Other Parts Discussed in Thread: TDA4VL
BSP: SDK 9.2
SoC: TDA4VL
Dear supporter,
We are going to migrate SDK from 8.6 to 9.x on J721S2 (TDA4VL) by referring above information. Found out some portions on 9.x are gone. Should we ignore them while porting? Thanks.
- Wilson
Differences:
A. SPL
1. Reduction in the number of DDR Instances
- U-boot (following codes not found)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 90b7ca1150..51e50fa9c5 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -67,8 +67,8 @@ int dram_init_banksize(void) #ifdef CONFIG_PHYS_64BIT /* Bank 1 declares the memory available in the DDR high region */ gd->bd->bi_dram[1].start = CONFIG_SYS_SDRAM_BASE1; - gd->bd->bi_dram[1].size = 0x37fffffff; - gd->ram_size = 0x400000000; + gd->bd->bi_dram[1].size = 0x17fffffff; + gd->ram_size = 0x200000000; #endif
3. Disabling/removing the additional cores
diff --git a/arch/arm/dts/k3-j721s2-common-proc-board.dts b/arch/arm/dts/k3-j721s2-common-proc-board.dts index 5b7e33490f..ffd9c8568b 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-common-proc-board.dts @@ -32,8 +32,6 @@ remoteproc1 = &mcu_r5fss0_core1; remoteproc2 = &main_r5fss0_core0; remoteproc3 = &main_r5fss0_core1; - remoteproc4 = &main_r5fss1_core0; - remoteproc5 = &main_r5fss1_core1; remoteproc6 = &c71_0; remoteproc7 = &c71_1; };
- Linux (following codes not found)
