AM625-Q1: u-boot & kernel porting
Part Number: AM625-Q1
Hi Team,
Kindly assist us on Uboot and kernel Porting guide for a Customboard using AM625-Q1. Till now We have bypassed the do_board_detect on uboot & we were able to Kernel using hello_world_dts but our kernel stop at platform 40900000.crypto: deferred probe pending.
Thank you
Karthik
  • Hi Karthik,
    Please attach the full console boot log.
  • Hi Bin Liu,
    Please Find the full console boot log
    U-Boot SPL 2023.04-ti-gd2612223375a (Feb 01 2024 - 15:06:40 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 15:06:40, Feb  1 2024
    SPL initial stack usage: 1904 bytes
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@22: Error reading output register
    U-Boot 2023.04-ti-gd2612223375a (Feb 01 2024 - 15:06:40 +0000)
    SoC:   AM62X SR1.0 HS-FS
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -1
    DRAM:  2 GiB
    Core:  72 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    24146432 bytes read in 1009 ms (22.8 MiB/s)
    29927 bytes read in 26 ms (1.1 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008fef5000, end 000000008fffffff ... OK
    Working FDT set to 8fef5000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.876.1.80-Raptee-gbaa5206ae7ff (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.000000] Machine model: Texas Instruments AM625 Generic
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009cafffff]
    [    0.000000]   node   0: [mem 0x000000009cb00000-0x000000009d9fffff]
    [    0.000000]   node   0: [mem 0x000000009da00000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a01fffff]
    [    0.000000]   node   0: [mem 0x00000000a0200000-0x00000000a0ffffff]
    [    0.000000]   node   0: [mem 0x00000000a1000000-0x00000000a103ffff]
    [    0.000000]   node   0: [mem 0x00000000a1040000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000fffeffff]
    [    0.000000]   node   0: [mem 0x00000000ffff0000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 29 pages/cpu s78056 r8192 d32536 u118784
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation forced OFF by mitigations=off
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=07e1c071-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1849776K/2097152K available (13312K kernel code, 2204K rwdata, 4808K rodata, 3136K init, 475K bss, 116304K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] trace event string verifier disabled
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000000800d0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000800e0000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008540] Console: colour dummy device 80x25
    [    0.013152] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023835] pid_max: default: 32768 minimum: 301
    [    0.028627] LSM: Security Framework initializing
    [    0.033388] LSM support for eBPF active
    [    0.037427] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045010] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054256] spectre-v4 mitigation disabled by command-line option
    [    0.061365] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068793] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075096] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082495] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088946] rcu: Hierarchical SRCU implementation.
    [    0.093857] rcu:     Max phase no-delay instances is 1000.
    [    0.099665] Platform MSI: msi-controller@1820000 domain created
    [    0.105876] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115152] EFI services will not be available.
    [    0.120028] smp: Bringing up secondary CPUs ...
    [    0.125466] Detected VIPT I-cache on CPU1
    [    0.125591] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125615] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125679] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125832] smp: Brought up 1 node, 2 CPUs
    [    0.155256] SMP: Total of 2 processors activated.
    [    0.160069] CPU features: detected: 32-bit EL0 Support
    [    0.165348] CPU features: detected: CRC32 instructions
    [    0.170664] CPU: All CPU(s) started at EL2
    [    0.174854] alternatives: applying system-wide alternatives
    [    0.182854] devtmpfs: initialized
    [    0.192095] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.202117] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.214900] pinctrl core: initialized pinctrl subsystem
    [    0.221055] DMI not present or invalid.
    [    0.225788] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233249] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240656] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.248740] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.256928] audit: initializing netlink subsys (disabled)
    [    0.262773] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263381] thermal_sys: Registered thermal governor 'step_wise'
    [    0.270726] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.277090] cpuidle: using governor menu
    [    0.287969] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.294981] ASID allocator initialised with 65536 entries
    [    0.305360] KASLR disabled due to lack of seed
    [    0.318120] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.325116] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.331586] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.338528] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.344937] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.351876] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.358285] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.365228] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.375233] iommu: Default domain type: Translated
    [    0.380295] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.387224] SCSI subsystem initialized
    [    0.391525] usbcore: registered new interface driver usbfs
    [    0.397189] usbcore: registered new interface driver hub
    [    0.402657] usbcore: registered new device driver usb
    [    0.408152] pps_core: LinuxPPS API ver. 1 registered
    [    0.413233] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.422583] PTP clock support registered
    [    0.426680] EDAC MC: Ver: 3.0.0
    [    0.430878] FPGA manager framework
    [    0.434471] Advanced Linux Sound Architecture Driver Initialized.
    [    0.441950] clocksource: Switched to clocksource arch_sys_counter
    [    0.448674] VFS: Disk quotas dquot_6.6.0
    [    0.452803] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.466388] NET: Registered PF_INET protocol family
    [    0.471740] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.481120] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.489981] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.497929] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.506149] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.514295] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.521246] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.528163] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.535727] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.542211] RPC: Registered named UNIX socket transport module.
    [    0.548286] RPC: Registered udp transport module.
    [    0.553107] RPC: Registered tcp transport module.
    [    0.557917] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.564513] NET: Registered PF_XDP protocol family
    [    0.569432] PCI: CLS 0 bytes, default 64
    [    0.574250] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.584214] Initialise system trusted keyrings
    [    0.589129] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.600597] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.607335] NFS: Registering the id_resolver key type
    [    0.612552] Key type id_resolver registered
    [    0.616852] Key type id_legacy registered
    [    0.621023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.627887] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.671118] NET: Registered PF_ALG protocol family
    [    0.676033] Key type asymmetric registered
    [    0.680220] Asymmetric key parser 'x509' registered
    [    0.685276] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.693102] io scheduler mq-deadline registered
    [    0.697742] io scheduler kyber registered
    [    0.703821] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.710258] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.721262] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.737165] loop: module loaded
    [    0.741263] megasas: 07.719.03.00-rc1
    [    0.747929] tun: Universal TUN/TAP device driver, 1.6
    [    0.753713] VFIO - User Level meta-driver version: 0.3
    [    0.759717] usbcore: registered new interface driver usb-storage
    [    0.766031] usbcore: registered new interface driver usbserial_generic
    [    0.772729] usbserial: USB Serial support registered for generic
    [    0.778902] usbcore: registered new interface driver cp210x
    [    0.784615] usbserial: USB Serial support registered for cp210x
    [    0.791282] i2c_dev: i2c /dev entries driver
    [    0.795712] usbcore: registered new interface driver i2c-tiny-usb
    [    0.802635] sdhci: Secure Digital Host Controller Interface driver
    [    0.808967] sdhci: Copyright(c) Pierre Ossman
    [    0.813585] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.819778] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.826095] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.832990] usbcore: registered new interface driver usbhid
    [    0.838693] usbhid: USB HID core driver
    [    0.843340] optee: probing for conduit method.
    [    0.847940] optee: revision 4.1 (012cdca4)
    [    0.848290] optee: dynamic shared memory is enabled
    [    0.857927] optee: initialized driver
    [    0.862586] usbcore: registered new interface driver snd-usb-audio
    [    0.869655] Initializing XFRM netlink socket
    [    0.874082] NET: Registered PF_PACKET protocol family
    [    0.879352] Key type dns_resolver registered
    [    0.884532] registered taskstats version 1
    [    0.888808] Loading compiled-in X.509 certificates
    [    0.902515] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.916321] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.933042] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    0.943100] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.949711] omap8250 2800000.serial: failed to get alias
    [    0.956449] mmc1: CQHCI version 5.10
    [    1.005105] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.046999] mmc1: new high speed SDXC card at address 0001
    [    1.053643] mmcblk1: mmc1:0001 SD 58.2 GiB
    [    1.061158]  mmcblk1: p1 p2
    [    1.135851] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.146729] ALSA device list:
    [    1.149762]   No soundcards found.
    [    1.153352] Warning: unable to open an initial console.
    [    1.562921] EXT4-fs (mmcblk1p2): recovery complete
    [    1.590682] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.599543] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.607708] devtmpfs: mounted
    [    1.613097] Freeing unused kernel memory: 3136K
    [    1.617999] Run /sbin/init as init process
    [    2.318865] systemd[1]: System time before build time, advancing clock.
    [    2.435395] NET: Registered PF_INET6 protocol family
    [    2.441927] Segment Routing with IPv6
    [    2.445764] In-situ OAM (IOAM) with IPv6
    [    2.574326] systemd[1]: systemd 255.4^ running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.607029] systemd[1]: Detected architecture arm64.
    [    2.627057] systemd[1]: Hostname set to <am62xx-evm>.
    [    3.405269] systemd[1]: Queued start job for default target Multi-User System.
    [    3.447432] systemd[1]: Created slice Slice /system/getty.
    [    3.455972] systemd[1]: Created slice Slice /system/modprobe.
    [    3.464377] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.472324] systemd[1]: Created slice User and Session Slice.
    [    3.478837] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.487304] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.495219] systemd[1]: Expecting device /dev/disk/by-uuid/A350-7496...
    [    3.502234] systemd[1]: Reached target Path Units.
    [    3.507246] systemd[1]: Reached target Remote File Systems.
    [    3.513035] systemd[1]: Reached target Slice Units.
    [    3.518123] systemd[1]: Reached target Swaps.
    [    3.532439] systemd[1]: Listening on Process Core Dump Socket.
    [    3.539185] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.547713] systemd[1]: Listening on Journal Audit Socket.
    [    3.554405] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.561369] systemd[1]: Listening on Journal Socket.
    [    3.567597] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.577619] systemd[1]: Listening on udev Control Socket.
    [    3.584110] systemd[1]: Listening on udev Kernel Socket.
    [    3.590443] systemd[1]: Listening on User Database Manager Socket.
    [    3.618619] systemd[1]: Mounting Huge Pages File System...
    [    3.631029] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.643520] systemd[1]: Mounting Kernel Debug File System...
    [    3.702991] systemd[1]: Mounting Kernel Trace File System...
    [    3.726819] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.748707] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.762610] systemd[1]: Starting Load Kernel Module configfs...
    [    3.823240] systemd[1]: Starting Load Kernel Module drm...
    [    3.840706] systemd[1]: Starting Load Kernel Module fuse...
    [    3.870289] systemd[1]: Starting SELinux autorelabel service loading...
    [    3.886991] systemd[1]: Starting SELinux init for /dev service loading...
    [    3.899536] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.931897] systemd[1]: Starting Journal Service...
    [    3.964008] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    3.977684] fuse: init (API version 7.37)
    [    4.007475] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.039750] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.099416] systemd[1]: Starting Apply Kernel Variables...
    [    4.147786] systemd-journald[147]: Collecting audit messages is enabled.
    [    4.171406] systemd[1]: Starting Coldplug All udev Devices...
    [    4.269894] systemd[1]: Started Journal Service.
    [    4.275897] audit: type=1130 audit(1706800001.952:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.280143] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    4.325633] audit: type=1130 audit(1706800002.000:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.345535] audit: type=1130 audit(1706800002.020:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.365437] audit: type=1131 audit(1706800002.020:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.386654] audit: type=1130 audit(1706800002.040:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.406433] audit: type=1131 audit(1706800002.040:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.457671] audit: type=1130 audit(1706800002.060:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.482547] audit: type=1131 audit(1706800002.060:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.501847] audit: type=1130 audit(1706800002.084:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.745381] systemd-journald[147]: Received client request to flush runtime journal.
