TDA4VM-Q1: TDA4VM88TCBALFQ1
Part Number: TDA4VM-Q1
Other Parts Discussed in Thread: TDA4VM
hello
Multiple failures have occurred in the project based on TDA4VM chip. The phenomenon is that OpenGL video blinking (frequency 4-8 frames/30 frames) continues to occur after a certain power on. View the video frame by frame, and you will see incorrect frames. Some may be moved half a screen to the left, while others may be covered by multiple irregular black horizontal bars.
There are the following records in the log:
PVR_K: (Error): DevicesWatchdogThread: Device status not OK!!! [598]
I have the following questions:
-Does the log indicate that the GPU has a reset action?
-If a GPU reset occurs, do we need to destroy and recreate for resources(framebuffer、TEXTURE2D、ImageKHR)?
-How to detect errors at the application layer? And how to manually restart the GPU driver?
13: 86034    23  10 CdV       0:00:00   2.54%        0  screen               pvrsrv_msg_handler
16: 86034    14  10 Rcv       0:00:00   2.10%        1  screen               pvrsrv_msg_handler
22: 86034    12  10 CdV       0:00:00   1.00%        0  screen               pvr_cacheop
35: 86034    13  20 Rcv       0:00:00   0.53%        0  screen               pvrsrv_pulse_misr_handler
39: 86034    11  10 CdV       0:00:00   0.42%        1  screen               pvr_device_wdg
43: 86034    24 250 Intr      0:00:00   0.39%        0  screen               pvrsrv_lisr_handler
105: 86034     2  15 CdV       0:00:00   0.12%        1  screen               screen-dpy-1
118: 86034    10  10 CdV       0:00:00   0.10%        1  screen               pvr_defer_free
142: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
145: 86034     4  10 Rcv       0:00:00   0.05%        0  screen               pvrsrv
498: Jan 01 08:00:00.457                   screen.86034                           0  -----ONLINE-----
499: Jan 01 08:00:00.457                   screen.86034                 slog*   300  screen: starting up...
500: Jan 01 08:00:00.458                   screen.86034                 slog    300  screen: Configuration file:  /usr/lib/graphics/j721e/graphics.conf.dss_on_r5
501: Jan 01 08:00:00.470                screen.86034..0                           0  -----ONLINE-----
502: Jan 01 08:00:00.470                   screen.86034                 slog    300  screen: slog2 context created with 1 pages
503: Jan 01 08:00:00.470                   screen.86034                 slog    300  screen: loading alloc module jacinto7-alloc...
504: Jan 01 08:00:00.471                   screen.86034                 slog    300  screen: display_mode_set: selecting preferred mode 0 for display 1
505: Jan 01 08:00:00.471                   screen.86034                 slog    300  screen: display 1 returned invalid value 0 for WFD_PORT_MODE_ROTATION_SUPPORT
506: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
507: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
508: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
509: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
510: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
511: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
512: Jan 01 08:00:00.471                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
513: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
514: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
515: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
516: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
517: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
518: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
519: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
520: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
521: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
522: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
523: Jan 01 08:00:00.472                   screen.86034                 slog    200  [j7_alloc]ERR : return: WFD_ERROR_NOT_SUPPORTED (pixel format is not supported)
524: Jan 01 08:00:00.472                   screen.86034                 slog    300  screen: loading libhiddi.so...
525: Jan 01 08:00:00.472                   screen.86034                 slog    300  screen: server is ready
661: Jan 01 08:00:05.920                   screen.86034                 slog    300  screen: loading EGL display 1...
662: Jan 01 08:00:05.950                   screen.86034                 slog    300  screen: set gpu id 1...
675: 86034    23  10 Rcv       0:00:01   2.32%        0  screen               pvrsrv_msg_handler
676: 86034    22  10 Rcv       0:00:01   2.10%        1  screen               pvrsrv_msg_handler
680: 86034    12  10 CdV       0:00:00   1.05%        0  screen               pvr_cacheop
694: 86034    13  20 Rcv       0:00:00   0.53%        0  screen               pvrsrv_pulse_misr_handler
703: 86034    24 250 Intr      0:00:00   0.41%        1  screen               pvrsrv_lisr_handler
707: 86034    11  10 CdV       0:00:00   0.38%        0  screen               pvr_device_wdg
725: 86034    14  10 Rcv       0:00:00   0.24%        0  screen               pvrsrv_msg_handler
760: 86034     2  15 CdV       0:00:00   0.13%        1  screen               screen-dpy-1
780: 86034    10  10 CdV       0:00:00   0.09%        0  screen               pvr_defer_free
797: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
799: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
1,090: 86034    22  10 Rcv       0:00:02   2.38%        0  screen               pvrsrv_msg_handler
1,091: 86034    23  10 Rcv       0:00:03   2.37%        0  screen               pvrsrv_msg_handler
1,094: 86034    12  10 CdV       0:00:01   1.02%        1  screen               pvr_cacheop
1,106: 86034    13  20 Rcv       0:00:00   0.54%        1  screen               pvrsrv_pulse_misr_handler
1,117: 86034    24 250 Intr      0:00:00   0.40%        0  screen               pvrsrv_lisr_handler
1,120: 86034    11  10 CdV       0:00:00   0.39%        1  screen               pvr_device_wdg
1,169: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
1,173: 86034    14  10 Rcv       0:00:00   0.11%        0  screen               pvrsrv_msg_handler
1,176: 86034    10  10 CdV       0:00:00   0.11%        1  screen               pvr_defer_free
1,205: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
1,206: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
1,506: 86034    22  10 Rcv       0:00:04   2.45%        1  screen               pvrsrv_msg_handler
1,507: 86034    14  10 Rcv       0:00:01   1.68%        0  screen               pvrsrv_msg_handler
1,510: 86034    12  10 CdV       0:00:02   1.01%        1  screen               pvr_cacheop
1,515: 86034    23  10 Rcv       0:00:03   0.74%        0  screen               pvrsrv_msg_handler
1,524: 86034    13  20 Rcv       0:00:01   0.53%        0  screen               pvrsrv_pulse_misr_handler
1,535: 86034    24 250 Intr      0:00:00   0.40%        0  screen               pvrsrv_lisr_handler
1,537: 86034    11  10 CdV       0:00:00   0.38%        0  screen               pvr_device_wdg
1,582: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
1,588: 86034    10  10 CdV       0:00:00   0.11%        1  screen               pvr_defer_free
1,620: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
1,621: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
1,922: 86034    14  10 Rcv       0:00:03   2.58%        0  screen               pvrsrv_msg_handler
1,923: 86034    22  10 Rdy       0:00:05   2.39%        1  screen               pvrsrv_msg_handler
1,926: 86034    12  10 Rdy       0:00:02   1.02%        1  screen               pvr_cacheop
1,937: 86034    13  20 Rcv       0:00:01   0.54%        1  screen               pvrsrv_pulse_misr_handler
1,947: 86034    24 250 Intr      0:00:01   0.41%        0  screen               pvrsrv_lisr_handler
1,951: 86034    11  10 CdV       0:00:01   0.38%        1  screen               pvr_device_wdg
1,999: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
2,006: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
2,037: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
2,039: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
2,337: 86034    14  10 Rcv       0:00:04   2.48%        1  screen               pvrsrv_msg_handler
2,338: 86034    22  10 Rcv       0:00:07   2.43%        1  screen               pvrsrv_msg_handler
2,341: 86034    12  10 Rdy       0:00:03   1.03%        0  screen               pvr_cacheop
2,352: 86034    13  20 Rcv       0:00:01   0.53%        1  screen               pvrsrv_pulse_misr_handler
2,362: 86034    24 250 Intr      0:00:01   0.40%        1  screen               pvrsrv_lisr_handler
2,365: 86034    11  10 CdV       0:00:01   0.39%        1  screen               pvr_device_wdg
2,416: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
2,421: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
2,458: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
2,459: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
2,553: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:(Error): DevicesWatchdogThread: Device status not OK!!! [598]
2,554: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: START (High) ]------------
2,555: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: DDK info: Rogue_DDK_Linux rogueddk 1.15@6133109 (release) j721e
2,556: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Time now: 171265402us
2,557: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Services State: OK
2,558: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Server Errors: 1
2,559: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Connections Device ID:0(1) P614450-V0-T28-SVVPP
2,560: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: ------[ Driver Info ]------
2,561: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Comparison of UM/KM components: MATCHING
2,562: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: KM Arch: 64 Bit
2,563: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: UM Connected Clients: 64 Bit
2,564: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: UM info: 1.15 @  6133109 (release) build options: 0x80000050
2,565: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: KM info: 1.15 @  6133109 (release) build options: 0x00000050
2,566: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Window system: screen
2,567: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 Start ]------
2,568: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Info ]------
2,569: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Device Node (Info): 1ac7e5f0f0 (1ac7e5e870)
2,570: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX BVNC: 22.104.208.318 (rogue)
2,571: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Device State: Active
2,572: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Power State: ON
2,573: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: FW info: 1.15 @  6133109 (release) build options: 0x80000050
2,574: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF0 - OK
2,575: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX FW State: NOT RESPONDING - KCCB stalled (HWRState 0x00000011:)
2,576: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 0 ms)
2,577: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX DVFS: 0 frequency changes. Current frequency: 749.988 MHz (sampled at 166290402370 ns). FW frequency: 750.000 MHz.
