TDA4VM: dfu rootfs
Part Number: TDA4VM
Hi expert,
My software version is:
  PDK-RTOS :processor-sdk-rtos-j721e-evm-08_06_00_12
  PDK-LINUX:processor-sdk-linux-08_06_00
I am upgrading EMMC on EVM board via DFU.
We have upgraded tiboot3.bin->tispl.bin->u-boot.img->sysfw.itb->tinyrootfs.img We executed exactly all the commands mentioned in the flashing guide, as shown in my logs:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 11:41:04
Press CTRL-A Z for help on special keys
U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 23:01:15 +0000)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev A
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
Trying to boot from DFU
####################################################DOWNLOAD ... OK
Ctrl+C to exit ...
init_env from device 18 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.4
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
Detected: J7X-BASE-CPB rev A
Detected: J7X-VSC8514-ETH rev E2
cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret -61)
cdns-usb3-peripheral usb@6000000: Unable to get USB3 phy (ret -22)
cdns-usb3-peripheral usb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200)
cdns-usb3-peripheral usb@6000000: Initialized  ep0 support:
cdns-usb3-peripheral usb@6000000: Initialized  ep1out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep2out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep3out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep4out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep5out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep6out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep7out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep8out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep9out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep10out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep11out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep12out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep13out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep14out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep15out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep1in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep2in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep3in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep4in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep5in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep6in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep7in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep8in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep9in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep10in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep11in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep12in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep13in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep14in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized  ep15in support: BULK, INT ISO
Ctrl+C to exit ...
U-Boot 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
SoC:   J721E SR1.1 GP
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... MMC: no card present
mmc_init: -123, time 2002
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq0
cdns,sierra serdes@5000000: sierra probed
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
SD/MMC found on device 1
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Bad Linux ARM64 Image magic!
=> env default -f -a
## Resetting to default environment
=> setenv mmcdev 0
=> setenv bootpart 0
=> saveenv
Saving Environment to FAT... MMC: no card present
Failed (1)
=> setenv dfu_alt_info ${dfu_alt_info_emmc}
=> gpt write mmc 0 ${partitions}
Writing GPT: success!
=> dfu 0 mmc 0
cdns,sierra serdes@5030000: sierra probed
###DOWNLOAD ... OK
Ctrl+C to exit ...
Ctrl+C to exit ...
Ctrl+C to exit ...
Ctrl+C to exit ...
Ctrl+C to exit ...
###DOWNLOAD ... OK
Ctrl+C to exit ...
##########################################################################################################################K
Ctrl+C to exit ...
=> mmc partconf 0 1 1 1
=> mmc bootbus 0 2 0 0
=> boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
** Unrecognized filesystem type **
19079680 bytes read in 111 ms (163.9 MiB/s)
111990 bytes read in 11 ms (9.7 MiB/s)
   Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-p3
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512t
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3271300K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008428] Console: colour dummy device 80x25
[    0.012989] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023659] pid_max: default: 32768 minimum: 301
[    0.028417] LSM: Security Framework initializing
[    0.033171] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040748] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049569] rcu: Hierarchical SRCU implementation.
[    0.054634] Platform MSI: msi-controller@1820000 domain created
[    0.060880] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070186] EFI services will not be available.
[    0.074908] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.088139] Detected PIPT I-cache on CPU1
[    0.088163] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088174] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
[    0.088208] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088256] smp: Brought up 1 node, 2 CPUs
[    0.117602] SMP: Total of 2 processors activated.
[    0.122407] CPU features: detected: 32-bit EL0 Support
[    0.127663] CPU features: detected: CRC32 instructions
[    0.141617] CPU: All CPU(s) started at EL2
[    0.145812] alternatives: patching kernel code
[    0.150819] devtmpfs: initialized
[    0.159741] KASLR disabled due to lack of seed
[    0.164388] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.174351] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.188524] pinctrl core: initialized pinctrl subsystem
[    0.194174] DMI not present or invalid.
[    0.198425] NET: Registered protocol family 16
[    0.203624] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.210927] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.218976] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.227276] thermal_sys: Registered thermal governor 'step_wise'
[    0.227278] thermal_sys: Registered thermal governor 'power_allocator'
[    0.233850] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.247484] ASID allocator initialised with 65536 entries
[    0.273495] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.280351] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.287201] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.294048] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.301496] cryptd: max_cpu_qlen set to 1000
[    0.307564] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.316389] vsys_3v3: supplied by evm_12v0
[    0.320747] vsys_5v0: supplied by evm_12v0
[    0.325501] iommu: Default domain type: Translated
[    0.330668] SCSI subsystem initialized
[    0.334834] mc: Linux media interface: v0.10
[    0.339212] videodev: Linux video capture interface: v2.00
[    0.344846] pps_core: LinuxPPS API ver. 1 registered
[    0.349917] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.359254] PTP clock support registered
[    0.363276] EDAC MC: Ver: 3.0.0
[    0.367076] FPGA manager framework
[    0.370582] Advanced Linux Sound Architecture Driver Initialized.
[    0.377169] clocksource: Switched to clocksource arch_sys_counter
[    0.383492] VFS: Disk quotas dquot_6.6.0
[    0.387524] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.397097] NET: Registered protocol family 2
[    0.401834] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.410406] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.419164] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.427364] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.435158] TCP: Hash tables configured (established 32768 bind 32768)
[    0.441961] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.448853] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.456252] NET: Registered protocol family 1
[    0.460960] RPC: Registered named UNIX socket transport module.
[    0.467023] RPC: Registered udp transport module.
[    0.471827] RPC: Registered tcp transport module.
[    0.476631] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.483212] NET: Registered protocol family 44
[    0.487758] PCI: CLS 0 bytes, default 64
[    0.492128] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.502513] Initialise system trusted keyrings
[    0.507135] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.515251] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.521497] NFS: Registering the id_resolver key type
[    0.526684] Key type id_resolver registered
[    0.530955] Key type id_legacy registered
[    0.535075] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.541923] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.549558] 9p: Installing v9fs 9p2000 file system support
[    0.574720] Key type asymmetric registered
[    0.578906] Asymmetric key parser 'x509' registered
[    0.583905] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.591465] io scheduler mq-deadline registered
[    0.596091] io scheduler kyber registered
[    0.601846] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.608036] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.617095] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.623535] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[    0.631515] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.637937] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[    0.645877] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.652294] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[    0.660219] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.666544] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[    0.674493] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.680820] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[    0.690539] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.698827] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.707041] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.714078] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.722555] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.735762] brd: module loaded
[    0.742205] loop: module loaded
[    0.745934] megasas: 07.714.04.00-rc1
[    0.751729] tun: Universal TUN/TAP device driver, 1.6
[    0.757206] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.763610] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.769681] sky2: driver version 1.30
[    0.774041] VFIO - User Level meta-driver version: 0.3
[    0.779824] i2c /dev entries driver
[    0.784341] sdhci: Secure Digital Host Controller Interface driver
[    0.790677] sdhci: Copyright(c) Pierre Ossman
[    0.795348] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.801783] ledtrig-cpu: registered to indicate activity on CPUs
[    0.808136] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.815531] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.820093] optee: revision 3.20 (8e74d476)
[    0.836492] optee: dynamic shared memory is enabled
[    0.845951] optee: initialized driver
[    0.851183] NET: Registered protocol family 17
[    0.855805] 9pnet: Installing 9P2000 support
[    0.860202] Key type dns_resolver registered
[    0.864653] Loading compiled-in X.509 certificates
[    0.878470] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[    0.942868] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.950671] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.956752] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.963192] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.969699] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.976518] pca953x 3-0020: using no AI
[    1.002061] pca953x 3-0022: supply vcc not found, using dummy regulator
[    1.008863] pca953x 3-0022: using AI
[    1.013136] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[    1.019113] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[    1.025358] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[    1.031850] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    1.038317] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    1.048513] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[    1.054831] pca953x 6-0020: supply vcc not found, using dummy regulator
[    1.061658] pca953x 6-0020: using no AI
[    1.089873] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    1.095948] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.101904] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.108164] pca953x 9-0020: supply vcc not found, using dummy regulator
[    1.114982] pca953x 9-0020: using no AI
[    1.141495] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    1.147970] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.157954] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.166758] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.176624] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.198453] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.206130] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.214407] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.222685] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.242004] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[    2.248419] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.254025] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    2.263715] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    2.270769] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    2.276908] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.286857] pci 0000:00:00.0: supports D1
[    2.290951] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.296838] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    2.303865] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    2.316042] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.326181] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.332954] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[    2.340427] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.345731] pcieport 0000:00:00.0: PME: Signaling with IRQ 68
[    2.352135] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.359820] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.368099] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.376380] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.384922] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[    3.391337] pci_bus 0001:00: root bus resource [bus 00-ff]
[    3.396944] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    3.406812] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[    3.413856] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[    3.419994] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.429921] pci 0001:00:00.0: supports D1
[    3.434015] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    3.442027] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.452266] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    3.459034] pci 0001:00:00.0: PCI bridge to [bus 01]
[    3.464318] pcieport 0001:00:00.0: PME: Signaling with IRQ 71
[    3.470686] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.478363] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.486640] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.494918] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.506272] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[    4.512700] pci_bus 0002:00: root bus resource [bus 00-ff]
[    4.518306] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    4.527553] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    4.538329] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[    4.544468] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    4.554396] pci 0002:00:00.0: supports D1
[    4.558489] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[    4.566482] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.576518] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[    4.583286] pci 0002:00:00.0: PCI bridge to [bus 01]
[    4.588562] pcieport 0002:00:00.0: PME: Signaling with IRQ 74
[    4.595390] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    4.605273] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    4.612032] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.621008] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    4.631164] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    4.637927] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.645897] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    4.655301] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    4.664047] printk: console [ttyS2] enabled
[    4.672484] printk: bootconsole [ns16550a0] disabled
[    4.682936] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    4.691873] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    4.702622] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.713135] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    4.723293] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    4.733532] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    4.744669] scsi host0: ufshcd
[    4.753784] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    4.766620] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAU0
[    4.797172] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    4.805649] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    4.813954] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 P0
[    4.826878] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    4.834089] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE]2
[    4.845719] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    4.845722] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLev0
[    4.862767] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.863149] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    4.880523] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.889205] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    4.897415] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    4.999071] mmc0: CQHCI version 5.10
[    4.999116] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    5.014778] vdd_mmc1: supplied by vsys_3v3
[    5.019696] pca953x 4-0020: supply vcc not found, using dummy regulator
[    5.026363] pca953x 4-0020: using no AI
[    5.041173] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    5.054200] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    5.061153] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    5.068091] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    5.075019] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    5.081878] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    5.092540] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    5.103165] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    5.117850] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
[    5.123089] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.129688] Creating 8 MTD partitions on "47040000.spi.0":
[    5.135166] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.141127] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.146814] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.152594] 0x000000680000-0x0000006c0000 : "ospi.env"
[    5.158110] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.163790] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    5.169899] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    5.175675] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    5.184644] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
[    5.190949] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    5.201182] mmc0: Command Queue Engine enabled
[    5.205619] mmc0: new HS200 MMC card at address 0001
[    5.210854] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    5.215490] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    5.221500] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    5.227507] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[    5.237186] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    5.244858]  mmcblk0: p1
[    5.245728] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    5.255708] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 P0
[    5.268596] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    5.275805] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    5.282112] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    5.292419] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    5.300628] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    5.315114] mmc1: CQHCI version 5.10
[    5.317814] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    5.326001] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    5.334369] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    5.341696] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    5.349046] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    5.356355] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    5.364712] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.385901] ALSA device list:
[    5.388861]   No soundcards found.
[    6.829639] sdhci-am654 4fb0000.mmc: Power on failed
[    6.865219] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    6.879253] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    6.887388] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    6.893636] devtmpfs: mounted
[    6.897425] Freeing unused kernel memory: 1856K
[    6.909236] Run /sbin/init as init process
INIT: version 2.96 booting
[    7.007230] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Mar  3 23:10:28 UTC 2023
chmod: /var/log/wtmp: No such file or directory
Failed to set mode -0664- for -/var/log/wtmp-.
[    7.167901] random: dd: uninitialized urandom read (512 bytes read)
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/ipk-postinsts/000-sysvinit-inittab...
INIT: Entering runlevel: 5un-postinsts exists during rc.d purge
Configuring network interfaces... [    7.254820] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI )
[    7.264296] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
udhcpc: started, v1.31.1
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting syslogd/klogd: done
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project j7-evm /dev/ttyS2
Arago 2021.09 j7-evm /dev/ttyS2
j7-evm login: root
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# ls
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# cd ../..
root@j7-evm:/#
root@j7-evm:/# ls -al
total 64
drwxr-xr-x   17 root     root          4096 Mar  3 23:10 .
drwxr-xr-x   17 root     root          4096 Mar  3 23:10 ..
drwxr-xr-x    2 root     root          4096 Mar  3 23:10 bin
drwxr-xr-x    2 root     root          4096 Apr 16  2024 boot
drwxr-xr-x    9 root     root          4440 Mar  3 23:10 dev
drwxr-xr-x   21 root     root          4096 Mar  3 23:10 etc
drwxr-xr-x    3 root     root          4096 Mar  3 22:59 home
drwxr-xr-x    6 root     root          4096 Mar  3 23:10 lib
lrwxrwxrwx    1 root     root            19 Mar  3 23:10 linuxrc -> /bin/busybox.nosuid
drwx------    2 root     root         16384 Apr 16  2024 lost+found
drwxr-xr-x    2 root     root          4096 Mar  3 22:59 media
drwxr-xr-x    2 root     root          4096 Mar  3 22:59 mnt
dr-xr-xr-x  157 root     root             0 Jan  1  1970 proc
drwxr-xr-x    4 root     root           260 Mar  3 23:10 run
drwxr-xr-x    2 root     root          4096 Mar  3 23:10 sbin
dr-xr-xr-x   12 root     root             0 Jan  1  1970 sys
lrwxrwxrwx    1 root     root             8 Mar  3 23:10 tmp -> /var/tmp
drwxr-xr-x    9 root     root          4096 Mar  3 23:10 usr
drwxr-xr-x    8 root     root          4096 Mar  3 23:10 var
root@j7-evm:/#
root@j7-evm:/# ls
bin         dev         home        linuxrc     media       proc        sbin        tmp         var
boot        etc         lib         lost+found  mnt         run         sys         usr
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
Can you tell me the reason why this Failed message appears?
How can we solve this problem?
Looking forward to the help of experts, thanks
Barry
  • HI Barry
    The problem that is coming is while loading the uEnv.txt
    if you see the loadbootenv command you can see that you are trying to read the uEnv.txt from the boot 0 partition which is having a RAW format.
    If you want to avoid this error you can keep both the boot images as well as rootfs in the UDA partition of the emmc.
    Diwakar
  • Hi Diwakar
    Thanks Reply
    1.What does this boot.scr represent? Why does it fail when loading this?
    2.Is this problem due to any steps or modifications we are missing?
    3.In order to solve this problem, can you give us specific steps to solve it?
    Looking forward for your reply, thanks
    Barry
  • Hi Barry
    Those above are just warning no need to worry about this.
    You can go through the document to get more detail on the boot.scr.
    Diwakar
  • Hi Diwakar
    Thanks Reply
    We don't have an SD card in the EVM board now, just upgrade the eMMC and boot.
    In order to solve this problem, can you send us the verified patch?
    Looking forward to detailed solution steps.
  • Hi Barry
    Allow us some time to check on this will respond you within 2 days.
    Diwakar
  • Hi Diwakar
    Can you update it for us now?
    Barry
  • Hi Barry
    Please do the below steps to flash the emmc.
    • Apply the patch to enable the saveenv functionality to the emmc fat partition.
      diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig
      index e71a862a6f..08d3eea845 100644
      --- a/configs/j721e_evm_a72_defconfig
      +++ b/configs/j721e_evm_a72_defconfig
      @@ -79,10 +79,10 @@ CONFIG_OF_LIST="k3-j721e-common-proc-board k3-j721e-tps65917-proc-board k3-j721e
       CONFIG_SPL_MULTI_DTB_FIT=y
       CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
       CONFIG_ENV_OVERWRITE=y
      -CONFIG_ENV_IS_IN_FAT=y
      -CONFIG_ENV_FAT_DEVICE_AND_PART="1:1"
      +CONFIG_ENV_IS_IN_MMC=y
      +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
       CONFIG_SYS_RELOC_GD_ENV_ADDR=y
      -CONFIG_SPL_ENV_IS_NOWHERE=y
      +CONFIG_SYS_MMC_ENV_PART=1
       CONFIG_NET_RANDOM_ETHADDR=y
       CONFIG_DM=y
       CONFIG_SPL_DM=y
    • Build UBOOT.
      • make u-boot
    • on device side
      • Boot unto uboot using any boot media like DFU/sd.
      • env default -f -a
      • mmc partconf 0 1 1 1
      • mmc bootbus 0 2 0 0
      • gpt write mmc 0 ${partitions}
      • setenv mmcdev 0
      • setenv bootpart 0
      • setenv dfu_alt_info ${dfu_alt_info_emmc}
      • setenv args_mmc "run finduuid;setenv bootargs console=ttyS2,115200n8  root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait"
      • saveenv
      • saveenv  // To store the same in redundant area
      • dfu 0 mmc 0
    • On HOST side:
      • sudo dfu-util -l
      • sudo dfu-util -a tiboot3.bin.raw -D <PATH_TO_BIN>/tiboot3.bin
      • sudo dfu-util -a tispl.bin.raw -D <PATH_TO_BIN>/tispl.bin
      • sudo dfu-util -a u-boot.img.raw -D <PATH_TO_BIN>/u-boot.img
      • sudo dfu-util -a rootfs -D rootfs.img
    • Change the boot mode to emmc boot mode and power on.
    Diwakar
  • Hi Diwakar
    Thanks Reply.
    Comparing the contents of the BOOT partition in the SD card, we only flashed tiboot3.bin/tispl.bin/u-boot.img/sysfw.itb.
    For eMMC, which files in the BOOT partition must we need to upgrade? How to flash?
    The rootfs partition can be upgraded through rootfs.ext4.
    We have removed the SD card and are replacing it completely with eMMC,For mass production, can you give us an accurate answer?
