I was using CSL example for I2C test. This is an code from example3 for interrupt implementation. I changed two lines to make the code looping forever.
The code always works from emulator. With stand-along code from flash memory, it will only loop 2-3 times. Then I2C interrupt is stopped. Here is my source code. Please help.
Howard
* Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2008
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied.
/** @file csl_i2c_intc_example.c
* @brief I2C functional layer interrupt mode example source file
* \page page5 I2C EXAMPLE DOCUMENTATION
* \section I2C3 I2C EXAMPLE3 - INTERRUPT MODE TEST
* \subsection I2C3x TEST DESCRIPTION:
* This test verifies the operation of CSL I2C module in interrupt mode.
* During the test 64 bytes of data is written to EEPROM page and is read back
* using the CSL I2C APIs and I2C data callback functions. Interrupts are used
* to indicate the device ready status for a byte of data transmit or receive
* operation. CSL INTC module should be configured and I2C ISR should be
* registered before starting the data transfer. I2C callback functions which
* are called from the Interrupt Service Routine should be configured using
* I2C_setCallback() API. I2C module will be configured to master mode, 7-bit
* addressing and 10KHz bus frequency using I2C_config() API. I2C own address,
* data length, clock values, data command should be sent to the I2C config API.
* Data buffer 'gI2cWrBuf' is used to store the data to be written to EEPROM
* page. Address of the page to be written is stored in the first two bytes of
* the I2C write buffer. So the data length sent to the config API should be
* 66 bytes. after configuring the I2C module, interrupts for I2C transmit and
* No Acknowledgement error will be enabled and I2C data transfer will be
* triggered by setting the start bit. I2C will start generating the transmit
* interrupts. One byte of data will be copied to the I2C data transmit
* register in the I2C transmit callback function for each interrupt generated.
* After completing the transfer of 66 bytes I2C interrupts will be disabled.
* This completes the EEPROM page write.
* Reading the data from the EEPROM page will be done in two steps. In first
* step address of the EEPROM page to be read is written to the EEPROM.
* This operation will be same as data write operation except that the length
* of the data will be 2 bytes. After writing the EEPROM page address I2C will
* be configured for data read using I2C_config() API. I2C receive ready
* interrupt is enabled and I2C data reception is started by setting the start
* bit. I2C starts generating read interrupts. I2C read callback function will
* read one byte of data from I2C read register for each interrupt generated.
* Data read from the EEPROM page is stored in the buffer 'gI2cRdBuf'. After
* reading 64 bytes of data I2C interrupts will be disabled. This completes
* I2C read operation. After successful completion of the write and read
* operations data buffers are compared to verify the success of the operations.
* A small delay is required after each data operation to allow the device get
* ready for next data transfer operation.
* NOTE: TEST SHOULD NOT BE RUN BY SINGLE STEPPING AFTER ENABLING THE I2C
* INTERRUPTS. DOING SO WILL LEAD TO IMPROPER HANDLING OF THE INTERRUPTS
* AND TEST FAILURE.
* NOTE: THIS TEST HAS BEEN DEVELOPED TO WORK WITH CHIP VERSIONS C5505 AND
* C5515. MAKE SURE THAT PROPER CHIP VERSION MACRO IS DEFINED IN THE FILE
* c55xx_csl\inc\csl_general.h.
* \subsection I2C3y TEST PROCEDURE:
* @li Open the CCS and connect the target (C5505/C5515 EVM)
* @li Open the project "CSL_I2C_IntcExample_Out.pjt" and build it
* @li Load the program on to the target
* @li Set the PLL frequency to 12.288MHz
* @li Run the program and observe the test result
* @li Repeat the test at PLL frequencies 40, 60, 75 and 100MHz
* @li Repeat the test in Release mode
* \subsection I2C3z TEST RESULT:
* @li All the CSL APIs should return success
* @li Read and write buffer comparison should be successful.
* Revision History
* 16-Oct-2008 Created
#include <stdio.h>
#include "csl_i2c.h"
#include "csl_intc.h"
#include <csl_general.h>
#define CSL_I2C_TEST_PASSED (0)
#define CSL_I2C_TEST_FAILED (1)
#define CSL_I2C_DATA_SIZE (1)
#define CSL_EEPROM_ADDR_SIZE (1)
#define CSL_I2C_OWN_ADDR (0x2F)
#define CSL_I2C_BUS_FREQ (100)
#define CSL_I2C_EEPROM_ADDR (0x50)
#define CSL_I2C_CODEC_ADDR (0x40)
extern pI2cHandle i2cHandle;
Uint16 gI2cWrBuf[CSL_I2C_DATA_SIZE + CSL_EEPROM_ADDR_SIZE];
Uint16 gI2cRdBuf[CSL_I2C_DATA_SIZE];
CSL_I2cSetup i2cSetup;
CSL_I2cConfig i2cConfig;
CSL_I2cConfig i2cGetConfig;
CSL_IRQ_Config config;
CSL_I2cIsrAddr i2cIsrAddr;
volatile Uint16 dataLength;
Uint16 i2cTxCount;
Uint16 i2cRxCount;
Uint16 i2cErrInTx;
Uint16 stopDetected = FALSE;
CSL_Status CSL_i2cIntcTest(void);
extern void VECSTART(void);
interrupt void i2c_isr(void);
void CSL_i2cAlCallback(void);
void CSL_i2cNackCallback(void);
void CSL_i2cArdyCallback(void);
void CSL_i2cRxCallback(void);
void CSL_i2cTxCallback(void);
void CSL_i2cScdCallback(void);
void CSL_i2cAasCallback(void);
* \brief main function
* \param none
* \return none
/////INSTRUMENTATION FOR BATCH TESTING -- Part 1 --
///// Define PaSs_StAtE variable for catching errors as program executes.