2,578: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
2,579: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB WO:0x2D RO:0x2D
2,580: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Firmware CCB WO:0x0 RO:0x0
2,581: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB commands executed = 47021
2,582: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX SLR: Forced UFO updates requested = 0
2,583: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Errors: WGP:0, TRP:0
2,584: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Thread0: FW IRQ count = 78298
2,585: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: Last sampled IRQ count in LISR = 78298
2,586: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: FW System config flags = 0x00020000 (Ctx switch options:)
2,587: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: FW OS config flags = 0x0000000F (Ctx switch:)
2,588: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX registers ]------
2,589: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Linear):   0x451feb7000
2,590: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Physical): 0x4E20000000
2,591: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CORE_ID                       : 0x0000000008470000
2,592: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CORE_REVISION                 : 0x00D0013E
2,593: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD1           : 0x00000000
2,594: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD2           : 0x00000000
2,595: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CHANGESET_NUMBER              : 0x0000000000000000
2,596: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL                      : 0x0aaaaa002a2aaaaa
2,597: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS                    : 0x0000000000600000
2,598: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL2                     : 0x0000000000000000
2,599: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS2                   : 0x0000000000000000
2,600: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: EVENT_STATUS                  : 0x00004410
2,601: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: TIMER                         : 0x000000001df97320
2,602: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_MMU_STATUS    : 0x00000000
2,603: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_REQ_STATUS    : 0x0000000000000000
2,604: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_MMU_STATUS    : 0x00000000
2,605: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_REQ_STATUS    : 0x0000000000000000
2,606: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_STATUS                : 0x00000000
2,607: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY                 : 0x00000000
2,608: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY_STATUS          : 0x0000000000000000
2,609: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_STATUS_MMU                : 0x00000000
2,610: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_EXT_STATUS          : 0x00000000
2,611: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_INT_STATUS          : 0x00000000
2,612: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_STATUS_MMU              : 0x00000000
2,613: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_EXT_STATUS        : 0x00000000
2,614: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_INT_STATUS        : 0x00000000
2,615: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE_INDEX            : 0x0000000000000101
2,616: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE0                 : 0x0000000000000000
2,617: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE1                 : 0x00000008f0549000
2,618: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE2                 : 0x0000000000000000
2,619: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE3                 : 0x0000000000000000
2,620: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE4                 : 0x0000000000000000
2,621: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE5                 : 0x0000000000000000
2,622: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE6                 : 0x0000000000000000
2,623: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE7                 : 0x0000000000000000
2,624: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL_INVAL                : 0x00000000
2,625: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL                      : 0x000000C0
2,626: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE0          : 0x000000008c5f2001
2,817: 54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE0           : 0x000000008c5f1001
2,818: May 15 15:57:54.912                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST0        : 0x000000008c5e6001
2,819: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE1          : 0x000000008c57e001
2,820: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE1           : 0x000000008c4cc001
2,821: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST1        : 0x000000008c574001
2,822: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_PHASE                 : 0x00007601
2,823: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_CYCLE                 : 0x8E48055C
2,824: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_PHASE                 : 0x00009805
2,825: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_CYCLE                 : 0xAE0E3ADB
2,826: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_OR_3D_CYCLE           : 0x018FB904
2,827: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_AND_3D_CYCLE          : 0x3AC68733
2,828: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_PHASE            : 0x00000000
2,829: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_CYCLE            : 0x00000000
2,830: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PM_PARTIAL_RENDER_ENABLE      : 0x00000000
2,831: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: ISP_RENDER                    : 0x00000000
2,832: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: TLA_STATUS                    : 0x0000000000000000
2,833: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MCU_FENCE                     : 0x0000018000000000
2,834: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_STATUS      : 0x00000001
2,835: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK0       : 0x0000000000000000
2,836: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK1       : 0x0000000000000000
2,837: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK2       : 0x0000000000000000
2,838: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK0      : 0x0000000000000000
2,839: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK1      : 0x0000000000000000
2,840: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK2      : 0x0000000000000000
2,841: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: ISP_CTL                       : 0x0001500F
2,842: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: ISP_STATUS                    : 0x00000003
2,843: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MTS_INTCTX                    : 0x00000000
2,844: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX                     : 0x00000000
2,845: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX_COUNTED_SCHEDULE    : 0x00000000
2,846: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MTS_SCHEDULE                  : 0x00000000
2,847: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MTS_GPU_INT_STATUS            : 0x00004510
2,848: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_STORE_STATUS      : 0x00000000
2,849: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS0              : 0x0000000000000000
2,850: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS1              : 0x0000000000000000
2,851: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS             : 0x0000000000000000
2,852: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS1            : 0x0000000000000000
2,853: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SIDEKICK_IDLE                 : 0x0000007E
2,854: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_IDLE                      : 0x000000FF
2,855: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS0                   : 0x00000000
2,856: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS1                   : 0x0000000000000000
2,857: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS2                   : 0x0000000000000000
2,858: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_BYPASS               : 0x01000000
2,859: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_MISC                 : 0x0000000000200003
2,860: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG1      : 0x1FC00001
2,861: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG2      : 0x00000008fcedf00c
2,862: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG1      : 0x1FC01001
2,863: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG2      : 0x00000008fcefb00c
2,864: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG1      : 0x1FC02001
2,865: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG2      : 0x00000008fcede00c
2,866: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG1      : 0x1FC00000
2,867: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG2      : 0x000000000000000c
2,868: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG1      : 0x00000001
2,869: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG2      : 0x00000008fcedf00c
2,870: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_WRAPPER_CONFIG           : 0x000000000001cf80
2,871: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: MIPS_EXCEPTION_STATUS         : 0x00000020
2,872: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: ---- [ MIPS internal state ] ----
2,873: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: PC                            : 0xC00171E6
2,874: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: STATUS_REGISTER               : 0x00481C05
2,875: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: CAUSE_REGISTER                : 0x00800008
2,876: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: BAD_REGISTER                  : 0xC00171E2
2,877: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: EPC                           : 0xC00171E2
2,878: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: SP                            : 0xCF600FE0
2,879: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: BAD_INSTRUCTION               : 0x00000000
2,880: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: TLB                           :
2,881: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV  , PA1 0x00000000    C
2,882: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  1) VA 0xCF000000 ( 16k) -> PA0 0x8fceb8000 DVGC, PA1 0x8fcebc000 DVGC
2,883: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  2) VA 0xCF600000 (  4k) -> PA0 0x8fcefc000 DV C, PA1 0x00000000    C
2,884: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  3) VA 0xC0032000 (  4k) -> PA0 0x8fcef8000 DVGC, PA1 0x8fcef9000 DVGC
2,885: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  4) VA 0xC0002000 (  4k) -> PA0 0x8fcec8000 DVGC, PA1 0x8fcec9000 DVGC
2,886: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  5) VA 0xC0004000 (  4k) -> PA0 0x8fceca000 DVGC, PA1 0x8fcecb000 DVGC
2,887: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  6) VA 0xC0028000 (  4k) -> PA0 0x8f0548000 DVGC, PA1 0x8f0522000 DVGC
2,888: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  7) VA 0xC0012000 (  4k) -> PA0 0x8fced8000 DVGC, PA1 0x8fced9000 DVGC
2,889: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  8) VA 0xC000E000 (  4k) -> PA0 0x8fced4000 DVGC, PA1 0x8fced5000 DVGC
2,890: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034:  9) VA 0xC0016000 (  4k) -> PA0 0x8fcedc000 DVGC, PA1 0x8fcedd000 DVGC