    SD card BOOT partition and rootfs partition:
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$ ls
    BOOT  rootfs
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$ ls  ./BOOT/
    sysfw.itb    tispl.bin  u-boot.img                  uEnv_am62a_vision_apps.txt  uEnv_j721e_edgeai_apps.txt  uEnv_j721s2_edgeai_apps.txt  uEnv_j784s4_edgeai_apps.txt  uEnv.txt       version
    tiboot3.bin  uboot.env  uEnv_am62a_edgeai_apps.txt  uEnv_edgeai-apps.txt        uEnv_j721e_vision_apps.txt  uEnv_j721s2_vision_apps.txt  uEnv_j784s4_vision_apps.txt  uEnv.txt.base
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$ ls ./rootfs/
    bin  boot  dev  etc  home  include  init  lib  linuxrc  lost+found  media  mnt  opt  proc  run  sbin  sys  tmp  usr  var
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$ ls ./rootfs/boot/
    fitImage                        k3-j721e-common-proc-board-infotainment.dtbo  k3-j721e-fpdlink-imx390-cm-0-1.dtbo  k3-j721e-fpdlink-imx390-cm-1-2.dtbo   k3-j721e-fpdlink-imx390-rcm-0-3.dtbo  k3-j721e-fpdlink-sk-fusion.dtbo   k3-j721e-sk-rpi-hdr-ehrpwm.dtbo
    fitImage-5.10.162-g76b3e88d56   k3-j721e-cpb-csi2-ov5640.dtbo                 k3-j721e-fpdlink-imx390-cm-0-2.dtbo  k3-j721e-fpdlink-imx390-cm-1-3.dtbo   k3-j721e-fpdlink-imx390-rcm-1-0.dtbo  k3-j721e-proc-board-tps65917.dtb  k3-j721e-vision-apps.dtbo
    Image                           k3-j721e-edgeai-apps.dtbo                     k3-j721e-fpdlink-imx390-cm-0-3.dtbo  k3-j721e-fpdlink-imx390-rcm-0-0.dtbo  k3-j721e-fpdlink-imx390-rcm-1-1.dtbo  k3-j721e-sk-csi2-ov5640.dtbo
    Image-5.10.162-g76b3e88d56      k3-j721e-fpdlink-cpb-fusion.dtbo              k3-j721e-fpdlink-imx390-cm-1-0.dtbo  k3-j721e-fpdlink-imx390-rcm-0-1.dtbo  k3-j721e-fpdlink-imx390-rcm-1-2.dtbo  k3-j721e-sk.dtb
    k3-j721e-common-proc-board.dtb  k3-j721e-fpdlink-imx390-cm-0-0.dtbo           k3-j721e-fpdlink-imx390-cm-1-1.dtbo  k3-j721e-fpdlink-imx390-rcm-0-2.dtbo  k3-j721e-fpdlink-imx390-rcm-1-3.dtbo  k3-j721e-sk-rpi-cam-imx219.dtbo
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$
    @sz-dl-260:/media/$
    Looking forward to the expert's reply.
    Barry
  • HI Barry
    I am not sure what exactly you are looking for, we already shared the steps on how to flash the images to the emmc using dfu boot mode.
    e2e.ti.com/.../5169319
    Have you tried these steps, what is the issue you are facing now ?
    The above mentioned steps are enough to flash to the emmc and boot no need of having SD card.
    We are already supporting the query over here let not respond the same query on the other thread :https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1346579/tda4vm-dfu-util
    To avoid the duplicacy of the responses.
    Diwakar
  • Hi Diwakar
    After changing according to the diff :
    Question 1:
    make u-boot:
    Question 2:
    Writing GPT: mmc write failed
    ** Can't write to device 0 **
    error!
    error!
    => setenv mmcdev 0
    => setenv args_mmc "run finduuid;setenv bootargs console=ttyS2,115200n8 root=/dev/mmcblk0p1 rw rootfstype="
    => saveenv
    Failed (1)
    => saveenv
    Failed (1)
    => dfu 0 mmc 0
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Po0
    Aborting!
    error!
    error!
    => setenv mmcdev 0
    => saveenv
    Failed (1)
    => saveenv
    Failed (1)
    => dfu 0 mmc 0
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    => boot
    19079680 bytes read in 110 ms (165.4 MiB/s)
    111990 bytes read in 9 ms (11.9 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolch3
    Looking forward to expert reply
    Barry
  • Hi Diwakar
    Regarding question 2, I adjusted the command order and it seems to be working.
    But it didn't solve the problem
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Aborting!
    => setenv mmcdev 0
    => setenv dfu_alt_info ${dfu_alt_info_emmc}<INTERRUPT>
    => saveenv
    Failed (1)
    => saveenv
    Failed (1)
    => dfu 0 mmc 0
    U-Boot SPL 2021.01-dirty (May 07 2024 - 15:49:49 +0800)
    Ctrl+C to exit ...
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-4
    U-Boot SPL 2021.01-dirty (May 07 2024 - 15:49:43 +0800)
    Ctrl+C to exit ...
    U-Boot 2021.01-dirty (May 07 2024 - 15:49:43 +0800)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Aborting!
    => setenv mmcdev 0
    => saveenv
    Saving Environment to MMC... Writing to redundant MMC(0)... OK
    => saveenv
    Saving Environment to MMC... Writing to MMC(0)... OK
    => dfu 0 mmc 0
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    => boot
    Starting kernel ...
    Barry
  • Hi Barry
    Now you are able to save the environment variable into the emmc fat partition
    After modifying the environment variable you need to save them also
    In the above logs you are modifying the environment variable but not saving those using "saveenv" command
    If you are not saving the updated environment variable then in the next boot you will loose the configuration.So you need to save the configuration before running  boot command .
    Diwakar
  • Hi Diwakar
    Thanks Reply He can work after we adjusted the dialing code.
    Can you finally help us with two questions?
    1.
    Environment offset (ENV_OFFSET)
    Redundant environment offset (ENV_OFFSET_REDUND) [] (NEW)
    We set the value to 0x680000. Is there any problem?
    2.
    • env default -f -a
    • setenv mmcdev 0
    • setenv bootpart 0
    • saveenv
    • dfu 0 mmc 0
    Can you explain that after setting according to the above command,
    What are the contents of the currently set environment variables? How are environment variables obtained?
    Looking forward to the expert's reply, thanks
    Barry
  • HI Barry
    You can keep the offset at 0x680000
    CONFIG_ENV_OFFSET_REDUND=0x7C0000
    CONFIG_ENV_OFFSET=0x680000
    saveenv command is storing the env in the first partiton of the emmc which is boot partition.
    During run time it will take the env from that only.
    Diwakar
  • Hi Diwakar
    thank you for your reply But after booting, we found that the startup was stuck at:
    remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 302028
    U-Boot SPL 2021.01 (Apr 30 2024 - 15:49:58 +0800)
    Ctrl+C to exit ...
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.24
    U-Boot SPL 2021.01 (Apr 30 2024 - 15:50:58 +0800)
    Ctrl+C to exit ...
    U-Boot 2021.01 (Apr 30 2024 - 15:50:58 +0800)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 P0
    Aborting!
    Unknown command 'env' - try 'help'
    Ctrl+C to exit ...
    I/TC:
    Ctrl+C to exit ...
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Aborting!
    => setenv mmcdev 0
    => saveenv
    Failed (1)
    => dfu 0 mmc 0
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    => boot
    19079680 bytes read in 118 ms (154.2 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolc3
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dml
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dl
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47t
    [    0.000000] Memory: 3271300K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K )
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_nss
    [    0.008394] Console: colour dummy device 80x25
    [    0.012956] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS )
    [    0.023626] pid_max: default: 32768 minimum: 301
    [    0.028380] LSM: Security Framework initializing
    [    0.033134] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040709] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049515] rcu: Hierarchical SRCU implementation.
    [    0.054575] Platform MSI: msi-controller@1820000 domain created
    [    0.060807] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070107] EFI services will not be available.
    [    0.074822] smp: Bringing up secondary CPUs ...
    [    0.088048] Detected PIPT I-cache on CPU1
    [    0.088073] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088084] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.088120] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088168] smp: Brought up 1 node, 2 CPUs
    [    0.117514] SMP: Total of 2 processors activated.
    [    0.122319] CPU features: detected: 32-bit EL0 Support
    [    0.127574] CPU features: detected: CRC32 instructions
    [    0.141536] CPU: All CPU(s) started at EL2
    [    0.145730] alternatives: patching kernel code
    [    0.150743] devtmpfs: initialized
    [    0.159629] KASLR disabled due to lack of seed
    [    0.164276] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 764504178510000s
    [    0.174240] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.187026] pinctrl core: initialized pinctrl subsystem
    [    0.192676] DMI not present or invalid.
    [    0.196920] NET: Registered protocol family 16
    [    0.202111] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209411] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217459] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.225762] thermal_sys: Registered thermal governor 'step_wise'
    [    0.225765] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.232339] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.245974] ASID allocator initialised with 65536 entries
    [    0.271224] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.278080] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.284926] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.291772] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.299225] cryptd: max_cpu_qlen set to 1000
    [    0.305323] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.314149] vsys_3v3: supplied by evm_12v0
    [    0.318507] vsys_5v0: supplied by evm_12v0
    [    0.323257] iommu: Default domain type: Translated
    [    0.328426] SCSI subsystem initialized
    [    0.332589] mc: Linux media interface: v0.10
    [    0.336967] videodev: Linux video capture interface: v2.00
    [    0.342601] pps_core: LinuxPPS API ver. 1 registered
    [    0.347673] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.357009] PTP clock support registered
    [    0.361030] EDAC MC: Ver: 3.0.0
    [    0.364834] FPGA manager framework
    [    0.368341] Advanced Linux Sound Architecture Driver Initialized.
    [    0.374932] clocksource: Switched to clocksource arch_sys_counter
    [    0.381256] VFS: Disk quotas dquot_6.6.0
    [    0.385286] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.394865] NET: Registered protocol family 2
    [    0.399595] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.408172] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.416932] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.425131] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.432917] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.439716] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.446609] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454006] NET: Registered protocol family 1
    [    0.458716] RPC: Registered named UNIX socket transport module.
    [    0.464779] RPC: Registered udp transport module.
    [    0.469583] RPC: Registered tcp transport module.
    [    0.474386] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.480968] NET: Registered protocol family 44
    [    0.485513] PCI: CLS 0 bytes, default 64
    [    0.489880] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.500276] Initialise system trusted keyrings
    [    0.504926] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.513036] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.519283] NFS: Registering the id_resolver key type
    [    0.524461] Key type id_resolver registered
    [    0.528734] Key type id_legacy registered
    [    0.532856] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.539703] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.547339] 9p: Installing v9fs 9p2000 file system support
    [    0.572677] Key type asymmetric registered
    [    0.576864] Asymmetric key parser 'x509' registered
    [    0.581860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.589419] io scheduler mq-deadline registered
    [    0.594044] io scheduler kyber registered
    [    0.599796] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.605981] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.615072] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.621494] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.629471] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.635896] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.643836] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.650253] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.658180] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.664505] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.672454] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.678783] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.688517] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.696804] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.705020] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.712052] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.720452] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.733651] brd: module loaded
    [    0.740082] loop: module loaded
    [    0.743809] megasas: 07.714.04.00-rc1
    [    0.749618] tun: Universal TUN/TAP device driver, 1.6
    [    0.755100] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.761503] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.767574] sky2: driver version 1.30
    [    0.771936] VFIO - User Level meta-driver version: 0.3
    [    0.777720] i2c /dev entries driver
    [    0.782231] sdhci: Secure Digital Host Controller Interface driver
    [    0.788554] sdhci: Copyright(c) Pierre Ossman
    [    0.793224] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.799649] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.806005] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.813392] optee: probing for conduit method.
    [    0.817953] optee: revision 3.20 (8e74d476)
    [    0.834353] optee: dynamic shared memory is enabled
    [    0.843815] optee: initialized driver
    [    0.849003] NET: Registered protocol family 17
    [    0.853626] 9pnet: Installing 9P2000 support
    [    0.858020] Key type dns_resolver registered
    [    0.862470] Loading compiled-in X.509 certificates
    [    0.876184] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.940275] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.948066] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.954147] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.960578] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.967083] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.973898] pca953x 3-0020: using no AI
    [    0.999823] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.006624] pca953x 3-0022: using AI
    [    1.010896] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    1.016872] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    1.023117] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    1.029609] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.036080] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.046289] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.052618] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    1.059447] pca953x 6-0020: using no AI
    [    1.087630] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.093710] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.099675] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.105934] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.112751] pca953x 9-0020: using no AI
    [    1.139258] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.145721] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain cread
    [    1.155707] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.164513] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.174388] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.196122] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.203800] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.212077] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.220353] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.239726] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.246151] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.251758] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.261449] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.268502] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.274641] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    2.284590] pci 0000:00:00.0: supports D1
    [    2.288685] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.294570] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.301597] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 )
    [    2.313563] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.323546] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.330320] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    2.337794] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.343099] pcieport 0000:00:00.0: PME: Signaling with IRQ 68
    [    2.349458] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.357124] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.365403] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.373681] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.382313] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.388728] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.394333] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010ff)
    [    3.404203] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.411246] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.417385] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    3.427312] pci 0001:00:00.0: supports D1
    [    3.431406] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.439201] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.449172] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.455939] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.461212] pcieport 0001:00:00.0: PME: Signaling with IRQ 71
    [    3.467554] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.475225] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.483502] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.491779] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.503131] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.509560] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    4.515166] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.524413] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000)
    [    4.535188] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.541327] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    4.551255] pci 0002:00:00.0: supports D1
    [    4.555350] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.563156] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.573129] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.579896] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.585169] pcieport 0002:00:00.0: PME: Signaling with IRQ 74
    [    4.592002] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:5
    [    4.601883] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.608642] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.617603] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-1
    [    4.627758] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.634522] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.642488] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.651888] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.660630] printk: console [ttyS2] enabled
    [    4.669066] printk: bootconsole [ns16550a0] disabled
    [    4.679530] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.688471] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.699231] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assd
    [    4.709742] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assumind
    [    4.719901] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assumid
    [    4.730141] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assumd
    [    4.741269] scsi host0: ufshcd
    [    4.750335] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    4.763059] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWA0
    [    4.794936] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.803482] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.811733] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST 2
    [    4.823364] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not0
    [    4.834522] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw vers0
    [    4.847310] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.847398] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.862950] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.869216] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.869326] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.886925] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.894353] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    5.004135] mmc0: CQHCI version 5.10
    [    5.004192] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.019812] vdd_mmc1: supplied by vsys_3v3
    [    5.024752] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    5.031427] pca953x 4-0020: using no AI
    [    5.043487] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    5.059930] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    5.066769] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    5.073597] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    5.080414] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    5.087225] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    5.097863] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    5.108486] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    5.123262] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    5.128494] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    5.135101] Creating 8 MTD partitions on "47040000.spi.0":
    [    5.140583] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    5.146565] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    5.152264] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    5.158030] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    5.163573] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    5.169258] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    5.175374] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.181149] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    5.190109] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    5.196732] mmc0: Command Queue Engine enabled
    [    5.197072] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    5.201183] mmc0: new HS200 MMC card at address 0001
    [    5.213028] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.217663] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.223679] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.229672] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.239480]  mmcblk0: p1
    [    5.246950] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.255458] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.263762] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw vers0
    [    5.276615] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.283822] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.290077] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.300344] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.308692] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.314880] mmc1: CQHCI version 5.10
    [    5.324641] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    5.331958] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    5.340316] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    5.347635] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    5.354947] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    5.362250] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    5.370608] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.391905] ALSA device list:
    [    5.394867]   No soundcards found.
    [    6.833128] sdhci-am654 4fb0000.mmc: Power on failed
    [    6.868702] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.882904] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    6.891042] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    6.897397] devtmpfs: mounted
    [    6.901146] Freeing unused kernel memory: 1856K
    [    6.911002] Run /sbin/init as init process
    [    6.974959] systemd[1]: System time before build time, advancing clock.
    [    7.001920] NET: Registered protocol family 10
    [    7.006851] Segment Routing with IPv6
    [    7.023501] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SM)
    [    7.045249] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    7.079250] systemd[1]: Set hostname to <j7-evm>.
    [    7.085688] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.092323] systemd[1]: Initializing machine ID from random generator.
    [    7.220322] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in .
    [    7.241520] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below lega.
    [    7.298605] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.306838] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    7.327066] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.334443] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    7.355671] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.379133] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    7.403060] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    7.427047] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.442998] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.462988] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.479026] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.510020] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.531067] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.553229] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.575136] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.600631] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.608964] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.631248] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.651285] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.675207] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.695127] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.717109] systemd[1]: Mounting Huge Pages File System...
    [    7.741114] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.769141] systemd[1]: Mounting Kernel Debug File System...
    [    7.795239] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.821327] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    7.854639] systemd[1]: Starting Start psplash boot splash screen...
    [    7.881236] systemd[1]: Starting RPC Bind...
    [    7.899124] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.911165] systemd[1]: Starting Journal Service...
    [    7.935471] systemd[1]: Starting Load Kernel Modules...
    [    7.949253] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    7.970204] cryptodev: loading out-of-tree module taints kernel.
    [    7.973647] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    7.985483] systemd[1]: Starting udev Coldplug all Devices...
    [    7.988289] cryptodev: driver 1.10 loaded.
    [    8.014018] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    8.031386] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [    8.229655] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.235055] random: systemd-journal: uninitialized urandom read (16 bytes read)
             Mounting Kernel Configuration File System.[    8.244315] random: systemd-journal: uninitialized u)
             Starting Flush Journal to Persistent Storage...
    [    8.279931] systemd-journald[183]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Run pending postinsts...
             Starting Rebuild Journal Catalog...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    9.096938] random: crng init done
    [    9.100403] random: 75 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    9.227384] CAN device driver interface
    [    9.244943] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.319327] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.343831] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.368368] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.395852] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.427136] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.443099] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    9.463819] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.471783] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    9.487339] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    9.499363] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.515765] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.561377] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [  OK  ] Started Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [    9.598775] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [  OK  ] Started Update is Completed.
    [    9.635891] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.651868] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    9.663036] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    9.675074] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.683092] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.694849] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    9.709219] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.711102] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.715623] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1334036
    [    9.736600] remoteproc remoteproc0: bad phdr da 0xa8100000 mem 0x8c
    [    9.745817] remoteproc remoteproc0: Failed to load program segments: -22
    [    9.760229] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.771436] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.779276] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.787429] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.801404] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.819127] remoteproc remoteproc1: 4d81800000.dsp is available
    [    9.848160] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.861925] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    9.867886] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1334036
    [    9.881695] remoteproc remoteproc1: bad phdr da 0xa9100000 mem 0x8c
    [    9.888004] remoteproc remoteproc1: Failed to load program segments: -22
    [    9.955215] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed st)
    [    9.984190] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [    9.993407] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [   10.012623] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [   10.020203] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power s
    [   10.042178] platform 41000000.r5f: configured R5F for IPC-only mode
    [   10.071308] remoteproc remoteproc2: 64800000.dsp is available
    [   10.083401] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.092326] PVR_K:  210: Read BVNC 22.104.208.318 from HW device registers
    [   10.160364] PVR_K:  210: RGX Device registered with BVNC 22.104.208.318
    [   10.172080] remoteproc remoteproc2: powering up 64800000.dsp
    [   10.177802] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 12849048
    [   10.188711] remoteproc remoteproc3: 41000000.r5f is available
    [   10.194579] remoteproc remoteproc2: unsupported resource 65538
    [   10.200474] remoteproc remoteproc2: bad phdr da 0xb2100000 mem 0x98
    [   10.206758] remoteproc remoteproc2: Failed to load program segments: -22
    [   10.253246] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 1
    [   10.290441] remoteproc remoteproc3: attaching to 41000000.r5f
    [   10.322272] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   10.367929]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.515439] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   10.523390] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.531041] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   10.608717]  remoteproc3#vdev0buffer: registered virtio0 (type 7)
    [   10.692288] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [   10.823277] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.911067] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.922591] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.930109] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.941094] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.949471] remoteproc remoteproc4: powering up 5c00000.r5f
    [   10.955250] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1424760
    [   10.966908] remoteproc remoteproc4: bad phdr da 0xa2104000 mem 0x1687b70
    [   10.974767] remoteproc remoteproc4: Failed to load program segments: -22
    [   10.986330] remoteproc remoteproc5: 5d00000.r5f is available
    [   11.011837] remoteproc remoteproc5: powering up 5d00000.r5f
    [   11.017932] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 302028
    What is the reason? How to fix it?
