LP-AM263: Flashing QSPI on Linux machine
Part Number: LP-AM263
Hi all,
we are trying to make the flashing procedure work on a Linux machine using the instructions
https://software-dl.ti.com/mcu-plus-sdk/esd/AM263X/09_01_00_41/exports/docs/api_guide_am263x/GETTING_STARTED_FLASH.html#autotoc_md50
So far we have validated that the AM263x LP USB port enumerates as /dev/ttyACM0 and that on minicom (# minicom -w -D/dev/ttyACM0) we can see CCCC strings.
Bootmode switch is set to 0111.
After closing minicom, and starting up the command line python flashing utility, we see the following
gunter@Linux-005:~/ti/mcu_plus_sdk_am263x_09_01_00_41/tools/boot$ python3 uart_uniflash.py -p /dev/ttyACM0 --cfg=sbl_prebuilt/am263x-lp/default_sbl_qspi.cfg
Parsing config file ...
Parsing config file ... SUCCESS. Found 3 command(s) !!!
Executing command 1 of 3 ...
Found flash writer ... sending sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage
Sending sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage: 0%| | 0/41113 [00:00<?, ?bytes/s]send error: expected NAK, CRC, EOT or CAN; got b'e'
send error: expected NAK, CRC, EOT or CAN; got b'8'
send error: expected NAK, CRC, EOT or CAN; got b'6'
send error: expected NAK, CRC, EOT or CAN; got b'1'
send error: expected NAK, CRC, EOT or CAN; got b'b'
send error: expected NAK, CRC, EOT or CAN; got b'f'
send error: expected NAK, CRC, EOT or CAN; got b'4'
send error: error_count reached 10, aborting.
Sending sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage: 0%| | 2/41113 [00:00<00:21, 1897.88bytes/s]
[ERROR] XMODEM send failed, no response OR incorrect response from EVM OR cancelled by user,
Power cycle EVM and run this script again !!!
What could be the issue here?
--Gunter
  • Hi Gunter Schmer,
    Can you confirm if the /dev/ttyACM0 correct port ? It looks like there are prints on this terminal. Can you open the terminal and confirm if you are getting prints like these -
    https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1119575/faq-mcu-plus-sdk-am243x-how-to-debug-sbl_qspi-for-am263-and-am273-or-sbl_ospi-for-am243-or-an-application-which-is-booted-via-ospi-qspi-boot
    I hope this helps.
    Aakash
  • Hi Aakash,
    I can confirm that
    shows the expected CCCCCC... output
    Before running the python flashing utility, we are closing minicom though.
    --Gunter
  • Hi Aakash,
    I noticed that I have an HS-FS board, after reading this
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1233883/processor-sdk-am64x-am64x-sk-getting-started-process-in-sdk-not-working
    The board shows the following
    Latitude-E7450:~/ti/mcu_plus_sdk_am263x_09_01_00_41/tools/boot/socid_parser$ python3 uart_boot_socid.py -d am263x -f data.txt
    data.txt
    SoC ID HW Info:
    partID : 0x0
    partNumber : 0x2
    PGVer : 0x2
    ROMVer : 0x1
    MetalVer : 0x0
    SoC ID R5 ROM Info:
    r5 ROM Ver : 0x10000
    SoC ID HSM Pub ROM Info:
    devName : AM263X
    devType : HS_FS
    hsm ROM Ver : 0x10000
    Is there an FAQ to build and flash the HS-FS binaries?
    Thanks!
    --Gunter
  • Hi ,
    AM64x device is very different from AM263x. The same method may not work for you.
    Can you try doing the same immediately after the power on reset is asserted ?
    Aakash
  • Hi Aakash,
    the behavior is the same, right after power on reset, then running the command right away:
    Sending sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage: 0%| | 0/41113 [00:00<?, ?bytes/s]send error: expected NAK, CRC, EOT or CAN; got b'0'
    send error: expected NAK, CRC, EOT or CAN; got b'2'
    send error: expected NAK, CRC, EOT or CAN; got b'5'
    send error: expected NAK, CRC, EOT or CAN; got b'd'
    send error: expected NAK, CRC, EOT or CAN; got b'c'
    send error: expected NAK, CRC, EOT or CAN; got b'7'
    Sending sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage: 0%| | 2/41113 [00:00<00:21, 1931.52bytes/s]
    Can you do two things on your setup:
    [] Validate that you also have an HS-FS board with uart_boot_socid.py
    [] On a Linux machine, run the command above and paste your output.
    Does the HS-FS not require signed images to be flashed?? That is why I am asking for a precise FAQ for the HS-FS device/board.
    Trying to get to the bottom of this.
    --Gunter
    I am successfully able to flash on am263x-lp board using "python uart_uniflash.py -p COM17 --cfg=sbl_prebuilt/am263x-lp/default_sbl_qspi.cfg". I have attached logs below:
    C:\ti\mcu_plus_sdk\tools\boot>python uart_uniflash.py -p COM17 --cfg=sbl_prebuilt/am263x-lp/default_sbl_qspi.cfg
    Sent flashwriter sbl_prebuilt/am263x-lp/sbl_uart_uniflash.release.tiimage of size 42145 bytes in 5.91s.
    Executing command 2 of 3 ...
    Command arguments : --file=sbl_prebuilt/am263x-lp/sbl_qspi.release.tiimage --operation=flash --flash-offset=0x0
    Sent sbl_prebuilt/am263x-lp/sbl_qspi.release.tiimage of size 227181 bytes in 23.83s.
    [STATUS] SUCCESS !!!
    Executing command 3 of 3 ...
    Command arguments : --file=../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage --operation=flash --flash-offset=0x80000
    Sending ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage: 30870bytes [00:0Sending ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage: 30871bytes [00:0Sending ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage: 30872bytes [00:0Sending ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage: 30873bytes [00:0Sending ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage: 30874bytes [00:0        Sent ../../examples/hello_world/am263x-lp/r5fss0-0_nortos/ti-arm-clang/hello_world.release.appimage of size 30388 bytes in 5.73s.
    All commands from config file are executed !!!
    My board info:
    SoC ID HW Info:
    partID               : 0x0
    partNumber           : 0x2
    PGVer                : 0x3
    ROMVer               : 0x2
    MetalVer             : 0x1
    SoC ID R5 ROM Info:
    r5 ROM Ver           : 0x10100
    devName              : AM263X
    devType              : HS_FS
    hsm ROM Ver          : 0x10100
    Can you verify if your "sbl_uart_uniflash.release.tiimage and sbl_qspi.release.tiimage" are latest for am263x-lp?
    I am attaching "sbl_uart_uniflash.release.tiimage and sbl_qspi.release.tiimage" files used for flashing, do verify with these if you still get this issue.https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/sbl_5F00_uart_5F00_uniflash.release.tiimage
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/sbl_5F00_qspi.release.tiimage
    Gunjan
