TDA4VM
Board model: SK-TDAVM (Board symbol :J721EXSKG01EVM, TDA4VM EDGE AI KIT)
SDK version: linux:ti-processor-sdk-linux-adas-j721e-evm-09_02_00_05-Linux-x86-Install.bin;
RTOS:ti-processor-sdk-rtos-j721e-evm-09_02_00_05.tar.gz
The user guide to use: https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/ETHFW_DEMOS.html,
note: The SDK internal documentation guide cannot be opened, other versions can be successfully opened, so refer to the documentation in the link.
According to the routine operation, the IP address cannot be found, and DHCP is using the company's server. If the ifconfig command is used, the IP address of core A can be displayed and the communication is normal. Using the ethfw routine, we cannot see the IP address of the R core, we are mainly trying to communicate properly with the lwIP of the R core.
Here is the Log running /opt/vision_apps/vision_apps_init.sh.
Please help answer, thank you!
[MCU2_0] 10.231373 s: CIO: Init ... Done !!! [MCU2_0] 10.231445 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 10.231483 s: CPU is running FreeRTOS [MCU2_0] 10.231483 s: CPU is running FreeRTOS [MCU2_0] 10.231507 s: APP: Init ... !!! [MCU2_0] 10.231507 s: APP: Init ... !!! [MCU2_0] 10.231527 s: SCICLIENT: Init ... !!! [MCU2_0] 10.231527 s: SCICLIENT: Init ... !!! [MCU2_0] 10.231729 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [MCU2_0] 10.231729 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [MCU2_0] 10.231775 s: SCICLIENT: DMSC FW revision 0x9 [MCU2_0] 10.231775 s: SCICLIENT: DMSC FW revision 0x9 [MCU2_0] 10.231801 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 10.231801 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 10.231831 s: SCICLIENT: Init ... Done !!! [MCU2_0] 10.231831 s: SCICLIENT: Init ... Done !!! [MCU2_0] 10.231856 s: UDMA: Init ... !!! [MCU2_0] 10.231856 s: UDMA: Init ... !!! [MCU2_0] 10.232838 s: UDMA: Init ... Done !!! [MCU2_0] 10.232838 s: UDMA: Init ... Done !!! [MCU2_0] 10.232898 s: MEM: Init ... !!! [MCU2_0] 10.232898 s: MEM: Init ... !!! [MCU2_0] 10.232933 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 15728640 bytes !!! [MCU2_0] 10.232933 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 15728640 bytes !!! [MCU2_0] 10.232993 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 10.232993 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 10.233042 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ d9f00000 of size 1048576 bytes !!! [MCU2_0] 10.233042 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ d9f00000 of size 1048576 bytes !!! [MCU2_0] 10.233087 s: MEM: Init ... Done !!! [MCU2_0] 10.233087 s: MEM: Init ... Done !!! [MCU2_0] 10.233110 s: IPC: Init ... !!! [MCU2_0] 10.233110 s: IPC: Init ... !!! [MCU2_0] 10.233156 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 10.233156 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 10.233207 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 10.233207 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 21.252429 s: IPC: HLOS is ready !!! [MCU2_0] 21.252429 s: IPC: HLOS is ready !!! [MCU2_0] 21.256761 s: IPC: Init ... Done !!! [MCU2_0] 21.256761 s: IPC: Init ... Done !!! [MCU2_0] 21.256824 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 21.256824 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 21.329144 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 21.329144 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 21.329287 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 21.329287 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 21.329584 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 21.329584 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 21.329643 s: ETHFW: Init ... !!! [MCU2_0] 21.329643 s: ETHFW: Init ... !!! [MCU2_0] 21.435727 s: ETHFW: Warning: Using 6 random MAC address(es) [MCU2_0] 21.435727 s: ETHFW: Warning: Using 6 random MAC address(es) [MCU2_0] 21.435856 s: ETHFW: Shared multicasts: [MCU2_0] 21.435856 s: ETHFW: Shared multicasts: [MCU2_0] 21.435911 s: ETHFW: 01:00:5e:00:00:01 [MCU2_0] 21.435911 s: ETHFW: 01:00:5e:00:00:01 [MCU2_0] 21.435947 s: ETHFW: 01:00:5e:00:00:fb [MCU2_0] 21.435947 s: ETHFW: 01:00:5e:00:00:fb [MCU2_0] 21.435980 s: ETHFW: 01:00:5e:00:00:fc [MCU2_0] 21.435980 s: ETHFW: 01:00:5e:00:00:fc [MCU2_0] 21.436009 s: ETHFW: 33:33:00:00:00:01 [MCU2_0] 21.436009 s: ETHFW: 33:33:00:00:00:01 [MCU2_0] 21.436040 s: ETHFW: 33:33:ff:1d:92:c2 [MCU2_0] 21.436040 s: ETHFW: 33:33:ff:1d:92:c2 [MCU2_0] 21.436069 s: ETHFW: 01:80:c2:00:00:00 [MCU2_0] 21.436069 s: ETHFW: 01:80:c2:00:00:00 [MCU2_0] 21.436099 s: ETHFW: 01:80:c2:00:00:03 [MCU2_0] 21.436199 s: ETHFW: 01:1b:19:00:00:00 [MCU2_0] 21.436242 s: ETHFW: CPSW recovery is not enabled [MCU2_0] 21.436427 s: EnetMcm: CPSW_9G on MAIN NAVSS [MCU2_0] 21.443466 s: Mdio_open: MDIO manual mode enabled [MCU2_0] 21.443466 