    Looking forward to your reply
    Barry
  • Hi Barry
    Does these firmware are present in the rootfs which you flashed on the board ?
    • j7-main-r5f0_0-fw
    • j7-main-r5f0_1-fw
    • j7-c71_0-fw,
    • j7-c66_1-fw
    • j7-c66_0-fw
    Diwakar
  • Hi Diwakar
    Thank you very much for your reply.
    The screenshot comes from the rootfs used in this rootfs.img, which comes from the TI source package.
    1.
    ti-processor-sdk-rtos-j721e-evm-08_06_00_12-prebuilt/rootfs_media/lib/firmware/
    2.
    ti-processor-sdk-rtos-j721e-evm-08_06_00_12-prebuilt/rootfs_media/lib/firmware/vision_apps_evm/
    The problem appears as shown in the log:
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 23:01:15 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev A
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    Trying to boot from DFU
    ####################################################DOWNLOAD ... OK
    Ctrl+C to exit ...
    init_env from device 18 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
    I/TC:
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret -61)
    cdns-usb3-peripheral usb@6000000: Unable to get USB3 phy (ret -22)
    cdns-usb3-peripheral usb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200)
    cdns-usb3-peripheral usb@6000000: Initialized  ep0 support:
    cdns-usb3-peripheral usb@6000000: Initialized  ep1out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep2out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep3out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep4out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep5out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep6out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep7out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep8out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep9out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep10out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep11out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep12out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep13out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep14out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep15out support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep1in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep2in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep3in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep4in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep5in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep6in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep7in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep8in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep9in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep10in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep11in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep12in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep13in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep14in support: BULK, INT ISO
    cdns-usb3-peripheral usb@6000000: Initialized  ep15in support: BULK, INT ISO
    Ctrl+C to exit ...
    U-Boot 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from FAT... MMC: no card present
    mmc_init: -123, time 2002
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    SD/MMC found on device 1
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    No FDT memory address configured. Please configure
    the FDT address via "fdt addr <address>" command.
    Aborting!
    Bad Linux ARM64 Image magic!
    => env default -f -a
    ## Resetting to default environment
    => setenv mmcdev 0
    => setenv bootpart 0
    => saveenv
    Saving Environment to FAT... MMC: no card present
    Failed (1)
    => gpt write mmc 0 ${partitions}
    Writing GPT: success!
    => dfu 0 mmc 0
    cdns,sierra serdes@5030000: sierra probed
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    Ctrl+C to exit ...
    ###DOWNLOAD ... OK
    Ctrl+C to exit ...
    ##########################################################################################################K
    Ctrl+C to exit ...
    => mmc partconf 0 1 1 1
    => mmc bootbus 0 2 0 0
    => boot
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    ** Unrecognized filesystem type **
    19079680 bytes read in 109 ms (166.9 MiB/s)
       Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008424] Console: colour dummy device 80x25
    [    0.012985] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS )
    [    0.023655] pid_max: default: 32768 minimum: 301
    [    0.028413] LSM: Security Framework initializing
    [    0.033167] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040742] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049551] rcu: Hierarchical SRCU implementation.
    [    0.054616] Platform MSI: msi-controller@1820000 domain created
    [    0.060858] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070164] EFI services will not be available.
    [    0.074884] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.088105] Detected PIPT I-cache on CPU1
    [    0.088128] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088139] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.088174] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088223] smp: Brought up 1 node, 2 CPUs
    [    0.117569] SMP: Total of 2 processors activated.
    [    0.122374] CPU features: detected: 32-bit EL0 Support
    [    0.127628] CPU features: detected: CRC32 instructions
    [    0.141588] CPU: All CPU(s) started at EL2
    [    0.145781] alternatives: patching kernel code
    [    0.150792] devtmpfs: initialized
    [    0.159666] KASLR disabled due to lack of seed
    [    0.164308] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 764504178510000s
    [    0.174271] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.187114] pinctrl core: initialized pinctrl subsystem
    [    0.192758] DMI not present or invalid.
    [    0.196996] NET: Registered protocol family 16
    [    0.202181] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.209483] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.217531] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.225834] thermal_sys: Registered thermal governor 'step_wise'
    [    0.225836] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.232402] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.246035] ASID allocator initialised with 65536 entries
    [    0.271357] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.278213] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.285059] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.291904] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.299356] cryptd: max_cpu_qlen set to 1000
    [    0.305452] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.314275] vsys_3v3: supplied by evm_12v0
    [    0.318636] vsys_5v0: supplied by evm_12v0
    [    0.323378] iommu: Default domain type: Translated
    [    0.328538] SCSI subsystem initialized
    [    0.332696] mc: Linux media interface: v0.10
    [    0.337074] videodev: Linux video capture interface: v2.00
    [    0.342708] pps_core: LinuxPPS API ver. 1 registered
    [    0.347779] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.357116] PTP clock support registered
    [    0.361137] EDAC MC: Ver: 3.0.0
    [    0.364947] FPGA manager framework
    [    0.368456] Advanced Linux Sound Architecture Driver Initialized.
    [    0.375045] clocksource: Switched to clocksource arch_sys_counter
    [    0.381367] VFS: Disk quotas dquot_6.6.0
    [    0.385397] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.394962] NET: Registered protocol family 2
    [    0.399699] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.408271] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.417026] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.425226] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.433022] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.439819] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.446713] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.454108] NET: Registered protocol family 1
    [    0.458814] RPC: Registered named UNIX socket transport module.
    [    0.464878] RPC: Registered udp transport module.
    [    0.469682] RPC: Registered tcp transport module.
    [    0.474485] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.481067] NET: Registered protocol family 44
    [    0.485613] PCI: CLS 0 bytes, default 64
    [    0.489984] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.500333] Initialise system trusted keyrings
    [    0.504963] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.513072] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.519338] NFS: Registering the id_resolver key type
    [    0.524518] Key type id_resolver registered
    [    0.528793] Key type id_legacy registered
    [    0.532914] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.539763] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.547404] 9p: Installing v9fs 9p2000 file system support
    [    0.572238] Key type asymmetric registered
    [    0.576424] Asymmetric key parser 'x509' registered
    [    0.581422] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.588981] io scheduler mq-deadline registered
    [    0.593606] io scheduler kyber registered
    [    0.599379] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.605553] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.614595] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.621036] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.629012] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.635432] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.643377] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.649795] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.657724] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.664049] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.671993] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.678318] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.688034] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.696311] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.704524] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.711552] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.719985] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.733274] brd: module loaded
    [    0.739685] loop: module loaded
    [    0.743415] megasas: 07.714.04.00-rc1
    [    0.749245] tun: Universal TUN/TAP device driver, 1.6
    [    0.754728] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.761137] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.767211] sky2: driver version 1.30
    [    0.771579] VFIO - User Level meta-driver version: 0.3
    [    0.777363] i2c /dev entries driver
    [    0.781877] sdhci: Secure Digital Host Controller Interface driver
    [    0.788201] sdhci: Copyright(c) Pierre Ossman
    [    0.792944] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.799375] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.805714] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.813105] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.817668] optee: revision 3.20 (8e74d476)
    [    0.834067] optee: dynamic shared memory is enabled
    [    0.843531] optee: initialized driver
    [    0.848702] NET: Registered protocol family 17
    [    0.853327] 9pnet: Installing 9P2000 support
    [    0.857723] Key type dns_resolver registered
    [    0.862167] Loading compiled-in X.509 certificates
    [    0.875918] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.939318] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.947035] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.953124] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.959552] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.966027] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.972849] pca953x 3-0020: using no AI
    [    0.999907] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.006706] pca953x 3-0022: using AI
    [    1.010981] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    1.016958] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    1.023201] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    1.029696] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.036137] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.045860] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.052165] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    1.058988] pca953x 6-0020: using no AI
    [    1.083729] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.089813] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.095783] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    1.102019] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    1.108831] pca953x 9-0020: using no AI
    [    1.135376] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    1.141844] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain cread
    [    1.151827] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.160638] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.170517] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.192111] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.199788] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.208065] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.216341] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.235702] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.242126] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.247739] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.257431] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.264484] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.270623] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    2.280575] pci 0000:00:00.0: supports D1
    [    2.284669] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.290557] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.297584] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 )
    [    2.309540] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.319527] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.326297] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    2.333773] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.339076] pcieport 0000:00:00.0: PME: Signaling with IRQ 68
    [    2.345436] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.353102] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.361377] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.369657] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.380952] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.387370] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.392976] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010ff)
    [    3.402844] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.409888] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.416027] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    3.425956] pci 0001:00:00.0: supports D1
    [    3.430051] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.437843] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.447822] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.454589] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.459868] pcieport 0001:00:00.0: PME: Signaling with IRQ 71
    [    3.466224] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.473894] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.482170] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.490447] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.501883] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.508302] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    4.513908] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.523155] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000)
    [    4.533929] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.540068] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bs
    [    4.549997] pci 0002:00:00.0: supports D1
    [    4.554091] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.561875] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.571856] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.578622] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.583898] pcieport 0002:00:00.0: PME: Signaling with IRQ 74
    [    4.590731] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:5
    [    4.600612] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.607370] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.616377] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-1
    [    4.626520] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.633285] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.641249] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.650646] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.659392] printk: console [ttyS2] enabled
    [    4.667830] printk: bootconsole [ns16550a0] disabled
    [    4.678293] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.687269] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.698011] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assd
    [    4.708525] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assumind
    [    4.718677] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assumid
    [    4.728914] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assumd
    [    4.740072] scsi host0: ufshcd
    [    4.749119] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    4.761845] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWA0
    [    4.795048] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.797903] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST 2
    [    4.803585] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.814343] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not0
    [    4.822609] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw vers0
    [    4.833827] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.846525] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.855210] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.862075] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.870750] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.883881] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.894301] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    5.003945] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.004174] mmc0: CQHCI version 5.10
    [    5.019649] vdd_mmc1: supplied by vsys_3v3
    [    5.024575] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    5.031233] pca953x 4-0020: using no AI
    [    5.054336] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    5.062872] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    5.069722] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    5.076550] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    5.083378] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    5.090187] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    5.100823] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    5.111455] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    5.126165] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    5.131415] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    5.138015] Creating 8 MTD partitions on "47040000.spi.0":
    [    5.143487] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    5.149070] mmc0: Command Queue Engine enabled
    [    5.151429] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    5.153520] mmc0: new HS200 MMC card at address 0001
    [    5.159185] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    5.164010] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.169549] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    5.173785] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.179196] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    5.184822] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.190376] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    5.201651] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.202011] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.213215]  mmcblk0: p1
    [    5.214763] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    5.226086] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    5.232344] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    5.279051] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.287459] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.295753] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw vers0
    [    5.308602] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.315809] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.322073] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.332421] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.340588] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.355263] mmc1: CQHCI version 5.10
    [    5.359976] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    5.367229] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    5.375630] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    5.382950] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    5.390254] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    5.397570] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    5.405947] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.427281] ALSA device list:
    [    5.430242]   No soundcards found.
    [    6.871539] sdhci-am654 4fb0000.mmc: Power on failed
    [    6.907118] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.921360] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    6.929496] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    6.936356] devtmpfs: mounted
    [    6.940125] Freeing unused kernel memory: 1856K
    [    6.951115] Run /sbin/init as init process
    [    7.014620] systemd[1]: System time before build time, advancing clock.
    [    7.040578] NET: Registered protocol family 10
    [    7.045482] Segment Routing with IPv6
    [    7.062218] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SM)
    [    7.083946] systemd[1]: Detected architecture arm64.
    [    7.127492] systemd[1]: Set hostname to <j7-evm>.
    [    7.136188] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.142818] systemd[1]: Initializing machine ID from random generator.
    [    7.269893] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in .
    [    7.291270] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below lega.
    [    7.347847] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.356110] systemd[1]: Created slice system-getty.slice.
    [    7.379125] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.386478] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    7.407753] systemd[1]: Created slice User and Session Slice.
    [    7.431237] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    7.455177] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    7.479168] systemd[1]: Reached target Paths.
    [    7.495112] systemd[1]: Reached target Remote File Systems.
    [    7.515104] systemd[1]: Reached target Slices.
    [    7.531107] systemd[1]: Reached target Swap.
    [    7.556531] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    7.579183] systemd[1]: Reached target RPC Port Mapper.
    [    7.603074] systemd[1]: Listening on Process Core Dump Socket.
    [    7.623249] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    7.648779] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.657106] systemd[1]: Listening on Journal Socket (/dev/log).
    [    7.679364] systemd[1]: Listening on Journal Socket.
    [    7.695394] systemd[1]: Listening on Network Service Netlink Socket.
    [    7.719332] systemd[1]: Listening on udev Control Socket.
    [    7.739237] systemd[1]: Listening on udev Kernel Socket.
    [    7.761261] systemd[1]: Mounting Huge Pages File System...
    [    7.777181] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.801270] systemd[1]: Mounting Kernel Debug File System...
    [    7.823393] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.841427] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    7.871325] systemd[1]: Starting Start psplash boot splash screen...
    [    7.897725] systemd[1]: Starting RPC Bind...
    [    7.915256] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.927329] systemd[1]: Starting Journal Service...
    [    7.950565] systemd[1]: Starting Load Kernel Modules...
    [    7.964352] cryptodev: loading out-of-tree module taints kernel.
    [    7.972705] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   7.982740] cryptodev: driver 1.10 loaded.
    [0m...
    [    7.994958] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    8.005348] systemd[1]: Starting udev Coldplug all Devices...
    [    8.030090] systemd[1]: Started RPC Bind.
    [    8.047547] systemd[1]: Started Journal Service.
    [    8.233194] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    8.241132] random: systemd: uninitialized urandom read (16 bytes read)
             Mounting Kernel Configuration File System.[    8.254786] random: systemd-journal: uninitialized u)
    [    8.287654] systemd-journald[184]: Received client request to flush runtime journal.
    [    9.045911] random: crng init done
    [    9.049742] random: 75 urandom warning(s) missed due to ratelimiting
    [    9.137076] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.162668] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.236558] CAN device driver interface
    [    9.252765] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.320569] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.352112] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.396391] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    9.422753] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.443123] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.468591] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    9.482465] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.495037] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    9.514224] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.554150] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.577564] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.577957] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    9.595599] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.611940] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.623653] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.637047] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [    9.639680] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.655957] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [    9.664720] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.679862] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.703748] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    9.712774] remoteproc remoteproc0: powering up 4d80800000.dsp
    [    9.718708] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1334036
    [    9.747925] remoteproc remoteproc0: bad phdr da 0xa8100000 mem 0x8c
    [    9.754229] remoteproc remoteproc0: Failed to load program segments: -22
    [    9.768766] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [    9.792197] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed st)
    [    9.803325] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [    9.839177] remoteproc remoteproc1: 4d81800000.dsp is available
    [    9.860266] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power s
    [    9.870785] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.882383] remoteproc remoteproc1: powering up 4d81800000.dsp
    [    9.895102] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1334036
    [    9.926507] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [    9.935084] remoteproc remoteproc1: bad phdr da 0xa9100000 mem 0x8c
    [    9.941404] remoteproc remoteproc1: Failed to load program segments: -22
    [    9.965524] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [    9.972722] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    9.976631] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.011256] PVR_K:  219: Read BVNC 22.104.208.318 from HW device registers
    [   10.134061] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [   10.165655] remoteproc remoteproc2: 41000000.r5f is available
    [   10.175164] PVR_K:  219: RGX Device registered with BVNC 22.104.208.318
    [   10.216428] remoteproc remoteproc3: 64800000.dsp is available
    [   10.271443] remoteproc remoteproc2: attaching to 41000000.r5f
    [   10.282050] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [   10.350178] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   10.394513] remoteproc remoteproc3: powering up 64800000.dsp
    [   10.401152] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 12849048
    [   10.414613] remoteproc remoteproc3: unsupported resource 65538
    [   10.422945] remoteproc remoteproc3: bad phdr da 0xb2100000 mem 0x98
    [   10.432928] remoteproc remoteproc3: Failed to load program segments: -22
    [   10.531754]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.665033] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   10.682349] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.689961] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   10.730636]  remoteproc2#vdev0buffer: registered virtio0 (type 7)
    [   10.772599] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [   10.867230] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.903895] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.955885] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.991899] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   11.004231] remoteproc remoteproc4: powering up 5c00000.r5f
    [   11.009852] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1424760
    [   11.023697] remoteproc remoteproc4: bad phdr da 0xa2104000 mem 0x1687b70
    [   11.030514] remoteproc remoteproc4: Failed to load program segments: -22
    [   11.071293] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   11.087330] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   11.097286] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   11.109823] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   11.123337] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [   11.127191] remoteproc remoteproc5: 5d00000.r5f is available
    [   11.168724] remoteproc remoteproc5: powering up 5d00000.r5f
    [   11.174432] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 302028
    Looking forward to your reply.
    Barry
  • Hi Barry
    Did you used tiny rootfs for flashing the emmc or you used default sdk image.
    How you created a rootfs.img the path you shared above seems to be custom.
    Also can you share the output of the below command.
    • Halt at UBOOT
    • ls mmc 0:1 lib/firmware (considering 1 as a partition where rootfs im present in the emmc)
    Diwakar
  • Hi Diwakar
    1.When using tiny and default SDK, booting is OK.
    ti-processor-sdk-linux-j7-evm-08_06_00_11/filesystem/
    tisdk-default-image-j7-evm.tar.xz
    tisdk-tiny-image-j7-evm.tar.xz
    2.
    We have not modified any TI source packages To put it simply, we need to completely upgrade the rootfs in the SD card.
    @sz-dl-260:~/ti-processor-sdk-rtos-j721e-evm-08_06_00_12-prebuilt$ ls
    BOOT  boot-j7-evm.tar.gz  install_data_set_to_sd_card.sh  install_to_sd_card.sh  mk-linux-card.sh  rootfs  test_data  tisdk-edgeai-image-j7-evm.tar.xz
    @sz-dl-260:./install_to_sd_card.sh
    The boot and rootfs generated after the execution of install_to_sd_card.sh
    Then make rootfs as rootfs.img
    3.