///// Define PaSs flag for holding final pass/fail result at program completion.
volatile Int16 PaSs_StAtE = 0x0001; // Init to 1. Reset to 0 at any monitored execution error.
volatile Int16 PaSs = 0x0000; // Init to 0. Updated later with PaSs_StAtE when and if
///// program flow reaches expected exit point(s).
void main(void)
CSL_Status result;
printf("I2C INTERRUPT MODE TEST!\n\n");
result = CSL_i2cIntcTest();
if(result == CSL_I2C_TEST_PASSED)
printf("\nI2C INTERRUPT MODE TEST PASSED!!\n");
else
printf("\nI2C INTERRUPT MODE TEST FAILED!!\n");
/////INSTRUMENTATION FOR BATCH TESTING -- Part 2 --
///// Reseting PaSs_StAtE to 0 if error detected here.
PaSs_StAtE = 0x0000; // Was intialized to 1 at declaration.
/////INSTRUMENTATION FOR BATCH TESTING -- Part 3 --
///// At program exit, copy "PaSs_StAtE" into "PaSs".
PaSs = PaSs_StAtE; //If flow gets here, override PaSs' initial 0 with
///// // pass/fail value determined during program execution.
///// Note: Program should next exit to C$$EXIT and halt, where DSS, under
///// control of a host PC script, will read and record the PaSs' value.
* \brief Tests I2C interrupt mode operation
* \param none
* \return Test result
CSL_Status status;
CSL_Status result;
volatile Uint16 looper;
result = CSL_I2C_TEST_FAILED;
/* Assign the EEPROM page address */
gI2cWrBuf[0] = 0x0;
gI2cWrBuf[1] = 0x0;
/* Initialize data buffers */
for(looper = 0; looper < CSL_I2C_DATA_SIZE; looper++)
//gI2cWrBuf[looper + CSL_EEPROM_ADDR_SIZE] = looper;
gI2cRdBuf[looper] = 0x0000;
/* Disable CPU Interrupts */
IRQ_globalDisable();
/* Clear any pending interrupts */
IRQ_clearAll();
/* Disable all the interrupts */
IRQ_disableAll();
/* Set the interrupt vector start address */
IRQ_setVecs((Uint32)(&VECSTART));
/* Plug the I2C Isr into vector table */
config.funcAddr = &i2c_isr;
IRQ_plug(I2C_EVENT, config.funcAddr);
/* Enable I2C Interrupts */
IRQ_enable(I2C_EVENT);
/* Enable CPU Interrupts */
IRQ_globalEnable();
/* Initialize I2C module */
status = I2C_init(CSL_I2C0);
if(status != CSL_SOK)
printf("I2C Init Failed!!\n");
return(result);
/* Set the I2C call back function address */
i2cIsrAddr.alAddr = CSL_i2cAlCallback;
i2cIsrAddr.nackAddr = CSL_i2cNackCallback;
i2cIsrAddr.ardyAddr = CSL_i2cArdyCallback;
i2cIsrAddr.rrdyAddr = CSL_i2cRxCallback;
i2cIsrAddr.xrdyAddr = CSL_i2cTxCallback;
i2cIsrAddr.scdAddr = CSL_i2cScdCallback;
i2cIsrAddr.aasAddr = CSL_i2cAasCallback;
status = I2C_setCallback(&i2cIsrAddr);
printf("I2C Set callback Failed!!\n");
return(result);
TestLoop:
/* Configure I2C module for write */
i2cConfig.icoar = CSL_I2C_ICOAR_DEFVAL;
i2cConfig.icimr = CSL_I2C_ICIMR_DEFVAL;
i2cConfig.icclkl = CSL_I2C_ICCLK_DEFVAL;
i2cConfig.icclkh = CSL_I2C_ICCLK_DEFVAL;
i2cConfig.iccnt = 1; //CSL_I2C_DATA_SIZE + CSL_EEPROM_ADDR_SIZE;
i2cConfig.icsar = 0x40; //CSL_I2C_ICSAR_DEFVAL;
i2cConfig.icmdr = CSL_I2C_ICMDR_WRITE_DEFVAL;
i2cConfig.icemdr = CSL_I2C_ICEMDR_DEFVAL;
i2cConfig.icpsc = CSL_I2C_ICPSC_DEFVAL;
status = I2C_config(&i2cConfig);
printf("I2C Config Failed!!\n");
return(result);
/* Read the configured values using I2C_getConfig function */
status = I2C_getConfig(&i2cGetConfig);
printf("I2C Get Config Failed!!\n");
return(result);
/* Verify the read configuration values */
