TDA4VH-Q1: M2M display example?
Part Number: TDA4VH-Q1
Hi experts,
I'm trying to use multi-display to display several images.
There are only 2 default display (TIVX_TARGET_DISPLAY1 and TIVX_TARGET_DISPLAY2).
Now I want to add (TIVX_TARGET_DISPLAY_M2M1, TIVX_TARGET_DISPLAY_M2M2, TIVX_TARGET_DISPLAY_M2M3), but don't know how to use them.
Are there any example code that I can refer to?
  • You can create separate display node, add target as TIVX_TARGET_DISPLAY1 and TIVX_TARGET_DISPLA2 and start using it. You can refer to below FAQ, which uses similar approach.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1107628/faq-processor-sdk-j721e-how-to-enable-multiple-displays-by-sending-bigger-size-frames-from-dss
    Brijesh
    Thanks for providing this example.
    How do you verify graph here?
    I tried to use 2 displayObj for TIVX_TARGET_DISPLAY1, but stuck at vxVerifyGraph.
  • No, you should use difference target for each display node and also different display pipeid.. using same pipeld or target id is incorrect for the display node.
    Brijesh
    Does this mean I can only display two images?
    I want to display total 5 images here.
    What do you mean displaying 5 images? I didn't get it, can you please elaborate?
    Brijesh
  • For each iteration in vxProcessGraph, I want to show a total of 5 images in the display at the same time, like this image:
  • In this case, you can use mosaic node to create this layout from 5 images. This is possible using mosaic node, there is no need to use multiple display nodes in this case.
    Brijesh
    For the rightmost image, is it able to set it in mosaic node too? Is there example code for mosaic node usage
  • Yes, if you set the position and size correctly, it can generate this output image from the input object array.
    Brijesh
  • Ok, got it. By the way, do you have some straightforward example for mosaicnode usage
    Like which you provided for displaynode last time.
    * Copyright (c) 2017 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdio.h>
    #include <VX/vx.h>
    #include <TI/tivx.h>
    #include <vx_internal.h>
    #include <TI/video_io_kernels.h>
    #include <TI/video_io_display.h>
    #include <utils/app_init/include/app_init.h>
    static vx_status readYUVInput(char* file_name, vx_image in_img)
        vx_status status;
        FILE * fp = fopen(file_name,"rb");
        vx_int32 j;
        if(fp == NULL)
            printf("Unable to open file %s \n", file_name);
            return (VX_FAILURE);
        vx_rectangle_t rect;
        vx_imagepatch_addressing_t image_addr;
        vx_map_id map_id;
        void * data_ptr;
        vx_uint32  img_width;
        vx_uint32  img_height;
        vx_uint32  num_bytes = 0;
        vxQueryImage(in_img, VX_IMAGE_WIDTH, &img_width, sizeof(vx_uint32));
        vxQueryImage(in_img, VX_IMAGE_HEIGHT, &img_height, sizeof(vx_uint32));
        printf("%d x %d \n", img_width, img_height);
        rect.start_x = 0;
        rect.start_y = 0;
        rect.end_x = img_width;
        rect.end_y = img_height;
        status = vxMapImagePatch(in_img,
                                &rect,
                                0,
                                &map_id,
                                &image_addr,
                                &data_ptr,
                                VX_WRITE_ONLY,
                                VX_MEMORY_TYPE_HOST,
                                VX_NOGAP_X);
        /* Copy Luma */
        for (j = 0; j < img_height; j++)
            num_bytes += fread(data_ptr, 1, img_width, fp);
            data_ptr += image_addr.stride_y;
        printf("data_ptr = 0x%p\n", data_ptr);
        if(num_bytes != (img_width*img_height))
            printf("Luma bytes read = %d, expected = %d\n", num_bytes, img_width*img_height);
        else
            printf("Luma bytes success read = %d, expected = %d\n", num_bytes, img_width*img_height);
        vxUnmapImagePatch(in_img, map_id);
        rect.start_x = 0;
        rect.start_y = 0;
        rect.end_y = img_height / 2;
                                &rect,
                                1,
                                &map_id,
                                &image_addr,
                                &data_ptr,
                                VX_WRITE_ONLY,
                                VX_NOGAP_X);
        /* Copy CbCr */
        num_bytes = 0;
        for (j = 0; j < img_height/2; j++)
        printf("U data_ptr = 0x%p\n", data_ptr);
        if(num_bytes != (img_width*img_height/2))