    • Halt at UBOOT
    U-Boot SPL 2021.01-dirty (May 11 2024 - 17:50:14 +0800)
    Trying to boot from MMC1
    init_env from device 17 not supported!
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.4
    U-Boot SPL 2021.01-dirty (May 11 2024 - 17:50:09 +0800)
    U-Boot 2021.01-dirty (May 11 2024 - 17:50:09 +0800)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:10
    => ls mmc 0:1 lib/firmware
    <DIR>       4096 .
    <DIR>       4096 ..
    <SYM>         43 j7-c66_0-fw
                2040 LICENCE.ibt_firmware
                2046 LICENCE.iwlwifi_firmware
              918268 iwlwifi-3160-17.ucode
             2120860 iwlwifi-8000C-22.ucode
             2227284 iwlwifi-8000C-27.ucode
             2310116 iwlwifi-8000C-31.ucode
             2448976 iwlwifi-8000C-34.ucode
             2428004 iwlwifi-8000C-36.ucode
             1811984 iwlwifi-8265-22.ucode
             2234528 iwlwifi-8265-27.ucode
             2307104 iwlwifi-8265-31.ucode
             2440780 iwlwifi-8265-34.ucode
             2436632 iwlwifi-8265-36.ucode
             2637216 iwlwifi-9260-th-b0-jf-b0-33.ucode
             2678092 iwlwifi-9260-th-b0-jf-b0-34.ucode
             2521412 iwlwifi-9260-th-b0-jf-b0-38.ucode
             2620656 iwlwifi-9260-th-b0-jf-b0-41.ucode
             2558176 iwlwifi-9260-th-b0-jf-b0-43.ucode
             1489668 iwlwifi-9260-th-b0-jf-b0-46.ucode
    <SYM>         49 j7-mcu-r5f0_0-fw
    <SYM>         65 j7-c66_0-fw-sec
    <SYM>         44 j7-main-r5f0_1-fw
    <SYM>         65 j7-c66_1-fw-sec
    <SYM>         44 j7-main-r5f0_0-fw
    <SYM>         65 j7-c71_0-fw-sec
    <SYM>         43 j7-c71_0-fw
    <SYM>         66 j7-main-r5f0_0-fw-sec
    <SYM>         43 j7-c66_1-fw
    <SYM>         66 j7-main-r5f0_1-fw-sec
    <SYM>         66 j7-main-r5f1_0-fw-sec
    <SYM>         66 j7-main-r5f1_1-fw-sec
              247469 pvdec_full_bin.fw
                4592 regulatory.db
                1182 regulatory.db.p7s
              122880 rgx.fw.22.104.208.318
              122880 rgx.fw.22.104.208.318.64k
              344760 rgx.sh.22.104.208.318
    <DIR>       4096 cadence
    <DIR>       4096 ethfw
    <DIR>       4096 intel
    <DIR>       4096 pdk-ipc
    <DIR>       4096 pru
    <DIR>       4096 ti-connectivity
    <DIR>       4096 vision_apps_eaik
    <DIR>       4096 vision_apps_evm
    <DIR>       4096 .
    <DIR>       4096 ..
                4592 regulatory.db
    <DIR>       4096 cadence
    <DIR>       4096 ethfw
    <DIR>       4096 intel
    <DIR>       4096 pdk-ipc
    <DIR>       4096 pru
    => boot
    111990 bytes read in 8 ms (13.3 MiB/s)
    Starting kernel ...
    Barry
  • Hi Barry
    I am suspecting that it is trying to read the firmware from the sd card
    can you create the sd card as per the sdk documentation with all the necessary file.
    Use emmc boot mode only just keep the sd card inserted and see if you are able to boot so that we can be sure that it is taking the firmware from the sd card only.
    Diwakar
  • Hi Diwakar
    1.ti-processor-sdk-rtos-j721e-evm-08_06_00_12-prebuilt
     install_to_sd_card.sh ---After making SD card,The system starts normally and uses OK.
    /sd-BOOT:
    /SD-rootfs:
    It can be confirmed that the SD content produced is fine.
    2.
    dfu currently only flashes tiboot3.bin/sysfw.itb/tispl.bin/u-boot.img and the rootfs.img generated by the entire rootfs of the SD card.
    The startup will be stuck as shown in the log reply above:
    Doesn’t uEnv.txt in the BOOT partition require flash?
    3.
    eMMC (boot0) +  Insert SD card  =  boot OK
    I/TC:
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from FAT... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    mmc1 is current device
    483 bytes read in 7 ms (67.4 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 9 ms (0 Bytes/s)
    Already setup.
    gpio: pin gpio@22_17 (gpio 281) value is 1
    gpio: pin gpio@22_16 (gpio 280) value is 0
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    1424760 bytes read in 69 ms (19.7 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 1424760 bytes: Success!
    302028 bytes read in 23 ms (12.5 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    1334036 bytes read in 65 ms (19.6 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 1334036 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 1334036 bytes: Success!
    12849048 bytes read in 540 ms (22.7 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 12849048 bytes: Success!
    19079680 bytes read in 795 ms (22.9 MiB/s)
    111990 bytes read in 13 ms (8.2 MiB/s)
    11789 bytes read in 9 ms (1.2 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain f3
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-l
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-l
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-l
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-l
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-l
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-l
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id sharedl
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shal
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shl
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id sharel
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB
    [    0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000t
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 1696364K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, )
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] GICv3: using LPI property table @0x00000008c7030000
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 4407s
    [    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008441] Console: colour dummy device 80x25
    [    0.013005] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=8)
    [    0.023675] pid_max: default: 32768 minimum: 301
    [    0.028431] LSM: Security Framework initializing
    [    0.033187] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040765] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049613] rcu: Hierarchical SRCU implementation.
    [    0.054684] Platform MSI: msi-controller@1820000 domain created
    [    0.060955] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070269] EFI services will not be available.
    [    0.074994] smp: Bringing up secondary CPUs ...
    [    0.088239] Detected PIPT I-cache on CPU1
    [    0.088263] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088274] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000
    [    0.088310] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088361] smp: Brought up 1 node, 2 CPUs
    [    0.117707] SMP: Total of 2 processors activated.
    [    0.122512] CPU features: detected: 32-bit EL0 Support
    [    0.127767] CPU features: detected: CRC32 instructions
    [    0.141919] CPU: All CPU(s) started at EL2
    [    0.146115] alternatives: patching kernel code
    [    0.151157] devtmpfs: initialized
    [    0.160468] KASLR disabled due to lack of seed
    [    0.165118] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.175082] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.188523] pinctrl core: initialized pinctrl subsystem
    [    0.194180] DMI not present or invalid.
    [    0.198430] NET: Registered protocol family 16
    [    0.203837] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.211150] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.219162] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.227474] thermal_sys: Registered thermal governor 'step_wise'
    [    0.227476] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.234063] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.247702] ASID allocator initialised with 65536 entries
    [    0.272025] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.278882] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.285728] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.292573] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.300040] cryptd: max_cpu_qlen set to 1000
    [    0.306160] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.314983] vsys_3v3: supplied by evm_12v0
    [    0.319372] vsys_5v0: supplied by evm_12v0
    [    0.324172] iommu: Default domain type: Translated
    [    0.329293] SCSI subsystem initialized
    [    0.333429] mc: Linux media interface: v0.10
    [    0.337801] videodev: Linux video capture interface: v2.00
    [    0.343431] pps_core: LinuxPPS API ver. 1 registered
    [    0.348504] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.357841] PTP clock support registered
    [    0.361860] EDAC MC: Ver: 3.0.0
    [    0.365665] FPGA manager framework
    [    0.369175] Advanced Linux Sound Architecture Driver Initialized.
    [    0.375770] clocksource: Switched to clocksource arch_sys_counter
    [    0.382098] VFS: Disk quotas dquot_6.6.0
    [    0.386131] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.395764] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.402057] NET: Registered protocol family 2
    [    0.406796] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.415427] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.424186] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.432390] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.440202] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.446997] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.453893] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.461295] NET: Registered protocol family 1
    [    0.466013] RPC: Registered named UNIX socket transport module.
    [    0.472069] RPC: Registered udp transport module.
    [    0.476884] RPC: Registered tcp transport module.
    [    0.481687] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.488269] NET: Registered protocol family 44
    [    0.492818] PCI: CLS 0 bytes, default 64
    [    0.497211] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.507631] Initialise system trusted keyrings
    [    0.512275] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.520413] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.526617] NFS: Registering the id_resolver key type
    [    0.531810] Key type id_resolver registered
    [    0.536082] Key type id_legacy registered
    [    0.540200] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.547048] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.554690] 9p: Installing v9fs 9p2000 file system support
    [    0.579671] Key type asymmetric registered
    [    0.583859] Asymmetric key parser 'x509' registered
    [    0.588855] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.596414] io scheduler mq-deadline registered
    [    0.601039] io scheduler kyber registered
    [    0.606761] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.612960] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.621988] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.628425] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.636418] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.642841] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.650781] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.657199] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.665127] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.671452] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.679419] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.685745] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.695435] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.703695] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.711939] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.719096] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.727655] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.740853] brd: module loaded
    [    0.747400] loop: module loaded
    [    0.751216] megasas: 07.714.04.00-rc1
    [    0.756981] tun: Universal TUN/TAP device driver, 1.6
    [    0.762446] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.768857] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.774935] sky2: driver version 1.30
    [    0.779279] VFIO - User Level meta-driver version: 0.3
    [    0.785061] i2c /dev entries driver
    [    0.789529] sdhci: Secure Digital Host Controller Interface driver
    [    0.795869] sdhci: Copyright(c) Pierre Ossman
    [    0.800529] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.806949] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.813299] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.820686] optee: probing for conduit method.
    [    0.825249] optee: revision 3.20 (8e74d476)
    [    0.841658] optee: dynamic shared memory is enabled
    [    0.851123] optee: initialized driver
    [    0.856347] NET: Registered protocol family 17
    [    0.860972] 9pnet: Installing 9P2000 support
    [    0.865368] Key type dns_resolver registered
    [    0.869827] Loading compiled-in X.509 certificates
    [    0.883316] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.942830] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.950648] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.956751] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.963136] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.969608] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.976440] pca953x 3-0020: using no AI
    [    1.004646] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    1.011458] pca953x 3-0022: using AI
    [    1.015733] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    1.021709] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    1.027953] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    1.034446] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.044181] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.050487] pca953x 5-0020: supply vcc not found, using dummy regulator
    [    1.057310] pca953x 5-0020: using no AI
    [    1.084444] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.090541] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
    [    1.096519] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
    [    1.102959] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.112942] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.121754] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.131620] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.151093] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.158789] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.167069] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.175348] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.192245] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    2.198658] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.204265] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    2.213955] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    2.221008] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.227147] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.237095] pci 0000:00:00.0: supports D1
    [    2.241189] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.247075] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    2.254102] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    2.266470] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.276828] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.283600] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    2.291075] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.296374] pcieport 0000:00:00.0: PME: Signaling with IRQ 61
    [    2.302757] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.310427] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.318704] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.326987] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.338243] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    3.344673] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.350280] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    3.360148] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    3.367191] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.373330] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.383260] pci 0001:00:00.0: supports D1
    [    3.387355] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.395356] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.405669] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.412436] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.417727] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
    [    3.424104] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.431779] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.440056] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.448334] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    4.456977] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    4.463390] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    4.468995] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    4.478242] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07f)
    [    4.489019] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.495157] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    4.505085] pci 0002:00:00.0: supports D1
    [    4.509180] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    4.517398] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.527704] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    4.534471] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    4.539757] pcieport 0002:00:00.0: PME: Signaling with IRQ 67
    [    4.546608] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    4.556491] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    4.563250] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.572272] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    4.582413] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.589176] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    4.597167] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    4.606580] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    4.615328] printk: console [ttyS2] enabled
    [    4.623766] printk: bootconsole [ns16550a0] disabled
    [    4.634235] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    4.643177] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    4.652878] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming d
    [    4.663391] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabd
    [    4.673552] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enad
    [    4.683792] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming end
    [    4.694799] scsi host0: ufshcd
    [    4.703949] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    4.716608] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MO0
    [    4.747776] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    4.756340] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    4.764593] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, 2
    [    4.776225] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, 0
    [    4.787382] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x0
    [    4.800171] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.800214] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    4.815813] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.822080] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    4.822188] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    4.839814] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    4.843946] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    4.956871] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    4.962771] mmc0: CQHCI version 5.10
    [    4.972980] vdd_mmc1: supplied by vsys_3v3
    [    4.978144] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    4.985019] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    4.991843] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    4.998673] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    5.005480] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    5.007660] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    5.016100] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    5.030244] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    5.044891] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    5.050128] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    5.056738] Creating 8 MTD partitions on "47040000.spi.0":
    [    5.062212] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    5.068229] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    5.073935] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    5.079720] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    5.085228] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    5.090935] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    5.097072] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.102857] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    5.111910] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    5.118199] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    5.134759] mmc0: Command Queue Engine enabled
    [    5.139206] mmc0: new HS200 MMC card at address 0001
    [    5.144484] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.149127] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.155152] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.161150] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.163785] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.177018] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.185337] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x0
    [    5.198159] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.205374] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.211493]  mmcblk0: p1
    [    5.211699] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.224672] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    5.233110] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.239316] mmc1: CQHCI version 5.10
    [    5.247874] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    5.255177] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    5.263553] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    5.270894] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    5.278207] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    5.285528] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    5.293933] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    5.314217] ALSA device list:
    [    5.317186]   No soundcards found.
    [    6.297862] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    6.306085] Waiting for root device PARTUUID=ba34b40c-02...
    [    6.355097] mmc1: new ultra high speed DDR50 SDHC card at address 5048
    [    6.361974] mmcblk1: mmc1:5048 SD32G 29.7 GiB
    [    6.368075]  mmcblk1: p1 p2
    [    6.701013] EXT4-fs (mmcblk1p2): recovery complete
    [    6.706858] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.714970] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    6.721841] devtmpfs: mounted
    [    6.725706] Freeing unused kernel memory: 1856K
    [    6.730329] Run /sbin/init as init process
    [    6.900919] systemd[1]: System time before build time, advancing clock.
    [    6.951185] NET: Registered protocol family 10
    [    6.956131] Segment Routing with IPv6
    [    6.982283] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +S)
    [    7.004035] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    7.044471] systemd[1]: Set hostname to <j7-evm>.
    [    7.201328] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in sectio.
    [    7.224003] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy dir.
    [    7.285282] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.293596] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    7.315858] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.323251] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    7.343847] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.351095] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    7.371980] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password �…ts to Console Directory Watch.
    [    7.395893] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R�…uests to Wall Directory Watch.
    [    7.419901] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    7.435838] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    7.455831] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    7.471829] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    7.502880] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    7.523908] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    7.546362] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    7.567994] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    7.593477] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    7.602789] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    7.628125] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    7.648147] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    7.672059] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    7.691972] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    7.714092] systemd[1]: Mounting Huge Pages File System...
    [    7.738107] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.762137] systemd[1]: Mounting Kernel Debug File System...
    [    7.786695] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    7.810263] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st�…odes for the current kernel...
    [    7.839226] systemd[1]: Starting Start psplash boot splash screen...
    [    7.862197] systemd[1]: Starting RPC Bind...
    [    7.876050] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    7.888345] systemd[1]: Starting Journal Service...
    [    7.912045] systemd[1]: Starting Load Kernel Modules...
    [    7.927275] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    7.944463] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    7.944651] cryptodev: loading out-of-tree module taints kernel.
    [    7.958557] systemd[1]: Starting udev Coldplug all Devices...
             Starting udev Coldplug all Devices...[    7.968326] cryptodev: driver 1.10 loaded.
    [    7.986863] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    8.004318] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta�… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star�…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    8.218356] systemd-journald[183]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    8.332422] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Reached target Local File Systems (Pre).
    [    8.356011] random: systemd: uninitialized urandom read (16 bytes read)
             Mounting /media/ram...
