PROCESSOR-SDK-J784S4: How to obtain the A72 toolchain for building in Windows?
Part Number: PROCESSOR-SDK-J784S4
Hello, my question is concerning building the J784S4 PDK components under Windows (see https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-j784s4/09_02_00_05/exports/docs/pdk_j784s4_09_02_00_30/docs/userguide/j784s4/getting_started.html).
PDK_INSTALL_DIR/packages/ti/build/pdk_tools_path.mk contains the following:
# Configure toolchain paths
  # This section applies to Processor SDK RTOS release
  PDK_VERSION_STR=_j784s4_09_02_00_30
ifeq ($(PDK_VERSION),)
endif
  #Tool versions
  GCC_ARCH64_VERSION=9.2-2019.12
  GCC_ARCH64_BIN_PREFIX_STR=aarch64-none-elf
  CGT_VERSION=8.3.7
  CGT_C7X_VERSION=4.1.0.LTS
  CGT_ARMLLVM_VERSION=3.2.1.LTS
  CG_XML_VERSION=2.61.00
# Dependent toolchain paths variables
  export C6X_GEN_INSTALL_PATH      ?= $(TOOLS_INSTALL_PATH)/ti-cgt-c6000_$(CGT_VERSION)
  export C7X_GEN_INSTALL_PATH      ?= $(TOOLS_INSTALL_PATH)/ti-cgt-c7000_$(CGT_C7X_VERSION)
ifeq ($(OS),Windows_NT)
  #Paths for windows machine
  export TOOLCHAIN_PATH_GCC_ARCH64 ?= $(TOOLS_INSTALL_PATH)/gcc-arm-$(GCC_ARCH64_VERSION)-mingw-w64-i686-aarch64-none-elf
else
  #Paths for linux machine
  export TOOLCHAIN_PATH_GCC_ARCH64 ?= $(TOOLS_INSTALL_PATH)/gcc-arm-$(GCC_ARCH64_VERSION)-x86_64-aarch64-none-elf
endif
  export GCC_ARCH64_BIN_PREFIX        ?= $(GCC_ARCH64_BIN_PREFIX_STR)
  export TOOLCHAIN_PATH_A72           ?= $(TOOLCHAIN_PATH_GCC_ARCH64)
  export TOOLCHAIN_PATH_R5            ?= $(TOOLS_INSTALL_PATH)/ti-cgt-armllvm_$(CGT_ARMLLVM_VERSION)
  export PDK_INSTALL_PATH             ?= $(SDK_INSTALL_PATH)/pdk$(PDK_VERSION_STR)/packages
  export CG_XML_BIN_INSTALL_PATH      ?= $(SDK_INSTALL_PATH)/cg_xml_$(CG_XML_VERSION)/bin
  export FREERTOS_KERNEL_INSTALL_PATH ?= $(PDK_INSTALL_PATH)/ti/kernel/freertos/FreeRTOS-LTS
  export FREERTOS_LABS_INSTALL_PATH   ?= $(PDK_INSTALL_PATH)/ti/kernel/freertos/FreeRTOS-Labs
# Utilities directory. This is required only if the build machine is Windows.
# This should be CCS install directory as in c:/ti/ccsv<ver>/ccs/utils/cygwin
  export utils_PATH ?= c:/ti/ccs1120/ccs/utils/cygwin
endif
As shown in that file, for a Windows machine, TOOLCHAIN_PATH_GCC_ARCH64 will be $(TOOLS_INSTALL_PATH)/gcc-arm-9.2-2019.12-mingw-w64-i686-aarch64-none-elf. However, I cannot find this path anywhere on my machine (there is no folder named gcc-arm-9.2-2019.12-mingw-w64-i686-aarch64-none-elf). Can you please tell me where I am supposed to obtain the necessary contents for that path?
Thanks in advance!
Dave
