TDA4VM: Edge AI : Run examples.sh error
Part Number: TDA4VM
X64 Architecture
Running 4 Models - ['cl-tfl-mobilenet_v1_1.0_224', 'ss-tfl-deeplabv3_mnv2_ade20k_float', 'od-tfl-ssd_mobilenet_v2_300_float', 'od-tfl-ssdlite_mobiledet_dsp_320x320_coco']
Processing config file #0 : /home/abhilash/edgeai-tidl-tools/model-artifacts/cl-tfl-mobilenet_v1_1.0_224/tempDir/86_tidl_io_.qunat_stats_config.txt
 Freeing memory for user provided Net
 ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
#    0 . .. T     903.57  .... ..... ... .... .....
#    1 . .. T     960.47  .... ..... ... .... .....
#    0 . .. T     642.42  .... ..... ... .... .....
#    1 . .. T     597.44  .... ..... ... .... .....
#    0 . .. T     555.69  .... ..... ... .... .....
#    1 . .. T     842.92  .... ..... ... .... .....
Processing config file #0 : /home/abhilash/edgeai-tidl-tools/model-artifacts/od-tfl-ssd_mobilenet_v2_300_float/tempDir/264_tidl_io_.qunat_stats_config.txt
#    0 . ..
#    0 . .. T     590.45  .... ..... ... .... .....
#    1 . .. T     627.72  .... ..... ... .... .....
#    0 . .. T     695.93  .... ..... ... .... .....
#    1 . ..
Processing config file #0 : /home/abhilash/edgeai-tidl-tools/model-artifacts/od-tfl-ssdlite_mobiledet_dsp_320x320_coco/tempDir/321_tidl_io_.qunat_stats_config.txt
#    0 . .. T     619.84  .... ..... ... .... .....
#    0 . .. T    3495.13  .... ..... ... .... .....
#    1 . .. T     664.43  .... ..... ... .... .....
#    1 . .. T     604.25  .... ..... ... .... .....
------------------ Network Compiler Traces -----------------------------
successful Memory allocation
successful Workload Creation
Running_Model :  cl-tfl-mobilenet_v1_1.0_224
Completed_Model :     1, Name : cl-tfl-mobilenet_v1_1.0_224                       , Total time :    6258.77, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_cl-tfl-mobilenet_v1_1.0_224_ADE_val_00001801.jpg
 T    2981.58  .... ..... ... .... ..... T    4368.99  .... ..... ... .... .....
#    1 . ..
#    0 . .. T    1369.71  .... ..... ... .... .....
#    1 . .. T    1427.43  .... ..... ... .... .....
#    0 . .. T    4648.49  .... ..... ... .... .....
#    0 . .. T    1437.67  .... ..... ... .... .....
#    1 . .. T    1359.41  .... ..... ... .... ..... T    1948.35  .... ..... ... .... .....
#    1 . ..
#    0 . .. T    1392.91  .... ..... ... .... .....
#    1 . .. T    2017.41  .... ..... ... .... .....
#    0 . .. T    1559.30  .... ..... ... .... .....
#    0 . .. T    2165.24  .... ..... ... .... .....
#    1 . .. T    1494.44  .... ..... ... .... .....
#    1 . .. T    2172.60  .... ..... ... .... .....
 T    1475.41  .... ..... ... .... ..... Freeing memory for user provided Net
#    0 . ..
#    0 . .. T    1886.10  .... ..... ... .... .....
#    1 . .. T    1433.16  .... ..... ... .... .....
#    1 . .. T    1602.57  .... ..... ... .... ..... T    2236.32  .... ..... ... .... .....
Processing config file #0 : /home/abhilash/edgeai-tidl-tools/model-artifacts/ss-tfl-deeplabv3_mnv2_ade20k_float/tempDir/201_tidl_io_.qunat_stats_config.txt
#    0 . ..
#    0 . ..
Running_Model :  od-tfl-ssd_mobilenet_v2_300_float
Completed_Model :     3, Name : od-tfl-ssd_mobilenet_v2_300_float                 , Total time :   16900.14, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssd_mobilenet_v2_300_float_ADE_val_00001801.jpg
 T    1972.80  .... ..... ... .... .....
#    1 . .. T    1823.95  .... ..... ... .... .....
#    0 . .. T    1819.05  .... ..... ... .... .....
#    1 . .. T    2048.29  .... ..... ... .... .....
TIDL Meta PipeLine (Proto) File  : ../../../models/public/ssdlite_mobiledet_dsp_320x320_coco_20200519.prototxt
Number of OD backbone nodes = 112
Size of odBackboneNodeIds = 112
 Preliminary number of subgraphs:1 , 129 nodes delegated out of 129 nodes
TF Meta PipeLine (Proto) File  : ../../../models/public/ssdlite_mobiledet_dsp_320x320_coco_20200519.prototxt
num_classes : 91
y_scale : 10.000000
x_scale : 10.000000
w_scale : 5.000000
h_scale : 5.000000
num_keypoints : 5.000000
score_threshold : 0.600000
iou_threshold : 0.450000
max_detections_per_class : 200
max_total_detections : 100
      scales, height_stride, width_stride, height_offset, width_offset
   0.2000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.3500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.5000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.6500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.8000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.9500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
aspect_ratios
   1.0000000
   2.0000000
   0.5000000
   3.0000000
   0.3333000
Warning : Requested Output Data Convert Layer is not Added to the network, It is currently not Optimal
 ************** Frame index 1 : Running float import *************
**                ALL MODEL CHECK PASSED          **
The soft limit is 2048
The hard limit is 2048
MEM: Init ... !!!
