Part Number: TDA4VM
HI TI
I want to change the camera and display the captured camera on the dp screen, but I encounter the following error and nothing is displayed on the screen
Terminal commands are shown as follows,
root@j7-evm:~# media-ctl -p
Media controller API version 5.10.162
Media device information
driver j721e-csi2rx
model TI-CSI2RX
serial
bus info platform:4500000.ticsi2rx
hw revision 0x1
driver version 5.10.162
Device topology
- entity 1: 4500000.ticsi2rx (17 pads, 17 links, 1 route)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev3
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
[stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE]
pad1: Source
-> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
pad2: Source
-> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
pad3: Source
-> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
pad4: Source
-> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
pad5: Source
-> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
pad6: Source
-> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
pad7: Source
-> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
pad8: Source
-> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
pad9: Source
-> "4500000.ticsi2rx context 8":0 [ENABLED,IMMUTABLE]
pad10: Source
-> "4500000.ticsi2rx context 9":0 [ENABLED,IMMUTABLE]
pad11: Source
-> "4500000.ticsi2rx context 10":0 [ENABLED,IMMUTABLE]
pad12: Source
-> "4500000.ticsi2rx context 11":0 [ENABLED,IMMUTABLE]
pad13: Source
-> "4500000.ticsi2rx context 12":0 [ENABLED,IMMUTABLE]
pad14: Source
-> "4500000.ticsi2rx context 13":0 [ENABLED,IMMUTABLE]
pad15: Source
-> "4500000.ticsi2rx context 14":0 [ENABLED,IMMUTABLE]
pad16: Source
-> "4500000.ticsi2rx context 15":0 [ENABLED,IMMUTABLE]
- entity 19: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 0 route)
device node name /dev/v4l-subdev4
pad0: Sink
<- "ds90ub960 9-003d":4 [ENABLED,IMMUTABLE]
pad1: Source
-> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE]
pad2: Source
pad3: Source
pad4: Source
- entity 25: ds90ub960 9-003d (6 pads, 2 links, 1 route)
device node name /dev/v4l-subdev5
routes:
0/0 -> 4/0 [ACTIVE]
pad0: Sink
[stream:0 fmt:UYVY8_2X8/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "ds90ub953 9-0044":1 [ENABLED,IMMUTABLE]
pad1: Sink
pad2: Sink
pad3: Sink
pad4: Source
-> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE]
pad5: Source
- entity 34: ds90ub953 9-0044 (2 pads, 2 links, 1 route)
device node name /dev/v4l-subdev6
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "imx390 10-0036":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "ds90ub960 9-003d":0 [ENABLED,IMMUTABLE]
- entity 39: imx390 10-0036 (1 pad, 1 link, 2 routes)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev7
routes:
0/0 -> 0/0 [ACTIVE, IMMUTABLE, SOURCE]
0/0 -> 0/1 [INACTIVE, IMMUTABLE, SOURCE]
pad0: Source
[stream:0 fmt:SRGGB12_1X12/1920x1284@1/30 field:none colorspace:smpte170m]
-> "ds90ub953 9-0044":0 [ENABLED,IMMUTABLE]
- entity 45: 4500000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
type Node subtype V4L flags 0
device node name /dev/video18
pad0: Sink
<- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE]
- entity 51: 4500000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
device node name /dev/video19
pad0: Sink
<- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE]
- entity 57: 4500000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
device node name /dev/video20
pad0: Sink
<- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE]
- entity 63: 4500000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
device node name /dev/video21
pad0: Sink
<- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE]
- entity 69: 4500000.ticsi2rx context 4 (1 pad, 1 link, 0 route)
device node name /dev/video22
pad0: Sink
<- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE]
- entity 75: 4500000.ticsi2rx context 5 (1 pad, 1 link, 0 route)
device node name /dev/video23
pad0: Sink
<- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE]