2,891: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 10) VA 0xC0008000 (  4k) -> PA0 0x8fcece000 DVGC, PA1 0x8fcecf000 DVGC
2,892: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 11) VA 0xC001A000 (  4k) -> PA0 0x8f056f000 DVG , PA1 0x8f056e000 DVG
2,893: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 12) VA 0xC0020000 (  4k) -> PA0 0x8f056c000 DVG , PA1 0x8f056b000 DVG
2,894: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 13) VA 0xC0000000 (  4k) -> PA0 0x8fcec6000 DVGC, PA1 0x8fcec7000 DVGC
2,895: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 14) VA 0xC000C000 (  4k) -> PA0 0x8fced2000 DVGC, PA1 0x8fced3000 DVGC
2,896: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: 15) VA 0xC000A000 (  4k) -> PA0 0x8fced0000 DVGC, PA1 0x8fced1000 DVGC
2,897: May 15 15:57:54.913                   screen.86034                 slog    100  PVR_K:  86034: --------------------------------
2,898: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX FW Trace Info ]------
2,899: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Debug log type: none
2,900: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: RGX FW thread 0: Trace buffer not yet allocated
2,901: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ Full CCB Status ]------
2,902: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028300 (TQ_3D-P614450-T28-SVVPP)
2,903: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   `--<Empty>
2,904: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028040 (TA-P614450-T28-SVVPP)
2,905: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting TA[slog2info]Time:2024-05-15 15:58:05
2,907: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   `--Waiting UPDATE @ 33784 Int=43233 Ext=43231
2,908: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002d020 Val=0x0000192e
2,909: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c0b1 Val=0x00000519
2,910: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC00280E0 (3D-P614450-T28-SVVPP)
2,911: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting FENCE_PR @ 37576 Int=43233 Ext=43231
2,912: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002d020 Val=0x0000192e
2,913: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting 3D @ 37624 Int=43233 Ext=43231
2,914: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:   `--Waiting UPDATE @ 38016 Int=43233 Ext=43231
2,915: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002d020 Val=0x0000192f
2,916: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c059 Val=0x00000519
2,917: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 End ]------
2,918: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ System Summary Device ID:0 ]------
2,919: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Device System Power State: ON
2,920: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
2,921: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ Server Thread Summary ]------
2,922: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ HTB Log state: Off ]------
2,923: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ Active Sync Checkpoints ]------
2,924: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 69127, FWAddr = 0xc002c058, r1:e1:f0: es3_DoKick3D_43231
2,925: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 69126, FWAddr = 0xc002c0b0, r1:e1:f0: es3_DoKickTA_43231
2,926: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: timelines ]------
2,927: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Timeline: RM_SWTimeline-n/SVVPP-28-614450, SeqNum: 0/0 - <0x1ac7e685a0>
2,928: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 30209/30210 - <0x1ac7e68630>
2,929: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 30210, Refs: 1, Active    - <0x1acab344b0>
2,930: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69126, FWAddr: 0xc002c0b1, Enq: 1, Ref: 1, Active    - <0x1ac8dc29d0>
2,931: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 25894/25895 - <0x1ac7e686c0>
2,932: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 25895, Refs: 1, Active    - <0x1acab34b70>
2,933: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69127, FWAddr: 0xc002c059, Enq: 1, Ref: 1, Active    - <0x1ac7ee5760>
2,934: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 13023/13023 - <0x1ac7e68990>
2,935: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: fences ]------
2,936: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_43211, Signalled - <0x1acab346f0>
2,937: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 25883, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34f90>
2,938: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69095, FWAddr: 0xc002c039, Enq: 1, Ref: 1, Signalled - <0x1ac7ec6990>
2,939: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_43221, Signalled - <0x1acab34e70>
2,940: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 25889, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34810>
2,941: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69111, FWAddr: 0xc002c0f9, Enq: 1, Ref: 1, Signalled - <0x1ac8de0990>
2,942: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Signalled - <0x1acab34a50>
2,943: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 13022, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Signalled - <0x1acab34ed0>
2,944: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69117, FWAddr: 0xc002c061, Enq: 3, Ref: 1, Signalled - <0x1ac7ee5560>
2,945: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_43224, Signalled - <0x1acab34ab0>
2,946: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 30207, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Signalled - <0x1acab34870>
2,947: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69120, FWAddr: 0xc002c0e1, Enq: 1, Ref: 1, Signalled - <0x1ac8dbe060>
2,948: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Signalled - <0x1ac8dd9db0>
2,949: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 13023, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Signalled - <0x1acab34db0>
2,950: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69122, FWAddr: 0xc002c029, Enq: 1, Ref: 1, Signalled - <0x1ac7ec6d90>
2,951: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_43223, Signalled - <0x1acab34bd0>
2,952: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 30208, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Signalled - <0x1acab34b10>
2,953: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69123, FWAddr: 0xc002c0c1, Enq: 1, Ref: 1, Signalled - <0x1ac7ecbf60>
2,954: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_43231, Active    - <0x1ac8dd9e10>
2,955: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 30210, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Active    - <0x1acab344b0>
2,956: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69126, FWAddr: 0xc002c0b1, Enq: 1, Ref: 1, Signalled - <0x1ac8dc29d0>
2,957: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_43231, Active    - <0x1acab347b0>
2,958: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 25895, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Active    - <0x1acab34b70>
2,959: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 69127, FWAddr: 0xc002c059, Enq: 1, Ref: 1, Active    - <0x1ac7ee5760>
2,960: May 15 15:57:54.914                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: END ]------------
2,972: 86034    14  10 Rcv       0:00:06   2.49%        1  screen               pvrsrv_msg_handler
2,973: 86034    22  10 Rcv       0:00:08   2.40%        0  screen               pvrsrv_msg_handler
2,976: 86034    12  10 CdV       0:00:03   1.03%        1  screen               pvr_cacheop
2,989: 86034    13  20 Rcv       0:00:01   0.52%        1  screen               pvrsrv_pulse_misr_handler
2,998: 86034    24 250 Intr      0:00:01   0.40%        0  screen               pvrsrv_lisr_handler
3,001: 86034    11  10 CdV       0:00:01   0.38%        1  screen               pvr_device_wdg
3,050: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
3,058: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
3,089: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
3,090: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
3,387: 86034    14  10 Rcv       0:00:07   2.51%        0  screen               pvrsrv_msg_handler
3,388: 86034    22  10 Rcv       0:00:09   2.43%        0  screen               pvrsrv_msg_handler
3,391: 86034    12  10 CdV       0:00:04   1.02%        1  screen               pvr_cacheop
3,402: 86034    13  20 Rcv       0:00:02   0.53%        0  screen               pvrsrv_pulse_misr_handler
3,413: 86034    24 250 Intr      0:00:01   0.40%        1  screen               pvrsrv_lisr_handler
3,416: 86034    11  10 CdV       0:00:01   0.38%        0  screen               pvr_device_wdg
3,466: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
3,472: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
3,507: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
3,508: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
3,792: May 15 15:58:59.480                   screen.86034                 slog    100  PVR_K:(Error): DevicesWatchdogThread: Device status not OK!!! [598]
3,793: May 15 15:58:59.480                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: START (High) ]------------
3,794: May 15 15:58:59.480                   screen.86034                 slog    100  PVR_K:  86034: DDK info: Rogue_DDK_Linux rogueddk 1.15@6133109 (release) j721e
3,795: May 15 15:58:59.480                   screen.86034                 slog    100  PVR_K:  86034: Time now: 235839402us
3,796: May 15 15:58:59.480                   screen.86034                 slog    100  PVR_K:  86034: Services State: OK
3,797: May 15 15:58:59.483                   screen.86034                 slog    100  PVR_K:  86034: Server Errors: 2
3,798: May 15 15:58:59.483                   screen.86034                 slog    100  PVR_K:  86034: Connections Device ID:0(1) P614450-V0-T28-SVVPP
3,799: May 15 15:58:59.483                   screen.86034                 slog    100  PVR_K:  86034: ------[ Driver Info ]------
3,800: May 15 15:58:59.483                   screen.86034                 slog    100  PVR_K:  86034: Comparison of UM/KM components: MATCHING
3,801: May 15 15:58:59.484                   screen.86034                 slog    100  PVR_K:  86034: KM Arch: 64 Bit
3,802: May 15 15:58:59.484                   screen.86034                 slog    100  PVR_K:  86034: UM Connected Clients: 64 Bit
3,803: May 15 15:58:59.485                   screen.86034                 slog    100  PVR_K:  86034: UM info: 1.15 @  6133109 (release) build options: 0x80000050
3,804: May 15 15:58:59.485                   screen.86034                 slog    100  PVR_K:  86034: KM info: 1.15 @  6133109 (release) build options: 0x00000050
3,805: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: Window system: screen
3,806: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 Start ]------
3,807: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Info ]------
3,808: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: Device Node (Info): 1ac7e5f0f0 (1ac7e5e870)
3,809: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: RGX BVNC: 22.104.208.318 (rogue)
3,810: May 15 15:58:59.486                   screen.86034                 slog    100  PVR_K:  86034: RGX Device State: Active
3,811: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Power State: ON
3,812: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: FW info: 1.15 @  6133109 (release) build options: 0x80000050
3,813: May 15 15:58:59.487                   screen.86034                 slog    100  [slog2info]Time:2024-05-15 15:59:05
3,815: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX FW State: NOT RESPONDING - Poll failing (HWRState 0x00000011:)
3,816: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 0 ms)
3,817: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX DVFS: 0 frequency changes. Current frequency: 749.963 MHz (sampled at 226307402370 ns). FW frequency: 750.000 MHz.