    [    8.366528] random: systemd-journal: uninitialized urandom read (16 bytes read)
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting udev Wait for Complete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    8.737232] random: crng init done
    [    8.740705] random: 66 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    8.772234] ina2xx 4-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.779690] ina2xx 4-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.787748] ina2xx 4-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.795525] ina2xx 4-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.803290] ina2xx 4-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.811108] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    8.818786] ina2xx 4-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.826573] ina2xx 4-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.834348] ina2xx 4-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.842154] ina2xx 4-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.849929] ina2xx 4-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.857739] ina2xx 4-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.865517] ina2xx 4-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.873318] ina2xx 4-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.881104] ina2xx 4-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.888964] ina2xx 4-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    8.926399] CAN device driver interface
    [    9.022393] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    9.033052] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    9.039942] remoteproc remoteproc0: 4d80800000.dsp is available
    [    9.046053] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    9.052294] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    9.059192]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    9.069287] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.074929] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    9.100056] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [    9.112886]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    9.126721] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.159291] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    9.234967] PVR_K:  211: Read BVNC 22.104.208.318 from HW device registers
    [    9.242188] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0)
    [    9.292003] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    9.299739] PVR_K:  211: RGX Device registered with BVNC 22.104.208.318
    [    9.334207] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    9.347844] platform 41000000.r5f: configured R5F for IPC-only mode
    [    9.356593] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    9.365589] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    9.408046] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    9.444234] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    9.453729] remoteproc remoteproc1: 41000000.r5f is available
    [    9.460488] remoteproc remoteproc1: attaching to 41000000.r5f
    [    9.467704] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.476963]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    9.497817] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.511913] remoteproc remoteproc2: 4d81800000.dsp is available
    [    9.517872] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.525486] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.535765]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    9.542203] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    9.556019] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    9.557908] remoteproc remoteproc2: attaching to 4d81800000.dsp
    [    9.564598] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    9.578585] remoteproc remoteproc3: 5c00000.r5f is available
    [    9.588267] remoteproc remoteproc3: attaching to 5c00000.r5f
    [    9.594123] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    9.602687]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    9.614839] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.620750]  remoteproc3#vdev0buffer: registered virtio2 (type 7)
    [    9.629754] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    9.648310] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    9.655169] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [    9.665336] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    9.671902] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    9.682641] remoteproc remoteproc4: 5d00000.r5f is available
    [    9.683049]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    9.690268] remoteproc remoteproc4: attaching to 5d00000.r5f
    [    9.732222] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    9.737820] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    9.789563] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    9.798192]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    9.799341]  remoteproc2#vdev0buffer: registered virtio3 (type 7)
    [    9.808134] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    9.819595]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    9.822964] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    9.826377] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
    [    9.860154] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    9.861476] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
    [    9.888114] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    9.898709] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    9.914059] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    9.922702] remoteproc remoteproc6: 64800000.dsp is available
    [    9.931758] remoteproc remoteproc6: attaching to 64800000.dsp
    [    9.939552] remoteproc remoteproc6: unsupported resource 65538
    [    9.945394] remoteproc remoteproc5: 5e00000.r5f is available
    [    9.949040] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [    9.951206] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    9.961976] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    9.968611]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    9.973277] remoteproc remoteproc5: powering up 5e00000.r5f
    [    9.982876] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    9.989348] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [    9.993901]  remoteproc6#vdev0buffer: registered virtio5 (type 7)
    [   10.009529] remoteproc remoteproc6: remote processor 64800000.dsp is now attached
    [   10.017070] remoteproc remoteproc5: request_firmware failed: -2
    [   10.023126] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   10.034876] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   10.044096] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   10.051605] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.059175] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   10.070001] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.074498] remoteproc remoteproc7: 5f00000.r5f is available
    [   10.080962] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [   10.091124] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.103003] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   10.108574] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   10.113548] virtio_rpmsg_bus virtio2: creating channel ti.ethfw.notifyservice addr 0x1e
    [   10.122800] remoteproc remoteproc7: powering up 5f00000.r5f
    [   10.127376] virtio_rpmsg_bus virtio2: creating channel rpmsg-kdrv addr 0x1a
    [   10.142568] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   10.144045] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   10.150082] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.167145] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF2
    [   10.171070] remoteproc remoteproc7: request_firmware failed: -2
    [   10.181054] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 28/Feb/2023 SHAa
    [   10.198613] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF ua2
    [   10.212063] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 28/Feb/2023 SHA:8ca
    [   10.225620] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.274617] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   10.299749] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   10.309512] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B0
    [   10.330145] m_can_platform 2701000.can: m_can device registered (irq=48, version=32)
    [   10.354661] m_can_platform 2721000.can: m_can device registered (irq=50, version=32)
    [   10.377113] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   10.387973] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:1720
    [   10.418256] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:71
    [   10.594701] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:000000071
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [   10.834586] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [   10.850391] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:1731
    [   10.876822] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:72
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [   11.169509] remoteproc remoteproc8: b034000.pru is available
    [   11.177976] usbcore: registered new interface driver usbfs
    [   11.189017] remoteproc remoteproc9: b004000.rtu is available
    [   11.208527] usbcore: registered new interface driver hub
    [   11.218395] remoteproc remoteproc10: b00a000.txpru is available
    [   11.227523] usbcore: registered new device driver usb
    [   11.233633] remoteproc remoteproc11: b038000.pru is available
    [   11.242256] remoteproc remoteproc12: b006000.rtu is available
    [   11.249748] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   11.250285] remoteproc remoteproc13: b00c000.txpru is available
    [   11.263473] remoteproc remoteproc14: b134000.pru is available
    [   11.270201] remoteproc remoteproc15: b104000.rtu is available
    [   11.278016] remoteproc remoteproc16: b10a000.txpru is available
    [   11.286760] remoteproc remoteproc17: b138000.pru is available
    [   11.293362] remoteproc remoteproc18: b106000.rtu is available
    [   11.299792] remoteproc remoteproc19: b10c000.txpru is available
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [   11.436887] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [  OK  ] Mounted /run/media/mmcblk0p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   12.139816] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.145375] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.153133] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.162553] xhci-hcd xhci-hcd.2.auto: irq 670, io mem 0x06410000
    [   12.168775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.177034] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.184251] usb usb1: Product: xHCI Host Controller
    [   12.189124] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   12.195731] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.200872] hub 1-0:1.0: USB hub found
    [   12.204638] hub 1-0:1.0: 1 port detected
    [   12.209476] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.214968] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.222620] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.229173] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.237314] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   12.245564] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.252774] usb usb2: Product: xHCI Host Controller
    [   12.257641] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   12.264242] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   12.269358] hub 2-0:1.0: USB hub found
    [   12.273126] hub 2-0:1.0: 1 port detected
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message B[   12.467794] usb 1-1: new high-speed USB device number 2 using xhcd
    us Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [   12.636086] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [  OK  ] Started Periodic Command Scheduler.
    [   12.651801] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   12.658937] usb 1-1: SerialNumber: 18010849A119
    [   12.664088] hub 1-1:1.0: USB hub found
    [   12.671874] hub 1-1:1.0: 4 ports detected
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis�…fety feature on power rails...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini�… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started startwlansta.
    [  OK  ] Started Update pmic regist�…safety feature on power rails.
    [  OK  ] Started Telephony service.
    [  OK  ] Started Update weston ini �…ge based on the platform name.
    [  OK  ] Started startwlanap.
    [  OK  ] Started set host name as per compat[   12.918511] Bluetooth: Core ver 2.22
    ible name.
    [   12.930753] NET: Registered protocol family 31
    [   12.939325] Bluetooth: HCI device and connection manager initialized
    [   12.951810] Bluetooth: HCI socket layer initialized
    [   12.961860] Bluetooth: L2CAP socket layer initialized
    [   12.971815] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [   13.076527] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [   13.142845] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [   13.208405] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [  OK  ] Started Login Service.
    [   13.279986] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Listening on Load/Save RF �…itch Status /dev/rfkill Watch.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma�…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting EdgeAI OOB demos...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [   13.910919] PVR_K:  838: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   13.936245] PVR_K:  838: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [  OK  ] Started Simple Network Man�…ement Protocol (SNMP) Daemon..
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login: root
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~# cd /opt/vision_apps/
    root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh
    Barry
  • HI Barry
    What is the boot mode you used for the above test.
    3.
    This one as i can see the boot media is mmc1 which is SD
    Net: eth0: ethernet@46000000port@1
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Suggested experiment was to boot the images using emmc boot mode and keep inserted the SD card partitioned and with all necessary  images.
    Diwakar
  • Hi Diwakar
    eMMC (boot0)+ SD card --- Make sure it is the reply 3 above.
    The phenomenon is that when Boot Switch Settings: eMMC (boot0), insert the SD card and start OK
    Doesn’t the content of uEnv.txt in the BOOT partition need to be flashed?
    7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 23:01:15 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev A
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
    I/TC:
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    Detected: J7X-BASE-CPB rev A
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    SoC:   J721E SR1.1 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    cdns,sierra serdes@5000000: sierra probed
    483 bytes read in 9 ms (51.8 KiB/s)
    Running uenvcmd ...
    Already setup.
    9066912 bytes read in 386 ms (22.4 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 9066912 bytes: Success!
    302028 bytes read in 24 ms (12 MiB/s)
    1334036 bytes read in 68 ms (18.7 MiB/s)
    1334036 bytes read in 67 ms (19 MiB/s)
    12849048 bytes read in 543 ms (22.6 MiB/s)
    19079680 bytes read in 764 ms (23.8 MiB/s)
    111983 bytes read in 13 ms (8.2 MiB/s)
    11915 bytes read in 10 ms (1.1 MiB/s)
       Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.008453] Console: colour dummy device 80x25
    [    0.013018] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=8)
    [    0.023689] pid_max: default: 32768 minimum: 301
    [    0.028445] LSM: Security Framework initializing
    [    0.033202] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040781] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049652] rcu: Hierarchical SRCU implementation.
    [    0.054725] Platform MSI: msi-controller@1820000 domain created
    [    0.060996] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070310] EFI services will not be available.
    [    0.075036] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.088269] Detected PIPT I-cache on CPU1
    [    0.088294] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.088305] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000
    [    0.088338] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.088388] smp: Brought up 1 node, 2 CPUs
    [    0.117735] SMP: Total of 2 processors activated.
    [    0.122541] CPU features: detected: 32-bit EL0 Support
    [    0.127796] CPU features: detected: CRC32 instructions
    [    0.141954] CPU: All CPU(s) started at EL2
    [    0.146150] alternatives: patching kernel code
    [    0.151191] devtmpfs: initialized
    [    0.160504] KASLR disabled due to lack of seed
    [    0.165154] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.175118] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.188542] pinctrl core: initialized pinctrl subsystem
    [    0.194204] DMI not present or invalid.
    [    0.198460] NET: Registered protocol family 16
    [    0.203863] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.211170] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.219180] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.227523] thermal_sys: Registered thermal governor 'step_wise'
    [    0.227525] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.234116] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.247749] ASID allocator initialised with 65536 entries
    [    0.270954] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.277812] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.284663] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.291511] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.298980] cryptd: max_cpu_qlen set to 1000
    [    0.305029] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.313866] vsys_3v3: supplied by evm_12v0
    [    0.318237] vsys_5v0: supplied by evm_12v0
    [    0.323041] iommu: Default domain type: Translated
    [    0.328240] SCSI subsystem initialized
    [    0.332352] mc: Linux media interface: v0.10
    [    0.336722] videodev: Linux video capture interface: v2.00
    [    0.342357] pps_core: LinuxPPS API ver. 1 registered
    [    0.347430] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.356768] PTP clock support registered
    [    0.360787] EDAC MC: Ver: 3.0.0
    [    0.364584] FPGA manager framework
    [    0.368098] Advanced Linux Sound Architecture Driver Initialized.
    [    0.374695] clocksource: Switched to clocksource arch_sys_counter
    [    0.381024] VFS: Disk quotas dquot_6.6.0
    [    0.385057] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.394642] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.400934] NET: Registered protocol family 2
    [    0.405674] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.414263] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.423021] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.431225] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.439034] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.445835] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.452729] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.460130] NET: Registered protocol family 1
    [    0.464863] RPC: Registered named UNIX socket transport module.
    [    0.470919] RPC: Registered udp transport module.
    [    0.475736] RPC: Registered tcp transport module.
    [    0.480539] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.487121] NET: Registered protocol family 44
    [    0.491669] PCI: CLS 0 bytes, default 64
    [    0.496034] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.506426] Initialise system trusted keyrings
    [    0.511061] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.519221] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.525435] NFS: Registering the id_resolver key type
    [    0.530630] Key type id_resolver registered
    [    0.534902] Key type id_legacy registered
    [    0.539022] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.545870] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.553513] 9p: Installing v9fs 9p2000 file system support
    [    0.578009] Key type asymmetric registered
    [    0.582195] Asymmetric key parser 'x509' registered
    [    0.587194] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.594753] io scheduler mq-deadline registered
    [    0.599378] io scheduler kyber registered
    [    0.605084] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.611290] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.620327] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.626760] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.634762] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.641180] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.649127] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.655547] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.663476] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.669801] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.677754] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.684079] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.693778] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.702054] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.710283] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.717445] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.726046] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.739260] brd: module loaded
    [    0.745811] loop: module loaded
    [    0.749628] megasas: 07.714.04.00-rc1
    [    0.755441] tun: Universal TUN/TAP device driver, 1.6
    [    0.760906] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.767315] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.773390] sky2: driver version 1.30
    [    0.777739] VFIO - User Level meta-driver version: 0.3
    [    0.783522] i2c /dev entries driver
    [    0.788005] sdhci: Secure Digital Host Controller Interface driver
    [    0.794326] sdhci: Copyright(c) Pierre Ossman
    [    0.798990] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.805386] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.811729] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.819113] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.823670] optee: revision 3.20 (8e74d476)
    [    0.840071] optee: dynamic shared memory is enabled
    [    0.849535] optee: initialized driver
    [    0.854761] NET: Registered protocol family 17
    [    0.859375] 9pnet: Installing 9P2000 support
    [    0.863769] Key type dns_resolver registered
    [    0.868224] Loading compiled-in X.509 certificates
    [    0.881591] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.940785] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.948624] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.954742] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.961132] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.971007] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.977332] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    0.984163] pca953x 4-0020: using no AI
    [    1.011393] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.017492] omap_i2c 2040000.i2c: bus 5 rev0.12 at 100 kHz
    [    1.023468] omap_i2c 2050000.i2c: bus 6 rev0.12 at 100 kHz
    [    1.029913] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.039885] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.048699] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.058562] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.078154] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.085848] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.094131] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.102409] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.111262] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.118945] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.127221] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.135502] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.144327] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.152008] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.160285] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.168562] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.177838] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.187718] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.194477] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.203527] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.213669] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.220428] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.228422] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.237833] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.246583] printk: console [ttyS2] enabled
    [    1.255023] printk: bootconsole [ns16550a0] disabled
    [    1.265496] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    1.274443] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    1.284301] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming d
    [    1.294810] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabd
    [    1.304962] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enad
    [    1.315200] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming end
    [    1.326211] scsi host0: ufshcd
    [    1.335536] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.348000] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MO0
    [    1.378700] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.387349] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.395709] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x0
    [    1.408524] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.415734] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.415738] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, 2
    [    1.421647] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, 0
    [    1.433676] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.453475] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    1.458860] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    1.470474] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    1.479267] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    1.571894] mmc0: CQHCI version 5.10
    [    1.571938] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.588252] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    1.595118] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    1.601946] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    1.608773] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    1.613283] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.615609] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    1.633269] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.640839] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.648980] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.657118] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.665876] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.673425] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.681557] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.689690] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.698365] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    1.705861] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    1.713949] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    1.722031] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.731249] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.741873] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    1.756239] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    1.761481] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.768091] Creating 8 MTD partitions on "47040000.spi.0":
    [    1.773569] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.779561] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.785247] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.791030] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.796556] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    1.802236] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
    [    1.808397] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.814178] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.823419] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    1.829892] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.838035] mmc0: Command Queue Engine enabled
    [    1.842478] mmc0: new HS200 MMC card at address 0001
    [    1.847768] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.852405] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    1.858429] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    1.864430] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    1.874282]  mmcblk0: p1
    [    1.874714] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.885717] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.894040] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x0
    [    1.906857] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.914061] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.920375] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.930933] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.939445] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.945385] mmc1: CQHCI version 5.10
    [    1.953939] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.961441] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.969525] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.977607] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.986249] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.993752] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.001831] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.009923] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.018541] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.026037] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.034114] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.042194] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.051264] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.058754] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.066834] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.074914] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.083517] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.091005] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.099083] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.107162] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.115740] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.123228] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.131307] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.139386] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.148001] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.155295] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    2.163672] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    2.170989] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    2.178299] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.185603] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    2.194004] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.201514] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    2.209004] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    2.215545] ALSA device list:
    [    2.217082] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    2.220035]   No soundcards found.
    [    2.228104] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.240210] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    2.247699] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    2.255781] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    2.263861] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.272460] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.279949] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.288027] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.296105] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.009521] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    3.017852] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.025357] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.033450] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.041564] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.049967] Waiting for root device PARTUUID=f748d092-02...
    [    3.050213] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    3.063082] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    3.071222] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    3.079360] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.088043] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.095581] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.103670] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.111763] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.145408] mmc1: new high speed SDHC card at address aaaa
    [    3.151260] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
    [    3.157023]  mmcblk1: p1 p2
    [    3.160877] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.168373] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.176455] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.184538] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.193150] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    3.200649] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    3.208729] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    3.216809] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.225403] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    3.232897] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    3.240980] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    3.249058] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.365854] EXT4-fs (mmcblk1p2): recovery complete
    [    3.371489] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.379606] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.386441] devtmpfs: mounted
    [    3.390286] Freeing unused kernel memory: 1856K
    [    3.394913] Run /sbin/init as init process
    [    3.696499] systemd[1]: System time before build time, advancing clock.
    [    3.782373] NET: Registered protocol family 10
    [    3.787307] Segment Routing with IPv6
    [    3.839076] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +S)
    [    3.860791] systemd[1]: Detected architecture arm64.
    [    3.899316] systemd[1]: Set hostname to <j7-evm>.
    [    4.103247] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in sectio.
    [    4.127114] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy dir.
    [    4.195477] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.203826] systemd[1]: Created slice system-getty.slice.
    [    4.226779] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.234167] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    4.254769] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.262008] systemd[1]: Created slice User and Session Slice.
    [    4.282908] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.306820] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.330808] systemd[1]: Reached target Paths.
    [    4.346756] systemd[1]: Reached target Remote File Systems.
    [    4.366748] systemd[1]: Reached target Slices.
    [    4.382754] systemd[1]: Reached target Swap.
    [    4.413568] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.434826] systemd[1]: Reached target RPC Port Mapper.
    [    4.457426] systemd[1]: Listening on Process Core Dump Socket.
    [    4.478903] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.504365] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.512724] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.535020] systemd[1]: Listening on Journal Socket.
    [    4.551062] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.574967] systemd[1]: Listening on udev Control Socket.
    [    4.594885] systemd[1]: Listening on udev Kernel Socket.
    [    4.616978] systemd[1]: Mounting Huge Pages File System...
    [    4.632991] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.660985] systemd[1]: Mounting Kernel Debug File System...
    [    4.686836] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.705247] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    4.747443] systemd[1]: Starting Start psplash boot splash screen...
    [    4.773162] systemd[1]: Starting RPC Bind...
    [    4.790924] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.803306] systemd[1]: Starting Journal Service...
    [    4.829301] systemd[1]: Starting Load Kernel Modules...
    [    4.844803] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.865531] systemd[1]: Starting udev Coldplug all Devices...
    [    4.870682] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
             Starting udev Coldplug all Devices...[    4.877646] cryptodev: loading out-of-tree module taints kernel.
    [    4.889019] cryptodev: driver 1.10 loaded.
    [    4.905848] systemd[1]: Started RPC Bind.
    [    4.923102] systemd[1]: Started Journal Service.
    [    5.145289] systemd-journald[182]: Received client request to flush runtime journal.
