J721EXCPXEVM: J721S2XSOMXEVM: Boot Mode Control from Test Automation Header
Part Number: J721EXCPXEVM
Other Parts Discussed in Thread: TCA6424A
I would like to check if the boot-mode switches(mcu and sys) could be overridden by using the Test Automation Header?
As per the EVM Common Board Schematics, Section 55, it says bootmode control from test automation header,
But in the Section 56, the test automation header(J50) doesn't really seem to indicate the pins that could be used to manipulate boot modes(except for the TA_BM_IOEXP_RSTn).
Could you kindly confirm if the boot-modes can be set/manipulated using Test Automation Header(J50), if yes, how does J50 pinout look like.
Thank you.
Moses