    [    5.365221] kauditd_printk_skb: 14 callbacks suppressed
    [    5.365239] audit: type=1334 audit(1706800003.040:25): prog-id=9 op=LOAD
    [    5.390142] audit: type=1334 audit(1706800003.052:26): prog-id=10 op=LOAD
    [    5.405882] audit: type=1334 audit(1706800003.056:27): prog-id=11 op=LOAD
    [    5.865711] audit: type=1130 audit(1706800003.540:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-userdbd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.433358] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    6.591602] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.608594] audit: type=1130 audit(1706800004.284:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.654609] audit: type=1131 audit(1706800004.304:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.666960] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.693146] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    6.720268] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.732733] cfg80211: failed to load regulatory.db
    [    6.816300] audit: type=1130 audit(1706800004.492:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.877208] audit: type=1130 audit(1706800004.552:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.901150] random: crng init done
    [    6.946742] audit: type=1334 audit(1706800004.624:33): prog-id=12 op=LOAD
    [    7.005094] audit: type=1130 audit(1706800004.680:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   17.023594] platform 600000.gpio: deferred probe pending
    [   17.029103] platform 601000.gpio: deferred probe pending
    [   17.034556] platform regulator-3: deferred probe pending
    [   17.040025] platform regulator-4: deferred probe pending
    [   17.045483] platform 40900000.crypto: deferred probe pending
    Device tree
    // SPDX-License-Identifier: GPL-2.0
     * AM625 Minimal dts file
     * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include <dt-bindings/gpio/gpio.h>
    #include "k3-am625.dtsi"
    	compatible =  "ti,am625-generic", "ti,am625";
    	model = "Texas Instruments AM625 Generic";
    		aliases {
    				gpio0 = &main_gpio0;
    				gpio1 = &main_gpio1;
    				gpio2 = &mcu_gpio0;
    				i2c0 = &main_i2c0;
    				i2c1 = &main_i2c1;
    				i2c2 = &main_i2c2;
    				i2c3 = &main_i2c3;
    				i2c4 = &wkup_i2c0;
    				i2c5 = &mcu_i2c0;
    				mmc0 = &sdhci0;
    				mmc1 = &sdhci1;
    				mmc2 = &sdhci2;
    	opp-table {
    		/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
    		opp-1400000000 {
    			opp-hz = /bits/ 64 <1400000000>;
    			opp-supported-hw = <0x01 0x0004>;
    			clock-latency-ns = <6000000>;
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    	cpus {
    		/delete-node/ cpu@2;
    		/delete-node/ cpu@3;
    	memory@80000000 {
    		device_type = "memory";
    		/* 2G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
    	reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		/* global cma region */
    		linux,cma {
    			compatible = "shared-dma-pool";
    			reusable;
    			size = <0x00 0x8000000>;
    			linux,cma-default;
    		mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
    			reg = <0x00 0x9cb00000 0x00 0x100000>;
    			no-map;
    		mcu_m4fss_memory_region: m4f-memory@9cc00000 {
    			reg = <0x00 0x9cc00000 0x00 0xe00000>;
    			no-map;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			alignment = <0x1000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    			no-map;
    		main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
    			reg = <0x00 0xa0000000 0x00 0x200000>;
    			no-map;
    		lpm_ctx_ddr: lpm-memory@a1000000 {
    			reg = <0x00 0xa1000000 0x00 0x40000>;
    			no-map;
    	vmain_pd: regulator-0 {
    		/* TPS65988 PD CONTROLLER OUTPUT */
    		compatible = "regulator-fixed";
    		regulator-name = "vmain_pd";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vcc_5v0: regulator-1 {
    		/* Output of LM34936 */
    		regulator-name = "vcc_5v0";
    		vin-supply = <&vmain_pd>;
    		regulator-boot-on;
    	vcc_3v3_sys: regulator-2 {
    		/* output of LM61460-Q1 */
    		regulator-name = "vcc_3v3_sys";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-boot-on;
    	vdd_mmc1: regulator-3 {
    		/* TPS22918DBVR */
    		regulator-name = "vdd_mmc1";
    		pinctrl-names = "default";
    		pinctrl-0 = <&vdd_sd_dv_pins_default>;
    		enable-active-high;
    		vin-supply = <&vcc_3v3_sys>;
    		gpio = <&main_gpio0 76 GPIO_ACTIVE_HIGH>;
    	vdd_sd_dv: regulator-4 {
    		/* Output of TLV71033 */
    		compatible = "regulator-gpio";
    		regulator-name = "tlv71033";
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		vin-supply = <&ldo1_reg>;
    		gpios = <&main_gpio0 40 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0>,
    			 <3300000 0x1>;
    	vcc_1v8: regulator-5 {
    		/* output of TPS6282518DMQ */
    		regulator-name = "vcc_1v8";
    		regulator-max-microvolt = <1800000>;
    		regulator-boot-on;
    	vdd_core: regulator-8 {
    		/* output of TPS62826DMQ */
    		regulator-name = "vdd_core";
    		regulator-min-microvolt = <850000>;
    		regulator-max-microvolt = <850000>;
    		regulator-boot-on;
    &cluster0 {
    	/delete-node/ core2;
    	/delete-node/ core3;
    &main_pmx0 {
    	main_uart0_pins_default: main-uart0-pins-default {
    		pinctrl-single,pins = <
    			AM62X_IOPAD(0x1d0, PIN_INPUT, 0) /* (A15) UART0_CTSn */
    			AM62X_IOPAD(0x1d4, PIN_OUTPUT, 0) /* (B15) UART0_RTSn */
    			AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
    			AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    	main_uart1_pins_default: main-uart1-pins-default {
    			AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */
    			AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */
    			AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */
    			AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */
    	vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
    			AM62X_IOPAD(0x00a4, PIN_INPUT, 7) /* (J19) GPMC0_DIR.GPIO0_40 */
    			AM62X_IOPAD(0x0138, PIN_INPUT, 7) /* (AA19) RGMII1_TD1.GPIO0_76 */
    	main_mmc1_pins_default: main-mmc1-pins-default {
    			AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */
    			AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */
    			AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */
    			AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */
    			AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */
    			AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */
    			AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */
    	pmic_irq_pins_default: pmic-irq-pins-default {
    			AM62X_IOPAD(0x01f4, PIN_INPUT, 7) /* (B16) EXTINTn.GPIO1_31 */
    	local_i2c_pins_default: local-i2c-pins-default {
    			AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (E12) I2C0_SCL */
    			AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (D14) I2C0_SDA */
    &mcu_pmx0 {
    	wkup_uart0_pins_default: wkup-uart0-pins-default {
    			AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6) WKUP_UART0_CTSn */
    			AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */
    			AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4) WKUP_UART0_RXD */
    			AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */
    &oc_sram {
    	status = "disabled";
    &main_uart0 {
    	pinctrl-0 = <&main_uart0_pins_default>;
    &main_uart1 {
            pinctrl-0 = <&main_uart1_pins_default>;
            /* Main UART1 is used by TIFS firmware */
    	status = "reserved";
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_i2c0 {
    	pinctrl-0 = <&local_i2c_pins_default>;
    	clock-frequency = <400000>;
    	status = "okay";
    	tps65219: pmic@30 {
    		compatible = "ti,tps65219";
    		reg = <0x30>;
    		buck1-supply = <&vmain_pd>;
    		buck2-supply = <&vmain_pd>;
    		buck3-supply = <&vmain_pd>;
    		ldo1-supply = <&vcc_3v3_sys>;
    		ldo2-supply = <&buck2_reg>;
    		ldo3-supply = <&vcc_3v3_sys>;
    		ldo4-supply = <&vcc_3v3_sys>;
    		pinctrl-0 = <&pmic_irq_pins_default>;
    		interrupt-parent = <&gic500>;
    		interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-controller;
    		#interrupt-cells = <1>;
    		system-power-controller;
    		ti,power-button;
    		regulators {
    			buck1_reg: buck1 {
    				regulator-name = "VDD_CORE";
    				regulator-boot-on;
    			buck2_reg: buck2 {
    				regulator-name = "VDD_1V8";
    				regulator-boot-on;
    			buck3_reg: buck3 {
    				regulator-name = "VDD_1V2";
    				regulator-min-microvolt = <1200000>;
    				regulator-max-microvolt = <1200000>;
    				regulator-boot-on;
    			ldo1_reg: ldo1 {
    				 * Regulator is left as is unused, vdd_sd
    				 * is controlled via GPIO with bypass config
    				 * as per the NVM configuration
    				regulator-name = "VDD_SD_3V3";
    				regulator-allow-bypass;
    				regulator-boot-on;
    			ldo2_reg: ldo2 {
    				regulator-name = "VDDA_0V85";
    				regulator-boot-on;
    			ldo3_reg: ldo3 {
    				regulator-name = "VDDA_1V8";
    				regulator-boot-on;
    			ldo4_reg: ldo4 {
    				regulator-name = "VDD_2V5";
    				regulator-min-microvolt = <2500000>;
    				regulator-max-microvolt = <2500000>;
    				regulator-boot-on;
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_gpio_intr {
    &main_gpio0 {
    	status = "okay";
    &main_gpio1 {
    	status = "okay";
    &sdhci0 {
    &sdhci1 {
    	/* SD/MMC */
    	status = "okay";
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    	no-1-8-v; /* disabling all the UHS modes */
    &sdhci2 {
    &fss {
    &ospi0 {
    &main_conf {
    &inta_main_dmss {
    &main_bcdma {
    &main_pktdma {
    &cpsw3g {
    /* MCU periperhals */
    &mcu_uart0 {
    &mcu_i2c0 {
    &mcu_gpio_intr {
    &mcu_gpio0 {
    /* WKUP periperhals */
    &wkup_conf {
    &chipid {
    /* wkup_uart0 is reserved for firmware usage */
    &wkup_uart0 {
            pinctrl-0 = <&wkup_uart0_pins_default>;
            /* WKUP UART0 is used by DM firmware */
    &wkup_i2c0 {
    &hwspinlock {
    &mailbox0_cluster0 {
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
  • Hi Harthik,
    &main_gpio_intr {
    &main_bcdma {
    &main_pktdma {
    Please enable the 3 nodes above, which should resolve the deferred probing issue.
  • Hi Bin,
    Please find the attached boot log after enabling the nodes
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    24146432 bytes read in 1005 ms (22.9 MiB/s)
    29915 bytes read in 27 ms (1.1 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 6.1.876.1.80-Raptee-gb33a27e38578 (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.008552] Console: colour dummy device 80x25
    [    0.013164] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023853] pid_max: default: 32768 minimum: 301
    [    0.028647] LSM: Security Framework initializing
    [    0.033414] LSM support for eBPF active
    [    0.037450] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045034] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054274] spectre-v4 mitigation disabled by command-line option
    [    0.061367] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068803] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075109] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082507] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088945] rcu: Hierarchical SRC
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    24146432 bytes read in 1004 ms (22.9 MiB/s)
    29915 bytes read in 28 ms (1 MiB/s)
    Starting kernel ...
    [    0.008560] Console: colour dummy device 80x25
    [    0.013172] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023856] pid_max: default: 32768 minimum: 301
    [    0.028638] LSM: Security Framework initializing
    [    0.033406] LSM support for eBPF active
    [    0.037437] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054262] spectre-v4 mitigation disabled by command-line option
    [    0.061313] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068743] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075059] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082454] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088890] rcu: Hierarchical SRCU implementation.
    [    0.093800] rcu:     Max phase no-delay instances is 1000.
    [    0.099619] Platform MSI: msi-controller@1820000 domain created
    [    0.105831] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115114] EFI services will not be available.