MEM: Init ... Done !!!
 0.0s:  VX_ZONE_INIT:Enabled
 0.7s:  VX_ZONE_ERROR:Enabled
 0.8s:  VX_ZONE_WARNING:Enabled
 0.2468s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
 ************ Frame index 1 : Running float inference ****************
 ************ Frame index 2 : Running fixed point mode for calibration ****************
Empty prototxt path, running calibration
~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
 *****************   Calibration iteration number 0 started ************************
 *****************   Calibration iteration number 0 completed ************************
 *****************   Calibration iteration number 1 started ************************
 *****************   Calibration iteration number 1 completed ************************
 *****************   Calibration iteration number 2 started ************************
 *****************   Calibration iteration number 2 completed ************************
 *****************   Calibration iteration number 3 started ************************
 *****************   Calibration iteration number 3 completed ************************
 *****************   Calibration iteration number 4 started ************************
 *****************   Calibration iteration number 4 completed ************************
**                ALL MODEL CHECK
Running_Model :  od-tfl-ssdlite_mobiledet_dsp_320x320_coco
Completed_Model :     4, Name : od-tfl-ssdlite_mobiledet_dsp_320x320_coco         , Total time :   21115.02, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssdlite_mobiledet_dsp_320x320_coco_ADE_val_00001801.jpg
 T   12435.50  .... ..... ... .... .....
#    1 . .. T   10438.78  .... ..... ... .... .....
#    0 . .. T    4707.15  .... ..... ... .... .....
#    1 . .. T    5080.44  .... ..... ... .... .....
#    0 . .. T    4410.99  .... ..... ... .... .....
#    1 . .. T    4703.71  .... ..... ... .... .....
#    0 . .. T    4822.36  .... ..... ... .... .....
#    1 . .. T    4051.73  .... ..... ... .... .....
#    0 . .. T    4891.99  .... ..... ... .... .....
#    1 . .. T    4881.33  .... ..... ... .... .....
#    0 . .. T    4353.13  .... ..... ... .... .....
#    1 . .. T    5619.70  .... ..... ... .... .....
 Preliminary number of subgraphs:1 , 81 nodes delegated out of 81 nodes
INFORMATION: [TIDL_ResizeLayer] ResizeBilinear_TIDL_0 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] ResizeBilinear_TIDL_1 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] ResizeBilinear Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] decoder/ResizeBilinear Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] ResizeBilinear_1 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
**          5 WARNINGS          0 ERRORS          **
MEM: Init ... !!!
 0.8s:  VX_ZONE_ERROR:Enabled
 0.9s:  VX_ZONE_WARNING:Enabled
 0.3760s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
Running_Model :  ss-tfl-deeplabv3_mnv2_ade20k_float
Completed_Model :     2, Name : ss-tfl-deeplabv3_mnv2_ade20k_float                , Total time :   52779.48, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_ss-tfl-deeplabv3_mnv2_ade20k_float_ADE_val_00001801.jpg
run python3 tflrt_delegate.py
 ,  0  0.691726  warplane, military plane ,,  1  0.181373  missile ,,  2  0.109571  projectile, missile ,,  3  0.006352  cannon ,,  4  0.005370  aircraft carrier, carrier, flattop, attack aircraft carrier ,
Saving image to  ../../../output_images/
Completed_Model :     1, Name : cl-tfl-mobilenet_v1_1.0_224                       , Total time :     179.95, Offload Time :     179.94 , DDR RW MBs : 18446744073709.55, Output File : py_out_cl-tfl-mobilenet_v1_1.0_224_airshow.jpg
Completed_Model :     3, Name : od-tfl-ssd_mobilenet_v2_300_float                 , Total time :     465.09, Offload Time :     465.08 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssd_mobilenet_v2_300_float_ADE_val_00001801.jpg
Completed_Model :     4, Name : od-tfl-ssdlite_mobiledet_dsp_320x320_coco         , Total time :     823.78, Offload Time :     823.77 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssdlite_mobiledet_dsp_320x320_coco_ADE_val_00001801.jpg
Completed_Model :     2, Name : ss-tfl-deeplabv3_mnv2_ade20k_float                , Total time :    1930.89, Offload Time :    1930.88 , DDR RW MBs : 18446744073709.55, Output File : py_out_ss-tfl-deeplabv3_mnv2_ade20k_float_ADE_val_00001801.jpg
Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 3 Models - ['cl-ort-resnet18-v1', 'od-ort-ssd-lite_mobilenetv2_fpn', 'ss-ort-deeplabv3lite_mobilenetv2']
ssd is meta arch name
Number of OD backbone nodes = 159
Size of odBackboneNodeIds = 159
Preliminary subgraphs created = 1
Final number of subgraphs created are : 1, - Offloaded Nodes - 482, Total Nodes - 482
 Graph Domain TO version : 11ERROR : ONNX RT data type : 19 not supported by TIDL
**   All the Input Tensor Dimensions has to be greater then Zero
**   DIM Error - For Tensor 0, Dim 3 is 0
hello Champs
I am trying to runthe following command  and its getting stuck in the middle for along time Please find the following settings of my system , the log file is attached
source ./scripts/run_python_examples.sh
OS: Ubuntu 22.04
Edgeai_SDK : 9.2.00
Device : TDA4
cmake version : cmake version 3.25.0