    [    5.251397] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.274876] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.286561] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    5.702871] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    5.710540] random: crng init done
    [    5.713974] random: 66 urandom warning(s) missed due to ratelimiting
    [    5.721662] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    5.730345] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    5.740108] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.754488] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.762131] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.774179] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.782329] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.790759] ina2xx 3-0040: error configuring the device: -121
    [    5.797099] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    5.804780] ina2xx 3-0041: error configuring the device: -121
    [    5.810569] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    5.818681] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    5.826791] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.835243] ina2xx 3-0042: error configuring the device: -121
    [    5.842008] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    5.849552] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    5.857686] ina2xx 3-0043: error configuring the device: -121
    [    5.857696] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    5.871539] ina2xx 3-0044: error configuring the device: -121
    [    5.871557] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    5.885592] ina2xx 3-0045: error configuring the device: -121
    [    5.891590] ina2xx 3-0046: error configuring the device: -121
    [    5.898034] ina2xx 3-0047: error configuring the device: -121
    [    5.904575] ina2xx 3-0048: error configuring the device: -121
    [    5.911010] ina2xx 3-0049: error configuring the device: -121
    [    5.917422] ina2xx 3-004a: error configuring the device: -121
    [    5.923814] ina2xx 3-004b: error configuring the device: -121
    [    5.930256] ina2xx 3-004c: error configuring the device: -121
    [    5.936676] ina2xx 3-004d: error configuring the device: -121
    [    5.943179] ina2xx 3-004e: error configuring the device: -121
    [    5.949631] ina2xx 3-004f: error configuring the device: -121
    [    5.979495] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    5.987072] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    5.998757] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.008600] CAN device driver interface
    [    6.012535] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.022875] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.034548] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.045205] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.060116] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.077664] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.089935] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.098498] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.108848] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.122869] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.130420] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.138566] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.146739] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.155486] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.163028] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.171151] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.179259] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.224038] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    6.241882] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.250762] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.263442] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    6.270333] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.278535] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.292106] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.302304] remoteproc remoteproc0: 4d80800000.dsp is available
    [    6.308352] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.316531] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.329924] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [    6.340059] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.351000] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.361908] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.378754] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.390972] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.396375] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    6.405407] PVR_K:  217: Read BVNC 22.104.208.318 from HW device registers
    [    6.406299] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    6.413235] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.422279]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    6.434820] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.442175] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.446568] PVR_K:  217: RGX Device registered with BVNC 22.104.208.318
    [    6.449707]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    6.456254] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.462330] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    6.474637] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.478993] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    6.486974] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    6.504207] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    6.511580] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.519249] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.527701] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    6.535960] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.544130] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.554134] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    6.561219] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.568803] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.582733] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.593320] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.615104] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0)
    [    6.615854] remoteproc remoteproc1: 4d81800000.dsp is available
    [    6.627949] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.632804] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [    6.646771] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.647661] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    6.654957] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    6.663131]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    6.668766] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.686865] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.695949] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.701565] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    6.708971]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [    6.715263] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.723028] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.732596] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.740817] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.741547] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    6.750618] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [    6.757912] platform 41000000.r5f: configured R5F for IPC-only mode
    [    6.764052] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.771145] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.777696] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.787136] remoteproc remoteproc2: 41000000.r5f is available
    [    6.800727] remoteproc remoteproc2: attaching to 41000000.r5f
    [    6.806761] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.807478] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    6.821962]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    6.822742] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.831697] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.850507] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.863386] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    6.872124]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [    6.878319] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [    6.885991] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    6.893791] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    6.901963] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    6.904286] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    6.910434] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.929807] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.937392] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.945549] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.955020] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    6.955706] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.970290] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    6.977853] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    6.989753] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    6.997933] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.006801] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    7.012944] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    7.015550] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.031197] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.039372] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.047572] remoteproc remoteproc3: 64800000.dsp is available
    [    7.053368] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.062122] remoteproc remoteproc3: attaching to 64800000.dsp
    [    7.069857] remoteproc remoteproc3: unsupported resource 65538
    [    7.075841] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    7.091772]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    7.104278] remoteproc remoteproc4: 5c00000.r5f is available
    [    7.110285] remoteproc remoteproc4: attaching to 5c00000.r5f
    [    7.126154] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    7.136275] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [    7.143584] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    7.150264]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    7.151510]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [    7.164349] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    7.165885] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    7.171240]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [    7.182732] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    7.184794] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [    7.196402] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
    [    7.200481] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
    [    7.207463] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    7.226017] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.238347] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    7.252149] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    7.258738] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    7.262880] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    7.274858] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.286372] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    7.297802] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.306582] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.316292] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.324435] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.333402] remoteproc remoteproc5: 5d00000.r5f is available
    [    7.339808] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    7.347574] remoteproc remoteproc5: attaching to 5d00000.r5f
    [    7.353357] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    7.361506] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    7.369632] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.378599] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    7.387430] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    7.395560] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    7.405853] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    7.412549] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.428414]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [    7.438359] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    7.445013]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [    7.453074] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [    7.453651] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
    [    7.462599] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [    7.467684] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.480686] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.482348] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.494827] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    7.506076] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.507590] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.515298] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.528383] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    7.537695] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    7.540237] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.550742] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    7.558854] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [    7.565958] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    7.573482] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [    7.582744] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.585081] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    7.598256] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    7.598414] virtio_rpmsg_bus virtio4: creating channel rpmssdev addr 0x15
    [    7.607108] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    7.614867] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [    7.629409] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [    7.634745] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    7.649419] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.657647] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.668702] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.677596] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.685750] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.687416] remoteproc remoteproc6: 5e00000.r5f is available
    [    7.698735] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.709228] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    7.716781] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    7.727861] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    7.735998] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.737123] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [    7.753494] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    7.761764] remoteproc remoteproc6: powering up 5e00000.r5f
    [    7.763918] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    7.767582] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [    7.782741] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    7.787704] remoteproc remoteproc6: request_firmware failed: -2
    [    7.793274] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    7.804979] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.825586] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [    7.847901] remoteproc remoteproc7: 5f00000.r5f is available
    [    7.861078] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [    7.875711] remoteproc remoteproc7: powering up 5f00000.r5f
    [    7.881378] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [    7.897145] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [    7.898708] remoteproc remoteproc7: request_firmware failed: -2
    [    7.909894] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [    7.931924] m_can_platform 2721000.can: m_can device registered (irq=49, version=32)
    [    7.943471] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.952438] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.965005] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.973139] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    7.990454] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.007986] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.025670] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.033810] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.051057] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    8.058604] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    8.069971] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    8.079832] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.093164] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.103386] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.118744] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.131686] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.143265] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.151038] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.162618] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.170749] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.181103] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    8.188622] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    8.196778] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    8.204909] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [    8.676888] usbcore: registered new interface driver usbfs
    [    8.685781] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.694374] remoteproc remoteproc8: b034000.pru is available
    [    8.694919] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.700520] usbcore: registered new interface driver hub
    [    8.714030] remoteproc remoteproc9: b004000.rtu is available
    [    8.718852] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.720107] remoteproc remoteproc10: b00a000.txpru is available
    [    8.729010] usbcore: registered new device driver usb
    [    8.738804] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.740460] remoteproc remoteproc11: b038000.pru is available
    [    8.751612] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.762086] remoteproc remoteproc12: b006000.rtu is available
    [    8.768609] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.770054] remoteproc remoteproc13: b00c000.txpru is available
    [    8.782045] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.782983] remoteproc remoteproc14: b134000.pru is available
    [    8.796852] remoteproc remoteproc15: b104000.rtu is available
    [    8.798761] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.803203] remoteproc remoteproc16: b10a000.txpru is available
    [    8.817140] remoteproc remoteproc17: b138000.pru is available
    [    8.824213] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    8.824443] remoteproc remoteproc18: b106000.rtu is available
    [    8.837862] remoteproc remoteproc19: b10c000.txpru is available
    [    8.838762] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    8.861747] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    8.876746] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.895901] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.909666] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    8.916304] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.927933] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.940326] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.956321] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.967634] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.981486] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.995866] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    9.011969] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    9.023235] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    9.035553] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
             Starting Start psplash boot splash screen.[    9.047111] j721e-pcie 2920000.pcie:   IB MEM 0x00000000000
    [    9.059875] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    9.068410] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [FAILED] Failed to start Start psplash boo[    9.077510] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017f0
    t splash screen.
    See 'systemctl status psplash-start.servic[    9.090518] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xfffff0
    e' for details.
    [DEPEND] Dependency failed for Star�…progress communication helper.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [    9.380707] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   10.419847] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   10.428334] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   10.437198] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   10.445366] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.454534] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [  OK  ] Reached target Hardware activated U[   10.462136] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400
    SB gadget.
    [   10.475687] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   10.485195] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.496221] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.503769] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.511887] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.520001] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.520808] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   10.529725] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   10.533769] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   10.541804] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   10.549006] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   10.557568] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   10.566424] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000
    [   10.574967] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.580613] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   10.596926] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.604141] usb usb1: Product: xHCI Host Controller
    [   10.609010] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   10.615611] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   10.620748] hub 1-0:1.0: USB hub found
    [   10.624523] hub 1-0:1.0: 1 port detected
    [   10.628760] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   10.634373] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   10.634969] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   10.641860] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   10.649971] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   10.657564] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   10.657574] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.664809] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.688597] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   10.696864] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.697291] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.704143] usb usb2: Product: xHCI Host Controller
    [   10.712042] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.716425] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   10.716427] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   10.716689] hub 2-0:1.0: USB hub found
    [   10.725626] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.731374] hub 2-0:1.0: 1 port detected
    [   10.736644] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.762922] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   10.770439] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   10.778556] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   10.786714] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.795657] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   10.803172] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   10.811261] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   10.819344] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.829348] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   10.836850] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   10.844944] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   10.853030] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   10.902712] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   11.054976] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   11.063193] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   11.070362] usb 1-1: SerialNumber: 18010849A119
    [   11.075648] hub 1-1:1.0: USB hub found
    [   11.079432] hub 1-1:1.0: 4 ports detected
    [   11.089400] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   11.096951] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   11.105100] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   11.113299] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.122255] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [   11.129836] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [   11.137967] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [   11.146079] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.157134] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.164637] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.172766] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.180912] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis�…fety feature on power rails...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini�… based on the platform name...
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started Update pmic regist�…safety feature on power rails.
    [  OK  ] Started startwlanap.
    [  OK  ] Started startwlansta.
    [  OK  ] Started Update weston ini �…ge based on the platform name.
    [  OK  ] Started Telephony service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [   11.926191] Bluetooth: Core ver 2.22
    [   11.931789] NET: Registered protocol family 31
    [   11.938768] Bluetooth: HCI device and connection manager initialized
    [   11.945178] Bluetooth: HCI socket layer initialized
    [   11.947065] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.954712] Bluetooth: L2CAP socket layer initialized
    [   11.966766] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Login Service.
    [   11.994555] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Listening on Load/Save RF �…itch Status /dev/rfkill Watch.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Started Your Script Description.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma�…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting EdgeAI OOB demos...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
    [   12.620119] PVR_K:  829: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   12.648562] PVR_K:  829: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [  OK  ] Started Simple Network Man�…ement Protocol (SNMP) Daemon..
    [   13.330841] Key type cifs.idmap registered
    [   13.335663] CIFS: Attempting to mount //20.20.1.1/shared_windows
    [   13.341755] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or late.
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login: [   19.507003] CIFS: VFS: Error connecting to socket. Aborting operation.
    [   19.515439] CIFS: VFS: cifs_mount failed w/return code = -113
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login:
    j7-evm login: root
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~# cd /opt/vision_apps/
    root@j7-evm:/opt/vision_apps#
    We are looking forward to your reply and hope to resolve this issue as soon as possible
    BR
  • Hi Barry
    I copied the rootfs binary to the uda partition of emmc and could boot without any issue.
    These are the steps i followed.
    • mkdir emmc sd
    • mount /dev/mmcblk1p2  sd
    • mount /dev/mmcblk0p1  emmc
    • cp -r sd/* emmc/
    • sync
    • Remove the SD card and set EMMC boot mode
    Logs:
    82514 bytes read in 7 ms (11.2 MiB/s)
       Loading Device Tree to 000000008fee8000, end 000000008fffffff ... OK
    Starting kernel ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for th3
    [    0.000000] Machine model: Texas Instruments J721S2 EVM
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000bffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a9bfffff]
    [    0.000000]   node   0: [mem 0x00000000a9c00000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x0000000bffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Reserved 512 MiB at 0x00000000dfc00000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4128766
    [    0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dbc00000-0x00000000dfc00000] (64MB)
    [    0.000000] Memory: 15663748K/16777208K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 589172K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000187] Console: colour dummy device 80x25
    [    0.000219] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000227] pid_max: default: 32768 minimum: 301
    [    0.000275] LSM: Security Framework initializing
    [    0.000374] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.000456] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.001404] rcu: Hierarchical SRCU implementation.
    [    0.001576] Platform MSI: msi-controller@1820000 domain created
    [    0.001715] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.001757] EFI services will not be available.
    [    0.001864] smp: Bringing up secondary CPUs ...
    [    0.010317] Detected PIPT I-cache on CPU1
    [    0.010344] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.010357] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.010398] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.010460] smp: Brought up 1 node, 2 CPUs
    [    0.010468] SMP: Total of 2 processors activated.
    [    0.010473] CPU features: detected: 32-bit EL0 Support
    [    0.010477] CPU features: detected: CRC32 instructions
    [    0.019917] CPU: All CPU(s) started at EL2
    [    0.019942] alternatives: patching kernel code
    [    0.020523] devtmpfs: initialized
    [    0.024580] KASLR disabled due to lack of seed
    [    0.024690] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.024702] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.030106] pinctrl core: initialized pinctrl subsystem
    [    0.030419] DMI not present or invalid.
    [    0.030770] NET: Registered protocol family 16
    [    0.031574] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
    [    0.031957] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.032513] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.032756] thermal_sys: Registered thermal governor 'step_wise'
    [    0.032759] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.033236] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.033287] ASID allocator initialised with 65536 entries
    [    0.049619] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.049627] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.049631] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.049635] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.050294] cryptd: max_cpu_qlen set to 1000
    [    0.052090] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.052553] vsys_3v3: supplied by evm_12v0
    [    0.052767] vsys_5v0: supplied by evm_12v0
    [    0.053333] iommu: Default domain type: Translated
    [    0.053482] SCSI subsystem initialized
    [    0.053757] mc: Linux media interface: v0.10
    [    0.053774] videodev: Linux video capture interface: v2.00
    [    0.053803] pps_core: LinuxPPS API ver. 1 registered
    [    0.053807] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.053814] PTP clock support registered
    [    0.053834] EDAC MC: Ver: 3.0.0
    [    0.054470] FPGA manager framework
    [    0.054512] Advanced Linux Sound Architecture Driver Initialized.
    [    0.054932] clocksource: Switched to clocksource arch_sys_counter
    [    0.055032] VFS: Disk quotas dquot_6.6.0
    [    0.055063] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.057618] NET: Registered protocol family 2
    [    0.058447] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.061841] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
    [    0.061944] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.062354] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [    0.062801] TCP: Hash tables configured (established 131072 bind 65536)
    [    0.062984] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.063147] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.063402] NET: Registered protocol family 1
    [    0.063740] RPC: Registered named UNIX socket transport module.
    [    0.063747] RPC: Registered udp transport module.
    [    0.063751] RPC: Registered tcp transport module.
    [    0.063753] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.063759] NET: Registered protocol family 44
    [    0.063771] PCI: CLS 0 bytes, default 64
    [    0.064157] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.066401] Initialise system trusted keyrings
    [    0.066501] workingset: timestamp_bits=46 max_order=22 bucket_order=0
    [    0.068214] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.068490] NFS: Registering the id_resolver key type
    [    0.068510] Key type id_resolver registered
    [    0.068514] Key type id_legacy registered
    [    0.068542] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.068547] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.068644] 9p: Installing v9fs 9p2000 file system support
    [    0.087857] Key type asymmetric registered
    [    0.087863] Asymmetric key parser 'x509' registered
    [    0.087889] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.087894] io scheduler mq-deadline registered
    [    0.087897] io scheduler kyber registered
    [    0.089398] pinctrl-single 4301c000.pinctrl: 101 pins, size 404
    [    0.089558] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.094485] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.101026] brd: module loaded
    [    0.104532] loop: module loaded
    [    0.105130] megasas: 07.714.04.00-rc1
    [    0.107283] tun: Universal TUN/TAP device driver, 1.6
    [    0.107616] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.107621] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.107648] sky2: driver version 1.30
    [    0.108304] VFIO - User Level meta-driver version: 0.3
    [    0.108903] i2c /dev entries driver
    [    0.109813] sdhci: Secure Digital Host Controller Interface driver
    [    0.109817] sdhci: Copyright(c) Pierre Ossman
    [    0.110028] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.110635] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.110857] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.111752] optee: probing for conduit method.
    [    0.111774] optee: revision 4.1 (012cdca4)
    [    0.128201] optee: dynamic shared memory is enabled
    [    0.128423] optee: initialized driver
    [    0.129808] NET: Registered protocol family 17
    [    0.129890] 9pnet: Installing 9P2000 support
    [    0.129936] Key type dns_resolver registered
    [    0.130035] Loading compiled-in X.509 certificates
    [    0.138307] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    [    0.149951] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=28, clk=14, ret=-19
    [    0.150022] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=28, clk=15, ret=-19
    [    0.150085] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=28, clk=16, ret=-19
    [    0.150148] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=28, clk=17, ret=-19
    [    0.151475] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=29, clk=14, ret=-19
    [    0.151571] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=29, clk=15, ret=-19
    [    0.151670] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=29, clk=16, ret=-19
    [    0.151766] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=29, clk=17, ret=-19
    [    0.161322] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=226, clk=16, ret=-19
    [    0.161402] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=226, clk=17, ret=-19
    [    0.161471] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=226, clk=18, ret=-19
    [    0.161540] ti-sci-clk 44083000.system-controller:clock-controller: recalc-rate failed for dev=226, clk=19, ret=-19
    [    0.166502] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.166992] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.167399] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.168194] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.168264] pca953x 3-0021: using no AI
    [    0.191488] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.191536] pca953x 3-0020: using no AI
    [    0.192292] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.192334] pca953x 3-0022: using AI
    [    0.193012] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.193950] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    0.194013] pca953x 4-0020: using no AI
    [    0.215271] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.216000] pca953x 5-0020: supply vcc not found, using dummy regulator
    [    0.216061] pca953x 5-0020: using no AI
    [    0.239269] omap_i2c 2050000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.240105] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    0.240202] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    0.240286] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    0.240449] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    0.244642] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.244664] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.244675] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.244686] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.246602] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
    [    1.246609] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.246615] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    1.246619] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    1.246651] pci 0000:00:00.0: [104c:b013] type 01 class 0x060400
    [    1.246753] pci 0000:00:00.0: supports D1
    [    1.246757] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    1.248298] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.249656] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.249669] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.249922] pcieport 0000:00:00.0: PME: Signaling with IRQ 58
    [    1.250709] ti-udma 311a0000.dma-controller: Number of rings: 48
    [    1.251567] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
    [    1.252459] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.252465] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.252469] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.253849] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.253856] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.253861] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.254084] omap8250 40a00000.serial: failed to get alias
    [    1.254686] printk: console [ttyS2] disabled
    [    1.254725] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 27, base_baud = 3000000) is a 8250
    [    2.970799] printk: console [ttyS2] enabled
    [    2.977103] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available
    [    2.984564] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.990662] cadence-qspi 47050000.spi: error -ENODEV: No Rx DMA available
    [    2.997747] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    3.006612] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    3.050955] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.059569] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    3.067871] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    3.080730] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    3.087937] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    3.094247] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    3.104595] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
    [    3.214373] mmc0: CQHCI version 5.10
    [    3.218210] gpio-mux mux-controller0: 2-way mux-controller registered
    [    3.225173] gpio-mux mux-controller1: 2-way mux-controller registered
    [    3.235074] vdd_mmc1: supplied by vsys_3v3
    [    3.240816] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    3.247633] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    3.254439] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    3.255496] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    3.268467] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    3.275684] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    3.285706] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
    [    3.297250] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    3.342935] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.351544] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    3.358411] mmc0: Command Queue Engine enabled
    [    3.359862] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    3.364251] mmc0: new HS400 MMC card at address 0001
    [    3.377096] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    3.382283] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    3.389153] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    3.399896] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    3.399914] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    3.405943] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    3.420772] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    3.428847] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    3.432471]  mmcblk0: p1
    [    3.440069] mmc1: CQHCI version 5.10
    [    3.445313] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
    [    3.452624] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
    [    3.460375] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present!