    [    0.119985] smp: Bringing up secondary CPUs ...
    [    0.125434] Detected VIPT I-cache on CPU1
    [    0.125564] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125583] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125654] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125808] smp: Brought up 1 node, 2 CPUs
    [    0.155231] SMP: Total of 2 processors activated.
    [    0.160052] CPU features: detected: 32-bit EL0 Support
    [    0.165331] CPU features: detected: CRC32 instructions
    [    0.170649] CPU: All CPU(s) started at EL2
    [    0.174838] alternatives: applying system-wide alternatives
    [    0.182802] devtmpfs: initialized
    [    0.192073] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.202102] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.214909] pinctrl core: initialized pinctrl subsystem
    [    0.221059] DMI not present or invalid.
    [    0.225787] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233252] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240674] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.248762] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.256946] audit: initializing netlink subsys (disabled)
    [    0.262814] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263425] thermal_sys: Registered thermal governor 'step_wise'
    [    0.270765] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.277129] cpuidle: using governor menu
    [    0.288013] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.295017] ASID allocator initialised with 65536 entries
    [    0.305994] KASLR disabled due to lack of seed
    [    0.318670] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.325653] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.332083] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.339076] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.345490] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.352430] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.358838] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.365777] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.375823] iommu: Default domain type: Translated
    [    0.380892] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.387762] SCSI subsystem initialized
    [    0.392043] usbcore: registered new interface driver usbfs
    [    0.397704] usbcore: registered new interface driver hub
    [    0.403178] usbcore: registered new device driver usb
    [    0.408689] pps_core: LinuxPPS API ver. 1 registered
    [    0.413769] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.423134] PTP clock support registered
    [    0.427243] EDAC MC: Ver: 3.0.0
    [    0.431465] FPGA manager framework
    [    0.435039] Advanced Linux Sound Architecture Driver Initialized.
    [    0.442504] clocksource: Switched to clocksource arch_sys_counter
    [    0.449220] VFS: Disk quotas dquot_6.6.0
    [    0.453336] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.466952] NET: Registered PF_INET protocol family
    [    0.472303] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.481678] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.490547] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.498486] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.506714] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.514859] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.521812] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.528732] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.536301] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.542791] RPC: Registered named UNIX socket transport module.
    [    0.548881] RPC: Registered udp transport module.
    [    0.553690] RPC: Registered tcp transport module.
    [    0.558497] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.565088] NET: Registered PF_XDP protocol family
    [    0.570001] PCI: CLS 0 bytes, default 64
    [    0.574819] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.584819] Initialise system trusted keyrings
    [    0.589701] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.601244] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.607974] NFS: Registering the id_resolver key type
    [    0.613218] Key type id_resolver registered
    [    0.617518] Key type id_legacy registered
    [    0.621681] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.628549] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.671483] NET: Registered PF_ALG protocol family
    [    0.676409] Key type asymmetric registered
    [    0.680597] Asymmetric key parser 'x509' registered
    [    0.685667] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.693492] io scheduler mq-deadline registered
    [    0.698132] io scheduler kyber registered
    [    0.704321] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.710740] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.718608] ti-bcdma 485c0100.dma-controller: No compatible SoC found
    [    0.725343] ti-pktdma 485c0000.dma-controller: No compatible SoC found
    [    0.735419] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.751372] loop: module loaded
    [    0.755475] megasas: 07.719.03.00-rc1
    [    0.762121] tun: Universal TUN/TAP device driver, 1.6
    [    0.767923] VFIO - User Level meta-driver version: 0.3
    [    0.773936] usbcore: registered new interface driver usb-storage
    [    0.780248] usbcore: registered new interface driver usbserial_generic
    [    0.786960] usbserial: USB Serial support registered for generic
    [    0.793129] usbcore: registered new interface driver cp210x
    [    0.798842] usbserial: USB Serial support registered for cp210x
    [    0.805498] i2c_dev: i2c /dev entries driver
    [    0.809923] usbcore: registered new interface driver i2c-tiny-usb
    [    0.816842] sdhci: Secure Digital Host Controller Interface driver
    [    0.823173] sdhci: Copyright(c) Pierre Ossman
    [    0.827797] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.833999] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.840295] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.847203] usbcore: registered new interface driver usbhid
    [    0.852904] usbhid: USB HID core driver
    [    0.857554] optee: probing for conduit method.
    [    0.862142] optee: revision 4.1 (012cdca4)
    [    0.862468] optee: dynamic shared memory is enabled
    [    0.872097] optee: initialized driver
    [    0.876771] usbcore: registered new interface driver snd-usb-audio
    [    0.883835] Initializing XFRM netlink socket
    [    0.888265] NET: Registered PF_PACKET protocol family
    [    0.893551] Key type dns_resolver registered
    [    0.898789] registered taskstats version 1
    [    0.903035] Loading compiled-in X.509 certificates
    [    0.916911] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.930766] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.946654] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    0.956643] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.962948] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.972471] omap8250 2800000.serial: failed to get alias
    [    0.979193] mmc1: CQHCI version 5.10
    [    1.022514] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.064361] mmc1: new high speed SDXC card at address 0001
    [    1.071012] mmcblk1: mmc1:0001 SD 58.2 GiB
    [    1.078575]  mmcblk1: p1 p2
    [    1.140215] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.151099] ALSA device list:
    [    1.154134]   No soundcards found.
    [    1.157735] Warning: unable to open an initial console.
    [    1.714191] EXT4-fs (mmcblk1p2): recovery complete
    [    1.722233] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.731093] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.739252] devtmpfs: mounted
    [    1.744713] Freeing unused kernel memory: 3136K
    [    1.749499] Run /sbin/init as init process
    [    2.405740] systemd[1]: System time before build time, advancing clock.
    [    2.520411] NET: Registered PF_INET6 protocol family
    [    2.527021] Segment Routing with IPv6
    [    2.530862] In-situ OAM (IOAM) with IPv6
    [    2.644984] systemd[1]: systemd 255.4^ running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.677697] systemd[1]: Detected architecture arm64.
    [    2.688474] systemd[1]: Hostname set to <am62xx-evm>.
    [    3.448548] systemd[1]: Queued start job for default target Multi-User System.
    [    3.492024] systemd[1]: Created slice Slice /system/getty.
    [    3.500431] systemd[1]: Created slice Slice /system/modprobe.
    [    3.508802] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.516730] systemd[1]: Created slice User and Session Slice.
    [    3.523233] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.531723] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.539651] systemd[1]: Expecting device /dev/disk/by-uuid/AF1F-8E36...
    [    3.546722] systemd[1]: Reached target Path Units.
    [    3.551778] systemd[1]: Reached target Remote File Systems.
    [    3.557560] systemd[1]: Reached target Slice Units.
    [    3.562667] systemd[1]: Reached target Swaps.
    [    3.577110] systemd[1]: Listening on Process Core Dump Socket.
    [    3.583781] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.592338] systemd[1]: Listening on Journal Audit Socket.
    [    3.599066] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.606040] systemd[1]: Listening on Journal Socket.
    [    3.612278] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.622325] systemd[1]: Listening on udev Control Socket.
    [    3.628848] systemd[1]: Listening on udev Kernel Socket.
    [    3.635214] systemd[1]: Listening on User Database Manager Socket.
    [    3.671211] systemd[1]: Mounting Huge Pages File System...
    [    3.682754] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.695416] systemd[1]: Mounting Kernel Debug File System...
    [    3.731591] systemd[1]: Mounting Kernel Trace File System...
    [    3.774678] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.790380] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.818929] systemd[1]: Starting Load Kernel Module configfs...
    [    3.877249] systemd[1]: Starting Load Kernel Module drm...
    [    3.889597] systemd[1]: Starting Load Kernel Module fuse...
    [    3.905215] systemd[1]: Starting SELinux autorelabel service loading...
    [    3.940269] systemd[1]: Starting SELinux init for /dev service loading...
    [    3.955349] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.987105] fuse: init (API version 7.37)
    [    4.001786] systemd[1]: Starting Journal Service...
    [    4.020844] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    4.055798] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.088078] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.167794] systemd[1]: Starting Apply Kernel Variables...
    [    4.196525] systemd-journald[146]: Collecting audit messages is enabled.
    [    4.220826] systemd[1]: Starting Coldplug All udev Devices...
    [    4.240538] systemd[1]: Mounted Huge Pages File System.
    [    4.249737] systemd[1]: Mounted POSIX Message Queue File System.
    [    4.257636] systemd[1]: Mounted Kernel Debug File System.
    [    4.265047] systemd[1]: Mounted Kernel Trace File System.
    [    4.283531] systemd[1]: Mounted Temporary Directory /tmp.
    [    4.300934] systemd[1]: Finished Create List of Static Device Nodes.
    [    4.315383] audit: type=1130 audit(1706800001.908:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.317095] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    4.350398] systemd[1]: Finished Load Kernel Module configfs.
    [    4.359691] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    4.367765] systemd[1]: Finished Load Kernel Module drm.
    [    4.383885] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    4.386646] audit: type=1130 audit(1706800001.948:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.391953] systemd[1]: Finished Load Kernel Module fuse.
    [    4.419488] systemd[1]: Started Journal Service.
    [    4.446162] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    4.479635] audit: type=1131 audit(1706800001.948:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.535350] audit: type=1130 audit(1706800001.964:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.570657] audit: type=1131 audit(1706800001.964:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.590486] audit: type=1130 audit(1706800002.008:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.616111] audit: type=1131 audit(1706800002.008:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.616781] audit: type=1130 audit(1706800002.016:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.617094] audit: type=1130 audit(1706800002.020:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.944980] systemd-journald[146]: Received client request to flush runtime journal.
    [    5.370082] kauditd_printk_skb: 12 callbacks suppressed
    [    5.370107] audit: type=1130 audit(1706800002.960:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.411278] audit: type=1334 audit(1706800002.968:24): prog-id=8 op=LOAD
    [    5.530421] audit: type=1334 audit(1706800003.120:25): prog-id=9 op=LOAD
    [    5.543210] audit: type=1334 audit(1706800003.132:26): prog-id=10 op=LOAD
    [    5.562282] audit: type=1334 audit(1706800003.132:27): prog-id=11 op=LOAD
    [    5.914762] audit: type=1130 audit(1706800003.504:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-userdbd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.362575] random: crng init done
    [    6.400072] audit: type=1130 audit(1706800003.992:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.509109] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    6.547210] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.598162] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.606023] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    6.619236] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.634470] cfg80211: failed to load regulatory.db
    [    6.754290] audit: type=1130 audit(1706800004.340:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.776209] audit: type=1131 audit(1706800004.344:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.795369] audit: type=1130 audit(1706800004.344:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   17.279332] platform regulator-4: deferred probe pending
    [   17.284833] platform 40900000.crypto: deferred probe pending
    device tree
    /dts-v1/;
    		aliases {
    				gpio2 = &mcu_gpio0;
    				i2c0 = &main_i2c0;
    				i2c1 = &main_i2c1;
    				i2c2 = &main_i2c2;
    				i2c3 = &main_i2c3;
    				i2c4 = &wkup_i2c0;
    				i2c5 = &mcu_i2c0;
    				mmc0 = &sdhci0;
    				mmc1 = &sdhci1;
    				mmc2 = &sdhci2;
    	opp-table {
    		opp-1400000000 {
    	chosen {
    	cpus {
    	memory@80000000 {
    		/* 2G RAM */
    	reserved-memory {
    		#size-cells = <2>;
    		ranges;
    		linux,cma {
    			reusable;
    			linux,cma-default;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    		regulator-boot-on;
    		regulator-boot-on;
    		regulator-boot-on;
    		/* TPS22918DBVR */
    		enable-active-high;
    		regulator-boot-on;
    			 <3300000 0x1>;
    		regulator-boot-on;
    		regulator-boot-on;
    &cluster0 {
    &main_pmx0 {
    &mcu_pmx0 {
    &oc_sram {
    &main_uart0 {
    &main_uart1 {
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_i2c0 {
    	status = "okay";
    	tps65219: pmic@30 {
    		reg = <0x30>;
    		ti,power-button;
    		regulators {
    			buck1_reg: buck1 {
    				regulator-boot-on;
    			buck2_reg: buck2 {
    				regulator-boot-on;
    			buck3_reg: buck3 {
    				regulator-boot-on;
    			ldo1_reg: ldo1 {
    				regulator-boot-on;
    			ldo2_reg: ldo2 {
    				regulator-boot-on;
    			ldo3_reg: ldo3 {
    				regulator-boot-on;
    			ldo4_reg: ldo4 {
    				regulator-boot-on;
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_gpio_intr {
    	status = "okay";
    &main_gpio0 {
    	status = "okay";
    &main_gpio1 {
    	status = "okay";
    &sdhci0 {
    &sdhci1 {
    	/* SD/MMC */
    	status = "okay";
    	disable-wp;
    &sdhci2 {
    &fss {
    &ospi0 {
    &main_conf {
    &inta_main_dmss {
    &main_bcdma {
    	status = "okay";
    &main_pktdma {
    	status = "okay";
    &cpsw3g {
    &mcu_uart0 {
    &mcu_i2c0 {
    &mcu_gpio_intr {
    &mcu_gpio0 {
    &wkup_conf {
    &chipid {
    &wkup_uart0 {
    &wkup_i2c0 {
    &hwspinlock {
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
    Update:
  • &inta_main_dmss {
    Please enable this node above as well.
