Part Number: AM62A7
Hi
We are developing through am62a7 custom board.
I flashed emmc through DFU, but a kernel panic error occurred as shown below.
Kernel panic errors occur in various ways.
If you look at the log, you will mostly see errors like the following
Internal error: Oops - Undefined instruction: 0000000002000000 [#1] PREEMPT SMP
Are there any suspicious points?
LOG:
U-Boot SPL 2023.04-dirty (May 20 2024 - 18:06:47 +0900)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
am62a_init: board_init_f done
SPL initial stack usage: 17040 bytes
am62a_init: spl_boot_device: devstat = 0x24b bootmedia = 0x9 bootindex = 0
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
NOTICE: BL31: Built : 09:34:15, Aug 24 2023
U-Boot SPL 2023.04-dirty (May 20 2024 - 18:06:39 +0900)
U-Boot 2023.04-dirty (May 20 2024 - 18:06:39 +0900)
SoC: AM62AX SR1.0 HS-FS
Model: Texas Instruments AM62A7 SK
DRAM: 2 GiB (effective 4 GiB)
Core: 58 devices, 28 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: Could not get PHY for ethernet@8000000port@1: addr 0
am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
Can't set block device
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20302336 bytes read in 134 ms (144.5 MiB/s)
57364 bytes read in 23 ms (2.4 MiB/s)
Working FDT set to 88000000
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.46-g247b2535b2 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Dec 6 17:54:04 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM62A7 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
[ 0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000997fffff]
[ 0.000000] node 0: [mem 0x0000000099800000-0x000000009b7fefff]
[ 0.000000] node 0: [mem 0x000000009b800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x00000000a2ffffff]
[ 0.000000] node 0: [mem 0x00000000a3000000-0x00000000adffffff]
[ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000bfffffff]
[ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 19 pages/cpu s37992 r8192 d31640 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032191
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=e24c44c0-44ea-304a-a929-2060435fb2c7 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 2807964K/4194300K available (12288K kernel code, 1266K rwdata, 4020K rodata, 2112K init, 438K bss, 796512K reserved, 589824K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008489] Console: colour dummy device 80x25
[ 0.013076] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023758] pid_max: default: 32768 minimum: 301
[ 0.028525] LSM: Security Framework initializing
[ 0.033349] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040928] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.050389] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.057824] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064113] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.071507] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.077879] rcu: Hierarchical SRCU implementation.
[ 0.082785] rcu: Max phase no-delay instances is 1000.
[ 0.088351] Platform MSI: msi-controller@1820000 domain created
[ 0.094611] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.104001] EFI services will not be available.
[ 0.108859] smp: Bringing up secondary CPUs ...
[ 0.114056] Detected VIPT I-cache on CPU1
[ 0.114140] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.114156] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[ 0.114199] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.114810] Detected VIPT I-cache on CPU2
[ 0.114881] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.114895] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
[ 0.114924] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.115476] Detected VIPT I-cache on CPU3
[ 0.115545] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.115559] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
[ 0.115587] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.115652] smp: Brought up 1 node, 4 CPUs
[ 0.195367] SMP: Total of 4 processors activated.
[ 0.200179] CPU features: detected: 32-bit EL0 Support
[ 0.205448] CPU features: detected: CRC32 instructions
[ 0.210752] CPU: All CPU(s) started at EL2
[ 0.214949] alternatives: applying system-wide alternatives
[ 0.222080] devtmpfs: initialized
[ 0.233587] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.243577] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.264142] pinctrl core: initialized pinctrl subsystem
[ 0.270011] DMI not present or invalid.