3,818: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
3,819: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB WO:0x43 RO:0x43
3,820: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Firmware CCB WO:0x0 RO:0x0
3,821: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB commands executed = 65987
3,822: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX SLR: Forced UFO updates requested = 0
3,823: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Errors: WGP:0, TRP:0
3,824: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: Thread0: FW IRQ count = 110166
3,825: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: Last sampled IRQ count in LISR = 110166
3,826: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: FW System config flags = 0x00020000 (Ctx switch options:)
3,827: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: FW OS config flags = 0x0000000F (Ctx switch:)
3,828: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX registers ]------
3,829: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Linear):   0x451feb7000
3,830: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Physical): 0x4E20000000
3,831: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: CORE_ID                       : 0x0000000008470000
3,832: May 15 15:58:59.487                   screen.86034                 slog    100  PVR_K:  86034: CORE_REVISION                 : 0x00D0013E
3,833: May 15 15:58:59.491                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD1           : 0x00000000
3,834: May 15 15:58:59.491                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD2           : 0x00000000
3,835: May 15 15:58:59.491                   screen.86034                 slog    100  PVR_K:  86034: CHANGESET_NUMBER              : 0x0000000000000000
3,836: May 15 15:58:59.492                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL                      : 0x0aaaaa002a1aa9aa
3,837: May 15 15:58:59.492                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS                    : 0x000000001b701551
3,838: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL2                     : 0x0000000000000000
3,839: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS2                   : 0x0000000000000000
3,840: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: EVENT_STATUS                  : 0x00004410
3,841: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: TIMER                         : 0x000000002940b57a
3,842: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_MMU_STATUS    : 0x00000000
3,843: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_REQ_STATUS    : 0x0000000000000000
3,844: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_MMU_STATUS    : 0x00000000
3,845: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_REQ_STATUS    : 0x0000000000000000
3,846: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_STATUS                : 0x00000011
3,847: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY                 : 0x00000000
3,848: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY_STATUS          : 0x0000000000000000
3,849: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_STATUS_MMU                : 0x00000000
3,850: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_EXT_STATUS          : 0x00000000
3,851: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_INT_STATUS          : 0x00000000
3,852: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_STATUS_MMU              : 0x00000008
3,853: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_EXT_STATUS        : 0x00000000
3,854: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_INT_STATUS        : 0x00000000
3,855: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE_INDEX            : 0x0000000000000101
3,856: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE0                 : 0x0000000000000000
3,857: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE1                 : 0x00000008f0549000
3,858: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE2                 : 0x0000000000000000
3,859: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE3                 : 0x0000000000000000
3,860: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE4                 : 0x0000000000000000
3,861: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE5                 : 0x0000000000000000
3,862: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE6                 : 0x0000000000000000
3,863: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE7                 : 0x0000000000000000
3,864: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL_INVAL                : 0x00000000
3,865: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL                      : 0x000000C0
3,866: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE0          : 0x000000008c5fa001
3,867: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE0           : 0x000000008c5ee001
3,868: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST0        : 0x000000008c5f5001
3,869: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE1          : 0x00000008faf24001
3,870: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE1           : 0x00000008faf26001
3,871: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST1        : 0x00000008faf1b001
3,872: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_PHASE                 : 0x0000A632
3,873: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_CYCLE                 : 0x6F915527
3,874: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_PHASE                 : 0x0000D5F8
3,875: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_CYCLE                 : 0x10E8D117
3,876: May 15 15:58:59.493                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_OR_3D_CYCLE           : 0x85C34878
3,877: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_AND_3D_CYCLE          : 0x00000000
3,878: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_PHASE            : 0x00000000
3,879: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_CYCLE            : 0x00000000
3,880: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: PM_PARTIAL_RENDER_ENABLE      : 0x00000000
3,881: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: ISP_RENDER                    : 0x00000000
3,882: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: TLA_STATUS                    : 0x0000000000000000
3,883: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MCU_FENCE                     : 0x0000008000000000
3,884: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_STATUS      : 0x00000001
3,885: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK0       : 0x0000000000000000
3,886: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK1       : 0x0000000000000000
3,887: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK2       : 0x0000000000000000
3,888: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK0      : 0x0000000000000000
3,889: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK1      : 0x0000000000000000
3,890: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK2      : 0x0000000000000000
3,891: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: ISP_CTL                       : 0x0003500F
3,892: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: ISP_STATUS                    : 0x00000002
3,893: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MTS_INTCTX                    : 0x00000000
3,894: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX                     : 0x00000000
3,895: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX_COUNTED_SCHEDULE    : 0x00000000
3,896: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MTS_SCHEDULE                  : 0x00000000
3,897: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MTS_GPU_INT_STATUS            : 0x00004510
3,898: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_STORE_STATUS      : 0x00000000
3,899: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS0              : 0x0000000000000000
3,900: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS1              : 0x0000000000000000
3,901: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS             : 0x0000000000000000
3,902: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS1            : 0x0000000000000000
3,903: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SIDEKICK_IDLE                 : 0x0000001E
3,905: screen.86034                 slog    100  PVR_K:  86034: SLC_IDLE                      : 0x0000001E
3,906: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS0                   : 0x00000000
3,907: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS1                   : 0x0000000600020004
3,908: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS2                   : 0x0000000000000000
3,909: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_BYPASS               : 0x01000000
3,910: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_MISC                 : 0x0000000000200003
3,911: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG1      : 0x1FC00001
3,912: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG2      : 0x00000008fcedf00c
3,913: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG1      : 0x1FC01001
3,914: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG2      : 0x00000008fcefb00c
3,915: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG1      : 0x1FC02001
3,916: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG2      : 0x00000008fcede00c
3,917: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG1      : 0x1FC00000
3,918: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG2      : 0x000000000000000c
3,919: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG1      : 0x00000001
3,920: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG2      : 0x00000008fcedf00c
3,921: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_WRAPPER_CONFIG           : 0x000000000001cf80
3,922: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: MIPS_EXCEPTION_STATUS         : 0x00000020
3,923: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: ---- [ MIPS internal state ] ----
3,924: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: PC                            : 0xC00171E6