    By the way, when attaching logs or files, please attach the original file, not copy&paste to the code block, by clicking "Insert -> Image/Video/File" below, then click the grey "Upload" text under the "File/URL" box.
  • Hi Bin,
    Please find the attached console boot log after enabling the node
    U-Boot SPL 2023.04-ti-gf9b966c67473 (Feb 01 2024 - 15:06:40 +0000)
    U-Boot 2023.04-ti-gf9b966c67473 (Feb 01 2024 - 15:06:40 +0000)
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    29890 bytes read in 28 ms (1 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 6.1.876.1.80-Raptee-gdac315c3c15c (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.008545] Console: colour dummy device 80x25
    [    0.013150] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023833] pid_max: default: 32768 minimum: 301
    [    0.028625] LSM: Security Framework initializing
    [    0.033387] LSM support for eBPF active
    [    0.045018] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054259] spectre-v4 mitigation disabled by command-line option
    [    0.061366] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.075113] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082511] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088952] rcu: Hierarchical SRCU implementation.
    [    0.093861] rcu:     Max phase no-delay instances is 1000.
    [    0.099658] Platform MSI: msi-controller@1820000 domain created
    [    0.105874] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115156] EFI services will not be available.
    [    0.120019] smp: Bringing up secondary CPUs ...
    [    0.125461] Detected VIPT I-cache on CPU1
    [    0.125587] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125605] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125672] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125823] smp: Brought up 1 node, 2 CPUs
    [    0.155236] SMP: Total of 2 processors activated.
    [    0.160050] CPU features: detected: 32-bit EL0 Support
    [    0.165333] CPU features: detected: CRC32 instructions
    [    0.170656] CPU: All CPU(s) started at EL2
    [    0.174842] alternatives: applying system-wide alternatives
    [    0.182820] devtmpfs: initialized
    [    0.192057] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.202085] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.214903] pinctrl core: initialized pinctrl subsystem
    [    0.221057] DMI not present or invalid.
    [    0.225779] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233263] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240686] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.248775] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.256965] audit: initializing netlink subsys (disabled)
    [    0.262819] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263370] thermal_sys: Registered thermal governor 'step_wise'
    [    0.270763] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.277122] cpuidle: using governor menu
    [    0.287998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.295005] ASID allocator initialised with 65536 entries
    [    0.306138] KASLR disabled due to lack of seed
    [    0.318703] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.325719] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.332149] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.339158] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.345567] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.352507] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.358915] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.365855] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.375892] iommu: Default domain type: Translated
    [    0.380970] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.387825] SCSI subsystem initialized
    [    0.392105] usbcore: registered new interface driver usbfs
    [    0.397761] usbcore: registered new interface driver hub
    [    0.403236] usbcore: registered new device driver usb
    [    0.408755] pps_core: LinuxPPS API ver. 1 registered
    [    0.413835] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.423193] PTP clock support registered
    [    0.427314] EDAC MC: Ver: 3.0.0
    [    0.431514] FPGA manager framework
    [    0.435090] Advanced Linux Sound Architecture Driver Initialized.
    [    0.442564] clocksource: Switched to clocksource arch_sys_counter
    [    0.449269] VFS: Disk quotas dquot_6.6.0
    [    0.453373] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.467025] NET: Registered PF_INET protocol family
    [    0.472378] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.481740] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.490588] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.498532] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.506752] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.514882] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.521824] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.528751] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.536317] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.542779] RPC: Registered named UNIX socket transport module.
    [    0.548880] RPC: Registered udp transport module.
    [    0.553689] RPC: Registered tcp transport module.
    [    0.558502] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.565093] NET: Registered PF_XDP protocol family
    [    0.570006] PCI: CLS 0 bytes, default 64
    [    0.574833] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.584820] Initialise system trusted keyrings
    [    0.589699] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.601164] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.607939] NFS: Registering the id_resolver key type
    [    0.613173] Key type id_resolver registered
    [    0.617468] Key type id_legacy registered
    [    0.621630] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.628484] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.671039] NET: Registered PF_ALG protocol family
    [    0.675952] Key type asymmetric registered
    [    0.680139] Asymmetric key parser 'x509' registered
    [    0.685195] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.693023] io scheduler mq-deadline registered
    [    0.697666] io scheduler kyber registered
    [    0.703940] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.711109] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.718962] ti-bcdma 485c0100.dma-controller: No compatible SoC found
    [    0.725708] ti-pktdma 485c0000.dma-controller: No compatible SoC found
    [    0.735957] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.752034] loop: module loaded
    [    0.756181] megasas: 07.719.03.00-rc1
    [    0.762935] tun: Universal TUN/TAP device driver, 1.6
    [    0.768732] VFIO - User Level meta-driver version: 0.3
    [    0.774715] usbcore: registered new interface driver usb-storage
    [    0.780970] usbcore: registered new interface driver usbserial_generic
    [    0.787667] usbserial: USB Serial support registered for generic
    [    0.793843] usbcore: registered new interface driver cp210x
    [    0.799562] usbserial: USB Serial support registered for cp210x
    [    0.806293] i2c_dev: i2c /dev entries driver
    [    0.810736] usbcore: registered new interface driver i2c-tiny-usb
    [    0.817672] sdhci: Secure Digital Host Controller Interface driver
    [    0.824004] sdhci: Copyright(c) Pierre Ossman
    [    0.828586] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.834812] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.841083] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.847952] usbcore: registered new interface driver usbhid
    [    0.853658] usbhid: USB HID core driver
    [    0.858321] optee: probing for conduit method.
    [    0.862912] optee: revision 4.1 (012cdca4)
    [    0.863316] optee: dynamic shared memory is enabled
    [    0.872947] optee: initialized driver
    [    0.877654] usbcore: registered new interface driver snd-usb-audio
    [    0.884695] Initializing XFRM netlink socket
    [    0.889115] NET: Registered PF_PACKET protocol family
    [    0.894379] Key type dns_resolver registered
    [    0.899608] registered taskstats version 1
    [    0.903864] Loading compiled-in X.509 certificates
    [    0.917377] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.931394] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.948210] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    0.958165] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.964468] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.973777] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.983065] omap8250 2800000.serial: failed to get alias
    [    0.989958] mmc1: CQHCI version 5.10
    [    1.030576] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.072415] mmc1: new high speed SDXC card at address 0001
    [    1.079075] mmcblk1: mmc1:0001 SD 58.2 GiB
    [    1.087326]  mmcblk1: p1 p2
    [    1.156937] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.167832] ALSA device list:
    [    1.170884]   No soundcards found.
    [    1.174463] Warning: unable to open an initial console.
    [    1.804327] EXT4-fs (mmcblk1p2): recovery complete
    [    1.812804] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.821662] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.830334] devtmpfs: mounted
    [    1.836188] Freeing unused kernel memory: 3136K
    [    1.841088] Run /sbin/init as init process
    [    3.687136] systemd[1]: System time before build time, advancing clock.
    [    3.962360] NET: Registered PF_INET6 protocol family
    [    3.968931] Segment Routing with IPv6
    [    3.972773] In-situ OAM (IOAM) with IPv6
    [    4.228933] systemd[1]: systemd 255.4^ running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    4.261574] systemd[1]: Detected architecture arm64.
    [    4.274280] systemd[1]: Hostname set to <am62xx-evm>.
    [    5.343047] systemd[1]: Queued start job for default target Multi-User System.
    [    5.384154] systemd[1]: Created slice Slice /system/getty.
    [    5.392742] systemd[1]: Created slice Slice /system/modprobe.
    [    5.400980] systemd[1]: Created slice Slice /system/serial-getty.
    [    5.408895] systemd[1]: Created slice User and Session Slice.
    [    5.415467] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    5.423932] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.431974] systemd[1]: Reached target Path Units.
    [    5.437008] systemd[1]: Reached target Remote File Systems.
    [    5.442812] systemd[1]: Reached target Slice Units.
    [    5.447903] systemd[1]: Reached target Swaps.
    [    5.462727] systemd[1]: Listening on Process Core Dump Socket.
    [    5.469533] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.478011] systemd[1]: Listening on Journal Audit Socket.
    [    5.484664] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.491610] systemd[1]: Listening on Journal Socket.
    [    5.497879] systemd[1]: Listening on Network Service Netlink Socket.
    [    5.508496] systemd[1]: Listening on udev Control Socket.
    [    5.515005] systemd[1]: Listening on udev Kernel Socket.
    [    5.521428] systemd[1]: Listening on User Database Manager Socket.
    [    5.555262] systemd[1]: Mounting Huge Pages File System...
    [    5.567380] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.580957] systemd[1]: Mounting Kernel Debug File System...
    [    5.604495] systemd[1]: Mounting Kernel Trace File System...
    [    5.651395] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.690371] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.704842] systemd[1]: Starting Load Kernel Module configfs...
    [    5.740705] systemd[1]: Starting Load Kernel Module drm...
    [    5.795265] systemd[1]: Starting Load Kernel Module fuse...
    [    5.807784] systemd[1]: Starting SELinux autorelabel service loading...
    [    5.847893] systemd[1]: Starting SELinux init for /dev service loading...
    [    5.859406] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.884750] systemd[1]: Starting Journal Service...
    [    5.985538] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    6.022431] systemd[1]: Starting Generate network units from Kernel command line...
    [    6.036139] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.051029] systemd[1]: Starting Apply Kernel Variables...
    [    6.061829] fuse: init (API version 7.37)
    [    6.074084] systemd[1]: Starting Coldplug All udev Devices...
    [    6.106383] systemd[1]: Mounted Huge Pages File System.
    [    6.117280] systemd[1]: Mounted POSIX Message Queue File System.
    [    6.143796] systemd[1]: Mounted Kernel Debug File System.