if((i2cConfig.icoar != i2cGetConfig.icoar) ||
(i2cConfig.icimr != i2cGetConfig.icimr) ||
(i2cConfig.icclkl != i2cGetConfig.icclkl) ||
(i2cConfig.icclkh != i2cGetConfig.icclkh) ||
(i2cConfig.iccnt != i2cGetConfig.iccnt) ||
(i2cConfig.icsar != i2cGetConfig.icsar) ||
(i2cConfig.icmdr != i2cGetConfig.icmdr) ||
(i2cConfig.icemdr != i2cGetConfig.icemdr) ||
(i2cConfig.icpsc != i2cGetConfig.icpsc))
printf("I2C get config not matching with config values!!\n");
return(result);
i2cErrInTx = FALSE;
i2cTxCount = 0;
dataLength = i2cConfig.iccnt;
/* Enable I2C NACK Error Event */
status = I2C_eventEnable(CSL_I2C_EVENT_NACK);
printf("I2C Event enable Failed!!\n");
return(result);
/* Enable I2C Tx Ready Event */
status = I2C_eventEnable(CSL_I2C_EVENT_ICXRDY);
return(result);
/* Set the start bit */
CSL_I2C_SETSTART();
/* Wait for the I2C transfer to complete */
while(dataLength != 0)
if(i2cErrInTx != FALSE)
printf("I2C NACK ERROR during TX\n");
return(result);
/* Disable I2C NACK Error Event */
status = I2C_eventDisable(CSL_I2C_EVENT_NACK);
printf("I2C Event disable Failed!!\n");
return(result);
/* Disable I2C Tx Ready Event */
status = I2C_eventDisable(CSL_I2C_EVENT_ICXRDY);
return(result);
printf("I2C Write compltete\n");
/* Give some delay */
for(looper = 0; looper < CSL_I2C_MAX_TIMEOUT; looper++){;}
/* Configure the I2C module for writing EEPROM page address for read operation */
i2cConfig.iccnt = 1; //CSL_EEPROM_ADDR_SIZE;
return(result);
return(result);
return(result);
i2cErrInTx = FALSE;
i2cTxCount = 0;
return(result);
return(result);
CSL_I2C_SETSTART();
return(result);
return(result);
return(result);
/* Configure I2C module for read */
i2cConfig.iccnt = 1; //CSL_I2C_DATA_SIZE;
i2cConfig.icmdr = CSL_I2C_ICMDR_READ_DEFVAL;
return(result);
return(result);
return(result);
i2cRxCount = 0;
/* Enable I2C Rx Ready Event */
status = I2C_eventEnable(CSL_I2C_EVENT_ICRRDY);
return(result);
/* Enable Stop condition detected Event */
status = I2C_eventEnable(CSL_I2C_EVENT_SCD);
return(result);
CSL_I2C_SETSTART();
if(stopDetected != FALSE)
break;
/* Disable I2C Rx Ready Event */
status = I2C_eventDisable(CSL_I2C_EVENT_ICRRDY);
return(result);
/* Disable I2C Stop condition detected Event */
status = I2C_eventDisable(CSL_I2C_EVENT_SCD);
return(result);
goto TestLoop;
IRQ_clearAll();
/* Disable all peripheral the interrupts */
IRQ_disableAll();
printf("I2C Read compltete\n");
result = CSL_I2C_TEST_PASSED;
return(result);
* \brief I2C Arbitration loss callback
* \param None
* \return None
* \brief I2C No acknowledgement callback
* \param None
* \return None
i2cErrInTx = TRUE;
* \brief I2C Access ready callback
* \param None
* \return None
* \brief I2C Receive ready callback
* \param None
* \return None
gI2cRdBuf[i2cRxCount++] = CSL_I2C_0_REGS->ICDRR;
dataLength--;
* \brief I2C Transmit ready callback
* \param None
* \return None
CSL_I2C_0_REGS->ICDXR = gI2cWrBuf[i2cTxCount++];
dataLength--;
* \brief I2C Stop condition detected callback
* \param None
* \return None
stopDetected = TRUE;
* \brief I2C Address as slave callback
* \param None
* \return None
* \brief I2C interrupt service routine
* \param None
* \return None
Uint16 eventId;
eventId = I2C_getEventId();
if(eventId != 0)
i2cHandle->I2C_isrDispatchTable[eventId - 1]();