            printf("CbCr bytes read = %d, expected = %d\n", num_bytes, img_width*img_height/2);
        else
            printf("CbCr bytes success read = %d, expected = %d\n", num_bytes, img_width*img_height/2);
        fclose(fp);
        return(status);
    static vx_status writeYUVInput(char* file_name, vx_image out_img)
        vx_status status;
        FILE * fp = fopen(file_name,"wb");
        vx_int32 j;
        if(fp == NULL)
        vx_map_id map_id;
        void * data_ptr;
        vxQueryImage(out_img, VX_IMAGE_WIDTH, &img_width, sizeof(vx_uint32));
        vxQueryImage(out_img, VX_IMAGE_HEIGHT, &img_height, sizeof(vx_uint32));
        rect.start_x = 0;
        rect.start_y = 0;
        status = vxMapImagePatch(out_img,
                                &rect,
                                0,
                                &map_id,
                                &image_addr,
                                &data_ptr,
                                VX_READ_ONLY,
                                VX_NOGAP_X);
        /* Copy Luma */
            num_bytes += fwrite(data_ptr, 1, img_width, fp);
        printf("O data_ptr = 0x%p\n", data_ptr);
            printf("Luma bytes written = %d, expected = %d\n", num_bytes, img_width*img_height);
        vxUnmapImagePatch(out_img, map_id);
        rect.start_x = 0;
        rect.start_y = 0;
                                &rect,
                                1,
                                &map_id,
                                &image_addr,
                                &data_ptr,
                                VX_READ_ONLY,
                                VX_NOGAP_X);
        /* Copy CbCr */
        num_bytes = 0;
        printf("OU data_ptr = 0x%p\n", data_ptr);
            printf("CbCr bytes written = %d, expected = %d\n", num_bytes, img_width*img_height/2);
        fclose(fp);
        return(status);
     * \brief Tutorial Entry Point
    int main()
        int status = 0;
        tivx_display_params_t display_params;
        vx_user_data_object display_param_obj;
        vx_node displayNode;
        vx_image display_image;
        int i = 0;
        vx_imagepatch_addressing_t  input_image_addr, display_image_addr;
        tivx_obj_desc_image_t *input_obj_desc = NULL;
        tivx_obj_desc_image_t *output_obj_desc = NULL;
        status = appInit();
        if(status == VX_SUCCESS)
            vx_context context = vxCreateContext();
            tivxVideoIOLoadKernels(context);
            vx_graph graph = vxCreateGraph(context);
            memset(&display_params, 0, sizeof(tivx_display_params_t));
            display_params.opMode = TIVX_KERNEL_DISPLAY_ZERO_BUFFER_COPY_MODE;
            display_params.pipeId = 2;
            display_params.outHeight = OUTPUT_TEX_HEIGHT;
            display_params.outWidth = OUTPUT_TEX_WIDTH;
            display_params.posX = 0;
            display_params.posY = 0;
            display_image = vxCreateImage(context, OUTPUT_TEX_WIDTH, OUTPUT_TEX_HEIGHT, VX_DF_IMAGE_NV12);
            // Display Initialization
            display_param_obj = vxCreateUserDataObject(context, "tivx_display_params_t", sizeof(tivx_display_params_t), &display_params);
            displayNode = tivxDisplayNode(graph, display_param_obj, display_image);
                status = vxSetNodeTarget(displayNode, VX_TARGET_STRING, TIVX_TARGET_DISPLAY1);
                printf("Display Set Target done\n");
                status = vxVerifyGraph(graph);
                printf("Verify Graph\n");
            status = readYUVInput(IN_FILE_NAME, display_image);
            printf("Input file filled\n");
                status = writeYUVInput(OUT_FILE_NAME, display_image);
                printf("Output file to test if the image read correctly before sending to display\n");
                    for(i = 0; i < LOOPCOUNT; i++)
                        status = vxProcessGraph(graph);
                status = vxReleaseUserDataObject(&display_param_obj);
                status |= vxReleaseImage(&display_image);
                status |= vxReleaseNode(&displayNode);
                status |= vxReleaseGraph(&graph);
                tivxVideoIOUnLoadKernels(context);
                status |= vxReleaseContext(&context);
                printf("Release Graph and context\n");
        else
            printf("app init fail \n");
        return 0;
    I think you can refer to multiple camera example. It uses mosaic node to create 2x2 or 3x3 mosaic output. You can update it based on your requirement.
    Brijesh