    [    6.177600] systemd[1]: Mounted Kernel Trace File System.
    [    6.199430] systemd[1]: Mounted Temporary Directory /tmp.
    [    6.210740] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    6.215227] systemd[1]: Finished Create List of Static Device Nodes.
    [    6.230260] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    6.240208] systemd[1]: Finished Load Kernel Module configfs.
    [    6.248568] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    6.256986] systemd[1]: Finished Load Kernel Module drm.
    [    6.265614] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    6.265700] systemd-journald[147]: Collecting audit messages is enabled.
    [    6.274351] systemd[1]: Finished Load Kernel Module fuse.
    [    6.285647] audit: type=1130 audit(1706800002.592:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.287499] systemd[1]: Finished Generate network units from Kernel command line.
    [    6.304901] audit: type=1131 audit(1706800002.592:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.331931] audit: type=1130 audit(1706800002.640:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.333782] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    6.359827] audit: type=1130 audit(1706800002.668:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.361662] systemd[1]: Reached target Preparation for Network.
    [    6.419263] systemd[1]: Mounting FUSE Control File System...
    [    6.441533] systemd[1]: Mounting Kernel Configuration File System...
    [    6.534397] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
    [    6.567815] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
    [    6.584242] systemd[1]: Started Journal Service.
    [    6.600741] audit: type=1130 audit(1706800002.908:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.658914] audit: type=1130 audit(1706800002.964:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-labeldev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.678980] audit: type=1131 audit(1706800002.964:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-labeldev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.698919] audit: type=1130 audit(1706800002.988:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.720537] audit: type=1131 audit(1706800002.988:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.745308] audit: type=1130 audit(1706800003.008:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.913926] systemd-journald[147]: Received client request to flush runtime journal.
    [    8.306644] random: crng init done
    [    9.562456] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    9.589847] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.597378] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    9.606347] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    9.615898] cfg80211: failed to load regulatory.db
    [   19.331375] platform regulator-4: deferred probe pending
    [   19.336854] platform 40900000.crypto: deferred probe pending
    Modifed Device tree
    /dts-v1/;
    		aliases {
    				gpio2 = &mcu_gpio0;
    				i2c0 = &main_i2c0;
    				i2c1 = &main_i2c1;
    				i2c2 = &main_i2c2;
    				i2c3 = &main_i2c3;
    				i2c4 = &wkup_i2c0;
    				i2c5 = &mcu_i2c0;
    				mmc0 = &sdhci0;
    				mmc1 = &sdhci1;
    				mmc2 = &sdhci2;
    	opp-table {
    		opp-1400000000 {
    	chosen {
    	cpus {
    	memory@80000000 {
    		/* 2G RAM */
    	reserved-memory {
    		#size-cells = <2>;
    		ranges;
    		linux,cma {
    			reusable;
    			linux,cma-default;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    			no-map;
    		regulator-boot-on;
    		regulator-boot-on;
    		regulator-boot-on;
    		/* TPS22918DBVR */
    		enable-active-high;
    		regulator-boot-on;
    			 <3300000 0x1>;
    		regulator-boot-on;
    		regulator-boot-on;
    &cluster0 {
    &main_pmx0 {
    &mcu_pmx0 {
    &oc_sram {
    &main_uart0 {
    &main_uart1 {
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_i2c0 {
    	status = "okay";
    	tps65219: pmic@30 {
    		reg = <0x30>;
    		ti,power-button;
    		regulators {
    			buck1_reg: buck1 {
    				regulator-boot-on;
    			buck2_reg: buck2 {
    				regulator-boot-on;
    			buck3_reg: buck3 {
    				regulator-boot-on;
    			ldo1_reg: ldo1 {
    				regulator-boot-on;
    			ldo2_reg: ldo2 {
    				regulator-boot-on;
    			ldo3_reg: ldo3 {
    				regulator-boot-on;
    			ldo4_reg: ldo4 {
    				regulator-boot-on;
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_gpio_intr {
    	status = "okay";
    &main_gpio0 {
    	status = "okay";
    &main_gpio1 {
    	status = "okay";
    &sdhci0 {
    &sdhci1 {
    	/* SD/MMC */
    	status = "okay";
    	disable-wp;
    &sdhci2 {
    &fss {
    &ospi0 {
    &main_conf {
    &inta_main_dmss {
    	status = "okay";
    &main_bcdma {
    	status = "okay";
    &main_pktdma {
    	status = "okay";
    &cpsw3g {
    &mcu_uart0 {
    &mcu_i2c0 {
    &mcu_gpio_intr {
    &mcu_gpio0 {
    &wkup_conf {
    &chipid {
    &wkup_uart0 {
    &wkup_i2c0 {
    &hwspinlock {
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
  • Please enable node '&wkup_conf' and '&chipid' to solve the crypto deferred probe issue.
  • Hi Bin,
    Please find the console boot log
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 15:06:40, Feb  1 2024
    SPL initial stack usage: 1904 bytes
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@22: Error reading output register
    SoC:   AM62X SR1.0 HS-FS
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -1
    DRAM:  2 GiB
    Core:  72 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    29939 bytes read in 28 ms (1 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008fef5000, end 000000008fffffff ... OK
    Working FDT set to 8fef5000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.876.1.80-Raptee-g511706ca8328 (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.000000] Machine model: Texas Instruments AM625 Generic
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009cafffff]
    [    0.000000]   node   0: [mem 0x000000009cb00000-0x000000009d9fffff]
    [    0.000000]   node   0: [mem 0x000000009da00000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a01fffff]
    [    0.000000]   node   0: [mem 0x00000000a0200000-0x00000000a0ffffff]
    [    0.000000]   node   0: [mem 0x00000000a1000000-0x00000000a103ffff]
    [    0.000000]   node   0: [mem 0x00000000a1040000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000fffeffff]
    [    0.000000]   node   0: [mem 0x00000000ffff0000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 29 pages/cpu s78056 r8192 d32536 u118784
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: kernel page table isolation forced OFF by mitigations=off
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=07e1c071-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1849776K/2097152K available (13312K kernel code, 2204K rwdata, 4808K rodata, 3136K init, 475K bss, 116304K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] trace event string verifier disabled
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000000800d0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000800e0000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000003] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008570] Console: colour dummy device 80x25
    [    0.013182] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023865] pid_max: default: 32768 minimum: 301
    [    0.028658] LSM: Security Framework initializing
    [    0.033422] LSM support for eBPF active
    [    0.037462] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045049] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054292] spectre-v4 mitigation disabled by command-line option
    [    0.061390] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068822] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075130] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082529] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088979] rcu: Hierarchical SRCU implementation.
    [    0.093888] rcu:     Max phase no-delay instances is 1000.
    [    0.099689] Platform MSI: msi-controller@1820000 domain created
    [    0.105910] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115194] EFI services will not be available.
    [    0.120068] smp: Bringing up secondary CPUs ...
    [    0.125502] Detected VIPT I-cache on CPU1
    [    0.125632] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125656] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125720] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125871] smp: Brought up 1 node, 2 CPUs
    [    0.155288] SMP: Total of 2 processors activated.
    [    0.160102] CPU features: detected: 32-bit EL0 Support
    [    0.165384] CPU features: detected: CRC32 instructions
    [    0.170701] CPU: All CPU(s) started at EL2
    [    0.174889] alternatives: applying system-wide alternatives
    [    0.183014] devtmpfs: initialized
    [    0.192322] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.202350] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.215178] pinctrl core: initialized pinctrl subsystem
    [    0.221345] DMI not present or invalid.
    [    0.226084] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233543] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240967] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.249059] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.257245] audit: initializing netlink subsys (disabled)
    [    0.263090] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263699] thermal_sys: Registered thermal governor 'step_wise'
    [    0.271039] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.277357] cpuidle: using governor menu
    [    0.288228] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.295232] ASID allocator initialised with 65536 entries
    [    0.306695] KASLR disabled due to lack of seed
    [    0.319399] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.326400] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.332878] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.339822] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.346233] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.353173] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.359581] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.366520] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.374944] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.385559] iommu: Default domain type: Translated
    [    0.390657] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.397449] SCSI subsystem initialized
    [    0.401737] usbcore: registered new interface driver usbfs
    [    0.407401] usbcore: registered new interface driver hub
    [    0.412876] usbcore: registered new device driver usb
    [    0.418389] pps_core: LinuxPPS API ver. 1 registered
    [    0.423484] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.432842] PTP clock support registered
    [    0.436954] EDAC MC: Ver: 3.0.0
    [    0.441195] FPGA manager framework
    [    0.444766] Advanced Linux Sound Architecture Driver Initialized.
    [    0.452241] clocksource: Switched to clocksource arch_sys_counter
    [    0.458970] VFS: Disk quotas dquot_6.6.0
    [    0.463048] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.476612] NET: Registered PF_INET protocol family
    [    0.481964] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.491351] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.500180] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.508118] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.516343] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.524482] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.531423] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.538354] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.545918] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.552414] RPC: Registered named UNIX socket transport module.
    [    0.558502] RPC: Registered udp transport module.
    [    0.563310] RPC: Registered tcp transport module.
    [    0.568120] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.574710] NET: Registered PF_XDP protocol family
    [    0.579638] PCI: CLS 0 bytes, default 64
    [    0.584469] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.594467] Initialise system trusted keyrings
    [    0.599368] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.610887] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.617629] NFS: Registering the id_resolver key type
    [    0.622881] Key type id_resolver registered
    [    0.627182] Key type id_legacy registered
    [    0.631345] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.638205] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.680777] NET: Registered PF_ALG protocol family
    [    0.685698] Key type asymmetric registered
    [    0.689885] Asymmetric key parser 'x509' registered
    [    0.694944] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.702775] io scheduler mq-deadline registered
    [    0.707423] io scheduler kyber registered
    [    0.713712] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.720774] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.732370] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.748519] loop: module loaded
    [    0.752642] megasas: 07.719.03.00-rc1
    [    0.759378] tun: Universal TUN/TAP device driver, 1.6
    [    0.765202] VFIO - User Level meta-driver version: 0.3
    [    0.771185] usbcore: registered new interface driver usb-storage
    [    0.777458] usbcore: registered new interface driver usbserial_generic
    [    0.784159] usbserial: USB Serial support registered for generic
    [    0.790325] usbcore: registered new interface driver cp210x
    [    0.796045] usbserial: USB Serial support registered for cp210x
    [    0.802780] i2c_dev: i2c /dev entries driver
    [    0.807220] usbcore: registered new interface driver i2c-tiny-usb
    [    0.814183] sdhci: Secure Digital Host Controller Interface driver
    [    0.820524] sdhci: Copyright(c) Pierre Ossman
    [    0.825107] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.831324] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.837596] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.844541] usbcore: registered new interface driver usbhid
    [    0.850241] usbhid: USB HID core driver
    [    0.854902] optee: probing for conduit method.
    [    0.859494] optee: revision 4.1 (012cdca4)
    [    0.859888] optee: dynamic shared memory is enabled
    [    0.869523] optee: initialized driver
    [    0.874238] usbcore: registered new interface driver snd-usb-audio
    [    0.881249] Initializing XFRM netlink socket
    [    0.885681] NET: Registered PF_PACKET protocol family
    [    0.890954] Key type dns_resolver registered
    [    0.896133] registered taskstats version 1
    [    0.900423] Loading compiled-in X.509 certificates
    [    0.914411] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.929276] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.945206] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    0.955132] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.961429] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.970789] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.979827] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    0.988278] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    0.999803] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    1.010501] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.020780] omap8250 2800000.serial: failed to get alias
    [    1.146083] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.156986] ALSA device list:
    [    1.160018]   No soundcards found.
