Part Number: SK-AM62P-LP
We are trying to initialize a SDIO wi-fi module on our board with the following configuration.
main_mmc2_pins_default: main-mmc2-default-pins {
pinctrl-single,pins = <
AM62PX_IOPAD(0x0120, PIN_INPUT, 0) /* (K24) MMC2_CMD */
AM62PX_IOPAD(0x0118, PIN_OUTPUT, 0) /* (K21) MMC2_CLK */
AM62PX_IOPAD(0x011C, PIN_INPUT, 0) /* () MMC2_CLKLB */
AM62PX_IOPAD(0x0114, PIN_INPUT, 0) /* (K23) MMC2_DAT0 */
AM62PX_IOPAD(0x0110, PIN_INPUT_PULLUP, 0) /* (K22) MMC2_DAT1 */
AM62PX_IOPAD(0x010c, PIN_INPUT_PULLUP, 0) /* (L20) MMC2_DAT2 */
AM62PX_IOPAD(0x0108, PIN_INPUT_PULLUP, 0) /* (L21) MMC2_DAT3 */
bootph-all;
main_wlirq_pins_default: main-wlirq-default-pins {
AM62PX_IOPAD(0x0128, PIN_INPUT, 7) /* (K25) MMC2_SDWP.GPIO0_72 */
wlan_en_pins_default: wlan-en-default-pins {
AM62PX_IOPAD(0x0124, PIN_INPUT, 7) /* (J25) MMC2_SDCD.GPIO0_71 */
&sdhci2 {
status = "okay";
vmmc-supply = <&wlan_en>;
vqmmc-supply = <&vddshv_sdio>;
pinctrl-names = "default";
pinctrl-0 = <&main_mmc2_pins_default>;
ti,driver-strength-ohm = <50>;
disable-wp;
bootph-all;
cap-power-off-card;
keep-power-in-suspend;
//non-removable;
//ti,fails-without-test-cd;
//assigned-clocks = <&k3_clks 157 158>;
//assigned-clock-parents = <&k3_clks 157 160>;
#address-cells = <1>;
#size-cells = <0>;
mwifiex: mwifiex@1 {
compatible = "marvell,sd8987";
reg = <0>;
interrupt-parent = <&main_gpio0>;
interrupts = <72 IRQ_TYPE_EDGE_RISING>; //interrupts = <38 IRQ_TYPE_LEVEL_LOW>;
interrupt-names = "host-wake";
//marvell,caldata_00_txpwrlimit_2g_cfg_set = /bits/ 8 <0x01 0x00 0x06 0x00 0x08 0x02 0x89 0x01>;
marvell,wakeup-pin = <3>;
sdhci2: mmc@fa20000 {
compatible = "ti,am62-sdhci";
reg = <0x00 0x0fa20000 0x00 0x1000>, <0x00 0x0fa28000 0x00 0x400>;
interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 184 5>, <&k3_clks 184 6>;
clock-names = "clk_ahb", "clk_xin";
bus-width = <4>;
ti,clkbuf-sel = <0x7>;
ti,trm-icp = <0x8>;
ti,otap-del-sel-legacy = <0x0>;
ti,otap-del-sel-sd-hs = <0x0>;
ti,otap-del-sel-sdr12 = <0xf>;
ti,otap-del-sel-sdr25 = <0xf>;
ti,otap-del-sel-sdr50 = <0xc>;
ti,otap-del-sel-ddr50 = <0x9>;
ti,otap-del-sel-sdr104 = <0x6>;
ti,itap-del-sel-legacy = <0x0>;
ti,itap-del-sel-sd-hs = <0x0>;
ti,itap-del-sel-sdr12 = <0x0>;
ti,itap-del-sel-sdr25 = <0x0>;
status = "disabled";
Comparing with MMC1 initialization our MMC2 error is in this line on initialization.
[ 3.305718] mmc_send_io_op_cond mmc2 rocr
[ 3.306078] mmc2: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 3.306450] mmc2: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 3.306823] mmc2: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 3.307195] mmc2: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 3.307214] mmc_set_bus_mode mmc2
[ 3.307217] mmc2: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 3.307639] mmc2: req done (CMD1): -110: 00000000 00000000 00000000 00000000
[ 3.307658] mmc_power_off mmc2
Please, does anyone knows how to fix this?
Thanks.