[ 0.274478] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.281422] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.288863] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.296942] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.305102] audit: initializing netlink subsys (disabled)
[ 0.310747] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[ 0.311135] thermal_sys: Registered thermal governor 'step_wise'
[ 0.318676] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.324855] cpuidle: using governor menu
[ 0.335685] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.342701] ASID allocator initialised with 65536 entries
[ 0.359247] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.370547] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[ 0.380008] KASLR disabled due to lack of seed
[ 0.391018] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.397981] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.404390] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.411330] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.417738] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.424677] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.431085] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.438024] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.445650] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
[ 0.455753] iommu: Default domain type: Translated
[ 0.460768] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.467425] SCSI subsystem initialized
[ 0.471542] usbcore: registered new interface driver usbfs
[ 0.477184] usbcore: registered new interface driver hub
[ 0.482640] usbcore: registered new device driver usb
[ 0.488192] pps_core: LinuxPPS API ver. 1 registered
[ 0.493270] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.502619] PTP clock support registered
[ 0.506748] EDAC MC: Ver: 3.0.0
[ 0.510732] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[ 0.517558] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[ 0.524361] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[ 0.531089] omap-mailbox 29030000.mailbox: no available mbox devices found
[ 0.538398] FPGA manager framework
[ 0.541944] Advanced Linux Sound Architecture Driver Initialized.
[ 0.549012] clocksource: Switched to clocksource arch_sys_counter
[ 0.555460] VFS: Disk quotas dquot_6.6.0
[ 0.559510] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.572300] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
[ 0.578642] NET: Registered PF_INET protocol family
[ 0.583827] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.594269] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.603079] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.611014] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.619320] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.627687] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.634550] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.641506] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.649037] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.655196] RPC: Registered named UNIX socket transport module.
[ 0.661268] RPC: Registered udp transport module.
[ 0.666077] RPC: Registered tcp transport module.
[ 0.670886] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677476] NET: Registered PF_XDP protocol family
[ 0.682385] PCI: CLS 0 bytes, default 64
[ 0.687013] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.696847] Initialise system trusted keyrings
[ 0.701595] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.712502] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.719010] NFS: Registering the id_resolver key type
[ 0.724225] Key type id_resolver registered
[ 0.728504] Key type id_legacy registered
[ 0.732655] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.739510] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.783705] Key type asymmetric registered
[ 0.787899] Asymmetric key parser 'x509' registered
[ 0.792925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.800611] io scheduler mq-deadline registered
[ 0.805254] io scheduler kyber registered
[ 0.812234] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.818673] pinctrl-single f4000.pinctrl: 151 pins, size 604
[ 0.825535] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.837364] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.852382] loop: module loaded
[ 0.856759] megasas: 07.719.03.00-rc1
[ 0.863328] tun: Universal TUN/TAP device driver, 1.6
[ 0.869203] thunder_xcv, ver 1.0
[ 0.872528] thunder_bgx, ver 1.0
[ 0.875858] nicpf, ver 1.0
[ 0.878774] e1000: Intel(R) PRO/1000 Network Driver
[ 0.883768] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.889680] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.894755] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.900842] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.906364] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.912092] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.918501] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.924666] sky2: driver version 1.30
[ 0.929077] VFIO - User Level meta-driver version: 0.3
[ 0.934997] usbcore: registered new interface driver usb-storage
[ 0.941652] i2c_dev: i2c /dev entries driver
[ 0.947369] sdhci: Secure Digital Host Controller Interface driver
[ 0.953722] sdhci: Copyright(c) Pierre Ossman
[ 0.958371] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.964853] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.971173] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.978095] usbcore: registered new interface driver usbhid
[ 0.983797] usbhid: USB HID core driver
[ 0.988534] optee: probing for conduit method.