    [    1.163609] Warning: unable to open an initial console.
    [    1.169087] Waiting for root device PARTUUID=07e1c071-02...
    [   11.396815] platform regulator-4: deferred probe pending
    Device tree
    // SPDX-License-Identifier: GPL-2.0
     * AM625 Minimal dts file
     * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include <dt-bindings/gpio/gpio.h>
    #include "k3-am625.dtsi"
    	compatible =  "ti,am625-generic", "ti,am625";
    	model = "Texas Instruments AM625 Generic";
    		aliases {
    				gpio0 = &main_gpio0;
    				gpio1 = &main_gpio1;
    				gpio2 = &mcu_gpio0;
    				i2c0 = &main_i2c0;
    				i2c1 = &main_i2c1;
    				i2c2 = &main_i2c2;
    				i2c3 = &main_i2c3;
    				i2c4 = &wkup_i2c0;
    				i2c5 = &mcu_i2c0;
    				mmc0 = &sdhci0;
    				mmc1 = &sdhci1;
    				mmc2 = &sdhci2;
    	opp-table {
    		/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
    		opp-1400000000 {
    			opp-hz = /bits/ 64 <1400000000>;
    			opp-supported-hw = <0x01 0x0004>;
    			clock-latency-ns = <6000000>;
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    	cpus {
    		/delete-node/ cpu@2;
    		/delete-node/ cpu@3;
    	memory@80000000 {
    		device_type = "memory";
    		/* 2G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
    	reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		/* global cma region */
    		linux,cma {
    			compatible = "shared-dma-pool";
    			reusable;
    			size = <0x00 0x8000000>;
    			linux,cma-default;
    		mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
    			reg = <0x00 0x9cb00000 0x00 0x100000>;
    			no-map;
    		mcu_m4fss_memory_region: m4f-memory@9cc00000 {
    			reg = <0x00 0x9cc00000 0x00 0xe00000>;
    			no-map;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			alignment = <0x1000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    			no-map;
    		main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
    			reg = <0x00 0xa0000000 0x00 0x200000>;
    			no-map;
    		lpm_ctx_ddr: lpm-memory@a1000000 {
    			reg = <0x00 0xa1000000 0x00 0x40000>;
    			no-map;
    	vmain_pd: regulator-0 {
    		/* TPS65988 PD CONTROLLER OUTPUT */
    		compatible = "regulator-fixed";
    		regulator-name = "vmain_pd";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vcc_5v0: regulator-1 {
    		/* Output of LM34936 */
    		regulator-name = "vcc_5v0";
    		vin-supply = <&vmain_pd>;
    		regulator-boot-on;
    	vcc_3v3_sys: regulator-2 {
    		/* output of LM61460-Q1 */
    		regulator-name = "vcc_3v3_sys";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		regulator-boot-on;
    	vdd_mmc1: regulator-3 {
    		/* TPS22918DBVR */
    		regulator-name = "vdd_mmc1";
    		pinctrl-names = "default";
    		pinctrl-0 = <&vdd_sd_dv_pins_default>;
    		enable-active-high;
    		vin-supply = <&vcc_3v3_sys>;
    		gpio = <&main_gpio0 76 GPIO_ACTIVE_HIGH>;
    	vdd_sd_dv: regulator-4 {
    		/* Output of TLV71033 */
    		compatible = "regulator-gpio";
    		regulator-name = "tlv71033";
    		regulator-min-microvolt = <1800000>;
    		regulator-boot-on;
    		vin-supply = <&ldo1_reg>;
    		gpios = <&main_gpio0 40 GPIO_ACTIVE_HIGH>;
    		states = <1800000 0x0>,
    			 <3300000 0x1>;
    	vcc_1v8: regulator-5 {
    		/* output of TPS6282518DMQ */
    		regulator-name = "vcc_1v8";
    		regulator-max-microvolt = <1800000>;
    		regulator-boot-on;
    	vdd_core: regulator-8 {
    		/* output of TPS62826DMQ */
    		regulator-name = "vdd_core";
    		regulator-min-microvolt = <850000>;
    		regulator-max-microvolt = <850000>;
    		regulator-boot-on;
    &cluster0 {
    	/delete-node/ core2;
    	/delete-node/ core3;
    &main_pmx0 {
    	main_uart0_pins_default: main-uart0-pins-default {
    		pinctrl-single,pins = <
    			AM62X_IOPAD(0x1d0, PIN_INPUT, 0) /* (A15) UART0_CTSn */
    			AM62X_IOPAD(0x1d4, PIN_OUTPUT, 0) /* (B15) UART0_RTSn */
    			AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
    			AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    	main_uart1_pins_default: main-uart1-pins-default {
    			AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */
    			AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */
    			AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */
    			AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */
    	vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
    			AM62X_IOPAD(0x00a4, PIN_OUTPUT, 7) /* (J19) GPMC0_DIR.GPIO0_40 */
    			AM62X_IOPAD(0x0138, PIN_INPUT, 7) /* (AA19) RGMII1_TD1.GPIO0_76 */
    	main_mmc1_pins_default: main-mmc1-pins-default {
    			AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */
    			AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */
    			AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */
    			AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */
    			AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */
    			AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */
    			AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */
    	pmic_irq_pins_default: pmic-irq-pins-default {
    			AM62X_IOPAD(0x01f4, PIN_INPUT, 7) /* (B16) EXTINTn.GPIO1_31 */
    	local_i2c_pins_default: local-i2c-pins-default {
    			AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (E12) I2C0_SCL */
    			AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (D14) I2C0_SDA */
    &mcu_pmx0 {
    	wkup_uart0_pins_default: wkup-uart0-pins-default {
    			AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6) WKUP_UART0_CTSn */
    			AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */
    			AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4) WKUP_UART0_RXD */
    			AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */
    &oc_sram {
    	status = "disabled";
    &main_uart0 {
    	pinctrl-0 = <&main_uart0_pins_default>;
    &main_uart1 {
            pinctrl-0 = <&main_uart1_pins_default>;
            /* Main UART1 is used by TIFS firmware */
    	status = "reserved";
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &main_i2c0 {
    	pinctrl-0 = <&local_i2c_pins_default>;
    	clock-frequency = <400000>;
    	status = "okay";
    	tps65219: pmic@30 {
    		compatible = "ti,tps65219";
    		reg = <0x30>;
    		buck1-supply = <&vmain_pd>;
    		buck2-supply = <&vmain_pd>;
    		buck3-supply = <&vmain_pd>;
    		ldo1-supply = <&vcc_3v3_sys>;
    		ldo2-supply = <&buck2_reg>;
    		ldo3-supply = <&vcc_3v3_sys>;
    		ldo4-supply = <&vcc_3v3_sys>;
    		pinctrl-0 = <&pmic_irq_pins_default>;
    		interrupt-parent = <&gic500>;
    		interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-controller;
    		#interrupt-cells = <1>;
    		system-power-controller;
    		ti,power-button;
    		regulators {
    			buck1_reg: buck1 {
    				regulator-name = "VDD_CORE";
    				regulator-boot-on;
    			buck2_reg: buck2 {
    				regulator-name = "VDD_1V8";
    				regulator-boot-on;
    			buck3_reg: buck3 {
    				regulator-name = "VDD_1V2";
    				regulator-min-microvolt = <1200000>;
    				regulator-max-microvolt = <1200000>;
    				regulator-boot-on;
    			ldo1_reg: ldo1 {
    				 * Regulator is left as is unused, vdd_sd
    				 * is controlled via GPIO with bypass config
    				 * as per the NVM configuration
    				regulator-name = "VDD_SD_3V3";
    				regulator-allow-bypass;
    				regulator-boot-on;
    			ldo2_reg: ldo2 {
    				regulator-name = "VDDA_0V85";
    				regulator-boot-on;
    			ldo3_reg: ldo3 {
    				regulator-name = "VDDA_1V8";
    				regulator-boot-on;
    			ldo4_reg: ldo4 {
    				regulator-name = "VDD_2V5";
    				regulator-min-microvolt = <2500000>;
    				regulator-max-microvolt = <2500000>;
    				regulator-boot-on;
    &main_i2c1 {
    &main_i2c2 {
    &main_i2c3 {
    &main_gpio_intr {
    	status = "okay";
    &main_gpio0 {
    	status = "okay";
    &main_gpio1 {
    	status = "okay";
    &sdhci0 {
    &sdhci1 {
    	/* SD/MMC */
    	vmmc-supply = <&vdd_mmc1>;
    	vqmmc-supply = <&vdd_sd_dv>;
    	status = "okay";
    	pinctrl-0 = <&main_mmc1_pins_default>;
    	disable-wp;
    &sdhci2 {
    &fss {
    &ospi0 {
    &main_conf {
    &inta_main_dmss {
    	status = "okay";
    &main_bcdma {
    	status = "okay";
    &main_pktdma {
    	status = "okay";
    &cpsw3g {
    /* MCU periperhals */
    &mcu_uart0 {
    &mcu_i2c0 {
    &mcu_gpio_intr {
    &mcu_gpio0 {
    /* WKUP periperhals */
    &wkup_conf {
    	status = "okay";
    &chipid {
    	status = "okay";
    /* wkup_uart0 is reserved for firmware usage */
    &wkup_uart0 {
            pinctrl-0 = <&wkup_uart0_pins_default>;
            /* WKUP UART0 is used by DM firmware */
    &wkup_i2c0 {
    &hwspinlock {
    &mailbox0_cluster0 {
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
  • Please follow the device tree or debug the kernel driver if necessary to understand what is missing for regulator-4 probe.
  • Hi Bin,
    Kindly suggest which device tree to follow
  • Start from your board dts file and follow the node/property dependencies.
  • Hi Bin,
    Resloved the regulator probe by following the k3-am625-sk.dts &
    git.ti.com/.../k3-am62-main.dtsi
    Please find the new console boot log
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    24146432 bytes read in 1005 ms (22.9 MiB/s)
    30123 bytes read in 27 ms (1.1 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 6.1.876.1.80-Raptee-geb628be413b1 (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008553] Console: colour dummy device 80x25
    [    0.013166] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023855] pid_max: default: 32768 minimum: 301
    [    0.028654] LSM: Security Framework initializing
    [    0.033417] LSM support for eBPF active
    [    0.037450] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045035] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054271] spectre-v4 mitigation disabled by command-line option
    [    0.061383] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068814] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075126] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.088974] rcu: Hierarchical SRCU implementation.
    [    0.093890] rcu:     Max phase no-delay instances is 1000.
    [    0.099694] Platform MSI: msi-controller@1820000 domain created
    [    0.105916] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115198] EFI services will not be available.
    [    0.120081] smp: Bringing up secondary CPUs ...
    [    0.125521] Detected VIPT I-cache on CPU1
    [    0.125654] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125673] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125743] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125885] smp: Brought up 1 node, 2 CPUs
    [    0.155299] SMP: Total of 2 processors activated.
    [    0.160113] CPU features: detected: 32-bit EL0 Support
    [    0.165390] CPU features: detected: CRC32 instructions
    [    0.170705] CPU: All CPU(s) started at EL2
    [    0.174896] alternatives: applying system-wide alternatives
    [    0.182765] devtmpfs: initialized
    [    0.192005] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.202032] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.214918] pinctrl core: initialized pinctrl subsystem
    [    0.221055] DMI not present or invalid.