    [    3.468245] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    3.477231] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=226, clk=19, ret=-19
    [    3.487713] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=226, clk=18, ret=-19
    [    3.498159] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=226, clk=17, ret=-19
    [    3.508611] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=226, clk=16, ret=-19
    [    3.521941] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=29, clk=17, ret=-19
    [    3.532298] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=29, clk=16, ret=-19
    [    3.542653] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=29, clk=15, ret=-19
    [    3.553008] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=29, clk=14, ret=-19
    [    3.563755] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=28, clk=17, ret=-19
    [    3.574110] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=28, clk=16, ret=-19
    [    3.584465] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=28, clk=15, ret=-19
    [    3.594818] ti-sci-clk 44083000.system-controller:clock-controller: is_prepared failed for dev=28, clk=14, ret=-19
    [    3.605770] ALSA device list:
    [    3.608730]   No soundcards found.
    [    4.963103] sdhci-am654 4fb0000.mmc: Power on failed
    [    4.998708] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    5.718640] EXT4-fs (mmcblk0p1): recovery complete
    [    5.724688] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    5.732809] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    5.738877] devtmpfs: mounted
    [    5.742558] Freeing unused kernel memory: 1856K
    [    5.747198] Run /sbin/init as init process
    [    5.804987] systemd[1]: System time before build time, advancing clock.
    [    5.829494] NET: Registered protocol family 10
    [    5.834481] Segment Routing with IPv6
    [    5.849756] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -)
    [    5.871590] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    5.907303] systemd[1]: Set hostname to <j721s2-evm>.
    [    6.033226] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
    [    6.053293] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file a .
    [    6.110467] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.118995] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    6.139087] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.146568] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.167018] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.174318] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    6.195171] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    6.219080] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    6.243076] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    6.263000] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    6.282986] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    6.302991] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    6.333307] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    6.355093] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    6.378034] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    6.399187] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    6.424938] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    6.433343] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    6.455318] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    6.475325] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    6.499256] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    6.519141] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    6.541547] systemd[1]: Mounting Huge Pages File System...
    [    6.565642] systemd[1]: Mounting POSIX Message Queue File System...
    [    6.589543] systemd[1]: Mounting Kernel Debug File System...
    [    6.615835] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    6.633814] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    6.663815] systemd[1]: Starting Start psplash boot splash screen...
    [    6.690099] systemd[1]: Starting RPC Bind...
    [    6.703163] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    6.715736] systemd[1]: Starting Journal Service...
    [    6.740086] systemd[1]: Starting Load Kernel Modules...
    [    6.756096] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.769490] cryptodev: loading out-of-tree module taints kernel.
    [    6.772622] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    6.784419] systemd[1]: Starting udev Coldplug all Devices...
             Starting udev Coldplug all Devices...[    6.792344] cryptodev: driver 1.10 loaded.
    [    6.814527] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    6.835501] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    7.061900] systemd-journald[171]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
    [    7.179750] random: systemd: uninitialized urandom read (16 bytes read)
             Starting Create Static Device Nodes in /dev    7.192221] random: systemd-journal: uninitialized urandom read (16 bytes read)
    m...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    7.247458] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [    7.844580] random: crng init done
    [    7.848167] random: 70 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    7.901937] CAN device driver interface
    [    7.919563] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* failed to find dsi host
    [    7.976893] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a6000000
    [    8.134704] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Started Rebuild Dynamic Linker Cache.
    [    8.181241] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
             Starting Update is Completed...
    [  OK  ] Started Update is Completed.
    [    8.264878] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [    8.273420] PVR_K:  193: Read BVNC 36.53.104.796 from HW device registers
    [    8.280313] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [    8.309569] m_can_platform 26a1000.can: m_can device registered (irq=41, version=32)
    [    8.351394] remoteproc remoteproc0: 64800000.dsp is available
    [    8.361703] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [    8.379419] m_can_platform 40568000.can: m_can device registered (irq=21, version=32)
    [    8.399395] m_can_platform 2731000.can: m_can device registered (irq=37, version=32)
    [    8.419490] m_can_platform 2751000.can: m_can device registered (irq=39, version=32)
    [    8.456204] platform 41000000.r5f: configured R5F for IPC-only mode
    [    8.465471] PVR_K:  193: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    8.511893] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a7000000
    [    8.515762] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.535821] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [    8.541991] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 1
    [    8.554794] remoteproc remoteproc0: powering up 64800000.dsp
    [    8.560539] remoteproc remoteproc0: Booting fw image j721s2-c71_0-fw, size 10488888
    [    8.574747] remoteproc remoteproc0: unsupported resource 65538
    [    8.581235] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa6e00000
    [    8.596798]  remoteproc0#vdev0buffer: assigned reserved memory node c71-dma-memory@a6000000
    [    8.605603] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.614270] remoteproc remoteproc2: 65800000.dsp is available
    [    8.619308] remoteproc remoteproc1: 41000000.r5f is available
    [    8.620109]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    8.625800] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.631831] remoteproc remoteproc0: remote processor 64800000.dsp is now up
    [    8.654126] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.679033] remoteproc remoteproc1: attaching to 41000000.r5f
    [    8.694217] remoteproc remoteproc2: powering up 65800000.dsp
    [    8.699924] remoteproc remoteproc2: Booting fw image j721s2-c71_1-fw, size 10488888
    [    8.711025] remoteproc remoteproc2: unsupported resource 65538
    [    8.717397] k3-dsp-rproc 65800000.dsp: booting DSP core using boot addr = 0xa7e00000
    [    8.727250]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a7000000
    [    8.736026] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.744016]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [    8.747739] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.750130] remoteproc remoteproc2: remote processor 65800000.dsp is now up
    [    8.762022] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    8.780500] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    8.849914]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.877101] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    8.889196] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.899097] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    8.908431]  remoteproc1#vdev0buffer: registered virtio2 (type 7)
    [    8.915006] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    8.923077] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.993384] platform 41400000.r5f: configured R5F for IPC-only mode
    [    9.045719] platform 41400000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [    9.112276] remoteproc remoteproc3: 41400000.r5f is available
    [    9.155011] remoteproc remoteproc3: attaching to 41400000.r5f
    [    9.198462] platform 41400000.r5f: R5F core initialized in IPC-only mode
    [    9.211743] remoteproc remoteproc3: remote processor 41400000.r5f is now attached
    [    9.240845] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    9.259220] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.301409] remoteproc remoteproc4: 5c00000.r5f is available
    [    9.338902] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    9.345645] remoteproc remoteproc4: powering up 5c00000.r5f
    [    9.352453] remoteproc remoteproc4: Booting fw image j721s2-main-r5f0_0-fw, size 86924
    [    9.365093]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.376697] usbcore: registered new interface driver usbfs
    [    9.382755] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    9.388415]  remoteproc4#vdev0buffer: registered virtio3 (type 7)
    [    9.388421] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [    9.397811] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.397934] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    9.404036] usbcore: registered new interface driver hub
    [    9.404287] usbcore: registered new device driver usb
    [    9.405050] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.405959] remoteproc remoteproc5: 5d00000.r5f is available
    [    9.407366] remoteproc remoteproc5: powering up 5d00000.r5f
    [    9.407375] remoteproc remoteproc5: Booting fw image j721s2-main-r5f0_1-fw, size 86924
    [    9.408690]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.409286] virtio_rpmsg_bus virtio4: rpmsg host is online
    [    9.409318]  remoteproc5#vdev0buffer: registered virtio4 (type 7)
    [    9.409322] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [    9.409447] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [    9.412019] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [    9.421692] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.421849] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [    9.437603] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    9.440142] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [    9.440927] remoteproc remoteproc6: 5e00000.r5f is available
    [    9.442356] remoteproc remoteproc6: powering up 5e00000.r5f
    [    9.442365] remoteproc remoteproc6: Booting fw image j721s2-main-r5f1_0-fw, size 86924
    [    9.443486] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    9.444567]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [    9.444965] virtio_rpmsg_bus virtio5: rpmsg host is online
    [    9.444996]  remoteproc6#vdev0buffer: registered virtio5 (type 7)
    [    9.444999] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [    9.445395] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [    9.445978] remoteproc remoteproc7: 5f00000.r5f is available
    [    9.447326] remoteproc remoteproc7: powering up 5f00000.r5f
    [    9.447336] remoteproc remoteproc7: Booting fw image j721s2-main-r5f1_1-fw, size 86924
    [    9.448416]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [    9.448810] virtio_rpmsg_bus virtio6: rpmsg host is online
    [    9.448842]  remoteproc7#vdev0buffer: registered virtio6 (type 7)
    [    9.448846] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [    9.462082] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.462197] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [    9.462264] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.462321] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Reached target Hardware activated USB gadget.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [   10.404295] Bluetooth: Core ver 2.22
    [   10.411050] NET: Registered protocol family 31
    [   10.419205] Bluetooth: HCI device and connection manager initialized
    [   10.432074] Bluetooth: HCI socket layer initialized
    [   10.441682] Bluetooth: L2CAP socket layer initialized
    [   10.455008] Bluetooth: SCO socket layer initialized
    [   10.622646] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   10.703009] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            tar
            which
            zeromq
    [   12.771951] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    [   12.780844] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
             Starting Hostname Service...
    [  OK  ] Started Hostname Service.
             Starting DEMO...
    [   14.429383] PVR_K:  792: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   14.456852] PVR_K:  792: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [   15.806424] PVR_K:(Error):   144: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358]
     _____                    _____           _         _
                  |___|                    |___|
    Arago Project j721s2-evm ttyS2
    Arago 2021.09 j721s2-evm ttyS2
    j721s2-evm login: root
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~# lsusb
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~# [   26.420717] Initializing XFRM netlink socket
    [   26.939716] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [   26.954713] Bridge firewalling registered
    [   27.386869] process 'docker/tmp/qemu-check025927761/check' started with executable stack
    Diwakar
  • Hi Diwakar
    This doesn't solve the problem
    1. Why is my mmcblk1 eMMC?
    2. What is the difference between the copy you make after booting and the copy you make directly using the SD card? SD card startup is always OK, this is not the cause of the problem!
    3. Can you share the logs from power on to Starting kernel...? I can’t tell from the log you posted what startup method you used to start.
    Looking forward to expert help, this problem has been around for a long time
    BR
  • Hi Expert,
    eMMC boot0 startup is always stuck here. It is ok when the same rootfs is used for SD card.
    What should we do? Looking forward to reply.
    Barry
  • Hi Barry
    can you follow the suggested changes in one of the older thread for this issue
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1313818/tda4vm-q1-tda4vm-q1-emmc-boot-mmcblk0-randomly-occurred-that-sd-card-mmcblk1-occupied-unexpectedly/4993732#4993732
    Diwakar
  • Can you share your environment variable settings?
    Can anyone help us solve the stuck startup problem?
  • Hi Barry
    Have you tried above suggestions ?
    Diwakar
  • Hi
    root@j7-evm:~# mount /dev/mmcblk1p2 sd
    root@j7-evm:~#
    root@j7-evm:~# sync
    root@j7-evm:~# mount /dev/mmcblk0p1 emmc
    root@j7-evm:~#
    root@j7-evm:~# sync
    Are there any experts who can help us? Thanks
    BR
  • Hi
    Why is this the reason why the startup is stuck?
    Why does mmcblk0 mean emmc is still stuck?
    BR
  • HI Barry
    Please have a look at the logs and the env.
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 23:01:15 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E7
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    Trying to boot from MMC1
    init_env from device 17 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 22:56:45, Mar  3 2023
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Fri Mar  3 22:59:24 UTC 2023 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g62a9e51344 (Mar 03 2023 - 22:59:37 +0000)
    SoC:   J721E SR1.0 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from FAT... MMC: no card present
    mmc_init: -123, time 2002
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: sierra probed
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    I/TC:
    SoC:   J721E SR1.0 GP
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    => setenv mmcdev 0
    => setenv bootpart 0
    => setenv args_mmc "run finduuid;setenv bootargs console=ttyS2,115200n8  root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait"
    => printenv
    addr_fit=0x90000000
    arch=arm
    args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 ${mtdparts}
    args_mmc=run finduuid;setenv bootargs console=ttyS2,115200n8  root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait
    args_ufs=setenv devtype scsi;setenv bootpart 1:1;run ufs_finduuid;setenv bootargs console = ${console} ${optargs}root=PARTUUID=${uuid} rw rootfstype=${scsirootfstype};setenv devtype scsi;setenv bootpart 1:1
    baudrate=115200
    board=j721e
    board_name=J721EX-PM2-SOM
    board_rev=E7
    board_serial=0177
    board_software_revision=01
    boot=mmc
    boot_fdt=try
    boot_fit=0
    boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init;run boot_rprocs_mmc;fi;
    boot_rprocs_mmc=env set rproc_id;env set rproc_fw;env set secure_suffix;if test ${boot_fit} -eq 1; then env set secure_suffix -sec;fi;for i in ${rproc_fw_binaries}; do if test -z "${rproc_id}" ; then env set rpe
    bootcmd=run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern
    bootdelay=2
    bootdir=/boot
    bootenvfile=uEnv.txt
    bootm_size=0x10000000
    bootpart=0
    bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
    cpu=armv8
    default_device_tree=k3-j721e-common-proc-board.dtb
    dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1;rootfs part 0 1 mmcpart 0;tiboot3.bin.raw raw 0x0 0x400 mmcpart 1;tispl.bin.raw raw 0x400 0x1000 mmcpart 1;u-boot.img.raw raw 0x1400 0x2000 mmcpart 1;u-env.raw1
    dfu_alt_info_mmc=boot part 1 1;rootfs part 1 2;tiboot3.bin fat 1 1;tispl.bin fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1;sysfw.itb fat 1 1
    dfu_alt_info_ospi=tiboot3.bin raw 0x0 0x080000;tispl.bin raw 0x080000 0x200000;u-boot.img raw 0x280000 0x400000;u-boot-env raw 0x680000 0x020000;sysfw.itb raw 0x6c0000 0x100000;rootfs raw 0x800000 0x3800000
    dfu_alt_info_ram=tispl.bin ram 0x80080000 0x200000;u-boot.img ram 0x81000000 0x400000
    dorprocboot=0
    dtboaddr=0x89000000
    envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootscript; then run bootscript;else if run loadbootenv; then echo Loaded env from ${bootenvfile};run importbooten;
    eth1addr=70:ff:76:1d:91:6c
    eth2addr=70:ff:76:1d:91:6d
    eth3addr=70:ff:76:1d:91:6e
    eth4addr=70:ff:76:1d:91:6f
    ethaddr=78:db:2f:e0:81:81
    fdt_addr_r=0x88000000
    fdtaddr=0x88000000
    fdtcontroladdr=fdeaf950
    fdtoverlay_addr_r=0x80200000
    findfdt=setenv name_fdt ${default_device_tree};if test $board_name = J721EX-PM1-SOM; then setenv name_fdt k3-j721e-proc-board-tps65917.dtb; fi;if test $board_name = j721e; then setenv name_fdt k3-j721e-common-p}
    finduuid=part uuid ${boot} ${bootpart} uuid
    get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}
    get_fdt_ufs=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
    get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}
    get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
    get_kern_ufs=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
    get_overlay_mmc=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
    get_overlay_ufs=fdt address ${fdtaddr};fdt resize 0x100000;for overlay in $name_overlays;do;load scsi ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr};done;
    get_overlaystring=for overlay in $name_overlays;do;setenv overlaystring ${overlaystring}'#'${overlay};done;
    importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
    init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17;gpio clear gpio@22_16
    init_mmc=run args_all args_mmc
    init_ufs=ufs init; scsi scan; run args_ufs
    kernel_addr_r=0x82000000
    loadaddr=0x82000000
    loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
    loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr
    loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
    loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
    main_cpsw0_qsgmii_phyinit=if test $board_name = J721EX-PM1-SOM || test $board_name = J721EX-PM2-SOM || test $board_name = j721e; then do_main_cpsw0_qsgmii_phyinit=1; else do_main_cpsw0_qsgmii_phyinit=0; fi;if t;
    mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run mmc;
    mmcdev=0
    mmcloados=if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; e;
    mmcrootfstype=ext4 rootwait
    mtdids=nor0=47040000.spi.0,nor0=47034000.hyperbus
    mtdparts=mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.ti)
    name_fit=fitImage
    name_kern=Image
    partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
    pxefile_addr_r=0x80100000
    ramdisk_addr_r=0x88080000
    rd_spec=-
    rdaddr=0x88080000
    rproc_fw_binaries=2 /lib/firmware/j7-main-r5f0_0-fw 3 /lib/firmware/j7-main-r5f0_1-fw 4 /lib/firmware/j7-main-r5f1_0-fw 5 /lib/firmware/j7-main-r5f1_1-fw 6 /lib/firmware/j7-c66_0-fw 7 /lib/firmware/j7-c66_1-fw
    rproc_load_and_boot_one=if load mmc ${bootpart} $loadaddr ${rproc_fw}; then if rproc load ${rproc_id} ${loadaddr} ${filesize}; then rproc start ${rproc_id};fi;fi
    run_fit=bootm ${addr_fit}#${fdtfile}${overlaystring}
    run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
    scriptaddr=0x80000000
    scsirootfstype=ext4 rootwait
    serial#=0000000000000177
    soc=k3
    stderr=serial@2800000
    stdin=serial@2800000
    stdout=serial@2800000
    ufs_finduuid=part uuid scsi ${bootpart} uuid
    update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
    vendor=ti
    Environment size: 6625/131068 bytes
    => boot
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Failed to load 'boot.scr'
    ** Unrecognized filesystem type **
    19079680 bytes read in 113 ms (161 MiB/s)
    111990 bytes read in 8 ms (13.3 MiB/s)
       Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK
    Starting kernel ...
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.000000] Linux version 5.10.162-g76b3e88d56 (diwakar@diwakar-HP-Z2-Tower-G5-Workstation) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, G4
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
    [    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
    [    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3271300K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 398716K reserved, 524288K cma-reserved)
    [    0.000209] Console: colour dummy device 80x25
    [    0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000244] pid_max: default: 32768 minimum: 301
    [    0.000285] LSM: Security Framework initializing
    [    0.000327] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.000349] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.001183] rcu: Hierarchical SRCU implementation.
    [    0.001336] Platform MSI: msi-controller@1820000 domain created
    [    0.001514] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.001569] EFI services will not be available.
    [    0.001664] smp: Bringing up secondary CPUs ...
    [    0.010267] Detected PIPT I-cache on CPU1
    [    0.010291] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.010302] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.010335] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.010385] smp: Brought up 1 node, 2 CPUs
    [    0.010392] SMP: Total of 2 processors activated.
    [    0.010396] CPU features: detected: 32-bit EL0 Support
    [    0.010400] CPU features: detected: CRC32 instructions
    [    0.019196] CPU: All CPU(s) started at EL2
    [    0.019214] alternatives: patching kernel code
    [    0.019699] devtmpfs: initialized
    [    0.025215] KASLR disabled due to lack of seed
    [    0.025315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.025324] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.031546] pinctrl core: initialized pinctrl subsystem
    [    0.031836] DMI not present or invalid.