[ 0.993113] optee: revision 4.0 (2a5b1d12)
[ 0.993374] optee: dynamic shared memory is enabled
[ 1.002907] optee: initialized driver
[ 1.008118] Initializing XFRM netlink socket
[ 1.012530] NET: Registered PF_PACKET protocol family
[ 1.017756] Key type dns_resolver registered
[ 1.022480] registered taskstats version 1
[ 1.026696] Loading compiled-in X.509 certificates
[ 1.039585] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
[ 1.080450] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.087462] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 1.094336] pca953x 1-0023: using AI
[ 1.121157] pca953x 1-0023: failed writing register
[ 1.126287] pca953x: probe of 1-0023 failed with error -121
[ 1.132549] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.139273] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.145216] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.153544] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.162748] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.171740] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
[ 1.181473] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.189555] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.200373] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.210196] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.219524] ti-udma 4e230000.dma-controller: Number of rings: 6
[ 1.225999] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[ 1.235199] printk: console [ttyS2] disabled
[ 1.239631] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
[ 1.248514] printk: console [ttyS2] enabled
[ 1.256971] printk: bootconsole [ns16550a0] disabled
[ 1.669035] spi-nand: probe of spi0.0 failed with error -110
[ 1.713043] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.721065] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
[ 1.727710] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.740542] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.747673] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.754026] pps pps0: new PPS source ptp0
[ 1.758284] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.768515] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.776892] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
[ 1.789249] mmc0: CQHCI version 5.10
[ 1.836567] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.938697] mmc0: Command Queue Engine enabled
[ 1.943187] mmc0: new HS200 MMC card at address 0001
[ 1.949075] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 1.956859] mmcblk0: p1
[ 1.960094] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 1.967752] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 1.973560] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[ 2.196031] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[ 2.202029] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[ 2.210235] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 2.216997] pca953x 1-0022: using AI
[ 2.220748] pca953x 1-0022: failed writing register
[ 2.225770] pca953x: probe of 1-0022 failed with error -121
[ 2.233213] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.241626] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.248983] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.262829] ALSA device list:
[ 2.265816] No soundcards found.
[ 2.315426] EXT4-fs (mmcblk0p1): recovery complete
[ 2.320770] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.329356] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 2.335831] devtmpfs: mounted
[ 2.339393] Freeing unused kernel memory: 2112K
[ 2.344050] Run /sbin/init as init process
[ 2.431945] systemd[1]: System time before build time, advancing clock.
[ 2.469830] NET: Registered PF_INET6 protocol family
[ 2.476092] Segment Routing with IPv6
[ 2.479821] In-situ OAM (IOAM) with IPv6
[ 2.502945] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 2.534985] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[ 2.610122] systemd[1]: Hostname set to <am62axx-evm>.
[ 2.714748] systemd-sysv-generator[152]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.740458] systemd-sysv-generator[152]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.765286] systemd-sysv-generator[152]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 2.790784] systemd-sysv-generator[152]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 3.110246] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.174579] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.247124] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.310870] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 3.335788] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 3.360227] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 3.386629] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.412560] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 3.437445] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 3.461694] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 3.477293] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.497360] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 3.513406] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 3.586978] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 3.613562] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 3.655173] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 3.678020] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 3.704764] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 3.727698] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.751887] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.772756] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.800243] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.823345] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.847641] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 3.905572] systemd[1]: Mounting Huge Pages File System...
[ 3.927257] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.958558] systemd[1]: Mounting Kernel Debug File System...
[ 3.973952] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.025711] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.053516] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.086941] systemd[1]: Starting Load Kernel Module configfs...
[ 4.110569] systemd[1]: Starting Load Kernel Module drm...
[ 4.130468] systemd[1]: Starting Load Kernel Module fuse...
[ 4.144342] fuse: init (API version 7.37)
[ 4.156669] systemd[1]: Starting Start psplash boot splash screen...
[ 4.192706] systemd[1]: Starting RPC Bind...
[ 4.217516] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 4.236647] systemd[1]: Starting Journal Service...
[ 4.260485] systemd[1]: Starting Load Kernel Modules...
[ 4.277649] cryptodev: loading out-of-tree module taints kernel.
[ 4.282130] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel co[ 4.292185] cryptodev: driver 1.12 loaded.
mmand line...
[ 4.353737] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.372453] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[ 4.383587] systemd[1]: Starting Coldplug All udev Devices...
[ 4.412088] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 4.425754] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 4.839374] systemd-journald[167]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create System Users...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /media/ram...
Mounting /var/volatile...
[ 5.111547] audit: type=1334 audit(1651167747.676:2): prog-id=5 op=LOAD
[ 5.118281] audit: type=1334 audit(1651167747.684:3): prog-id=6 op=LOAD
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Finished Create Volatile Files and Directories.
[ OK ] Started Rule-based Manager for Device Events and Files.
Starting Rebuild Journal Catalog...