    [    0.225797] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233194] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240609] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.248685] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.256866] audit: initializing netlink subsys (disabled)
    [    0.262722] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263331] thermal_sys: Registered thermal governor 'step_wise'
    [    0.270674] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.277035] cpuidle: using governor menu
    [    0.287895] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.294900] ASID allocator initialised with 65536 entries
    [    0.306331] KASLR disabled due to lack of seed
    [    0.319032] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.326038] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.332515] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.339459] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.345873] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.352816] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.359224] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.366164] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.374554] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.385155] iommu: Default domain type: Translated
    [    0.390243] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.397034] SCSI subsystem initialized
    [    0.401295] usbcore: registered new interface driver usbfs
    [    0.406958] usbcore: registered new interface driver hub
    [    0.412430] usbcore: registered new device driver usb
    [    0.417952] pps_core: LinuxPPS API ver. 1 registered
    [    0.423047] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.432398] PTP clock support registered
    [    0.436510] EDAC MC: Ver: 3.0.0
    [    0.440733] FPGA manager framework
    [    0.444328] Advanced Linux Sound Architecture Driver Initialized.
    [    0.451782] clocksource: Switched to clocksource arch_sys_counter
    [    0.458507] VFS: Disk quotas dquot_6.6.0
    [    0.462582] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.476157] NET: Registered PF_INET protocol family
    [    0.481509] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.490900] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.499732] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.507689] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.515892] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.524040] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.530982] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.537907] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.545479] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.551936] RPC: Registered named UNIX socket transport module.
    [    0.558022] RPC: Registered udp transport module.
    [    0.562832] RPC: Registered tcp transport module.
    [    0.567639] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.574230] NET: Registered PF_XDP protocol family
    [    0.579142] PCI: CLS 0 bytes, default 64
    [    0.583980] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.593993] Initialise system trusted keyrings
    [    0.598876] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.610373] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.617145] NFS: Registering the id_resolver key type
    [    0.622375] Key type id_resolver registered
    [    0.626674] Key type id_legacy registered
    [    0.630846] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.637705] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.680161] NET: Registered PF_ALG protocol family
    [    0.685072] Key type asymmetric registered
    [    0.689261] Asymmetric key parser 'x509' registered
    [    0.694320] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.702162] io scheduler mq-deadline registered
    [    0.706804] io scheduler kyber registered
    [    0.713105] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.720312] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.731934] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.748078] loop: module loaded
    [    0.752221] megasas: 07.719.03.00-rc1
    [    0.758941] tun: Universal TUN/TAP device driver, 1.6
    [    0.764792] VFIO - User Level meta-driver version: 0.3
    [    0.770771] usbcore: registered new interface driver usb-storage
    [    0.777078] usbcore: registered new interface driver usbserial_generic
    [    0.783794] usbserial: USB Serial support registered for generic
    [    0.789955] usbcore: registered new interface driver cp210x
    [    0.795666] usbserial: USB Serial support registered for cp210x
    [    0.802338] i2c_dev: i2c /dev entries driver
    [    0.806776] usbcore: registered new interface driver i2c-tiny-usb
    [    0.813733] sdhci: Secure Digital Host Controller Interface driver
    [    0.820062] sdhci: Copyright(c) Pierre Ossman
    [    0.824650] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.830869] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.837153] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.844089] usbcore: registered new interface driver usbhid
    [    0.849789] usbhid: USB HID core driver
    [    0.854489] optee: probing for conduit method.
    [    0.859083] optee: revision 4.1 (012cdca4)
    [    0.859427] optee: dynamic shared memory is enabled
    [    0.869067] optee: initialized driver
    [    0.873729] usbcore: registered new interface driver snd-usb-audio
    [    0.880781] Initializing XFRM netlink socket
    [    0.885216] NET: Registered PF_PACKET protocol family
    [    0.890511] Key type dns_resolver registered
    [    0.895652] registered taskstats version 1
    [    0.899972] Loading compiled-in X.509 certificates
    [    0.914299] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.928383] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.944344] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    0.954388] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.960864] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.970370] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    0.979453] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    0.987999] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    0.999494] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    1.010187] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.020449] omap8250 2800000.serial: failed to get alias
    [    1.034734] mmc1: CQHCI version 5.10
    [    1.075816] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.118084] mmc1: new high speed SDXC card at address 0001
    [    1.125145] mmcblk1: mmc1:0001 SD 58.2 GiB
    [    1.133812]  mmcblk1: p1 p2
    [    1.143382] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.154256] ALSA device list:
    [    1.157300]   No soundcards found.
    [    1.160871] Warning: unable to open an initial console.
    [    1.412096] EXT4-fs (mmcblk1p2): recovery complete
    [    1.420514] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.429386] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.438024] devtmpfs: mounted
    [    1.444096] Freeing unused kernel memory: 3136K
    [    1.448940] Run /sbin/init as init process
    [    3.407384] systemd[1]: System time before build time, advancing clock.
    [    3.681856] NET: Registered PF_INET6 protocol family
    [    3.688362] Segment Routing with IPv6
    [    3.692196] In-situ OAM (IOAM) with IPv6
    [    3.971830] systemd[1]: systemd 255.4^ running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    4.004453] systemd[1]: Detected architecture arm64.
    [    4.041684] systemd[1]: Hostname set to <am62xx-evm>.
    [    5.132565] systemd[1]: Queued start job for default target Multi-User System.
    [    5.169302] systemd[1]: Created slice Slice /system/getty.
    [    5.178052] systemd[1]: Created slice Slice /system/modprobe.
    [    5.186231] systemd[1]: Created slice Slice /system/serial-getty.
    [    5.194139] systemd[1]: Created slice User and Session Slice.
    [    5.200640] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    5.209112] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.217187] systemd[1]: Reached target Path Units.
    [    5.222224] systemd[1]: Reached target Remote File Systems.
    [    5.228031] systemd[1]: Reached target Slice Units.
    [    5.233140] systemd[1]: Reached target Swaps.
    [    5.247993] systemd[1]: Listening on Process Core Dump Socket.
    [    5.254676] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.263143] systemd[1]: Listening on Journal Audit Socket.
    [    5.269814] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.276802] systemd[1]: Listening on Journal Socket.
    [    5.283049] systemd[1]: Listening on Network Service Netlink Socket.
    [    5.293037] systemd[1]: Listening on udev Control Socket.
    [    5.299480] systemd[1]: Listening on udev Kernel Socket.
    [    5.305746] systemd[1]: Listening on User Database Manager Socket.
    [    5.344507] systemd[1]: Mounting Huge Pages File System...
    [    5.356771] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.369754] systemd[1]: Mounting Kernel Debug File System...
    [    5.414557] systemd[1]: Mounting Kernel Trace File System...
    [    5.445056] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.462756] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.489780] systemd[1]: Starting Load Kernel Module configfs...
    [    5.537969] systemd[1]: Starting Load Kernel Module drm...
    [    5.559092] systemd[1]: Starting Load Kernel Module fuse...
    [    5.588530] systemd[1]: Starting SELinux autorelabel service loading...
    [    5.608185] systemd[1]: Starting SELinux init for /dev service loading...
    [    5.620830] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.662492] systemd[1]: Starting Journal Service...
    [    5.671413] fuse: init (API version 7.37)
    [    5.733692] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    5.769050] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.783735] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.797794] systemd[1]: Starting Apply Kernel Variables...
    [    5.817263] systemd[1]: Starting Coldplug All udev Devices...
    [    5.879193] systemd[1]: Mounted Huge Pages File System.
    [    5.886162] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.913655] systemd[1]: Mounted Kernel Debug File System.
    [    5.937606] systemd[1]: Mounted Kernel Trace File System.
    [    5.949509] systemd[1]: Mounted Temporary Directory /tmp.
    [    5.967456] systemd[1]: Finished Create List of Static Device Nodes.
    [    5.969108] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    5.986120] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    5.994519] systemd[1]: Finished Load Kernel Module configfs.
    [    6.005679] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    6.013574] systemd[1]: Finished Load Kernel Module drm.
    [    6.021069] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    6.029661] systemd[1]: Finished Load Kernel Module fuse.
    [    6.037967] systemd[1]: Finished Generate network units from Kernel command line.
    [    6.047756] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    6.057828] systemd[1]: Reached target Preparation for Network.
    [    6.080742] systemd[1]: Mounting FUSE Control File System...
    [    6.092972] systemd[1]: Mounting Kernel Configuration File System...
    [    6.153545] systemd-journald[148]: Collecting audit messages is enabled.
    [    6.258637] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
    [    6.309174] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
    [    6.326914] systemd[1]: Started Journal Service.
    [    6.340918] audit: type=1130 audit(1706800002.932:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.435336] audit: type=1130 audit(1706800003.024:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.544675] audit: type=1130 audit(1706800003.136:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.575368] audit: type=1131 audit(1706800003.144:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-autorelabel comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.609053] audit: type=1130 audit(1706800003.156:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-labeldev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.630261] audit: type=1131 audit(1706800003.156:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=selinux-labeldev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.680398] audit: type=1130 audit(1706800003.272:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev-early comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.727386] systemd-journald[148]: Received client request to flush runtime journal.
    [    6.791136] audit: type=1130 audit(1706800003.380:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.858819] audit: type=1130 audit(1706800003.448:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.897074] audit: type=1334 audit(1706800003.488:11): prog-id=6 op=LOAD
    [    8.311846] random: crng init done
    [    9.459082] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    9.535457] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.543381] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    9.553500] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    9.568298] cfg80211: failed to load regulatory.db
    Still We are stuck at the kernel boot.
  • I am not sure what else causes this booting issue, but your boot log has:
    So please add main_uart0 to the aliases section in your kernel board dts file.
  • Hi Bin,
    We got the linux booted up after making the suggested changes
    Boot Console log
    U-Boot SPL 2023.04-ti-gf9b966c67473 (Feb 01 2024 - 15:06:40 +0000)
    U-Boot 2023.04-ti-gf9b966c67473 (Feb 01 2024 - 15:06:40 +0000)
    Board:  rev
    DRAM:  2 GiB
    In:    serial
    Out:   serial
    Err:   serial
    24146432 bytes read in 1004 ms (22.9 MiB/s)
    28715 bytes read in 28 ms (1001 KiB/s)
    ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
    Starting kernel ...
    [    0.000000] Linux version 6.1.876.1.80-Raptee-g413b690a2464 (oe-user@oe-host) (aarch64-agl-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT Thu Feb  1 15:06:40 UTC 2024
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
    [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009d9fffff]
    [    0.000000]   node   0: [mem 0x000000009da00000-0x000000009dafffff]
    [    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000fffc9fff]
    [    0.000000]   node   0: [mem 0x00000000fffca000-0x00000000ffffffff]
    [    0.000000] Memory: 1835880K/2097152K available (13312K kernel code, 2204K rwdata, 4808K rodata, 3136K init, 475K bss, 130200K reserved, 131072K cma-reserved)
    [    0.008550] Console: colour dummy device 80x25
    [    0.013162] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023845] pid_max: default: 32768 minimum: 301
    [    0.028646] LSM: Security Framework initializing
    [    0.033411] LSM support for eBPF active
    [    0.037445] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045031] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.054270] spectre-v4 mitigation disabled by command-line option
    [    0.061359] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.068786] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.075095] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.082491] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.088939] rcu: Hierarchical SRCU implementation.
    [    0.093853] rcu:     Max phase no-delay instances is 1000.
    [    0.099665] Platform MSI: msi-controller@1820000 domain created
    [    0.105864] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.115134] EFI services will not be available.
    [    0.120002] smp: Bringing up secondary CPUs ...