s: Mdio_open: MDIO manual mode enabled [MCU2_0] 21.443534 s: [MCU2_0] 21.450371 s: CpswMacPort_setSgmiiInterface: MAC 2: SERDES PLL is not locked [MCU2_0] 21.450371 s: CpswMacPort_setSgmiiInterface: MAC 2: SERDES PLL is not locked [MCU2_0] 21.450436 s: : -9 [MCU2_0] 21.450467 s: CpswMacPort_setSgmiiInterface: [MCU2_0] 21.450467 s: CpswMacPort_setSgmiiInterface: [MCU2_0] 21.450499 s: : -1 [MCU2_0] 21.450527 s: Assertion @ Line: 2330 in src/mod/cpsw_macport.c: BFALSE [MCU2_0] 21.450527 s: Assertion @ Line: 2330 in src/mod/cpsw_macport.c: BFALSE [MCU2_1] 10.200945 s: CIO: Init ... Done !!! [MCU2_1] 10.200945 s: CIO: Init ... Done !!! [MCU2_1] 10.201014 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 10.201014 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 10.201051 s: CPU is running FreeRTOS [MCU2_1] 10.201051 s: CPU is running FreeRTOS [MCU2_1] 10.201074 s: APP: Init ... !!! [MCU2_1] 10.201074 s: APP: Init ... !!! [MCU2_1] 10.201091 s: SCICLIENT: Init ... !!! [MCU2_1] 10.201091 s: SCICLIENT: Init ... !!! [MCU2_1] 10.201290 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [MCU2_1] 10.201290 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [MCU2_1] 10.201333 s: SCICLIENT: DMSC FW revision 0x9 [MCU2_1] 10.201333 s: SCICLIENT: DMSC FW revision 0x9 [MCU2_1] 10.201358 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 10.201358 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 10.201383 s: SCICLIENT: Init ... Done !!! [MCU2_1] 10.201383 s: SCICLIENT: Init ... Done !!! [MCU2_1] 10.201405 s: UDMA: Init ... !!! [MCU2_1] 10.201405 s: UDMA: Init ... !!! [MCU2_1] 10.202550 s: UDMA: Init ... Done !!! [MCU2_1] 10.202550 s: UDMA: Init ... Done !!! [MCU2_1] 10.202608 s: MEM: Init ... !!! [MCU2_1] 10.202608 s: MEM: Init ... !!! [MCU2_1] 10.202643 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 10.202643 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 10.202701 s: MEM: Init ... Done !!! [MCU2_1] 10.202701 s: MEM: Init ... Done !!! [MCU2_1] 10.202721 s: IPC: Init ... !!! [MCU2_1] 10.202721 s: IPC: Init ... !!! [MCU2_1] 10.202775 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 10.202775 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 10.202818 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 10.202818 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 21.324723 s: IPC: HLOS is ready !!! [MCU2_1] 21.324723 s: IPC: HLOS is ready !!! [MCU2_1] 21.329042 s: IPC: Init ... Done !!! [MCU2_1] 21.329042 s: IPC: Init ... Done !!! [MCU2_1] 21.329101 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 21.329101 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 21.329142 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 21.329142 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 21.329172 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 21.329172 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 21.329544 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 21.329544 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 21.329607 s: FVID2: Init ... !!! [MCU2_1] 21.329607 s: FVID2: Init ... !!! [MCU2_1] 21.329669 s: FVID2: Init ... Done !!! [MCU2_0] 21.436126 s: ETHFW: Reserved multicasts: [MCU2_1] 21.329702 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 21.329726 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 21.329726 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 21.329983 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 21.329983 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 21.330016 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 21.330016 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 21.330144 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 21.330144 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 21.330170 s: VHWA: DOF Init ... !!! [MCU2_1] 21.330170 s: VHWA: DOF Init ... !!! [MCU2_1] 21.337696 s: VHWA: DOF Init ... Done !!! [MCU2_1] 21.337696 s: VHWA: DOF Init ... Done !!! [MCU2_1] 21.337765 s: VHWA: SDE Init ... !!! [MCU2_1] 21.337765 s: VHWA: SDE Init ... !!! [MCU2_1] 21.339967 s: VHWA: SDE Init ... Done !!! [MCU2_1] 21.339967 s: VHWA: SDE Init ... Done !!! [MCU2_1] 21.340024 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 21.340024 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 21.340066 s: VX_ZONE_INIT:Enabled [MCU2_1] 21.340066 s: VX_ZONE_INIT:Enabled [MCU2_1] 21.340091 s: VX_ZONE_ERROR:Enabled [MCU2_1] 21.340091 s: VX_ZONE_ERROR:Enabled [MCU2_1] 21.340112 s: VX_ZONE_WARNING:Enabled [MCU2_1] 21.340112 s: VX_ZONE_WARNING:Enabled [MCU2_1] 21.341701 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MCU2-1 [MCU2_1] 21.341701 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MCU2-1 [MCU2_1] 21.341882 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_SDE [MCU2_1] 21.341882 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_SDE [MCU2_1] 21.342031 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_DOF [MCU2_1] 21.342031 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_DOF [MCU2_1] 21.342080 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [MCU2_1] 21.342080 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [MCU2_1] 21.342111 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 21.342111 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 21.342358 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 21.342358 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 21.342392 s: UDMA Copy: Init ... !!! [MCU2_1] 21.342392 s: UDMA Copy: Init ... !!! [MCU2_1] 21.343857 s: UDMA Copy: Init ... Done !!! [MCU2_1] 21.343857 s: UDMA Copy: Init ... Done !!! [MCU2_1] 21.343922 s: APP: Init ... Done !!! [MCU2_1] 21.343922 s: APP: Init ... Done !!! [MCU2_1] 21.343951 s: APP: Run ... !!! [MCU2_1] 21.343951 s: APP: Run ... !!! [MCU2_1] 21.343972 s: IPC: Starting echo test ... [MCU2_1] 21.343972 s: IPC: Starting echo test ... [MCU2_1] 21.344186 s: APP: Run ... Done !!! [MCU2_1] 21.344186 s: APP: Run ... Done !!! [MCU2_1] 21.345102 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 21.345102 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 21.345189 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 21.345189 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 21.345256 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 21.345256 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 21.436157 s: ETHFW: 01:80:c2:00:00:0e [C6x_1 ] 10.269439 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 10.269450 s: CPU is running FreeRTOS [C6x_1 ] 10.269450 s: CPU is running FreeRTOS [C6x_1 ] 10.269458 s: APP: Init ... !!! [C6x_1 ] 10.269458 s: APP: Init ... !!! [C6x_1 ] 10.269466 s: SCICLIENT: Init ... !!! [C6x_1 ] 10.269466 s: SCICLIENT: Init ... !!! [C6x_1 ] 10.269640 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C6x_1 ] 10.269640 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C6x_1 ] 10.269651 s: SCICLIENT: DMSC FW revision 0x9 [C6x_1 ] 10.269651 s: SCICLIENT: DMSC FW revision 0x9 [C6x_1 ] 10.269661 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 10.269661 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 10.269671 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 10.269671 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 10.269680 s: UDMA: Init ... !!! [C6x_1 ] 10.269680 s: UDMA: Init ... !!! [C6x_1 ] 10.270910 s: UDMA: Init ... Done !!! [C6x_1 ] 10.270910 s: UDMA: Init ... Done !!! [C6x_1 ] 10.270932 s: MEM: Init ... !!! [C6x_1 ] 10.270932 s: MEM: Init ... !!! [C6x_1 ] 10.270944 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 10.270944 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 10.270961 s: MEM: Init ... Done !!! [C6x_1 ] 10.270961 s: MEM: Init ... Done !!! [C6x_1 ] 10.270970 s: IPC: Init ... !!! [C6x_1 ] 10.270970 s: IPC: Init ... !!! [C6x_1 ] 10.270992 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 10.270992 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 10.271007 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 10.271007 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 18.377351 s: IPC: HLOS is ready !!! [C6x_1 ] 18.377351 s: IPC: HLOS is ready !!! [C6x_1 ] 18.381056 s: IPC: Init ... Done !!! [C6x_1 ] 18.381056 s: IPC: Init ... Done !!! [C6x_1 ] 18.381085 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 18.381085 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 21.329142 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 21.329142 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 21.329157 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 21.329157 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 21.329582 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 21.329582 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 21.329626 s: VX_ZONE_INIT:Enabled [C6x_1 ] 21.329626 s: VX_ZONE_INIT:Enabled [C6x_1 ] 21.329637 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 21.329637 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 21.329647 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 21.329647 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 21.330613 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C6x_1 ] 21.330613 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C6x_1 ] 21.330628 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 21.330628 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 21.330926 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 21.330926 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 21.330942 s: UDMA Copy: Init ... !!! [C6x_1 ] 21.330942 s: UDMA Copy: Init ... !!! [C6x_1 ] 21.334008 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 21.334008 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 