- entity 81: 4500000.ticsi2rx context 6 (1 pad, 1 link, 0 route)
device node name /dev/video24
pad0: Sink
<- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE]
- entity 87: 4500000.ticsi2rx context 7 (1 pad, 1 link, 0 route)
device node name /dev/video25
pad0: Sink
<- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE]
- entity 93: 4500000.ticsi2rx context 8 (1 pad, 1 link, 0 route)
device node name /dev/video26
pad0: Sink
<- "4500000.ticsi2rx":9 [ENABLED,IMMUTABLE]
- entity 99: 4500000.ticsi2rx context 9 (1 pad, 1 link, 0 route)
device node name /dev/video27
pad0: Sink
<- "4500000.ticsi2rx":10 [ENABLED,IMMUTABLE]
- entity 105: 4500000.ticsi2rx context 10 (1 pad, 1 link, 0 route)
device node name /dev/video28
pad0: Sink
<- "4500000.ticsi2rx":11 [ENABLED,IMMUTABLE]
- entity 111: 4500000.ticsi2rx context 11 (1 pad, 1 link, 0 route)
device node name /dev/video29
pad0: Sink
<- "4500000.ticsi2rx":12 [ENABLED,IMMUTABLE]
- entity 117: 4500000.ticsi2rx context 12 (1 pad, 1 link, 0 route)
device node name /dev/video30
pad0: Sink
<- "4500000.ticsi2rx":13 [ENABLED,IMMUTABLE]
- entity 123: 4500000.ticsi2rx context 13 (1 pad, 1 link, 0 route)
device node name /dev/video31
pad0: Sink
<- "4500000.ticsi2rx":14 [ENABLED,IMMUTABLE]
- entity 129: 4500000.ticsi2rx context 14 (1 pad, 1 link, 0 route)
device node name /dev/video32
pad0: Sink
<- "4500000.ticsi2rx":15 [ENABLED,IMMUTABLE]
- entity 135: 4500000.ticsi2rx context 15 (1 pad, 1 link, 0 route)
device node name /dev/video33
pad0: Sink
<- "4500000.ticsi2rx":16 [ENABLED,IMMUTABLE]
root@j7-evm:~#
eld: none]':~# media-ctl -V '"ds90ub953 9-0044":0 [fmt:SRGGB12_1X12/1920x1284 fie
root@j7-evm:~# media-ctl -R '"ds90ub960 9-003d" [0/0 -> 4/0 [1]]'
eld: none]':~# media-ctl -V '"ds90ub960 9-003d":0 [fmt:SRGGB12_1X12/1920x1284 fie
root@j7-evm:~# media-ctl -R '"4500000.ticsi2rx" [0/0 -> 1/0 [1]]'
root@j7-evm:~# yavta -c8 -f SRGGB12 -s 1936x1284 /dev/video18
Device /dev/video18 opened.
Device `j721e-csi2rx' on `platform:4500000.ticsi2rx' is a video output (without mplanes) device.
Video format set: SRGGB12 (32314752) 1936x1284 (stride 3872) field none buffer size 4971648
Video format: SRGGB12 (32314752) 1936x1284 (stride 3872) field none buffer size 4971648
8 buffers requested.
length: 4971648 offset: 0 timestamp type/source: mono/EoF
Buffer 0/0 mapped at address 0xffff84af5000.
length: 4971648 offset: 4972544 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0xffff84637000.
length: 4971648 offset: 9945088 timestamp type/source: mono/EoF
Buffer 2/0 mapped at address 0xffff84179000.
length: 4971648 offset: 14917632 timestamp type/source: mono/EoF
Buffer 3/0 mapped at address 0xffff83cbb000.
length: 4971648 offset: 19890176 timestamp type/source: mono/EoF
Buffer 4/0 mapped at address 0xffff837fd000.
length: 4971648 offset: 24862720 timestamp type/source: mono/EoF
Buffer 5/0 mapped at address 0xffff8333f000.
length: 4971648 offset: 29835264 timestamp type/source: mono/EoF
Buffer 6/0 mapped at address 0xffff82e81000.
length: 4971648 offset: 34807808 timestamp type/source: mono/EoF
Buffer 7/0 mapped at address 0xffff829c3000.
0 (0) [-] any 0 4971648 B 455.138670 455.138684 44.585 fps ts mono/EoF
1 (1) [-] any 1 4971648 B 455.155237 455.155245 60.361 fps ts mono/EoF
2 (2) [-] any 2 4971648 B 455.171815 455.171823 60.321 fps ts mono/EoF
3 (3) [-] any 3 4971648 B 455.188394 455.188400 60.317 fps ts mono/EoF
4 (4) [-] any 4 4971648 B 455.204972 455.204979 60.321 fps ts mono/EoF
5 (5) [-] any 5 4971648 B 455.221549 455.221556 60.325 fps ts mono/EoF
6 (6) [-] any 6 4971648 B 455.238128 455.238134 60.317 fps ts mono/EoF
7 (7) [-] any 7 4971648 B 455.254706 455.254712 60.321 fps ts mono/EoF
Captured 8 frames in 0.138470 seconds (57.773970 fps, 287231840.765696 B/s).
8 buffers released.
=1920, height=1284, format=UYVY ! autovideosinkdev/video18" ! video/x-raw, width=
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:10.449361130
Setting pipeline to NULL ...
Freeing pipeline ...
root@j7-evm:~# gst-launch-1.0 v4l2src device="/dev/video18" ! video/x-raw, widt