    [    0.125448] Detected VIPT I-cache on CPU1
    [    0.125579] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.125597] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
    [    0.125667] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.125810] smp: Brought up 1 node, 2 CPUs
    [    0.155232] SMP: Total of 2 processors activated.
    [    0.160045] CPU features: detected: 32-bit EL0 Support
    [    0.165326] CPU features: detected: CRC32 instructions
    [    0.170644] CPU: All CPU(s) started at EL2
    [    0.174832] alternatives: applying system-wide alternatives
    [    0.182812] devtmpfs: initialized
    [    0.191810] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.201837] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.214743] pinctrl core: initialized pinctrl subsystem
    [    0.220871] DMI not present or invalid.
    [    0.225601] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.233046] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.240468] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.248557] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.256725] audit: initializing netlink subsys (disabled)
    [    0.262570] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.263175] thermal_sys: Registered thermal governor 'step_wise'
    [    0.270520] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.276886] cpuidle: using governor menu
    [    0.287751] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.294757] ASID allocator initialised with 65536 entries
    [    0.301829] OF: /bus@f0000/serial@2800000: could not get #interrupt-cells for /bus@f0000/pinctrl@f4000
    [    0.311418] OF: /bus@f0000/serial@2800000: could not get #interrupt-cells for /bus@f0000/pinctrl@f4000
    [    0.325136] KASLR disabled due to lack of seed
    [    0.337852] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.344859] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.351334] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.358275] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.364686] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.371628] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.378036] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.384979] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.393389] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.403698] iommu: Default domain type: Translated
    [    0.408780] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.415599] SCSI subsystem initialized
    [    0.419872] usbcore: registered new interface driver usbfs
    [    0.425531] usbcore: registered new interface driver hub
    [    0.431012] usbcore: registered new device driver usb
    [    0.436529] pps_core: LinuxPPS API ver. 1 registered
    [    0.441610] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.450961] PTP clock support registered
    [    0.455064] EDAC MC: Ver: 3.0.0
    [    0.459243] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    0.466388] FPGA manager framework
    [    0.469994] Advanced Linux Sound Architecture Driver Initialized.
    [    0.477426] clocksource: Switched to clocksource arch_sys_counter
    [    0.484253] VFS: Disk quotas dquot_6.6.0
    [    0.488324] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.507523] NET: Registered PF_INET protocol family
    [    0.513089] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.522680] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.531508] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.539446] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.547675] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.555791] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.562798] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.569728] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.577295] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.583790] RPC: Registered named UNIX socket transport module.
    [    0.589920] RPC: Registered udp transport module.
    [    0.594731] RPC: Registered tcp transport module.
    [    0.599540] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.606136] NET: Registered PF_XDP protocol family
    [    0.611057] PCI: CLS 0 bytes, default 64
    [    0.616053] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.626113] Initialise system trusted keyrings
    [    0.631056] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.642545] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.649305] NFS: Registering the id_resolver key type
    [    0.654556] Key type id_resolver registered
    [    0.658856] Key type id_legacy registered
    [    0.663021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.669876] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.711772] NET: Registered PF_ALG protocol family
    [    0.716693] Key type asymmetric registered
    [    0.720882] Asymmetric key parser 'x509' registered
    [    0.725972] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.733798] io scheduler mq-deadline registered
    [    0.738443] io scheduler kyber registered
    [    0.744650] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.751071] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.762675] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.779010] loop: module loaded
    [    0.783139] megasas: 07.719.03.00-rc1
    [    0.789961] tun: Universal TUN/TAP device driver, 1.6
    [    0.795762] VFIO - User Level meta-driver version: 0.3
    [    0.801768] usbcore: registered new interface driver usb-storage
    [    0.808064] usbcore: registered new interface driver usbserial_generic
    [    0.814763] usbserial: USB Serial support registered for generic
    [    0.820932] usbcore: registered new interface driver cp210x
    [    0.826643] usbserial: USB Serial support registered for cp210x
    [    0.833358] i2c_dev: i2c /dev entries driver
    [    0.837787] usbcore: registered new interface driver i2c-tiny-usb
    [    0.844753] sdhci: Secure Digital Host Controller Interface driver
    [    0.851084] sdhci: Copyright(c) Pierre Ossman
    [    0.855671] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.861859] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.868137] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.875083] usbcore: registered new interface driver usbhid
    [    0.880786] usbhid: USB HID core driver
    [    0.885482] optee: probing for conduit method.
    [    0.890067] optee: revision 4.1 (012cdca4)
    [    0.890482] optee: dynamic shared memory is enabled
    [    0.900125] optee: initialized driver
    [    0.904826] usbcore: registered new interface driver snd-usb-audio
    [    0.911877] Initializing XFRM netlink socket
    [    0.916307] NET: Registered PF_PACKET protocol family
    [    0.921591] Key type dns_resolver registered
    [    0.926811] registered taskstats version 1
    [    0.931062] Loading compiled-in X.509 certificates
    [    0.945682] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    [    0.961339] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=13, clk=7, ret=-19
    [    0.976978] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.983030] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    0.992357] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.001401] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    1.009896] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.021320] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    1.032130] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.042320] OF: /bus@f0000/serial@2800000: could not get #interrupt-cells for /bus@f0000/pinctrl@f4000
    [    1.052459] printk: console [ttyS2] disabled
    [    1.056919] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 228, base_baud = 3000000) is a 8250
    [    1.065824] printk: console [ttyS2] enabled
    [    1.074286] printk: bootconsole [ns16550a0] disabled
    [    1.093536] mmc1: CQHCI version 5.10
    [    1.137576] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.171215] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=13, clk=7, ret=-19
    [    1.179804] mmc1: new high speed SDXC card at address 0001
    [    1.187280] ALSA device list:
    [    1.188109] mmcblk1: mmc1:0001 SD 58.2 GiB
    [    1.190304]   No soundcards found.
    [    1.197581]  mmcblk1: p1 p2
    [    1.345315] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.354091] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.362312] devtmpfs: mounted
    [    1.368017] Freeing unused kernel memory: 3136K
    [    1.372854] Run /sbin/init as init process
    [    3.334142] systemd[1]: System time before build time, advancing clock.
    [    3.608989] NET: Registered PF_INET6 protocol family
    [    3.615417] Segment Routing with IPv6
    [    3.619169] In-situ OAM (IOAM) with IPv6
    [    3.899042] systemd[1]: systemd 255.4^ running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.930891] systemd[1]: Detected architecture arm64.
    Welcome to Automotive Grade Linux 17.90.0 (ricefish)!
    [    3.984107] systemd[1]: Hostname set to <am62xx-evm>.
    [    4.037451] systemd[1]: Initializing machine ID from random generator.
    [    5.149839] systemd[1]: Queued start job for default target Multi-User System.
    [    5.186956] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    5.212037] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    5.235862] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    5.259267] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    5.282162] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    5.305934] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    5.329805] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    5.345612] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.365574] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    5.381616] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    5.408048] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    5.430284] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    5.455323] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    5.478556] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.502548] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    5.522768] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.549710] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.570499] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.594498] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    5.646133] systemd[1]: Mounting Huge Pages File System...
    [    5.690272] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.718945] systemd[1]: Mounting Kernel Debug File System...
    [    5.766347] systemd[1]: Mounting Kernel Trace File System...
    [    5.802727] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.846659] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.880099] systemd[1]: Starting Load Kernel Module configfs...
    [    5.934694] systemd[1]: Starting Load Kernel Module drm...
    [    5.967840] systemd[1]: Starting Load Kernel Module fuse...
    [    6.014924] systemd[1]: Starting SELinux autorelabel service loading...
    [    6.051589] systemd[1]: Starting SELinux init for /dev service loading...
    [    6.078103] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    6.115080] systemd[1]: Starting Journal Service...
    [    6.177100] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    6.194784] systemd[1]: Starting Generate network units from Kernel command line...
    [    6.245557] fuse: init (API version 7.37)
    [    6.254676] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.298999] systemd[1]: Starting Apply Kernel Variables...
    [    6.359584] systemd[1]: Starting Coldplug All udev Devices...
    [    6.390250] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    6.415793] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File Sy[    6.433868] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    stem.
    [    6.453106] systemd-journald[147]: Collecting audit messages is enabled.
    [    6.465218] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    6.489178] systemd[1]: Mounted Kernel Trace File System.
    [  OK  ] Mounted Kernel Trace File System.
    [    6.510980] systemd[1]: Mounted Temporary Directory /tmp.
    [  OK  ] Mounted Temporary Directory /tmp.
    [    6.539134] systemd[1]: Finished Create List of Static Device Nodes.
    [  OK  ] Finished Create List of Static Device Nodes.
    [    6.562278] audit: type=1130 audit(1706800003.224:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.563104] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [    6.602640] audit: type=1130 audit(1706800003.264:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Finished Load Kernel Module configfs.
    [    6.637864] audit: type=1130 audit(1706800003.300:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.656910] audit: type=1131 audit(1706800003.300:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Finished Load Kernel Module drm.
    [    6.693800] audit: type=1130 audit(1706800003.356:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.712538] audit: type=1131 audit(1706800003.356:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Finished Load Kernel Module fuse.
    [    6.745791] audit: type=1130 audit(1706800003.408:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.764492] audit: type=1131 audit(1706800003.408:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Finished Generate network units from Kernel command line.
    [    6.797984] audit: type=1130 audit(1706800003.460:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [    6.833968] audit: type=1130 audit(1706800003.496:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Reached target Preparation for Network.
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Finished SELinux autorelabel service loading.
    [  OK  ] Finished SELinux init for /dev service loading.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Mounted FUSE Control File System.
    [    7.172989] systemd-journald[147]: Received client request to flush runtime journal.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create System Users...
             Starting User Database Manager...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Started User Database Manager.
    [  OK  ] Finished Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting SELinux init service loading...
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished SELinux init service loading.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Load Audit Rules...
             Starting Rebuild Journal Catalog...
             Starting Network Name Resolution...
    [    9.101518] random: crng init done
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Finished Load/Save OS Random Seed.
             Starting Generated file SELinux relabeling...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Starting Network Configuration...
    [  OK  ] Finished Rebuild Journal Catalog.
    [  OK  ] Finished Load Audit Rules.
    [   10.696336] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   10.774517] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   10.786512] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   10.799660] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [   10.810214] cfg80211: failed to load regulatory.db
    [  OK  ] Finished Generated file SELinux relabeling.
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting Security Audit Logging Service...
             Starting Virtual Console Setup...
    [  OK  ] Started Security Audit Logging Service.
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Finished Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [  OK  ] Finished Update is Completed.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting D-Bus System Message Bus...
             Starting User Login Management...
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Started User Login Management.
    [  OK  ] Reached target Multi-User System.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
    Automotive Grade Linux 17.90.0 am62xx-evm ttyS2
    am62xx-evm login: root
    root@am62xx-evm:~# ls
    root@am62xx-evm:~# ifconfig
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
    root@am62xx-evm:~# htop
    -sh: htop: command not found
    root@am62xx-evm:~# lsmod
    Module                  Size  Used by
    crct10dif_ce           16384  1
    optee_rng              16384  0
    sa2ul                  36864  0
    rng_core               20480  1 optee_rng
    cfg80211              884736  0
    rfkill                 24576  2 cfg80211
    fuse                  131072  1
    drm                   561152  0
    drm_panel_orientation_quirks    28672  1 drm
    ip_tables              32768  0
    x_tables               40960  1 ip_tables
    ipv6                  479232  12
    root@am62xx-evm:~#
    Thank you.
  • Great! Thanks for the update.