3,925: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: STATUS_REGISTER               : 0x00481C05
3,926: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: CAUSE_REGISTER                : 0x00800000
3,927: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: BAD_REGISTER                  : 0xC0003CAC
3,928: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: EPC                           : 0xC00171E2
3,929: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: SP                            : 0xCF600FE0
3,930: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: BAD_INSTRUCTION               : 0x00000000
3,931: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: TLB                           :
3,932: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV  , PA1 0x00000000    C
3,933: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  1) VA 0xCF000000 ( 16k) -> PA0 0x8fceb8000 DVGC, PA1 0x8fcebc000 DVGC
3,934: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  2) VA 0xCF600000 (  4k) -> PA0 0x8fcefc000 DV C, PA1 0x00000000    C
3,935: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  3) VA 0xC0032000 (  4k) -> PA0 0x8fcef8000 DVGC, PA1 0x8fcef9000 DVGC
3,936: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  4) VA 0xC006C000 (  4k) -> PA0 0x8007b000 DVGC, PA1 0x8007c000 DVGC
3,937: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  5) VA 0xC002C000 (  4k) -> PA0 0x8f04e1000 DVG , PA1 0x8f01c0000 DVG
3,938: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  6) VA 0xC0008000 (  4k) -> PA0 0x8fcece000 DVGC, PA1 0x8fcecf000 DVGC
3,939: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  7) VA 0xC0002000 (  4k) -> PA0 0x8fcec8000 DVGC, PA1 0x8fcec9000 DVGC
3,940: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  8) VA 0xC0010000 (  4k) -> PA0 0x8fced6000 DVGC, PA1 0x8fced7000 DVGC
3,941: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034:  9) VA 0xC001A000 (  4k) -> PA0 0x8f056f000 DVG , PA1 0x8f056e000 DVG
3,942: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 10) VA 0xC0028000 (  4k) -> PA0 0x8f0548000 DVGC, PA1 0x8f0522000 DVGC
3,943: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 11) VA 0xC000E000 (  4k) -> PA0 0x8fced4000 DVGC, PA1 0x8fced5000 DVGC
3,944: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 12) VA 0xC0014000 (  4k) -> PA0 0x8fceda000 DVGC, PA1 0x8fcedb000 DVGC
3,945: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 13) VA 0xC0004000 (  4k) -> PA0 0x8fceca000 DVGC, PA1 0x8fcecb000 DVGC
3,946: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 14) VA 0xC0016000 (  4k) -> PA0 0x8fcedc000 DVGC, PA1 0x8fcedd000 DVGC
3,947: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: 15) VA 0xC000C000 (  4k) -> PA0 0x8fced2000 DVGC, PA1 0x8fced3000 DVGC
3,948: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: --------------------------------
3,949: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX FW Trace Info ]------
3,950: May 15 15:58:59.494                   screen.86034                 slog    100  PVR_K:  86034: Debug log type: none
3,951: May 15 15:58:59.495                   screen.86034                 slog    100  PVR_K:  86034: RGX FW thread 0: Trace buffer not yet allocated
3,952: May 15 15:58:59.495                   screen.86034                 slog    100  PVR_K:  86034: ------[ Full CCB Status ]------
3,953: May 15 15:58:59.495                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028300 (TQ_3D-P614450-T28-SVVPP)
3,954: May 15 15:58:59.495                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting FENCE @ 28576 Int=60856 Ext=60856
3,955: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002c0d1 Val=0x00000519
3,956: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting TQ_3D @ 28624 Int=60856 Ext=60856
3,957: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting UPDATE @ 28824 Int=60856 Ext=60856
3,958: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |  |--Addr:0xc002b000 Val=0x00004786
3,959: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002c0c9 Val=0x00000519
3,960: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting FENCE @ 28880 Int=60857 Ext=60857
3,961: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002c0d1 Val=0x00000519
3,962: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting TQ_3D @ 28928 Int=60857 Ext=60857
3,963: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   `--Waiting UPDATE @ 29128 Int=60857 Ext=60857
3,964: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002b000 Val=0x00004787
3,965: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c0a1 Val=0x00000519
3,966: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028040 (TA-P614450-T28-SVVPP)
3,967: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   `--<Empty>
3,968: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC00280E0 (3D-P614450-T28-SVVPP)
3,969: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   |--Ready 3D @ 27936 Int=60855 Ext=60845
3,970: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:   `--Ready UPDATE @ 28328 Int=60855 Ext=60845
3,971: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002d018 Val=0x000017ca
3,972: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c0d1 Val=0x00000519
3,973: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 End ]------
3,974: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: ------[ System Summary Device ID:0 ]------
3,975: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: Device System Power State: ON
3,976: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
3,977: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: ------[ Server Thread Summary ]------
3,978: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: ------[ HTB Log state: Off ]------
3,979: May 15 15:58:59.496                   screen.86034                 slog    100  PVR_K:  86034: ------[ Active Sync Checkpoints ]------
3,980: May 15 15:58:59.497                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 97325, FWAddr = 0xc002c0a0, r1:e1:f0: TQM
3,981: May 15 15:58:59.497                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 97324, FWAddr = 0xc002c0c8, r1:e1:f0: TQM
3,982: May 15 15:58:59.497                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 97323, FWAddr = 0xc002c0d0, r1:e3:f0: es3_DoKick3D_60845
3,983: May 15 15:58:59.497                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: timelines ]------
3,984: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Timeline: RM_SWTimeline-n/SVVPP-28-614450, SeqNum: 0/0 - <0x1ac7e685a0>
3,985: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 42546/42546 - <0x1ac7e68630>
3,986: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 36468/36469 - <0x1ac7e686c0>
3,987: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 36469, Refs: 1, Active    - <0x1acab34f30>
3,988: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97323, FWAddr: 0xc002c0d1, Enq: 3, Ref: 1, Active    - <0x1ac8dc10c0>
3,989: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 18309/18311 - <0x1ac7e68990>
3,990: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 18310, Refs: 1, Active    - <0x1acab30f90>
3,991: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97324, FWAddr: 0xc002c0c9, Enq: 1, Ref: 1, Active    - <0x1ac8dc12e0>
3,992: May 15 15:58:59.498                   screen.86034                 sl[slog2info]Time:2024-05-15 15:59:15
3,994: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97325, FWAddr: 0xc002c0a1, Enq: 1, Ref: 1, Active    - <0x1ac7ee2f90>
3,995: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: fences ]------
3,996: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_60841, Signalled - <0x1acab34870>
3,997: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 36461, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34e10>
3,998: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97303, FWAddr: 0xc002c091, Enq: 1, Ref: 1, Signalled - <0x1ac7ee3410>
3,999: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_60851, Signalled - <0x1acab34810>
4,000: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 36467, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34ed0>
4,001: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97319, FWAddr: 0xc002c039, Enq: 1, Ref: 1, Signalled - <0x1ac7ec6990>
4,002: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_60822, Signalled - <0x1acab34bd0>
4,003: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 36468, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34cf0>
4,004: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97321, FWAddr: 0xc002c011, Enq: 1, Ref: 1, Signalled - <0x1ac7ec7390>
4,005: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_60845, Signalled - <0x1ac8dc45d0>
4,006: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 42546, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Signalled - <0x1acab34b70>
4,007: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97322, FWAddr: 0xc002c079, Enq: 1, Ref: 1, Signalled - <0x1ac7ecc630>
4,008: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_60845, Active    - <0x1acab34db0>
4,009: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 36469, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Active    - <0x1acab34f30>
4,010: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97323, FWAddr: 0xc002c0d1, Enq: 3, Ref: 1, Active    - <0x1ac8dc10c0>
4,011: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Active    - <0x1acab30810>
4,012: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 18310, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Active    - <0x1acab30f90>
4,013: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97324, FWAddr: 0xc002c0c9, Enq: 1, Ref: 1, Active    - <0x1ac8dc12e0>
4,014: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Active    - <0x1ac8dd9e10>
4,015: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 18311, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Active    - <0x1ac8dd9db0>
4,016: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 97325, FWAddr: 0xc002c0a1, Enq: 1, Ref: 1, Active    - <0x1ac7ee2f90>
4,017: May 15 15:58:59.498                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: END ]------------
4,029: 86034    14  10 Rcv       0:00:09   2.52%        0  screen               pvrsrv_msg_handler
