
                    if (token != NULL)
                        token[strlen(token) - 1] = 0;
                        obj->channel_number = atoi(token);
                        printf("channel_number = [%d]\n", obj->channel_number);
                else
                if(strcmp(token, "is_interactive")==0)
                    if (NULL != token)
                        obj->is_interactive = atoi(token);
                        printf("is_interactive = [%d]\n", obj->is_interactive);
                else
                    APP_PRINTF("Invalid token [%s]\n", token);
        fclose(fp);
    if(obj->width_in<128)
        obj->width_in = 128;
    if(obj->height_in<128)
        obj->height_in = 128;
    if(obj->width_out<128)
        obj->width_out = 128;
    if(obj->height_out<128)
        obj->height_out = 128;
vx_status app_parse_cmd_line_args(AppObj *obj, int argc, char *argv[])
    vx_bool set_test_mode = vx_false_e;
    vx_int8 sensor_override = 0xFF;
    app_set_cfg_default(obj);
    int i;
    if(argc==1)
        app_show_usage(argc, argv);
        printf("Defaulting to interactive mode \n");
        return VX_SUCCESS;
    for(i=0; i<argc; i++)
        if(strcmp(argv[i], "--cfg")==0)
            i++;
            if(i>=argc)
            app_parse_cfg_file(obj, argv[i]);
        else
        if(strcmp(argv[i], "--help")==0)
            return VX_FAILURE;
        else
        if(strcmp(argv[i], "--test")==0)
            set_test_mode = vx_true_e;
        else
        if(strcmp(argv[i], "--sensor")==0)
            // check to see if there is another argument following --sensor
            if (argc > i+1)
                sensor_override = atoi(argv[i+1]);
                // increment i again to avoid this arg
                i++;
    if(set_test_mode == vx_true_e)
        obj->test_mode = 1;
        obj->is_interactive = 0;
        obj->num_frames_to_run = NUM_FRAMES;
        if (sensor_override != 0xFF)
            obj->sensor_sel = sensor_override;
    return VX_SUCCESS;
#ifdef _APP_DEBUG_
vx_int32 write_output_image_nv12(char * file_name, vx_image out_nv12)
    FILE * fp = fopen(file_name, "wb");
    if(!fp)
        APP_PRINTF("Unable to open file %s\n", file_name);
        return -1;
    vx_uint32 len1 = write_output_image_fp(fp, out_nv12);
    fclose(fp);
    APP_PRINTF("%d bytes written to %s\n", len1, file_name);
    return len1;
#endif
AppObj gAppObj;
int app_single_cam_main(int argc, char* argv[])
    AppObj *obj = &gAppObj;
    status = app_parse_cmd_line_args(obj, argc, argv);
        status = app_init(obj);
            APP_PRINTF("app_init done\n");
            /* Not checking status because application may be waiting for
                error/test frame */
            app_create_graph(obj);
                APP_PRINTF("app_create_graph done\n");
                    status = app_run_graph_interactive(obj);
                else
                    status = app_run_graph(obj);
                    //status = app_run_graph_interactive(obj);  //Still keep interactive ability  @Jason
                    APP_PRINTF("app_run_graph done\n");
                    status = app_delete_graph(obj);
                        APP_PRINTF("app_delete_graph done\n");
                    else
                        printf("Error : app_delete_graph returned 0x%x \n", status);
                else
                    printf("Error : app_run_graph_xx returned 0x%x \n", status);
            else
                printf("Error : app_create_graph returned 0x%x is_interactive =%d  \n", status, obj->is_interactive);
        else
            printf("Error : app_init returned 0x%x \n", status);
        status = app_deinit(obj);
            APP_PRINTF("app_deinit done\n");
        else
            printf("Error : app_deinit returned 0x%x \n", status);
        appDeInitImageSensor(obj->sensor_name);
    else
        printf("Error: app_parse_cmd_line_args returned 0x%x \n", status);
        if((test_result == vx_false_e) || (status == VX_FAILURE))
            printf("\n\nTEST FAILED\n\n");
            print_new_checksum_structs();
            status = (status == VX_SUCCESS) ? VX_FAILURE : status;
        else
            printf("\n\nTEST PASSED\n\n");
    return status;
vx_status app_send_test_frame(vx_node cap_node, tivx_raw_image raw_img)
    status = tivxCaptureRegisterErrorFrame(cap_node, (vx_reference)raw_img);
    return status;