21.334032 s: APP: Init ... Done !!! [C6x_1 ] 21.334032 s: APP: Init ... Done !!! [C6x_1 ] 21.334040 s: APP: Run ... !!! [C6x_1 ] 21.334040 s: APP: Run ... !!! [MCU2_1] 21.329669 s: FVID2: Init ... Done !!! [C6x_1 ] 21.334559 s: APP: Run ... Done !!! [C6x_1 ] 21.334907 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 21.334907 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 21.344915 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 21.344915 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 10.328597 s: CIO: Init ... Done !!! [C6x_2 ] 10.328597 s: CIO: Init ... Done !!! [C6x_2 ] 10.328624 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 10.328624 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 10.328635 s: CPU is running FreeRTOS [C6x_2 ] 10.328635 s: CPU is running FreeRTOS [C6x_2 ] 10.328643 s: APP: Init ... !!! [C6x_2 ] 10.328643 s: APP: Init ... !!! [C6x_2 ] 10.328651 s: SCICLIENT: Init ... !!! [C6x_2 ] 10.328651 s: SCICLIENT: Init ... !!! [C6x_2 ] 10.328828 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C6x_2 ] 10.328828 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C6x_2 ] 10.328840 s: SCICLIENT: DMSC FW revision 0x9 [C6x_2 ] 10.328840 s: SCICLIENT: DMSC FW revision 0x9 [C6x_2 ] 10.328850 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 10.328850 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 10.328861 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 10.328861 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 10.328871 s: UDMA: Init ... !!! [C6x_2 ] 10.328871 s: UDMA: Init ... !!! [C6x_2 ] 10.330093 s: UDMA: Init ... Done !!! [C6x_2 ] 10.330093 s: UDMA: Init ... Done !!! [C6x_2 ] 10.330116 s: MEM: Init ... !!! [C6x_2 ] 10.330116 s: MEM: Init ... !!! [C6x_2 ] 10.330128 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 10.330128 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 10.330146 s: MEM: Init ... Done !!! [C6x_2 ] 10.330146 s: MEM: Init ... Done !!! [C6x_2 ] 10.330154 s: IPC: Init ... !!! [C6x_2 ] 10.330154 s: IPC: Init ... !!! [C6x_2 ] 10.330176 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 10.330176 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 10.330192 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 10.330192 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 18.946800 s: IPC: HLOS is ready !!! [C6x_2 ] 18.946800 s: IPC: HLOS is ready !!! [C6x_2 ] 18.950281 s: IPC: Init ... Done !!! [C6x_2 ] 18.950281 s: IPC: Init ... Done !!! [C6x_2 ] 18.950310 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 18.950310 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 21.329141 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 21.329141 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 21.329157 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 21.329157 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 21.329592 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 21.329592 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 21.329639 s: VX_ZONE_INIT:Enabled [C6x_2 ] 21.329639 s: VX_ZONE_INIT:Enabled [C6x_2 ] 21.329650 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 21.329650 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 21.329659 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 21.329659 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 10.269414 s: CIO: Init ... Done !!! [C6x_2 ] 21.330631 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 21.330930 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 21.330930 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 21.330947 s: UDMA Copy: Init ... !!! [C6x_2 ] 21.330947 s: UDMA Copy: Init ... !!! [C6x_2 ] 21.334130 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 21.334130 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 21.334153 s: APP: Init ... Done !!! [C6x_2 ] 21.334153 s: APP: Init ... Done !!! [C6x_2 ] 21.334162 s: APP: Run ... !!! [C6x_2 ] 21.334162 s: APP: Run ... !!! [C6x_2 ] 21.334170 s: IPC: Starting echo test ... [C6x_2 ] 21.334170 s: IPC: Starting echo test ... [C6x_2 ] 21.334773 s: APP: Run ... Done !!! [C6x_1 ] 21.334049 s: IPC: Starting echo test ... [C6x_2 ] 21.335109 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 21.335109 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 21.335144 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 21.335144 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 21.344936 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 10.495630 s: CIO: Init ... Done !!! [C6x_2 ] 21.344936 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 10.495644 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 10.495644 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 10.495655 s: CPU is running FreeRTOS [C7x_1 ] 10.495655 s: CPU is running FreeRTOS [C7x_1 ] 10.495663 s: APP: Init ... !!! [C7x_1 ] 10.495663 s: APP: Init ... !!! [C7x_1 ] 10.495670 s: SCICLIENT: Init ... !!! [C7x_1 ] 10.495670 s: SCICLIENT: Init ... !!! [C7x_1 ] 10.495844 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C7x_1 ] 10.495844 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)] [C7x_1 ] 10.495858 s: SCICLIENT: DMSC FW revision 0x9 [C7x_1 ] 10.495858 s: SCICLIENT: DMSC FW revision 0x9 [C7x_1 ] 10.495868 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 10.495868 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 10.495879 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 10.495879 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 10.495888 s: UDMA: Init ... !!! [C7x_1 ] 10.495888 s: UDMA: Init ... !!! [C7x_1 ] 10.496808 s: UDMA: Init ... Done !!! [C7x_1 ] 10.496808 s: UDMA: Init ... Done !!! [C7x_1 ] 10.496819 s: MEM: Init ... !!! [C7x_1 ] 10.496819 s: MEM: Init ... !!! [C7x_1 ] 10.496830 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 10.496830 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 10.496851 s: MEM: Init ... Done !!! [C7x_1 ] 10.496851 s: MEM: Init ... Done !!! [C7x_1 ] 10.496859 s: IPC: Init ... !!! [C7x_1 ] 10.496859 s: IPC: Init ... !!! [C7x_1 ] 10.496874 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 10.496874 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 10.496887 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 10.496887 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 19.154583 s: IPC: HLOS is ready !!! [C7x_1 ] 19.154583 s: IPC: HLOS is ready !!! [C7x_1 ] 19.156400 s: IPC: Init ... Done !!! [C7x_1 ] 19.156400 s: IPC: Init ... Done !!! [C7x_1 ] 19.156414 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 19.156414 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 21.330616 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C7x_1 ] 21.329160 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 21.329248 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 21.329248 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 21.329304 s: VX_ZONE_INIT:Enabled [C7x_1 ] 21.329304 s: VX_ZONE_INIT:Enabled [C7x_1 ] 21.329316 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 21.329316 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 21.329326 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 21.329563 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1 [C7x_1 ] 21.329563 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1 [C7x_1 ] 21.329632 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_2 [C7x_1 ] 21.329632 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_2 [C7x_1 ] 21.329715 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_3 [C7x_1 ] 21.329715 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_3 [C7x_1 ] 21.329800 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_4 [C7x_1 ] 21.329800 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_4 [C7x_1 ] 21.329868 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_5 [C7x_1 ] 21.329868 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_5 [C7x_1 ] 21.329935 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_6 [C7x_1 ] 21.329935 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_6 [C7x_1 ] 21.329999 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_7 [C7x_1 ] 21.329999 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_7 [C7x_1 ] 21.330067 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_8 [C7x_1 ] 21.330067 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_8 [C7x_1 ] 21.330088 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C7x_1 ] 21.330088 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! [C7x_1 ] 21.330101 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 21.330101 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 21.330267 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 21.330267 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 21.330280 s: APP: Init ... Done !!! [C7x_1 ] 21.330280 s: APP: Init ... Done !!! [C7x_1 ] 21.330290 s: APP: Run ... !!! [C7x_1 ] 21.330290 s: APP: Run ... !!! [C7x_1 ] 21.330299 s: IPC: Starting echo test ... [C7x_1 ] 21.330299 s: IPC: Starting echo test ... [C7x_1 ] 21.330401 s: APP: Run ... Done !!! [C7x_1 ] 21.330401 s: APP: Run ... Done !!! [C7x_1 ] 21.334914 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s] [C7x_1 ] 21.334914 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s] [C7x_1 ] 21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 21.335113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 21.344952 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 21.344952 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C6x_2 ] 21.334773 s: APP: Run ... Done !!! [C7x_1 ] 21.329143 s: APP: Syncing with 5 CPUs ... Done !!! [ 821.480321] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
