AM68A: status on compilation bug
Part Number: AM68A
Hey,
I wanted to check a status on a related bug: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1307531/am68a-compilation-not-work-properly-on-sdk-9-1
It should be fixed for 9.2 and here following ticket: jira.itg.ti.com/.../TIDL-3572
Does anybody have status on this bug and can confirm that it is resolved?
  • Hi Roman,
    Due to a holiday, half of our team is currently out of the office. Please expect a 1~2 day delay in response from the engineer tracking this issue.
    Thank you,
    Fabiana
    I have initiated loop back on above mentioned jira, will get back to you once i have update.
    In the mean time, is it possible for you to try the same experiment on 9.2 ?
    Pratik
  • Yes, I tried it and can say that array mismatch is the same:
    Sub Graph Stats 64.000000 250866.000000 630.000000
    *******  TIDL_subgraphRtInvoke done  ********
    Error margin: 0.1
    The arrays are 12.66% similar.
    Error margin: 0.01
    The arrays are 1.32% similar.
    Error margin: 0.001
    The arrays are 0.13% similar.
    Error margin: 0.0001
    The arrays are 0.01% similar.
    Error margin: 0.1
    The arrays are 11.33% similar.
    Error margin: 0.01
    The arrays are 1.05% similar.
    Error margin: 0.001
    The arrays are 0.12% similar.
    Error margin: 0.1
    The arrays are 8.90% similar.
    Error margin: 0.01
    The arrays are 0.89% similar.
    Error margin: 0.001
    The arrays are 0.11% similar.
    Error margin: 0.1
    The arrays are 8.96% similar.
    Error margin: 0.01
    Error margin: 0.001
    The arrays are 0.07% similar.
    Error margin: 0.1
    The arrays are 8.55% similar.
    Error margin: 0.01
    The arrays are 0.91% similar.
    Error margin: 0.001
    The arrays are 0.10% similar.
    The docker built with sdk 9.2 (github.com/.../rel_09_02) and I can observe different behaviour with DataOps: 0 and 1 (same bug as in 9.1)
  • I see,
    Error margin: 0.1
    Correlations percentage seems to be poor, data_ops to 0 (arm offload).
    Thanks for confirmation, will update the JIRA with the same and try to get back to you once i have an update on this.