4,030: 86034    22  10 CdV       0:00:10   1.70%        0  screen               pvrsrv_msg_handler
4,033: 86034    12  10 CdV       0:00:05   1.03%        0  screen               pvr_cacheop
4,037: 86034    23  10 Rcv       0:00:04   0.78%        0  screen               pvrsrv_msg_handler
4,045: 86034    13  20 Rcv       0:00:02   0.54%        0  screen               pvrsrv_pulse_misr_handler
4,055: 86034    24 250 Intr      0:00:02   0.40%        1  screen               pvrsrv_lisr_handler
4,056: 86034    11  10 CdV       0:00:01   0.39%        0  screen               pvr_device_wdg
4,105: 86034     2  15 CdV       0:00:00   0.13%        0  screen               screen-dpy-1
4,111: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
4,148: 86034     9  10 Rcv       0:00:00   0.07%        0  screen               screen-msg
4,150: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
4,435: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:(Error): DevicesWatchdogThread: Device status not OK!!! [598]
4,436: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: START (High) ]------------
4,437: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: DDK info: Rogue_DDK_Linux rogueddk 1.15@6133109 (release) j721e
4,438: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Time now: 279681402us
4,439: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Services State: OK
4,440: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Server Errors: 3
4,441: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Connections Device ID:0(1) P614450-V0-T28-SVVPP
4,442: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: ------[ Driver Info ]------
4,443: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Comparison of UM/KM components: MATCHING
4,444: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: KM Arch: 64 Bit
4,445: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: UM Connected Clients: 64 Bit
4,446: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: UM info: 1.15 @  6133109 (release) build options: 0x80000050
4,447: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: KM info: 1.15 @  6133109 (release) build options: 0x00000050
4,448: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Window system: screen
4,449: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 Start ]------
4,450: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Info ]------
4,451: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Device Node (Info): 1ac7e5f0f0 (1ac7e5e870)
4,452: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX BVNC: 22.104.208.318 (rogue)
4,453: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Device State: Active
4,454: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Power State: ON
4,455: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: FW info: 1.15 @  6133109 (release) build options: 0x80000050
4,456: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: BIF0 - OK
4,457: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX FW State: NOT RESPONDING - Poll failing (HWRState 0x00000011:)
4,458: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 0 ms)
4,459: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX DVFS: 0 frequency changes. Current frequency: 749.938 MHz (sampled at 276314402370 ns). FW frequency: 750.000 MHz.
4,460: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
4,461: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB WO:0x0 RO:0x0
4,462: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Firmware CCB WO:0x0 RO:0x0
4,463: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Kernel CCB commands executed = 78976
4,464: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX SLR: Forced UFO updates requested = 0
4,465: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Errors: WGP:0, TRP:0
4,466: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Thread0: FW IRQ count = 131990
4,467: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: Last sampled IRQ count in LISR = 131990
4,468: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: FW System config flags = 0x00020000 (Ctx switch options:)
4,469: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: FW OS config flags = 0x0000000F (Ctx switch:)
4,470: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX registers ]------
4,471: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Linear):   0x451feb7000
4,472: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: RGX Register Base Address (Physical): 0x4E20000000
4,473: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CORE_ID                       : 0x0000000008470000
4,474: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CORE_REVISION                 : 0x00D0013E
4,475: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD1           : 0x00000000
4,476: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: DESIGNER_REV_FIELD2           : 0x00000000
4,477: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CHANGESET_NUMBER              : 0x0000000000000000
4,478: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL                      : 0x0aaaaa002a1aa9aa
4,479: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS                    : 0x000000001b70155d
4,480: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CLK_CTRL2                     : 0x0000000000000000
4,481: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: CLK_STATUS2                   : 0x0000000000000000
4,482: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: EVENT_STATUS                  : 0x00004410
4,483: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: TIMER                         : 0x0000000030e80726
4,484: May 15 15:59:43.318                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_MMU_STATUS    : 0x00000000
4,485: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK0_REQ_STATUS    : 0x0000000000000000
4,486: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_MMU_STATUS    : 0x00000000
4,487: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_FAULT_BANK1_REQ_STATUS    : 0x0000000000000000
4,488: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_STATUS                : 0x00000001
4,489: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY                 : 0x00000000
4,490: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_MMU_ENTRY_STATUS          : 0x0000000000000000
4,491: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_STATUS_MMU                : 0x00000000
4,492: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_EXT_STATUS          : 0x00000000
4,493: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_READS_INT_STATUS          : 0x00000000
4,494: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_STATUS_MMU              : 0x00000002
4,495: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_EXT_STATUS        : 0x00000000
4,496: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIFPM_READS_INT_STATUS        : 0x00000000
4,497: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE_INDEX            : 0x0000000000000101
4,498: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE0                 : 0x0000000000000000
4,499: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE1                 : 0x00000008f0549000
4,500: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE2                 : 0x0000000000000000
4,501: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE3                 : 0x0000000000000000
4,502: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE4                 : 0x0000000000000000
4,503: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE5                 : 0x0000000000000000
4,504: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE6                 : 0x0000000000000000
4,505: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CAT_BASE7                 : 0x0000000000000000
4,506: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL_INVAL                : 0x00000000
4,507: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_CTRL                      : 0x000000C0
4,508: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE0          : 0x000000008c57f001
4,509: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE0           : 0x000000008c595001
4,510: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST0        : 0x000000008c582001
4,511: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_VCE1          : 0x00000008faf37001
4,512: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_TE1           : 0x00000008faf26001
4,513: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: BIF_PM_CAT_BASE_ALIST1        : 0x00000008faf2a001
4,514: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_PHASE                 : 0x0000C741
4,515: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_CYCLE                 : 0xBA971396
4,516: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_PHASE                 : 0x00010079
4,517: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_3D_CYCLE                 : 0x71DD7BB2
4,518: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_OR_3D_CYCLE           : 0xFD6E1ECF
4,519: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_TA_AND_3D_CYCLE          : 0x00000000
4,520: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_PHASE            : 0x00000000
4,521: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PERF_COMPUTE_CYCLE            : 0x00000000
4,522: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: PM_PARTIAL_RENDER_ENABLE      : 0x00000000
4,523: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: ISP_RENDER                    : 0x00000000
4,524: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: TLA_STATUS                    : 0x0000000000000000
4,525: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MCU_FENCE                     : 0x0000008000000000
4,527: screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_STATUS      : 0x00000001
4,528: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK0       : 0x0000000000000000
4,529: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK1       : 0x0000000000000000
4,530: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_STORE_TASK2       : 0x0000000000000000
4,531: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK0      : 0x0000000000000000