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Finished Rebuild Dynamic Linker Cache.
[ OK ] Finished Rebuild Journal Catalog.
Starting Update is Completed...
[ OK ] Finished Update is Completed.
[ 5.751176] random: crng init done
[ OK ] Finished Load/Save Random Seed.
[ OK ] Started Network Time Synchronization.
[ 5.796345] Internal error: Oops - Undefined instruction: 0000000002000000 [#1] PREEMPT SMP
[ 5.804704] Modules linked in: snd_soc_tlv320aic3x syscopyarea sysfillrect sysimgblt fb_sys_fops optee_rng rng_core cryptodev(O) fuse drm drm_panel_orientation_quirks ipv6
[ 5.820018] CPU: 1 PID: 1 Comm: systemd Tainted: G O 6.1.46-g247b2535b2 #1
[ 5.828271] Hardware name: Texas Instruments AM62A7 SK (DT)
[ 5.833832] pstate: 40000005 (nZcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 5.840782] pc : mod_objcg_state+0x0/0x2c0
[ 5.844880] lr : kmem_cache_free+0xe8/0x27c
[ 5.849059] sp : ffff80000940b930
[ 5.852363] x29: ffff80000940b930 x28: ffff000800108000 x27: ffff000801d05a00
[ 5.859493] x26: 000003da000003df x25: ffff80000940bd60 x24: 0000000000000000
[ 5.866621] x23: 0000000040000060 x22: ffff000802345200 x21: fffffc002004a400
[ 5.873748] x20: ffff000801290000 x19: ffff000800ec8300 x18: 0000000000000000
[ 5.880877] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80000940baec
[ 5.888007] x14: 0000000000000000 x13: 0000000000000000 x12: 000000007ffff000
[ 5.895136] x11: 0000000000000002 x10: 0000000000000001 x9 : ffff80000940baec
[ 5.902263] x8 : 0000000000000c30 x7 : 000000000000001c x6 : 0000000000000000
[ 5.909392] x5 : 0000000000000001 x4 : 0000000044002000 x3 : 00000000fffffbb8
[ 5.916522] x2 : 0000000000000006 x1 : ffff800009345bc0 x0 : ffff000802345200
[ 5.923652] Call trace:
[ 5.926092] mod_objcg_state+0x0/0x2c0
[ 5.929839] __sk_destruct+0x138/0x224
[ 5.933590] sk_destruct+0x54/0x64
[ 5.936991] __sk_free+0x74/0x120
[ 5.940304] sock_wfree+0x94/0x250
[ 5.943703] unix_destruct_scm+0x78/0xd0
[ 5.947625] skb_release_head_state+0x2c/0xe0
[ 5.951979] kfree_skb_reason+0x30/0xb0
[ 5.955810] skb_free_datagram+0x18/0x24
[ 5.959732] __unix_dgram_recvmsg+0x18c/0x444
[ 5.964084] unix_dgram_recvmsg+0x40/0x4c
[ 5.968089] ____sys_recvmsg+0x8c/0x210
[ 5.971921] ___sys_recvmsg+0x80/0xf0
[ 5.975580] __sys_recvmsg+0x68/0xcc
[ 5.979152] __arm64_sys_recvmsg+0x24/0x30
[ 5.983243] invoke_syscall+0x48/0x114
[ 5.986990] el0_svc_common.constprop.0+0x44/0xfc
[ 5.991691] do_el0_svc+0x20/0x30
[ 5.995002] el0_svc+0x28/0xa0
[ 5.998059] el0t_64_sync_handler+0xbc/0x140
[ 6.002323] el0t_64_sync+0x18c/0x190
[ 6.005987] Code: a8c27bfd d50323bf d65f03c0 d503201f (d503233f)
[ 6.012071] ---[ end trace 0000000000000000 ]---
[ 6.026444] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 6.034107] SMP: stopping secondary CPUs
[ 6.038032] Kernel Offset: disabled
[ 6.041509] CPU features: 0x00000,00800084,0000420b
[ 6.046378] Memory Limit: none
[ 6.049425] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