    [    0.032193] NET: Registered protocol family 16
    [    0.032843] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.032942] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.033081] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.033292] thermal_sys: Registered thermal governor 'step_wise'
    [    0.033294] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.033719] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.033754] ASID allocator initialised with 65536 entries
    [    0.053288] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.053296] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.053300] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.053303] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.053901] cryptd: max_cpu_qlen set to 1000
    [    0.055609] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.055880] vsys_3v3: supplied by evm_12v0
    [    0.056060] vsys_5v0: supplied by evm_12v0
    [    0.056624] iommu: Default domain type: Translated
    [    0.056756] SCSI subsystem initialized
    [    0.057061] mc: Linux media interface: v0.10
    [    0.057073] videodev: Linux video capture interface: v2.00
    [    0.057104] pps_core: LinuxPPS API ver. 1 registered
    [    0.057107] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.057113] PTP clock support registered
    [    0.057130] EDAC MC: Ver: 3.0.0
    [    0.057712] FPGA manager framework
    [    0.057751] Advanced Linux Sound Architecture Driver Initialized.
    [    0.058105] clocksource: Switched to clocksource arch_sys_counter
    [    0.058198] VFS: Disk quotas dquot_6.6.0
    [    0.058224] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.060705] NET: Registered protocol family 2
    [    0.060984] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.062008] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.062044] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.062194] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.062511] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.062620] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.062665] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.062766] NET: Registered protocol family 1
    [    0.063042] RPC: Registered named UNIX socket transport module.
    [    0.063046] RPC: Registered udp transport module.
    [    0.063049] RPC: Registered tcp transport module.
    [    0.063052] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.063057] NET: Registered protocol family 44
    [    0.063068] PCI: CLS 0 bytes, default 64
    [    0.063432] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.065451] Initialise system trusted keyrings
    [    0.065522] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.067054] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.067289] NFS: Registering the id_resolver key type
    [    0.067307] Key type id_resolver registered
    [    0.067310] Key type id_legacy registered
    [    0.067340] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.067344] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.067422] 9p: Installing v9fs 9p2000 file system support
    [    0.087294] Key type asymmetric registered
    [    0.087300] Asymmetric key parser 'x509' registered
    [    0.087320] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.087325] io scheduler mq-deadline registered
    [    0.087328] io scheduler kyber registered
    [    0.088980] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.089189] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.092423] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.092440] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.092604] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.092620] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.092725] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.092739] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.092847] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.092857] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.092982] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.092993] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.094832] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.096627] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.096910] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.097093] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.098681] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.103789] brd: module loaded
    [    0.107115] loop: module loaded
    [    0.107619] megasas: 07.714.04.00-rc1
    [    0.109682] tun: Universal TUN/TAP device driver, 1.6
    [    0.110000] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.110004] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.110030] sky2: driver version 1.30
    [    0.110702] VFIO - User Level meta-driver version: 0.3
    [    0.111222] i2c /dev entries driver
    [    0.112168] sdhci: Secure Digital Host Controller Interface driver
    [    0.112171] sdhci: Copyright(c) Pierre Ossman
    [    0.112390] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.113027] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.113241] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.114025] optee: probing for conduit method.
    [    0.114043] optee: revision 3.20 (8e74d476)
    [    0.130455] optee: dynamic shared memory is enabled
    [    0.130658] optee: initialized driver
    [    0.132062] NET: Registered protocol family 17
    [    0.132134] 9pnet: Installing 9P2000 support
    [    0.132179] Key type dns_resolver registered
    [    0.132271] Loading compiled-in X.509 certificates
    [    0.141124] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.194784] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    0.196593] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.196958] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.197651] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.198425] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.198479] pca953x 3-0020: using no AI
    [    0.222964] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.223011] pca953x 3-0022: using AI
    [    0.223630] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    0.223824] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    0.224016] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    0.224373] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.225216] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.229360] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [    0.230064] pca953x 6-0020: supply vcc not found, using dummy regulator
    [    0.230131] pca953x 6-0020: using no AI
    [    0.254780] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [    0.255245] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.255599] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.256224] pca953x 9-0020: supply vcc not found, using dummy regulator
    [    0.256278] pca953x 9-0020: using no AI
    [    0.278436] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [    0.279299] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.279402] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.279491] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    0.279652] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    0.292768] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    0.292789] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    0.292800] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    0.292811] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.302640] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    1.302663] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.302668] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    1.302680] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    1.302712] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    1.302718] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    1.302821] pci 0000:00:00.0: supports D1
    [    1.302825] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    1.302845] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    1.302850] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    1.304896] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.306736] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.306753] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
    [    1.306761] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.306990] pcieport 0000:00:00.0: PME: Signaling with IRQ 68
    [    1.307491] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.307508] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.307518] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.307528] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.310377] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    2.310382] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    2.310387] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.310391] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.310420] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.310426] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.310490] pci 0001:00:00.0: supports D1
    [    2.310493] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    2.312445] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.314281] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.314293] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    2.314499] pcieport 0001:00:00.0: PME: Signaling with IRQ 71
    [    2.314982] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    2.315000] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    2.315009] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    2.315020] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.318010] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    3.318016] pci_bus 0002:00: root bus resource [bus 00-ff]
    [    3.318021] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    3.318025] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    3.318055] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.318060] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.318138] pci 0002:00:00.0: supports D1
    [    3.318142] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    3.320089] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.321919] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.321931] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    3.322149] pcieport 0002:00:00.0: PME: Signaling with IRQ 74
    [    3.323104] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    3.323110] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    3.323114] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.324616] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    3.324622] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    3.324626] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.325104] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    3.325588] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
    [    5.377840] printk: console [ttyS2] enabled
    [    5.382509] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
    [    5.391462] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
    [    5.402163] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    5.412671] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    5.422827] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    5.433066] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    5.444244] scsi host0: ufshcd
    [    5.453241] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    5.466004] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    5.498108] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.502061] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    5.506642] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    5.525670] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    5.538476] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    5.545690] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    5.551989] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    5.562371] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    5.655135] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: cmd at tag 3 not pending in the device.
    [    5.664435] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    5.674122] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: cmd at tag 3 successfully cleared from DB.
    [    5.685124] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    5.685589] mmc0: CQHCI version 5.10
    [    5.694594] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    5.706267] cdns-ufshcd 4e84000.ufs: ufshcd_err_handler: exit: saved_err 0x4 saved_uic_err 0x40
    [    5.720972] vdd_mmc1: supplied by vsys_3v3
    [    5.725898] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    5.732560] pca953x 4-0020: using no AI
    [    5.750652] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    5.759121] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    5.765961] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    5.772787] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    5.779610] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    5.786412] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    5.797042] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    5.807665] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    5.822349] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
    [    5.827591] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    5.834622] Creating 8 MTD partitions on "47040000.spi.0":
    [    5.840097] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    5.845687] mmc0: Command Queue Engine enabled
    [    5.850129] mmc0: new HS200 MMC card at address 0001
    [    5.850474] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    5.855120] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: cmd pending in the device. tag = 5
    [    5.860778] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    5.869250] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    5.875011] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    5.883335] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    5.888609] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    5.899933] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    5.905955] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    5.910203] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    5.915778] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    5.921277] cdns-ufshcd 4e84000.ufs: ufshcd_err_handler: exit: saved_err 0x4 saved_uic_err 0x40
    [    5.927055] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
    [    5.935473] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    5.947081] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    5.958859]  mmcblk0: p1
    [    5.962236] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
    [    5.968528] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    6.014111] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    6.022554] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    6.030849] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    6.043651] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    6.050857] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    6.057120] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    6.067484] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    6.075662] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    6.079313] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: cmd pending in the device. tag = 6
    [    6.090490] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    6.102126] cdns-ufshcd 4e84000.ufs: ufshcd_err_handler: exit: saved_err 0x4 saved_uic_err 0x40
    [    6.119144] mmc1: CQHCI version 5.10
    [    6.123876] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    6.131129] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    6.139496] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    6.146844] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    6.154153] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    6.161467] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    6.169864] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    6.191034] ALSA device list:
    [    6.193993]   No soundcards found.
    [    6.248595] cdns-ufshcd 4e84000.ufs: ufshcd_try_to_abort_task: cmd pending in the device. tag = 16
    [    6.257654] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    6.269283] cdns-ufshcd 4e84000.ufs: ufshcd_err_handler: exit: saved_err 0x4 saved_uic_err 0x40
    [    6.278333] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    6.287063] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    7.642582] sdhci-am654 4fb0000.mmc: Power on failed
    [    7.678165] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    7.899965] EXT4-fs (mmcblk0p1): recovery complete
    [    7.905993] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    7.914107] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    7.921677] devtmpfs: mounted
    [    7.925453] Freeing unused kernel memory: 1856K
    [    7.930073] Run /sbin/init as init process
    [    7.987671] systemd[1]: System time before build time, advancing clock.
    [    8.012604] NET: Registered protocol family 10
    [    8.017527] Segment Routing with IPv6
    [    8.031293] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -)
    [    8.053123] systemd[1]: Detected architecture arm64.
    [    8.090432] systemd[1]: Set hostname to <j7-evm>.
    [    8.208904] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
    [    8.229456] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file ac.
    [    8.285467] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.293705] systemd[1]: Created slice system-getty.slice.
    [    8.314228] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.321593] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    8.342180] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.349444] systemd[1]: Created slice User and Session Slice.
    [    8.370312] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    8.394231] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    8.418218] systemd[1]: Reached target Paths.
    [    8.438169] systemd[1]: Reached target Remote File Systems.
    [    8.458160] systemd[1]: Reached target Slices.
    [    8.478163] systemd[1]: Reached target Swap.
    [    8.507424] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    8.530238] systemd[1]: Reached target RPC Port Mapper.
    [    8.552264] systemd[1]: Listening on Process Core Dump Socket.
    [    8.574317] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    8.599695] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    8.608027] systemd[1]: Listening on Journal Socket (/dev/log).
    [    8.630408] systemd[1]: Listening on Journal Socket.
    [    8.650452] systemd[1]: Listening on Network Service Netlink Socket.
    [    8.674389] systemd[1]: Listening on udev Control Socket.
    [    8.694299] systemd[1]: Listening on udev Kernel Socket.
    [    8.716360] systemd[1]: Mounting Huge Pages File System...
    [    8.740372] systemd[1]: Mounting POSIX Message Queue File System...
    [    8.768364] systemd[1]: Mounting Kernel Debug File System...
    [    8.790630] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    8.808526] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    8.839217] systemd[1]: Starting Start psplash boot splash screen...
    [    8.864902] systemd[1]: Starting RPC Bind...
    [    8.882313] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    8.894347] systemd[1]: Starting Journal Service...
    [    8.917737] systemd[1]: Starting Load Kernel Modules...
    [    8.931225] cryptodev: loading out-of-tree module taints kernel.
    [    8.939703] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   8.947598] cryptodev: driver 1.10 loaded.
    [0m...
    [    8.964927] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    8.973478] systemd[1]: Starting udev Coldplug all Devices...
    [    8.997167] systemd[1]: Started RPC Bind.
    [    9.014557] systemd[1]: Started Journal Service.
    [    9.235070] systemd-journald[185]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [    9.350723] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.378283] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.390435] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    9.700411] random: crng init done
    [    9.703959] random: 64 urandom warning(s) missed due to ratelimiting
    [    9.782566] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.794260] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.805969] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.821809] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.830869] CAN device driver interface
    [    9.840343] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.860307] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    9.874057] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.892849] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.910295] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.920071] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.939686] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.948093] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [    9.959966] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    9.968759] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [    9.984024] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.003523] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [   10.006733] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.020002] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [   10.027539] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.034808] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [   10.042480] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.050616] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [   10.057205] remoteproc remoteproc0: 4d80800000.dsp is available
    [   10.066735] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [   10.076131] remoteproc remoteproc0: powering up 4d80800000.dsp
    [   10.082007] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 144652
    [   10.092626] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200400
    [   10.104811] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [   10.112071]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [   10.120871] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   10.126429] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [   10.128759] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.133632]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   10.147160] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [   10.147207] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   10.164846] remoteproc remoteproc1: 4d81800000.dsp is available
    [   10.173869] remoteproc remoteproc1: powering up 4d81800000.dsp
    [   10.181631] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [   10.190502] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 144652
    [   10.200716] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200400
    [   10.210238] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [   10.210316] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   10.228972] remoteproc remoteproc2: 64800000.dsp is available
    [   10.236907]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [   10.248658] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   10.249353] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [   10.254984]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [   10.264186] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.264249] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   10.278169] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [   10.292928] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [   10.301491] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [   10.308774] platform 41000000.r5f: configured R5F for IPC-only mode
    [   10.316420] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.325660] PVR_K:  203: Read BVNC 22.104.208.318 from HW device registers
    [   10.335324] PVR_K:  203: RGX Device registered with BVNC 22.104.208.318
    [   10.346620] remoteproc remoteproc3: 41000000.r5f is available
    [   10.357046] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 1
    [   10.359053] remoteproc remoteproc2: powering up 64800000.dsp
    [   10.372363] remoteproc remoteproc3: attaching to 41000000.r5f
    [   10.373492] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10488888
    [   10.389399] remoteproc remoteproc2: unsupported resource 65538
    [   10.395855] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
    [   10.403368] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   10.410815]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [   10.422056] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   10.430340]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   10.436501] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    [   10.448876] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.456943] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   10.470199]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   10.498598] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.524723] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [   10.534058] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   10.546678]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   10.616549] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [   10.683966] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   10.784906] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.827760] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
    [   10.839769] m_can_platform 2701000.can: m_can device registered (irq=55, version=32)
    [   10.852679] m_can_platform 2721000.can: m_can device registered (irq=57, version=32)
    [   10.864703] remoteproc remoteproc4: 5c00000.r5f is available
    [   10.870884] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
    [   10.882054] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.926927] remoteproc remoteproc4: powering up 5c00000.r5f
    [   10.932590] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 650580
    [   10.951817] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   10.961527]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [   10.971896] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.977497]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   10.985685] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   11.079086] remoteproc remoteproc5: 5d00000.r5f is available
    [   11.156850] remoteproc remoteproc5: powering up 5d00000.r5f
    [   11.162463] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98828
    [   11.186235] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   11.192645]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   11.201587] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   11.207141]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   11.215039] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.215259] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   11.249458] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   11.298928] remoteproc remoteproc6: 5e00000.r5f is available
    [   11.349962] remoteproc remoteproc6: powering up 5e00000.r5f
    [   11.350577] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   11.355572] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98828
    [   11.377488]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [   11.388117] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   11.394814]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   11.396342] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.404095] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   11.479188] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [   11.506595] remoteproc remoteproc7: 5f00000.r5f is available
    [   11.524964] remoteproc remoteproc7: powering up 5f00000.r5f
    [   11.530578] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98828
    [   11.543909]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [   11.556406] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   11.576533]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   11.591542] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   11.601838] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.623706] usbcore: registered new interface driver usbfs
    [   11.657877] usbcore: registered new interface driver hub
    [   11.669704] remoteproc remoteproc8: b034000.pru is available
    [   11.672381] usbcore: registered new device driver usb
    [   11.690950] remoteproc remoteproc9: b004000.rtu is available
    [   11.699172] remoteproc remoteproc10: b00a000.txpru is available
    [   11.709266] remoteproc remoteproc11: b038000.pru is available
    [   11.721870] remoteproc remoteproc12: b006000.rtu is available
    [   11.729611] remoteproc remoteproc13: b00c000.txpru is available
    [   11.738259] remoteproc remoteproc14: b134000.pru is available
    [   11.747069] remoteproc remoteproc15: b104000.rtu is available
    [   11.755364] remoteproc remoteproc16: b10a000.txpru is available
    [   11.763923] remoteproc remoteproc17: b138000.pru is available
    [   11.775125] remoteproc remoteproc18: b106000.rtu is available
    [   11.782765] remoteproc remoteproc19: b10c000.txpru is available
    [   11.791007] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   11.800157] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.809684] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [   12.397085] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [   12.456036] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   12.463154] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   12.470133] virtio_rpmsg_bus virtio4: channel rpmsg-kdrv:ffffffff:1a already exist
    [   12.478023] virtio_rpmsg_bus virtio4: rpmsg_create_channel failed
    [   12.487436] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [   12.498376] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 18/Oct/2022 SHA:71138eee
    [   12.509203] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [   12.519868] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 18/Oct/2022 SHA:71138eee
    [   12.530519] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   12.537898] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   12.545052] virtio_rpmsg_bus virtio4: channel rpmsg_chrdev:ffffffff:15 already exist
    [   12.552827] virtio_rpmsg_bus virtio4: rpmsg_create_channel failed
    [   12.559981] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.565523] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.573457] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   12.582980] xhci-hcd xhci-hcd.2.auto: irq 677, io mem 0x06410000
    [   12.589169] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.597429] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.604642] usb usb1: Product: xHCI Host Controller
    [   12.609514] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   12.614384] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
    [   12.616123] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   12.626786] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
    [   12.628310] hub 1-0:1.0: USB hub found
    [   12.649742] hub 1-0:1.0: 1 port detected
    [   12.653958] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.654859] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   12.659469] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.668656] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
    [   12.687665] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   12.687724] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   12.695750] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.713801] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   12.722216] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.729451] usb usb2: Product: xHCI Host Controller
    [   12.734333] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
    [   12.740940] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   12.746146] hub 2-0:1.0: USB hub found
    [   12.749903] hub 2-0:1.0: 1 port detected
    [   12.774267] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
    [   12.797313] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
    [   12.805246] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
    [   12.818646] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
    [   12.878654] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
    [   12.918125] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.070392] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   13.078559] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.085686] usb 1-1: SerialNumber: 1E0108497885
    [   13.090738] hub 1-1:1.0: USB hub found
    [   13.094528] hub 1-1:1.0: 4 ports detected
    [   13.145639] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Save/Restore Sound Card State...
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Update pmic regis…fety feature on power rails...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
    [  OK  ] Started Save/Restore Sound Card State.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started startwlansta.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Reached target Sound Card.
             Starting Network Service...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Update pmic regist…safety feature on power rails.
    [   13.675149] Bluetooth: Core ver 2.22
    [   13.682175] NET: Registered protocol family 31
    [   13.686637] Bluetooth: HCI device and connection manager initialized
    [   13.706161] Bluetooth: HCI socket layer initialized
    [   13.711066] Bluetooth: L2CAP socket layer initialized
    [  OK  ] Started set host name as per compatible name.
    [   13.724025] Bluetooth: SCO socket layer initialized
    [  OK  ] Started startwlanap.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [   14.007604] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
    [  OK  ] Started Login Service.
    [  OK  ] Started rc.pvr.service.
             Starting weston.service...
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started DEMO.
    [   14.354363] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [   14.443575] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   14.458218] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   14.616378] PVR_K:  727: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [   14.648626] PVR_K:  727: Shader binary image 'rgx.sh.22.104.208.318' loaded
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7-evm ttyS2
    Arago 2021.09 j7-evm ttyS2
    j7-evm login:
    CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.8 | VT102 | Offline | ttyUSB0
    We followed the same steps as suggested to you
    Diwakar