4,532: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK1      : 0x0000000000000000
4,533: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: VDM_CONTEXT_RESUME_TASK2      : 0x0000000000000000
4,534: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: ISP_CTL                       : 0x0003500F
4,535: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: ISP_STATUS                    : 0x00000002
4,536: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MTS_INTCTX                    : 0x00000000
4,537: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX                     : 0x00000000
4,538: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MTS_BGCTX_COUNTED_SCHEDULE    : 0x00000000
4,539: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MTS_SCHEDULE                  : 0x00000000
4,540: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MTS_GPU_INT_STATUS            : 0x00004510
4,541: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_STORE_STATUS      : 0x00000000
4,542: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS0              : 0x0000000000000000
4,543: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: CDM_CONTEXT_PDS1              : 0x0000000000000000
4,544: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS             : 0x0000000000000000
4,545: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: CDM_TERMINATE_PDS1            : 0x0000000000000000
4,546: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SIDEKICK_IDLE                 : 0x0000001E
4,547: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_IDLE                      : 0x0000001E
4,548: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS0                   : 0x00000000
4,549: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS1                   : 0x0000000000000000
4,550: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_STATUS2                   : 0x0000000000000000
4,551: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_BYPASS               : 0x01000000
4,552: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: SLC_CTRL_MISC                 : 0x0000000000200003
4,553: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG1      : 0x1FC00001
4,554: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP1_CONFIG2      : 0x00000008fcedf00c
4,555: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG1      : 0x1FC01001
4,556: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP2_CONFIG2      : 0x00000008fcefb00c
4,557: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG1      : 0x1FC02001
4,558: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP3_CONFIG2      : 0x00000008fcede00c
4,559: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG1      : 0x1FC00000
4,560: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP4_CONFIG2      : 0x000000000000000c
4,561: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG1      : 0x00000001
4,562: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_ADDR_REMAP5_CONFIG2      : 0x00000008fcedf00c
4,563: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_WRAPPER_CONFIG           : 0x000000000001cf80
4,564: May 15 15:59:43.319                   screen.86034                 slog    100  PVR_K:  86034: MIPS_EXCEPTION_STATUS         : 0x00000020
4,565: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ---- [ MIPS internal state ] ----
4,566: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: PC                            : 0xC00171E6
4,567: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: STATUS_REGISTER               : 0x00481C05
4,568: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: CAUSE_REGISTER                : 0x00800008
4,569: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: BAD_REGISTER                  : 0xC00171E2
4,570: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: EPC                           : 0xC00171E2
4,571: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: SP                            : 0xCF600FE0
4,572: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: BAD_INSTRUCTION               : 0x00000000
4,573: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: TLB                           :
4,574: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV  , PA1 0x00000000    C
4,575: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  1) VA 0xCF000000 ( 16k) -> PA0 0x8fceb8000 DVGC, PA1 0x8fcebc000 DVGC
4,576: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  2) VA 0xCF600000 (  4k) -> PA0 0x8fcefc000 DV C, PA1 0x00000000    C
4,577: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  3) VA 0xC0032000 (  4k) -> PA0 0x8fcef8000 DVGC, PA1 0x8fcef9000 DVGC
4,578: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  4) VA 0xC0004000 (  4k) -> PA0 0x8fceca000 DVGC, PA1 0x8fcecb000 DVGC
4,579: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  5) VA 0xC0006000 (  4k) -> PA0 0x8fcecc000 DVGC, PA1 0x8fcecd000 DVGC
4,580: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  6) VA 0xC002C000 (  4k) -> PA0 0x8f04e1000 DVG , PA1 0x8f01c0000 DVG
4,581: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  7) VA 0xC0002000 (  4k) -> PA0 0x8fcec8000 DVGC, PA1 0x8fcec9000 DVGC
4,582: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  8) VA 0xC0012000 (  4k) -> PA0 0x8fced8000 DVGC, PA1 0x8fced9000 DVGC
4,583: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  9) VA 0xC000E000 (  4k) -> PA0 0x8fced4000 DVGC, PA1 0x8fced5000 DVGC
4,584: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 10) VA 0xC0008000 (  4k) -> PA0 0x8fcece000 DVGC, PA1 0x8fcecf000 DVGC
4,585: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 11) VA 0xC002A000 (  4k) -> PA0 0x8f0502000 DVG , PA1 0x8f04cd000 DVG
4,586: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 12) VA 0xC0016000 (  4k) -> PA0 0x8fcedc000 DVGC, PA1 0x8fcedd000 DVGC
4,587: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 13) VA 0xC003A000 (  4k) -> PA0 0x8fcf82000 DVGC, PA1 0x8fcf83000 DVGC
4,588: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 14) VA 0xC0066000 (  4k) -> PA0 0x8fcfae000 DVGC, PA1 0x80076000 DVGC
4,589: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: 15) VA 0xC0028000 (  4k) -> PA0 0x8f0548000 DVGC, PA1 0x8f0522000 DVGC
4,590: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: --------------------------------
4,591: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX FW Trace Info ]------
4,592: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: Debug log type: none
4,593: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: RGX FW thread 0: Trace buffer not yet allocated
4,594: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ Full CCB Status ]------
4,595: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028300 (TQ_3D-P614450-T28-SVVPP)
4,596: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting FENCE @ 24928 Int=72946 Ext=72946
4,597: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002c099 Val=0x00000519
4,598: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Waiting TQ_3D @ 24976 Int=72946 Ext=72946
4,599: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   `--Waiting UPDATE @ 25176 Int=72946 Ext=72946
4,600: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002b000 Val=0x000055b1
4,601: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c0e9 Val=0x00000519
4,602: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC0028040 (TA-P614450-T28-SVVPP)
4,603: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   `--<Empty>
4,604: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: FWCtx 0xC00280E0 (3D-P614450-T28-SVVPP)
4,605: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Ready 3D @ 13792 Int=72944 Ext=72912
4,606: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Ready UPDATE @ 14184 Int=72944 Ext=72912
4,607: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |  |--Addr:0xc002d004 Val=0x00002ab4
4,608: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002c029 Val=0x00000519
4,609: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Ready FENCE_PR @ 14240 Int=72945 Ext=72935
4,610: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |  `--Addr:0xc002d01c Val=0x00001c81
4,611: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   |--Ready 3D @ 14288 Int=72945 Ext=72935
4,612: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:   `--Ready UPDATE @ 14680 Int=72945 Ext=72935
4,613: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:      |--Addr:0xc002d01c Val=0x00001c82
4,614: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:      `--Addr:0xc002c099 Val=0x00000519
4,615: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ RGX Device ID:0 End ]------
4,616: May 15 15:59:43.320                   screen.86034[top]Time:2024-05-15 15:59:51
4,627: 86034    14  10 Rdy       0:00:10   2.39%        0  screen               pvrsrv_msg_handler
4,629: 86034    23  10 Rcv       0:00:04   1.34%        1  screen               pvrsrv_msg_handler
4,631: 86034    22  10 Rcv       0:00:11   1.17%        0  screen               pvrsrv_msg_handler
4,632: 86034    12  10 CdV       0:00:05   1.02%        1  screen               pvr_cacheop
4,642: 86034    13  20 Rcv       0:00:02   0.54%        1  screen               pvrsrv_pulse_misr_handler
4,654: 86034    24 250 Intr      0:00:02   0.40%        1  screen               pvrsrv_lisr_handler
4,657: 86034    11  10 CdV       0:00:02   0.38%        1  screen               pvr_device_wdg
4,707: 86034     2  15 CdV       0:00:00   0.13%        1  screen               screen-dpy-1
4,712: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
4,747: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
4,749: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
4,844: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: Device System Power State: ON
4,845: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
4,846: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ Server Thread Summary ]------
4,847: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ HTB Log state: Off ]------
4,848: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ Active Sync Checkpoints ]------
4,849: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 116668, FWAddr = 0xc002c0e8, r1:e1:f0: TQM
4,850: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 116667, FWAddr = 0xc002c098, r1:e2:f0: es3_DoKick3D_72935
