TI Android GingerBread 2.3 DevKit 2.0 Compilation errors
I have followed the steps as mentioned in http://processors.wiki.ti.com/index.php/TI-Android-GingerBread-2.3-DevKit-2.0_DeveloperGuide and I am getting compilation errors.
I have tried each and every option what somebody had answered on the same problem but still I am getting the same error.\acd the error is:
Copying: out/target/common/obj/APPS/Browser_intermediates/noproguard.classes.dex
target Package: Browser (out/target/product/ti816xevm/obj/APPS/Browser_intermediates/package.apk)
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
aapt: warning: string 'pref_default_text_encoding_default' has no default translation in packages/apps/Browser/res; found: ja
aapt: warning: **** string 'pref_default_text_encoding_default' has no default or required localization for 'mdpi' in packages/apps/Browser/res
aapt: warning: **** string 'pref_default_text_encoding_default' has no default or required localization for 'nodpi' in packages/apps/Browser/res
 'out/target/common/obj/APPS/Browser_intermediates//classes.dex' as 'classes.dex'...
Notice file: packages/apps/Browser/NOTICE -- out/target/product/ti816xevm/obj/NOTICE_FILES/src//system/app/Browser.apk.txt
Install: out/target/product/ti816xevm/system/app/Browser.apk
target R.java/Manifest.java: Calculator (out/target/common/obj/APPS/Calculator_intermediates/src/R.stamp)
Compiling SDK Stubs: out/target/common/obj/JAVA_LIBRARIES/android_stubs_current_intermediates/classes.jar
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
target Prebuilt: Calculator (out/target/common/obj/JAVA_LIBRARIES/libarity_intermediates/javalib.jar)
target Java: Calculator (out/target/common/obj/APPS/Calculator_intermediates/classes)
packages/apps/Calculator/src/com/android/calculator2/CalculatorDisplay.java:19: cannot access android.content.Context
bad class file: android/content/Context.class(android/content:Context.class)
unable to access file: corrupted zip file
Please remove or make sure it appears in the correct subdirectory of the classpath.
import android.content.Context;
make: *** [out/target/common/obj/APPS/Calculator_intermediates/classes-full-debug.jar] Error 41
Please help me to solve this problem. I am struggling with it from last 4 days.
And I have downloaded the source from your release page.
JAVA version which I am using is :
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02, mixed mode)