4,851: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034:  - ID = 116665, FWAddr = 0xc002c028, r1:e1:f0: es3_DoKick3D_72912
4,852: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: timelines ]------
4,853: May 15 15:59:43.320                   screen.86034                 slog    100  PVR_K:  86034: Timeline: RM_SWTimeline-n/SVVPP-28-614450, SeqNum: 0/0 - <0x1ac7e685a0>
4,854: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 51009/51009 - <0x1ac7e68630>
4,855: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 43721/43723 - <0x1ac7e686c0>
4,856: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43722, Refs: 1, Active    - <0x1acab34b10>
4,857: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116665, FWAddr: 0xc002c029, Enq: 1, Ref: 1, Active    - <0x1ac7ec6d90>
4,858: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43723, Refs: 1, Active    - <0x1acab34e70>
4,859: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116667, FWAddr: 0xc002c099, Enq: 2, Ref: 1, Active    - <0x1ac7ee31d0>
4,860: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450, SeqNum: 21936/21937 - <0x1ac7e68990>
4,861: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 21937, Refs: 1, Active    - <0x1acab344b0>
4,862: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116668, FWAddr: 0xc002c0e9, Enq: 1, Ref: 1, Active    - <0x1ac8de3de0>
4,863: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: ------[ Fallback Fence Sync: fences ]------
4,864: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_72931, Signalled - <0x1acab34f90>
4,865: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43715, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab34390>
4,866: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116647, FWAddr: 0xc002c059, Enq: 1, Ref: 1, Signalled - <0x1ac7ee5760>
4,867: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Signalled - <0x1acab30810>
4,868: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 21936, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Signalled - <0x1acab34b70>
4,869: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116658, FWAddr: 0xc002c111, Enq: 1, Ref: 1, Signalled - <0x1ac7ec83a0>
4,870: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_72941, Signalled - <0x1acab347b0>
4,871: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43721, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Signalled - <0x1acab346f0>
4,872: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116663, FWAddr: 0xc002c041, Enq: 1, Ref: 1, Signalled - <0x1ac7ec65e0>
4,873: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_72912, Signalled - <0x1ac8dd9db0>
4,874: May 15 15:59:43.324                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 51008, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Signalled - <0x1acab30f90>
4,875: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116664, FWAddr: 0xc002c0b9, Enq: 1, Ref: 1, Signalled - <0x1ac8dc1f60>
4,876: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_72912, Active    - <0x1acab34ed0>
4,877: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43722, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Active    - <0x1acab34b10>
4,878: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116665, FWAddr: 0xc002c029, Enq: 1, Ref: 1, Active    - <0x1ac7ec6d90>
4,879: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKickTA_72935, Signalled - <0x1ac8dd9e10>
4,880: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 51009, Refs: 1, Timeline: V3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68630>, Signalled - <0x1acab34750>
4,881: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116666, FWAddr: 0xc002c079, Enq: 1, Ref: 1, Signalled - <0x1ac7ecc630>
4,882: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034: Fence: es3_DoKick3D_72935, Active    - <0x1acab34bd0>
4,883: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 43723, Refs: 1, Timeline: P3-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e686c0>, Active    - <0x1acab34e70>
4,884: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116667, FWAddr: 0xc002c099, Enq: 2, Ref: 1, Active    - <0x1ac7ee31d0>
4,885: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034: Fence: TQM, Active    - <0x1ac8dc45d0>
4,886: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:  - SyncPt: SeqNum: 21937, Refs: 1, Timeline: QE-pt/SVVPP/bin/SVVPP-28-614450 <0x1ac7e68990>, Active    - <0x1acab344b0>
4,887: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034:     - CbType: PVR-Checkpoint, ID: 116668, FWAddr: 0xc002c0e9, Enq: 1, Ref: 1, Active    - <0x1ac8de3de0>
4,888: May 15 15:59:43.325                   screen.86034                 slog    100  PVR_K:  86034: ------------[ PVR DBG: END ]------------
5,090: 86034    23  10 Rcv       0:00:06   2.38%        1  screen               pvrsrv_msg_handler
5,091: 86034    14  10 Rcv       0:00:11   2.15%        1  screen               pvrsrv_msg_handler
5,094: 86034    12  10 CdV       0:00:06   1.03%        0  screen               pvr_cacheop
5,105: 86034    13  20 Rcv       0:00:03   0.54%        1  screen               pvrsrv_pulse_misr_handler
5,115: 86034    24 250 Intr      0:00:02   0.41%        0  screen               pvrsrv_lisr_handler
5,116: 86034    22  10 Rcv       0:00:11   0.40%        1  screen               pvrsrv_msg_handler
5,119: 86034    11  10 CdV       0:00:02   0.39%        0  screen               pvr_device_wdg
5,170: 86034     2  15 CdV       0:00:00   0.13%        1  screen               screen-dpy-1
5,175: 86034    10  10 CdV       0:00:00   0.10%        0  screen               pvr_defer_free
5,208: 86034     4  10 Rcv       0:00:00   0.06%        1  screen               pvrsrv
5,210: 86034     9  10 Rcv       0:00:00   0.06%        1  screen               screen-msg
5,506: 86034    23  10 Rcv       0:00:07   2.48%        0  screen               pvrsrv_msg_handler
5,507: 86034    22  10 Rcv       0:00:13   2.40%        0  screen               pvrsrv_msg_handler
5,510: 86034    12  10 Rdy       0:00:07   1.02%        0  screen               pvr_cacheop
5,520: 86034    13  20 Rcv       0:00:03   0.55%        1  screen               pvrsrv_pulse_misr_handler
5,531: 86034    24 250 Intr      0:00:02   0.41%        0  screen               pvrsrv_lisr_handler
5,534: 86034    11  10 Rdy       0:00:02   0.38%        0  screen               pvr_device_wdg
5,584: 86034     2  15 CdV       0:00:00   0.12%        0  screen               screen-dpy-1
5,590: 86034    10  10 CdV       0:00:00   0.11%        0  screen               pvr_defer_free
5,624: 86034     4  10 Rcv       0:00:00   0.06%        0  screen               pvrsrv
5,625: 86034     9  10 Rcv       0:00:00   0.06%        0  screen               screen-msg
5,748: May 15 16:00:59.873                   screen.86034                 slog    300  screen: loading blit module gles2blt...
5,753: May 15 16:01:00.251                   screen.86034                 slog    300  screen: stream 1ac7e3f7e0 already schedule for death row
5,923: May 15 16:01:03.245                   screen.86034                 slog    300  screen: stream 1ac7e3f7e0 already schedule for death row
    Please expect a delay in response due to holiday in US on 27 May 2024.
    Nikhil
    Which operating system are you using? This looks like QNX. Please contact QNX support for questions regarding the GPU driver as we don't have insight into the one they are using.
    If it is Linux, please let me know.
    Erick
  • Hi Erick
    Yes, the operating system is QNX710. QNX engineers suggest ask Ti for help. Do you have any suggestions for the problem?
    As a customer, I am not sure who should be responsible for the GPU driver. If you think QNX should be responsible, please give me and QNX a suitable reason.
    thanks
    QNX owns the GPU driver, they support it themselves and pick a particular version to use. We are not aware of the integration they have done to make it compatible with their operating system. If there is an issue with your application and the QNX operating system, QNX would need to front-end the issue.
    That being said, I have a general guidance for GPU issues seen on Linux in this FAQ: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1218307/faq-how-can-i-analyze-a-gpu-graphics-process-unit-driver-or-hardware-issue
    While this only applies to Linux, QNX may have similar functionality.
    The logs you are seeing are from a GPU hardware recovery (the state of the GPU has degraded during its processing and it has triggered a recovery). There could be a bug-fix you are missing in your GPU drivers.
    Erick
  • hi Erick
    Thank you for your answer
    Based on your above viewpoint, I will push QNX engineers to conduct preliminary analysis. I will forward this link as a reference to QNX.
    What does the GPU degradation state you mentioned mean? Can you provide a technical manual?
    It may take a long time to solve this problem, and I have an additional topic about temporary remedial measures:
    How to release and reload GPU driver and graphics memory on a Linux system?
    thanks
    We have at best the description in the FAQ. Right now, I'm working on releasing an application note describing in more detail the issue, but I can give the summary below.
    The GPU firmware will have checks on the GPU state at different parts of the processing pipeline. If there is a "degradation" such as an unexpected value or an interrupt at the wrong time, the GPU will issue a HWR (self-reset) in order to alleviate the issue. Due to this, it also dumps information about the firmware state at the time of the issue (PVR debug messages).
    The GPU driver can be removed the same way any other driver on Linux is removed, such as with rmmod. I have not tried this and observed the behavior or actively running applications, not sure how it would respond (probably a Kernel panic).
    -If a GPU reset occurs, do we need to destroy and recreate for resources(framebuffer、TEXTURE2D、ImageKHR)?
    No, if a HWR occurs it does not affect the state of the currently bound objects (textures, frambuffers, etc.). If you remove the GPU driver, however, you will need to restart your applications and recreate all of your resources.
    Erick
